  4. iobroker cmd in Konsole geht nicht
32 Beiträge 4 Kommentatoren 3.1k Aufrufe 2 Beobachtet
  • H hukio
    pi@raspibull:~ $ sudo systemctl unmask iobroker.service
    pi@raspibull:~ $ iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
    -bash: iob_diag:: command not found
    @hukio
    So eingeben:
    H 1 Antwort Letzte Antwort
      @hukio
      So eingeben:
      hukio
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspibull
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       18:03:11 up  3:13,  2 users,  load average: 6.03, 2.30, 1.14
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-07-19 18:03:11 CEST
                 Universal time: Fri 2024-07-19 16:03:11 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      pi
      HOME=/home/pi
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        2.5G        318M        1.0M        966M        1.4G
      Swap:           2.0G          0B        2.0G
      Total:          5.8G        2.5G        2.3G
      Active iob-Instances:   0
               3793 M total memory
               2508 M used memory
               2599 M active memory
                691 M inactive memory
                318 M free memory
                 96 M buffer memory
                869 M swap cache
               2027 M total swap
                  0 M used swap
               2027 M free swap
      top - 18:03:11 up  3:13,  2 users,  load average: 6.03, 2.30, 1.14
      Tasks: 188 total,   1 running, 187 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  1.4 us,  5.6 sy,  0.0 ni, 93.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3793.3 total,    318.6 free,   2508.3 used,    966.5 buff/cache
      MiB Swap:   2028.0 total,   2028.0 free,      0.0 used.   1354.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       30G   20G  8.2G  71% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/sda3      ext4      439G  3.9G  413G   1% /mnt/hukdata
      /dev/sda1      vfat      256M   32M  225M  13% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Fri Jul 19 14:49:43 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:1E:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=4d904d30-02 rootfstype=ext4 fsck.repair=yes rootwait rootdelay=5
      [Fri Jul 19 14:49:51 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Jul 19 14:49:51 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Jul 19 14:49:53 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      [Fri Jul 19 14:49:55 2024] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET                       SOURCE     FSTYPE     OPTIONS
      /                            /dev/sda2  ext4       rw,noatime
      |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
      | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
      | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc       proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
      |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
      | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
      | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
      |-/mnt/hukdata               /dev/sda3  ext4       rw,noatime
      `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      5.9G    /var/
      3.1G    /var/log
      3.0G    /var/log/journal/1ffd49df1b3a44ffb614b2c58029c285
      630M    /var/cache
      Archived and active journals take up 2.9G in the file system.
      /opt/iobroker/backups:
      7.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      858M    /opt/iobroker/iobroker-data/
      356M    /opt/iobroker/iobroker-data/files
      342M    /opt/iobroker/iobroker-data/history
      138M    /opt/iobroker/iobroker-data/files/javascript.admin
      129M    /opt/iobroker/iobroker-data/backup-objects
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      29M     /opt/iobroker/iobroker-data/objects.jsonl
      26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_323adb3b74d9eb11b6e6178e6fe9f4d9-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.4
      /usr/bin/node           v18.20.4
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      nodejs:
        Installed: 18.20.4-1nodesource1
        Candidate: 18.20.4-1nodesource1
        Version table:
       *** 18.20.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           18.20.3-1nodesource1 1001
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Core adapters versions
      js-controller:
      admin:
      javascript:
      nodejs modules from github:     1
      +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)
      Adapter State
      ioBroker-Repositories
      Installed ioBroker-Instances
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.78:8100     0.0.0.0:*               LISTEN      1000       16018      1419/io.doorbird.0
      tcp        0      0 192.168.178.78:8087     0.0.0.0:*               LISTEN      1000       16143      1495/io.simple-api.
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      110        15380      540/redis-server 12
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1000       17981      1523/adb
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2012       1101/iobroker.js-co
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       17891      1408/io.shelly.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       17626      1291/io.mqtt.0
      tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       17761      1366/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3518       548/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        1805       777/influxd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       15245      1532/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       16403      1118/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        3698       777/influxd
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       15223      1514/io.socketio.0
      tcp6       0      0 ::1:6379                :::*                    LISTEN      110        15381      540/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0          3520       548/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        15671      1049/grafana
      tcp6       0      0 :::51989                :::*                    LISTEN      1000       16644      1325/io.nuki-extend
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14160      429/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       15014      1351/io.shelly.0
      udp        0      0 0.0.0.0:36430           0.0.0.0:*                           1000       153027     1336/io.onkyo.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14462      773/dhcpcd
      udp        0      0 0.0.0.0:45834           0.0.0.0:*                           1000       151987     1336/io.onkyo.0
      udp        0      0 0.0.0.0:33672           0.0.0.0:*                           108        14162      429/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        14161      429/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          1753       773/dhcpcd
      udp6       0      0 :::52066                :::*                                108        14163      429/avahi-daemon: r
      2024-07-19 17:06:30.780  - info: javascript.0 (1186) script.js.Sensoren.Waschmaschine:  vEnergy_start: 701.39
      2024-07-19 17:06:30.780  - info: javascript.0 (1186) script.js.Sensoren.Waschmaschine: Zählerstand Strom: 31164.17
      2024-07-19 17:33:56.909  - info: javascript.0 (1186) script.js.Sensoren.Trockner: Verbrauch (plug): 0.4 kWh
      2024-07-19 17:33:56.909  - info: javascript.0 (1186) script.js.Sensoren.Trockner: totaler Verbrauch Zählerdifferenz: 1.3 kWh
      2024-07-19 17:33:56.966  - info: signal-cmb.0 (1484) Send Karin der Trockner ist seit  17:33 fertig. to f98af11f-c3df-4b54-9f1e-0454df85f8bd
      2024-07-19 17:53:52.316  - info: javascript.0 (1186) script.js.Sensoren.Proximity_Sensor_Echo: true
      2024-07-19 17:57:36.227  - info: zigbee.0 (1397) Device '0xec1bbdfffe79e066' announced itself
      2024-07-19 18:02:30.140  - warn: influxdb.0 (1171) Error on writePoint("{"value":5.6,"time":"2024-07-19T16:02:00.131Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:31.681  - warn: influxdb.0 (1171) Error on writePoint("{"value":584,"time":"2024-07-19T16:02:01.675Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:34.365  - warn: influxdb.0 (1171) Error on writePoint("{"value":8.3,"time":"2024-07-19T16:02:04.358Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:38.418  - warn: influxdb.0 (1171) Error on writePoint("{"value":7.3,"time":"2024-07-19T16:02:08.407Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:38.572  - warn: influxdb.0 (1171) Error on writePoint("{"value":2383,"time":"2024-07-19T16:02:08.561Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:40.147  - info: influxdb.0 (1171) Connecting http://localhost:8086/ ...
      2024-07-19 18:02:40.148  - info: influxdb.0 (1171) Influx DB Version used: 1.x
      2024-07-19 18:02:45.287  - warn: influxdb.0 (1171) Error on writePoint("{"value":1033,"time":"2024-07-19T16:02:15.274Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:45.288  - info: influxdb.0 (1171) Add point that had error for javascript.0.gStromc to buffer again, error-count=4
      2024-07-19 18:02:48.495  - info: influxdb.0 (1171) Store 8 buffered influxDB history points
      2024-07-19 18:02:53.190  - warn: influxdb.0 (1171) Error on writePoint("{"value":359,"time":"2024-07-19T16:02:23.184Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:53.191  - info: influxdb.0 (1171) Add point that had error for javascript.0.gStromc to buffer again, error-count=5
      2024-07-19 18:02:58.759  - warn: influxdb.0 (1171) Error on writePoint("{"value":349,"time":"2024-07-19T16:02:28.748Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:58.760  - info: influxdb.0 (1171) Add point that had error for javascript.0.gStromc to buffer again, error-count=6
      2024-07-19 18:02:59.711  - warn: influxdb.0 (1171) Error on writePoint("{"value":31165.8,"time":"2024-07-19T16:02:28.578Z","from":"system.adapter.sonoff.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:59.712  - info: influxdb.0 (1171) Add point that had error for sonoff.0.Stromzähler._Zählerstand to buffer again, error-count=1
      2024-07-19 18:02:59.713  - warn: influxdb.0 (1171) Error on writePoint("{"value":31165.81,"time":"2024-07-19T16:02:29.702Z","from":"system.adapter.sonoff.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
      2024-07-19 18:02:59.714  - info: influxdb.0 (1171) Add point that had error for sonoff.0.Stromzähler._Zählerstand to buffer again, error-count=2
      • H hukio
        Skript v.2024-05-22
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        pi
        HOME=/home/pi
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           2.0G          0B        2.0G
                 3793 M total memory
                 2508 M used memory
                  318 M free memory
                   96 M buffer memory
                  869 M swap cache
                 2027 M total swap
                    0 M used swap
                 2027 M free swap
        *** FILESYSTEM ***
        /var:
        5.9G    /var/
        3.1G    /var/log
        630M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        js-controller:
        admin:
        javascript:
        Adapter State
        Objects and States
        Objects:        0
        States:         0
        Pending Updates: 0
        @hukio sagte in iobroker cmd in Konsole geht nicht:
        pi
        Das muss der user 'iobroker' sein.
        Was haste da bitte gemacht?
          pi
          hukio
          Habe ich in der ersten mail skizziert. Mehr Einzelheiten kann ich chronologisch nicht sagen. Wie kann ich den Fehler ändern?
          • H hukio
            @hukio
            systemctl status iobroker.service
              @hukio
              hukio
              pi@raspibull:~ $ systemctl status iobroker.service
              ● iobroker.service
                   Loaded: masked (Reason: Unit iobroker.service is masked.)
                   Active: inactive (dead)
              • H hukio
                ● iobroker.service
                @hukio
                systemctl status mask iobroker.service
                systemctl status unmask iobroker.service
                • H hukio
                  Ich habe ein update/upgrade des OS gemacht. Das in einen dpkg Fehler lief (problem mit node 18.20.4 update (war 18.19.x)). IOB startete nicht mehr. Habe dann nodejs alleine upgrade gemacht. Das iobroker system konnte ich mit
                  node node_modules/iobroker.js-controller/controller.js --logs
                  erfolgreich starten.
                  Alle iobroker cmd in der Konsole geben keine Antwort. Iobroker startet nicht nach reboot.
                  Meine Installation Raspberry Pi4 mit Bullseye
                  jetzt node 18.20.4 npm 10.7.0
                  Wie kann ich die iobroker Befehle in der Konsole wieder herstellen?
                  HUK
                  PS:
                  ● iobroker.service
                  Ro75R Online
                  Ro75R Online
                  Ro75
                  Kannst du ggfs. die letzten Befehle in der Konsole mal posten, also die die obiges betreffen. In der Konsole sollte man diese sehen, mit der Pfeiltaste nach oben bzw. nach unten.
                  Ro75.
                    @hukio
                    hukio
                    pi@raspibull:~ $ systemctl status mask iobroker.service
                    Unit mask.service could not be found.
                    ● iobroker.service
                    pi@raspibull:~ $ systemctl status unmask iobroker.service
                    Unit unmask.service could not be found.
                    ● iobroker.service
                    • H hukio
                      ● iobroker.service
                      ● iobroker.service
                      @hukio
                      Sorry, Quatsch von mir...
                      sudo systemctl mask iobroker.service
                      • Ro75R Ro75
                        Ro75.
                        hukio
                        @ro75
                        Habe aus Versehen diesen Befehl abgesetzt.
                        vorher diesen
                        sudo dpkg --configure -a
                        mehr finde ich nicht
                          @hukio
                          hukio
                          pi@raspibull:~ $ sudo systemctl mask iobroker.service
                          Created symlink /etc/systemd/system/iobroker.service → /dev/null.
                          Removed /etc/systemd/system/iobroker.service.
                          • H hukio
                            @ro75
                            vorher diesen
                            @hukio
                            Da frag ich mir nur... WARUM??
                            Mit dpgk direkt hast du in der Regel nix am Hut.
                            sagt nun?
                              @hukio
                              sagt nun?
                              hukio
                              ● iobroker.service
                              weil ich einen Fehler mit dpkg hatte.
                              • H hukio
                                ● iobroker.service
                                Und genau was wurde von dpkg bemängelt?
                                sudo apt install --reinstall nodejs
                                sudo reboot
                                  sudo reboot
                                  hukio
                                  pi@raspibull:~ $ sudo apt install --reinstall nodejs
                                  0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                                  Need to get 0 B/28.9 MB of archives.
                                  After this operation, 0 B of additional disk space will be used.
                                  (Reading database ... 59474 files and directories currently installed.)
                                  Preparing to unpack .../nodejs_18.20.4-1nodesource1_arm64.deb ...
                                  Detected old npm client, removing...
                                  Unpacking nodejs (18.20.4-1nodesource1) over (18.20.4-1nodesource1) ...
                                  Setting up nodejs (18.20.4-1nodesource1) ...
                                  Processing triggers for man-db (2.9.4-2) ...
                                  nach reboot iobroker startet nicht. cmd geht nicht
                                  • H hukio
                                    @hukio
                                    sudo -u iobroker id
                                    Jag den Fixer mal über das System:
                                    curl -fsL https://iobroker.net/fix.sh | bash -
                                      @hukio
                                      sudo -u iobroker id
                                      hukio
                                      Das war es! cmd und iobroker laufen wieder.
                                      pi@raspibull:~ $ sudo -u iobroker id
                                      uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker),5(tty),20(dialout),29(audio),44(video),46(plugdev),112(bluetooth),114(redis),997(gpio),998(i2c)
                                      ● iobroker.service
                                      pi@raspibull:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
                                      library: loaded
                                      Library version=2024-05-24
                                          Welcome to the ioBroker installation fixer!
                                          Script version: 2024-01-04
                                          You might need to enter your password a couple of times.
                                          Installing prerequisites (1/5)
                                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Checking ioBroker user and directory permissions (2/5)
                                          Check and cleanup npm temporary directories (3/5)
                                      Done.
                                          Database maintenance (4/5)
                                      Checking for uncompressed JSONL databases... This might take a while!
                                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                      Compressed 1 JSONL files. Done
                                          Checking autostart (5/5)
                                      Enabling autostart...
                                      Autostart enabled!
                                          Your installation was fixed successfully
                                          Run iobroker start to start ioBroker again!
                                      Vielen Dank für die Mühe. Ich frage immer zu spät, bzw. ich versuche es erst mal selbst. Habe aber nicht den background.
                                      Nochmals Danke
                                      HUK
                                      • H hukio
                                        ● iobroker.service
                                        library: loaded
                                        Done.
                                        Autostart enabled!
                                        Nochmals Danke
                                        HUK
                                        @hukio
                                        Dann bring die Kiste nun auf nodejs@20 und zeig dann nochmal die Langfassung von
                                        iob nodejs-update 20
                                        iob diag
                                        • H Offline
                                          hukio
                                          Sorry, hab erst mal einen Kaffee zur Entspannung getrunken.
                                          Skript v.2024-05-22
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                           19:59:36 up  1:20,  3 users,  load average: 1.59, 1.72, 1.53
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Fri 2024-07-19 19:59:36 CEST
                                                     Universal time: Fri 2024-07-19 17:59:36 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          HOME=/home/pi
                                          iobroker
                                          HOME=/home/iobroker
                                          GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            3.8G        2.0G        535M        1.0M        1.2G        1.8G
                                          Swap:           2.0G          0B        2.0G
                                          Total:          5.8G        2.0G        2.6G
                                          Active iob-Instances:   30
                                                   3793 M total memory
                                                   2037 M used memory
                                                   2141 M active memory
                                                    844 M inactive memory
                                                    535 M free memory
                                                    122 M buffer memory
                                                   1098 M swap cache
                                                   2027 M total swap
                                                      0 M used swap
                                                   2027 M free swap
                                          top - 19:59:36 up  1:20,  3 users,  load average: 1.59, 1.72, 1.53
                                          Tasks: 196 total,   2 running, 194 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  8.1 us,  4.1 sy,  0.0 ni, 87.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   3793.3 total,    535.2 free,   2037.4 used,   1220.7 buff/cache
                                          MiB Swap:   2028.0 total,   2028.0 free,      0.0 used.   1797.4 avail Mem
                                          *** FILESYSTEM ***
                                          [Fri Jul 19 18:39:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:1E:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=4d904d30-02 rootfstype=ext4 fsck.repair=yes rootwait rootdelay=5
                                          [Fri Jul 19 18:39:31 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Fri Jul 19 18:39:31 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Fri Jul 19 18:39:33 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                          [Fri Jul 19 18:39:35 2024] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
                                          | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
                                          /var:
                                          5.9G    /var/
                                          3.1G    /var/log
                                          660M    /var/cache
                                          871M    /opt/iobroker/iobroker-data/
                                          42M     /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          HINT:
                                          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                          /dev/ttyUSB0
                                          /usr/bin/nodejs         v20.15.1
                                          /usr/bin/node           v20.15.1
                                          /usr/bin/npm            10.7.0
                                          /usr/bin/npx            10.7.0
                                          /usr/bin/corepack       0.28.1
                                          nodejs:
                                            Installed: 20.15.1-1nodesource1
                                            Candidate: 20.15.1-1nodesource1
                                            Version table:
                                           *** 20.15.1-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: redis
                                          js-controller:  5.0.19
                                          admin:          6.17.14
                                          javascript:     8.3.1
                                          Adapter State
                                            system.adapter.adb.0                    : adb                   : raspibull                                - disabled
                                          + system.adapter.admin.0                  : admin                 : raspibull                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.alexa2.0                 : alexa2                : raspibull                                -  enabled
                                          + system.adapter.backitup.0               : backitup              : raspibull                                -  enabled
                                            system.adapter.broadlink2.0             : broadlink2            : raspibull                                - disabled
                                          + system.adapter.daikin.0                 : daikin                : raspibull                                -  enabled
                                          + system.adapter.daikin.1                 : daikin                : raspibull                                -  enabled
                                            system.adapter.discovery.0              : discovery             : raspibull                                - disabled
                                          + system.adapter.doorbird.0               : doorbird              : raspibull                                -  enabled
                                          + system.adapter.email.0                  : email                 : raspibull                                -  enabled
                                          + system.adapter.email.1                  : email                 : raspibull                                - disabled
                                            system.adapter.flot.0                   : flot                  : raspibull                                - disabled
                                          + system.adapter.fritzdect.0              : fritzdect             : raspibull                                -  enabled
                                            system.adapter.fullybrowser.0           : fullybrowser          : raspibull                                - disabled
                                          + system.adapter.history.0                : history               : raspibull                                -  enabled
                                          + system.adapter.influxdb.0               : influxdb              : raspibull                                -  enabled, port: 8086
                                          + system.adapter.iot.0                    : iot                   : raspibull                                -  enabled
                                          + system.adapter.iqontrol.0               : iqontrol              : raspibull                                -  enabled
                                          + system.adapter.javascript.0             : javascript            : raspibull                                -  enabled
                                          + system.adapter.lgtv.0                   : lgtv                  : raspibull                                -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : raspibull                                -  enabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.netatmo.0                : netatmo               : raspibull                                -  enabled
                                          + system.adapter.nuki-extended.0          : nuki-extended         : raspibull                                -  enabled
                                          + system.adapter.onkyo.0                  : onkyo                 : raspibull                                -  enabled
                                            system.adapter.onvif.0                  : onvif                 : raspibull                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
                                            system.adapter.onvif.1                  : onvif                 : raspibull                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
                                            system.adapter.ping.0                   : ping                  : raspibull                                - disabled
                                            system.adapter.robonect.0               : robonect              : raspibull                                - disabled
                                          + system.adapter.scenes.0                 : scenes                : raspibull                                -  enabled
                                          + system.adapter.shelly.0                 : shelly                : raspibull                                -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.shelly.1                 : shelly                : raspibull                                -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.signal-cmb.0             : signal-cmb            : raspibull                                -  enabled
                                          + system.adapter.simple-api.0             : simple-api            : raspibull                                -  enabled, port: 8087, bind: 192.168.178.78, run as: admin
                                          + system.adapter.socketio.0               : socketio              : raspibull                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                          + system.adapter.sonoff.0                 : sonoff                : raspibull                                -  enabled, port: 1889, bind: 0.0.0.0
                                            system.adapter.telegram.0               : telegram              : raspibull                                - disabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.text2command.0           : text2command          : raspibull                                - disabled
                                          + system.adapter.tr-064.0                 : tr-064                : raspibull                                -  enabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : raspibull                                - disabled
                                          + system.adapter.web.0                    : web                   : raspibull                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + system.adapter.zigbee.0                 : zigbee                : raspibull                                -  enabled, port: /dev/ttyUSB0
                                          + instance is alive
                                          Active repo(s): stable
                                          Used repository: stable
                                          Adapter    "adb"          : 0.0.7    , installed 0.0.7
                                          Adapter    "admin"        : 6.17.14  , installed 6.17.14
                                          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                          Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                                          Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                                          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                          Adapter    "doorbird"     : 1.6.0    , installed 1.6.0
                                          Adapter    "email"        : 1.3.1    , installed 1.3.1
                                          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                          Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                                          Controller "js-controller": 5.0.19   , installed 5.0.19
                                          Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                                          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                                          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                                          Adapter    "robonect"     : 1.3.6    , installed 1.3.6
                                          Adapter    "scenes"       : 3.0.4    , installed 3.0.4
                                          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                          Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                                          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                          Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                          Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                                          Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                          Adapter    "web"          : 6.2.5    , installed 6.2.5
                                          Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                          Objects and States
                                          Objects:        11797
                                          States:         8235
                                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                                          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Hit:6 https://repos.influxdata.com/debian stable InRelease
                                          Pending Updates: 0
                                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13736      778/influxd
                                          tcp        0      0 192.168.178.78:8087     0.0.0.0:*               LISTEN      1001       65522      7315/io.simple-api.
                                          tcp        0      0 192.168.178.78:8100     0.0.0.0:*               LISTEN      1001       66435      7184/io.doorbird.0
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14502      555/sshd: /usr/sbin
                                          tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       79079      9094/adb
                                          tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       68076      7113/io.sonoff.0
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       67385      7177/io.shelly.1
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       66341      7080/io.mqtt.0
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       65132      6872/iobroker.js-co
                                          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      110        12228      538/redis-server 12
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      111        13919      1039/grafana
                                          tcp6       0      0 :::51989                :::*                    LISTEN      1001       65452      7094/io.nuki-extend
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          14513      555/sshd: /usr/sbin
                                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        1980       778/influxd
                                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       67467      7339/io.socketio.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       67486      7363/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       65204      6894/io.admin.0
                                          tcp6       0      0 ::1:6379                :::*                    LISTEN      110        12229      538/redis-server 12
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14420      430/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       67442      7112/io.shelly.0
                                          udp        0      0 0.0.0.0:46765           0.0.0.0:*                           1001       88232      7095/io.onkyo.0
                                          udp        0   1536 0.0.0.0:59344           0.0.0.0:*                           1001       88278      7095/io.onkyo.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13663      774/dhcpcd
                                          udp        0      0 0.0.0.0:45133           0.0.0.0:*                           108        14422      430/avahi-daemon: r
                                          udp6       0      0 :::54489                :::*                                108        14423      430/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        14421      430/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          13675      774/dhcpcd
                                          2024-07-19 19:51:34.258  - info: shelly.0 (7112) [CoAP] Device 192.168.178.51 (shellyswitch / shellyswitch-135140 / SHSW-21#135140#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:35.002  - info: shelly.0 (7112) [CoAP] Device 192.168.178.49 (shellyswitch / shellyswitch-134FB4 / SHSW-21#134FB4#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:35.066  - info: shelly.0 (7112) [CoAP] Device 192.168.178.79 (shelly1 / shelly1-500291F06303 / SHSW-1#500291F06303#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:36.289  - info: shelly.0 (7112) [CoAP] Device 192.168.178.33 (shellyswitch / shellyswitch-135173 / SHSW-21#135173#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:36.384  - info: shelly.0 (7112) [CoAP] Device 192.168.178.57 (shellyswitch25 / shellyswitch25-BA7AC4 / SHSW-25#BA7AC4#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:36.843  - info: shelly.0 (7112) [CoAP] Device 192.168.178.95 (shellyswitch25 / shellyswitch25-E098068D2599 / SHSW-25#E098068D2599#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:37.382  - info: shelly.0 (7112) [CoAP] Device 192.168.178.81 (shelly1 / shelly1-F4CFA2764699 / SHSW-1#F4CFA2764699#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:37.396  - info: shelly.0 (7112) [CoAP] Device 192.168.178.55 (shelly1 / shelly1-0597BD / SHSW-1#0597BD#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:38.189  - info: shelly.0 (7112) [CoAP] Device 192.168.178.54 (shelly1 / shelly1-1D92AF / SHSW-1#1D92AF#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:38.696  - info: shelly.0 (7112) [CoAP] Device 192.168.178.65 (shellyswitch25 / shellyswitch25-76C387 / SHSW-25#76C387#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:39.970  - info: shelly.0 (7112) [CoAP] Device 192.168.178.58 (shellyswitch25 / shellyswitch25-BA76C8 / SHSW-25#BA76C8#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:40.553  - info: shelly.0 (7112) [CoAP] Device 192.168.178.92 (shelly1 / shelly1-3083988C032A / SHSW-1#3083988C032A#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:40.557  - info: shelly.0 (7112) [CoAP] Device 192.168.178.77 (shelly1 / shelly1-1D92AC / SHSW-1#1D92AC#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:41.461  - info: shelly.0 (7112) [CoAP] Device 192.168.178.40 (shelly1 / shelly1-1D92BD / SHSW-1#1D92BD#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:41.997  - info: shelly.0 (7112) [CoAP] Device 192.168.178.66 (shellyswitch25 / shellyswitch25-76CFA7 / SHSW-25#76CFA7#1) connected! Polltime set to 20 sec.
                                          2024-07-19 19:51:42.712  - info: sonoff.0 (7113) Client [Stromzähler] connected with secret 1721411502684_8632
                                          2024-07-19 19:51:51.981  - info: shelly.1 (7177) [MQTT] Device with client id "shellyplus1pm-fcb467279060" connected!
                                          2024-07-19 19:51:53.267  - info: shelly.1 (7177) [MQTT] Device with client id "shellyplusplugs-d4d4daebcba4" connected!
                                          2024-07-19 19:52:01.783  - info: shelly.1 (7177) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-fcb467279060 / shellyplus1pm#fcb467279060#1) (false)
                                          2024-07-19 19:52:03.250  - info: shelly.1 (7177) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-d4d4daebcba4 / shellyplusplugs#d4d4daebcba4#1) (false)
                                          2024-07-19 19:52:04.869  - error: shelly.1 (7177) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-fcb467279060"
                                          2024-07-19 19:52:05.237  - error: shelly.1 (7177) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daebcba4"
                                          2024-07-19 19:52:55.695  - info: shelly.1 (7177) [MQTT] Device with client id "shellyplus1pm-fcb467279060" connected!
                                          2024-07-19 19:52:58.529  - info: shelly.1 (7177) [MQTT] Device with client id "shellyplusplugs-d4d4daebcba4" connected!
                                          2024-07-19 19:59:47.641  - info: influxdb.0 (6951) Store 19 buffered influxDB history points
                                          Nochmals Danke!
