  4. NPM verschwunden ,Keine Änderungen in der Konsole möglich
66 Beiträge 3 Kommentatoren 7.9k Aufrufe 2 Beobachtet
  • B Burgsteff
    Hab mich wieder als burgsteff angemeldet
    Danke schon mal.
    @burgsteff
    iob nodejs-update
      @burgsteff
      iob nodejs-update
      Burgsteff
      Your nodejs- Installation seems to be faulty. Shall we try to fix it?
      Mit y beantworten oder?
      • B Burgsteff
        @burgsteff sagte in NPM verschwunden ,Keine Änderungen in der Konsole möglich:
        bitte alles zeigen!
        • B Burgsteff
          Ja, das soll ja berichtigt werden.
            Burgsteff
            ioBroker nodejs fixer 2024-05-23
            Recommended nodejs-version is: 20.17.0
            Checking your installation now. Please be patient!
            Your current setup is:
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /home/iobroker/.nodejs-update.sh: line 146: npm: command not found
            /home/iobroker/.nodejs-update.sh: line 147: npx: command not found
            /home/iobroker/.nodejs-update.sh: line 168: npm: command not found
            /home/iobroker/.nodejs-update.sh: line 169: npx: command not found
            *** nodejs is NOT correctly installed ***
            We found these nodejs versions available for installation:
            nodejs:
              Installed: 18.19.0+dfsg-6~deb12u2
              Candidate: 18.19.0+dfsg-6~deb12u2
              Version table:
             *** 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
            Your nodejs-Installation seems to be faulty. Shall we try to fix it?
            Press <y> to continue or any other key to quit
            Fixing your nodejs setup
            *** Deleting  ***
            rm: cannot remove '': No such file or directory
            *** Deleting  ***
            Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
            You are running nodejs v18.19.0. Do you want to install recommended version 20.17.0?
            Trying to fix your installation now. Please be patient.
            Virtualization: kvm
            Waiting for ioBroker to shut down - Give me a minute...
            *** These repos are active on your system:
            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
            Reading package lists... Done
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
            Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
            Get:5 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [8942 B]
            Fetched 21.1 kB in 1s (29.9 kB/s)
            Installing nodejs now!
            E: Broken packages
            E: Broken packages
            *** You need to manually restart your container/virtual machine now! ***
            We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
            • B Burgsteff
              nodejs:
                Version table:
              *** Deleting  ***
              *** Deleting  ***
              Virtualization: kvm
              Package: nodejs
              Pin-Priority: 1001
              E: Broken packages
              E: Broken packages
              @burgsteff
              Ah, die Version ist nicht aktuell genug.
              Versuch es mal mit der Beta:
              curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update.sh > iob_node_update
              chmod 744 iob_node_update
              ./iob_node_update
                @burgsteff
                ./iob_node_update
                Burgsteff
                ioBroker nodejs maintenance 2024-08-08
                ./iob_node_update: line 157: npm: command not found
                ./iob_node_update: line 158: npx: command not found
                ./iob_node_update: line 179: npm: command not found
                ./iob_node_update: line 180: npx: command not found
                nodejs:
                  Candidate: 20.17.0-1nodesource1
                  Version table:
                     20.17.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                *** Deleting  ***
                *** Deleting  ***
                Virtualization: kvm
                Removing dfsg-nodejs
                (Reading database ... 45351 files and directories currently installed.)
                Removing nodejs-doc (18.19.0+dfsg-6~deb12u2) ...
                Removing nodejs (18.19.0+dfsg-6~deb12u2) ...
                Removing libnode108:amd64 (18.19.0+dfsg-6~deb12u2) ...
                Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                Removing node-busboy (1.6.0+~cs2.6.0-2) ...
                Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
                Removing node-xtend (4.0.2-3) ...
                Processing triggers for libc-bin (2.36-9+deb12u7) ...
                Package: nodejs
                Pin-Priority: 1001
                Fetched 21.1 kB in 1s (30.2 kB/s)
                (Reading database ... 44612 files and directories currently installed.)
                Preparing to unpack .../libaom3_3.6.0-1+deb12u1_amd64.deb ...
                Unpacking libaom3:amd64 (3.6.0-1+deb12u1) over (3.6.0-1) ...
                Selecting previously unselected package nodejs.
                Preparing to unpack .../nodejs_20.17.0-1nodesource1_amd64.deb ...
                Unpacking nodejs (20.17.0-1nodesource1) ...
                Setting up libaom3:amd64 (3.6.0-1+deb12u1) ...
                Setting up nodejs (20.17.0-1nodesource1) ...
                burgsteff@ioBroker:~$
                • B Burgsteff
                  nodejs:
                    Version table:
                  *** Deleting  ***
                  *** Deleting  ***
                  Virtualization: kvm
                  Package: nodejs
                  Pin-Priority: 1001
                  Mach das mal.
                  • B Burgsteff
                    nodejs:
                      Version table:
                    *** Deleting  ***
                    *** Deleting  ***
                    Virtualization: kvm
                    Package: nodejs
                    Pin-Priority: 1001
                    aber vorher
                      Mach das mal.
                      Burgsteff
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: ioBroker
                             Icon name: computer-vm
                               Chassis: vm 🖴
                        Virtualization: kvm
                                Kernel: Linux 6.1.0-23-amd64
                          Architecture: x86-64
                       Hardware Vendor: QEMU
                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                      model name      : QEMU Virtual CPU version 2.5+
                      Docker          : false
                      Virtualization  : kvm
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                      CPU threads: 4
                      *** Time and Time Zones ***
                                     Local time: Sun 2024-08-25 19:45:28 CEST
                                 Universal time: Sun 2024-08-25 17:45:28 UTC
                                       RTC time: Sun 2024-08-25 17:45:28
                      System clock synchronized: no
                                    NTP service: n/a
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      burgsteff
                      HOME=/home/burgsteff
                      GROUPS=burgsteff adm dialout cdrom floppy sudo audio dip video plugdev users input netdev iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      *** Display-Server-Setup ***
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            4.1G        1.2G        2.7G        516K        384M        2.9G
                      Swap:           1.0G          0B        1.0G
                      Total:          5.1G        1.2G        3.7G
                      Active iob-Instances:   12
                               3914 M total memory
                               1181 M used memory
                                124 M active memory
                               1027 M inactive memory
                               2583 M free memory
                                 36 M buffer memory
                                331 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                      top - 19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                      Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3914.7 total,   2583.4 free,   1181.6 used,    367.3 buff/cache
                      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   2733.2 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      udev           devtmpfs  1.9G     0  1.9G   0% /dev
                      tmpfs          tmpfs     392M  512K  391M   1% /run
                      /dev/sda1      ext4       31G  6.5G   23G  23% /
                      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
                      [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                      Show mounted filesystems:
                      TARGET                                                  SOURCE      FSTYPE      OPTIONS
                      /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
                      |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                      | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                      | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                      | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                      |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
                      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14461
                      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                      |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1981136k,nr_inodes=495284,mode=755,inode64
                      | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                      | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
                      | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                      | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                      `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=400872k,mode=755,inode64
                        |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                        |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                        |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400868k,nr_inodes=100217,mode=700,uid=1000,gid=1000,inode64
                        `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      /var:
                      745M    /var/
                      348M    /var/cache
                      343M    /var/cache/apt
                      267M    /var/cache/apt/archives
                      240M    /var/log
                      Archived and active journals take up 224.3M in the file system.
                      /opt/iobroker/backups:
                      35M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      837M    /opt/iobroker/iobroker-data/
                      748M    /opt/iobroker/iobroker-data/files
                      441M    /opt/iobroker/iobroker-data/files/javascript.admin
                      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                      25M     /opt/iobroker/iobroker-data/objects.jsonl
                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
                      9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.17.0
                      /usr/bin/node           v20.17.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.29.3
                      nodejs:
                        Installed: 20.17.0-1nodesource1
                        Version table:
                       *** 20.17.0-1nodesource1 1001
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  6.0.9
                      admin:          7.0.22
                      javascript:     8.7.6
                      nodejs modules from github:     2
                      +-- iobroker.tibber@0.3.1-beta (git+ssh://git@github.com/Magnus8513/ioBroker.tibber.git#283b14b7fbea6bb07eb37364dfba42eb2ca71786)
                      +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.backitup.0               : backitup              : ioBroker                                 - disabled
                        system.adapter.flot.0                   : flot                  : ioBroker                                 -  enabled
                        system.adapter.history.0                : history               : ioBroker                                 - disabled
                      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                      + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                      + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                        system.adapter.modbus.1                 : modbus                : ioBroker                                 - disabled
                      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
                      + system.adapter.tibber.0                 : tibber                : ioBroker                                 -  enabled
                        system.adapter.tibberconnect.0          : tibberconnect         : ioBroker                                 -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                        system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                        system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
                        system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                        system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                      + system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                        system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      ioBroker-Repositories
                      │ (index) │ name               │ url                                                     │ auto upgrade │
                      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                      Upgrade policy: none
                      Installed ioBroker-Instances
                      Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
                      Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
                      Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                      Controller "js-controller": 6.0.9    , installed 6.0.9
                      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                      Adapter    "semp"         : 1.4.5    , installed 1.4.5
                      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                      Objects and States
                      Objects:        6488
                      States:         5380
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 192.168.1.217:2010      0.0.0.0:*               LISTEN      1001       15000      655/io.hm-rpc.1
                      tcp        0      0 192.168.1.217:2001      0.0.0.0:*               LISTEN      1001       1768       640/io.hm-rpc.0
                      tcp        0      0 192.168.1.217:9292      0.0.0.0:*               LISTEN      1001       1783       670/io.hm-rpc.2
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14816      501/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14811      501/iobroker.js-con
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13729      1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14797      515/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17224      544/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16008      841/io.web.0
                      tcp6       0      0 :::9765                 :::*                    LISTEN      1001       17623      872/io.semp.0
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          934        1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14799      515/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17625      872/io.semp.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14757      417/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1311       1/init
                      udp6       0      0 :::111                  :::*                                0          1312       1/init
                      2024-08-25 19:44:58.750  - info: mqtt.0 (685) Try to connect to mqtt://192.168.1.216:1883 with clientId=ioBroker.mqtt.0
                      2024-08-25 19:44:58.811  - info: mqtt.0 (685) Connected to 192.168.1.216
                      2024-08-25 19:44:58.812  - info: mqtt.0 (685) Subscribe on "#"
                      2024-08-25 19:45:01.141  - info: host.ioBroker instance system.adapter.modbus.0 in version "6.2.3" started with pid 703
                      2024-08-25 19:45:02.310  - info: modbus.0 (703) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.17.0, js-controller: 6.0.9
                      2024-08-25 19:45:02.813  - info: modbus.0 (703) Connected to slave 192.168.1.236
                      2024-08-25 19:45:04.449  - info: hm-rpc.2 (670) Connected
                      2024-08-25 19:45:05.149  - info: host.ioBroker instance system.adapter.tibber.0 in version "0.3.1-beta" (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) started with pid 718
                      2024-08-25 19:45:06.519  - info: tibber.0 (718) starting. Version 0.3.1-beta (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) in /opt/iobroker/node_modules/iobroker.tibber, node: v20.17.0, js-controller: 6.0.9
                      2024-08-25 19:45:06.894  - info: tibber.0 (718) Tibber refresh success
                      2024-08-25 19:45:09.217  - info: host.ioBroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 772
                      2024-08-25 19:45:10.533  - info: vis-inventwo.0 (772) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.17.0, js-controller: 6.0.9
                      2024-08-25 19:45:14.459  - info: vis.0 (801) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.9
                      2024-08-25 19:45:15.948  - info: vis.0 (801) Terminated (NO_ERROR): Without reason
                      2024-08-25 19:45:16.563  - info: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
                      2024-08-25 19:45:17.198  - info: host.ioBroker instance system.adapter.web.0 in version "6.2.5" started with pid 841
                      2024-08-25 19:45:18.951  - info: web.0 (841) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.9
                      2024-08-25 19:45:19.078  - info: web.0 (841) socket.io server listening on port 8082
                      2024-08-25 19:45:19.084  - info: web.0 (841) http server listening on port 8082
                      2024-08-25 19:45:21.172  - info: host.ioBroker instance system.adapter.tibberconnect.0 in version "0.0.10" (non-npm: Codibris/ioBroker.tibberconnect#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83) started with pid 857
                      2024-08-25 19:45:25.193  - info: host.ioBroker instance system.adapter.semp.0 in version "1.4.5" started with pid 872
                      2024-08-25 19:45:26.860  - info: semp.0 (872) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.semp, node: v20.17.0, js-controller: 6.0.9
                      2024-08-25 19:45:26.898  - error: semp.0 (872) Lambda wrong device SerialNr
                      2024-08-25 19:45:26.900  - info: semp.0 (872) device created F-12287760-000000000001-00 Lambda
                      2024-08-25 19:45:29.921  - info: semp.0 (872) adapter discovered by SHM
                      @Homoran Habe ich davor neu gestartet, danke für den Hinweis.
                      • B Burgsteff
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                                 Chassis: vm 🖴
                          Virtualization: kvm
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 4
                                      NTP service: n/a
                                  RTC in local TZ: no
                        burgsteff
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           1.0G          0B        1.0G
                                 3914 M total memory
                                 1181 M used memory
                                  124 M active memory
                                 2583 M free memory
                                   36 M buffer memory
                                  331 M swap cache
                                  974 M total swap
                                    0 M used swap
                                  974 M free swap
                        *** FILESYSTEM ***
                        /var:
                        745M    /var/
                        348M    /var/cache
                        343M    /var/cache/apt
                        240M    /var/log
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          7.0.22
                        javascript:     8.7.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        6488
                        States:         5380
                        Pending Updates: 0
                        usr/bin/npm 10.8.2
                        da isses ja!
                        dann müsstest du jetzt die fehlenden Updates machen können.
                          Burgsteff
                          Meeeeeeega, jetzt passt das wieder.
                          Vielen herzlichen Dank 👏 👏 👏
                          Was kann man euch Gutes tun?
                          • B Burgsteff
                            @burgsteff
                            Gut, der ioBroker rennt wohl wieder.
                            cat /etc/profile
                            sagt?
                              @burgsteff
                              cat /etc/profile
                              sagt?
                              Burgsteff
                              burgsteff@ioBroker:~$ cat /etc/profile
                              # /etc/profile: system-wide .profile file for the Bourne shell (sh(1))
                              # and Bourne compatible shells (bash(1), ksh(1), ash(1), ...).
                              if [ "$(id -u)" -eq 0 ]; then
                                PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
                              else
                                PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games"
                              fi
                              export PATH
                              if [ "${PS1-}" ]; then
                                if [ "${BASH-}" ] && [ "$BASH" != "/bin/sh" ]; then
                                  # The file bash.bashrc already sets the default PS1.
                                  # PS1='\h:\w\$ '
                                  if [ -f /etc/bash.bashrc ]; then
                                    . /etc/bash.bashrc
                                  fi
                                else
                                    PS1='# '
                                  else
                                    PS1='$ '
                                  fi
                                fi
                              fi
                              if [ -d /etc/profile.d ]; then
                                for i in /etc/profile.d/*.sh; do
                                  if [ -r $i ]; then
                                    . $i
                                  fi
                                done
                                unset i
                              fi
                              • B Burgsteff
                                else
                                fi
                                export PATH
                                    # PS1='\h:\w\$ '
                                      . /etc/bash.bashrc
                                    fi
                                  else
                                      PS1='# '
                                    else
                                      PS1='$ '
                                    fi
                                  fi
                                fi
                                    if [ -r $i ]; then
                                      . $i
                                    fi
                                  done
                                  unset i
                                fi
                                @burgsteff
                                Das passt eigentlich. Lass es so.
                                  @burgsteff
                                  Burgsteff
                                  Dann ist ja gut, perfekt.
                                  Wirklich echt vielen Dank für die schnelle, kompetente und freundliche Hilfe.
                                  • B Burgsteff
                                    else
                                    fi
                                    export PATH
                                        # PS1='\h:\w\$ '
                                          . /etc/bash.bashrc
                                        fi
                                      else
                                          PS1='# '
                                        else
                                          PS1='$ '
                                        fi
                                      fi
                                    fi
                                        if [ -r $i ]; then
                                          . $i
                                        fi
                                      done
                                      unset i
                                    fi
                                    @burgsteff
                                    Trag mal in der Zeile 8 das ein:
                                    PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
                                      @burgsteff
                                      Burgsteff
                                      wie bzw. wo in Zeile 8?
                                      • B Burgsteff
                                        @burgsteff
                                        sudo nano /etc/profile
                                        Und dann statt
                                        da
                                        eintragen.
                                        Mit STRG-O und STRG-X speichern und den Editor verlassen.
                                        B 2 Antworten Letzte Antwort
                                          @burgsteff
                                          Und dann statt
                                          da
                                          eintragen.
                                          Burgsteff
                                          ok, hab ich gemacht. und nun?
