  4. Node-Red
  5. Function Node welche zwei Werte vergleicht
    6.4k
207 Beiträge 5 Kommentatoren 45.7k Aufrufe 4 Beobachtet
  • 1 1984chris
    @mickym
    Dann bedanke ich mich mal im Voraus.
    mickymM Offline
    mickymM Offline
    mickym
    @1984chris Probier, ob das auch funktioniert:
    [{"id":"e031c1eb61cee531","type":"switch","z":"517cd16e4d7e6ae4","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":2270,"y":3620,"wires":[["0a2c55c834860319","20c24184ed9fb4a5"],["20c24184ed9fb4a5"]]},{"id":"25b787845d8332e8","type":"trigger","z":"517cd16e4d7e6ae4","name":"","op1":"","op2":"false","op1type":"nul","op2type":"bool","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"true","bytopic":"all","topic":"topic","outputs":1,"x":2440,"y":3660,"wires":[["0a2c55c834860319"]]},{"id":"66feb9f77ab376f2","type":"rbe","z":"517cd16e4d7e6ae4","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":2630,"y":3620,"wires":[["5c2a2507c0efb56e"]]},{"id":"ddf39dae01705e59","type":"junction","z":"517cd16e4d7e6ae4","x":2180,"y":3620,"wires":[["e031c1eb61cee531"]]},{"id":"0a2c55c834860319","type":"junction","z":"517cd16e4d7e6ae4","x":2540,"y":3620,"wires":[["66feb9f77ab376f2"]]},{"id":"20c24184ed9fb4a5","type":"junction","z":"517cd16e4d7e6ae4","x":2360,"y":3660,"wires":[["25b787845d8332e8"]]},{"id":"5c2a2507c0efb56e","type":"junction","z":"517cd16e4d7e6ae4","x":2720,"y":3620,"wires":[["fe12d75c77ea96a9","b1dfdd79c609cc2a"]]}]
    1 1 Antwort Letzte Antwort
    • mickymM mickym
      1 Offline
      1 Offline
      1984chris
      schrieb am zuletzt editiert von 1984chris
      @mickym
      habs probiert funktioniert.
      wie könnte ich jetzt z.b sagen nach 5 Stunden Laufzeit der Pumpe soll diese Zeit X stillstehen das diese abkühlen kann?
      Ich meinte die Poolpumpe nicht die Wärmepumpe.....
      • 1 1984chris
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        @1984chris Nun Du hast doch den Shelly mit dem Du die Pumpe betriebst (?) - der liefert Dir doch mind. 2 mal in der Minute den aktuellen Energieverbrauch. Daran kannst du doch feststellen, ob die Pumpe läuft oder nicht.
        • mickymM mickym
          1 Offline
          1 Offline
          1984chris
          @mickym
          Mit dem Shelly schalte ich einen Kontakt in der Wärmepumpe.
          Ist ein Shelly Plus1 der kann das nicht.
          Und mit dem UDP Telegramm sende ich die Nachricht an den Homserver der mir die Poolpumpe Ein/Aus schaltet.
          • 1 1984chris
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @1984chris Ok dann müssen wir also selbst protokollieren und den Status der Wärmepumpe als gegeben nehmen oder kannst Du den Status des Shellys mit einer Node abfragen? Ich nutze die Nodes ja nicht, sondern nur mqtt. Also kannst Du mit Deinen Shelly Nodes des Status der Wärmepumpe abfragen? Poste mal welche Nodes Du nutzt, also den Link.
            1 2 Antworten Letzte Antwort
            • mickymM mickym
              1 Offline
              1 Offline
              1984chris
              @mickym
              Der shelly schaltet nur einen internen Kontakt in der Wärmepumpe ist von Fairland.
              Nein auf die Wärmepumpe kann ich garnicht zugreifen.Kann nur mit dem handy wo die smartlife App installiert ist auf die wärmepumpe zugreifen.
              • mickymM mickym
                1 Offline
                1 Offline
                1984chris
                @mickym
                Damit meinte ich die Poolpumpe
                • 1 1984chris
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @1984chris Du hast doch die Shelly Nodes mit der Du die WP steuerst, da kann man doch sicher auch den Status des Shellies abfragen. Gib halt nochmal den Link zu den Nodes
                  Sind das diese hier: https://flows.nodered.org/node/node-red-contrib-shelly
                  • mickymM mickym
                    1 Offline
                    1 Offline
                    1984chris
                    @mickym
                    aso,ja das sind diese.
                    • 1 1984chris
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @1984chris Hast dann schon mal versucht die im callback Mode zu betreiben?
                      • mickymM mickym
                        1 Offline
                        1 Offline
                        1984chris
                        @mickym
                        callback Mode?
                        • 1 1984chris
                          @mickym
                          callback Mode?
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @1984chris sagte in Function Node welche zwei Werte vergleicht:
                          @mickym
                          callback Mode?
                          Na in dem Link steht doch, was die Nodes für Möglichkeiten haben:
                          • 1 1984chris
                            @mickym
                            callback Mode?
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @mickym
                            callback Mode?
                            OK ich habe es gesehen, Du kannst entweder Pollen oder Deine Maschine als Shelly Server betreiben, bei dem die Geräte ihren Status melden. Was ist Dir lieber - einfacher ist das Pollen.
                            OK dann nimmst eine Shelly Node und lässt diese triggern und den Status der Wärmepumpe abfragen. Wenn Du das in Deiner Shelly Node so konfigurierst und eine debug Node dahinter hängst, dann sollte alle 5 s der Status Deines Shellies gemeldet werden,
                            Das Intervall kannst natürlich noch vergrößern, damit nicht alles zugespammt wird. Ggf. langen ja auch alle 30s.
                            • mickymM mickym
                              @mickym
                              callback Mode?
                              1 Offline
                              1 Offline
                              1984chris
                              #66
                              @mickym
                              ok das wusste ich nicht.
                              Brauche aber eh die Poolpumpe, im Homeserver habe ich eine Zeitschaltuhr das die Poolpumpe 3 x 2 Stunden am Tag läuft auch ohne PV Überschuss.
                              Wenn ich jetzt aber Auto Ein bei unseren Flow aktiviere wird die Zeitschaltuhr im Homeserver deaktiviert, wenn jetzt z.b bewölktes Wetter und es kommt nichts zum laufen weil zu Wenig PV Überschuss muss ich sicherstellen das die Poolpumpe mindestens 6 Stunden gelaufen ist (Umwälzung Wasser).
                              Weißt du was ich meine?
                              • 1 1984chris
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #67
                                @mickym
                                Das mag alles sein - ist aber mit Ungenauigkeiten behaftet - gerade wenn Du mal die Maschine oder NodeRed neustarten musst, dann ist das ja alles unbekannt, Ich habe Dir gerade geschrieben, was Du machen musst .
                                Hast Du eigentlich iobroker auch am Laufen oder nur NodeRed? Hast Du einen mqtt Broker am Laufen?
                                Wie gesagt nimmt den Shelly 1 Plus in der Node - konfiguriere die wie ich unten beschrieben habe und hänge ein Debug Node hinten dran und poste mal das Ergebnis aus dem Debugfenster.
                                • mickymM mickym
                                  @mickym
                                  1 Offline
                                  1 Offline
                                  1984chris
                                  #68
                                  @mickym
                                  habe nur node red, ja habe einen mqtt broker.
                                  • 1 1984chris
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #69
                                    @1984chris Na dann konfiguriere die Shelly Node wie unten beschrieben auf Deinen Shelly 1 Plus Deiner Wärmepumpe und hänge eine Debug Node an und poste das Ergebnis des Debugfensters
                                    • mickymM mickym
                                      1 Offline
                                      1 Offline
                                      1984chris
                                      #70
                                      • 1 1984chris
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #71
                                        @1984chris Sehr gut. Mach mal das switch0 Objekt auf, da sollte dann der aktuelle Status des Shellies drin stehen
                                        • mickymM mickym
                                          1 Offline
                                          1 Offline
                                          1984chris
                                          #72
                                          @mickym
                                          ja steht drinnen.
