  4. Zeitplan startet nicht mehr
86 Beiträge 7 Kommentatoren 11.0k Aufrufe 4 Beobachtet
  • SMSS SMS
    @thomas-braun sagte in Zeitplan startet nicht mehr:
    sudo apt update
    alles soweit richtig bzw. i.O.?
    pi@Homee:~ $ sudo apt update
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://packages.grafana.com/oss/deb stable InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Get:8 https://repos.influxdata.com/debian bookworm InRelease [12.9 kB]
    Get:9 http://archive.raspbian.org/raspbian bookworm InRelease [15.0 kB]
    Hit:10 http://archive.raspberrypi.com/debian bookworm InRelease
    Err:9 http://archive.raspbian.org/raspbian bookworm InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
    Err:8 https://repos.influxdata.com/debian bookworm InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Reading package lists... Done
    W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    W: GPG error: http://archive.raspbian.org/raspbian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
    E: The repository 'http://archive.raspbian.org/raspbian bookworm InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    W: GPG error: https://repos.influxdata.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bookworm InRelease' is not signed.
    @sms sagte in Zeitplan startet nicht mehr:
    bei einem
    Err:9 http://ar
    kannst du davon ausgehen dass nicht ok ist
    und davon hast du einige
    SMSS 1 Antwort Letzte Antwort
    • SMSS SMS
      @codierknecht sagte in Zeitplan startet nicht mehr:
      Pending OS-Updates: 177
      und jetzt warten wir mal auf den Nächsten, der sich über die "unnötigen" und "nervigen" Update-Hinweise am Host beschwert ... 😡
      das heißt?
      CodierknechtC Offline
      Codierknecht
      @sms
      War nicht direkt an Dich adressiert.
      Aber eigentlich müsstest Du in der GUI schon längst einen Hinweis bekommen haben, dass da etliche Updates auf Installation warten.
      Das kocht aber dummerweise hier regelmäßig hoch, weil sich einige dadurch "gegängelt" fühlen.
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
        bei einem
        Err:9 http://ar
        SMSS Offline
        SMSS Offline
        SMS
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: Homee
               Icon name: computer
                  Kernel: Linux 6.6.28+rpt-rpi-v8
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         13:48:33 up 7 days, 23:14,  4 users,  load average: 0.85, 0.75, 0.82
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Tue 2024-09-03 13:48:33 CEST
                   Universal time: Tue 2024-09-03 11:48:33 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** Display-Server-Setup ***
        Display-Server: true
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            8.2G        2.5G        923M         17M        4.6G        5.7G
        Swap:           209M          0B        209M
        Total:          8.4G        2.5G        1.1G
        Active iob-Instances:   36
                 7810 M total memory
                 2400 M used memory
                 5494 M active memory
                 1136 M inactive memory
                  880 M free memory
                  137 M buffer memory
                 4271 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        top - 13:48:34 up 7 days, 23:14,  4 users,  load average: 0.85, 0.75, 0.82
        Tasks: 234 total,   1 running, 233 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7810.0 total,    879.3 free,   2402.2 used,   4408.5 buff/cache
        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5407.9 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     782M  1.4M  780M   1% /run
        /dev/mmcblk0p2 ext4      117G   19G   93G  17% /
        tmpfs          tmpfs     3.9G  148K  3.9G   1% /dev/shm
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
        tmpfs          tmpfs     781M   40K  781M   1% /run/user/1000
        [Mon Aug 26 14:33:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B6:0D:F1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f26be412-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Mon Aug 26 14:34:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
        [Mon Aug 26 14:34:07 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET                                                  SOURCE         FSTYPE          OPTIONS
        /                                                       /dev/mmcblk0p2 ext4            rw,noatime,commit=600
        |-/sys                                                  sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security                                securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                                      cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore                                      pstore         pstore          rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                                         bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                                   debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing                                 tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/fuse/connections                            fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
        | `-/sys/kernel/config                                  configfs       configfs        rw,nosuid,nodev,noexec,relatime
        |-/proc                                                 proc           proc            rw,relatime
        | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5312
        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc     rw,nosuid,nodev,noexec,relatime
        |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=3725568k,nr_inodes=931392,mode=755
        | |-/dev/pts                                            devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                                            tmpfs          tmpfs           rw,nosuid,nodev
        | `-/dev/mqueue                                         mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
        |-/run                                                  tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=799748k,mode=755
        | |-/run/lock                                           tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs      rw,relatime
        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
        | `-/run/user/1000                                      tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=799744k,nr_inodes=199936,mode=700,uid=1000,gid=1000
        |   |-/run/user/1000/doc                                portal         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |   `-/run/user/1000/gvfs                               gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot/firmware                                        /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        5.2G    /var/
        4.0G    /var/log/journal/6c7cbef6aa2e4815900727fbf6286f9a
        4.0G    /var/log
        761M    /var/lib
        Archived and active journals take up 3.9G in the file system.
        /opt/iobroker/backups:
        5.1G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        817M    /opt/iobroker/iobroker-data/
        719M    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
        20M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D306MB4E-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.14.0
        /usr/bin/node           v20.14.0
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.1
        nodejs:
          Installed: 20.14.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
             20.17.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
         *** 20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.0.23
        javascript:     8.7.6
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : Homee                                    -  enabled, port: 7770, bind: 0.0.0.0, run as: admin
        + system.adapter.alpha-ess.0              : alpha-ess             : Homee                                    -  enabled
        + system.adapter.backitup.0               : backitup              : Homee                                    -  enabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: Homee                                    -  enabled
          system.adapter.daswetter.0              : daswetter             : Homee                                    -  enabled
          system.adapter.devices.0                : devices               : Homee                                    -  enabled
        + system.adapter.discovery.0              : discovery             : Homee                                    -  enabled
        + system.adapter.ds18b20.1                : ds18b20               : Kellerkind                               -  enabled
        + system.adapter.ds18b20.3                : ds18b20               : PapaHuette                               -  enabled
          system.adapter.dwd.0                    : dwd                   : Homee                                    -  enabled
        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : Homee                                    -  enabled
        + system.adapter.email.0                  : email                 : Homee                                    -  enabled
        + system.adapter.growatt.0                : growatt               : Homee                                    -  enabled
        + system.adapter.growatt.1                : growatt               : Homee                                    -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : Homee                                    -  enabled
          system.adapter.ical.0                   : ical                  : Homee                                    -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Homee                                    -  enabled
        + system.adapter.influxdb.0               : influxdb              : Homee                                    -  enabled, port: 8086
        + system.adapter.javascript.0             : javascript            : Homee                                    -  enabled
        + system.adapter.modbus.0                 : modbus                : Homee                                    -  enabled
        + system.adapter.modbus.1                 : modbus                : Homee                                    -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : Homee                                    -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.nina.0                   : nina                  : Homee                                    -  enabled
          system.adapter.pegelalarm.0             : pegelalarm            : Homee                                    -  enabled
          system.adapter.pegelalarm.1             : pegelalarm            : Homee                                    -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : Homee                                    -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : Homee                                    -  enabled
        + system.adapter.rpi2.1                   : rpi2                  : Kellerkind                               -  enabled
        + system.adapter.rpi2.2                   : rpi2                  : MotionEye                                -  enabled
        + system.adapter.rpi2.3                   : rpi2                  : PapaHuette                               -  enabled
        + system.adapter.rpi2.4                   : rpi2                  : Gartenklo                                -  enabled
        + system.adapter.semp.0                   : semp                  : Homee                                    -  enabled
        + system.adapter.smartmeter.0             : smartmeter            : Homee                                    -  enabled
        + system.adapter.sonoff.0                 : sonoff                : Homee                                    -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.systeminfo.0             : systeminfo            : Homee                                    -  enabled
        + system.adapter.systeminfo.1             : systeminfo            : Kellerkind                               -  enabled
        + system.adapter.systeminfo.2             : systeminfo            : MotionEye                                -  enabled
        + system.adapter.systeminfo.3             : systeminfo            : PapaHuette                               -  enabled
        + system.adapter.systeminfo.4             : systeminfo            : Gartenklo                                -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : Homee                                    -  enabled
          system.adapter.vis-bars.0               : vis-bars              : Homee                                    -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Homee                                    -  enabled
          system.adapter.vis-history.0            : vis-history           : Homee                                    -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Homee                                    -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : Homee                                    -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : Homee                                    -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Homee                                    -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : Homee                                    -  enabled
          system.adapter.vis-metro.0              : vis-metro             : Homee                                    -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : Homee                                    -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : Homee                                    -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : Homee                                    -  enabled
          system.adapter.vis.0                    : vis                   : Homee                                    -  enabled
        + system.adapter.web.0                    : web                   : Homee                                    -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
        + system.adapter.worx.2                   : worx                  : PapaHuette                               -  enabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Upgrade policy: none
        Installed ioBroker-Instances
        Adapter    "admin"        : 7.0.23   , installed 7.0.23
        Adapter    "alpha-ess"    : 2.1.4    , installed 2.1.4
        Adapter    "backitup"     : 3.0.19   , installed 3.0.19
        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "growatt"      : 3.2.4    , installed 3.2.4
        Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "semp"         : 1.4.5    , installed 1.4.5
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Objects and States
        Objects:        13113
        States:         13797
        Pending Updates: 177
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        9319       1110/influxd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3886       791/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          4168842    510715/cupsd
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       2756026    339106/iobroker.js-
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       2754907    339106/iobroker.js-
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       2756733    339460/io.sonoff.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       2756442    339324/io.mqtt.0
        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       2756443    339324/io.mqtt.0
        tcp6       0      0 :::3000                 :::*                    LISTEN      112        12504      1318/grafana
        tcp6       0      0 :::7777                 :::*                    LISTEN      1001       2760726    339937/io.web.0
        tcp6       0      0 :::7770                 :::*                    LISTEN      1001       2753355    339124/io.admin.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          4168841    510715/cupsd
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        8571       1110/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          3888       791/sshd: /usr/sbin
        tcp6       0      0 :::9765                 :::*                    LISTEN      1001       2759858    339866/io.semp.0
        udp        0      0 0.0.0.0:39233           0.0.0.0:*                           104        3795       587/avahi-daemon: r
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          4169875    510716/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3793       587/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2759861    339866/io.semp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2759860    339866/io.semp.0
        udp6       0      0 fe80::c6ff:9450:166:546 :::*                                0          4398053    714/NetworkManager
        udp6       0      0 fe80::fe25:eded:c85:546 :::*                                0          343588     714/NetworkManager
        udp6       0      0 :::54452                :::*                                104        3796       587/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        3794       587/avahi-daemon: r
        2024-09-03 12:49:01.565  - warn: javascript.0 (339187)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
        2024-09-03 12:49:01.565  - warn: javascript.0 (339187)     at processImmediate (node:internal/timers:478:21)
        2024-09-03 12:49:01.566  - warn: javascript.0 (339187) getState "growatt.0.353433.devices.DLE3A1113A.deviceData.eMonth" not found (3)
        2024-09-03 12:49:01.570  - warn: javascript.0 (339187)     at Object.<anonymous> (script.js.PV-Anlage.Monatsproduktion:84:93)
        2024-09-03 12:49:01.571  - warn: javascript.0 (339187)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2024-09-03 12:49:01.571  - warn: javascript.0 (339187)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2024-09-03 12:49:01.571  - warn: javascript.0 (339187)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11013:62)
        2024-09-03 12:49:01.571  - warn: javascript.0 (339187)     at processImmediate (node:internal/timers:478:21)
        2024-09-03 12:49:06.758  - info: smartmeter.0 (339445) Received 10 values, 3 updated
        2024-09-03 12:49:08.394  - debug: mqtt.0 (339324) Client [Wemos_.81_0]  pingreq
        2024-09-03 12:49:13.390  - debug: mqtt.0 (339324) Client [Wemos_.81_0] received publish package {"cmd":"publish","retain":false,"qos":0,"dup":false,"length":54,"topic":"Wemos .81/Füllstand Brunnen/Füllstand Brunnen","payload":{"type":"Buffer","data":[50,52,46,57,54]}}
        2024-09-03 12:49:13.390  - debug: mqtt.0 (339324) Server received "Wemos .81/Füllstand Brunnen/Füllstand Brunnen" (number): 24.96
        2024-09-03 12:49:13.401  - silly: mqtt.0 (339324) States user redis pmessage mqtt.0.*/mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen:{"val":24.96,"ack":true,"ts":1725364153395,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725364153395}
        2024-09-03 12:49:13.402  - debug: mqtt.0 (339324) stateChange mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen: {"val":24.96,"ack":true,"ts":1725364153395,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725364153395}
        2024-09-03 12:49:13.402  - debug: mqtt.0 (339324) onStateChange mqtt.0.Wemos_.81.Füllstand_Brunnen.Füllstand_Brunnen: {"val":24.96,"ack":true,"ts":1725364153395,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1725364153395}
        2024-09-03 12:49:13.403  - debug: mqtt.0 (339324) Client [Wemos_.81_0] send to this client "Wemos .81/Füllstand Brunnen/Füllstand Brunnen": 24.96
        2024-09-03 12:49:17.254  - info: smartmeter.0 (339445) Received 10 values, 3 updated
        2024-09-03 12:49:22.895  - debug: homeconnect.0 (340397) event: {"type":"NOTIFY","data":"{\"haId\":\"484020392374002592\",\"items\":[{\"handling\":\"none\",\"key\":\"BSH.Common.Option.RemainingProgramTime\",\"level\":\"hint\",\"timestamp\":1725364162,\"unit\":\"seconds\",\"uri\":\"/api/homeappliances/484020392374002592/programs/active/options/BSH.Common.Option.RemainingProgramTime\",\"value\":6960},{\"handling\":\"none\",\"key\":\"BSH.Common.Option.EstimatedTotalProgramTime\",\"level\":\"hint\",\"timestamp\":1725364162,\"unit\":\"seconds\",\"uri\":\"/api/homeappliances/484020392374002592/programs/active/options/BSH.Common.Option.EstimatedTotalProgramTime\",\"value\":6960}]}","lastEventId":"484020392374002592","origin":"https://api.home-connect.com"}
        2024-09-03 12:49:22.895  - debug: homeconnect.0 (340397) 484020392374002592.programs.active.options.BSH_Common_Option_RemainingProgramTime:6960
        2024-09-03 12:49:22.896  - debug: homeconnect.0 (340397) 484020392374002592.programs.active.options.BSH_Common_Option_EstimatedTotalProgramTime:6960
        2024-09-03 12:49:22.899  - debug: homeconnect.0 (340397) Set event state
        2024-09-03 12:49:22.900  - debug: homeconnect.0 (340397) Set event state
        2024-09-03 12:49:22.948  - silly: homeconnect.0 (340397) States user redis pmessage homeconnect.0.*/homeconnect.0.484020392374002592.programs.active.options.BSH_Common_Option_RemainingProgramTime:{"val":6960,"ack":true,"ts":1725364162944,"q":0,"from":"system.adapter.homeconnect.0","user":"system.user.admin","lc":1725364162944}
        2024-09-03 12:49:22.951  - silly: homeconnect.0 (340397) States user redis pmessage homeconnect.0.*/homeconnect.0.484020392374002592.programs.active.options.BSH_Common_Option_EstimatedTotalProgramTime:{"val":6960,"ack":true,"ts":1725364162945,"q":0,"from":"system.adapter.homeconnect.0","user":"system.user.admin","lc":1725364162945}
        2024-09-03 12:49:23.402  - debug: mqtt.0 (339324) Client [Wemos_.81_0]  pingreq
        iob diag has finished.
        • CodierknechtC Codierknecht
          @sms
          SMSS Offline
          SMSS Offline
          SMS
          @codierknecht Sowas meinst du:
          dachte das wäre falsch weil ich es gemacht habe und dann kam es immer gleich wieder
          • SMSS SMS
            Codierknecht
            @SMS
            Im Prinzip ja. Da tauchen nämlich auch die Meldungen zu OS-Updates auf. Die sollte man dann zeitnah durchführen.
            Weil Du vermutlich nicht auf "Bestätigen" geklickt hast?
            SMSS HomoranH 2 Antworten Letzte Antwort
            • SMSS SMS
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           209M          0B        209M
                       7810 M total memory
                       2400 M used memory
                        880 M free memory
                        137 M buffer memory
                       4271 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              *** FILESYSTEM ***
              /var:
              5.2G    /var/
              4.0G    /var/log
              761M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          7.0.23
              javascript:     8.7.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        13113
              States:         13797
              hast du nicht gerade ein update der Pakete gemacht?
              PapaHuette
              Multihost mit 4 Slaves?
              wie sieht es dort mit der Aktualität aus?
              Repos aktualisieren!
              suche nach dem Thread "fantastische Repositories...."
                @SMS
                SMSS Offline
                SMSS Offline
                SMS
                @codierknecht jetzt kommt das hier:
                Auf "Bestätigen und schliessen" geklickt
                  @SMS
                  oder noch ungepflegte Slaves existieren.
                    PapaHuette
                    SMSS Offline
                    SMSS Offline
                    SMS
                    @homoran sagte in Zeitplan startet nicht mehr:
                    PapaHuette
                    Ja 4 Slaves. Aktualisierung wird "eigentlich" immer zusammen gemacht.
                    • SMSS SMS
                      PapaHuette
                      also auch
                        also auch
                        SMSS Offline
                        SMSS Offline
                        SMS
                        @homoran was sind "Pendling OS-Updates"?
                        sudo apt full-upgrade
                        läuft noch
                        • AsgothianA Asgothian
                          @sms Unabhängig davon ob das prinzipiell so läuft oder so nicht läuft - das ist Ressourcenverschwendung auf einem Irren Level.
                          Jede Sekunde (oder auch jede Minute) nachschauen ob die aktuelle Minute der eingestellten Minute entspricht und nur dann etwas tun ist.. sagen wir mal Ineffizient.
                          Der korrekte Weg ist:
                          • Erkennen wenn sich der Datenpunkt 0_userdata.0.Haushaltsgeraete.01_Uhrzeit_Spuelmaschine ändert
                          • Zeitplan umschreiben, so dass genau zu dieser Zeit gestartet wird.
                          • Bei Skriptstart: Zeitplan korrekt setzen.
                          In dem Beispiel muss natürlich der Datenpunkt für den Trigger und den Wert von... auf 0_userdata.0.Haushaltsgeraete.01_Uhrzeit_Spuelmaschine gesetzt werden - den hab ich hier nicht.
                          Im Spoiler: XML zum einfügen
                           <variables>
                             <variable id="8mWj.p^^$e{CjI3XaM6U">Uhrzeit</variable>
                             <variable id="EJUE1H]|FWmaOe2J}Ba3">CronZeiten</variable>
                             <variable type="cron" id="schedule1">schedule1</variable>
                           </variables>
                           <block type="procedures_callnoreturn" id="3pHqhIVWg;hE`n{;,c,z" x="588" y="113">
                             <mutation name="Setze Zeitplan">
                               <arg name="Uhrzeit"></arg>
                             </mutation>
                             <value name="ARG0">
                               <block type="get_value" id="]}(I[fOG6tU28;aeV36B">
                                 <field name="OID">ID auswählen</field>
                               </block>
                             </value>
                             <next>
                               <block type="on_ext" id=")/#2*G=T!svi=aX`CGru">
                                 <value name="OID0">
                                   <shadow type="field_oid" id="Z(Z%A6pwMb/PM,N$h^J~">
                                     <field name="oid">ID auswählen</field>
                                   </shadow>
                                 </value>
                                 <statement name="STATEMENT">
                                   <block type="procedures_callnoreturn" id=",Hp-/U_0#^J14XSt6uY=">
                                     </mutation>
                                     <value name="ARG0">
                                       <block type="on_source" id="+@2%*?{xSI/n{ZG3]q5L">
                                       </block>
                                     </value>
                                   </block>
                                 </statement>
                               </block>
                             </next>
                           </block>
                           <block type="procedures_defnoreturn" id="u!|@+,F8/yB]hnAtN@AB" x="588" y="313">
                             <mutation>
                               <arg name="Uhrzeit" varid="8mWj.p^^$e{CjI3XaM6U"></arg>
                             </mutation>
                             <field name="NAME">Setze Zeitplan</field>
                             <statement name="STACK">
                               <block type="schedule_clear" id="-jAeO7G`x.H~kU8MV7(F">
                                 <field name="NAME">schedule1</field>
                                 <next>
                                   <block type="comment" id="6[9_71JRX?PTi13miN|=">
                                     <field name="COMMENT">Cron erwartet Minuten zuerst</field>
                                     <next>
                                       <block type="variables_set" id=",3e/:fy.-_/D7;*9a6s+">
                                         <field name="VAR" id="EJUE1H]|FWmaOe2J}Ba3">CronZeiten</field>
                                         <value name="VALUE">
                                           <block type="lists_reverse" id="XeeyBhs@o.9^(Y?d]GJq">
                                             <value name="LIST">
                                               <block type="lists_split" id="gA5(}}l)QorG~Qa]H{s7">
                                                 <mutation mode="SPLIT"></mutation>
                                                 <field name="MODE">SPLIT</field>
                                                 <value name="INPUT">
                                                   <block type="variables_get" id="na^HeX`/l{?4=K{e3+rd">
                                                     <field name="VAR" id="8mWj.p^^$e{CjI3XaM6U">Uhrzeit</field>
                                                   </block>
                                                 </value>
                                                 <value name="DELIM">
                                                   <shadow type="text" id="PSqy0/e3QRP?bfz}31:{">
                                                     <field name="TEXT">:</field>
                                                   </shadow>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                           <block type="controls_if" id="_Jx,I1;O.RC};5t.,?q2">
                                             <value name="IF0">
                                               <block type="logic_compare" id="lE`}QKUizijGvGJF+5ZY">
                                                 <field name="OP">NEQ</field>
                                                 <value name="A">
                                                   <block type="lists_length" id="w5vWcO_5SoZXD=Qda#m3">
                                                       <block type="variables_get" id="0;;,xw:)pz^Qeu{duB;g">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <value name="B">
                                                   <block type="math_number" id="8fc2nJ(dsD{1!}YAU|iS">
                                                     <field name="NUM">2</field>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <statement name="DO0">
                                               <block type="debug" id="i^Mn:SlAQqA+k5{/nF8U">
                                                 <field name="Severity">error</field>
                                                 <value name="TEXT">
                                                   <shadow type="text" id="zZPV1UBSYuIWMx2hZN{V">
                                                     <field name="TEXT">Uhrzeit im falschen Format, auf 12:00 gesetzt</field>
                                                   </shadow>
                                                   <block type="text_join" id="29XLr5]c-GdrzT$3s;*x">
                                                     <value name="ADD0">
                                                       <block type="text" id="d!/9%0-C.Ji0[/-j+O.-">
                                                         <field name="TEXT">Uhrzeit (</field>
                                                       </block>
                                                     </value>
                                                     <value name="ADD1">
                                                       <block type="variables_get" id="+nqBnanD/5)4X;sV+Lz^">
                                                       </block>
                                                     </value>
                                                     <value name="ADD2">
                                                       <block type="text" id="=[Yi3l]1UOqv2Q?5j1!:">
                                                         <field name="TEXT">) im falschen Format, Startzeit auf 12:00 Uhr gesetzt</field>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                   <block type="variables_set" id="BeCZB`E+Pm|/i!oQ)iym">
                                                       <block type="lists_create_with" id="S[_h(j*Gr9:ba+oGoCo3">
                                                         <value name="ADD0">
                                                           <block type="math_number" id="UJ~,OE{C+Z+#FrfU80*j">
                                                             <field name="NUM">0</field>
                                                           </block>
                                                         </value>
                                                         <value name="ADD1">
                                                           <block type="math_number" id=",,d7xQ7Y/QQ$G5T4Vv/i">
                                                             <field name="NUM">12</field>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </next>
                                               </block>
                                             </statement>
                                             <next>
                                               <block type="comment" id="UkE?be_0oKqza/e06{O9">
                                                 <field name="COMMENT">Tag des Monats </field>
                                                 <next>
                                                   <block type="lists_setIndex" id="E%h$kBJrzc,XL+AwPXAj">
                                                     <mutation at="false"></mutation>
                                                     <field name="MODE">INSERT</field>
                                                     <field name="WHERE">LAST</field>
                                                     <value name="LIST">
                                                       <block type="variables_get" id="!kX9ELl5!x|1xlbBzk%F">
                                                       </block>
                                                     </value>
                                                     <value name="TO">
                                                       <block type="text" id="%wH1Q)5Xj78q=)LPQiB(">
                                                         <field name="TEXT">*</field>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="comment" id="D;fGH|Red9*}B+S=:,|I">
                                                         <field name="COMMENT">Monat</field>
                                                         <next>
                                                           <block type="lists_setIndex" id="@)/_5,650^0:KHxs*9h:">
                                                             <value name="LIST">
                                                               <block type="variables_get" id="y705}QnPb5+@=u-*M~fR">
                                                               </block>
                                                             </value>
                                                             <value name="TO">
                                                               <block type="text" id="0E87ko@P5fg)?X(4c?hQ">
                                                               </block>
                                                             </value>
                                                             <next>
                                                               <block type="comment" id="_m*1/*y.}?U`?.x[chHr">
        <field name="COMMENT">Wochentag</field>
        <next>
        <block type="lists_setIndex" id="}a_%){8Ulhl/J%H$AfKh">
        <value name="LIST">
        <block type="variables_get" id="ljv*Nb)Us!UW)qDcV8n2">
        </block>
        </value>
        <value name="TO">
        <block type="text" id=")|Uq+$cPMGnaoe+,d`eM">
        </block>
        </value>
        <next>
        <block type="schedule_create" id="v4H,!u56TaVN,d0=}#c^">
        <value name="SCHEDULE">
        <shadow type="field_cron" id=":m3(S5oUgD.d`:,9%p7j">
        <field name="CRON">* * * * *</field>
        </shadow>
        <block type="lists_split" id="[,M*4fO2CoRD8p[7z#m3">
        <mutation mode="JOIN"></mutation>
        <field name="MODE">JOIN</field>
        <block type="variables_get" id="r1`vb65U410feJ[if+s?">
        </block>
        </value>
        <shadow type="text" id="g_SLsT5:$s)rL7IzGf9{">
        <field name="TEXT"> </field>
        </shadow>
        </value>
        </block>
        </value>
        <block type="debug" id="1@@)4{3@=T()gcW4~GC1">
        <field name="Severity">info</field>
        <value name="TEXT">
        <shadow type="text" id="`g^y9:z4$jXW;/iNM{*A">
        <field name="TEXT">Zeitplan wurde gestartet</field>
        </shadow>
        </value>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                          </xml>
                          haus-automatisierungH Offline
                          @asgothian sagte in Zeitplan startet nicht mehr:
                          Viel zu kompliziert. Trigger: "Zeitplan aus Zeitzustand".
                          Der macht genau das alles, was Du manuell getan hast. Nur den Datenpunkt auswählen und fertig.
                          📚 Meine Dokumentation
                          • SMSS SMS
                            läuft noch
                            "pending" heist "ausstehende".
                            da fehlen also 177 Updates vom Betriebssystem!
                            läuft noch
                            auch auf jedem slave?
                            • SMSS SMS
                              @asgothian Hi
                              Mit der Ressourcenverschwendung gebe ich dir natürlich recht. Die Sekunde steht auch nur drin damit ich sehe ob es auch funktioniert. Im eigentlichen Script stehen 15 Minuten drin.
                              Wobei, vielleicht ist auch gerade dass das Problem, das die Sekunde zu viel ist ...
                              Ich werde es mal ausprobieren.
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @asgothian Hi
                              Bei 15 Minuten hast du ein anderes Problem. Du hast ggf. einen Zeitversatz zwischen der eingestellten Zeit und dem Zeitpunkt an dem das Skript zum Zuge kommt. Dazu kommt die Problematik des Zeitvergleichs (wenn da mal jemand 12:25 eingetragen hat), sowie die Problematik das ein Vergleich auf "später als ..." der für jeden Durchlauf später als die eingetragene Zeit wahr wird.
                              Insgesamt solltest du versuchen die System-tools zu benutzen um zu bestimmten Zeiten zu agieren - nicht mit eigenen "Heartbeats" arbeiten. Die multiplizieren sich gerne mal. Das meiste kann man mit geschickten Ansätzen anders abbilden.
                              A.
                                läuft noch
                                SMSS Offline
                                SMSS Offline
                                SMS
                                schrieb am zuletzt editiert von SMS
                                @homoran Ja, läuft bei allen gerade
                                Danach nochmal die Diagnose?
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @haus-automatisierung sagte in Zeitplan startet nicht mehr:
                                  Stimmt das auch dann wenn in dem Zeitzustand nur eine Uhrzeit, kein Tag drin steht ? Da war ich nicht sicher, deswegen der komplexe weg - das läuft bei mir zu Hause so seit einiger Zeit.
                                  Ansonsten - super :)
                                  A.
                                    A.
                                    Das geht nur mit Datenpunkten im Format hh:mm oder hh:mm:ss. Also Tage geht generell nicht.
                                    CodierknechtC HomoranH 2 Antworten Letzte Antwort
                                      Codierknecht
                                      Ist aber vermutlich genau das was der TE braucht ;-)
                                      Hatte ich auch nicht auf dem Schirm 😊
                                      • SMSS SMS
                                        das heißt?
                                        das heißt?
                                        Das heißt, das du dich noch nie um dein Betriebssystem gekümmert hast.
                                        grafana und influxdb-Repo müssen richtig eingerichtet werden:
                                        https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                        Da sind aber auch noch andere kinken drin. Aber eins nach dem anderen.
                                          auch wenn der DP nicht vom typ text, sondern number ist?
