  4. GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log
61 Beiträge 3 Kommentatoren 8.3k Aufrufe 2 Beobachtet
  • M Mathias2803
    @thomas-braun said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
    iob diag
    Ja, komme wieder rein, aber es "funktioniert" nicht richtig nach meinem Gefühl.
    Vis lädt z.B. nicht, Grafana hat keine aktuellen Daten, Telegram Nachricht wurde nach dem Start nicht verschickt,...
    iob diag:
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     10:47:35 up 15 min,  2 users,  load average: 1.66, 2.56, 2.12
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-08-05 10:47:35 CEST
               Universal time: Mon 2024-08-05 08:47:35 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        661M        2.1G        8.0M        1.0G        3.0G
    Swap:           99M          0B         99M
    Total:         3.9G        661M        2.2G
    Active iob-Instances:   5
             3838 M total memory
              661 M used memory
              301 M active memory
             1275 M inactive memory
             2138 M free memory
               81 M buffer memory
              956 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 10:47:35 up 15 min,  2 users,  load average: 1.66, 2.56, 2.12
    Tasks: 162 total,   2 running, 160 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 24.6 us,  2.9 sy,  0.0 ni, 72.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3838.7 total,   2137.0 free,    662.7 used,   1039.1 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3030.9 avail Mem
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * lightdm.service loaded failed failed Light Display Manager
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    Filesystem                  Type      Size  Used Avail Use% Mounted on
    /dev/root                   ext4       29G   19G  9.7G  66% /
    devtmpfs                    devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs                       tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs                       tmpfs     1.9G  8.6M  1.9G   1% /run
    tmpfs                       tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    tmpfs                       tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1              vfat      253M   49M  204M  20% /boot
    /dev/sda1                   ext4      117G   43G   68G  39% /mnt/mySSD
    tmpfs                       tmpfs     384M     0  384M   0% /run/user/1000
    //192.168.0.24/nas/ioBroker cifs      5.4T  2.8T  2.7T  51% /opt/iobroker/backups
    [Mon Aug  5 10:32:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:F2:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f0881a94-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles ip=192.168.1.95::192.168.0.1:255.255.128.0:ioBroker:eth0:off
    [Mon Aug  5 10:32:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Aug  5 10:32:05 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Aug  5 10:32:07 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Mon Aug  5 10:32:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    Show mounted filesystems:
    TARGET                                SOURCE                      FSTYPE     OPTIONS
    /                                     /dev/mmcblk0p2              ext4       rw,noatime
    |-/dev                                devtmpfs                    devtmpfs   rw,relatime,size=1800568k,nr_inodes=84157,mode=755
    | |-/dev/shm                          tmpfs                       tmpfs      rw,nosuid,nodev
    | |-/dev/pts                          devpts                      devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                       mqueue                      mqueue     rw,relatime
    |-/sys                                sysfs                       sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs                  securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs                       tmpfs      ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/unified          cgroup2                     cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
    | | |-/sys/fs/cgroup/systemd          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
    | | |-/sys/fs/cgroup/devices          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,devices
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/blkio            cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,blkio
    | | |-/sys/fs/cgroup/cpuset           cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
    | | |-/sys/fs/cgroup/freezer          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/pids             cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,pids
    | | `-/sys/fs/cgroup/perf_event       cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
    | |-/sys/fs/bpf                       none                        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                 debugfs                     debugfs    rw,relatime
    | `-/sys/kernel/config                configfs                    configfs   rw,relatime
    |-/proc                               proc                        proc       rw,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1                   autofs     rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/run                                tmpfs                       tmpfs      rw,nosuid,nodev,mode=755
    | |-/run/lock                         tmpfs                       tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc                      rpc_pipefs rw,relatime
    | `-/run/user/1000                    tmpfs                       tmpfs      rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
    |-/boot                               /dev/mmcblk0p1              vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/mnt/mySSD                          /dev/sda1                   ext4       rw,relatime,sync
    `-/opt/iobroker/backups               //192.168.0.24/nas/ioBroker cifs       rw,relatime,vers=2.1,cache=strict,username=admin,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.0.24,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    1.8G    /var/
    1.1G    /var/log
    408M    /var/cache
    395M    /var/cache/apt
    333M    /var/cache/apt/archives
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    14G     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    640M    /opt/iobroker/iobroker-data/
    426M    /opt/iobroker/iobroker-data/files
    140M    /opt/iobroker/iobroker-data/backup-objects
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2409981-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.4
    /usr/bin/node           v18.20.4
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.0
    nodejs:
      Installed: 18.20.4-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
     *** 18.20.4-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.3-1nodesource1 600
         18.20.2-1nodesource1 600
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         10.24.0~dfsg-1~deb10u3 500
            500 https://archive.raspbian.org/raspbian buster/main armhf Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  6.0.9
    admin:          6.13.16
    javascript:     "javascript" not found
    nodejs modules from github:     4
    | `-- node-botvac@0.4.2-schedule-write (git+ssh://git@github.com/PeterVoronov/node-botvac.git#04674af96bca09ac0db3f2f590209080474521fe)
    +-- iobroker.husq-automower@1.1.0 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#2c07e136ae715bffdde7fc1ceca07a797579735b)
    +-- iobroker.openuv@0.0.5 (git+ssh://git@github.com/x3l4c0d3/ioBroker.openuv.git#810f8d7ec1fb30af3cc77f8ee0aee709ae68dbc3)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.backitup.1               : backitup              : ioBroker                                 -  enabled
      system.adapter.botvac.0                 : botvac                : ioBroker                                 - disabled
      system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.deconz.0                 : deconz                : ioBroker                                 -  enabled, port: 80
      system.adapter.devices.0                : devices               : ioBroker                                 - disabled
      system.adapter.discord.0                : discord               : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
      system.adapter.husq-automower.0         : husq-automower        : ioBroker                                 - disabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
      system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.lifx.0                   : lifx                  : ioBroker                                 - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
      system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
      system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1888, bind: 0.0.0.0
      system.adapter.openuv.0                 : openuv                : ioBroker                                 - disabled
      system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 - disabled
      system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
      system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      system.adapter.rpi2.0                   : rpi2                  : ioBroker                                 -  enabled
      system.adapter.rtl_433.0                : rtl_433               : ioBroker                                 - disabled
      system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 45000, bind: 0.0.0.0
      system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
      system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
      system.adapter.tr-064.1                 : tr-064                : ioBroker                                 - disabled
      system.adapter.tr-064.2                 : tr-064                : ioBroker                                 - disabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 - disabled
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │   name   │                           url                           │ auto upgrade │
    │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.0.22   , installed 6.13.16 [Updatable]
    Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
    Adapter    "botvac"       : 2.2.0    , installed 2.0.2  [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
    Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Controller "js-controller": 6.0.9    , installed 6.0.9
    Adapter    "lifx"         : 1.0.4    , installed 1.0.4
    Adapter    "panasonic-viera": 2.1.0  , installed 2.0.0  [Updatable]
    Adapter    "samsung"      : 0.6.0    , installed 0.5.11 [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Objects and States
    Objects:        20714
    States:         17825
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://twolife.be/raspbian buster InRelease: The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
    W: Failed to fetch https://twolife.be/raspbian/dists/buster/InRelease  The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Get:3 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
    Hit:4 https://phoscon.de/apt/deconz buster InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:6 https://archive.raspbian.org/raspbian buster InRelease
    Hit:7 https://twolife.be/raspbian buster InRelease
    Err:3 https://repos.influxdata.com/debian buster InRelease
    Err:7 https://twolife.be/raspbian buster InRelease
    Fetched 12.9 kB in 2s (5857 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18039      465/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20122      829/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17284      447/cupsd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        33014      2041/influxd
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17214      465/deCONZ
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26861      1547/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28924      1547/iobroker.js-co
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       28191      1640/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        32541      2041/influxd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          21758      834/xrdp-sesman
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20124      829/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17283      447/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      115        20145      733/grafana-server
    tcp6       0      0 :::3389                 :::*                    LISTEN      116        19048      854/xrdp
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18602      690/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15136      452/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17294      465/deCONZ
    udp        0      0 0.0.0.0:44442           0.0.0.0:*                           108        15138      452/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15184      806/dhcpcd
    udp6       0      0 :::57988                :::*                                108        15139      452/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        15137      452/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16330      806/dhcpcd
    2024-08-05 10:47:59.237  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.PoolPumpe.Heizung.Solar-Temperatur, Alias=false, 32 points now activated
    2024-08-05 10:47:59.238  - info: influxdb.0 (4464) enabled logging of alias.0.Pool.UVC.ELECTRIC_POWER, Alias=false, 33 points now activated
    2024-08-05 10:47:59.239  - info: influxdb.0 (4464) enabled logging of alias.0.Pool.Filter.ELECTRIC_POWER, Alias=false, 34 points now activated
    2024-08-05 10:47:59.239  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.indoorhumidity, Alias=false, 35 points now activated
    2024-08-05 10:47:59.240  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.indoortemp, Alias=false, 36 points now activated
    2024-08-05 10:47:59.241  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.pressureabs, Alias=false, 37 points now activated
    2024-08-05 10:47:59.241  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.1.soilmoisture, Alias=false, 38 points now activated
    2024-08-05 10:47:59.242  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.2.soilmoisture, Alias=false, 39 points now activated
    2024-08-05 10:47:59.243  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.PoolPumpe.Wasser-Temp-Test, Alias=false, 40 points now activated
    2024-08-05 10:47:59.244  - info: influxdb.0 (4464) enabled logging of shelly.0.SHUNI-1#3494547AD6C8#1.ADC.Power, Alias=false, 41 points now activated
    2024-08-05 10:47:59.244  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.Regenwasserpumpe.Wasserstandsensor.Wasserstand, Alias=false, 42 points now activated
    2024-08-05 10:47:59.245  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.Regenwasserpumpe.Wasserstandsensor.Fuellstand, Alias=false, 43 points now activated
    2024-08-05 10:47:59.246  - info: influxdb.0 (4464) enabled logging of Beregnung, Alias=true, 44 points now activated
    2024-08-05 10:47:59.246  - info: influxdb.0 (4464) enabled logging of smartgarden.0.LOCATION_5ec04d8f-2Dd6ec-2D4b4b-2Daa4a-2D3405684cec21.DEVICE_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.SERVICE_SENSOR_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.soilHumidity_value, Alias=false, 45 points now activated
    2024-08-05 10:47:59.247  - info: influxdb.0 (4464) enabled logging of smartgarden.0.LOCATION_5ec04d8f-2Dd6ec-2D4b4b-2Daa4a-2D3405684cec21.DEVICE_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.SERVICE_SENSOR_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.soilTemperature_value, Alias=false, 46 points now activated
    2024-08-05 10:48:00.753  - info: host.ioBroker iobroker npm-install: NPM version: 10.7.0Installing iobroker.javascript@7.8.0... (System call)
    2024-08-05 10:48:00.854  - info: influxdb.0 (4464) Do not store value "null" for Beregnung because no number
    2024-08-05 10:48:21.385  - info: host.ioBroker iobroker npm-install:
    2024-08-05 10:48:21.386  - info: host.ioBroker iobroker npm-install: added 17 packages in 21s184 packages are looking for funding  run `npm fund` for details
    2024-08-05 10:48:43.558  - info: host.ioBroker iobroker npm-install: host.ioBroker install adapter javascript@7.8.0
    2024-08-05 10:49:27.144  - info: host.ioBroker iobroker npm-install: upload [310] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    2024-08-05 10:49:27.446  - info: host.ioBroker iobroker npm-install: upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
    2024-08-05 10:49:27.852  - info: host.ioBroker iobroker npm-install: upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
    2024-08-05 10:49:30.586  - info: host.ioBroker iobroker npm-install: upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/666.f676e7ac.chunk.js.LICENSE.txt static/js/666.f676e7ac.chunk.js.LICENSE.txt text/plain
    2024-08-05 10:49:46.127  - info: admin.0 (1640) <== Disconnect system.user.admin from ::ffff:192.168.1.87 javascript
    iob diag has finished.
    @mathias2803 läuft ja auch fast nichts!
    da muss ein + vor der Zeile sein
    • M Mathias2803
      iob diag
      iob diag:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               3838 M total memory
                661 M used memory
                301 M active memory
               2138 M free memory
                 81 M buffer memory
                956 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      1.8G    /var/
      1.1G    /var/log
      408M    /var/cache
      395M    /var/cache/apt
      USB-Devices by-id:
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      Adapter State
      + instance is alive
      Objects and States
      Objects:        20714
      States:         17825
      Pending Updates: 0
      Mathias2803
      schrieb am zuletzt editiert von Mathias2803
      @Homoran
      Warum läuft das alles nicht?
      Soll ich bei Instanzen einfach alles jetzt starten? Funktioniert leider so nicht.
      Warum laufen die Instanzen nicht?
      • M Mathias2803
        iob diag
        iob diag:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           99M          0B         99M
                 3838 M total memory
                  661 M used memory
                  301 M active memory
                 2138 M free memory
                   81 M buffer memory
                  956 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        1.8G    /var/
        1.1G    /var/log
        408M    /var/cache
        395M    /var/cache/apt
        USB-Devices by-id:
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.13.16
        Adapter State
        + instance is alive
        Objects and States
        Objects:        20714
        States:         17825
        Pending Updates: 0
        @mathias2803
        Kiste weiter updaten.
        iob update
        iob upgrade all -y
        Dann zieh ein aktuelles Backup und zieh damit um.
        Neuinstallation wie hier:
        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
        OHNE Desktop und sonstigem Quatsch und in der 64Bit-Version.
        M 2 Antworten Letzte Antwort
          @mathias2803
          iob update
          iob upgrade all -y
          Mathias2803
                                  v.2024-05-22
                   Icon name: computer
                Architecture: arm
          Kernel:                 armv7l
          Userland:               32 bit
          User-ID:                1000
          Pending OS-Updates:     0
          Pending iob updates:    16
          Nodejs-Installation:
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          Recommended versions are nodejs 18.20.4 and npm 10.7.0
          MEMORY:
          Mem:           3.8G        1.4G        692M        8.0M        1.8G        2.3G
          Swap:           99M          0B         99M
          Total:         3.9G        1.4G        792M
          Active iob-Instances:   10
          ioBroker Core:          js-controller           6.0.9
                                  admin                   6.13.16
          Objects type: jsonl
          States  type: jsonl
          Objects:                20349
          States:                 17590
          Size of iob-Database:
          43M     /opt/iobroker/iobroker-data/objects.jsonl
          12M     /opt/iobroker/iobroker-data/objects.json.migrated
          12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          0       /opt/iobroker/iobroker-data/objects.json.broken
          12M     /opt/iobroker/iobroker-data/states.jsonl
          4.0M    /opt/iobroker/iobroker-data/states.json.migrated
          4.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
          • M Mathias2803
                                    v.2024-05-22
                     Icon name: computer
                  Architecture: arm
            Kernel:                 armv7l
            Userland:               32 bit
            User-ID:                1000
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            MEMORY:
            Swap:           99M          0B         99M
                                    admin                   6.13.16
            Objects type: jsonl
            States  type: jsonl
            Objects:                20349
            States:                 17590
            @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
            Das muss 0 werden.
            HomoranH M 2 Antworten Letzte Antwort
              Das muss 0 werden.
              @thomas-braun sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
              Das muss 0 werden.
              @Mathias2803
              wie sieht denn die Seite "Adapter" im admin aus.
              gefiltert auf Adapter mit Update
                Das muss 0 werden.
                Mathias2803
                pi@ioBroker:~ $ iob update
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
                Adapter    "chromecast"   : 3.4.0    , installed 3.2.0  [Updatable]
                Adapter    "daswetter"    : 3.1.15   , installed 3.1.13 [Updatable]
                Adapter    "deconz"       : 1.4.1    , installed 2.0.7
                Adapter    "javascript"   : 8.7.6    , installed 7.8.0  [Updatable]
                Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                Adapter    "telegram"     : 3.3.2    , installed 3.1.0  [Updatable]
                pi@ioBroker:~ $ iob upgrade all -y
                Update vis-jqui-mfd from @1.0.12 to @1.1.1
                NPM version: 10.7.0
                Installing iobroker.vis-jqui-mfd@1.1.1... (System call)
                changed 1 package in 17s
                231 packages are looking for funding
                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                Adapter "system.adapter.vis.0" restarted.
                Update "system.adapter.vis-jqui-mfd.0"
                upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                Update vis-hqwidgets from @1.4.0 to @1.5.1
                NPM version: 10.7.0
                Installing iobroker.vis-hqwidgets@1.5.1... (System call)
                changed 1 package in 15s
                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                Update "system.adapter.vis-hqwidgets.0"
                upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                Update simple-api from @2.7.2 to @2.8.0
                host.ioBroker Adapter "system.adapter.simple-api.0" is stopped.
                NPM version: 10.7.0
                Installing iobroker.simple-api@2.8.0... (System call)
                added 55 packages, removed 167 packages, and changed 2 packages in 1m
                237 packages are looking for funding
                Update "system.adapter.simple-api.0"
                upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
                upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.json application/json
                upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
                host.ioBroker Adapter "system.adapter.simple-api.0" is started
                Update discovery from @4.4.0 to @4.5.0
                NPM version: 10.7.0
                Installing iobroker.discovery@4.5.0... (System call)
                changed 2 packages in 16s
                Update "system.adapter.discovery.0"
                upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                Update daswetter from @3.1.13 to @3.1.15
                host.ioBroker Adapter "system.adapter.daswetter.0" is stopped.
                NPM version: 10.7.0
                Installing iobroker.daswetter@3.1.15... (System call)
                removed 3 packages, and changed 2 packages in 18s
                Update "system.adapter.daswetter.0"
                upload [482] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
                upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/10.png icons/tiempo-weather/galeria1/10.png image/png
                upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/19.png icons/tiempo-weather/galeria3/19.png image/png
                upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/1.png icons/tiempo-weather/galeria5/PNG/White/1.png image/png
                upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/SVG/White/15.svg icons/tiempo-weather/galeria5/SVG/White/15.svg image/svg+xml
                upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/5.png icons/tiempo-weather/galeria6/5.png image/png
                upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/41.png icons/viento-wind/Beaufort-White/41.png image/png
                upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/87.png icons/viento-wind/Beaufort-White/87.png image/png
                upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/104.png icons/viento-wind/galeria2-Beaufort/104.png image/png
                upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/2.png icons/viento-wind/galeria2-Beaufort/2.png image/png
                upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/29.png icons/viento-wind/galeria2-Beaufort/29.png image/png
                upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/38.png icons/viento-wind/galeria2-Beaufort/38.png image/png
                upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/47.png icons/viento-wind/galeria2-Beaufort/47.png image/png
                upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/56.png icons/viento-wind/galeria2-Beaufort/56.png image/png
                upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/65.png icons/viento-wind/galeria2-Beaufort/65.png image/png
                upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/74.png icons/viento-wind/galeria2-Beaufort/74.png image/png
                upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/83.png icons/viento-wind/galeria2-Beaufort/83.png image/png
                upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/84.png icons/viento-wind/galeria2-Beaufort/84.png image/png
                upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/85.png icons/viento-wind/galeria2-Beaufort/85.png image/png
                upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/86.png icons/viento-wind/galeria2-Beaufort/86.png image/png
                upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/87.png icons/viento-wind/galeria2-Beaufort/87.png image/png
                upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/88.png icons/viento-wind/galeria2-Beaufort/88.png image/png
                upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/89.png icons/viento-wind/galeria2-Beaufort/89.png image/png
                upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/9.png icons/viento-wind/galeria2-Beaufort/9.png image/png
                upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/90.png icons/viento-wind/galeria2-Beaufort/90.png image/png
                upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/91.png icons/viento-wind/galeria2-Beaufort/91.png image/png
                upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/92.png icons/viento-wind/galeria2-Beaufort/92.png image/png
                upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/93.png icons/viento-wind/galeria2-Beaufort/93.png image/png
                upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/94.png icons/viento-wind/galeria2-Beaufort/94.png image/png
                upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/95.png icons/viento-wind/galeria2-Beaufort/95.png image/png
                upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/96.png icons/viento-wind/galeria2-Beaufort/96.png image/png
                upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/97.png icons/viento-wind/galeria2-Beaufort/97.png image/png
                upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/98.png icons/viento-wind/galeria2-Beaufort/98.png image/png
                upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/99.png icons/viento-wind/galeria2-Beaufort/99.png image/png
                upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/index_m.html index_m.html text/html
                upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/jsonConfig.json jsonConfig.json application/json
                upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/words.js words.js application/javascript
                host.ioBroker Adapter "system.adapter.daswetter.0" is started
                Update alexa2 from @3.26.4 to @3.26.5
                NPM version: 10.7.0
                Installing iobroker.alexa2@3.26.5... (System call)
                changed 7 packages in 33s
                239 packages are looking for funding
                Update "system.adapter.alexa2.0"
                upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                Update admin from @6.13.16 to @7.0.22
                host.ioBroker Adapter "system.adapter.admin.0" is stopped.
                NPM version: 10.7.0
                Installing iobroker.admin@7.0.22... (System call)
                added 26 packages, removed 8 packages, and changed 21 packages in 2m
                245 packages are looking for funding
                host.ioBroker Cannot install iobroker.admin@7.0.22: 0
                • M Mathias2803
                  NPM version: 10.7.0
                  NPM version: 10.7.0
                  NPM version: 10.7.0
                  NPM version: 10.7.0
                  NPM version: 10.7.0
                  NPM version: 10.7.0
                  NPM version: 10.7.0
                  Danach kommt nix mehr?
                  Sind die Updates der anderen Adapter nun drin?
                  iob update
                  nochmal anschauen.
                    iob update
                    nochmal anschauen.
                    Mathias2803
                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                    Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                    Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
                    Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
                    Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
                    Wohl leider nicht.
                    Habe auch neu starten müssen. Der IoBroker lief dann nicht mehr richtig. im Browser.
                      iob update
                      nochmal anschauen.
                      Mathias2803
                      Aber das System scheint wieder etwas besser zu laufen.
                      Vis ist an, Daten kommen in Grafana an...
                      Aber es fehlen doch noch Elemente.
                      • M Mathias2803
                        @mathias2803
                        Dann nochmal
                        iob upgrade all -y
                        Zur Not die Adapter einzeln updaten.
                          @mathias2803
                          Dann nochmal
                          iob upgrade all -y
                          und dazu ggf. im admin nachsehen warum die nicht wollen.
                          das steht dann 7n der Kachel
                            Mathias2803
                            Update vis-inventwo from @3.3.3 to @3.3.4
                            NPM version: 10.7.0
                            Installing iobroker.vis-inventwo@3.3.4... (System call)
                            added 30 packages, removed 122 packages, and changed 36 packages in 28s
                            272 packages are looking for funding
                            Adapter "system.adapter.web.0" restarted.
                            Update "system.adapter.vis-inventwo.0"
                            upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                            upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                            upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                            upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                            upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                            upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                            upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                            upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                            upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                            upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                            upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                            upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                            upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                            upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                            upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                            upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                            upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                            upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                            upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
                            upload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
                            upload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                            upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                            NPM version: 10.7.0
                            added 25 packages, removed 8 packages, and changed 21 packages in 1m
                            276 packages are looking for funding
                            Update "system.adapter.admin.0"
                            upload [67] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                            upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91570.411e854b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91570.411e854b.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91571.499943a2.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91571.499943a2.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js.map'
                            upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js.map'
                            upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js.map'
                            upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js.map'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js'
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js.map'
                            upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js'
                            upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map'
                            upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js'
                            upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map'
                            upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js'
                            upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map'
                            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js'
                            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map'
                            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico'
                            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json'
                            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json'
                            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json'
                            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json'
                            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json'
                            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json'
                            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json'
                            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json'
                            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json'
                            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json'
                            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json'
                            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                            Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5'
                            Update ws from @2.5.10 to @2.6.1
                            NPM version: 10.7.0
                            Installing iobroker.ws@2.6.1... (System call)
                            Try to solve ENOTEMPTY error automatically
                            Could not handle ENOTEMPTY, because no deletable files were found
                            npm error code ENOTEMPTY
                            npm error syscall rename
                            npm error path /opt/iobroker/node_modules/iobroker.admin
                            npm error dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                            npm error errno -39
                            npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-05T09_22_38_819Z-debug-0.log
                            host.ioBroker Cannot install iobroker.ws@2.6.1: 217
                            Thomas BraunT M 2 Antworten Letzte Antwort
                            • M Mathias2803
                              NPM version: 10.7.0
                              NPM version: 10.7.0
                              NPM version: 10.7.0
                              npm error errno -39
                              @mathias2803
                              iob stop
                              iob fix
                              iob update
                              iob upgrade all -y
                              Das u. U. so lange wiederholen, bis keine Updates mehr vorliegen.
                              • M Mathias2803
                                NPM version: 10.7.0
                                NPM version: 10.7.0
                                NPM version: 10.7.0
                                npm error errno -39
                                Mathias2803
                                @mathias2803
                                pi@ioBroker:~ $ iob stop
                                pi@ioBroker:~ $ iob fix
                                library: loaded
                                Library version=2024-05-24
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2024-01-04
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/5)
                                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                Holen:3 https://repos.influxdata.com/debian buster InRelease [12,9 kB]
                                OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                OK:5 https://phoscon.de/apt/deconz buster InRelease
                                OK:6 https://twolife.be/raspbian buster InRelease
                                Fehl:3 https://repos.influxdata.com/debian buster InRelease
                                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                Fehl:6 https://twolife.be/raspbian buster InRelease
                                  Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                                OK:7 https://archive.raspbian.org/raspbian buster InRelease
                                Es wurden 12,9 kB in 6 s geholt (2.284 B/s).
                                W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian buster InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://twolife.be/raspbian buster InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                                W: Fehlschlag beim Holen von https://twolife.be/raspbian/dists/buster/InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                                W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/buster/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                    Checking ioBroker user and directory permissions (2/5)
                                This system does not support setting default permissions.
                                Do not use npm to manually install adapters unless you know what you are doing!
                                    Check and cleanup npm temporary directories (3/5)
                                Done.
                                    Database maintenance (4/5)
                                Checking for uncompressed JSONL databases... This might take a while!
                                Compressing /opt/iobroker/iobroker-data/states.jsonl
                                Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                Compressed 2 JSONL files. Done
                                    Checking autostart (5/5)
                                Enabling autostart...
                                Autostart enabled!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                  Mathias2803
                                  Die Oberfläche startet gerade nicht mehr.
                                  Dafür aber VIS und die Skripte. :-)
                                  Ich lasse die Updates mehrfach laufen oder einzeln in Putty.
                                  Admin konnte ich einzeln durchbekommen.
                                  • M Mathias2803
                                    Versuch mal
                                    iob start admin
                                      @mathias2803
                                      iob stop
                                      iob fix
                                      iob update
                                      iob upgrade all -y
                                      Mathias2803
                                      NPM version: 10.7.0
                                      added 3 packages, removed 1 package, and changed 2 packages in 13s
                                      296 packages are looking for funding
                                      upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
                                      Update web from @6.2.3 to @6.2.5
                                      host.ioBroker Adapter "system.adapter.web.0" is stopped.
                                      NPM version: 10.7.0
                                      Installing iobroker.web@6.2.5... (System call)
                                      removed 2 packages, and changed 5 packages in 24s
                                      295 packages are looking for funding
                                      upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                      upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                      upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                      upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                      upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                      upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                      upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                      upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                      upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                      upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                      upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                      upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                      upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                      upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                      upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                      upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                      upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                      upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                      upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                      upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                      upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                      upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                      upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                      upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                      upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                      upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                      upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                      upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                      upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                      upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                      upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                      upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                      upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                      upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                      upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                      Update "system.adapter.web.0"
                                      upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                      upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                                      upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                                      upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                                      upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                                      upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                                      upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                                      upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                                      upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                                      upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                      upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                      upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                      upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                      upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                      upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                      upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                      upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                      upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                      upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                      upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                                      upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                      upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                      upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                                      upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                      upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                                      upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                      upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                                      upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                                      upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                      upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                      host.ioBroker Adapter "system.adapter.web.0" is started
                                      Update vis from @1.5.4 to @1.5.6
                                      NPM version: 10.7.0
                                      Installing iobroker.vis@1.5.6... (System call)
                                      changed 1 package in 1m
                                        run `npm fund` for details
                                      upload [746] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                      upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/stateful.png icon/stateful.png image/png
                                      upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/js/connSignalR.js js/connSignalR.js application/javascript
                                      upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/24/zip.png js/fm/icon/mine/24/zip.png image/png
                                      upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/dropzone.js lib/js/dropzone.js application/javascript
                                      upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_StatefulContainerView8.png widgets/basic/img/Prev_StatefulContainerView8.png image/png
                                      upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/img/Prev_tplEchartsChart.png widgets/echarts/img/Prev_tplEchartsChart.png image/png
                                      upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/prev/Prev_hqwidgetsDimmer.png widgets/hqwidgets/img/prev/Prev_hqwidgetsDimmer.png image/png
                                      upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_20.png widgets/jqui-mfd/img/fts_shutter_20.png image/png
                                      upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_roof.png widgets/jqui-mfd/img/fts_window_roof.png image/png
                                      upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_50.svg widgets/jqui-mfd/img/sani_valve_50.svg image/svg+xml
                                      upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/001-3.png widgets/timeandweather/img/clock/001-3.png image/png
                                      upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/511-3.png widgets/timeandweather/img/clock/511-3.png image/png
                                      upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Image.png widgets/vis-inventwo/img/0_Image.png image/png
                                      upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Switch1.png widgets/vis-inventwo/img/0_Switch1.png image/png
                                      upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Multi.gif widgets/vis-inventwo/img/Multi.gif image/gif
                                      upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png image/png
                                      upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01/min.png widgets/vis-inventwo/img/clock_analog/01/min.png image/png
                                      upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png
                                      upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png
                                      upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.browser.js widgets/weather/lib/js/flot/jquery.flot.browser.js application/javascript
                                      upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.js widgets/weather/lib/js/flot/jquery.flot.js application/javascript
                                      upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.legend.js widgets/weather/lib/js/flot/jquery.flot.legend.js application/javascript
                                      upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.logaxis.js widgets/weather/lib/js/flot/jquery.flot.logaxis.js application/javascript
                                      upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.navigate.js widgets/weather/lib/js/flot/jquery.flot.navigate.js application/javascript
                                      upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.pie.js widgets/weather/lib/js/flot/jquery.flot.pie.js application/javascript
                                      upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.resize.js widgets/weather/lib/js/flot/jquery.flot.resize.js application/javascript
                                      upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.saturated.js widgets/weather/lib/js/flot/jquery.flot.saturated.js application/javascript
                                      upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.selection.js widgets/weather/lib/js/flot/jquery.flot.selection.js application/javascript
                                      upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.stack.js widgets/weather/lib/js/flot/jquery.flot.stack.js application/javascript
                                      upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.symbol.js widgets/weather/lib/js/flot/jquery.flot.symbol.js application/javascript
                                      upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.threshold.js widgets/weather/lib/js/flot/jquery.flot.threshold.js application/javascript
                                      upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.time.js widgets/weather/lib/js/flot/jquery.flot.time.js application/javascript
                                      upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touch.js widgets/weather/lib/js/flot/jquery.flot.touch.js application/javascript
                                      upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js application/javascript
                                      upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.uiConstants.js widgets/weather/lib/js/flot/jquery.flot.uiConstants.js application/javascript
                                      upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js widgets/weather/lib/js/flot/jquery.js application/javascript
                                      upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js widgets/weather/lib/js/lib/globalize.culture.en-US.js application/javascript
                                      upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js widgets/weather/lib/js/lib/globalize.js application/javascript
                                      upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js widgets/weather/lib/js/lib/jquery.event.drag.js application/javascript
                                      upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js widgets/weather/lib/js/lib/jquery.mousewheel.js application/javascript
                                      upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html widgets/weather.html text/html
                                      Update "system.adapter.vis.0"
                                      upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                      Update trashschedule from @3.2.0 to @3.3.0
                                      NPM version: 10.7.0
                                      Installing iobroker.trashschedule@3.3.0... (System call)
                                      changed 1 package in 13s
                                      Adapter "system.adapter.vis.0" restarted.
                                      Update "system.adapter.trashschedule.0"
                                      upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                      upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                                      Update tr-064 from @4.2.18 to @4.3.0
                                      NPM version: 10.7.0
                                      Installing iobroker.tr-064@4.3.0... (System call)
                                      Update "system.adapter.tr-064.0"
                                      Update "system.adapter.tr-064.1"
                                      Update "system.adapter.tr-064.2"
                                      upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                      upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                      upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                      Update telegram from @3.1.0 to @3.3.2
                                      host.ioBroker Adapter "system.adapter.telegram.0" is stopped.
                                      NPM version: 10.7.0
                                      Installing iobroker.telegram@3.3.2... (System call)
                                      changed 2 packages in 16s
                                      Update "system.adapter.telegram.0"
                                      upload [70] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                      upload [60] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                                      upload [50] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_prop-types_index_js.6da256b6.chunk.js custom/static/js/node_modules_prop-types_index_js.6da256b6.chunk.js application/javascript
                                      upload [40] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es.json i18n/es.json application/json
                                      upload [30] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                      upload [20] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pl.json rules/i18n/pl.json application/json
                                      upload [19] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pt.json rules/i18n/pt.json application/json
                                      upload [18] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/ru.json rules/i18n/ru.json application/json
                                      upload [17] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/uk.json rules/i18n/uk.json application/json
                                      upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/zh-cn.json rules/i18n/zh-cn.json application/json
                                      upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.a721e2f4.js rules/static/js/main.a721e2f4.js application/javascript
                                      upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.a721e2f4.js.map rules/static/js/main.a721e2f4.js.map application/json
                                      upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js application/javascript
                                      upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js.map application/json
                                      upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js application/javascript
                                      upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js.map application/json
                                      upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js application/javascript
                                      upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js.map rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js.map application/json
                                      upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.6114a944.chunk.js rules/static/js/node_modules_react_index_js.6114a944.chunk.js application/javascript
                                      upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.6114a944.chunk.js.map rules/static/js/node_modules_react_index_js.6114a944.chunk.js.map application/json
                                      upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js application/javascript
                                      upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js.map rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js.map application/json
                                      upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js application/javascript
                                      upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js.map rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js.map application/json
                                      upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                      upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                      host.ioBroker Adapter "system.adapter.telegram.0" is started
                                      Update socketio from @6.6.1 to @6.7.0
                                      NPM version: 10.7.0
                                      Installing iobroker.socketio@6.7.0... (System call)
                                      added 1 package, and changed 1 package in 14s
                                      upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                      Update smartgarden from @2.0.0 to @2.0.1
                                      NPM version: 10.7.0
                                      Installing iobroker.smartgarden@2.0.1... (System call)
                                      Update "system.adapter.smartgarden.0"
                                      upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html
                                      upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png
                                      upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json
                                      Update samsung from @0.5.11 to @0.6.0
                                      NPM version: 10.7.0
                                      Installing iobroker.samsung@0.6.0... (System call)
                                      Update "system.adapter.samsung.0"
                                      upload [1] samsung.admin /opt/iobroker/node_modules/iobroker.samsung/admin/index.html index.html text/html
                                      upload [0] samsung.admin /opt/iobroker/node_modules/iobroker.samsung/admin/samsung.png samsung.png image/png
                                      Update sainlogic from @0.10.5 to @0.11.4
                                      NPM version: 10.7.0
                                      Installing iobroker.sainlogic@0.11.4... (System call)
                                      Update "system.adapter.sainlogic.0"
                                      upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
                                      upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
                                      upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
                                      upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
                                      Update panasonic-viera from @2.0.0 to @2.1.0
                                      NPM version: 10.7.0
                                      Installing iobroker.panasonic-viera@2.1.0... (System call)
                                      Update "system.adapter.panasonic-viera.0"
                                      upload [3] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index.html index.html text/html
                                      upload [2] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index_m.html index_m.html text/html
                                      upload [1] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/panasonic-viera.png panasonic-viera.png image/png
                                      upload [0] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/words.js words.js application/javascript
                                      Update modbus from @6.1.0 to @6.2.3
                                      NPM version: 10.7.0
                                      Installing iobroker.modbus@6.2.3... (System call)
                                      Update "system.adapter.modbus.0"
                                      upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                                      upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                      upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                                      upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                                      upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                                      upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                                      upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                                      upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
                                      upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
                                      upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
                                      Update javascript from @7.8.0 to @8.7.6
                                      NPM version: 10.7.0
                                      Installing iobroker.javascript@8.7.6... (System call)
                                      removed 1 package, and changed 2 packages in 4m
                                      Update "system.adapter.javascript.0"
                                      upload [881] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                      upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js application/javascript
                                      upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_object.js google-blockly/own/blocks_object.js application/javascript
                                      upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/864.4c85ffd6.chunk.css static/css/864.4c85ffd6.chunk.css text/css
                                      upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/173.4e774f7f.chunk.js static/js/173.4e774f7f.chunk.js application/javascript
                                      upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/26.79c81b4e.chunk.js static/js/26.79c81b4e.chunk.js application/javascript
                                      upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/320.d9816b46.chunk.js.map static/js/320.d9816b46.chunk.js.map application/json
                                      upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.168f947c.chunk.js.map static/js/409.168f947c.chunk.js.map application/json
                                      upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/456.97a46315.chunk.js.LICENSE.txt static/js/456.97a46315.chunk.js.LICENSE.txt text/plain
                                      upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/61.913ccfa8.chunk.js.map static/js/61.913ccfa8.chunk.js.map application/json
                                      upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/709.88d87b7c.chunk.js.map static/js/709.88d87b7c.chunk.js.map application/json
                                      upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/826.76c09000.chunk.js.map static/js/826.76c09000.chunk.js.map application/json
                                      upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/880.e4029d50.chunk.js static/js/880.e4029d50.chunk.js application/javascript
                                      upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/961.02d44700.chunk.js.map static/js/961.02d44700.chunk.js.map application/json
                                      upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.720010c8.js static/js/main.720010c8.js application/javascript
                                      upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Cellar.7ec1b1803a2437c8b78c.svg static/media/Cellar.7ec1b1803a2437c8b78c.svg image/svg+xml
                                      upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Room.3c380ab767be35f904e1.svg static/media/Living Room.3c380ab767be35f904e1.svg image/svg+xml
                                      upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/People.12a7e9127e72f3259186.svg static/media/People.12a7e9127e72f3259186.svg image/svg+xml
                                      upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Security.1ec78971bd34efa950f8.svg static/media/Security.1ec78971bd34efa950f8.svg image/svg+xml
                                      upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Storeroom.7de4e6f3364554459b8a.svg static/media/Storeroom.7de4e6f3364554459b8a.svg image/svg+xml
                                      upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                      upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                      upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                      upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                      upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                      upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                      upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                      upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                      upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                      upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                      upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                      upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                      upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                      upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                      upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                      upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                      upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                      upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                      upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                      upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                      upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                                      upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                                      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                                      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                                      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                                      Update ical from @1.14.3 to @1.15.0
                                      NPM version: 10.7.0
                                      Installing iobroker.ical@1.15.0... (System call)
                                      Update "system.adapter.ical.0"
                                      upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                      upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                                      upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                                      upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                      Update discord from @2.2.0 to @2.4.0
                                      NPM version: 10.7.0
                                      Installing iobroker.discord@2.4.0... (System call)
                                      Update "system.adapter.discord.0"
                                      upload [18] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/blockly.js blockly.js application/javascript
                                      upload [17] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/channel-text.svg channel-text.svg image/svg+xml
                                      upload [16] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/channel-voice.svg channel-voice.svg image/svg+xml
                                      upload [15] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/discord.png discord.png image/png
                                      upload [14] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/de.json i18n/de.json application/json
                                      upload [13] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/en.json i18n/en.json application/json
                                      upload [12] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/es.json i18n/es.json application/json
                                      upload [11] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/fr.json i18n/fr.json application/json
                                      upload [10] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/it.json i18n/it.json application/json
                                      upload [9] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/nl.json i18n/nl.json application/json
                                      upload [8] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/pl.json i18n/pl.json application/json
                                      upload [7] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/pt.json i18n/pt.json application/json
                                      upload [6] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/ru.json i18n/ru.json application/json
                                      upload [5] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/uk.json i18n/uk.json application/json
                                      upload [4] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                                      upload [3] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/index_m.html index_m.html text/html
                                      upload [2] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [1] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/jsonCustom.json jsonCustom.json application/json
                                      upload [0] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/style.css style.css text/css
                                      Update chromecast from @3.2.0 to @3.4.0
                                      NPM version: 10.7.0
                                      Installing iobroker.chromecast@3.4.0... (System call)
                                      changed 1 package in 17s
                                      Update "system.adapter.chromecast.0"
                                      upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                                      upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                                      upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                                      upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                                      Update botvac from @2.0.2 to @2.2.0
                                      NPM version: 10.7.0
                                      Installing iobroker.botvac@2.2.0... (System call)
                                      Update "system.adapter.botvac.0"
                                      upload [1] botvac.admin /opt/iobroker/node_modules/iobroker.botvac/admin/botvac.png botvac.png image/png
                                      upload [0] botvac.admin /opt/iobroker/node_modules/iobroker.botvac/admin/index.html index.html text/html
                                      Update backitup from @2.10.11 to @2.11.0
                                      host.ioBroker Adapter "system.adapter.backitup.0" is stopped.
                                      host.ioBroker Adapter "system.adapter.backitup.1" is stopped.
                                      NPM version: 10.7.0
                                      Installing iobroker.backitup@2.11.0... (System call)
                                      Update "system.adapter.backitup.0"
                                      Update "system.adapter.backitup.1"
                                      upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                      upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                      upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                      upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                      host.ioBroker Adapter "system.adapter.backitup.0" is started
                                      host.ioBroker Adapter "system.adapter.backitup.1" is started
                                      code_textpi@ioBroker:~ $ iob update
                                      Used repository: stable
                                      Adapter    "admin"        : 7.0.22   , installed 7.0.22
                                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                      Adapter    "botvac"       : 2.2.0    , installed 2.2.0
                                      Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
                                      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                                      Adapter    "deconz"       : 1.4.1    , installed 2.0.7
                                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                      Adapter    "discord"      : 2.4.0    , installed 2.4.0
                                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                      Controller "js-controller": 6.0.9    , installed 6.0.9
                                      Adapter    "lifx"         : 1.0.4    , installed 1.0.4
                                      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                      Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
                                      Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
                                      Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                                      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                                      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                      Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                      • M Mathias2803
                                        pi@ioBroker:~ $ iob upgrade all -y
                                        NPM version: 10.7.0
                                        Adapter "system.adapter.web.0" restarted.
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        NPM version: 10.7.0
                                        @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                        Was haste denn da installiert? Soweit ich das sehe ist 1.4.1 aktuell:
                                        github:	1.4.1
                                        latest:	1.4.1 for 88 days
                                        stable:	1.4.1 for 88 days
                                          Versuch mal
                                          iob start admin
                                          Mathias2803
                                          @thomas-braun said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                          iob start admin
                                          Die Benutzeroberfläche läuft wieder. Alle Adapter sind aktuell.
                                          Alle Instanzen außer "info.0" laufen wieder. Was die macht, weiß ich gar nicht.
                                          VIS läuft wieder.
                                          Alles ist aktuell etwas "träge", aber vielleicht macht er im Hintergrund noch sehr vieles
