  4. Adapter Update nicht möglich --> gelöst
39 Beiträge 7 Kommentatoren 5.7k Aufrufe 6 Beobachtet
    @k_o_bold dann mach mal ein iob upgrade daikin-cloud --debug und poste das Ergebnis
    K_o_bold
    @homoran sagte in Adapter Update nicht möglich:
    root@uwe-nuc7i3bnh:/opt/iobroker# iob upgrade daikin-cloud --debug
    This upgrade of "daikin-cloud" will introduce the following changes:
    -> 0.4.6:
    Update dependencies with optimizations and second blocking layer for rate limiting
    -> 0.4.5:
    Block communication when rate limited according to Daikin response
    -> 0.4.4:
    Fix initialization retry schedule
    -> 0.4.3:
    IMPORTANT: Minimum Node.js version is 18.2
    BREAKING: Adjusted to new Daiking Cloud API - You need to reauthenticate!
    BREAKING: New rate limit of new API is 200 requests per day!! Adjust your usage!
    Added option to set "slow polling" interval
    Make electrical data available as states (arrays for now)
    Restore last data updated timestamp
    Make sure cloudConnection always contains a boolean
    Refresh token also when error is "Refresh Token has expired"
    Would you like to upgrade daikin-cloud from @0.3.0 to @0.4.6 now? [(y)es, (n)o]: y
    Update daikin-cloud from @0.3.0 to @0.4.6
    NPM version: 10.8.1
    Installing iobroker.daikin-cloud@0.4.6... (System call)
    npm error code EHOSTUNREACH
    npm error syscall connect
    npm error errno EHOSTUNREACH
    npm error request to https://registry.npmjs.org/iobroker.daikin-cloud failed, reason: connect EHOSTUNREACH 2606:4700::6810:323:443
    npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-07-16T19_41_55_122Z-debug-0.log
    upload [6] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/admin.d.ts admin.d.ts video/mp2t
    upload [5] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin-cloud.jpg daikin-cloud.jpg image/jpeg
    upload [4] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/daikin_logo.jpg daikin_logo.jpg image/jpeg
    upload [3] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/index_m.html index_m.html text/html
    upload [2] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/style.css style.css text/css
    upload [1] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/warning.png warning.png image/png
    upload [0] daikin-cloud.admin /opt/iobroker/node_modules/iobroker.daikin-cloud/admin/words.js words.js application/javascript
    • K K_o_bold
      -> 0.4.6:
      -> 0.4.5:
      -> 0.4.4:
      -> 0.4.3:
      NPM version: 10.8.1
      @k_o_bold sagte in Adapter Update nicht möglich:
      du erreichst den npm Server nicht!
      hast du Probleme mit dem Netzwerk, wahrscheinlich mit IPv6?
        K_o_bold
        @homoran ,
        mein Netzwerk sollte ok, sein. Zumindest habe ich nichts geändert.
        Der Server ist per LAN mit der Fritzbox verbunden...IPv4 soweit ich das beurteilen kann...
        Wie könnte ich den Prüfen ob es an meinem Netzwerk liegt?
        Sorry ich bin da noch nicht so fit
        • K K_o_bold
          @homoran ,
          nix gut!
          der server wird per ipv6 aufgerufen!
          teste mal https://internet.nl/connection/
            nix gut!
            K_o_bold
            @homoran ,
            Ok, ich denke dann kommen wir der Sachen näher...
            Ich frage mich nur, warum das bisher funktioniert hat...
            Ich denke, das kann ich in der Fritzbox einstellen, oder?
            • K K_o_bold
              @homoran ,
              ich denke auch. weiss aber nicht wo
                K_o_bold
                @homoran ,
                scheint aber bei mir aktiv zu sein...
                • K K_o_bold
                  @homoran ,
                  dann klemmt's irgendwo beim Provider wenn's draußen ist oder irgendwo drinnen bei dir.
                  ggf. kannst du auch ipv6 via ipv4 tunneln.
                  • K K_o_bold
                    @homoran ,
                    @k_o_bold
                    Was ist denn das da für ein Zugang?
                      K_o_bold
                      @homoran ,
                      oder einfach mal die Fritzbox neustarten 😬 hilft auch manchmal....
                      Oh Mann...
                      Vielen, Vielen Dank für deine und eure Hilfe und Geduld....
                        @k_o_bold
                        K_o_bold
                        @thomas-braun ,
                        was meinst du?
                        • K K_o_bold
                          @thomas-braun ,
                          was meinst du?
                          @k_o_bold
                          Ich meinte, über welchen Internetprovider bzw. über welche Technik du ins Netz gehst.
                          Ich vermute, dein ISP hat dich auf IPv6 gehievt.
                            @k_o_bold
                            K_o_bold
                            @thomas-braun sagte in Adapter Update nicht möglich --> gelöst:
                            Vodafone Kabelanschluss mit Fritzbox 7490.
                            Könnte natürlich auch sein, dass mein Provider was gemacht hat und dadurch die IPv6 Verbindung gekappt wurde...
                            • K K_o_bold
                              @k_o_bold sagte in Adapter Update nicht möglich --> gelöst:
                              Das kann nicht sein, die 7490 ist eine DSL-Kiste.
                              KabelBoxen sind die 6000er. Hier rumpelt z. B. eine 6660.
                              Wenn es nun läuft...
                              internet.nl zeigt nun 100%?
                                K_o_bold
                                Sorry, ist eine 6490
                                internet.nl zeigt 100%, ja.
