  4. js-controller 6.0.x jetzt für alle User im STABLE!
    1.0k
    6.1k
controllerjs-controllerkierastable
257 Beiträge 47 Kommentatoren 88.2k Aufrufe 45 Beobachtet
  • J Offline
    Joe550
    #190
    Skript v.2024-05-22
    *** BASE SYSTEM ***
     Static hostname: smarthome
           Icon name: computer-desktop
             Chassis: desktop
    Operating System: Ubuntu 22.04.4 LTS
              Kernel: Linux 5.15.0-118-generic
        Architecture: x86-64
     Hardware Vendor: Intel Corporation
      Hardware Model: NUC6CAYH
    model name	: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     18:50:37 up  2:35,  2 users,  load average: 0.27, 0.23, 0.53
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Tue 2024-08-13 18:50:38 CEST
               Universal time: Tue 2024-08-13 16:50:38 UTC
                     RTC time: Tue 2024-08-13 16:50:38
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    smarthome
    HOME=/home/smarthome
    GROUPS=smarthome adm tty dialout cdrom sudo dip plugdev lxd sambashare lpadmin iobroker
    js-controller is not running
    *** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            7.8G        2.0G        2.3G         49M        3.5G        5.4G
    Swap:           2.0G          0B        2.0G
    Total:          9.8G        2.0G        4.3G
    Active iob-Instances: 	0
             7786 M total memory
             1998 M used memory
             1494 M active memory
             3230 M inactive memory
             2264 M free memory
              699 M buffer memory
             2824 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 18:50:38 up  2:35,  2 users,  load average: 0.27, 0.23, 0.53
    Tasks: 181 total,   2 running, 179 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 20.9 us,  7.5 sy,  0.0 ni, 71.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7786.7 total,   2263.8 free,   1999.0 used,   3523.9 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5427.5 avail Mem
    *** FAILED SERVICES ***
      UNIT               LOAD   ACTIVE SUB    DESCRIPTION
    * ureadahead.service loaded failed failed Read required files in advance
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    tmpfs          tmpfs  779M  2.9M  776M   1% /run
    /dev/sda2      ext4   219G   79G  129G  39% /
    tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1      vfat   511M  9.9M  502M   2% /boot/efi
    tmpfs          tmpfs  779M  4.0K  779M   1% /run/user/1000
    [Tue Aug 13 16:15:21 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Tue Aug 13 16:15:22 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
    Show mounted filesystems:
    TARGET                                        SOURCE                 FSTYPE      OPTIONS
    /                                             /dev/sda2              ext4        rw,relatime,errors=remount-ro
    |-/sys                                        sysfs                  sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                      securityfs             securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                            cgroup2                cgroup2     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/pstore                            pstore                 pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/firmware/efi/efivars                 efivarfs               efivarfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                               bpf                    bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                         debugfs                debugfs     rw,nosuid,nodev,noexec,relatime
    | | `-/sys/kernel/debug/tracing               tracefs                tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                       tracefs                tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections                  fusectl                fusectl     rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config                        configfs               configfs    rw,nosuid,nodev,noexec,relatime
    |-/proc                                       proc                   proc        rw,nosuid,nodev,noexec,relatime
    | `-/proc/sys/fs/binfmt_misc                  systemd-1              autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15291
    |   `-/proc/sys/fs/binfmt_misc                binfmt_misc            binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                        udev                   devtmpfs    rw,nosuid,relatime,size=3928256k,nr_inodes=982064,mode=755,inode64
    | |-/dev/pts                                  devpts                 devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                  tmpfs                  tmpfs       rw,nosuid,nodev,inode64
    | |-/dev/hugepages                            hugetlbfs              hugetlbfs   rw,relatime,pagesize=2M
    | `-/dev/mqueue                               mqueue                 mqueue      rw,nosuid,nodev,noexec,relatime
    |-/run                                        tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=797364k,mode=755,inode64
    | |-/run/lock                                 tmpfs                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
    | |-/run/credentials/systemd-sysusers.service none                   ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/rpc_pipefs                           sunrpc                 rpc_pipefs  rw,relatime
    | |-/run/user/1000                            tmpfs                  tmpfs       rw,nosuid,nodev,relatime,size=797360k,nr_inodes=199340,mode=700,uid=1000,gid=1000,inode64
    | `-/run/snapd/ns                             tmpfs[/snapd/ns]       tmpfs       rw,nosuid,nodev,noexec,relatime,size=797364k,mode=755,inode64
    |   |-/run/snapd/ns/lxd.mnt                   nsfs[mnt:[4026532578]] nsfs        rw
    |   `-/run/snapd/ns/canonical-livepatch.mnt   nsfs[mnt:[4026532579]] nsfs        rw
    |-/snap/canonical-livepatch/282               /dev/loop0             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/canonical-livepatch/278               /dev/loop1             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core/16928                            /dev/loop2             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core18/2823                           /dev/loop3             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core18/2829                           /dev/loop5             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core/17200                            /dev/loop4             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core20/2264                           /dev/loop6             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core20/2318                           /dev/loop7             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core22/1380                           /dev/loop8             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core22/1439                           /dev/loop9             squashfs    ro,nodev,relatime,errors=continue
    |-/snap/lxd/24061                             /dev/loop10            squashfs    ro,nodev,relatime,errors=continue
    |-/snap/lxd/29619                             /dev/loop11            squashfs    ro,nodev,relatime,errors=continue
    |-/boot/efi                                   /dev/sda1              vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
    `-/var/lib/lxcfs                              lxcfs                  fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
    /var:
    46G	/var/
    38G	/var/www/nextcloud
    38G	/var/www
    37G	/var/www/nextcloud/data
    28G	/var/www/nextcloud/data/joe/files
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    2.1G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    964M	/opt/iobroker/iobroker-data/
    748M	/opt/iobroker/iobroker-data/files
    442M	/opt/iobroker/iobroker-data/files/javascript.admin
    409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    27M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
    19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DM00ZYB7-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.16.0
    /usr/bin/node 		v20.16.0
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.28.2
    nodejs:
      Installed: 20.16.0-1nodesource1
      Candidate: 20.16.0-1nodesource1
      Version table:
     *** 20.16.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         12.22.9~dfsg-1ubuntu3.6 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1148
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
        at Module._load (node:internal/modules/cjs/loader:986:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
        at node:internal/main/run_main_module:28:49 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v20.16.0
    Core adapters versions
      throw err;
      requireStack: []
    Node.js v20.16.0
    js-controller:
      throw err;
      requireStack: []
    Node.js v20.16.0
    admin:
      throw err;
      requireStack: []
    Node.js v20.16.0
    javascript:
    nodejs modules from github: 	0
    Adapter State
    ioBroker-Repositories
      throw err;
      requireStack: []
    Node.js v20.16.0
    Installed ioBroker-Instances
      throw err;
      requireStack: []
    Node.js v20.16.0
    Objects and States
    Objects: 	0
    States: 	0
    Hit:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:6 https://esm.ubuntu.com/apps/ubuntu jammy-apps-security InRelease
    Hit:7 https://esm.ubuntu.com/apps/ubuntu jammy-apps-updates InRelease
    Hit:8 https://esm.ubuntu.com/infra/ubuntu jammy-infra-security InRelease
    Hit:9 https://esm.ubuntu.com/infra/ubuntu jammy-infra-updates InRelease
    Hit:10 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      113        26362      1004/mariadbd
    tcp        0      0 0.0.0.0:555             0.0.0.0:*               LISTEN      0          30490      1377/perl
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          28373      687/deCONZ
    tcp        0      0 192.168.178.33:53       0.0.0.0:*               LISTEN      110        29197      827/named
    tcp        0      0 192.168.178.33:53       0.0.0.0:*               LISTEN      110        29198      827/named
    tcp        0      0 192.168.178.33:53       0.0.0.0:*               LISTEN      110        29196      827/named
    tcp        0      0 192.168.178.33:53       0.0.0.0:*               LISTEN      110        29195      827/named
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19982      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30780      1265/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          29404      1291/smbd
    tcp        0      0 0.0.0.0:20877           0.0.0.0:*               LISTEN      0          29891      687/deCONZ
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          29403      1291/smbd
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      114        26317      804/redis-server 12
    tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          29415      1303/perl
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        28272      661/systemd-resolve
    tcp        0      0 127.0.0.1:11211         0.0.0.0:*               LISTEN      115        28837      801/memcached
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      110        29836      827/named
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      110        29835      827/named
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      110        29834      827/named
    tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      110        29833      827/named
    tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      110        28404      827/named
    tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      110        28403      827/named
    tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      110        28402      827/named
    tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      110        28401      827/named
    tcp6       0      0 :::80                   :::*                    LISTEN      0          30301      1272/apache2
    tcp6       0      0 :::111                  :::*                    LISTEN      0          19983      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          30782      1265/sshd: /usr/sbi
    tcp6       0      0 :::139                  :::*                    LISTEN      0          29402      1291/smbd
    tcp6       0      0 :::445                  :::*                    LISTEN      0          29401      1291/smbd
    tcp6       0      0 :::443                  :::*                    LISTEN      0          30305      1272/apache2
    tcp6       0      0 fe80::96c6:91ff:fea0:53 :::*                    LISTEN      110        28634      827/named
    tcp6       0      0 fe80::96c6:91ff:fea0:53 :::*                    LISTEN      110        29153      827/named
    tcp6       0      0 fe80::96c6:91ff:fea0:53 :::*                    LISTEN      110        29152      827/named
    tcp6       0      0 fe80::96c6:91ff:fea0:53 :::*                    LISTEN      110        29151      827/named
    tcp6       0      0 ::1:53                  :::*                    LISTEN      110        29841      827/named
    tcp6       0      0 ::1:53                  :::*                    LISTEN      110        29842      827/named
    tcp6       0      0 ::1:53                  :::*                    LISTEN      110        29843      827/named
    tcp6       0      0 ::1:53                  :::*                    LISTEN      110        29844      827/named
    tcp6       0      0 ::1:953                 :::*                    LISTEN      110        28413      827/named
    tcp6       0      0 ::1:953                 :::*                    LISTEN      110        28412      827/named
    tcp6       0      0 ::1:953                 :::*                    LISTEN      110        28410      827/named
    tcp6       0      0 ::1:953                 :::*                    LISTEN      110        28411      827/named
    tcp6       0      0 2003:c2:ef2f:6e00:96:53 :::*                    LISTEN      110        26528      827/named
    tcp6       0      0 2003:c2:ef2f:6e00:96:53 :::*                    LISTEN      110        26529      827/named
    tcp6       0      0 2003:c2:ef2f:6e00:96:53 :::*                    LISTEN      110        26530      827/named
    tcp6       0      0 2003:c2:ef2f:6e00:96:53 :::*                    LISTEN      110        26527      827/named
    tcp6       0      0 ::1:6379                :::*                    LISTEN      114        26318      804/redis-server 12
    udp        0      0 0.0.0.0:48543           0.0.0.0:*                           112        26074      680/avahi-daemon: r
    udp        0      0 192.168.178.33:53       0.0.0.0:*                           110        29193      827/named
    udp        0      0 192.168.178.33:53       0.0.0.0:*                           110        29194      827/named
    udp        0      0 192.168.178.33:53       0.0.0.0:*                           110        29192      827/named
    udp        0      0 192.168.178.33:53       0.0.0.0:*                           110        29191      827/named
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           110        29832      827/named
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           110        29831      827/named
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           110        29830      827/named
    udp        0      0 127.0.0.1:53            0.0.0.0:*                           110        29829      827/named
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        28271      661/systemd-resolve
    udp        0      0 192.168.178.33:68       0.0.0.0:*                           100        26542      618/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15303      1/init
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          30822      1238/nmbd
    udp        0      0 192.168.178.33:137      0.0.0.0:*                           0          30821      1238/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          30806      1238/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          30824      1238/nmbd
    udp        0      0 192.168.178.33:138      0.0.0.0:*                           0          30823      1238/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          30807      1238/nmbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        26070      680/avahi-daemon: r
    udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          29416      1303/perl
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          29037      687/deCONZ
    udp6       0      0 ::1:53                  :::*                                110        29837      827/named
    udp6       0      0 ::1:53                  :::*                                110        29838      827/named
    udp6       0      0 ::1:53                  :::*                                110        29839      827/named
    udp6       0      0 ::1:53                  :::*                                110        29840      827/named
    udp6       0      0 fe80::96c6:91ff:fea0:53 :::*                                110        29142      827/named
    udp6       0      0 fe80::96c6:91ff:fea0:53 :::*                                110        28602      827/named
    udp6       0      0 fe80::96c6:91ff:fea0:53 :::*                                110        29150      827/named
    udp6       0      0 fe80::96c6:91ff:fea0:53 :::*                                110        28633      827/named
    udp6       0      0 2003:c2:ef2f:6e00:96:53 :::*                                110        26526      827/named
    udp6       0      0 2003:c2:ef2f:6e00:96:53 :::*                                110        26525      827/named
    udp6       0      0 2003:c2:ef2f:6e00:96:53 :::*                                110        26524      827/named
    udp6       0      0 2003:c2:ef2f:6e00:96:53 :::*                                110        28638      827/named
    udp6       0      0 :::111                  :::*                                0          15632      1/init
    udp6       0      0 :::53572                :::*                                112        26075      680/avahi-daemon: r
    udp6       0      0 fe80::96c6:91ff:fea:546 :::*                                100        26519      618/systemd-network
    udp6       0      0 :::50215                :::*                                0          30787      687/deCONZ
    udp6       0      0 :::5353                 :::*                                112        26071      680/avahi-daemon: r
    2024-08-13 18:23:51.507  - info: host.smarthome stopInstance system.adapter.ical.1 (force=false, process=false)
    2024-08-13 18:23:51.508  - info: host.smarthome stopInstance system.adapter.mihome-vacuum.0 (force=false, process=false)
    2024-08-13 18:23:51.508  - info: host.smarthome stopInstance system.adapter.mihome-vacuum.1 (force=false, process=false)
    2024-08-13 18:23:51.509  - info: host.smarthome stopInstance system.adapter.ping.0 (force=false, process=false)
    2024-08-13 18:23:51.509  - info: host.smarthome stopInstance system.adapter.pollenflug.0 (force=false, process=false)
    2024-08-13 18:23:51.510  - info: host.smarthome stopInstance system.adapter.sonoff.0 (force=false, process=false)
    2024-08-13 18:23:51.510  - info: host.smarthome stopInstance system.adapter.tr-064.0 (force=false, process=false)
    2024-08-13 18:23:51.511  - info: host.smarthome stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
    2024-08-13 18:23:51.511  - info: host.smarthome stopInstance system.adapter.alexa2.0 (force=false, process=false)
    2024-08-13 18:23:51.511  - info: host.smarthome stopInstance system.adapter.birthdays.0 (force=false, process=false)
    2024-08-13 18:23:51.512  - info: host.smarthome stopInstance system.adapter.ble.0 (force=false, process=false)
    2024-08-13 18:23:51.512  - info: host.smarthome stopInstance system.adapter.daswetter.0 (force=false, process=false)
    2024-08-13 18:23:51.512  - info: host.smarthome stopInstance system.adapter.discovery.0 (force=false, process=false)
    2024-08-13 18:23:51.513  - info: host.smarthome stopInstance system.adapter.icons-mfd-png.0 (force=false, process=false)
    2024-08-13 18:23:51.513  - info: host.smarthome stopInstance system.adapter.icons-ultimate-png.0 (force=false, process=false)
    2024-08-13 18:23:51.513  - info: host.smarthome stopInstance system.adapter.info.0 (force=false, process=false)
    2024-08-13 18:23:51.513  - info: host.smarthome stopInstance system.adapter.iot.0 (force=false, process=false)
    2024-08-13 18:23:51.514  - info: host.smarthome stopInstance system.adapter.mobile.0 (force=false, process=false)
    2024-08-13 18:23:51.514  - info: host.smarthome stopInstance system.adapter.terminal.0 (force=false, process=false)
    2024-08-13 18:23:51.514  - info: host.smarthome stopInstance system.adapter.text2command.0 (force=false, process=false)
    2024-08-13 18:23:51.514  - info: host.smarthome stopInstance system.adapter.trashschedule.0 (force=false, process=false)
    2024-08-13 18:23:51.514  - info: host.smarthome stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
    2024-08-13 18:23:51.514  - info: host.smarthome stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
    2024-08-13 18:23:51.515  - info: host.smarthome stopInstance system.adapter.vis.0 (force=false, process=false)
    2024-08-13 18:23:51.515  - info: host.smarthome stopInstance system.adapter.web.0 (force=false, process=false)
    • J Joe550
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Chassis: desktop
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      smarthome
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           2.0G          0B        2.0G
               7786 M total memory
               1998 M used memory
               2264 M free memory
                699 M buffer memory
               2824 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      /var:
      46G	/var/
      38G	/var/www
      USB-Devices by-id:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
        throw err;
        requireStack: []
      Node.js v20.16.0
        throw err;
        requireStack: []
      Node.js v20.16.0
      js-controller:
        throw err;
        requireStack: []
      Node.js v20.16.0
      admin:
        throw err;
        requireStack: []
      Node.js v20.16.0
      javascript:
      Adapter State
        throw err;
        requireStack: []
      Node.js v20.16.0
        throw err;
        requireStack: []
      Node.js v20.16.0
      Objects and States
      Objects: 	0
      States: 	0
      Pending Updates: 0
      #191
      @joe550
      iob stop
      sudo apt update
      sudo apt install --reinstall nodejs
      cd /opt/iobroker
      npm install iobroker.js-controller@6.0.9
      iob fix
      iob start
      Nix mit root, nix mit sudo (außer halt apt), nix mit npm global reinklatschen.
      • J Offline
        Joe550
        #192
        jetzt startet der iobroker in kurzen Abständen immer neu.
        Der iobroker bleibt immer nur für wenige Sekunden da, hängt sich auf und startet neu.
        Im Log ist eine Anzeige, dass der js-controller nicht gefunden wird.
        Das Bild stand immer zu kurz, so dass ich kein Screenshot machen konnte
        • J Joe550
          #193
          @joe550 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
          Will ich eh nicht sehen.
          Schau in's Log:
          iob logs --watch
          • J Offline
            Joe550
            schrieb am zuletzt editiert von Joe550
            #194
            @thomas-braun sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
            iob logs --watch
            2024-08-13 19:25:32.571  - info: host.smarthome Delete state "system.host.smarthome.versions.npmNewest"
            2024-08-13 19:25:32.620  - info: host.smarthome Delete state "system.host.smarthome.versions.npmNewestNext"
            2024-08-13 19:25:32.627  - info: host.smarthome Some obsolete host states deleted.
            2024-08-13 19:25:34.781  - info: host.smarthome iobroker npm-install: NPM version: 10.8.1
            2024-08-13 19:25:34.783  - info: host.smarthome iobroker npm-install: Installing iobroker.icons-mfd-png@1.2.1... (System call)
            2024-08-13 19:25:35.311  - info: admin.0 (92249) starting. Version 7.0.22 in /opt/iobroker/node_modules/iobroker.admin, node: v20.16.0, js-controller: 6.0.9
            2024-08-13 19:25:35.351  - info: admin.0 (92249) requesting all objects
            2024-08-13 19:25:37.131  - info: admin.0 (92249) received all objects
            2024-08-13 19:25:37.776  - info: admin.0 (92249) Secure socket.io server listening on port 8081
            2024-08-13 19:25:37.781  - info: admin.0 (92249) https server listening on port 8081
            2024-08-13 19:25:37.781  - info: admin.0 (92249) Use link "https://127.0.0.1:8081" to configure.
            2024-08-13 19:25:48.401  - error: host.smarthome uncaught exception: Could not determine controller directory
            2024-08-13 19:25:48.402  - error: host.smarthome Error: Could not determine controller directory
                at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1853:11)
                at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1323:37)
                at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3223:30)
            Das sind die Fehler, die immer wieder angezeigt werden.
            Die als fehlend bemängelten Dateien tools.js und main.js sind aber an den genannten Stellen vorhanden
            • J Joe550
              iob logs --watch
              #195
              @joe550
              Was sagt denn der
              iob fix
              zu der Geschichte?
              • J Offline
                Joe550
                #196
                der iob fix läuft ohne meckern durch.
                Habe dann noch immer die gleichen Fehlermeldungen
                JoJo58J 1 Antwort Letzte Antwort
                • J Joe550
                  JoJo58J Offline
                  JoJo58J Offline
                  JoJo58
                  #197
                  Moin Zusammen,
                  ich habe letzte Woche auch die Version 6.0.9 installiert und auf meinem Produktivsystem lief danach alles normal weiter. Mir ist aber aufgefallen das in den letzten Tagen die Reaktion des IOB langsamer ist. Bewegungsmelder schalten das Licht erst nach etwa 2 Sekunden ein und das war vorher nicht so, meine ich zumindest. Wenn ich im IOB unter Hosts nachsehe, ist die CPU im Schnitt bei über 50%. Gestern Linuxupdates gemacht und danach war die Auslastung bei 106%. Also das System aus einem Snapshot, das ich vorher erstellt hatte, wiederhergestellt.
                  Ich würde jetzt gerne (zum Testen) auf den js-controller 5.x zurückgehen und dann mal sehen wie die Auslastung usw. ist.
                  Kann ich das problemlos machen? Wenn ja, wie? Ich habe dazu keine Anleitung gefunden?
                  Gruß, Johannes
                  Intel NUC i7 64GB 1TB SSD - Proxmox - Raspi 4 8GB 500 GB SSD - Raspi 4 4GB 500GB SSD - Qnap 16TB - CCU3 - Fritz 6591 Cable - Green Cell USV 1500VA
                  Sonoff CC2652P - HUE Bridge - Broadlink RM4 pro u. RM3 mini - 5 x Echo - 1 x Samsung STab 8 - 54 x HM und HMIP - 32 x Zigbee - 2 x Shelly 3EM.
                  Einfach ein tolles Hobby :-)
                  • JoJo58J JoJo58
                    Moin Zusammen,
                    Gruß, Johannes
                    crunchipC Offline
                    crunchipC Offline
                    #198
                    @jojo58 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                    Steht im ersten Beitrag
                      JoJo58J Offline
                      JoJo58J Offline
                      JoJo58
                      #199
                      @crunchip
                      Okay, das hatte ich echt überlesen. Sorry. Was da nicht steht, man musste vorher in den Ordner IoBroker wechseln, zumindest war es bei mir so.
                      Nachdem ich zurück auf die Version 5.0.19 bin, liegt die durchschnittliche Auslastung bei 40%, anstatt wie bei 6.0.9 bei über 50% und auch die Bewegungsmelder schalten wieder sofort. Jemand eine Idee, was das sein kann?
                      Ich installiere jetzt nochmal die 6.0.9 und mal sehen ob es immer noch so ist.
                      JoJo58J crunchipC 2 Antworten Letzte Antwort
                      • JoJo58J JoJo58
                        @crunchip
                        JoJo58J Offline
                        JoJo58J Offline
                        JoJo58
                        #200
                        Also, folgender Stand:
                        Version 5.0.19: Auslastung unter Hosts zwischen 30% und 55%. Bewegungsmelder reagieren sofort und Licht geht sofort an.
                        Version 6.0.9 : Auslastung unter Hosts zwischen 50% und 80%. Bewegungsmelder und damit das Licht einschalten und andere Aktionen, reagieren verzögert. Etwa 1 bis 1,5 Sekunden.
                        Was kann ich tun im das Problem zu lösen, oder einzugrenzen? Oder muss ich jetzt damit leben?
                        Das System Bookworm ist auf aktuellem Stand und auch alle Adapter sind aktuell. Das System läuft auf Proxmox mit 8 CPUs und 12 GB Ram. Ich habe zwar etliche Adapter installiert, da aber unter 5.0.19 alles okay ist, sollte es damit nichts zu tun haben.
                        Oder soll ich die Version 6.0.10 mal testen? Ich weiß im Moment nicht weiter.
                        • JoJo58J JoJo58
                          @crunchip
                          crunchipC Offline
                          crunchipC Offline
                          #201
                          Nicht nur bei dir, das ist immer der Fall
                          • JoJo58J JoJo58
                            #202
                            @jojo58
                            Schau dir das Gesamtkonstrukt an. Mittels
                            iob diag
                            am besten.
                            • JoJo58J JoJo58
                              crunchipC Offline
                              crunchipC Offline
                              #203
                              Mehr Informationen liefern, Beginnend mit der Ausgabe
                              iob diag
                                iob diag
                                JoJo58J Offline
                                JoJo58J Offline
                                JoJo58
                                #204
                                @crunchip @Thomas-Braun
                                Hier das Ergebnis:
                                Summary:
                                                       v.2024-05-22
                                Static hostname: vm-iobroker
                                      Icon name: computer-vm
                                        Chassis: vm 🖴
                                 Virtualization: kvm
                                         Kernel: Linux 6.1.0-23-amd64
                                Hardware Vendor: QEMU
                                 Hardware Model: Standard PC _i440FX + PIIX, 1996_
                                Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                                Installation:           kvm
                                Kernel:                 x86_64
                                Userland:               64 bit
                                User-ID:                1000
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                Recommended versions are nodejs 20.16.0 and npm 10.8.1
                                MEMORY:
                                Mem:             16G        5.7G         10G        1.1M        1.4G         11G
                                Swap:           1.0G          0B        1.0G
                                Total:           17G        5.7G         11G
                                Active iob-Instances:   62
                                Upgrade policy: none
                                ioBroker Core:          js-controller           6.0.9
                                                       admin                   7.0.22
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : vm-iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : vm-iobroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.1                    : web                   : vm-iobroker                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                                Objects:                72049
                                States:                 65059
                                Size of iob-Database:
                                129M    /opt/iobroker/iobroker-data/objects.jsonl
                                236M    /opt/iobroker/iobroker-data/states.jsonl
                                Langfassung:
                                Skript v.2024-05-22
                                *** BASE SYSTEM ***
                                        Chassis: vm 🖴
                                 Virtualization: kvm
                                model name      : QEMU Virtual CPU version 2.5+
                                Docker          : false
                                Virtualization  : kvm
                                Kernel          : x86_64
                                Userland        : 64 bit
                                12:40:31 up 37 min,  2 users,  load average: 0.98, 1.28, 1.06
                                CPU threads: 8
                                              Local time: Fri 2024-08-16 12:40:31 CEST
                                          Universal time: Fri 2024-08-16 10:40:31 UTC
                                                RTC time: Fri 2024-08-16 10:40:31
                                             NTP service: active
                                         RTC in local TZ: no
                                smarthome
                                GROUPS=smarthome cdrom floppy audio dip video plugdev users netdev bluetooth lpadmin scanner iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev bluetooth redis
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:             16G        5.7G         10G        1.1M        1.3G         11G
                                Swap:           1.0G          0B        1.0G
                                Total:           17G        5.7G         11G
                                       15991 M total memory
                                        5451 M used memory
                                         440 M active memory
                                        5533 M inactive memory
                                        9620 M free memory
                                          89 M buffer memory
                                        1121 M swap cache
                                         974 M total swap
                                           0 M used swap
                                         974 M free swap
                                top - 12:40:31 up 37 min,  2 users,  load average: 0.98, 1.28, 1.06
                                Tasks: 235 total,   3 running, 232 sleeping,   0 stopped,   0 zombie
                                %Cpu(s): 40.0 us,  0.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :  15991.7 total,   9624.3 free,   5447.1 used,   1210.9 buff/cache
                                MiB Swap:    975.0 total,    975.0 free,      0.0 used.  10544.6 avail Mem
                                * networking.service loaded failed failed Raise network interfaces
                                *** FILESYSTEM ***
                                udev                  devtmpfs  7.8G     0  7.8G   0% /dev
                                tmpfs                 tmpfs     1.6G 1008K  1.6G   1% /run
                                /dev/sda1             ext4       62G   44G   16G  74% /
                                tmpfs                 tmpfs     7.9G     0  7.9G   0% /dev/shm
                                tmpfs                 tmpfs     5.0M     0  5.0M   0% /run/lock
                                192.168.1.6:/RasPi-BU nfs        11T  9.6T  1.2T  89% /mnt/backup
                                tmpfs                 tmpfs     1.6G   28K  1.6G   1% /run/user/1000
                                [Fri Aug 16 12:03:05 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                [Fri Aug 16 12:03:05 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                /                                                       /dev/sda1             ext4            rw,relatime,errors=remount-ro
                                | |-/sys/fs/cgroup                                      cgroup2               cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                | `-/proc/sys/fs/binfmt_misc                            systemd-1             autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13983
                                |-/dev                                                  udev                  devtmpfs        rw,nosuid,relatime,size=8155500k,nr_inodes=2038875,mode=755,inode64
                                | `-/dev/hugepages                                      hugetlbfs             hugetlbfs       rw,relatime,pagesize=2M
                                |-/run                                                  tmpfs                 tmpfs           rw,nosuid,nodev,noexec,relatime,size=1637556k,mode=755,inode64
                                | |-/run/credentials/systemd-sysusers.service           ramfs                 ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                                | |-/run/credentials/systemd-sysctl.service             ramfs                 ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                                | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                 ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                                | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                 ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                                | `-/run/user/1000                                      tmpfs                 tmpfs           rw,nosuid,nodev,relatime,size=1637552k,nr_inodes=409388,mode=700,uid=1000,gid=1000,inode64
                                |   `-/run/user/1000/gvfs                               gvfsd-fuse            fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                `-/mnt/backup                                           192.168.1.6:/RasPi-BU nfs             rw,relatime,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.6,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.1.6
                                /var:
                                4.9G    /var/
                                2.9G    /var/log/journal/16b2cb0d6af74575856d4757cf8a865a
                                2.9G    /var/log
                                1.7G    /var/cache/apt
                                Archived and active journals take up 2.0G in the file system.
                                25G     /opt/iobroker/backups/
                                1.8G    /opt/iobroker/iobroker-data/
                                1.2G    /opt/iobroker/iobroker-data/files
                                441M    /opt/iobroker/iobroker-data/files/javascript.admin
                                208M    /opt/iobroker/iobroker-data/states.jsonl
                                41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                HINT:
                                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                /dev/ttyUSB0
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                 Version table:
                                *** 20.16.0-1nodesource1 1001
                                    20.15.1-1nodesource1 1001
                                    20.15.0-1nodesource1 1001
                                    20.14.0-1nodesource1 1001
                                    20.13.1-1nodesource1 1001
                                    20.13.0-1nodesource1 1001
                                    20.12.2-1nodesource1 1001
                                    20.12.1-1nodesource1 1001
                                    20.12.0-1nodesource1 1001
                                    20.11.1-1nodesource1 1001
                                    20.11.0-1nodesource1 1001
                                    20.10.0-1nodesource1 1001
                                    20.9.0-1nodesource1 1001
                                    20.8.1-1nodesource1 1001
                                    20.8.0-1nodesource1 1001
                                    20.7.0-1nodesource1 1001
                                    20.6.1-1nodesource1 1001
                                    20.6.0-1nodesource1 1001
                                    20.5.1-1nodesource1 1001
                                    20.5.0-1nodesource1 1001
                                    20.4.0-1nodesource1 1001
                                    20.3.1-1nodesource1 1001
                                    20.3.0-1nodesource1 1001
                                    20.2.0-1nodesource1 1001
                                    20.1.0-1nodesource1 1001
                                    20.0.0-1nodesource1 1001
                                    18.19.0+dfsg-6~deb12u2 500
                                       500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                    18.19.0+dfsg-6~deb12u1 500
                                       500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          7.0.22
                                javascript:     8.7.6
                                nodejs modules from github:     6
                                +-- iobroker.alexa2@3.26.5 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#37160cf729a9c70ca70679d4b1d3c16ba51c6456)
                                +-- iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
                                +-- iobroker.life360@0.2.22 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1)
                                +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
                                +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
                                Adapter State
                                + system.adapter.alexa2.0                 : alexa2                : vm-iobroker                              -  enabled
                                 system.adapter.alias-manager.0          : alias-manager         : vm-iobroker                              - disabled
                                + system.adapter.backitup.0               : backitup              : vm-iobroker                              -  enabled
                                + system.adapter.backitup.1               : backitup              : vm-iobroker                              -  enabled
                                + system.adapter.broadlink2.0             : broadlink2            : vm-iobroker                              -  enabled
                                + system.adapter.cloud.0                  : cloud                 : vm-iobroker                              -  enabled
                                + system.adapter.cloud.1                  : cloud                 : vm-iobroker                              -  enabled
                                 system.adapter.daswetter.0              : daswetter             : vm-iobroker                              -  enabled
                                + system.adapter.device-reminder.0        : device-reminder       : vm-iobroker                              -  enabled
                                + system.adapter.device-watcher.0         : device-watcher        : vm-iobroker                              -  enabled
                                 system.adapter.devices.0                : devices               : vm-iobroker                              - disabled
                                + system.adapter.discovery.0              : discovery             : vm-iobroker                              -  enabled
                                + system.adapter.drops-weather.0          : drops-weather         : vm-iobroker                              -  enabled
                                 system.adapter.dwd.0                    : dwd                   : vm-iobroker                              -  enabled
                                + system.adapter.echarts.0                : echarts               : vm-iobroker                              -  enabled
                                + system.adapter.email.0                  : email                 : vm-iobroker                              -  enabled
                                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : vm-iobroker                              -  enabled
                                 system.adapter.feiertage.0              : feiertage             : vm-iobroker                              -  enabled
                                 system.adapter.flot.0                   : flot                  : vm-iobroker                              - disabled
                                + system.adapter.fullybrowser.0           : fullybrowser          : vm-iobroker                              -  enabled
                                + system.adapter.hm-rega.0                : hm-rega               : vm-iobroker                              -  enabled
                                + system.adapter.hm-rpc.0                 : hm-rpc                : vm-iobroker                              -  enabled, port: 0
                                + system.adapter.hm-rpc.1                 : hm-rpc                : vm-iobroker                              -  enabled, port: 0
                                + system.adapter.hm-rpc.3                 : hm-rpc                : vm-iobroker                              -  enabled, port: 0
                                + system.adapter.hue.0                    : hue                   : vm-iobroker                              -  enabled, port: 443
                                 system.adapter.ical.0                   : ical                  : vm-iobroker                              -  enabled
                                 system.adapter.ical.1                   : ical                  : vm-iobroker                              -  enabled
                                 system.adapter.iceroad.0                : iceroad               : vm-iobroker                              -  enabled
                                 system.adapter.icons-icons8.0           : icons-icons8          : vm-iobroker                              - disabled
                                 system.adapter.icons-mfd-png.0          : icons-mfd-png         : vm-iobroker                              - disabled
                                 system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : vm-iobroker                              - disabled
                                + system.adapter.influxdb.0               : influxdb              : vm-iobroker                              -  enabled, port: 8086
                                + system.adapter.info.0                   : info                  : vm-iobroker                              -  enabled
                                + system.adapter.iot.0                    : iot                   : vm-iobroker                              -  enabled
                                + system.adapter.javascript.0             : javascript            : vm-iobroker                              -  enabled
                                 system.adapter.life360.0                : life360               : vm-iobroker                              - disabled
                                + system.adapter.linux-control.0          : linux-control         : vm-iobroker                              -  enabled
                                + system.adapter.logparser.0              : logparser             : vm-iobroker                              -  enabled
                                 system.adapter.material.0               : material              : vm-iobroker                              - disabled
                                 system.adapter.meteoalarm.0             : meteoalarm            : vm-iobroker                              -  enabled
                                 system.adapter.meteoalarm.1             : meteoalarm            : vm-iobroker                              -  enabled
                                 system.adapter.meteoalarm.2             : meteoalarm            : vm-iobroker                              -  enabled
                                 system.adapter.meteoalarm.3             : meteoalarm            : vm-iobroker                              -  enabled
                                + system.adapter.mqtt.0                   : mqtt                  : vm-iobroker                              -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.net-tools.0              : net-tools             : vm-iobroker                              -  enabled
                                + system.adapter.notification-manager.0   : notification-manager  : vm-iobroker                              -  enabled
                                + system.adapter.nuki-extended.0          : nuki-extended         : vm-iobroker                              -  enabled
                                + system.adapter.nut.0                    : nut                   : vm-iobroker                              -  enabled
                                + system.adapter.operating-hours.0        : operating-hours       : vm-iobroker                              -  enabled
                                + system.adapter.parcel.0                 : parcel                : vm-iobroker                              -  enabled
                                + system.adapter.parcel.1                 : parcel                : vm-iobroker                              -  enabled
                                + system.adapter.ping.0                   : ping                  : vm-iobroker                              -  enabled
                                + system.adapter.pollenflug.0             : pollenflug            : vm-iobroker                              -  enabled
                                + system.adapter.proxmox.0                : proxmox               : vm-iobroker                              -  enabled, port: 8006
                                + system.adapter.pushover.0               : pushover              : vm-iobroker                              -  enabled
                                + system.adapter.pushover.1               : pushover              : vm-iobroker                              -  enabled
                                + system.adapter.pushover.2               : pushover              : vm-iobroker                              -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : vm-iobroker                              -  enabled
                                + system.adapter.samsung_tizen.0          : samsung_tizen         : vm-iobroker                              -  enabled, port: 8002
                                + system.adapter.scenes.0                 : scenes                : vm-iobroker                              -  enabled
                                 system.adapter.schoolfree.0             : schoolfree            : vm-iobroker                              -  enabled
                                + system.adapter.shelly.0                 : shelly                : vm-iobroker                              -  enabled, port: 1882, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : vm-iobroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.snmp.0                   : snmp                  : vm-iobroker                              -  enabled
                                + system.adapter.socketio.0               : socketio              : vm-iobroker                              -  enabled, port: 8094, bind: 0.0.0.0, run as: admin
                                + system.adapter.sourceanalytix.0         : sourceanalytix        : vm-iobroker                              -  enabled
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : vm-iobroker                              -  enabled
                                + system.adapter.telegram.0               : telegram              : vm-iobroker                              -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.text2command.0           : text2command          : vm-iobroker                              -  enabled
                                + system.adapter.tr-064.0                 : tr-064                : vm-iobroker                              -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : vm-iobroker                              -  enabled
                                + system.adapter.upnp.0                   : upnp                  : vm-iobroker                              -  enabled
                                 system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : vm-iobroker                              - disabled
                                 system.adapter.vis-colorpicker.0        : vis-colorpicker       : vm-iobroker                              - disabled
                                 system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : vm-iobroker                              - disabled
                                 system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : vm-iobroker                              - disabled
                                 system.adapter.vis-icontwo.0            : vis-icontwo           : vm-iobroker                              - disabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : vm-iobroker                              -  enabled
                                 system.adapter.vis-justgage.0           : vis-justgage          : vm-iobroker                              - disabled
                                 system.adapter.vis-map.0                : vis-map               : vm-iobroker                              - disabled
                                 system.adapter.vis-material-advanced.0  : vis-material-advanced : vm-iobroker                              - disabled
                                 system.adapter.vis-material-webfont.0   : vis-material-webfont  : vm-iobroker                              - disabled
                                 system.adapter.vis-materialdesign.0     : vis-materialdesign    : vm-iobroker                              - disabled
                                 system.adapter.vis-metro.0              : vis-metro             : vm-iobroker                              - disabled
                                 system.adapter.vis-owl.0                : vis-owl               : vm-iobroker                              - disabled
                                 system.adapter.vis-timeandweather.0     : vis-timeandweather    : vm-iobroker                              - disabled
                                 system.adapter.vis-weather.0            : vis-weather           : vm-iobroker                              - disabled
                                 system.adapter.vis.0                    : vis                   : vm-iobroker                              -  enabled
                                 system.adapter.weatherunderground.0     : weatherunderground    : vm-iobroker                              -  enabled
                                + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : vm-iobroker                              -  enabled
                                + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : vm-iobroker                              -  enabled
                                + system.adapter.ws.0                     : ws                    : vm-iobroker                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                 system.adapter.yr.0                     : yr                    : vm-iobroker                              -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : vm-iobroker                              -  enabled, port: /dev/ttyUSB0
                                + instance is alive
                                Active repo(s): stable
                                Used repository: stable
                                Adapter    "admin"        : 7.0.22   , installed 7.0.22
                                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                Adapter    "backitup"     : 3.0.16   , installed 3.0.16
                                Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                                Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                Adapter    "email"        : 1.3.1    , installed 1.3.1
                                Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                                Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                                Adapter    "hue"          : 3.11.0   , installed 3.11.0
                                Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                                Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                Controller "js-controller": 6.0.9    , installed 6.0.9
                                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                                Adapter    "material"     : 1.3.1    , installed 1.3.1
                                Adapter    "meteoalarm"   : 3.0.2    , installed 3.0.2
                                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                Adapter    "notification-manager": 1.1.2, installed 1.1.2
                                Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                                Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                Adapter    "operating-hours": 1.0.6  , installed 1.0.6
                                Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                                Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                                Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                                Adapter    "scenes"       : 3.2.1    , installed 3.2.1
                                Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
                                Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
                                Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                Adapter    "web"          : 6.2.5    , installed 6.2.5
                                Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                Objects and States
                                Objects:        72049
                                States:         65059
                                Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                Hit:4 https://repos.influxdata.com/debian stable InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      995        20499      636/influxd
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          846        610/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12417      1/init
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       20893      1570/io.shelly.0
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      112        14210      604/mosquitto
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       19406      747/iobroker.js-con
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       12784      747/iobroker.js-con
                                tcp        0      0 192.168.1.14:42010      0.0.0.0:*               LISTEN      1002       24007      1242/io.hm-rpc.1
                                tcp        0      0 192.168.1.14:42001      0.0.0.0:*               LISTEN      1002       25651      1216/io.hm-rpc.0
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          828        594/cupsd
                                tcp        0      0 192.168.1.14:49292      0.0.0.0:*               LISTEN      1002       20052      1257/io.hm-rpc.3
                                tcp        0      0 0.0.0.0:44467           0.0.0.0:*               LISTEN      115        12755      717/rpc.statd
                                tcp        0      0 0.0.0.0:44155           0.0.0.0:*               LISTEN      0          22684      -
                                tcp6       0      0 :::56179                :::*                    LISTEN      115        12759      717/rpc.statd
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1002       16147      790/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1002       34256      3291/io.web.0
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1002       38562      3334/io.ws.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      995        22644      636/influxd
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1002       29326      3125/io.simple-api.
                                tcp6       0      0 :::8089                 :::*                    LISTEN      1002       40253      3312/io.web.1
                                tcp6       0      0 :::8094                 :::*                    LISTEN      1002       36115      3347/io.socketio.0
                                tcp6       0      0 :::8188                 :::*                    LISTEN      999        22048      625/node
                                tcp6       0      0 :::8000                 :::*                    LISTEN      1002       30131      3209/io.upnp.0
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          848        610/sshd: /usr/sbin
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          14371      1/init
                                tcp6       0      0 :::1883                 :::*                    LISTEN      112        14211      604/mosquitto
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          827        594/cupsd
                                tcp6       0      0 :::35813                :::*                    LISTEN      0          22686      -
                                udp        0      0 0.0.0.0:42838           0.0.0.0:*                           115        12752      717/rpc.statd
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1002       40232      3209/io.upnp.0
                                udp        0      0 0.0.0.0:43018           0.0.0.0:*                           1002       29379      3209/io.upnp.0
                                udp        0      0 0.0.0.0:51474           0.0.0.0:*                           0          22683      -
                                udp        0      0 0.0.0.0:51675           0.0.0.0:*                           1002       19900      984/io.broadlink2.0
                                udp        0      0 0.0.0.0:51787           0.0.0.0:*                           1002       22418      984/io.broadlink2.0
                                udp        0      0 0.0.0.0:45727           0.0.0.0:*                           105        19332      549/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           105        19330      549/avahi-daemon: r
                                udp        0      0 0.0.0.0:46609           0.0.0.0:*                           1002       22419      984/io.broadlink2.0
                                udp        0      0 0.0.0.0:47439           0.0.0.0:*                           1002       26825      1585/io.snmp.0
                                udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1002       22415      984/io.broadlink2.0
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13990      1/init
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12722      627/cups-browsed
                                udp        0      0 127.0.0.1:893           0.0.0.0:*                           0          12747      717/rpc.statd
                                udp6       0      0 :::34696                :::*                                115        12757      717/rpc.statd
                                udp6       0      0 :::35676                :::*                                105        19333      549/avahi-daemon: r
                                udp6       0      0 :::36223                :::*                                0          22685      -
                                udp6       0      0 :::5353                 :::*                                105        19331      549/avahi-daemon: r
                                udp6       0      0 :::111                  :::*                                0          15864      1/init
                                udp6       0      0 fe80::9064:1cff:fe5:546 :::*                                0          22731      564/NetworkManager
                                2024-08-16 12:35:07.951  - info: ical.1 (7088) Terminated (NO_ERROR): Without reason
                                2024-08-16 12:35:08.464  - info: host.vm-iobroker instance system.adapter.ical.1 having pid 7088 terminated with code 0 (NO_ERROR)
                                2024-08-16 12:35:09.475  - info: host.vm-iobroker instance system.adapter.dwd.0 having pid 8016 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-08-16 12:36:11.436  - info: javascript.0 (867) script.js.VIS_Scripte.Material-Design_DasWetter: Material Design Widgets: Wetter Skript triggered by 'hm-rpc.1.000EDF29AF0CB5.1.ACTUAL_TEMPERATURE'
                                2024-08-16 12:36:11.559  - info: host.vm-iobroker instance system.adapter.meteoalarm.0 in version "3.0.2" started with pid 8118
                                2024-08-16 12:36:15.033  - info: host.vm-iobroker instance system.adapter.meteoalarm.0 having pid 8118 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-08-16 12:36:20.016  - info: host.vm-iobroker instance system.adapter.meteoalarm.2 in version "3.0.2" started with pid 8145
                                2024-08-16 12:36:25.124  - info: host.vm-iobroker instance system.adapter.meteoalarm.2 having pid 8145 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-08-16 12:37:43.521  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:37:44.693  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:37:45.357  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:37:45.451  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:37:45.518  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:37:45.625  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:37:45.703  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:37:45.841  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:37:45.944  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
                                2024-08-16 12:38:22.312  - info: javascript.0 (867) script.js.VIS_Scripte.Material-Design_DasWetter: Material Design Widgets: Wetter Skript triggered by 'hm-rpc.1.000EDF29AF0CB5.1.ACTUAL_TEMPERATURE'
                                2024-08-16 12:39:25.497  - info: admin.0 (790) <== Disconnect system.user.admin from ::ffff:192.168.1.55 admin
                                2024-08-16 12:39:25.636  - info: admin.0 (790) ==> Connected system.user.admin from ::ffff:192.168.1.55
                                2024-08-16 12:39:26.528  - info: admin.0 (790) ==> Connected system.user.admin from ::ffff:192.168.1.55
                                2024-08-16 12:40:07.009  - info: host.vm-iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 9001
                                2024-08-16 12:40:09.379  - info: host.vm-iobroker instance system.adapter.dwd.0 having pid 9001 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-08-16 12:40:21.610  - info: host.vm-iobroker instance system.adapter.meteoalarm.3 in version "3.0.2" started with pid 9030
                                2024-08-16 12:40:25.063  - info: host.vm-iobroker instance system.adapter.meteoalarm.3 having pid 9030 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                Danke für eure Hilfe.
                                • JoJo58J JoJo58
                                  Hier das Ergebnis:
                                  Summary:
                                                         v.2024-05-22
                                          Chassis: vm 🖴
                                   Virtualization: kvm
                                  Installation:           kvm
                                  Kernel:                 x86_64
                                  Userland:               64 bit
                                  User-ID:                1000
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  MEMORY:
                                  Swap:           1.0G          0B        1.0G
                                  Total:           17G        5.7G         11G
                                                         admin                   7.0.22
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                72049
                                  States:                 65059
                                  Langfassung:
                                  Skript v.2024-05-22
                                  *** BASE SYSTEM ***
                                          Chassis: vm 🖴
                                   Virtualization: kvm
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                  CPU threads: 8
                                               NTP service: active
                                           RTC in local TZ: no
                                  smarthome
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           1.0G          0B        1.0G
                                  Total:           17G        5.7G         11G
                                          5451 M used memory
                                           440 M active memory
                                          9620 M free memory
                                            89 M buffer memory
                                          1121 M swap cache
                                           974 M total swap
                                             0 M used swap
                                           974 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  4.9G    /var/
                                  2.9G    /var/log
                                  1.7G    /var/cache/apt
                                  USB-Devices by-id:
                                  HINT:
                                  /dev/ttyUSB0
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                   Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          7.0.22
                                  javascript:     8.7.6
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        72049
                                  States:         65059
                                  Pending Updates: 0
                                  #205
                                  @jojo58
                                  Dicke Dinger seh ich da nicht. Der nicht laufende networking.service kommt mir komisch vor.
                                  Stell vielleicht mal von jsonl auf redis um.
                                  JoJo58J 2 Antworten Letzte Antwort
                                    @jojo58
                                    JoJo58J Offline
                                    JoJo58J Offline
                                    JoJo58
                                    #206
                                    Das mit dem network.sevice habe ich auch gesehen, aber keine Ahnung woher das kommt. Es scheint aber auf die Funktionalität des IOB keinen Einfluss zu haben.
                                    Auf redis umstellen traue ich mich noch nicht, da werde ich wohl erst noch etwas dazu recherchieren müssen.
                                    • JoJo58J JoJo58
                                      Hier das Ergebnis:
                                      Summary:
                                                             v.2024-05-22
                                              Chassis: vm 🖴
                                       Virtualization: kvm
                                      Installation:           kvm
                                      Kernel:                 x86_64
                                      Userland:               64 bit
                                      User-ID:                1000
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      MEMORY:
                                      Swap:           1.0G          0B        1.0G
                                      Total:           17G        5.7G         11G
                                                             admin                   7.0.22
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                72049
                                      States:                 65059
                                      Langfassung:
                                      Skript v.2024-05-22
                                      *** BASE SYSTEM ***
                                              Chassis: vm 🖴
                                       Virtualization: kvm
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      CPU threads: 8
                                                   NTP service: active
                                               RTC in local TZ: no
                                      smarthome
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           1.0G          0B        1.0G
                                      Total:           17G        5.7G         11G
                                              5451 M used memory
                                               440 M active memory
                                              9620 M free memory
                                                89 M buffer memory
                                              1121 M swap cache
                                               974 M total swap
                                                 0 M used swap
                                               974 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      4.9G    /var/
                                      2.9G    /var/log
                                      1.7G    /var/cache/apt
                                      USB-Devices by-id:
                                      HINT:
                                      /dev/ttyUSB0
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                       Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          7.0.22
                                      javascript:     8.7.6
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        72049
                                      States:         65059
                                      Pending Updates: 0
                                      crunchipC Offline
                                      crunchipC Offline
                                      #207
                                      /opt/iobroker/backups: 25G /opt/iobroker/backups/
                                      Zwar nicht Thema, macht aber wenig Sinn
                                        JoJo58J Offline
                                        JoJo58J Offline
                                        JoJo58
                                        #208
                                        @crunchip sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                                        Ich weiß, aber das liegt daran, das ich auch auf OneDrive sichere und die letzten 20 behalte. Die liegen alle immer auf OneDrive und leider auch unter /opt/iobroker/backups.
                                        Ich weiß nicht warum die doppelt gespeichert werden. Ich bin immer davon ausgegangen, das das sozusagen temporäre Daten für OneDrive sind. Das ich es also so hinnehmen muss.
                                          @jojo58
                                          JoJo58J Offline
                                          JoJo58J Offline
                                          JoJo58
                                          #209
                                          Ich habe eben ein "apt full-upgrade" gemacht und danach den Server neu gestartet, Jetzt schwankt die Auslastung unter Hosts zwischen 70% und 105% und wenn ich über ssh mal top eingebe, kommt das raus:
                                          top - 09:27:26 up 17 min,  1 user,  load average: 1,35, 2,16, 1,78
                                          Tasks: 229 total,   1 running, 228 sleeping,   0 stopped,   0 zombie
                                          %CPU(s): 13,0 us,  1,3 sy,  0,0 ni, 84,7 id,  0,0 wa,  0,0 hi,  0,9 si,  0,0 st
                                          MiB Spch:  15991,7 total,   9823,0 free,   5236,7 used,   1185,4 buff/cache
                                          MiB Swap:    975,0 total,    975,0 free,      0,0 used.  10755,0 avail Spch
                                             PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                                             757 iobroker  20   0   22,1g 998,6m  50788 S  76,5   6,2  17:14.68 iobroker.js-con
                                             959 iobroker  20   0   31,8g 723940  50984 S  16,9   4,4   5:41.55 io.javascript.0
                                             944 iobroker  20   0   11,1g 153936  44624 S   8,3   0,9   1:26.85 io.influxdb.0
                                            3454 iobroker  20   0   11,0g 118436  48972 S   7,9   0,7   1:19.55 io.operating-ho
                                            2019 iobroker  20   0   11,3g 152108  51228 S   7,0   0,9   0:13.57 io.zigbee.0
                                            1679 iobroker  20   0   11,1g  81968  44776 S   3,6   0,5   0:07.06 io.proxmox.0
                                            2415 iobroker  20   0   11,0g  88808  49136 S   3,0   0,5   0:09.82 io.logparser.0
                                            1767 iobroker  20   0   11,0g 103460  48984 S   2,6   0,6   0:13.38 io.shelly.0
                                          top - 09:28:33 up 18 min,  1 user,  load average: 1,52, 2,05, 1,77
                                          Tasks: 229 total,   2 running, 227 sleeping,   0 stopped,   0 zombie
                                          %CPU(s): 17,8 us,  1,4 sy,  0,0 ni, 80,0 id,  0,0 wa,  0,0 hi,  0,8 si,  0,0 st
                                          MiB Spch:  15991,7 total,   9774,7 free,   5271,5 used,   1199,1 buff/cache
                                          MiB Swap:    975,0 total,    975,0 free,      0,0 used.  10720,2 avail Spch
                                             757 iobroker  20   0   22,1g 996,5m  50788 R 118,2   6,2  18:11.70 iobroker.js-con
                                             959 iobroker  20   0   31,8g 749536  50984 S  20,4   4,6   5:56.12 io.javascript.0
                                             944 iobroker  20   0   11,1g 163976  44624 S   7,9   1,0   1:32.19 io.influxdb.0
                                             637 influxdb  20   0 1666088 157516  28532 S   2,3   1,0   0:05.66 influxd
                                            3454 iobroker  20   0   11,0g 118960  48972 S   2,3   0,7   1:25.66 io.operating-ho
                                            3604 iobroker  20   0   11,0g  89996  44700 S   1,3   0,5   0:17.64 io.upnp.0
                                            1580 iobroker  20   0   21,0g  87492  45772 S   0,7   0,5   0:06.33 io.hue.0
                                            2250 iobroker  20   0   21,1g  95864  46244 S   0,7   0,6   0:21.31 io.fb-checkpres
                                              17 root      20   0       0      0      0 I   0,3   0,0   0:00.37 kworker/0:1-mm_percpu_wq
                                              60 root      20   0       0      0      0 I   0,3   0,0   0:00.18 kworker/u16:6-writeback
                                          top - 09:49:21 up 39 min,  1 user,  load average: 2,01, 1,87, 1,94
                                          %CPU(s): 13,7 us,  1,0 sy,  0,0 ni, 84,4 id,  0,1 wa,  0,0 hi,  0,7 si,  0,0 st
                                          MiB Spch:  15991,7 total,   9398,7 free,   5419,7 used,   1430,1 buff/cache
                                          MiB Swap:    975,0 total,    975,0 free,      0,0 used.  10572,0 avail Spch
                                             757 iobroker  20   0   22,2g   1,0g  50788 R  91,7   6,3  37:53.33 iobroker.js-con
                                             959 iobroker  20   0   31,8g 746432  50984 S  16,9   4,6  11:23.84 io.javascript.0
                                            9414 iobroker  20   0   21,3g  86692  45172 S  11,0   0,5   0:05.93 io.daswetter.0
                                            3454 iobroker  20   0   11,0g 124744  48972 S   6,6   0,8   3:39.92 io.operating-ho
                                             944 iobroker  20   0   11,1g 153964  44624 S   6,3   0,9   3:24.35 io.influxdb.0
                                            2415 iobroker  20   0   11,0g  92096  49136 S   2,3   0,6   0:19.33 io.logparser.0
                                            3604 iobroker  20   0   11,0g  91448  44700 S   1,7   0,6   0:37.79 io.upnp.0
                                            1580 iobroker  20   0   21,0g  90992  45772 S   1,0   0,6   0:11.31 io.hue.0
                                            1442 iobroker  20   0   11,3g  94588  45380 S   0,7   0,6   0:23.14 io.alexa2.0
                                            3510 iobroker  20   0   11,0g 107328  44132 S   0,7   0,7   0:35.51 io.sourceanalyt
                                          Der JS-Controller ist immer ganz oben. Meinst du das eine Umstellung auf redis da wirklich helfen könnte?
                                          Ro75R foxriver76F 2 Antworten Letzte Antwort
