  4. Beta Test js-controller Kiera (v6.0)
    1.0k
betajs-controllerkieratest
331 Beiträge 39 Kommentatoren 118.7k Aufrufe 42 Beobachtet
  • G Gui
    Hi, beim aktuellen Update vom js-controller erhalte ich folgende Fehlermeldung:
    Update js-controller from @6.0.7 to @6.0.8
    Stopped Objects DB
    Stopped States DB
    NPM version: 10.7.0
    Installing iobroker.js-controller@6.0.8... (System call)
    npm error code 6
    npm error path /opt/iobroker/node_modules/iobroker.js-controller
    npm error command failed
    npm error command sh -c node iobroker.js setup first
    npm error Uncaught Rejection: TypeError: callback is not a function
    npm error     at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
    npm error This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    npm error TypeError: callback is not a function
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-17T15_07_38_698Z-debug-0.log
    host.iob10 Cannot install iobroker.js-controller@6.0.8: 6
    • Adaptername: iobroker.js-controller
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 6.0.8
    • js-controller Version: 6.0.7
    • Admin Version: 7.0.17
    • Hardwaresystem: lxc with PROXMOX on NUC
    • Arbeitsspeicher: 32GB
    • Festplattenart: SSD
    • Betriebssystem: Debian
    • Nodejs-Version: 20.15.1
    • NPM-Version: 10.7.0
    • Installationsart: Skript und Manuell
    • Image, Docker genutzt: Nein
    • Ort, Name der Imagedatei: ...
    Linux User bitte hier den Output von iob diag einfügen.
                            v.2024-05-22
     Static hostname: iob10
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.8-2-pve
        Architecture: x86-64
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               64 bit
    User-ID:                0
    Display-Server:         false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:
    /usr/bin/nodejs         v20.15.1
    /usr/bin/node           v20.15.1
    /usr/bin/npm            10.7.0
    /usr/bin/npx            10.7.0
    /usr/bin/corepack       0.28.1
    Recommended versions are nodejs 20.15.1 and npm 10.7.0
    MEMORY:
    Mem:            3.2G        1.9G        310M        163K        1.1G        1.4G
    Swap:             0B          0B          0B
    Total:          3.2G        1.9G        310M
    Active iob-Instances:   37
    Upgrade policy: none
    ioBroker Core:          js-controller           6.0.7
                            admin                   7.0.17
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    + system.adapter.admin.0                  : admin                 : iob                                      -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : iob10                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : iob                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                13975
    States:                 10431
    Size of iob-Database:
    5.8M    /opt/iobroker/iobroker-data/objects.json.bak
    1.4M    /opt/iobroker/iobroker-data/states.json.bak
    #285
    @gui sagte in Fehler bei Update js-controller 6.0.7 auf 6.0.8:
    die Langfassung wäre hier jetzt sinnvoller.
    sonst noch mehr Beta-Versionen?
    wie durchgeführt?
    und aktuell ist ebenfalls relativ
    auch das ist Beta!
    • G Gui
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.7.0
      npm error code 6
                              v.2024-05-22
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      User-ID:                0
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      MEMORY:
      Swap:             0B          0B          0B
                              admin                   7.0.17
      Objects type: redis
      States  type: redis
      Objects:                13975
      States:                 10431
      #286
      @gui ich hab das mal zum Betatester Thread hinzugefügt
      • FeuersturmF Offline
        FeuersturmF Offline
        Feuersturm
        #287
        @foxriver76 js-controller 6.0.9 lies sich ohne Probleme auf meinen Testsystemen installieren und es gibt keine Auffälligkeiten
        • G Gui
          Stopped Objects DB
          Stopped States DB
          NPM version: 10.7.0
          npm error code 6
                                  v.2024-05-22
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               64 bit
          User-ID:                0
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          MEMORY:
          Swap:             0B          0B          0B
                                  admin                   7.0.17
          Objects type: redis
          States  type: redis
          Objects:                13975
          States:                 10431
          #288
          @gui
          Bitte NICHT als root im LXC herumturnen.
          G 1 Antwort Letzte Antwort
            @gui
            Gui
            #289
            Hi @thomas-braun, ich werde das mal nicht weiter kommentieren, und nehme einfach an, dass es ein allgemeiner guter Ratschlag war.
            Ich habe es als erstes über die Weboberfläche gemacht, mit dem selben Ergebnis, und die läuft nicht unter root.
            • G Gui
              #290
              @gui
              Im Container hampelt ein root herum:
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               64 bit
              User-ID:                0
              Macht man NICHT. Ist kein Ratschlag, sondern allgemein übliches Verhalten aka 'best practise'.
              Leg dir einen user dafür an, wenn es noch keinen geben sollte.
                @gui
                Installation:           lxc
                Kernel:                 x86_64
                Userland:               64 bit
                User-ID:                0
                Gui
                #291
                i@thomas-braun das war ich. Es gibt einen user für iobroker. Ich arbeite aber lieber als root, und ja ich weiß, das man das nicht macht ...
                Zurück zum Problem. Hab mal die Harte Tour gemacht:
                • js-controller Verzeichniss gelöscht
                • js-controller neu installier "npm install iobroker.js-controller"
                • npm rebuild
                • iob upload
                Bis jetzt sieht alles gut.
                Aber bitte nicht nachmachen !!!!
                Und bitte nicht schimpfen ;-)
                Thomas BraunT G 2 Antworten Letzte Antwort
                • G Gui
                  • npm rebuild
                  • iob upload
                  #292
                  @gui sagte in Beta Test js-controller Kiera (v6.0):
                  Harakiri?
                  Nein, man macht es NICHT.
                  • G Gui
                    • npm rebuild
                    • iob upload
                    Gui
                    schrieb am zuletzt editiert von Gui
                    #293
                    Hat nicht funktioniert. Nach ein paar Stunden waren plötzlich alle Instanzen down.
                    War ein Versuch auf die schnelle ...
                    ... und ja, ich gewöhne mir den root ab.
                    • G Gui
                      #294
                      Du könntest ja auch mal ordentlich mit dem System umgehen...
                        Gui
                        #295
                        @thomas-braun mach (versuch) ich doch.
                        Muss die Sache mal in ruhe angehen. Vielleicht noch als Ergänzung. Ich habe eine "Master-Slave" Installation, also 2 Instanzen mit Redis.
                        So richtig "Master-Slave" gibt es ja nicht mehr. Beim Master habe ich den Update noch nicht probiert.
                        Mal schauen ...
                        • G Gui
                          Mal schauen ...
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          #296
                          @gui Aus dem ersten Beitrag
                          Achtung: MASTER/SLAVE-Systeme Reihenfolgen beachten!
                          Bei einem Multi-Host-System, welches auf js-controller 5.0.x läuft, ist es beim Update auf Version 6.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                          • FeuersturmF Feuersturm
                            #297
                            @feuersturm
                            wie heisst es so schoen? kaum macht man's richtig... funktionierts... :D
                              @feuersturm
                              Gui
                              #298
                              @ilovegym fast ;-)
                              @thomas-braun Danke für den Tipp.
                              Master - ohne Probleme auf 6.0.9. Beim Slave dann gleicher Fehler.
                              Da muss beim letzten Update irgendetwas kaputt gegangen sein.
                              • G Gui
                                @ilovegym fast ;-)
                                Gui
                                #299
                                So, Backup eingespielt bei dem der Adapter noch 6.0.6 war, update auf 6.0.9 ohne Probleme.
                                Muss also von 6.0.6 auf 6.0.7 was schief gelaufen sein.
                                • G Gui
                                  FeuersturmF Offline
                                  FeuersturmF Offline
                                  Feuersturm
                                  #300
                                  @gui js-controller 6.0.7 war buggy und hat nicht funktioniert.
                                  F 1 Antwort Letzte Antwort
                                    Flugschüler
                                    #301
                                    Seit dem update 6.0.9 und auch eine Version davor funktioniert bei mir beim Blockly request (deprecated) nicht mehr. Ich will damit den PC herunterfahren. Hat vorher funktioniert, jetzt nicht mehr. Ist das bei euch auch so?
                                    JB_SullivanJ T UweRLPU 3 Antworten Letzte Antwort
                                    • F Flugschüler
                                      JB_SullivanJ Offline
                                      JB_Sullivan
                                      #302
                                      @flugschüler
                                      Sicher das es an der Host Version liegt? Welche Adapter Version vom JavaSkript Adapter hast du?
                                      In einem anderen Adapter Thread gibt es aktuell auch Probleme mit allem was größer als 8.7.1 ist. Könnte also auch am JS-Adapter liegen (für den Fall das du mehrere Sachen gleichzeitig geupdatet hast)
                                      • JB_SullivanJ JB_Sullivan
                                        @flugschüler
                                        Flugschüler
                                        #303
                                        @jb_sullivan Ja stimmt. Ich glaub es liegt am Adapter. Wohin kann ich mich da wenden, hast du einen link?
                                        • F Flugschüler
                                          FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          #304
                                          @flugschüler hier kannst du ein issue beim Javascript Adapter erstellen https://github.com/ioBroker/ioBroker.javascript/issues
