SONOFF NSPanel mit Lovelace UI (TypeScript Version)
@nobody-else
alles klar, sehe heute Abend nochmal vorbei, wie es läuft.@tt-tom ich habe jetzt alles aktualisiert und du hast recht gehabt, der dayjs Fehler läuft durch und das Panel funktioniert trotzdem.
2024-08-09 21:15:38.696 - info: javascript.0 (177494) Stopping script script.js.NS_Panels.NS_Panel_Update_3 2024-08-09 21:15:39.933 - info: javascript.0 (177494) Compiling TypeScript source script.js.NS_Panels.NS_Panel_Update_3 2024-08-09 21:15:41.722 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: source code did not change, using cached compilation result... 2024-08-09 21:15:42.000 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.000 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.000 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.000 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.001 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86 2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243) 2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.004 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.004 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.005 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.005 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.005 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86 2024-08-09 21:15:42.005 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243) 2024-08-09 21:15:42.005 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.005 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.006 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.006 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.008 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.009 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.009 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.009 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.009 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86 2024-08-09 21:15:42.009 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243) 2024-08-09 21:15:42.009 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.010 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.010 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.010 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.045 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.045 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.045 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.046 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.046 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86 2024-08-09 21:15:42.046 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243) 2024-08-09 21:15:42.046 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.046 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.047 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.047 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.050 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.050 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.050 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.050 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.051 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86 2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243) 2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.054 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.054 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.054 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.055 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.055 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86 2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243) 2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.058 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.059 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.059 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.059 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.059 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86 2024-08-09 21:15:42.059 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243) 2024-08-09 21:15:42.059 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.060 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.060 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.060 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.063 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.063 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.063 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.063 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.063 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86 2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243) 2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.067 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.067 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.067 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.067 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.068 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86 2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243) 2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.071 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.072 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.072 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86 2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243) 2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.073 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.073 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.075 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.076 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.076 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.076 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.076 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86 2024-08-09 21:15:42.076 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243) 2024-08-09 21:15:42.076 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.077 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.077 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.077 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.080 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.080 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.080 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.080 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.080 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86 2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243) 2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.084 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.084 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.085 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.085 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86 2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243) 2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.086 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.089 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.089 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.089 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.090 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.090 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86 2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243) 2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.093 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.094 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.094 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86 2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243) 2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.095 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.095 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.098 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.098 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.098 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.098 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.098 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86 2024-08-09 21:15:42.098 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243) 2024-08-09 21:15:42.099 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.099 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.099 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.099 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.102 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.102 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.102 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.102 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.102 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86 2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243) 2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.106 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.107 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.107 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.107 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.107 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86 2024-08-09 21:15:42.107 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243) 2024-08-09 21:15:42.107 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.108 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.108 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.108 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.111 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.111 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.112 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.112 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86 2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243) 2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.113 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.115 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.116 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.116 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.116 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.116 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86 2024-08-09 21:15:42.116 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243) 2024-08-09 21:15:42.116 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.117 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.117 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.117 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.120 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.120 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.120 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.120 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.120 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86 2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243) 2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.124 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.124 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.124 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.124 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.125 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86 2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243) 2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.128 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.128 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.129 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.129 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.129 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86 2024-08-09 21:15:42.129 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243) 2024-08-09 21:15:42.129 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.129 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.130 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.130 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.133 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.133 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.133 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.133 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.133 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86 2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246) 2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.137 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.138 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.138 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.138 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.138 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86 2024-08-09 21:15:42.138 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243) 2024-08-09 21:15:42.138 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.139 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.139 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.139 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.142 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.142 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.142 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.142 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.143 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86 2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243) 2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.146 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.146 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.146 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.147 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.147 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86 2024-08-09 21:15:42.147 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243) 2024-08-09 21:15:42.147 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.147 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.147 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.148 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.151 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.151 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.151 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.151 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.151 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86 2024-08-09 21:15:42.151 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243) 2024-08-09 21:15:42.151 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.152 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.152 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.152 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.155 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.155 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.155 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.155 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.155 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86 2024-08-09 21:15:42.155 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243) 2024-08-09 21:15:42.156 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.156 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.156 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.156 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.159 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.159 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.159 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.159 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.159 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86 2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243) 2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.163 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.163 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.163 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.164 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.164 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86 2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243) 2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.167 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.167 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.168 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.168 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86 2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243) 2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.169 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.171 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.171 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.172 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.172 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.172 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86 2024-08-09 21:15:42.172 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243) 2024-08-09 21:15:42.172 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.172 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.173 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.173 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.175 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.176 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.176 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86 2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243) 2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.177 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.177 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.180 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.180 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.180 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.180 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.180 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86 2024-08-09 21:15:42.180 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243) 2024-08-09 21:15:42.181 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.181 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.181 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.181 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.184 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.184 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.184 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.184 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.184 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86 2024-08-09 21:15:42.184 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243) 2024-08-09 21:15:42.185 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.185 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.185 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.185 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.188 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.188 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.188 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.188 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.188 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86 2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246) 2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.192 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs' 2024-08-09 21:15:42.192 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27) 2024-08-09 21:15:42.192 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19) 2024-08-09 21:15:42.192 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18) 2024-08-09 21:15:42.192 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86 2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246) 2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14) 2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10) 2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32) 2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12) 2024-08-09 21:15:42.248 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: nodeJS must be at least v18.X.X. Currently: v16.20.2! Please Update your System! --> iob nodejs-update 18 2024-08-09 21:15:42.248 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: nodeJS must be at least v18.X.X. Currently: v16.19.0! Please Update your System! --> iob nodejs-update 18 2024-08-09 21:15:42.249 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: setObjects enabled - create Alias Channels possible 2024-08-09 21:15:42.265 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: weather alias for accuweather.0. already exists 2024-08-09 21:15:42.299 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: No Updates for NSPanel available 2024-08-09 21:15:42.300 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 2024-08-09 21:15:42.312 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: No Updates for NSPanel available 2024-08-09 21:15:42.753 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Desired TFT Firmware: 53 / v4.4.0 2024-08-09 21:15:42.753 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Installed TFT Firmware: 53 / v4.4.0 2024-08-09 21:15:42.972 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Debug mode disabled 2024-08-09 21:15:43.608 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Desired TFT Firmware: 53 / v4.4.0 2024-08-09 21:15:43.609 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Installed TFT Firmware: 53 / v4.4.0 2024-08-09 21:15:43.837 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Desired TFT Firmware: 53 / v4.4.0 2024-08-09 21:15:43.838 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Installed TFT Firmware: 53 / v4.4.0 2024-08-09 21:15:47.654 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Start MQTT-Port-Check ------------------------------------- 2024-08-09 21:15:47.655 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- admin.0 - 8081 2024-08-09 21:15:47.656 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- hue.0 - 443 2024-08-09 21:15:47.656 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- mqtt.0 - 1884 2024-08-09 21:15:47.656 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- shelly.0 - 1885 2024-08-09 21:15:47.657 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- sonoff.0 - 1883 2024-08-09 21:15:47.657 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- telegram.0 - 8443 2024-08-09 21:15:47.657 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- web.0 - 8082 2024-08-09 21:15:47.658 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- zigbee.0 - /dev 2024-08-09 21:15:47.659 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1884 2024-08-09 21:15:47.659 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: End MQTT-Port-Check --------------------------------------- -
Hi Zusammen,
ich hab mal noch eine kleines Problem, wenn ich im Systemmenü des Panels die Helligkeit ändere wird dies erst geändert wenn ich das Skript neu starte, b.z.w. wenn ich das Panel mal stromlos gemacht habe sind auch wieder die Default werte eingestellt bis ich das Skript neu starte.
Das Problem hab ich eigentlich schon von Anfang an, seit verschiedenen Skript Versionen, stört jetzt nicht so, aber der innere Monk will halt das alles irgendwie rund läuft.
Hi Zusammen,
@nobody-else
Kannst du bitte dazu ein Issue auf Github machen, danke. -
@armilar Hier das Log vom Start:
2024-08-07 23:31:01.945 - info: javascript.0 (398) Compiling TypeScript source script.js.common.NSPanel.NSPanelTS_44 2024-08-07 23:31:09.877 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: TypeScript compilation successful 2024-08-07 23:31:10.207 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.207 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.208 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.208 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86 2024-08-07 23:31:10.208 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243) 2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.208 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.208 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.211 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.211 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.211 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.211 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.211 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86 2024-08-07 23:31:10.211 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243) 2024-08-07 23:31:10.211 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.211 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.212 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.212 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.213 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.214 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.214 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.214 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.214 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86 2024-08-07 23:31:10.214 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243) 2024-08-07 23:31:10.214 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.214 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.217 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.217 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.219 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.219 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.219 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.219 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.219 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86 2024-08-07 23:31:10.220 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243) 2024-08-07 23:31:10.220 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.220 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.220 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.220 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.222 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.222 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.222 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.222 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.222 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86 2024-08-07 23:31:10.227 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243) 2024-08-07 23:31:10.227 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.227 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.227 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.227 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.237 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.237 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.237 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.237 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86 2024-08-07 23:31:10.237 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243) 2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.237 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.237 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.240 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.240 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.240 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.240 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86 2024-08-07 23:31:10.240 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243) 2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.240 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.240 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.242 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.242 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.242 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.242 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.243 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86 2024-08-07 23:31:10.243 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243) 2024-08-07 23:31:10.243 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.243 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.243 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.243 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.245 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.245 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.245 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.245 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86 2024-08-07 23:31:10.245 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243) 2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.245 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.245 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.247 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.247 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.247 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.247 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.248 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86 2024-08-07 23:31:10.248 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243) 2024-08-07 23:31:10.248 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.248 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.248 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.248 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.250 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.250 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.250 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.250 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86 2024-08-07 23:31:10.250 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243) 2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.250 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.250 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.252 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.252 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.252 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.253 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.253 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86 2024-08-07 23:31:10.253 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243) 2024-08-07 23:31:10.253 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.253 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.253 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.253 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.255 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.255 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.255 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.256 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.256 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86 2024-08-07 23:31:10.256 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243) 2024-08-07 23:31:10.256 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.256 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.256 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.256 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.258 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.258 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.258 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.258 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.258 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86 2024-08-07 23:31:10.259 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243) 2024-08-07 23:31:10.259 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.259 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.259 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.259 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.261 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.261 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.261 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.261 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86 2024-08-07 23:31:10.261 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243) 2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.261 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.261 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.263 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.263 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.263 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.263 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.264 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86 2024-08-07 23:31:10.264 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243) 2024-08-07 23:31:10.270 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.270 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.270 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.275 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.277 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.277 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.277 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.277 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.278 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86 2024-08-07 23:31:10.278 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243) 2024-08-07 23:31:10.278 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.278 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.278 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.278 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.280 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.280 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.280 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.280 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86 2024-08-07 23:31:10.280 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243) 2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.280 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.280 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.282 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.282 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.282 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.282 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.282 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86 2024-08-07 23:31:10.283 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243) 2024-08-07 23:31:10.283 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.283 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.283 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.283 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.284 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.285 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.285 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.285 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86 2024-08-07 23:31:10.285 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243) 2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.285 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.285 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.287 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.287 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.287 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.287 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.287 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86 2024-08-07 23:31:10.287 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243) 2024-08-07 23:31:10.287 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.287 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.288 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.288 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.289 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.289 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.290 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.290 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86 2024-08-07 23:31:10.290 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243) 2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.290 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.290 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.292 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.292 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.292 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.292 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86 2024-08-07 23:31:10.292 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243) 2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.292 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.292 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.294 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.294 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.294 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.294 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.294 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86 2024-08-07 23:31:10.295 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246) 2024-08-07 23:31:10.295 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.295 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.295 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.295 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.296 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.297 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.297 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.297 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86 2024-08-07 23:31:10.297 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243) 2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.297 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.297 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.299 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.299 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.299 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.299 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86 2024-08-07 23:31:10.299 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243) 2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.299 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.300 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.301 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.301 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.301 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.301 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.302 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86 2024-08-07 23:31:10.302 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243) 2024-08-07 23:31:10.302 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.302 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.302 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.302 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.304 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.304 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.304 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.304 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86 2024-08-07 23:31:10.304 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243) 2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.304 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.304 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.306 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.306 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.306 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.306 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.306 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86 2024-08-07 23:31:10.307 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243) 2024-08-07 23:31:10.307 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.307 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.307 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.307 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.309 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.309 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.309 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.309 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86 2024-08-07 23:31:10.309 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243) 2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.309 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.309 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.311 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.311 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.311 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.311 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.311 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86 2024-08-07 23:31:10.311 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243) 2024-08-07 23:31:10.312 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.312 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.312 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.312 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.313 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.314 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.314 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.314 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86 2024-08-07 23:31:10.314 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243) 2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.314 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.314 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.316 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.316 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.316 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.316 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.316 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86 2024-08-07 23:31:10.316 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243) 2024-08-07 23:31:10.316 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.316 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.317 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.317 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.318 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.318 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.319 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.319 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86 2024-08-07 23:31:10.319 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243) 2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.319 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.319 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.321 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.321 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.321 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.321 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.321 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86 2024-08-07 23:31:10.321 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243) 2024-08-07 23:31:10.321 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.321 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.323 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.323 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.325 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.325 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.325 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.325 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.325 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86 2024-08-07 23:31:10.325 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243) 2024-08-07 23:31:10.325 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.334 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.334 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.334 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.335 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.336 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.336 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.336 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.336 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86 2024-08-07 23:31:10.337 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246) 2024-08-07 23:31:10.337 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.337 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.337 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.337 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.339 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs' 2024-08-07 23:31:10.339 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27) 2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19) 2024-08-07 23:31:10.339 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18) 2024-08-07 23:31:10.339 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86 2024-08-07 23:31:10.339 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246) 2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14) 2024-08-07 23:31:10.339 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) 2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32) 2024-08-07 23:31:10.339 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) 2024-08-07 23:31:10.339 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: getDayjsLocale de 2024-08-07 23:31:10.360 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: setObjects enabled - create Alias Channels possible 2024-08-07 23:31:10.368 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: weather alias for accuweather.0. already exists 2024-08-07 23:31:10.434 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions -
@rene55 said in SONOFF NSPanel mit Lovelace UI:
Geanu so sieht es bei mir aus.
Er findet nicht das Modul Dayjs@tobiasp
Mein Ordner ist da. Komisch auch die Datei zh-cn.jsjavascript.0 2024-08-11 07:45:52.295 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.295 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.294 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.294 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86 javascript.0 2024-08-11 07:45:52.294 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.294 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246) javascript.0 2024-08-11 07:45:52.294 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.294 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.294 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.293 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.290 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.290 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.290 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86 javascript.0 2024-08-11 07:45:52.290 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.290 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246) javascript.0 2024-08-11 07:45:52.290 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.290 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.290 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.289 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.289 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.285 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.285 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.285 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243) javascript.0 2024-08-11 07:45:52.285 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86 javascript.0 2024-08-11 07:45:52.285 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.285 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.285 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.285 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.284 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.284 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.280 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.280 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.280 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86 javascript.0 2024-08-11 07:45:52.280 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.280 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243) javascript.0 2024-08-11 07:45:52.280 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.280 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.280 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.279 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.279 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.276 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.275 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.275 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243) javascript.0 2024-08-11 07:45:52.275 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.275 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.275 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86 javascript.0 2024-08-11 07:45:52.275 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.275 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.275 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.274 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.272 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.271 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.271 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243) javascript.0 2024-08-11 07:45:52.271 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.271 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.271 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86 javascript.0 2024-08-11 07:45:52.271 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.271 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.271 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.270 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.267 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.267 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.266 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.266 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86 javascript.0 2024-08-11 07:45:52.266 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.266 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243) javascript.0 2024-08-11 07:45:52.266 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.266 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.266 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.265 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.262 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.262 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.261 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.261 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243) javascript.0 2024-08-11 07:45:52.261 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.261 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.261 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86 javascript.0 2024-08-11 07:45:52.261 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.261 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.261 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.258 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.258 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.258 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86 javascript.0 2024-08-11 07:45:52.258 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.258 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243) javascript.0 2024-08-11 07:45:52.258 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.258 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.258 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.257 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.257 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.254 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.254 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.254 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86 javascript.0 2024-08-11 07:45:52.254 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243) javascript.0 2024-08-11 07:45:52.254 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.254 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.253 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.253 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.253 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.253 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.249 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.249 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.249 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243) javascript.0 2024-08-11 07:45:52.249 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.249 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86 javascript.0 2024-08-11 07:45:52.249 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.249 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.248 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.248 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.248 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.245 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.245 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.245 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243) javascript.0 2024-08-11 07:45:52.245 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.245 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.245 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86 javascript.0 2024-08-11 07:45:52.245 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.245 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.244 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.244 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.241 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.241 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.241 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243) javascript.0 2024-08-11 07:45:52.241 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.241 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.240 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86 javascript.0 2024-08-11 07:45:52.240 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.240 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.240 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.240 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.236 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.236 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.236 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.235 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243) javascript.0 2024-08-11 07:45:52.235 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86 javascript.0 2024-08-11 07:45:52.235 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.234 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.234 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.234 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.234 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.231 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.231 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.230 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.230 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86 javascript.0 2024-08-11 07:45:52.230 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.230 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.230 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.230 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246) javascript.0 2024-08-11 07:45:52.230 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.230 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.227 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.226 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.226 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.226 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86 javascript.0 2024-08-11 07:45:52.226 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.226 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.226 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243) javascript.0 2024-08-11 07:45:52.226 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.225 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.225 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.223 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.222 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.222 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.222 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86 javascript.0 2024-08-11 07:45:52.222 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.222 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.222 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.222 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243) javascript.0 2024-08-11 07:45:52.222 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.221 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.219 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.218 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.218 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.218 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86 javascript.0 2024-08-11 07:45:52.218 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.218 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243) javascript.0 2024-08-11 07:45:52.218 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.218 error at Module.require (node:internal/modules/cjs/loader:1233:19) javascript.0 2024-08-11 07:45:52.217 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.217 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.214 error at Module.load (node:internal/modules/cjs/loader:1208:32) javascript.0 2024-08-11 07:45:52.214 error at Module._compile (node:internal/modules/cjs/loader:1358:14) javascript.0 2024-08-11 07:45:52.214 error at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86 javascript.0 2024-08-11 07:45:52.214 error at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243) javascript.0 2024-08-11 07:45:52.214 error at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) javascript.0 2024-08-11 07:45:52.214 error at Function.Module._load (node:internal/modules/cjs/loader:1024:12) javascript.0 2024-08-11 07:45:52.213 error at require (node:internal/modules/helpers:179:18) javascript.0 2024-08-11 07:45:52.213 error at Function.Module._load (node:internal/modules/cjs/loader:986:27) javascript.0 2024-08-11 07:45:52.213 error script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs' javascript.0 2024-08-11 07:45:52.213 error at Module.require (node:internal/modules/cjs/loader:1233:19) -
Servus, ich habe das Problem daß in letzter Zeit das NS-Panel öfter hängen bleibt. Ich habe vor einer Woche mal alles auf den neuesten Stand gebracht, aber das hat nichts geändert. Heute morgen wieder ohne Funktion, Uhrzeit steht auf 11:17, Tasmota ist nicht mehr erreichbar, hilft nur noch Sicherung raus und wieder rein. Kennt jemand das Problem?
@wuschl sagte in SONOFF NSPanel mit Lovelace UI:
Könntest du das etwas detaillierter beschreiben? Ist so etwa wie mein Vogelhaus kippt ständig um und ich sage meiner Frau, sie soll den Herd an und ausmachen
Wie ist Tasmota nicht erreichbar?
- per MQTT oder per Web-GUI?
Wovon wird ne Sicherung gemacht und wieder eingespielt?
- etwa vom ioBroker? falls ja, warum sollte es das Problem zu einem komplett entkoppeltem System ändern?
- Oder Sicherung für die Stromversorgung aus/an?
Für mich deutet im Moment mehr auf eine schlechte WLAN-Kommunikation hin...
- Check das mal, ggfs. Pings aufzeichnen, um zu sehen, ob es Abrisse gibt
- WLAN Channel prüfen, um auszuschließen, dass es permanente Kanalwechsel gibt
- RSSI checken um sicherzustellen, dass da außer Rauschen überhaupt etwas ankommen kann
- etc.
Kann tausende Gründe dafür geben... Etwas mehr Input...
- etc.
@armilar das Panel ist weder per mqtt noch über die Web-Gui erreichbar. Kein Neustart mehr möglich. Heißt, die STROM-Sicherung raus und wieder rein, dann läuft es wieder ein paar Tage, manchmal länger manchmal kürzer. Schlechte Wlan Verbindung ist auszuschließen. Es reagieren nicht mal mehr die Taster-Relais an denen ein ganz normales Licht angeschlossen ist.
Dies trat vor ein paar Monaten plötzlich auf, es wurde aber nichts verändert außer Tasmota Auto-Update.
Was steht denn im Logfile vom Tasmota?
Schieb die Ausgabe auf n Syslogserver und schau dir an, was da los ist..
ansonsten, einfach dann flash doch alles nochmal, vielleicht ist da was schief gegangen. -
@ilovegym wo finde ich das Logfile?
Ich habe es vor einer Woche komplett neu gemacht. Auch das Script auf den neuesten Stand gebracht. Aber es ist heute genauso passiert wie vor dem Neuflash.
Fehler sind oft in der Tasmota Console zu sehen. Oder sind die Fehler im javascript im iobroker?
Musst halt mal schauen, was da los ist..
Ansonsten per serial kabel dran und debuggen, so wie du flashst.. da sieht man alle Ausgaben..Dann gibts in Tasmota noch die Möglichkeit, die Daten an einen Syslogserver zu senden, dann tauchen die Fehler auch dort auf.
Hat es denn mittlerweile schon mal jemand probiert, ein Ns Panel hinter einem Shelly Dimmer 2 laufen zu lassen?
@lustig29
Hi,wie meinst Du das? Einen Dimmer mit dem Panel anzusteuern, ist kein Thema.
Wie meinst Du das mit "ein Panel hinter einem Dimmer betreiben"?LG
@lustig29
@kuckuckmann
Naja, im Moment ist ein Shelly Dimmer an einem Taster im Bad angeschlossen. Jetzt möchte ich gerne den Taster gegen ein Ns Panel tauschen. Und wenn möglich, die Helligkeit/Ein-Aus über die 2 Tasten von dem Ns Panel steuern. -
@kuckuckmann
Naja, im Moment ist ein Shelly Dimmer an einem Taster im Bad angeschlossen. Jetzt möchte ich gerne den Taster gegen ein Ns Panel tauschen. Und wenn möglich, die Helligkeit/Ein-Aus über die 2 Tasten von dem Ns Panel steuern.@lustig29
Hatten wir das Thema nicht schon mal? Ich erinnere mich da wage.Was auf jeden Fall geht, du kannst den Shelly über das NSPanel über den ioBroker steuern. Sprich via Touch auf dem Display.
Das ganze über die beiden Tasten zu steuern, auch mit long push auf den Tasten, da habe ich bei meinen Recherchen keine funktionierende Lösung gefunden. Letztlich müsstest Du da mal in die Tasmota Beschreibung schauen, wenn Du es unbedingt über die Buttons machen willst. Die Buttons von den Relais zu entkoppeln, geht. Dazu haben wir auch eine Anleitung in der Wiki. Mit einem Kurzdruck was zu steuern, was via ioBroker geht, sollte auch gehen. Aber die Taste gedrückt halten und dann eine Aktion machen - oder ein Doppel-/Dreifach-Druck, das ist eine Herausforderung - in meinen Augen.Wäre die Option über das Display für dich auch ausreichend?
LG
@kuckuckmann
Ja, definitiv. Mir geht es in erster Linie darum das ich über das Display Radio, Rollo, Licht usw. steuern kann. -
@kuckuckmann
Ja, definitiv. Mir geht es in erster Linie darum das ich über das Display Radio, Rollo, Licht usw. steuern kann.@lustig29
Ja dann :-)
Benötigst Du außer An/Aus und Helligkeit einstellen noch mehr? -
Müsste mit
- setOption1 1 (Multimode)
- setOption73 1 (Detach)
gehen
Rule 2 dabei deaktivieren...
Per MQTT wird zum Zeitpunkt:
23:57:30.884 MQT: SmartHome/NSPanel_4/stat/RESULT = {"Button1":{"Action":"SINGLE"}} 23:57:33.949 MQT: SmartHome/NSPanel_4/stat/RESULT = {"Button1":{"Action":"DOUBLE"}} 23:57:39.531 MQT: SmartHome/NSPanel_4/stat/RESULT = {"Button1":{"Action":"TRIPLE"}} 23:57:44.991 MQT: SmartHome/NSPanel_4/stat/RESULT = {"Button1":{"Action":"QUAD"}} 23:57:47.199 MQT: SmartHome/NSPanel_4/stat/RESULT = {"Button1":{"Action":"PENTA"}} 23:57:51.111 MQT: SmartHome/NSPanel_4/stat/RESULT = {"Button1":{"Action":"HOLD"}} 23:57:55.834 MQT: SmartHome/NSPanel_4/stat/RESULT = {"Button1":{"Action":"CLEAR"}}gesendet.
Da man die DOUBLE bis PENTA nicht benötigt, kann man die auch auf die gleiche Logik wie SINGLE legen.
Bei langem Druck wird HOLD mitgegeben und beim Loslassen CLEAR
Daraus lässt sich dann eine Logik bauen...
- Solange HOLD gedrückt ist, wird ein Wert kontinuierlich inkrementiert oder dekrementiert, bis CLEAR kommt
- Mit SINGLE bis PENTA wird getoggelt
Der Toggle setzt sich auf den Switch des Shelly Dimmer und der Inkrementierte/Dekrementierte Wert verändert den Dimmer-Datenpunkt
Also alles im separaten Blockly oder JS oder TS - sollte aber machbar sein...
Zum Abgreifen der Werte kann man sich am Beispiel im Wiki orientieren... Der Rest ist Fleißarbeit
https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Tasmota-FAQ#12--multipress-mode
@lustig29
Ja dann :-)
Benötigst Du außer An/Aus und Helligkeit einstellen noch mehr?Nee, was das Licht angeht nicht.😃
Es soll dann mal eine Sonos Box und das Rollo drüber angesteuert werden.
