  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 239.7k Aufrufe 52 Beobachtet
    @reddddich
    Und welche Befehle hast du da woher kopiert?
    reddddich
    #419
    zumindest alles aus dem Forum...
    weiterhin starten adapter aber nicht...
    	2024-07-30 23:12:13.735	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2024-07-30 23:12:13.735	error	Caught by controller[0]: Node.js v20.16.0
    host.raspberrypi
    2024-07-30 23:12:13.735	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.raspberrypi
    2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.raspberrypi
    2024-07-30 23:12:13.734	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
    host.raspberrypi
    2024-07-30 23:12:13.734	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.raspberrypi
    2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
    host.raspberrypi
    2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.raspberrypi
    2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.raspberrypi
    2024-07-30 23:12:13.732	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
    host.raspberrypi
    2024-07-30 23:12:13.732	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
    host.raspberrypi
    2024-07-30 23:12:13.732	error	Caught by controller[0]: SyntaxError: Unexpected token '!'
    host.raspberrypi
    2024-07-30 23:12:13.731	error	Caught by controller[0]: ^
    host.raspberrypi
    2024-07-30 23:12:13.731	error	Caught by controller[0]: var!x00) = requiru8'..x509�);
    host.raspberrypi
    2024-07-30 23:12:13.730	error	Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
    host.raspberrypi
    2024-07-30 23:12:05.243	info	Restart adapter system.adapter.sony-bravia.0 because enabled
    • R reddddich
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      #420
      @reddddich
      Ohne zu wissen was du da genau gemacht hast kann man auch nicht nachvollziehen, was da nun vielleicht alles krumm ist.
      R 1 Antwort Letzte Antwort
        @reddddich
        reddddich
        #421
        Ich kann dir nur noch Recht geben... :)
        • R reddddich
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          #422
          @reddddich mit dem Befehl
          history
          bekommt man eine Liste mit dem was man gemacht hat. Ohne Anspruch auf Vollständigkeit (z.B. bei mehreren Sitzungen gleichzeitig)
            tony63526
            #423
            ich bekomme die node.js 20x nicht installiert, bzw Iobroker leasst sich sobal alle befehle ausgefuehrt sind nicht mehr oeffnen.
            Installiert habe ich es nach dieser Anleitung
            https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
            iob diag ergab folgendes:
                                    v.2024-05-22
               Static hostname: raspberrypi
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 10 (buster)
                        Kernel: Linux 5.10.103-v7l+
                  Architecture: arm
            Kernel:                 armv7l
            Userland:               32 bit
            User-ID:                1000
            Display-Server:         true
            Pending OS-Updates:     0
            node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
            Pending iob updates:    0
            Nodejs-Installation:
            nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            /usr/bin/npx
            /usr/bin/corepack
            Recommended versions are nodejs  and npm
            MEMORY:
            Mem:           7.9G        232M        6.4G         16M        1.3G        7.4G
            Swap:           99M          0B         99M
            Total:         8.0G        232M        6.5G
            Active iob-Instances:   0
            ioBroker Core:          js-controller
                                    admin
            ioBroker Status:
            Objects:                0
            States:                 0
            Size of iob-Database:
            29M     /opt/iobroker/iobroker-data/objects.jsonl
            5.3M    /opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
            pi@raspberrypi:~ $ iob fix
            library: loaded
            Library version=2024-05-24
            Welcome to the ioBroker installation fixer!
            Script version: 2024-01-04
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists... Done
            Checking ioBroker user and directory permissions (2/5)
            Check and cleanup npm temporary directories (3/5)
            Done.
            Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node) main: line 14: [: -lt: unary operator expected node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node)
            Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
            pi@raspberrypi:~ $ iob start
            • T tony63526
                                      v.2024-05-22
                       Icon name: computer
                    Architecture: arm
              Kernel:                 armv7l
              Userland:               32 bit
              User-ID:                1000
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              /usr/bin/corepack
              MEMORY:
              Swap:           99M          0B         99M
                                      admin
              ioBroker Status:
              Objects:                0
              States:                 0
              library: loaded
              Done.
              Autostart enabled!
              #424
              @tony63526 sagte in Troubleshooting NodeJS update:
              buster
              Ist zu alt, installier da dringend was lebendiges.
              Diesmal gleich in der 64Bit-Lite Version.
              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                buster
                tony63526
                #425
                Würde bedeuten ich muss alles neu aufsetzten?
                • Zigbee gereate neu anlernen
                • Text2command neu eintippen.
                  eigentlich alles, weil ich mein backup nicht nutzen kann?
                mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
                • T tony63526
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #426
                  @tony63526
                  Wieso kannst du dein Backup nicht nutzen?
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • T tony63526
                    #427
                    Ja. Musst du so oder so, weil ein Architektur-Wechsel nicht möglich ist und die Änderungen von RPi OS 10 zu 12 zu groß sind.
                    Warum nicht?
                    • mcm1957M mcm1957
                      @tony63526
                      tony63526
                      #428
                      @mcm1957
                      Weis ich nicht.
                      War eine Frage. Mein backup bassiert ja auf dem alten system, kann ich es einfach auf dem neuen aufspielen?
                      mcm1957M Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                      • T tony63526
                        @mcm1957
                        Weis ich nicht.
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        #429
                        @tony63526
                        Reden wir von einem IOBROKER Backup oder eine Imagebackup des Betreibssystems ?
                        • T tony63526
                          @mcm1957
                          Weis ich nicht.
                          #430
                          Ein Backup via backitup ist unabhängig vom Betriebssystem.
                          • T tony63526
                            @mcm1957
                            Weis ich nicht.
                            #431
                            warum nicht?
                            was war daran "zu alt"?
                            • mcm1957M mcm1957
                              @tony63526
                              tony63526
                              #432
                              @mcm1957
                              rein iobroker backup.
                              Ueber den Backitup adapter
                                tony63526
                                #433
                                Danke Thomas
                                  warum nicht?
                                  tony63526
                                  #434
                                  Denke das Image :man-shrugging:
                                  Beziehe mich jetzt nur auf die Aussage von Thomas.
                                  buster
                                  "Ist zu alt, installier da dringend was lebendiges.
                                  Diesmal gleich in der 64Bit-Lite Version".
                                  • T tony63526
                                    buster
                                    #435
                                    Denke das Image
                                    = das OS.
                                    damit hat ein iob backup nichts zu tun.
                                    Schwieriger wird es wenn der Controller < v5 ist.
                                      Denke das Image
                                      = das OS.
                                      tony63526
                                      #436
                                      Okay, danke für die Info.
                                      Du siehst, ich habe mit Linux nichts am Hut, aber ich lerne immer gerne dazu.. 😊
                                      Ich versuche, mein System immer auf dem neuesten Stand zu halten, um genau das zu vermeiden, aber jetzt hat mir mein altes Image einen Strich durch die Rechnung gemacht.
                                      Hab ich jetzt bissi was zu tun.
                                      Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                                      • T tony63526
                                        #437
                                        HUST...
                                        buster ist schon geraume Zeit abgekündigt.
                                        • T tony63526
                                          Meister MopperM Online
                                          Meister Mopper
                                          schrieb am zuletzt editiert von Meister Mopper
                                          #438
                                          Image ziehen ist eh nicht optimal weil du auch alle Schwachstellen mitziehst.
                                          Besser sind Backups der laufenden Anwendungen, dann kannst du das Betriebssystem von 0 aufsetzen und hast ein frisches System mit den aktuellen Anwendungsdaten.
                                          Proxmox und HA ...
