  4. GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log
61 Beiträge 3 Kommentatoren 8.3k Aufrufe 2 Beobachtet
    @mathias2803
    Kiste weiter updaten.
    iob update
    iob upgrade all -y
    Dann zieh ein aktuelles Backup und zieh damit um.
    Neuinstallation wie hier:
    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
    OHNE Desktop und sonstigem Quatsch und in der 64Bit-Version.
    Mathias2803
                            v.2024-05-22
       Static hostname: ioBroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    User-ID:                1000
    Display-Server:         true
    Pending OS-Updates:     0
    Pending iob updates:    16
    Nodejs-Installation:
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    Recommended versions are nodejs 18.20.4 and npm 10.7.0
    MEMORY:
    Mem:           3.8G        1.4G        692M        8.0M        1.8G        2.3G
    Swap:           99M          0B         99M
    Total:         3.9G        1.4G        792M
    Active iob-Instances:   10
    Upgrade policy: none
    ioBroker Core:          js-controller           6.0.9
                            admin                   6.13.16
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                20349
    States:                 17590
    Size of iob-Database:
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/objects.json.migrated
    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    0       /opt/iobroker/iobroker-data/objects.json.broken
    12M     /opt/iobroker/iobroker-data/states.jsonl
    4.0M    /opt/iobroker/iobroker-data/states.json.migrated
    4.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    • M Mathias2803
                              v.2024-05-22
               Icon name: computer
            Architecture: arm
      Kernel:                 armv7l
      Userland:               32 bit
      User-ID:                1000
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      MEMORY:
      Swap:           99M          0B         99M
                              admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      Objects:                20349
      States:                 17590
      @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
      Das muss 0 werden.
      HomoranH M 2 Antworten Letzte Antwort
        Das muss 0 werden.
        @thomas-braun sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
        Das muss 0 werden.
        @Mathias2803
        wie sieht denn die Seite "Adapter" im admin aus.
        gefiltert auf Adapter mit Update
          Das muss 0 werden.
          Mathias2803
          pi@ioBroker:~ $ iob update
          Used repository: stable
          Adapter    "admin"        : 7.0.22   , installed 6.13.16 [Updatable]
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
          Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
          Adapter    "botvac"       : 2.2.0    , installed 2.0.2  [Updatable]
          Adapter    "chromecast"   : 3.4.0    , installed 3.2.0  [Updatable]
          Adapter    "daswetter"    : 3.1.15   , installed 3.1.13 [Updatable]
          Adapter    "deconz"       : 1.4.1    , installed 2.0.7
          Adapter    "devices"      : 1.1.5    , installed 1.1.5
          Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
          Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
          Adapter    "javascript"   : 8.7.6    , installed 7.8.0  [Updatable]
          Controller "js-controller": 6.0.9    , installed 6.0.9
          Adapter    "lifx"         : 1.0.4    , installed 1.0.4
          Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "panasonic-viera": 2.1.0  , installed 2.0.0  [Updatable]
          Adapter    "samsung"      : 0.6.0    , installed 0.5.11 [Updatable]
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "telegram"     : 3.3.2    , installed 3.1.0  [Updatable]
          Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
          Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          pi@ioBroker:~ $ iob upgrade all -y
          Update vis-jqui-mfd from @1.0.12 to @1.1.1
          NPM version: 10.7.0
          Installing iobroker.vis-jqui-mfd@1.1.1... (System call)
          changed 1 package in 17s
          231 packages are looking for funding
            run `npm fund` for details
          INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
          Adapter "system.adapter.vis.0" restarted.
          Update "system.adapter.vis-jqui-mfd.0"
          upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
          Update vis-hqwidgets from @1.4.0 to @1.5.1
          NPM version: 10.7.0
          Installing iobroker.vis-hqwidgets@1.5.1... (System call)
          changed 1 package in 15s
          INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
          Update "system.adapter.vis-hqwidgets.0"
          upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
          upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
          Update simple-api from @2.7.2 to @2.8.0
          host.ioBroker Adapter "system.adapter.simple-api.0" is stopped.
          NPM version: 10.7.0
          Installing iobroker.simple-api@2.8.0... (System call)
          added 55 packages, removed 167 packages, and changed 2 packages in 1m
          237 packages are looking for funding
          Update "system.adapter.simple-api.0"
          upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
          upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
          upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
          upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
          upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
          upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
          upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
          upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
          upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
          upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
          upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
          upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.json application/json
          upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
          upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
          host.ioBroker Adapter "system.adapter.simple-api.0" is started
          Update discovery from @4.4.0 to @4.5.0
          NPM version: 10.7.0
          Installing iobroker.discovery@4.5.0... (System call)
          changed 2 packages in 16s
          Update "system.adapter.discovery.0"
          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
          Update daswetter from @3.1.13 to @3.1.15
          host.ioBroker Adapter "system.adapter.daswetter.0" is stopped.
          NPM version: 10.7.0
          Installing iobroker.daswetter@3.1.15... (System call)
          removed 3 packages, and changed 2 packages in 18s
          Update "system.adapter.daswetter.0"
          upload [482] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
          upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/10.png icons/tiempo-weather/galeria1/10.png image/png
          upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/19.png icons/tiempo-weather/galeria3/19.png image/png
          upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/1.png icons/tiempo-weather/galeria5/PNG/White/1.png image/png
          upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/SVG/White/15.svg icons/tiempo-weather/galeria5/SVG/White/15.svg image/svg+xml
          upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/5.png icons/tiempo-weather/galeria6/5.png image/png
          upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/41.png icons/viento-wind/Beaufort-White/41.png image/png
          upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/87.png icons/viento-wind/Beaufort-White/87.png image/png
          upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/104.png icons/viento-wind/galeria2-Beaufort/104.png image/png
          upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/2.png icons/viento-wind/galeria2-Beaufort/2.png image/png
          upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/29.png icons/viento-wind/galeria2-Beaufort/29.png image/png
          upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/38.png icons/viento-wind/galeria2-Beaufort/38.png image/png
          upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/47.png icons/viento-wind/galeria2-Beaufort/47.png image/png
          upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/56.png icons/viento-wind/galeria2-Beaufort/56.png image/png
          upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/65.png icons/viento-wind/galeria2-Beaufort/65.png image/png
          upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/74.png icons/viento-wind/galeria2-Beaufort/74.png image/png
          upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/83.png icons/viento-wind/galeria2-Beaufort/83.png image/png
          upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/84.png icons/viento-wind/galeria2-Beaufort/84.png image/png
          upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/85.png icons/viento-wind/galeria2-Beaufort/85.png image/png
          upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/86.png icons/viento-wind/galeria2-Beaufort/86.png image/png
          upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/87.png icons/viento-wind/galeria2-Beaufort/87.png image/png
          upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/88.png icons/viento-wind/galeria2-Beaufort/88.png image/png
          upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/89.png icons/viento-wind/galeria2-Beaufort/89.png image/png
          upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/9.png icons/viento-wind/galeria2-Beaufort/9.png image/png
          upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/90.png icons/viento-wind/galeria2-Beaufort/90.png image/png
          upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/91.png icons/viento-wind/galeria2-Beaufort/91.png image/png
          upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/92.png icons/viento-wind/galeria2-Beaufort/92.png image/png
          upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/93.png icons/viento-wind/galeria2-Beaufort/93.png image/png
          upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/94.png icons/viento-wind/galeria2-Beaufort/94.png image/png
          upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/95.png icons/viento-wind/galeria2-Beaufort/95.png image/png
          upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/96.png icons/viento-wind/galeria2-Beaufort/96.png image/png
          upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/97.png icons/viento-wind/galeria2-Beaufort/97.png image/png
          upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/98.png icons/viento-wind/galeria2-Beaufort/98.png image/png
          upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/99.png icons/viento-wind/galeria2-Beaufort/99.png image/png
          upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/index_m.html index_m.html text/html
          upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/jsonConfig.json jsonConfig.json application/json
          upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/words.js words.js application/javascript
          host.ioBroker Adapter "system.adapter.daswetter.0" is started
          Update alexa2 from @3.26.4 to @3.26.5
          NPM version: 10.7.0
          Installing iobroker.alexa2@3.26.5... (System call)
          changed 7 packages in 33s
          239 packages are looking for funding
          Update "system.adapter.alexa2.0"
          upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
          upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
          upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
          upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
          upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
          upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
          upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
          upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
          Update admin from @6.13.16 to @7.0.22
          host.ioBroker Adapter "system.adapter.admin.0" is stopped.
          NPM version: 10.7.0
          Installing iobroker.admin@7.0.22... (System call)
          added 26 packages, removed 8 packages, and changed 21 packages in 2m
          245 packages are looking for funding
          host.ioBroker Cannot install iobroker.admin@7.0.22: 0
          • M Mathias2803
            NPM version: 10.7.0
            NPM version: 10.7.0
            NPM version: 10.7.0
            NPM version: 10.7.0
            NPM version: 10.7.0
            NPM version: 10.7.0
            NPM version: 10.7.0
            Danach kommt nix mehr?
            Sind die Updates der anderen Adapter nun drin?
            iob update
            nochmal anschauen.
              iob update
              nochmal anschauen.
              Mathias2803
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
              Adapter    "echarts"      : 1.7.2    , installed 1.7.2
              Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
              Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
              Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
              Wohl leider nicht.
              Habe auch neu starten müssen. Der IoBroker lief dann nicht mehr richtig. im Browser.
                iob update
                nochmal anschauen.
                Mathias2803
                schrieb am zuletzt editiert von Mathias2803
                Aber das System scheint wieder etwas besser zu laufen.
                Vis ist an, Daten kommen in Grafana an...
                Aber es fehlen doch noch Elemente.
                • M Mathias2803
                  @mathias2803
                  Dann nochmal
                  iob upgrade all -y
                  Zur Not die Adapter einzeln updaten.
                    @mathias2803
                    Dann nochmal
                    iob upgrade all -y
                    und dazu ggf. im admin nachsehen warum die nicht wollen.
                    das steht dann 7n der Kachel
                      Mathias2803
                      Update vis-inventwo from @3.3.3 to @3.3.4
                      NPM version: 10.7.0
                      Installing iobroker.vis-inventwo@3.3.4... (System call)
                      added 30 packages, removed 122 packages, and changed 36 packages in 28s
                      272 packages are looking for funding
                      Adapter "system.adapter.web.0" restarted.
                      Update "system.adapter.vis-inventwo.0"
                      upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                      upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                      upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                      upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                      upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                      upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                      upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                      upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                      upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                      upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                      upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                      upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                      upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                      upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                      upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                      upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                      upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                      upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                      upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
                      upload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
                      upload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                      upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                      NPM version: 10.7.0
                      added 25 packages, removed 8 packages, and changed 21 packages in 1m
                      276 packages are looking for funding
                      Update "system.adapter.admin.0"
                      upload [67] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                      upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91570.411e854b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91570.411e854b.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91571.499943a2.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91571.499943a2.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js.map'
                      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js.map'
                      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js.map'
                      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js.map'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js'
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js.map'
                      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js'
                      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map'
                      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js'
                      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map'
                      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js'
                      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map'
                      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js'
                      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map'
                      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico'
                      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json'
                      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json'
                      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json'
                      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json'
                      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json'
                      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json'
                      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json'
                      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json'
                      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json'
                      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json'
                      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json'
                      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                      Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5'
                      Update ws from @2.5.10 to @2.6.1
                      NPM version: 10.7.0
                      Installing iobroker.ws@2.6.1... (System call)
                      Try to solve ENOTEMPTY error automatically
                      Could not handle ENOTEMPTY, because no deletable files were found
                      npm error code ENOTEMPTY
                      npm error syscall rename
                      npm error path /opt/iobroker/node_modules/iobroker.admin
                      npm error dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                      npm error errno -39
                      npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-05T09_22_38_819Z-debug-0.log
                      host.ioBroker Cannot install iobroker.ws@2.6.1: 217
                      Thomas BraunT M 2 Antworten Letzte Antwort
                      • M Mathias2803
                        NPM version: 10.7.0
                        NPM version: 10.7.0
                        NPM version: 10.7.0
                        npm error errno -39
                        @mathias2803
                        iob stop
                        iob fix
                        iob update
                        iob upgrade all -y
                        Das u. U. so lange wiederholen, bis keine Updates mehr vorliegen.
                        • M Mathias2803
                          NPM version: 10.7.0
                          NPM version: 10.7.0
                          NPM version: 10.7.0
                          npm error errno -39
                          Mathias2803
                          @mathias2803
                          pi@ioBroker:~ $ iob stop
                          pi@ioBroker:~ $ iob fix
                          library: loaded
                          Library version=2024-05-24
                              Welcome to the ioBroker installation fixer!
                              Script version: 2024-01-04
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/5)
                          OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:2 http://archive.raspberrypi.org/debian buster InRelease
                          Holen:3 https://repos.influxdata.com/debian buster InRelease [12,9 kB]
                          OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          OK:5 https://phoscon.de/apt/deconz buster InRelease
                          OK:6 https://twolife.be/raspbian buster InRelease
                          Fehl:3 https://repos.influxdata.com/debian buster InRelease
                            Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                          Fehl:6 https://twolife.be/raspbian buster InRelease
                            Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                          OK:7 https://archive.raspbian.org/raspbian buster InRelease
                          Es wurden 12,9 kB in 6 s geholt (2.284 B/s).
                          W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian buster InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                          W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://twolife.be/raspbian buster InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                          W: Fehlschlag beim Holen von https://twolife.be/raspbian/dists/buster/InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                          W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/buster/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                          W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                              Checking ioBroker user and directory permissions (2/5)
                          This system does not support setting default permissions.
                          Do not use npm to manually install adapters unless you know what you are doing!
                              Check and cleanup npm temporary directories (3/5)
                          Done.
                              Database maintenance (4/5)
                          Checking for uncompressed JSONL databases... This might take a while!
                          Compressing /opt/iobroker/iobroker-data/states.jsonl
                          Compressing /opt/iobroker/iobroker-data/objects.jsonl
                          Compressed 2 JSONL files. Done
                              Checking autostart (5/5)
                          Enabling autostart...
                          Autostart enabled!
                              Your installation was fixed successfully
                              Run iobroker start to start ioBroker again!
                            Mathias2803
                            Die Oberfläche startet gerade nicht mehr.
                            Dafür aber VIS und die Skripte. :-)
                            Ich lasse die Updates mehrfach laufen oder einzeln in Putty.
                            Admin konnte ich einzeln durchbekommen.
                            • M Mathias2803
                              Versuch mal
                              iob start admin
                                @mathias2803
                                iob stop
                                iob fix
                                iob update
                                iob upgrade all -y
                                Mathias2803
                                NPM version: 10.7.0
                                added 3 packages, removed 1 package, and changed 2 packages in 13s
                                296 packages are looking for funding
                                upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                                upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
                                Update web from @6.2.3 to @6.2.5
                                host.ioBroker Adapter "system.adapter.web.0" is stopped.
                                NPM version: 10.7.0
                                Installing iobroker.web@6.2.5... (System call)
                                removed 2 packages, and changed 5 packages in 24s
                                295 packages are looking for funding
                                upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                Update "system.adapter.web.0"
                                upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                                upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                                upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                                upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                                upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                                upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                                upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                                upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                                upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                                upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                                upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                                upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                                upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                                upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                host.ioBroker Adapter "system.adapter.web.0" is started
                                Update vis from @1.5.4 to @1.5.6
                                NPM version: 10.7.0
                                Installing iobroker.vis@1.5.6... (System call)
                                changed 1 package in 1m
                                upload [746] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/stateful.png icon/stateful.png image/png
                                upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/js/connSignalR.js js/connSignalR.js application/javascript
                                upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/24/zip.png js/fm/icon/mine/24/zip.png image/png
                                upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/dropzone.js lib/js/dropzone.js application/javascript
                                upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_StatefulContainerView8.png widgets/basic/img/Prev_StatefulContainerView8.png image/png
                                upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/img/Prev_tplEchartsChart.png widgets/echarts/img/Prev_tplEchartsChart.png image/png
                                upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/prev/Prev_hqwidgetsDimmer.png widgets/hqwidgets/img/prev/Prev_hqwidgetsDimmer.png image/png
                                upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_20.png widgets/jqui-mfd/img/fts_shutter_20.png image/png
                                upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_roof.png widgets/jqui-mfd/img/fts_window_roof.png image/png
                                upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_50.svg widgets/jqui-mfd/img/sani_valve_50.svg image/svg+xml
                                upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/001-3.png widgets/timeandweather/img/clock/001-3.png image/png
                                upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/511-3.png widgets/timeandweather/img/clock/511-3.png image/png
                                upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Image.png widgets/vis-inventwo/img/0_Image.png image/png
                                upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Switch1.png widgets/vis-inventwo/img/0_Switch1.png image/png
                                upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Multi.gif widgets/vis-inventwo/img/Multi.gif image/gif
                                upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png image/png
                                upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01/min.png widgets/vis-inventwo/img/clock_analog/01/min.png image/png
                                upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png
                                upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png
                                upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.browser.js widgets/weather/lib/js/flot/jquery.flot.browser.js application/javascript
                                upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.js widgets/weather/lib/js/flot/jquery.flot.js application/javascript
                                upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.legend.js widgets/weather/lib/js/flot/jquery.flot.legend.js application/javascript
                                upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.logaxis.js widgets/weather/lib/js/flot/jquery.flot.logaxis.js application/javascript
                                upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.navigate.js widgets/weather/lib/js/flot/jquery.flot.navigate.js application/javascript
                                upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.pie.js widgets/weather/lib/js/flot/jquery.flot.pie.js application/javascript
                                upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.resize.js widgets/weather/lib/js/flot/jquery.flot.resize.js application/javascript
                                upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.saturated.js widgets/weather/lib/js/flot/jquery.flot.saturated.js application/javascript
                                upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.selection.js widgets/weather/lib/js/flot/jquery.flot.selection.js application/javascript
                                upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.stack.js widgets/weather/lib/js/flot/jquery.flot.stack.js application/javascript
                                upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.symbol.js widgets/weather/lib/js/flot/jquery.flot.symbol.js application/javascript
                                upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.threshold.js widgets/weather/lib/js/flot/jquery.flot.threshold.js application/javascript
                                upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.time.js widgets/weather/lib/js/flot/jquery.flot.time.js application/javascript
                                upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touch.js widgets/weather/lib/js/flot/jquery.flot.touch.js application/javascript
                                upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js application/javascript
                                upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.uiConstants.js widgets/weather/lib/js/flot/jquery.flot.uiConstants.js application/javascript
                                upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js widgets/weather/lib/js/flot/jquery.js application/javascript
                                upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js widgets/weather/lib/js/lib/globalize.culture.en-US.js application/javascript
                                upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js widgets/weather/lib/js/lib/globalize.js application/javascript
                                upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js widgets/weather/lib/js/lib/jquery.event.drag.js application/javascript
                                upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js widgets/weather/lib/js/lib/jquery.mousewheel.js application/javascript
                                upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html widgets/weather.html text/html
                                Update "system.adapter.vis.0"
                                upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                Update trashschedule from @3.2.0 to @3.3.0
                                NPM version: 10.7.0
                                Installing iobroker.trashschedule@3.3.0... (System call)
                                changed 1 package in 13s
                                  run `npm fund` for details
                                Adapter "system.adapter.vis.0" restarted.
                                Update "system.adapter.trashschedule.0"
                                upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                                upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                                Update tr-064 from @4.2.18 to @4.3.0
                                NPM version: 10.7.0
                                Installing iobroker.tr-064@4.3.0... (System call)
                                Update "system.adapter.tr-064.0"
                                Update "system.adapter.tr-064.1"
                                Update "system.adapter.tr-064.2"
                                upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                Update telegram from @3.1.0 to @3.3.2
                                host.ioBroker Adapter "system.adapter.telegram.0" is stopped.
                                NPM version: 10.7.0
                                Installing iobroker.telegram@3.3.2... (System call)
                                changed 2 packages in 16s
                                Update "system.adapter.telegram.0"
                                upload [70] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                upload [60] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                                upload [50] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_prop-types_index_js.6da256b6.chunk.js custom/static/js/node_modules_prop-types_index_js.6da256b6.chunk.js application/javascript
                                upload [40] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es.json i18n/es.json application/json
                                upload [30] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                upload [20] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pl.json rules/i18n/pl.json application/json
                                upload [19] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pt.json rules/i18n/pt.json application/json
                                upload [18] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/ru.json rules/i18n/ru.json application/json
                                upload [17] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/uk.json rules/i18n/uk.json application/json
                                upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/zh-cn.json rules/i18n/zh-cn.json application/json
                                upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.a721e2f4.js rules/static/js/main.a721e2f4.js application/javascript
                                upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.a721e2f4.js.map rules/static/js/main.a721e2f4.js.map application/json
                                upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js application/javascript
                                upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js.map application/json
                                upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js application/javascript
                                upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js.map application/json
                                upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js application/javascript
                                upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js.map rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js.map application/json
                                upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.6114a944.chunk.js rules/static/js/node_modules_react_index_js.6114a944.chunk.js application/javascript
                                upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.6114a944.chunk.js.map rules/static/js/node_modules_react_index_js.6114a944.chunk.js.map application/json
                                upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js application/javascript
                                upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js.map rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js.map application/json
                                upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js application/javascript
                                upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js.map rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js.map application/json
                                upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                host.ioBroker Adapter "system.adapter.telegram.0" is started
                                Update socketio from @6.6.1 to @6.7.0
                                NPM version: 10.7.0
                                Installing iobroker.socketio@6.7.0... (System call)
                                added 1 package, and changed 1 package in 14s
                                upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                                upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                Update smartgarden from @2.0.0 to @2.0.1
                                NPM version: 10.7.0
                                Installing iobroker.smartgarden@2.0.1... (System call)
                                Update "system.adapter.smartgarden.0"
                                upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html
                                upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/jsonConfig.json jsonConfig.json application/json
                                upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png
                                upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json
                                Update samsung from @0.5.11 to @0.6.0
                                NPM version: 10.7.0
                                Installing iobroker.samsung@0.6.0... (System call)
                                Update "system.adapter.samsung.0"
                                upload [1] samsung.admin /opt/iobroker/node_modules/iobroker.samsung/admin/index.html index.html text/html
                                upload [0] samsung.admin /opt/iobroker/node_modules/iobroker.samsung/admin/samsung.png samsung.png image/png
                                Update sainlogic from @0.10.5 to @0.11.4
                                NPM version: 10.7.0
                                Installing iobroker.sainlogic@0.11.4... (System call)
                                Update "system.adapter.sainlogic.0"
                                upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
                                upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
                                upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
                                upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
                                Update panasonic-viera from @2.0.0 to @2.1.0
                                NPM version: 10.7.0
                                Installing iobroker.panasonic-viera@2.1.0... (System call)
                                Update "system.adapter.panasonic-viera.0"
                                upload [3] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index.html index.html text/html
                                upload [2] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index_m.html index_m.html text/html
                                upload [1] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/panasonic-viera.png panasonic-viera.png image/png
                                upload [0] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/words.js words.js application/javascript
                                Update modbus from @6.1.0 to @6.2.3
                                NPM version: 10.7.0
                                Installing iobroker.modbus@6.2.3... (System call)
                                Update "system.adapter.modbus.0"
                                upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                                upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                                upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                                upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                                upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                                upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                                upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
                                upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
                                upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
                                Update javascript from @7.8.0 to @8.7.6
                                NPM version: 10.7.0
                                Installing iobroker.javascript@8.7.6... (System call)
                                removed 1 package, and changed 2 packages in 4m
                                Update "system.adapter.javascript.0"
                                upload [881] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js application/javascript
                                upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_object.js google-blockly/own/blocks_object.js application/javascript
                                upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/864.4c85ffd6.chunk.css static/css/864.4c85ffd6.chunk.css text/css
                                upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/173.4e774f7f.chunk.js static/js/173.4e774f7f.chunk.js application/javascript
                                upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/26.79c81b4e.chunk.js static/js/26.79c81b4e.chunk.js application/javascript
                                upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/320.d9816b46.chunk.js.map static/js/320.d9816b46.chunk.js.map application/json
                                upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.168f947c.chunk.js.map static/js/409.168f947c.chunk.js.map application/json
                                upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/456.97a46315.chunk.js.LICENSE.txt static/js/456.97a46315.chunk.js.LICENSE.txt text/plain
                                upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/61.913ccfa8.chunk.js.map static/js/61.913ccfa8.chunk.js.map application/json
                                upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/709.88d87b7c.chunk.js.map static/js/709.88d87b7c.chunk.js.map application/json
                                upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/826.76c09000.chunk.js.map static/js/826.76c09000.chunk.js.map application/json
                                upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/880.e4029d50.chunk.js static/js/880.e4029d50.chunk.js application/javascript
                                upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/961.02d44700.chunk.js.map static/js/961.02d44700.chunk.js.map application/json
                                upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.720010c8.js static/js/main.720010c8.js application/javascript
                                upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Cellar.7ec1b1803a2437c8b78c.svg static/media/Cellar.7ec1b1803a2437c8b78c.svg image/svg+xml
                                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Room.3c380ab767be35f904e1.svg static/media/Living Room.3c380ab767be35f904e1.svg image/svg+xml
                                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/People.12a7e9127e72f3259186.svg static/media/People.12a7e9127e72f3259186.svg image/svg+xml
                                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Security.1ec78971bd34efa950f8.svg static/media/Security.1ec78971bd34efa950f8.svg image/svg+xml
                                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Storeroom.7de4e6f3364554459b8a.svg static/media/Storeroom.7de4e6f3364554459b8a.svg image/svg+xml
                                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                                Update ical from @1.14.3 to @1.15.0
                                NPM version: 10.7.0
                                Installing iobroker.ical@1.15.0... (System call)
                                Update "system.adapter.ical.0"
                                upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                                upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                                upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                                upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                Update discord from @2.2.0 to @2.4.0
                                NPM version: 10.7.0
                                Installing iobroker.discord@2.4.0... (System call)
                                Update "system.adapter.discord.0"
                                upload [18] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/blockly.js blockly.js application/javascript
                                upload [17] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/channel-text.svg channel-text.svg image/svg+xml
                                upload [16] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/channel-voice.svg channel-voice.svg image/svg+xml
                                upload [15] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/discord.png discord.png image/png
                                upload [14] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/de.json i18n/de.json application/json
                                upload [13] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/en.json i18n/en.json application/json
                                upload [12] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/es.json i18n/es.json application/json
                                upload [11] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/fr.json i18n/fr.json application/json
                                upload [10] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/it.json i18n/it.json application/json
                                upload [9] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/nl.json i18n/nl.json application/json
                                upload [8] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/pl.json i18n/pl.json application/json
                                upload [7] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/pt.json i18n/pt.json application/json
                                upload [6] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/ru.json i18n/ru.json application/json
                                upload [5] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/uk.json i18n/uk.json application/json
                                upload [4] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                                upload [3] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/index_m.html index_m.html text/html
                                upload [2] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/jsonConfig.json jsonConfig.json application/json
                                upload [1] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/jsonCustom.json jsonCustom.json application/json
                                upload [0] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/style.css style.css text/css
                                Update chromecast from @3.2.0 to @3.4.0
                                NPM version: 10.7.0
                                Installing iobroker.chromecast@3.4.0... (System call)
                                changed 1 package in 17s
                                Update "system.adapter.chromecast.0"
                                upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                                upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                                upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                                upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                                Update botvac from @2.0.2 to @2.2.0
                                NPM version: 10.7.0
                                Installing iobroker.botvac@2.2.0... (System call)
                                Update "system.adapter.botvac.0"
                                upload [1] botvac.admin /opt/iobroker/node_modules/iobroker.botvac/admin/botvac.png botvac.png image/png
                                upload [0] botvac.admin /opt/iobroker/node_modules/iobroker.botvac/admin/index.html index.html text/html
                                Update backitup from @2.10.11 to @2.11.0
                                host.ioBroker Adapter "system.adapter.backitup.0" is stopped.
                                host.ioBroker Adapter "system.adapter.backitup.1" is stopped.
                                NPM version: 10.7.0
                                Installing iobroker.backitup@2.11.0... (System call)
                                Update "system.adapter.backitup.0"
                                Update "system.adapter.backitup.1"
                                upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                host.ioBroker Adapter "system.adapter.backitup.0" is started
                                host.ioBroker Adapter "system.adapter.backitup.1" is started
                                code_textpi@ioBroker:~ $ iob update
                                Used repository: stable
                                Adapter    "admin"        : 7.0.22   , installed 7.0.22
                                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                Adapter    "botvac"       : 2.2.0    , installed 2.2.0
                                Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
                                Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                                Adapter    "deconz"       : 1.4.1    , installed 2.0.7
                                Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                Adapter    "discord"      : 2.4.0    , installed 2.4.0
                                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                Controller "js-controller": 6.0.9    , installed 6.0.9
                                Adapter    "lifx"         : 1.0.4    , installed 1.0.4
                                Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
                                Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
                                Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                                Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                Adapter    "web"          : 6.2.5    , installed 6.2.5
                                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                • M Mathias2803
                                  pi@ioBroker:~ $ iob upgrade all -y
                                  NPM version: 10.7.0
                                  Adapter "system.adapter.web.0" restarted.
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  NPM version: 10.7.0
                                  @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                  Was haste denn da installiert? Soweit ich das sehe ist 1.4.1 aktuell:
                                  github:	1.4.1
                                  latest:	1.4.1 for 88 days
                                  stable:	1.4.1 for 88 days
                                    Versuch mal
                                    iob start admin
                                    Mathias2803
                                    @thomas-braun said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                    iob start admin
                                    Die Benutzeroberfläche läuft wieder. Alle Adapter sind aktuell.
                                    Alle Instanzen außer "info.0" laufen wieder. Was die macht, weiß ich gar nicht.
                                    VIS läuft wieder.
                                    Alles ist aktuell etwas "träge", aber vielleicht macht er im Hintergrund noch sehr vieles
                                    • M Mathias2803
                                      iob start admin
                                      VIS läuft wieder.
                                      info.0
                                      Den Info-Adapter gibt es nicht mehr. Schmeiß den raus.
                                      iob del info
                                      • M Mathias2803
                                        iob start admin
                                        VIS läuft wieder.
                                        das könnte dir top sagen
                                          Mathias2803
                                          @homoran said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                          top
                                          Ist da alles in Ordnung?
                                          pi@ioBroker:~ $ top
                                          top - 12:29:25 up  1:17,  3 users,  load average: 0,64, 1,02, 1,85
                                          Tasks: 178 total,   1 running, 177 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 27,2 us,  2,8 sy,  0,0 ni, 69,6 id,  0,0 wa,  0,0 hi,  0,5 si,  0,0 st
                                          MiB Mem :   3838,7 total,    471,4 free,   1621,5 used,   1745,9 buff/cache
                                          MiB Swap:    100,0 total,     96,7 free,      3,2 used.   2089,3 avail Mem
                                            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                                          11821 iobroker  20   0  364272 251512  40980 S  69,5   6,4   7:10.41 iobroker.js-con
                                          12095 iobroker  20   0  246996 136616  40836 S  15,6   3,5   2:16.72 io.shelly.0
                                            992 pi        20   0   52788   3376   2440 S   7,3   0,1   7:39.68 rtl_433
                                          11887 iobroker  20   0  226156  85232  36328 S   4,6   2,2   1:01.07 io.influxdb.0
                                          12530 iobroker  20   0  256228 108964  37288 S   4,0   2,8   1:17.08 io.web.0
                                          11918 iobroker  20   0  293592 157764  40784 S   3,6   4,0   1:54.33 io.javascript.0
                                          12040 iobroker  20   0  227228  97940  36892 S   3,0   2,5   1:19.58 io.mqtt.0
                                          12569 iobroker  20   0  193616  63756  36936 S   2,6   1,6   0:07.09 io.sainlogic.0
                                          12145 iobroker  20   0  209428  85356  40776 S   2,0   2,2   0:32.93 io.shelly.1
                                           1843 influxdb  20   0 1041476 166020  26936 S   1,3   4,2   3:52.60 influxd
                                            513 pi        20   0  179416  75840  31176 S   1,0   1,9   0:47.37 deCONZ
                                          12024 iobroker  20   0  195160  65640  36332 S   1,0   1,7   0:09.64 io.modbus.0
                                          12077 iobroker  20   0  196160  67412  36264 S   1,0   1,7   0:11.80 io.ping.0
                                          11954 iobroker  20   0  214464  82464  37168 S   0,7   2,1   0:37.26 io.alexa2.0
                                          15704 pi        20   0   10420   3076   2540 R   0,7   0,1   0:00.21 top
                                            121 root      20   0   29596  17944  16856 S   0,3   0,5   0:05.99 systemd-journal
                                            459 root      20   0   25500   3404   2500 S   0,3   0,1   0:02.04 rsyslogd
                                          11857 iobroker  20   0  248996 125240  42016 S   0,3   3,2   0:50.79 io.admin.0
                                          11992 iobroker  20   0  202952  77088  41276 S   0,3   2,0   0:08.37 io.backitup.1
                                          12016 iobroker  20   0  197736  68088  36264 S   0,3   1,7   0:08.56 io.chromecast.0
                                          12137 root      20   0       0      0      0 I   0,3   0,0   0:01.08 kworker/u8:0-brcmf_wq/mmc1:0001:1
                                          14850 root      20   0       0      0      0 I   0,3   0,0   0:00.13 kworker/0:2-events
                                              1 root      20   0   34852   8344   6420 S   0,0   0,2   0:09.06 systemd
                                              2 root      20   0       0      0      0 S   0,0   0,0   0:00.02 kthreadd
                                              3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                                              4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                                              8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                                              9 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_rude_
                                             10 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_trace
                                             11 root      20   0       0      0      0 S   0,0   0,0   0:03.40 ksoftirqd/0
                                             12 root      20   0       0      0      0 I   0,0   0,0   0:04.34 rcu_sched
                                             13 root      rt   0       0      0      0 S   0,0   0,0   0:00.17 migration/0
                                             14 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                                             15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                                             16 root      rt   0       0      0      0 S   0,0   0,0   0:00.16 migration/1
                                             17 root      20   0       0      0      0 S   0,0   0,0   0:00.53 ksoftirqd/1
                                             20 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
                                             21 root      rt   0       0      0      0 S   0,0   0,0   0:00.14 migration/2
                                             22 root      20   0       0      0      0 S   0,0   0,0   0:00.55 ksoftirqd/2
                                             25 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
                                             26 root      rt   0       0      0      0 S   0,0   0,0   0:00.12 migration/3
                                             27 root      20   0       0      0      0 S   0,0   0,0   0:00.47 ksoftirqd/3
                                             30 root      20   0       0      0      0 S   0,0   0,0   0:00.01 kdevtmpfs
                                             31 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
                                             34 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
                                             36 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
                                             37 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
                                             38 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
                                             39 root      20   0       0      0      0 S   0,0   0,0   0:00.26 kcompactd0
                                             59 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
                                             60 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
                                             61 root     -51   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
                                             63 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rpciod
                                             65 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 xprtiod
                                             68 root      20   0       0      0      0 S   0,0   0,0   0:02.08 kswapd0
                                             69 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nfsiod
                                             70 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
