  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 239.7k Aufrufe 52 Beobachtet
  • R reddddich
    @thomas-braun said in Troubleshooting NodeJS update:
    @reddddich sagte in Troubleshooting NodeJS update:
    Rapsberry neu aufsetzen oder node.js neu installieren?
    Beides.
    iob nodejs-update 20
    jetzt sofort und das komplette Betriebssystem in nächster Zeit.
    hat leider keine Abhilfe gebracht... dann wohl doch PLATT MACHEN :) :(
    #410
    Was hat es denn gebracht?
    Musst du eh.
    R 2 Antworten Letzte Antwort
      Musst du eh.
      reddddich
      #411
      			v.2024-05-22
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7l+
            Architecture: arm
      Installation: 		native
      Kernel: 		armv7l
      Userland: 		32 bit
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		1000
      Display-Server: 	true
      Boot Target: 		graphical.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/nodejs 	v20.16.0
      /usr/bin/node 		v20.16.0
      /usr/bin/npm 		10.8.1
      /usr/bin/npx 		10.8.1
      /usr/bin/corepack 	0.28.2
      Recommended versions are nodejs 18.20.4 and npm 10.7.0
      MEMORY:
      Mem:            7.9G        1.8G        5.4G        4.0M        695M        6.1G
      Swap:            99M          0B         99M
      Total:          8.0G        1.8G        5.5G
      Active iob-Instances: 	29
      Active repo(s): stable
      ioBroker Core: 		js-controller 		5.0.19
      			admin 			6.17.14
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      Objects: 		13144
      States: 		10376
      Size of iob-Database:
      17M	/opt/iobroker/iobroker-data/objects.jsonl
      9.2M	/opt/iobroker/iobroker-data/objects.json.migrated
      9.2M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      18M	/opt/iobroker/iobroker-data/states.jsonl
      1.4M	/opt/iobroker/iobroker-data/states.json.migrated
      1.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
      0	/opt/iobroker/iobroker-data/states.json.broken
      • R reddddich
        			v.2024-05-22
                 Icon name: computer
              Architecture: arm
        Kernel: 		armv7l
        Userland: 		32 bit
        User-ID: 		1000
        /usr/bin/npm 		10.8.1
        /usr/bin/npx 		10.8.1
        MEMORY:
        Swap:            99M          0B         99M
        			admin 			6.17.14
        Objects type: jsonl
        States  type: jsonl
        Objects: 		13144
        States: 		10376
        #412
        Wie hast du eigentlich nodejs v20.16.0 ohne Repo auf das System gewuchtet?
        Mach es damit:
        curl -fsSL https://deb.nodesource.com/setup_20.x | sudo bash -
        R 1 Antwort Letzte Antwort
          Musst du eh.
          reddddich
          #413
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Model		: Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : 32 bit
          Systemuptime and Load:
           23:09:24 up 4 days, 23:14,  1 user,  load average: 4.26, 4.46, 3.87
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          *** Time and Time Zones ***
                         Local time: Tue 2024-07-30 23:09:24 CEST
                     Universal time: Tue 2024-07-30 21:09:24 UTC
                           RTC time: Tue 2024-07-30 21:09:24
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          *** Display-Server-Setup ***
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Mem:            7.9G        1.8G        5.4G        4.0M        691M        6.1G
          Swap:            99M          0B         99M
                   7897 M total memory
                   1814 M used memory
                    125 M active memory
                   2265 M inactive memory
                   5391 M free memory
                     27 M buffer memory
                    663 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 23:09:25 up 4 days, 23:14,  1 user,  load average: 4.26, 4.46, 3.87
          Tasks: 219 total,   5 running, 214 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 41.1 us, 19.2 sy,  0.0 ni, 27.4 id, 11.0 wa,  0.0 hi,  1.4 si,  0.0 st
          MiB Mem :   7897.4 total,   5398.7 free,   1816.3 used,    682.4 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6060.6 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      118G   21G   92G  19% /
          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  2.0M  1.6G   1% /run
          /dev/sda1      vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
          [Thu Jul 25 23:54:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:5F:37:B2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=c4837344-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Thu Jul 25 23:55:01 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Thu Jul 25 23:55:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Thu Jul 25 23:55:04 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET                       SOURCE     FSTYPE     OPTIONS
          /                            /dev/sda2  ext4       rw,noatime
          |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=3780284k,nr_inodes=25694,mode=755
          | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
          | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
          |-/proc                      proc       proc       rw,relatime
          | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
          |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
          | `-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
          |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=1617384k,nr_inodes=819200,mode=755
          | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
          | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=808688k,nr_inodes=202172,mode=700,uid=1000,gid=1000
          |-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          `-/var/lib/lxcfs             lxcfs      fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
          8.1G	/var/
          4.7G	/var/log
          3.9G	/var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
          3.2G	/var/lib
          Archived and active journals take up 3.8G in the file system.
          /opt/iobroker/backups:
          3.2G	/opt/iobroker/backups/
          4.0K	/opt/iobroker/backups/redistmp
          /opt/iobroker/iobroker-data:
          1.3G	/opt/iobroker/iobroker-data/
          652M	/opt/iobroker/iobroker-data/files
          227M	/opt/iobroker/iobroker-data/ring_0/snapshot
          227M	/opt/iobroker/iobroker-data/files/ring.0/doorbell_118278720
          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
          27M	/opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
          24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          19M	/opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD48FA-if00
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyACM0
          *** NodeJS-Installation ***
          /usr/bin/npm 		10.8.1
          /usr/bin/npx 		10.8.1
          nodejs:
            Installed: 20.16.0-1nodesource1
            Candidate: 20.16.0-1nodesource1
            Version table:
           *** 20.16.0-1nodesource1 600
                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
               20.15.1-1nodesource1 600
               20.15.0-1nodesource1 600
               20.14.0-1nodesource1 600
               20.13.1-1nodesource1 600
               20.13.0-1nodesource1 600
               20.12.2-1nodesource1 600
               20.12.1-1nodesource1 600
               20.12.0-1nodesource1 600
               20.11.1-1nodesource1 600
               20.11.0-1nodesource1 600
               20.10.0-1nodesource1 600
               20.9.0-1nodesource1 600
               20.8.1-1nodesource1 600
               20.8.0-1nodesource1 600
               20.7.0-1nodesource1 600
               20.6.1-1nodesource1 600
               20.6.0-1nodesource1 600
               20.5.1-1nodesource1 600
               20.5.0-1nodesource1 600
               20.4.0-1nodesource1 600
               20.3.1-1nodesource1 600
               20.3.0-1nodesource1 600
               20.2.0-1nodesource1 600
               20.1.0-1nodesource1 600
               20.0.0-1nodesource1 600
               12.22.12~dfsg-1~deb11u4 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	5.0.19
          admin: 		6.17.14
          javascript: 	8.3.1
          nodejs modules from github: 	2
          +-- iobroker.mercedesme@0.2.3 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#127508de20b11a628957ab2478fbf590ef99cf9f)
          +-- iobroker.telegram@3.9.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.telegram.git#d0b5366c77d6e7f1656dc53648d9cb160d3b66b2)
          Adapter State
          + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
          + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
            system.adapter.devices.0                : devices               : raspberrypi                              - disabled
          + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
          + system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
          + system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
          + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
          + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
          + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
          + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
            system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              - disabled
            system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
            system.adapter.midea.0                  : midea                 : raspberrypi                              - disabled
            system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1894
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1894, bind: 192.168.5.206
          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1893, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
            system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
            system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
          + system.adapter.unifi.0                  : unifi                 : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
          + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
          + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
            system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.17.14  , installed 6.17.14
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "denon"        : 1.15.5   , installed 1.15.5
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "devices"      : 1.1.5    , installed 1.1.5
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "eusec"        : 1.2.1    , installed 1.2.1
          Adapter    "evcc"         : 0.1.1    , installed 0.1.1
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "heos"         : 2.2.1    , installed 2.2.1
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
          Controller "js-controller": 5.0.19   , installed 5.0.19
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "midea"        : 0.0.7    , installed 0.0.7
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "ring"         : 5.1.0    , installed 5.1.0
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
          Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
          Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "telegram"     : 3.3.2    , installed 3.9.0
          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
          Adapter    "web"          : 6.2.5    , installed 6.2.5
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "worx"         : 3.0.2    , installed 3.0.2
          Adapter    "ws"           : 2.6.1    , installed 2.6.1
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects: 	13144
          States: 	10376
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://repos.influxdata.com/debian stable InRelease
          Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15383      894/sshd: /usr/sbin
          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16415      911/dnsmasq
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          15408      921/lighttpd
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15520      817/influxd
          tcp        0      0 192.168.5.206:1895      0.0.0.0:*               LISTEN      1001       26900300   10369/io.mqtt.0
          tcp        0      0 192.168.5.206:1894      0.0.0.0:*               LISTEN      1001       26900299   10369/io.mqtt.0
          tcp        0      0 192.168.5.206:18701     0.0.0.0:*               LISTEN      1001       26900112   10222/io.hm-rpc.2
          tcp        0      0 127.0.0.1:34001         0.0.0.0:*               LISTEN      1001       26904227   11155/io.yahka.1
          tcp        0      0 192.168.5.206:12001     0.0.0.0:*               LISTEN      1001       26896947   10262/io.hm-rpc.3
          tcp        0      0 192.168.5.206:12010     0.0.0.0:*               LISTEN      1001       26897068   10307/io.hm-rpc.4
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       26899050   9931/iobroker.js-co
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       26898098   9931/iobroker.js-co
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26897360   10245/node-red
          tcp        0      0 0.0.0.0:1893            0.0.0.0:*               LISTEN      1001       26900842   10471/io.shelly.0
          tcp        0      0 192.168.5.206:2087      0.0.0.0:*               LISTEN      1001       26902560   10245/node-red
          tcp        0      0 192.168.5.206:2088      0.0.0.0:*               LISTEN      1001       26902561   10245/node-red
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15385      894/sshd: /usr/sbin
          tcp6       0      0 :::80                   :::*                    LISTEN      0          15409      921/lighttpd
          tcp6       0      0 :::42775                :::*                    LISTEN      1001       26903307   11155/io.yahka.1
          tcp6       0      0 :::8554                 :::*                    LISTEN      1001       26903034   11150/go2rtc
          tcp6       0      0 :::8555                 :::*                    LISTEN      1001       26903038   11150/go2rtc
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26896763   10009/io.admin.0
          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       26905949   11072/io.web.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        18493      817/influxd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       26904793   10997/io.simple-api
          tcp6       0      0 :::3000                 :::*                    LISTEN      111        14047      809/grafana-server
          tcp6       0      0 :::991                  :::*                    LISTEN      1001       26902026   10245/node-red
          tcp6       0      0 :::1984                 :::*                    LISTEN      1001       26903048   11150/go2rtc
          tcp6       0      0 :::992                  :::*                    LISTEN      1001       26902024   10245/node-red
          tcp6       0      0 :::993                  :::*                    LISTEN      1001       26902022   10245/node-red
          tcp6       0      0 :::994                  :::*                    LISTEN      1001       26902014   10245/node-red
          tcp6       0      0 :::995                  :::*                    LISTEN      1001       26902012   10245/node-red
          tcp6       0      0 :::996                  :::*                    LISTEN      1001       26902010   10245/node-red
          tcp6       0      0 :::997                  :::*                    LISTEN      1001       26902008   10245/node-red
          tcp6       0      0 :::998                  :::*                    LISTEN      1001       26902017   10245/node-red
          tcp6       0      0 :::999                  :::*                    LISTEN      1001       26902003   10245/node-red
          udp        0      0 0.0.0.0:44041           0.0.0.0:*                           108        1810       458/avahi-daemon: r
          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16414      911/dnsmasq
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16411      911/dnsmasq
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14688      700/dhclient
          udp        0      0 0.0.0.0:52309           0.0.0.0:*                           1001       26903063   10761/io.eusec.0
          udp        0      0 0.0.0.0:42662           0.0.0.0:*                           1001       26932801   10894/io.heos.0
          udp        0      0 0.0.0.0:39622           0.0.0.0:*                           1001       26903058   10761/io.eusec.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26903089   11123/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1808       458/avahi-daemon: r
          udp        0      0 0.0.0.0:56565           0.0.0.0:*                           1001       26903053   10761/io.eusec.0
          udp        0      0 0.0.0.0:48394           0.0.0.0:*                           1001       26903990   10761/io.eusec.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       26900965   10245/node-red
          udp        0      0 0.0.0.0:51662           0.0.0.0:*                           1001       26903970   10761/io.eusec.0
          udp6       0      0 :::5353                 :::*                                108        1809       458/avahi-daemon: r
          udp6       0      0 :::57656                :::*                                108        1811       458/avahi-daemon: r
          udp6       0      0 :::8555                 :::*                                1001       26903039   11150/go2rtc
          2024-07-30 23:10:56.760  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-07-30 23:10:56.761  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2024-07-30 23:10:57.034  - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
          2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]: var!x00) = requiru8'..x509�);
          2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]:    ^
          2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]: SyntaxError: Unexpected token '!'
          2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1281:20)
          2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1321:27)
          2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
          2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
          2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
          2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/fingerprint.js:12:19)
          2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]: Node.js v20.16.0
          2024-07-30 23:10:57.040  - error: host.raspberrypi instance system.adapter.sony-bravia.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-07-30 23:10:57.040  - info: host.raspberrypi Restart adapter system.adapter.sony-bravia.0 because enabled
            Mach es damit:
            reddddich
            #414
            Mach es damit:
            wie gesagt...: n00b
            • R reddddich
              Mach es damit:
              wie gesagt...: n00b
              #415
              @reddddich
              Und wie hat es der n00b gemacht?
              • R reddddich
                Mach es damit:
                wie gesagt...: n00b
                #416
                @reddddich
                Jetzt passt es.
                Das nodesource-Repo ist jetzt richtig auf 20 gesetzt worden.
                Dann kannste jetzt den Desktop ausschalten und zigbee auf den 'by-id'-Link setzen.
                  @reddddich
                  reddddich
                  #417
                  @reddddich
                  wine and n00bness did its job... als typischer copy paste mensch der befehle lief da bestimmt was schief
                  • R reddddich
                    @reddddich
                    #418
                    @reddddich
                    Und welche Befehle hast du da woher kopiert?
                      @reddddich
                      reddddich
                      #419
                      zumindest alles aus dem Forum...
                      weiterhin starten adapter aber nicht...
                      	2024-07-30 23:12:13.735	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi
                      2024-07-30 23:12:13.735	error	Caught by controller[0]: Node.js v20.16.0
                      host.raspberrypi
                      2024-07-30 23:12:13.735	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      host.raspberrypi
                      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      host.raspberrypi
                      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
                      host.raspberrypi
                      2024-07-30 23:12:13.734	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                      host.raspberrypi
                      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                      host.raspberrypi
                      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                      host.raspberrypi
                      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                      host.raspberrypi
                      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      host.raspberrypi
                      2024-07-30 23:12:13.732	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
                      host.raspberrypi
                      2024-07-30 23:12:13.732	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
                      host.raspberrypi
                      2024-07-30 23:12:13.732	error	Caught by controller[0]: SyntaxError: Unexpected token '!'
                      host.raspberrypi
                      2024-07-30 23:12:13.731	error	Caught by controller[0]: ^
                      host.raspberrypi
                      2024-07-30 23:12:13.731	error	Caught by controller[0]: var!x00) = requiru8'..x509�);
                      host.raspberrypi
                      2024-07-30 23:12:13.730	error	Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
                      host.raspberrypi
                      2024-07-30 23:12:05.243	info	Restart adapter system.adapter.sony-bravia.0 because enabled
                      • R reddddich
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        host.raspberrypi
                        #420
                        @reddddich
                        Ohne zu wissen was du da genau gemacht hast kann man auch nicht nachvollziehen, was da nun vielleicht alles krumm ist.
                          @reddddich
                          reddddich
                          #421
                          Ich kann dir nur noch Recht geben... :)
                          • R reddddich
                            BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            #422
                            @reddddich mit dem Befehl
                            history
                            bekommt man eine Liste mit dem was man gemacht hat. Ohne Anspruch auf Vollständigkeit (z.B. bei mehreren Sitzungen gleichzeitig)
                              tony63526
                              #423
                              ich bekomme die node.js 20x nicht installiert, bzw Iobroker leasst sich sobal alle befehle ausgefuehrt sind nicht mehr oeffnen.
                              Installiert habe ich es nach dieser Anleitung
                              https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                              iob diag ergab folgendes:
                                                      v.2024-05-22
                                       Icon name: computer
                                Operating System: Raspbian GNU/Linux 10 (buster)
                                          Kernel: Linux 5.10.103-v7l+
                                    Architecture: arm
                              Kernel:                 armv7l
                              Userland:               32 bit
                              User-ID:                1000
                              node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
                              nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              /usr/bin/npx
                              /usr/bin/corepack
                              Recommended versions are nodejs  and npm
                              MEMORY:
                              Mem:           7.9G        232M        6.4G         16M        1.3G        7.4G
                              Swap:           99M          0B         99M
                              Total:         8.0G        232M        6.5G
                              Active iob-Instances:   0
                                                      admin
                              ioBroker Status:
                              Objects:                0
                              States:                 0
                              29M     /opt/iobroker/iobroker-data/objects.jsonl
                              5.3M    /opt/iobroker/iobroker-data/states.jsonl
                              === Mark text until here for copying ===
                              pi@raspberrypi:~ $ iob fix
                              library: loaded
                              Library version=2024-05-24
                              Welcome to the ioBroker installation fixer!
                              Script version: 2024-01-04
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/5)
                              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
                              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Reading package lists... Done
                              Checking ioBroker user and directory permissions (2/5)
                              Check and cleanup npm temporary directories (3/5)
                              Done.
                              Database maintenance (4/5)
                              Checking for uncompressed JSONL databases... This might take a while!
                              node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node) main: line 14: [: -lt: unary operator expected node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node)
                              Checking autostart (5/5)
                              Enabling autostart...
                              Autostart enabled!
                              Your installation was fixed successfully
                              Run iobroker start to start ioBroker again!
                              pi@raspberrypi:~ $ iob start
                              • T tony63526
                                                        v.2024-05-22
                                         Icon name: computer
                                      Architecture: arm
                                Kernel:                 armv7l
                                Userland:               32 bit
                                User-ID:                1000
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                /usr/bin/npx
                                /usr/bin/corepack
                                MEMORY:
                                Swap:           99M          0B         99M
                                                        admin
                                ioBroker Status:
                                Objects:                0
                                States:                 0
                                library: loaded
                                Done.
                                Autostart enabled!
                                #424
                                @tony63526 sagte in Troubleshooting NodeJS update:
                                buster
                                Ist zu alt, installier da dringend was lebendiges.
                                Diesmal gleich in der 64Bit-Lite Version.
                                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                  buster
                                  tony63526
                                  #425
                                  Würde bedeuten ich muss alles neu aufsetzten?
                                  • Zigbee gereate neu anlernen
                                  • Text2command neu eintippen.
                                    eigentlich alles, weil ich mein backup nicht nutzen kann?
                                  mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
                                  • T tony63526
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #426
                                    @tony63526
                                    Wieso kannst du dein Backup nicht nutzen?
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    • T tony63526
                                      #427
                                      Ja. Musst du so oder so, weil ein Architektur-Wechsel nicht möglich ist und die Änderungen von RPi OS 10 zu 12 zu groß sind.
                                      Warum nicht?
                                      • mcm1957M mcm1957
                                        @tony63526
                                        tony63526
                                        #428
                                        @mcm1957
                                        Weis ich nicht.
                                        War eine Frage. Mein backup bassiert ja auf dem alten system, kann ich es einfach auf dem neuen aufspielen?
                                        mcm1957M Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                                        • T tony63526
                                          @mcm1957
                                          Weis ich nicht.
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #429
                                          @tony63526
                                          Reden wir von einem IOBROKER Backup oder eine Imagebackup des Betreibssystems ?
