  4. Adapterfehler WEB-Server und IP-Kameras
78 Beiträge 6 Kommentatoren 9.5k Aufrufe 5 Beobachtet
  • L Loco
    admin.0
    2024-08-14 14:10:08.274	info	<== Disconnect system.user.admin from ::ffff:192.168.220.191 web
    admin.0
    host.E5440
    2024-08-14 14:10:07.616	info	instance system.adapter.web.0 is handled by compact group controller pid 42532
    host.E5440.compactgroup1
    2024-08-14 14:10:06.452	info	Do not restart adapter system.adapter.web.0 because desired by instance
    2024-08-14 14:10:06.452	info	instance system.adapter.web.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2024-08-14 14:10:06.452	warn	instance system.adapter.web.0 terminated due to 11
    web.0
    2024-08-14 14:10:05.919	info	(COMPACT) http server listening on port 8096
    web.0
    2024-08-14 14:10:05.918	info	(COMPACT) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    web.0
    2024-08-14 14:10:05.918	error	(COMPACT) port 8088 already in use
    web.0
    2024-08-14 14:10:05.111	debug	(COMPACT) Activating web files from objectDB
    web.0
    2024-08-14 14:10:05.111	debug	(COMPACT) Activating extensions
    web.0
    2024-08-14 14:10:05.110	debug	(COMPACT) Secure connection not enabled - using http createServer
    web.0
    2024-08-14 14:10:05.109	debug	(COMPACT) Activating states & socket info
    web.0
    2024-08-14 14:10:05.053	info	(COMPACT) starting. Version 6.3.0 in C:/ioBroker/node_modules/iobroker.web, node: v20.16.0, js-controller: 6.0.10
    2024-08-14 14:10:04.856	info	instance system.adapter.web.0 started in COMPACT mode
    host.E5440
    2024-08-14 14:10:03.981	info	stopInstance system.adapter.web.0 (force=false, process=true)
    admin.0
    2024-08-14 14:09:58.991	info	==> Connected system.user.admin from ::ffff:192.168.220.191
    host.E5440
    2024-08-14 14:09:12.019	info	instance system.adapter.cameras.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    cameras.0
    2024-08-14 14:09:11.901	info	terminating
    cameras.0
    2024-08-14 14:09:11.402	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    cameras.0
    2024-08-14 14:09:11.402	info	terminating
    cameras.0
    2024-08-14 14:09:11.399	info	Got terminate signal TERMINATE_YOURSELF
    host.E5440
    2024-08-14 14:09:11.398	info	stopInstance system.adapter.cameras.0 send kill signal
    host.E5440
    2024-08-14 14:09:11.393	info	stopInstance system.adapter.cameras.0 (force=false, process=true)
    host.E5440
    2024-08-14 14:09:11.392	info	"system.adapter.cameras.0" disabled
    host.E5440
    2024-08-14 14:04:20.423	info	instance system.adapter.web.0 is handled by compact group controller pid 42532
    2024-08-14 14:04:19.562	info	Do not restart adapter system.adapter.web.0 because desired by instance
    2024-08-14 14:04:19.562	info	instance system.adapter.web.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2024-08-14 14:04:19.562	warn	instance system.adapter.web.0 terminated due to 11
    web.0
    2024-08-14 14:04:18.997	info	(COMPACT) http server listening on port 8095
    web.0
    2024-08-14 14:04:18.996	info	(COMPACT) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    web.0
    2024-08-14 14:04:18.996	error	(COMPACT) port 8088 already in use
    @loco ich kenne den compact mode nicht, aber das
    @loco sagte in Adapterfehler WEB-Server und IP-Kameras:
    host.E5440.compactgroup1 2024-08-14 14:10:06.452 warn instance system.adapter.web.0 terminated due to 11
    klingt für mich danach, dass die gesamte Gruppe die Ressourcen gemeinsam nutzt
    L 1 Antwort Letzte Antwort
      Loco
      @homoran wie kann ich den compact Mode den umschalten?
      HomoranH S crunchipC 3 Antworten Letzte Antwort
      • L Loco
        keine Ahnung!
        ich hab den noch nie genutzt.
          keine Ahnung!
          Loco
          Ich hab auch keine Ahnung wieso "Compact Mode". Hatte alles neu aufgesetzt auf einem Win11-64bit und dann meine alte VIS importiert...
          • L Loco
            S Abwesend
            S Abwesend
            Shadowhunter23
            @loco
            Laut suche im Forum:
            https://forum.iobroker.net/topic/32789/anleitung-für-adapter-entwickler-compact-mode-testen
            Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
            ioBroker Backup Analyzer
            • S Shadowhunter23
              @loco
              @shadowhunter23
              naja, das ist jetzt 4 Jahre alt und richtete sich an Entwickler.
              Ich denke schon, dass sich da bis heute noch was geändert haben kann.
              L S 2 Antworten Letzte Antwort
              • L Loco
                crunchipC Offline
                crunchipC Offline
                @loco hatte ich doch oben schon gezeigt
                  @shadowhunter23
                  Loco
                  Zumindest hat das geklappt. Habe den compact mode deaktiviert. Mal sehen was jetzt so passiert....
                    @shadowhunter23
                    S Abwesend
                    S Abwesend
                    Shadowhunter23
                    schrieb am zuletzt editiert von Shadowhunter23
                    @homoran sagte in Adapterfehler WEB-Server und IP-Kameras:
                    Möglich aber der Befehl ist aktiv und man könnte den verwenden...
                    • S Shadowhunter23
                      Loco
                      @shadowhunter23
                      habe den compact mode deaktiviert, jetzt startet meine VIS aber nicht mehr
                      mehr passiert nicht...
                      • L Loco
                        @shadowhunter23
                        für alle Instanzen?
                        danach iobroker neu gestartet?
                        Was sagt die Browserkonsole?
                          für alle Instanzen?
                          Loco
                          C:\ioBroker>iob list instances
                          + system.adapter.admin.0                  : admin                 : E5440                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : E5440                                    -  enabled
                          + system.adapter.backitup.0               : backitup              : E5440                                    -  enabled
                          + system.adapter.broadlink2.0             : broadlink2            : E5440                                    -  enabled
                            system.adapter.cameras.0                : cameras               : E5440                                    - disabled, port: 8200, bind: 127.0.0.1
                          + system.adapter.chromecast.0             : chromecast            : E5440                                    -  enabled
                            system.adapter.daswetter.0              : daswetter             : E5440                                    -  enabled
                          + system.adapter.deyeidc.0                : deyeidc               : E5440                                    -  enabled, port: 8899
                          + system.adapter.discovery.0              : discovery             : E5440                                    -  enabled
                          + system.adapter.echarts.0                : echarts               : E5440                                    -  enabled
                            system.adapter.flot.0                   : flot                  : E5440                                    -  enabled
                          + system.adapter.fritzdect.0              : fritzdect             : E5440                                    -  enabled
                          + system.adapter.history.0                : history               : E5440                                    -  enabled
                            system.adapter.hue.0                    : hue                   : E5440                                    - disabled, port: 443
                            system.adapter.hue.1                    : hue                   : E5440                                    - disabled, port: 443
                            system.adapter.hue.2                    : hue                   : E5440                                    - disabled, port: 443
                            system.adapter.ical.0                   : ical                  : E5440                                    -  enabled
                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: E5440                                    -  enabled
                            system.adapter.icons-icons8.0           : icons-icons8          : E5440                                    -  enabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : E5440                                    -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : E5440                                    -  enabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: E5440                                    -  enabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : E5440                                    -  enabled
                          + system.adapter.javascript.0             : javascript            : E5440                                    -  enabled
                          + system.adapter.net-tools.0              : net-tools             : E5440                                    -  enabled
                            system.adapter.onvif.0                  : onvif                 : E5440                                    - disabled
                          + system.adapter.ping.0                   : ping                  : E5440                                    -  enabled
                          + system.adapter.pollenflug.0             : pollenflug            : E5440                                    -  enabled
                          + system.adapter.signal-cmb.0             : signal-cmb            : E5440                                    -  enabled
                          + system.adapter.sonoff.0                 : sonoff                : E5440                                    -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.sourceanalytix.0         : sourceanalytix        : E5440                                    -  enabled
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : E5440                                    -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : E5440                                    -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : E5440                                    -  enabled
                            system.adapter.vesync.0                 : vesync                : E5440                                    - disabled
                            system.adapter.vis-bars.0               : vis-bars              : E5440                                    -  enabled
                            system.adapter.vis-history.0            : vis-history           : E5440                                    -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : E5440                                    -  enabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : E5440                                    -  enabled
                          + system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : E5440                                    -  enabled
                          + system.adapter.vis-justgage.0           : vis-justgage          : E5440                                    -  enabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : E5440                                    -  enabled
                            system.adapter.vis-metro.0              : vis-metro             : E5440                                    -  enabled
                            system.adapter.vis-players.0            : vis-players           : E5440                                    -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : E5440                                    -  enabled
                            system.adapter.vis-weather.0            : vis-weather           : E5440                                    -  enabled
                            system.adapter.vis.0                    : vis                   : E5440                                    -  enabled
                          + system.adapter.web.0                    : web                   : E5440                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.wifilight.0              : wifilight             : E5440                                    -  enabled
                          + instance is alive
                          • L Loco
                            + instance is alive
                            Loco
                            @loco
                            Also, auch nach aktivieren des Compact Mode läuft meine vis nicht mehr! iobroker läuft vis kein Zugriff mehr! Was kann ich machen?
                            • L Loco
                              @loco
                              crunchipC Offline
                              crunchipC Offline
                              @loco dann zeig mal jetzt die Einstellung im Web Adapter
                              Und was zeigt die Browser console(f12) ?
                                Loco
                                @crunchip sieht aus wie vorher:
                                + system.adapter.web.0                    : web                   : E5440                                    -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                Keine Verbindung mehr in der VIS
                                crunchipC S 3 Antworten Letzte Antwort
                                • L Loco
                                  + instance is alive
                                  crunchipC Offline
                                  crunchipC Offline
                                  #66
                                  Deshalb
                                  @crunchip sagte in Adapterfehler WEB-Server und IP-Kameras:
                                  Ist aber nicht normal
                                  • L Loco
                                    + instance is alive
                                    S Abwesend
                                    S Abwesend
                                    Shadowhunter23
                                    #67
                                    Nicht ganz der Port ist jetzt 8083 anstatt 8082. Wird aber wohl nicht das erwartete ändern.
                                    • L Loco
                                      + instance is alive
                                      crunchipC Offline
                                      crunchipC Offline
                                      #68
                                      Vergleich doch mal meinen screen
                                      https://forum.iobroker.net/post/1190976
                                      Wie schon geschrieben, fehlt dir da bisserl was in den Einstellungen und nun ist dein websocket nicht eingestellt
                                      Ausserdem warten wir immer noch aufs Browserlog
                                        Loco
                                        #69
                                        Wie kann ich denn dieses Browser-Log erstellen? Und soll das erstellt werden im Fehlerfall?
                                        Ich glaube das ist eher der Nachteil wenn iobroker unter Win läuft und nicht auf einer Pi. Vermute auf einer Pi würde das laufen....
                                        • L Loco
                                          #70
