  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 239.7k Aufrufe 52 Beobachtet
  • R reddddich
    			v.2024-05-22
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7l+
          Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		32 bit
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    Display-Server: 	true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation:
    /usr/bin/nodejs 	v20.16.0
    /usr/bin/node 		v20.16.0
    /usr/bin/npm 		10.8.1
    /usr/bin/npx 		10.8.1
    /usr/bin/corepack 	0.28.2
    Recommended versions are nodejs 18.20.4 and npm 10.7.0
    MEMORY:
    Mem:            7.9G        1.8G        5.4G        4.0M        695M        6.1G
    Swap:            99M          0B         99M
    Total:          8.0G        1.8G        5.5G
    Active iob-Instances: 	29
    Active repo(s): stable
    ioBroker Core: 		js-controller 		5.0.19
    			admin 			6.17.14
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    Objects: 		13144
    States: 		10376
    Size of iob-Database:
    17M	/opt/iobroker/iobroker-data/objects.jsonl
    9.2M	/opt/iobroker/iobroker-data/objects.json.migrated
    9.2M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    18M	/opt/iobroker/iobroker-data/states.jsonl
    1.4M	/opt/iobroker/iobroker-data/states.json.migrated
    1.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
    #412
    @reddddich sagte in Troubleshooting NodeJS update:
    Wie hast du eigentlich nodejs v20.16.0 ohne Repo auf das System gewuchtet?
    Mach es damit:
    curl -fsSL https://deb.nodesource.com/setup_20.x | sudo bash -
    R 1 Antwort Letzte Antwort
      hat leider keine Abhilfe gebracht...
      Was hat es denn gebracht?
      dann wohl doch PLATT MACHEN
      Musst du eh.
      reddddich
      #413
      Skript v.2024-05-22
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Model		: Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       23:09:24 up 4 days, 23:14,  1 user,  load average: 4.26, 4.46, 3.87
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      *** Time and Time Zones ***
                     Local time: Tue 2024-07-30 23:09:24 CEST
                 Universal time: Tue 2024-07-30 21:09:24 UTC
                       RTC time: Tue 2024-07-30 21:09:24
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Mem:            7.9G        1.8G        5.4G        4.0M        691M        6.1G
      Swap:            99M          0B         99M
               7897 M total memory
               1814 M used memory
                125 M active memory
               2265 M inactive memory
               5391 M free memory
                 27 M buffer memory
                663 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 23:09:25 up 4 days, 23:14,  1 user,  load average: 4.26, 4.46, 3.87
      Tasks: 219 total,   5 running, 214 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 41.1 us, 19.2 sy,  0.0 ni, 27.4 id, 11.0 wa,  0.0 hi,  1.4 si,  0.0 st
      MiB Mem :   7897.4 total,   5398.7 free,   1816.3 used,    682.4 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6060.6 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      118G   21G   92G  19% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  2.0M  1.6G   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      [Thu Jul 25 23:54:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:5F:37:B2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=c4837344-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu Jul 25 23:55:01 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Jul 25 23:55:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Thu Jul 25 23:55:04 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET                       SOURCE     FSTYPE     OPTIONS
      /                            /dev/sda2  ext4       rw,noatime
      |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=3780284k,nr_inodes=25694,mode=755
      | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc       proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
      |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=1617384k,nr_inodes=819200,mode=755
      | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
      | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=808688k,nr_inodes=202172,mode=700,uid=1000,gid=1000
      |-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      `-/var/lib/lxcfs             lxcfs      fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      8.1G	/var/
      4.7G	/var/log
      3.9G	/var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
      3.2G	/var/lib
      Archived and active journals take up 3.8G in the file system.
      /opt/iobroker/backups:
      3.2G	/opt/iobroker/backups/
      4.0K	/opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      1.3G	/opt/iobroker/iobroker-data/
      652M	/opt/iobroker/iobroker-data/files
      227M	/opt/iobroker/iobroker-data/ring_0/snapshot
      227M	/opt/iobroker/iobroker-data/files/ring.0/doorbell_118278720
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      27M	/opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      19M	/opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD48FA-if00
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/npm 		10.8.1
      /usr/bin/npx 		10.8.1
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.19
      admin: 		6.17.14
      javascript: 	8.3.1
      nodejs modules from github: 	2
      +-- iobroker.mercedesme@0.2.3 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#127508de20b11a628957ab2478fbf590ef99cf9f)
      +-- iobroker.telegram@3.9.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.telegram.git#d0b5366c77d6e7f1656dc53648d9cb160d3b66b2)
      Adapter State
      + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
      + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
      + system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
      + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
        system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              - disabled
        system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
        system.adapter.midea.0                  : midea                 : raspberrypi                              - disabled
        system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1894
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1894, bind: 192.168.5.206
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1893, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
        system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.unifi.0                  : unifi                 : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
      + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
      + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
        system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.17.14  , installed 6.17.14
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "denon"        : 1.15.5   , installed 1.15.5
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "eusec"        : 1.2.1    , installed 1.2.1
      Adapter    "evcc"         : 0.1.1    , installed 0.1.1
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "heos"         : 2.2.1    , installed 2.2.1
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "midea"        : 0.0.7    , installed 0.0.7
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "ring"         : 5.1.0    , installed 5.1.0
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
      Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.3.2    , installed 3.9.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "worx"         : 3.0.2    , installed 3.0.2
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects: 	13144
      States: 	10376
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15383      894/sshd: /usr/sbin
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16415      911/dnsmasq
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          15408      921/lighttpd
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15520      817/influxd
      tcp        0      0 192.168.5.206:1895      0.0.0.0:*               LISTEN      1001       26900300   10369/io.mqtt.0
      tcp        0      0 192.168.5.206:1894      0.0.0.0:*               LISTEN      1001       26900299   10369/io.mqtt.0
      tcp        0      0 192.168.5.206:18701     0.0.0.0:*               LISTEN      1001       26900112   10222/io.hm-rpc.2
      tcp        0      0 127.0.0.1:34001         0.0.0.0:*               LISTEN      1001       26904227   11155/io.yahka.1
      tcp        0      0 192.168.5.206:12001     0.0.0.0:*               LISTEN      1001       26896947   10262/io.hm-rpc.3
      tcp        0      0 192.168.5.206:12010     0.0.0.0:*               LISTEN      1001       26897068   10307/io.hm-rpc.4
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       26899050   9931/iobroker.js-co
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       26898098   9931/iobroker.js-co
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26897360   10245/node-red
      tcp        0      0 0.0.0.0:1893            0.0.0.0:*               LISTEN      1001       26900842   10471/io.shelly.0
      tcp        0      0 192.168.5.206:2087      0.0.0.0:*               LISTEN      1001       26902560   10245/node-red
      tcp        0      0 192.168.5.206:2088      0.0.0.0:*               LISTEN      1001       26902561   10245/node-red
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15385      894/sshd: /usr/sbin
      tcp6       0      0 :::80                   :::*                    LISTEN      0          15409      921/lighttpd
      tcp6       0      0 :::42775                :::*                    LISTEN      1001       26903307   11155/io.yahka.1
      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       26903034   11150/go2rtc
      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       26903038   11150/go2rtc
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26896763   10009/io.admin.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       26905949   11072/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        18493      817/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       26904793   10997/io.simple-api
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        14047      809/grafana-server
      tcp6       0      0 :::991                  :::*                    LISTEN      1001       26902026   10245/node-red
      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       26903048   11150/go2rtc
      tcp6       0      0 :::992                  :::*                    LISTEN      1001       26902024   10245/node-red
      tcp6       0      0 :::993                  :::*                    LISTEN      1001       26902022   10245/node-red
      tcp6       0      0 :::994                  :::*                    LISTEN      1001       26902014   10245/node-red
      tcp6       0      0 :::995                  :::*                    LISTEN      1001       26902012   10245/node-red
      tcp6       0      0 :::996                  :::*                    LISTEN      1001       26902010   10245/node-red
      tcp6       0      0 :::997                  :::*                    LISTEN      1001       26902008   10245/node-red
      tcp6       0      0 :::998                  :::*                    LISTEN      1001       26902017   10245/node-red
      tcp6       0      0 :::999                  :::*                    LISTEN      1001       26902003   10245/node-red
      udp        0      0 0.0.0.0:44041           0.0.0.0:*                           108        1810       458/avahi-daemon: r
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16414      911/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16411      911/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14688      700/dhclient
      udp        0      0 0.0.0.0:52309           0.0.0.0:*                           1001       26903063   10761/io.eusec.0
      udp        0      0 0.0.0.0:42662           0.0.0.0:*                           1001       26932801   10894/io.heos.0
      udp        0      0 0.0.0.0:39622           0.0.0.0:*                           1001       26903058   10761/io.eusec.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26903089   11123/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1808       458/avahi-daemon: r
      udp        0      0 0.0.0.0:56565           0.0.0.0:*                           1001       26903053   10761/io.eusec.0
      udp        0      0 0.0.0.0:48394           0.0.0.0:*                           1001       26903990   10761/io.eusec.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       26900965   10245/node-red
      udp        0      0 0.0.0.0:51662           0.0.0.0:*                           1001       26903970   10761/io.eusec.0
      udp6       0      0 :::5353                 :::*                                108        1809       458/avahi-daemon: r
      udp6       0      0 :::57656                :::*                                108        1811       458/avahi-daemon: r
      udp6       0      0 :::8555                 :::*                                1001       26903039   11150/go2rtc
      2024-07-30 23:10:56.760  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-07-30 23:10:56.761  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2024-07-30 23:10:57.034  - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
      2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]: var!x00) = requiru8'..x509�);
      2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]:    ^
      2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]: SyntaxError: Unexpected token '!'
      2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1281:20)
      2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1321:27)
      2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
      2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
      2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
      2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
      2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
      2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
      2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
      2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
      2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
      2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
      2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/fingerprint.js:12:19)
      2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
      2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]: Node.js v20.16.0
      2024-07-30 23:10:57.040  - error: host.raspberrypi instance system.adapter.sony-bravia.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-07-30 23:10:57.040  - info: host.raspberrypi Restart adapter system.adapter.sony-bravia.0 because enabled
        Mach es damit:
        reddddich
        #414
        @thomas-braun said in Troubleshooting NodeJS update:
        Mach es damit:
        wie gesagt...: n00b
        • R reddddich
          Mach es damit:
          wie gesagt...: n00b
          #415
          @reddddich
          Und wie hat es der n00b gemacht?
          • R reddddich
            Mach es damit:
            wie gesagt...: n00b
            #416
            @reddddich
            Jetzt passt es.
            Das nodesource-Repo ist jetzt richtig auf 20 gesetzt worden.
            Dann kannste jetzt den Desktop ausschalten und zigbee auf den 'by-id'-Link setzen.
              @reddddich
              reddddich
              #417
              @reddddich
              wine and n00bness did its job... als typischer copy paste mensch der befehle lief da bestimmt was schief
              • R reddddich
                @reddddich
                #418
                @reddddich
                Und welche Befehle hast du da woher kopiert?
                  @reddddich
                  reddddich
                  #419
                  zumindest alles aus dem Forum...
                  weiterhin starten adapter aber nicht...
                  	2024-07-30 23:12:13.735	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.raspberrypi
                  2024-07-30 23:12:13.735	error	Caught by controller[0]: Node.js v20.16.0
                  host.raspberrypi
                  2024-07-30 23:12:13.735	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                  host.raspberrypi
                  2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                  host.raspberrypi
                  2024-07-30 23:12:13.734	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
                  host.raspberrypi
                  2024-07-30 23:12:13.734	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                  host.raspberrypi
                  2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                  host.raspberrypi
                  2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                  host.raspberrypi
                  2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                  host.raspberrypi
                  2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                  host.raspberrypi
                  2024-07-30 23:12:13.732	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
                  host.raspberrypi
                  2024-07-30 23:12:13.732	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
                  host.raspberrypi
                  2024-07-30 23:12:13.732	error	Caught by controller[0]: SyntaxError: Unexpected token '!'
                  host.raspberrypi
                  2024-07-30 23:12:13.731	error	Caught by controller[0]: ^
                  host.raspberrypi
                  2024-07-30 23:12:13.731	error	Caught by controller[0]: var!x00) = requiru8'..x509�);
                  host.raspberrypi
                  2024-07-30 23:12:13.730	error	Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
                  host.raspberrypi
                  2024-07-30 23:12:05.243	info	Restart adapter system.adapter.sony-bravia.0 because enabled
                  • R reddddich
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    #420
                    @reddddich
                    Ohne zu wissen was du da genau gemacht hast kann man auch nicht nachvollziehen, was da nun vielleicht alles krumm ist.
                      @reddddich
                      reddddich
                      #421
                      Ich kann dir nur noch Recht geben... :)
                      • R reddddich
                        BananaJoeB Offline
                        BananaJoeB Offline
                        BananaJoe
                        #422
                        @reddddich mit dem Befehl
                        history
                        bekommt man eine Liste mit dem was man gemacht hat. Ohne Anspruch auf Vollständigkeit (z.B. bei mehreren Sitzungen gleichzeitig)
                          tony63526
                          #423
                          ich bekomme die node.js 20x nicht installiert, bzw Iobroker leasst sich sobal alle befehle ausgefuehrt sind nicht mehr oeffnen.
                          Installiert habe ich es nach dieser Anleitung
                          https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                          iob diag ergab folgendes:
                                                  v.2024-05-22
                                   Icon name: computer
                            Operating System: Raspbian GNU/Linux 10 (buster)
                                      Kernel: Linux 5.10.103-v7l+
                                Architecture: arm
                          Kernel:                 armv7l
                          Userland:               32 bit
                          User-ID:                1000
                          node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
                          nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          /usr/bin/npx
                          /usr/bin/corepack
                          Recommended versions are nodejs  and npm
                          MEMORY:
                          Mem:           7.9G        232M        6.4G         16M        1.3G        7.4G
                          Swap:           99M          0B         99M
                          Total:         8.0G        232M        6.5G
                          Active iob-Instances:   0
                                                  admin
                          ioBroker Status:
                          Objects:                0
                          States:                 0
                          29M     /opt/iobroker/iobroker-data/objects.jsonl
                          5.3M    /opt/iobroker/iobroker-data/states.jsonl
                          === Mark text until here for copying ===
                          pi@raspberrypi:~ $ iob fix
                          library: loaded
                          Library version=2024-05-24
                          Welcome to the ioBroker installation fixer!
                          Script version: 2024-01-04
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/5)
                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
                          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Reading package lists... Done
                          Checking ioBroker user and directory permissions (2/5)
                          Check and cleanup npm temporary directories (3/5)
                          Done.
                          Database maintenance (4/5)
                          Checking for uncompressed JSONL databases... This might take a while!
                          node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node) main: line 14: [: -lt: unary operator expected node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node)
                          Checking autostart (5/5)
                          Enabling autostart...
                          Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                          pi@raspberrypi:~ $ iob start
                          • T tony63526
                                                    v.2024-05-22
                                     Icon name: computer
                                  Architecture: arm
                            Kernel:                 armv7l
                            Userland:               32 bit
                            User-ID:                1000
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            /usr/bin/npx
                            /usr/bin/corepack
                            MEMORY:
                            Swap:           99M          0B         99M
                                                    admin
                            ioBroker Status:
                            Objects:                0
                            States:                 0
                            library: loaded
                            Done.
                            Autostart enabled!
                            #424
                            @tony63526 sagte in Troubleshooting NodeJS update:
                            buster
                            Ist zu alt, installier da dringend was lebendiges.
                            Diesmal gleich in der 64Bit-Lite Version.
                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                              buster
                              tony63526
                              #425
                              Würde bedeuten ich muss alles neu aufsetzten?
                              • Zigbee gereate neu anlernen
                              • Text2command neu eintippen.
                                eigentlich alles, weil ich mein backup nicht nutzen kann?
                              mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
                              • T tony63526
                                mcm1957M Offline
                                mcm1957M Offline
                                mcm1957
                                #426
                                @tony63526
                                Wieso kannst du dein Backup nicht nutzen?
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                • T tony63526
                                  #427
                                  Ja. Musst du so oder so, weil ein Architektur-Wechsel nicht möglich ist und die Änderungen von RPi OS 10 zu 12 zu groß sind.
                                  Warum nicht?
                                  • mcm1957M mcm1957
                                    @tony63526
                                    tony63526
                                    #428
                                    @mcm1957
                                    Weis ich nicht.
                                    War eine Frage. Mein backup bassiert ja auf dem alten system, kann ich es einfach auf dem neuen aufspielen?
                                    mcm1957M Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                                    • T tony63526
                                      @mcm1957
                                      Weis ich nicht.
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      #429
                                      @tony63526
                                      Reden wir von einem IOBROKER Backup oder eine Imagebackup des Betreibssystems ?
                                      • T tony63526
                                        @mcm1957
                                        Weis ich nicht.
                                        #430
                                        Ein Backup via backitup ist unabhängig vom Betriebssystem.
                                        • T tony63526
                                          @mcm1957
                                          Weis ich nicht.
                                          #431
                                          warum nicht?
                                          was war daran "zu alt"?
