  4. Host Problem nach Aktualisierung auf 6.0.9
48 Beiträge 9 Kommentatoren 6.5k Aufrufe 6 Beobachtet
  • J Offline
    JoergK
    heute bin ich leider in die selbe Falle getappt.
    Nachdem Update des Host Adapers auf 6.0.9 gibt der Javascript Adapter Fehler aus und findet einige zusatzmodule nicht mehr.
    	2024-08-05 20:17:42.280	error	Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/Math/' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js at new NodeError (node:internal/errors:405:5) at legacyMainResolve (node:internal/modules/esm/resolve:233:9) at packageResolve (node:internal/modules/esm/resolve:874:14) at moduleResolve (node:internal/modules/esm/resolve:936:20) at defaultResolve (node:internal/modules/esm/resolve:1129:11) at nextResolve (node:internal/modules/esm/loader:163:28) at ESMLoader.resolve (node:internal/modules/esm/loader:835:30) at ESMLoader.getModuleJob (node:internal/modules/esm/loader:424:18) at ESMLoader.import (node:internal/modules/esm/loader:524:22) at importModuleDynamically (node:internal/modules/cjs/loader:1188:29)
    javascript.0
    	2024-08-05 20:17:42.279	error	Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/Math/' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
    javascript.0
    	2024-08-05 20:17:42.279	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0
    	2024-08-05 20:14:36.394	error	Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/Math/' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js at new NodeError (node:internal/errors:405:5) at legacyMainResolve (node:internal/modules/esm/resolve:233:9) at packageResolve (node:internal/modules/esm/resolve:874:14) at moduleResolve (node:internal/modules/esm/resolve:936:20) at defaultResolve (node:internal/modules/esm/resolve:1129:11) at nextResolve (node:internal/modules/esm/loader:163:28) at ESMLoader.resolve (node:internal/modules/esm/loader:835:30) at ESMLoader.getModuleJob (node:internal/modules/esm/loader:424:18) at ESMLoader.import (node:internal/modules/esm/loader:524:22) at importModuleDynamically (node:internal/modules/cjs/loader:1188:29)
    javascript.0
    	2024-08-05 20:14:36.393	error	Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/Math/' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
    javascript.0
    	2024-08-05 20:14:36.393	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    Habe auch die üblichen Updates gefahren.
    Node.js
    v18.17.1 (Es gibt eine neuere Version: v18.20.4)
    NPM
    9.6.7
    Pfad
    /opt/iobroker/
    "Raspbian GNU/Linux 10 (buster)"
    Kann das mit der buster-Version zusammenhängen?
    Vielen Dank für Tipps.
    Jörg
    HomoranH haselchenH mcm1957M Thomas BraunT 4 Antworten Letzte Antwort
    • J JoergK
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Node.js
      NPM
      9.6.7
      Pfad
      /opt/iobroker/
      Jörg
      @joergk sagte in Host Problem nach Aktualisierung auf 6.0.9:
      ja!
      Buster ist schon lange tot!
      mal sehen ob due Langfassung von iob diag noch mehr Leichen findet
      • J JoergK
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        Node.js
        NPM
        9.6.7
        Pfad
        /opt/iobroker/
        Jörg
        haselchenH Offline
        haselchenH Offline
        haselchen
        @joergk
        Buster ist längst begraben und Node18 nicht mehr Up to Date.
        Beides auf aktuellen Stand bringen .
        Edit: Du bist seit 5 Jahren hier dabei und tappst in eine „Falle“?
        @Homoran
        Ich lese das in letzter Zeit öfter , dass die OS uralt sind.
        Und damit wachsen durch die aktuellen Anforderungen die Probleme hier.
        Ob man in gewissen Abständen auch ne Kachel im Admin aufploppen lassen kann, die auf ein altes OS hinweisen?
        • J JoergK
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          Node.js
          NPM
          9.6.7
          Pfad
          /opt/iobroker/
          Jörg
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @joergk
          Aber auf Buster KEINESFALLS node > 18 versuchen zu installieren. Sonst hast das nächste Problem ...
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • haselchenH haselchen
            @joergk
            @Homoran
            @haselchen sagte in Host Problem nach Aktualisierung auf 6.0.9:
            https://forum.iobroker.net/topic/76236/update-meldungen-nach-dem-einloggen-abschalten/15
            • J JoergK
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              Node.js
              NPM
              9.6.7
              Pfad
              /opt/iobroker/
              Jörg
              Zumindest ist da eine Neuinstallation des aktuellen Releases mehr als überfällig.
              • mcm1957M mcm1957
                @joergk
                mcm1957M Online
                mcm1957M Online
                mcm1957
                Und generell Probleme die vermutlich js-controller 6 zuzuordnen sind nicht hier sondern im 'Js-controller 6 nun km stable' Topic ansprechen. DORT lesen due betreffenden core devs mit.
                @Homoran
                Überleg ob das neue Theme hier sinnvoller Weise abgetrennt und in de js-c 6 topic verschoben werden sollte. Und anschließend hier geschlossen werden jann um doppelte js-c 6 threads zu vermeiden.
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  Da wird über Updates des aktuellen Systems geschrieben .
                  In dem Hinweis steht nicht, dass es veraltet ist oder der Hinweis: Sie benutzen Buster , aktuell ist Bookworm (zum Beispiel).
                  Erscheint die Kachel egal für welches OS Updates anstehen?
                  Denn dann würde der User nicht sehen, dass es veraltet ist/wäre.
                  • mcm1957M mcm1957
                    @Homoran
                    @mcm1957 ist es ein jsc6 Thema?
                    das hab ich nicht herauslesen können.
                      Der kommt aber (zugegeben etwas verklausuliert) bei dem Update über die Kommandozeile dann.
                      Da steht dann sinngemäß, das sich der Suite-Wert von 'stable' auf 'oldstable', in der nächsten Stufe dann von 'oldstable' auf 'oldoldstable' verändert. Und man verwendet kein 'oldstable', 'oldoldstable' dann schon garnicht.
                      Raspberry OS unterstützt nämlich nur 'stable' und 'oldstable'.
                      Und genau deswegen bekommst du auch kein nodejs>=20 mehr auf das längst abgekündigte Ding.
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        Nunja, da müssen wir uns aber ehrlich machen .
                        Wieviele User, denkst Du, erkennen an dem Wort Oldstable, dass es sich um ein altes OS handelt !?
                        Außer den Cracks hier niemand .
                        Außerdem müsste man ja erstmal die Konsole dazu bemühen. Und wenn nicht schon in der Kachel ein fetter Hinweis auf ein altes OS gemacht wird , wird auch niemand vorher handeln.
                        Ich denke, dass viele den Update Hinweis einfach wegklicken.
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          @homoran said in Host Problem nach Aktualisierung auf 6.0.9:
                          Na ja die fehlenden npm module hä gen zu 99% mit der Umstellung wie der javascript Adapter nun unter js-controller 6 module einbindet zusammen. Ob das nun eher javascript oder js-controller 6 ist weiß iach auch nicht. Die beiden sind in dem Punkt m.W. nach verzahnt. Nicht umsonst wurden js-controller 6 und javascript x.x.x zusmmen in stable gepusht.
                          Aber OK, kann auch hier weiterlaufen ...
                            @haselchen
                            OT:
                            Ich hatte schon mal überlegt eine entsprechende Meldung in iob diag zu übernehmen.
                            Stable = Grün markiert
                            Old Stable = Gelb
                            Oldold Stable = Rot
                              @haselchen
                              OT:
                              Old Stable = Gelb
                              Oldold Stable = Rot
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              @thomas-braun said in Host Problem nach Aktualisierung auf 6.0.9:
                              @haselchen
                              OT:
                              Old Stable = Gelb
                              Oldold Stable = Rot
                              OT:
                              a) klingt gut
                              b) ev. könnte man die Info auch im Admin geeignet anzeigen - aber NICHT als popup.
                              Frage ist da aber wie der Admin bei x unterschiedlichen O/S da sicher was beurteilen kann. Das wird immer ne halbe Sache. Wahrscheinlich würde es reichen in iob-diag und im node update script alte O/S Versionen anzumeckern und veraltete Versionen beim node update zu sperren. Da stehen dann irgendwann die User eh an weil Adapter ein neues node verlangen ...
                              Und OT+:
                              c) Ich mecker derzeit an wenn ein Adapter weniger als js-controller 4 verlangt und empfehle js-controller 5 zu verlangen. Wär zu überlegen wann wir bei neuen Adapter Releases js-controller 5 verbindlich verlangen sollten.
                              • mcm1957M mcm1957
                                @haselchen
                                OT:
                                Old Stable = Gelb
                                Oldold Stable = Rot
                                OT:
                                a) klingt gut
                                Und OT+:
                                @mcm1957 sagte in Host Problem nach Aktualisierung auf 6.0.9:
                                Genau das war der Grund, warum ich das auch für iob diag nicht drin habe. Neben den Debian-Releases müsstest du da dann auch die diversen Schnubbibuntus drin haben und deren Interims-Versionen haben nur eine Lebensdauer von 9 Monaten. Die sollte man zwar eh nicht für anderes als Tests verwenden, aber du siehst die Eintagsfliegen aber dennoch in freier ioBroker-Wildbahn.
                                mcm1957M HomoranH 2 Antworten Letzte Antwort
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  OK - das ist wirklich dein Fachgebiet. Wenn jemadn dann weißt du was sinnvoll geht und was nicht...
                                    @thomas-braun von suse (gibts das noch?) redhat (dito) mint und sonstigen Varianten ganz abgesehen.
                                      Klar gibt es das noch. Ist aber mittlerweile eher im Enterprise-Umfeld zu finden. Ebenso wie Redhat (Fedora).
                                      Mint wäre einfach, ist das doch eine Abwandlung von Ubuntu (die schmeißen allerdings viel von dem Ubuntu-Quatsch wieder raus), was wiederum eine Abwandlung von Debian ist...
                                      Soooo grausam viele Basis-Distributionen gibt es ja eigentlich gar nicht. Viele lassen sich auf auf eine der 'Urmütter' wie Debian, Arch, Redhat oder eben Suse zurückführen. Der 'Rest' ist im Grunde nur an der Oberfläche etwas anders, aka 'Wallpaper-Distribution'.
                                      • J Offline
                                        JoergK
                                        Danke für die schnellen Antworten :-)
                                        Jetzt hab ich das System neu aufgesetzt. Und es läuft fast alles wieder.
                                        Soweit so gut.
                                        Wäre schön, wenn wir hier mit unserem Übereifer an den Update-Meldungen oder Warnungen anderen das Leid ersparen können, z.B durch einen Versionscheck ;-)
                                        Ist halt schon ärgerlich, wenn sowas, wie in meinem Fall am Produktivsystem nach Feierabend bei 30Grad passiert und man eigentlich dafür keine Zeit hat. Och es ist doch nur EIN Update 😵
                                        Ich dachte eigentlich, die Zeiten in denen ich nächtelang Linuxsysteme aufsetze, sind vorbei 🙄
                                        Gruß.
                                        • J JoergK
                                          Soweit so gut.
                                          Gruß.
                                          Dafür hast du tausende Upgrades zuvor halt verpasst. Das holt dich irgendwann immer ein.
