  4. iobroker cmd in Konsole geht nicht
32 Beiträge 4 Kommentatoren 3.1k Aufrufe 2 Beobachtet
  • H Offline
    hukio
    Ihr seid zu schnell für mich.
    pi@raspibull:~ $ sudo systemctl unmask iobroker.service
    pi@raspibull:~ $ sudo systemctl enable iobroker.service
    Failed to enable unit: Unit file /lib/systemd/system/iobroker.service is masked.
    • H hukio
      @hukio
      systemctl status iobroker.service
      • H hukio
        @hukio sagte in iobroker cmd in Konsole geht nicht:
        oder du zu schnell für den pi.
        hast fu die Zeilen einzeln eingegeben?
        oder etwa alles auf einmal
        H 1 Antwort Letzte Antwort
          hukio
          pi@raspibull:~ $ iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
          -bash: iob_diag:: command not found
          • H hukio
            was soll das iob_diag: davor?
            • H hukio
              @hukio
              So eingeben:
                @hukio
                So eingeben:
                hukio
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                   Static hostname: raspibull
                         Icon name: computer
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Model           : Raspberry Pi 4 Model B Rev 1.1
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : 64 bit
                Systemuptime and Load:
                 18:03:11 up  3:13,  2 users,  load average: 6.03, 2.30, 1.14
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Fri 2024-07-19 18:03:11 CEST
                           Universal time: Fri 2024-07-19 16:03:11 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                pi
                HOME=/home/pi
                *** Display-Server-Setup ***
                Display-Server: false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            3.8G        2.5G        318M        1.0M        966M        1.4G
                Swap:           2.0G          0B        2.0G
                Total:          5.8G        2.5G        2.3G
                Active iob-Instances:   0
                         3793 M total memory
                         2508 M used memory
                         2599 M active memory
                          691 M inactive memory
                          318 M free memory
                           96 M buffer memory
                          869 M swap cache
                         2027 M total swap
                            0 M used swap
                         2027 M free swap
                top - 18:03:11 up  3:13,  2 users,  load average: 6.03, 2.30, 1.14
                Tasks: 188 total,   1 running, 187 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  1.4 us,  5.6 sy,  0.0 ni, 93.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3793.3 total,    318.6 free,   2508.3 used,    966.5 buff/cache
                MiB Swap:   2028.0 total,   2028.0 free,      0.0 used.   1354.1 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4       30G   20G  8.2G  71% /
                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                tmpfs          tmpfs     759M  1.2M  758M   1% /run
                /dev/sda3      ext4      439G  3.9G  413G   1% /mnt/hukdata
                /dev/sda1      vfat      256M   32M  225M  13% /boot
                tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                [Fri Jul 19 14:49:43 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:1E:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=4d904d30-02 rootfstype=ext4 fsck.repair=yes rootwait rootdelay=5
                [Fri Jul 19 14:49:51 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                [Fri Jul 19 14:49:51 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Fri Jul 19 14:49:53 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                [Fri Jul 19 14:49:55 2024] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
                Show mounted filesystems:
                TARGET                       SOURCE     FSTYPE     OPTIONS
                /                            /dev/sda2  ext4       rw,noatime
                |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
                | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
                | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
                |-/proc                      proc       proc       rw,relatime
                | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
                | `-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
                |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
                | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
                | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
                |-/mnt/hukdata               /dev/sda3  ext4       rw,noatime
                `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                5.9G    /var/
                3.1G    /var/log
                3.0G    /var/log/journal/1ffd49df1b3a44ffb614b2c58029c285
                630M    /var/cache
                Archived and active journals take up 2.9G in the file system.
                /opt/iobroker/backups:
                7.2G    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                858M    /opt/iobroker/iobroker-data/
                356M    /opt/iobroker/iobroker-data/files
                342M    /opt/iobroker/iobroker-data/history
                138M    /opt/iobroker/iobroker-data/files/javascript.admin
                129M    /opt/iobroker/iobroker-data/backup-objects
                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                29M     /opt/iobroker/iobroker-data/objects.jsonl
                26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_323adb3b74d9eb11b6e6178e6fe9f4d9-if00-port0
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.20.4
                /usr/bin/node           v18.20.4
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                /usr/bin/corepack       0.28.0
                nodejs:
                  Installed: 18.20.4-1nodesource1
                  Candidate: 18.20.4-1nodesource1
                  Version table:
                 *** 18.20.4-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                     18.20.3-1nodesource1 1001
                     18.20.2-1nodesource1 1001
                     18.20.1-1nodesource1 1001
                     18.20.0-1nodesource1 1001
                     18.19.1-1nodesource1 1001
                     18.19.0-1nodesource1 1001
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Core adapters versions
                js-controller:
                admin:
                javascript:
                nodejs modules from github:     1
                +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)
                Adapter State
                ioBroker-Repositories
                Installed ioBroker-Instances
                Objects and States
                Objects:        0
                States:         0
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:5 https://repos.influxdata.com/debian stable InRelease
                Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                Reading package lists... Done
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 192.168.178.78:8100     0.0.0.0:*               LISTEN      1000       16018      1419/io.doorbird.0
                tcp        0      0 192.168.178.78:8087     0.0.0.0:*               LISTEN      1000       16143      1495/io.simple-api.
                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      110        15380      540/redis-server 12
                tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1000       17981      1523/adb
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2012       1101/iobroker.js-co
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       17891      1408/io.shelly.1
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       17626      1291/io.mqtt.0
                tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       17761      1366/io.sonoff.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3518       548/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        1805       777/influxd
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       15245      1532/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       16403      1118/io.admin.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        3698       777/influxd
                tcp6       0      0 :::8084                 :::*                    LISTEN      1000       15223      1514/io.socketio.0
                tcp6       0      0 ::1:6379                :::*                    LISTEN      110        15381      540/redis-server 12
                tcp6       0      0 :::22                   :::*                    LISTEN      0          3520       548/sshd: /usr/sbin
                tcp6       0      0 :::3000                 :::*                    LISTEN      111        15671      1049/grafana
                tcp6       0      0 :::51989                :::*                    LISTEN      1000       16644      1325/io.nuki-extend
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14160      429/avahi-daemon: r
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       15014      1351/io.shelly.0
                udp        0      0 0.0.0.0:36430           0.0.0.0:*                           1000       153027     1336/io.onkyo.0
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14462      773/dhcpcd
                udp        0      0 0.0.0.0:45834           0.0.0.0:*                           1000       151987     1336/io.onkyo.0
                udp        0      0 0.0.0.0:33672           0.0.0.0:*                           108        14162      429/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        14161      429/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          1753       773/dhcpcd
                udp6       0      0 :::52066                :::*                                108        14163      429/avahi-daemon: r
                2024-07-19 17:06:30.780  - info: javascript.0 (1186) script.js.Sensoren.Waschmaschine:  vEnergy_start: 701.39
                2024-07-19 17:06:30.780  - info: javascript.0 (1186) script.js.Sensoren.Waschmaschine: Zählerstand Strom: 31164.17
                2024-07-19 17:33:56.909  - info: javascript.0 (1186) script.js.Sensoren.Trockner: Verbrauch (plug): 0.4 kWh
                2024-07-19 17:33:56.909  - info: javascript.0 (1186) script.js.Sensoren.Trockner: totaler Verbrauch Zählerdifferenz: 1.3 kWh
                2024-07-19 17:33:56.966  - info: signal-cmb.0 (1484) Send Karin der Trockner ist seit  17:33 fertig. to f98af11f-c3df-4b54-9f1e-0454df85f8bd
                2024-07-19 17:53:52.316  - info: javascript.0 (1186) script.js.Sensoren.Proximity_Sensor_Echo: true
                2024-07-19 17:57:36.227  - info: zigbee.0 (1397) Device '0xec1bbdfffe79e066' announced itself
                2024-07-19 18:02:30.140  - warn: influxdb.0 (1171) Error on writePoint("{"value":5.6,"time":"2024-07-19T16:02:00.131Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:31.681  - warn: influxdb.0 (1171) Error on writePoint("{"value":584,"time":"2024-07-19T16:02:01.675Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:34.365  - warn: influxdb.0 (1171) Error on writePoint("{"value":8.3,"time":"2024-07-19T16:02:04.358Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:38.418  - warn: influxdb.0 (1171) Error on writePoint("{"value":7.3,"time":"2024-07-19T16:02:08.407Z","from":"system.adapter.shelly.1","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:38.572  - warn: influxdb.0 (1171) Error on writePoint("{"value":2383,"time":"2024-07-19T16:02:08.561Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:40.147  - info: influxdb.0 (1171) Connecting http://localhost:8086/ ...
                2024-07-19 18:02:40.148  - info: influxdb.0 (1171) Influx DB Version used: 1.x
                2024-07-19 18:02:45.287  - warn: influxdb.0 (1171) Error on writePoint("{"value":1033,"time":"2024-07-19T16:02:15.274Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:45.288  - info: influxdb.0 (1171) Add point that had error for javascript.0.gStromc to buffer again, error-count=4
                2024-07-19 18:02:48.495  - info: influxdb.0 (1171) Store 8 buffered influxDB history points
                2024-07-19 18:02:53.190  - warn: influxdb.0 (1171) Error on writePoint("{"value":359,"time":"2024-07-19T16:02:23.184Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:53.191  - info: influxdb.0 (1171) Add point that had error for javascript.0.gStromc to buffer again, error-count=5
                2024-07-19 18:02:58.759  - warn: influxdb.0 (1171) Error on writePoint("{"value":349,"time":"2024-07-19T16:02:28.748Z","from":"system.adapter.javascript.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:58.760  - info: influxdb.0 (1171) Add point that had error for javascript.0.gStromc to buffer again, error-count=6
                2024-07-19 18:02:59.711  - warn: influxdb.0 (1171) Error on writePoint("{"value":31165.8,"time":"2024-07-19T16:02:28.578Z","from":"system.adapter.sonoff.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:59.712  - info: influxdb.0 (1171) Add point that had error for sonoff.0.Stromzähler._Zählerstand to buffer again, error-count=1
                2024-07-19 18:02:59.713  - warn: influxdb.0 (1171) Error on writePoint("{"value":31165.81,"time":"2024-07-19T16:02:29.702Z","from":"system.adapter.sonoff.0","q":0,"ack":true}): Error: ESOCKETTIMEDOUT / "ESOCKETTIMEDOUT""
                2024-07-19 18:02:59.714  - info: influxdb.0 (1171) Add point that had error for sonoff.0.Stromzähler._Zählerstand to buffer again, error-count=2
                • H hukio
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  pi
                  HOME=/home/pi
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           2.0G          0B        2.0G
                           3793 M total memory
                           2508 M used memory
                            318 M free memory
                             96 M buffer memory
                            869 M swap cache
                           2027 M total swap
                              0 M used swap
                           2027 M free swap
                  *** FILESYSTEM ***
                  /var:
                  5.9G    /var/
                  3.1G    /var/log
                  630M    /var/cache
                  USB-Devices by-id:
                  /usr/bin/npm            10.7.0
                  /usr/bin/npx            10.7.0
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  js-controller:
                  admin:
                  javascript:
                  Adapter State
                  Objects and States
                  Objects:        0
                  States:         0
                  Pending Updates: 0
                  pi
                  Das muss der user 'iobroker' sein.
                  Was haste da bitte gemacht?
                    pi
                    hukio
                    Habe ich in der ersten mail skizziert. Mehr Einzelheiten kann ich chronologisch nicht sagen. Wie kann ich den Fehler ändern?
                    • H hukio
                      @hukio
                        @hukio
                        hukio
                        pi@raspibull:~ $ systemctl status iobroker.service
                        ● iobroker.service
                             Loaded: masked (Reason: Unit iobroker.service is masked.)
                             Active: inactive (dead)
                        • H hukio
                          ● iobroker.service
                          @hukio
                          systemctl status mask iobroker.service
                          systemctl status unmask iobroker.service
                          • H hukio
                            Ich habe ein update/upgrade des OS gemacht. Das in einen dpkg Fehler lief (problem mit node 18.20.4 update (war 18.19.x)). IOB startete nicht mehr. Habe dann nodejs alleine upgrade gemacht. Das iobroker system konnte ich mit
                            node node_modules/iobroker.js-controller/controller.js --logs
                            erfolgreich starten.
                            Alle iobroker cmd in der Konsole geben keine Antwort. Iobroker startet nicht nach reboot.
                            Meine Installation Raspberry Pi4 mit Bullseye
                            jetzt node 18.20.4 npm 10.7.0
                            Wie kann ich die iobroker Befehle in der Konsole wieder herstellen?
                            HUK
                            PS:
                            ● iobroker.service
                            Ro75R Online
                            Ro75R Online
                            Ro75
                            Kannst du ggfs. die letzten Befehle in der Konsole mal posten, also die die obiges betreffen. In der Konsole sollte man diese sehen, mit der Pfeiltaste nach oben bzw. nach unten.
                            Ro75.
                              @hukio
                              hukio
                              pi@raspibull:~ $ systemctl status mask iobroker.service
                              Unit mask.service could not be found.
                              ● iobroker.service
                              pi@raspibull:~ $ systemctl status unmask iobroker.service
                              Unit unmask.service could not be found.
                              ● iobroker.service
                              • H hukio
                                ● iobroker.service
                                ● iobroker.service
                                @hukio
                                Sorry, Quatsch von mir...
                                sudo systemctl mask iobroker.service
                                • Ro75R Ro75
                                  Ro75.
                                  hukio
                                  @ro75
                                  Habe aus Versehen diesen Befehl abgesetzt.
                                  vorher diesen
                                  sudo dpkg --configure -a
                                  mehr finde ich nicht
                                    @hukio
                                    hukio
                                    pi@raspibull:~ $ sudo systemctl mask iobroker.service
                                    Created symlink /etc/systemd/system/iobroker.service → /dev/null.
                                    Removed /etc/systemd/system/iobroker.service.
                                    • H hukio
                                      @ro75
                                      vorher diesen
                                      @hukio
                                      Da frag ich mir nur... WARUM??
                                      Mit dpgk direkt hast du in der Regel nix am Hut.
                                      sagt nun?
                                        @hukio
                                        sagt nun?
                                        hukio
                                        ● iobroker.service
                                        weil ich einen Fehler mit dpkg hatte.
                                        • H hukio
                                          ● iobroker.service
                                          Und genau was wurde von dpkg bemängelt?
                                          sudo apt install --reinstall nodejs
                                          sudo reboot
