  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 239.8k Aufrufe 52 Beobachtet
  • R reddddich
    @thomas-braun said in Troubleshooting NodeJS update:
    @reddddich
    Und wie hat es der n00b gemacht?
    wine and n00bness did its job... als typischer copy paste mensch der befehle lief da bestimmt was schief
    Thomas BraunT Offline
    #418
    @reddddich
    Und welche Befehle hast du da woher kopiert?
    R 1 Antwort Letzte Antwort
      @reddddich
      reddddich
      #419
      zumindest alles aus dem Forum...
      weiterhin starten adapter aber nicht...
      	2024-07-30 23:12:13.735	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      2024-07-30 23:12:13.735	error	Caught by controller[0]: Node.js v20.16.0
      host.raspberrypi
      2024-07-30 23:12:13.735	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      host.raspberrypi
      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
      host.raspberrypi
      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
      host.raspberrypi
      2024-07-30 23:12:13.734	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
      host.raspberrypi
      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
      host.raspberrypi
      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
      host.raspberrypi
      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
      host.raspberrypi
      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      host.raspberrypi
      2024-07-30 23:12:13.732	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
      host.raspberrypi
      2024-07-30 23:12:13.732	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
      host.raspberrypi
      2024-07-30 23:12:13.732	error	Caught by controller[0]: SyntaxError: Unexpected token '!'
      host.raspberrypi
      2024-07-30 23:12:13.731	error	Caught by controller[0]: ^
      host.raspberrypi
      2024-07-30 23:12:13.731	error	Caught by controller[0]: var!x00) = requiru8'..x509�);
      host.raspberrypi
      2024-07-30 23:12:13.730	error	Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
      host.raspberrypi
      2024-07-30 23:12:05.243	info	Restart adapter system.adapter.sony-bravia.0 because enabled
      • R reddddich
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        #420
        @reddddich
        Ohne zu wissen was du da genau gemacht hast kann man auch nicht nachvollziehen, was da nun vielleicht alles krumm ist.
          @reddddich
          reddddich
          #421
          Ich kann dir nur noch Recht geben... :)
          • R reddddich
            BananaJoeB Online
            BananaJoeB Online
            BananaJoe
            #422
            @reddddich mit dem Befehl
            history
            bekommt man eine Liste mit dem was man gemacht hat. Ohne Anspruch auf Vollständigkeit (z.B. bei mehreren Sitzungen gleichzeitig)
              tony63526
              #423
              ich bekomme die node.js 20x nicht installiert, bzw Iobroker leasst sich sobal alle befehle ausgefuehrt sind nicht mehr oeffnen.
              Installiert habe ich es nach dieser Anleitung
              https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
              iob diag ergab folgendes:
                                      v.2024-05-22
                 Static hostname: raspberrypi
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 10 (buster)
                          Kernel: Linux 5.10.103-v7l+
                    Architecture: arm
              Kernel:                 armv7l
              Userland:               32 bit
              User-ID:                1000
              Display-Server:         true
              Pending OS-Updates:     0
              node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
              Pending iob updates:    0
              Nodejs-Installation:
              nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              /usr/bin/corepack
              Recommended versions are nodejs  and npm
              MEMORY:
              Mem:           7.9G        232M        6.4G         16M        1.3G        7.4G
              Swap:           99M          0B         99M
              Total:         8.0G        232M        6.5G
              Active iob-Instances:   0
              ioBroker Core:          js-controller
                                      admin
              ioBroker Status:
              Objects:                0
              States:                 0
              Size of iob-Database:
              29M     /opt/iobroker/iobroker-data/objects.jsonl
              5.3M    /opt/iobroker/iobroker-data/states.jsonl
              === Mark text until here for copying ===
              pi@raspberrypi:~ $ iob fix
              library: loaded
              Library version=2024-05-24
              Welcome to the ioBroker installation fixer!
              Script version: 2024-01-04
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists... Done
              Checking ioBroker user and directory permissions (2/5)
              Check and cleanup npm temporary directories (3/5)
              Done.
              Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node) main: line 14: [: -lt: unary operator expected node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node)
              Checking autostart (5/5)
              Enabling autostart...
              Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
              pi@raspberrypi:~ $ iob start
              • T tony63526
                                        v.2024-05-22
                         Icon name: computer
                      Architecture: arm
                Kernel:                 armv7l
                Userland:               32 bit
                User-ID:                1000
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                /usr/bin/corepack
                MEMORY:
                Swap:           99M          0B         99M
                                        admin
                ioBroker Status:
                Objects:                0
                States:                 0
                library: loaded
                Done.
                Autostart enabled!
                #424
                @tony63526 sagte in Troubleshooting NodeJS update:
                buster
                Ist zu alt, installier da dringend was lebendiges.
                Diesmal gleich in der 64Bit-Lite Version.
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                  buster
                  tony63526
                  #425
                  Würde bedeuten ich muss alles neu aufsetzten?
                  • Zigbee gereate neu anlernen
                  • Text2command neu eintippen.
                    eigentlich alles, weil ich mein backup nicht nutzen kann?
                  mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
                  • T tony63526
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #426
                    @tony63526
                    Wieso kannst du dein Backup nicht nutzen?
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • T tony63526
                      #427
                      Ja. Musst du so oder so, weil ein Architektur-Wechsel nicht möglich ist und die Änderungen von RPi OS 10 zu 12 zu groß sind.
                      Warum nicht?
                      • mcm1957M mcm1957
                        @tony63526
                        tony63526
                        #428
                        @mcm1957
                        Weis ich nicht.
                        War eine Frage. Mein backup bassiert ja auf dem alten system, kann ich es einfach auf dem neuen aufspielen?
                        mcm1957M Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                        • T tony63526
                          @mcm1957
                          Weis ich nicht.
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #429
                          @tony63526
                          Reden wir von einem IOBROKER Backup oder eine Imagebackup des Betreibssystems ?
                          • T tony63526
                            @mcm1957
                            Weis ich nicht.
                            #430
                            Ein Backup via backitup ist unabhängig vom Betriebssystem.
                            • T tony63526
                              @mcm1957
                              Weis ich nicht.
                              #431
                              warum nicht?
                              was war daran "zu alt"?
                              • mcm1957M mcm1957
                                @tony63526
                                tony63526
                                #432
                                @mcm1957
                                rein iobroker backup.
                                Ueber den Backitup adapter
                                  tony63526
                                  #433
                                  Danke Thomas
                                    warum nicht?
                                    tony63526
                                    #434
                                    Denke das Image :man-shrugging:
                                    Beziehe mich jetzt nur auf die Aussage von Thomas.
                                    buster
                                    "Ist zu alt, installier da dringend was lebendiges.
                                    Diesmal gleich in der 64Bit-Lite Version".
                                    • T tony63526
                                      buster
                                      #435
                                      Denke das Image
                                      = das OS.
                                      damit hat ein iob backup nichts zu tun.
                                      Schwieriger wird es wenn der Controller < v5 ist.
                                        Denke das Image
                                        = das OS.
                                        tony63526
                                        #436
                                        Okay, danke für die Info.
                                        Du siehst, ich habe mit Linux nichts am Hut, aber ich lerne immer gerne dazu.. 😊
                                        Ich versuche, mein System immer auf dem neuesten Stand zu halten, um genau das zu vermeiden, aber jetzt hat mir mein altes Image einen Strich durch die Rechnung gemacht.
                                        Hab ich jetzt bissi was zu tun.
                                        Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                                        • T tony63526
                                          #437
                                          HUST...
                                          buster ist schon geraume Zeit abgekündigt.
