  4. [gelöst] Sonoff Zigbee 3.0 Dongle "Failure to connect"
19 Beiträge 5 Kommentatoren 3.3k Aufrufe 5 Beobachtet
  • AsgothianA Asgothian
    @aupex sagte in Sonoff Zigbee 3.0 Dongle "Failure to connect":
    @asgothian
    Habe es so gemacht, wie du geschrieben hast. Funktioniert leider nicht. Siehe log:
    2024-07-11 14:55:04.610  - error: zigbee.0 (7238) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-07-11 14:55:04.874  - info: zigbee.0 (7238) List of port: [{"path":"/dev/ttyACM0","manufacturer":"ITEAD","serialNumber":"20231214181142","pnpId":"usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231214181142-if00","vendorId":"1a86","productId":"55d4"},{"path":"/dev/ttyAMA0"}]
    2024-07-11 14:55:33.447  - info: admin.0 (846) <== Disconnect system.user.admin from ::ffff:192.168.2.106
    2024-07-11 14:55:33.660  - warn: zigbee.0 (7238) Got terminate signal. Checking desired PID: 0 vs own PID 7238
    2024-07-11 14:55:33.695  - info: host.iobroker instance system.adapter.zigbee.0 started with pid 7429
    2024-07-11 14:55:33.664  - info: zigbee.0 (7238) cleaned everything up...
    2024-07-11 14:55:33.677  - info: zigbee.0 (7238) Zigbee: disabling joining new devices.
    2024-07-11 14:55:33.895  - warn: zigbee.0 (7238) Failed to stop zigbee during startup
    2024-07-11 14:55:33.897  - info: zigbee.0 (7238) terminating
    2024-07-11 14:55:33.900  - info: zigbee.0 (7238) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-07-11 14:55:33.923  - warn: zigbee.0 (7238) Got terminate signal. Checking desired PID: 7429 vs own PID 7238
    2024-07-11 14:55:34.165  - info: zigbee.0 (7238) terminating
    2024-07-11 14:55:34.556  - info: host.iobroker instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2024-07-11 14:55:34.556  - info: host.iobroker Do not restart adapter system.adapter.zigbee.0 because desired by instance
    2024-07-11 14:55:39.834  - info: zigbee.0 (7429) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.4, js-controller: 5.0.19
    2024-07-11 14:55:39.953  - info: zigbee.0 (7429) Starting Zigbee  npm ...
    2024-07-11 14:55:40.439  - info: zigbee.0 (7429) Installed Version: iobroker.zigbee@1.10.3
    2024-07-11 14:55:44.622  - error: zigbee.0 (7429) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    2024-07-11 14:55:44.624  - error: zigbee.0 (7429) Failed to start Zigbee
    2024-07-11 14:55:44.624  - error: zigbee.0 (7429) Error herdsman start
    2024-07-11 14:55:54.630  - info: zigbee.0 (7429) Try to reconnect. 1 attempts left
    2024-07-11 14:55:54.631  - info: zigbee.0 (7429) Starting Zigbee  npm ...
    2024-07-11 14:55:54.645  - info: zigbee.0 (7429) Installed Version: iobroker.zigbee@1.10.3
    2024-07-11 14:56:25.061  - error: zigbee.0 (7429) Starting zigbee-herdsman problem : "Failure to connect"
    2024-07-11 14:56:25.063  - error: zigbee.0 (7429) Failed to start Zigbee
    2024-07-11 14:56:25.064  - error: zigbee.0 (7429) Error herdsman start
    Mir fehlen da Log Meldungen von vor 14:55:04 - die erste Fehlermeldung ist bereits ein Problem welches darauf hin deutet das der Adapter davor nicht sauber war. Bitte Posten.
    Hast du sicher gestellt das der Adapter angehalten war und nicht mehr lief bevor du die Daten im Verzeichnis gelöscht hast ? Wenn nein dann schreibt der Adapter die am Ende.
    A.
    aupexA Offline
    aupexA Offline
    aupex
    schrieb am zuletzt editiert von aupex
    @asgothian
    Das war das komplette Log, das mir angezeigt wurde. Würde es helfen ein Log nach einem reboot zu posten?
    Kann man es irgendwie nach Adaptern filtern oder soll ich es komplett einstellen?
    2024-07-11 17:37:21.275  - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-07-11 17:37:21.286  - info: zigbee.0 (1176) Got terminate signal TERMINATE_YOURSELF
    2024-07-11 17:37:21.289  - info: zigbee.0 (1176) cleaned everything up...
    2024-07-11 17:37:21.296  - info: zigbee.0 (1176) Zigbee: disabling joining new devices.
    2024-07-11 17:37:21.374  - warn: zigbee.0 (1176) Failed to stop zigbee during startup
    2024-07-11 17:37:21.375  - info: zigbee.0 (1176) terminating
    2024-07-11 17:37:21.377  - info: zigbee.0 (1176) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-07-11 17:37:21.508  - info: host.iobroker stopInstance system.adapter.zigbee.0 send kill signal
    2024-07-11 17:37:21.791  - info: zigbee.0 (1176) terminating
    2024-07-11 17:37:22.021  - info: host.iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-07-11 17:37:24.625  - info: host.iobroker instance system.adapter.zigbee.0 started with pid 2133
    2024-07-11 17:37:30.742  - info: zigbee.0 (2133) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.4, js-controller: 5.0.19
    2024-07-11 17:37:30.862  - info: zigbee.0 (2133) Starting Zigbee  npm ...
    2024-07-11 17:37:31.292  - info: zigbee.0 (2133) Installed Version: iobroker.zigbee@1.10.3
    2024-07-11 17:37:35.470  - error: zigbee.0 (2133) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    2024-07-11 17:37:35.471  - error: zigbee.0 (2133) Failed to start Zigbee
    2024-07-11 17:37:35.472  - error: zigbee.0 (2133) Error herdsman start
    2024-07-11 17:37:45.477  - info: zigbee.0 (2133) Try to reconnect. 1 attempts left
    2024-07-11 17:37:45.478  - info: zigbee.0 (2133) Starting Zigbee  npm ...
    2024-07-11 17:37:45.492  - info: zigbee.0 (2133) Installed Version: iobroker.zigbee@1.10.3
    2024-07-11 17:38:15.923  - error: zigbee.0 (2133) Starting zigbee-herdsman problem : "Failure to connect"
    2024-07-11 17:38:15.924  - error: zigbee.0 (2133) Failed to start Zigbee
    2024-07-11 17:38:15.926  - error: zigbee.0 (2133) Error herdsman start
    Das ist jetzt nach einem Adapter-neustart
      @arteck sagte in Sonoff Zigbee 3.0 Dongle "Failure to connect":
      Ich wollte meinen cc2531 nachdem er immer öfter ausgefallen ist durch einen Sonoff Dongle ersetzen.
      du hättest einfach NUR der alten raus den neuen rein.. 5 min Warten fertig...
      Wenn er den richtigen sonoff dongle erwischt hat. (-p Variante, nicht -e Variante). Das log oben deutet darauf hin das er einen -e hat. (EZSP Firmware und dann die Meldung “configuration mismatch”)
      A.
      arteckA Offline
      arteckA Offline
      arteck
      @asgothian
      ist ein P
      @aupex
      also nochmal ganz langsam
      auf der console
      iob stop
      rm -R /opt/iobroker/iobroker-data/zigbee_0
      iob start
      geht es jetzt
      S aupexA 3 Antworten Letzte Antwort
      • arteckA arteck
        @asgothian
        ist ein P
        @aupex
        auf der console
        iob stop
        iob start
        geht es jetzt
        stefande
        @asgothian
        ist ein P
        NEIN der V2 ist ein E !!!
        • arteckA arteck
          @asgothian
          ist ein P
          @aupex
          auf der console
          iob stop
          iob start
          geht es jetzt
          aupexA Offline
          aupexA Offline
          aupex
          @arteck
          Ich probiere es später gleich aus. Btw es ist ein "e". Habe ich versäumt zu schreiben.
          • aupexA aupex
            @arteck
            @aupex
            Die Sonoff Zigbee Dongles gibt es in zwei Varianten, die jeweils einen anderen 'Treiber' benötigen. Entweder den 'Z-Stack' oder den 'EZSP'-Stack (oder so ähnlich...) Musst du evtl. mal umstellen.
            aupexA 1 Antwort Letzte Antwort
              @aupex
              aupexA Offline
              aupexA Offline
              aupex
              Es ist ein "e" weshalb ich ezsp/efr32 eingestellt habe.
              • aupexA aupex
                @aupex
                So aus Interesse:
                Wie meldet der sich in
                lsusb
                denn?
                  @aupex
                  So aus Interesse:
                  lsusb
                  denn?
                  aupexA Offline
                  aupexA Offline
                  aupex
                  pi@iobroker:~ $ lsusb
                  Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                  Bus 001 Device 004: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongle Plus V2
                  Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                  • aupexA aupex
                    @aupex
                    Danke! Damit kann ich einen Check in
                    iob diag
                    einbauen und eine entsprechende Empfehlung geben.
                    • arteckA arteck
                      @asgothian
                      ist ein P
                      @aupex
                      auf der console
                      iob stop
                      iob start
                      geht es jetzt
                      aupexA Offline
                      aupexA Offline
                      aupex
                      @arteck said in Sonoff Zigbee 3.0 Dongle "Failure to connect":
                      VIELEN DANK.
                      Jetzt wird der Adapter grün. Habe vorher nur den Adapter gestoppt, nicht aber den IObroker.
                      Da ich sowieso neu anlernen muss, wollte ich einen anderen Kanal auswählen, weshalb ich einen Kanalscan machen wollte. Dieser wurde mit folgendem Log beendet:
                      2024-07-12 15:26:40.922  - info: zigbee.0 (7854) Zigbee started
                      2024-07-12 15:26:41.389  - info: zigbee.0 (7854) debug devices set to []
                      2024-07-12 15:26:40.873  - info: zigbee.0 (7854) Coordinator firmware version: {"type":"EZSP v12","meta":{"product":12,"majorrel":"7","minorrel":"3","maintrel":"1 ","revision":"7.3.1.0 build 176"}}
                      2024-07-12 15:26:40.876  - info: zigbee.0 (7854) Unable to disable LED, unsupported function.
                      2024-07-12 15:26:40.904  - info: zigbee.0 (7854)   --> transmitPower : normal
                      2024-07-12 15:26:40.920  - info: zigbee.0 (7854) Currently no devices.
                      2024-07-12 15:26:45.712  - error: zigbee.0 (7854) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2024-07-12 15:26:45.713  - error: zigbee.0 (7854) unhandled promise rejection: Cannot read properties of undefined (reading 'waitFor')
                      2024-07-12 15:26:46.028  - error: zigbee.0 (7854) TypeError: Cannot read properties of undefined (reading 'waitFor')
                          at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:1010:54)
                          at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:513:52)
                          at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:84:34)
                          at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:16:48)
                          at Zigbee.emit (node:events:529:35)
                          at Zigbee.emit (node:domain:489:12)
                          at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11114:34)
                          at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:379:37)
                          at processImmediate (node:internal/timers:476:21)
                      2024-07-12 15:26:46.029  - error: zigbee.0 (7854) Cannot read properties of undefined (reading 'waitFor')
                      2024-07-12 15:26:46.041  - info: zigbee.0 (7854) cleaned everything up...
                      2024-07-12 15:26:46.045  - info: zigbee.0 (7854) Zigbee: disabling joining new devices.
                      2024-07-12 15:26:46.390  - info: zigbee.0 (7854) terminating
                      2024-07-12 15:26:46.393  - warn: zigbee.0 (7854) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2024-07-12 15:26:46.543  - info: zigbee.0 (7854) terminating
                      2024-07-12 15:26:47.027  - error: host.iobroker Caught by controller[1]: zh:controller: Failed to disable join on stop: TypeError: Cannot read properties of undefined (reading 'permitJoin')
                      2024-07-12 15:26:47.028  - error: host.iobroker Caught by controller[2]: zhc:lixee: Was not able to detect the Linky linky_mode. Default to historique
                      2024-07-12 15:26:47.029  - error: host.iobroker Caught by controller[3]: zhc:lixee: Was not able to detect the Linky energy_phase. Default to single_phase
                      2024-07-12 15:26:47.030  - error: host.iobroker Caught by controller[4]: zhc:lixee: Not able to detect the current tarif. Not filtering any expose...
                      2024-07-12 15:26:47.030  - error: host.iobroker Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                      2024-07-12 15:26:47.030  - error: host.iobroker Caught by controller[6]: TypeError: Cannot read properties of undefined (reading 'waitFor')
                      2024-07-12 15:26:47.030  - error: host.iobroker Caught by controller[6]:     at ZigbeeController.getChannelsEnergy (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:1010:54)
                      2024-07-12 15:26:47.030  - error: host.iobroker Caught by controller[6]:     at Commands.getChannels (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:513:52)
                      2024-07-12 15:26:47.030  - error: host.iobroker Caught by controller[6]:     at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:84:34)
                      2024-07-12 15:26:47.031  - error: host.iobroker Caught by controller[6]:     at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:16:48)
                      2024-07-12 15:26:47.031  - error: host.iobroker Caught by controller[6]:     at Zigbee.emit (node:events:529:35)
                      2024-07-12 15:26:47.031  - error: host.iobroker Caught by controller[6]:     at Zigbee.emit (node:domain:489:12)
                      2024-07-12 15:26:47.031  - error: host.iobroker Caught by controller[6]:     at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11114:34)
                      2024-07-12 15:26:47.031  - error: host.iobroker Caught by controller[6]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:379:37)
                      2024-07-12 15:26:47.032  - error: host.iobroker Caught by controller[6]:     at processImmediate (node:internal/timers:476:21)
                      2024-07-12 15:26:47.032  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2024-07-12 15:26:47.032  - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
                      2024-07-12 15:27:17.214  - info: host.iobroker instance system.adapter.zigbee.0 started with pid 7870
                      2024-07-12 15:27:23.232  - info: zigbee.0 (7870) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.4, js-controller: 5.0.19
                      2024-07-12 15:27:23.352  - info: zigbee.0 (7870) Starting Zigbee  npm ...
                      2024-07-12 15:27:23.793  - info: zigbee.0 (7870) Installed Version: iobroker.zigbee@1.10.3
                      2024-07-12 15:27:29.017  - info: zigbee.0 (7870) Coordinator firmware version: {"type":"EZSP v12","meta":{"product":12,"majorrel":"7","minorrel":"3","maintrel":"1 ","revision":"7.3.1.0 build 176"}}
                      2024-07-12 15:27:29.019  - info: zigbee.0 (7870) Unable to disable LED, unsupported function.
                      2024-07-12 15:27:29.046  - info: zigbee.0 (7870)   --> transmitPower : normal
                      2024-07-12 15:27:29.062  - info: zigbee.0 (7870) Currently no devices.
                      2024-07-12 15:27:29.064  - info: zigbee.0 (7870) Zigbee started
                      2024-07-12 15:27:29.433  - info: zigbee.0 (7870) debug devices set to []
                        @aupex
                        iob diag
                        aupexA Offline
                        aupexA Offline
                        aupex
                                                v.2024-05-22
                         Static hostname: iobroker
                               Icon name: computer
                                  Kernel: Linux 6.1.21-v8+
                            Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               32 bit
                        User-ID:                1000
                        Display-Server:         false
                        Boot Target:            multi-user.target
                        Pending OS-Updates:     0
                        Pending iob updates:    0
                        Nodejs-Installation:
                        /usr/bin/nodejs         v18.20.4
                        /usr/bin/node           v18.20.4
                        /usr/bin/npm            10.7.0
                        /usr/bin/npx            10.7.0
                        /usr/bin/corepack       0.28.0
                        Recommended versions are nodejs 18.20.4 and npm 10.7.0
                        MEMORY:
                        Mem:            4.0G        1.3G        2.1G        1.2M        709M        2.7G
                        Swap:           209M          0B        209M
                        Total:          4.2G        1.3G        2.3G
                        Active iob-Instances:   18
                        Active repo(s): stable
                        ioBroker Core:          js-controller           5.0.19
                                                admin                   6.17.14
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                10178
                        States:                 7878
                        Size of iob-Database:
                        48M     /opt/iobroker/iobroker-data/objects.jsonl
                        7.8M    /opt/iobroker/iobroker-data/states.jsonl
                        • aupexA aupex
                          VIELEN DANK.
                          aupexA Offline
                          aupexA Offline
                          aupex
                          Die Fehler sind irgendwie alle verschwunden und es läuft jetzt reibungslos.
                          Vielen Dank für eure Hilfe.
                          • aupexA aupex
                            @aupex
                            Dann bring jetzt nodejs auf die Version 20:
                            iob nodejs-update 20
