  4. NPM verschwunden ,Keine Änderungen in der Konsole möglich
66 Beiträge 3 Kommentatoren 7.9k Aufrufe 2 Beobachtet
  • B Burgsteff
    ioBroker nodejs maintenance 2024-08-08
    Recommended nodejs-version is: 20.17.0
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    ./iob_node_update: line 157: npm: command not found
    ./iob_node_update: line 158: npx: command not found
    ./iob_node_update: line 179: npm: command not found
    ./iob_node_update: line 180: npx: command not found
    *** nodejs is NOT correctly installed ***
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u2
      Candidate: 20.17.0-1nodesource1
      Version table:
         20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
     *** 18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    Your nodejs-Installation seems to be faulty. Shall we try to fix it?
    Press <y> to continue or any other key to quit
    Fixing your nodejs setup
    *** Deleting  ***
    rm: cannot remove '': No such file or directory
    *** Deleting  ***
    Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
    You are running nodejs v18.19.0. Do you want to install recommended version 20.17.0?
    Trying to fix your installation now. Please be patient.
    Virtualization: kvm
    Waiting for ioBroker to shut down - Give me a minute...
    Removing dfsg-nodejs
    (Reading database ... 45351 files and directories currently installed.)
    Removing nodejs-doc (18.19.0+dfsg-6~deb12u2) ...
    Removing nodejs (18.19.0+dfsg-6~deb12u2) ...
    Removing libnode108:amd64 (18.19.0+dfsg-6~deb12u2) ...
    Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
    Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
    Removing node-busboy (1.6.0+~cs2.6.0-2) ...
    Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
    Removing node-xtend (4.0.2-3) ...
    Processing triggers for libc-bin (2.36-9+deb12u7) ...
    *** These repos are active on your system:
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
    Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [8942 B]
    Fetched 21.1 kB in 1s (30.2 kB/s)
    Installing nodejs now!
    (Reading database ... 44612 files and directories currently installed.)
    Preparing to unpack .../libaom3_3.6.0-1+deb12u1_amd64.deb ...
    Unpacking libaom3:amd64 (3.6.0-1+deb12u1) over (3.6.0-1) ...
    Selecting previously unselected package nodejs.
    Preparing to unpack .../nodejs_20.17.0-1nodesource1_amd64.deb ...
    Unpacking nodejs (20.17.0-1nodesource1) ...
    Setting up libaom3:amd64 (3.6.0-1+deb12u1) ...
    Setting up nodejs (20.17.0-1nodesource1) ...
    *** You need to manually restart your container/virtual machine now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    burgsteff@ioBroker:~$
    @burgsteff sagte in NPM verschwunden ,Keine Änderungen in der Konsole möglich:
    Mach das mal.
    • B Burgsteff
      nodejs:
        Version table:
      *** Deleting  ***
      *** Deleting  ***
      Virtualization: kvm
      Package: nodejs
      Pin-Priority: 1001
      aber vorher
        Mach das mal.
        Burgsteff
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-23-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
        model name      : QEMU Virtual CPU version 2.5+
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Sun 2024-08-25 19:45:28 CEST
                   Universal time: Sun 2024-08-25 17:45:28 UTC
                         RTC time: Sun 2024-08-25 17:45:28
        System clock synchronized: no
                      NTP service: n/a
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        burgsteff
        HOME=/home/burgsteff
        GROUPS=burgsteff adm dialout cdrom floppy sudo audio dip video plugdev users input netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            4.1G        1.2G        2.7G        516K        384M        2.9G
        Swap:           1.0G          0B        1.0G
        Total:          5.1G        1.2G        3.7G
        Active iob-Instances:   12
                 3914 M total memory
                 1181 M used memory
                  124 M active memory
                 1027 M inactive memory
                 2583 M free memory
                   36 M buffer memory
                  331 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        top - 19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
        Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3914.7 total,   2583.4 free,   1181.6 used,    367.3 buff/cache
        MiB Swap:    975.0 total,    975.0 free,      0.0 used.   2733.2 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  1.9G     0  1.9G   0% /dev
        tmpfs          tmpfs     392M  512K  391M   1% /run
        /dev/sda1      ext4       31G  6.5G   23G  23% /
        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
        [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                                                  SOURCE      FSTYPE      OPTIONS
        /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
        |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
        |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
        | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14461
        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1981136k,nr_inodes=495284,mode=755,inode64
        | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
        | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
        | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
        `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=400872k,mode=755,inode64
          |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
          |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
          |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400868k,nr_inodes=100217,mode=700,uid=1000,gid=1000,inode64
          `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        /var:
        745M    /var/
        348M    /var/cache
        343M    /var/cache/apt
        267M    /var/cache/apt/archives
        240M    /var/log
        Archived and active journals take up 224.3M in the file system.
        /opt/iobroker/backups:
        35M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        837M    /opt/iobroker/iobroker-data/
        748M    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
        9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.17.0
        /usr/bin/node           v20.17.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.9
        admin:          7.0.22
        javascript:     8.7.6
        nodejs modules from github:     2
        +-- iobroker.tibber@0.3.1-beta (git+ssh://git@github.com/Magnus8513/ioBroker.tibber.git#283b14b7fbea6bb07eb37364dfba42eb2ca71786)
        +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : ioBroker                                 - disabled
          system.adapter.flot.0                   : flot                  : ioBroker                                 -  enabled
          system.adapter.history.0                : history               : ioBroker                                 - disabled
        + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
          system.adapter.modbus.1                 : modbus                : ioBroker                                 - disabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
        + system.adapter.tibber.0                 : tibber                : ioBroker                                 -  enabled
          system.adapter.tibberconnect.0          : tibberconnect         : ioBroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
        + system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Upgrade policy: none
        Installed ioBroker-Instances
        Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
        Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
        Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "semp"         : 1.4.5    , installed 1.4.5
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Objects and States
        Objects:        6488
        States:         5380
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.1.217:2010      0.0.0.0:*               LISTEN      1001       15000      655/io.hm-rpc.1
        tcp        0      0 192.168.1.217:2001      0.0.0.0:*               LISTEN      1001       1768       640/io.hm-rpc.0
        tcp        0      0 192.168.1.217:9292      0.0.0.0:*               LISTEN      1001       1783       670/io.hm-rpc.2
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14816      501/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14811      501/iobroker.js-con
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13729      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14797      515/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17224      544/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16008      841/io.web.0
        tcp6       0      0 :::9765                 :::*                    LISTEN      1001       17623      872/io.semp.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          934        1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14799      515/sshd: /usr/sbin
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17625      872/io.semp.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14757      417/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1311       1/init
        udp6       0      0 :::111                  :::*                                0          1312       1/init
        2024-08-25 19:44:58.750  - info: mqtt.0 (685) Try to connect to mqtt://192.168.1.216:1883 with clientId=ioBroker.mqtt.0
        2024-08-25 19:44:58.811  - info: mqtt.0 (685) Connected to 192.168.1.216
        2024-08-25 19:44:58.812  - info: mqtt.0 (685) Subscribe on "#"
        2024-08-25 19:45:01.141  - info: host.ioBroker instance system.adapter.modbus.0 in version "6.2.3" started with pid 703
        2024-08-25 19:45:02.310  - info: modbus.0 (703) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.17.0, js-controller: 6.0.9
        2024-08-25 19:45:02.813  - info: modbus.0 (703) Connected to slave 192.168.1.236
        2024-08-25 19:45:04.449  - info: hm-rpc.2 (670) Connected
        2024-08-25 19:45:05.149  - info: host.ioBroker instance system.adapter.tibber.0 in version "0.3.1-beta" (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) started with pid 718
        2024-08-25 19:45:06.519  - info: tibber.0 (718) starting. Version 0.3.1-beta (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) in /opt/iobroker/node_modules/iobroker.tibber, node: v20.17.0, js-controller: 6.0.9
        2024-08-25 19:45:06.894  - info: tibber.0 (718) Tibber refresh success
        2024-08-25 19:45:09.217  - info: host.ioBroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 772
        2024-08-25 19:45:10.533  - info: vis-inventwo.0 (772) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.17.0, js-controller: 6.0.9
        2024-08-25 19:45:14.459  - info: vis.0 (801) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.9
        2024-08-25 19:45:15.948  - info: vis.0 (801) Terminated (NO_ERROR): Without reason
        2024-08-25 19:45:16.563  - info: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
        2024-08-25 19:45:17.198  - info: host.ioBroker instance system.adapter.web.0 in version "6.2.5" started with pid 841
        2024-08-25 19:45:18.951  - info: web.0 (841) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.9
        2024-08-25 19:45:19.078  - info: web.0 (841) socket.io server listening on port 8082
        2024-08-25 19:45:19.084  - info: web.0 (841) http server listening on port 8082
        2024-08-25 19:45:21.172  - info: host.ioBroker instance system.adapter.tibberconnect.0 in version "0.0.10" (non-npm: Codibris/ioBroker.tibberconnect#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83) started with pid 857
        2024-08-25 19:45:25.193  - info: host.ioBroker instance system.adapter.semp.0 in version "1.4.5" started with pid 872
        2024-08-25 19:45:26.860  - info: semp.0 (872) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.semp, node: v20.17.0, js-controller: 6.0.9
        2024-08-25 19:45:26.898  - error: semp.0 (872) Lambda wrong device SerialNr
        2024-08-25 19:45:26.900  - info: semp.0 (872) device created F-12287760-000000000001-00 Lambda
        2024-08-25 19:45:29.921  - info: semp.0 (872) adapter discovered by SHM
        @Homoran Habe ich davor neu gestartet, danke für den Hinweis.
        • B Burgsteff
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: n/a
                    RTC in local TZ: no
          burgsteff
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
                   3914 M total memory
                   1181 M used memory
                    124 M active memory
                   2583 M free memory
                     36 M buffer memory
                    331 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          745M    /var/
          348M    /var/cache
          343M    /var/cache/apt
          240M    /var/log
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          7.0.22
          javascript:     8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        6488
          States:         5380
          Pending Updates: 0
          usr/bin/npm 10.8.2
          da isses ja!
          dann müsstest du jetzt die fehlenden Updates machen können.
            Burgsteff
            Meeeeeeega, jetzt passt das wieder.
            Vielen herzlichen Dank 👏 👏 👏
            Was kann man euch Gutes tun?
            • B Burgsteff
              @burgsteff
              Gut, der ioBroker rennt wohl wieder.
              cat /etc/profile
              sagt?
                @burgsteff
                cat /etc/profile
                sagt?
                Burgsteff
                burgsteff@ioBroker:~$ cat /etc/profile
                # /etc/profile: system-wide .profile file for the Bourne shell (sh(1))
                # and Bourne compatible shells (bash(1), ksh(1), ash(1), ...).
                if [ "$(id -u)" -eq 0 ]; then
                  PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
                else
                  PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games"
                fi
                export PATH
                if [ "${PS1-}" ]; then
                  if [ "${BASH-}" ] && [ "$BASH" != "/bin/sh" ]; then
                    # The file bash.bashrc already sets the default PS1.
                    # PS1='\h:\w\$ '
                    if [ -f /etc/bash.bashrc ]; then
                      . /etc/bash.bashrc
                    fi
                  else
                      PS1='# '
                    else
                      PS1='$ '
                    fi
                  fi
                fi
                if [ -d /etc/profile.d ]; then
                  for i in /etc/profile.d/*.sh; do
                    if [ -r $i ]; then
                      . $i
                    fi
                  done
                  unset i
                fi
                • B Burgsteff
                  else
                  fi
                  export PATH
                      # PS1='\h:\w\$ '
                        . /etc/bash.bashrc
                      fi
                    else
                        PS1='# '
                      else
                        PS1='$ '
                      fi
                    fi
                  fi
                      if [ -r $i ]; then
                        . $i
                      fi
                    done
                    unset i
                  fi
                  @burgsteff
                  Das passt eigentlich. Lass es so.
                    @burgsteff
                    Burgsteff
                    Dann ist ja gut, perfekt.
                    Wirklich echt vielen Dank für die schnelle, kompetente und freundliche Hilfe.
                    • B Burgsteff
                      else
                      fi
                      export PATH
                          # PS1='\h:\w\$ '
                            . /etc/bash.bashrc
                          fi
                        else
                            PS1='# '
                          else
                            PS1='$ '
                          fi
                        fi
                      fi
                          if [ -r $i ]; then
                            . $i
                          fi
                        done
                        unset i
                      fi
                      @burgsteff
                      Trag mal in der Zeile 8 das ein:
                      PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
                        @burgsteff
                        Burgsteff
                        wie bzw. wo in Zeile 8?
                        • B Burgsteff
                          @burgsteff
                          sudo nano /etc/profile
                          Und dann statt
                          da
                          eintragen.
                          Mit STRG-O und STRG-X speichern und den Editor verlassen.
                          B 2 Antworten Letzte Antwort
                            @burgsteff
                            Und dann statt
                            da
                            eintragen.
                            Burgsteff
                            ok, hab ich gemacht. und nun?
                            • B Burgsteff
                              @burgsteff
                              Starte den Container mal neu.
                              Danach sollte dann auch bei
                              type -P usermod
                              der Pfad zurückgemeldet werden. Also so:
                              echad@chet:~ $ type -P usermod
                              /usr/sbin/usermod
                              echad@chet:~ $
                                @burgsteff
                                Und dann statt
                                da
                                eintragen.
                                Burgsteff
                                else
                                fi
                                export PATH
                                    # PS1='\h:\w\$ '
                                      . /etc/bash.bashrc
                                    fi
                                  else
                                      PS1='# '
                                    else
                                      PS1='$ '
                                    fi
                                  fi
                                fi
                                    if [ -r $i ]; then
                                      . $i
                                    fi
                                  done
                                  unset i
                                fi
                                so oder?
                                • B Burgsteff
                                  else
                                  fi
                                  export PATH
                                      # PS1='\h:\w\$ '
                                        . /etc/bash.bashrc
                                      fi
                                    else
                                        PS1='# '
                                      else
                                        PS1='$ '
                                      fi
                                    fi
                                  fi
                                      if [ -r $i ]; then
                                        . $i
                                      fi
                                    done
                                    unset i
                                  fi
                                  so oder?
                                  @burgsteff
                                  Ja.
                                    @burgsteff
                                    type -P usermod
                                    /usr/sbin/usermod
                                    echad@chet:~ $
                                    Burgsteff
                                    burgsteff@ioBroker:~$ type -P usermod
                                    /usr/sbin/usermod
                                    passt oder?
                                      @burgsteff
                                      Ja.
                                      Burgsteff
                                      was bedeutet das eigentlich noch? muss ich da noch was tun?
                                      • B Burgsteff
                                        @burgsteff was sagt denn sudo apt update?
                                        • B Burgsteff
                                          @burgsteff
                                          Ich glaube die libaom3 war eben schon dabei.
                                          Kannste 'Bestätigen und schließen'.
                                          System halt eigenständig regelmäßig aktuell halten:
                                          sudo apt update
                                          sudo apt full-upgrade
