  4. ...nicht in offiziellem Repo
  5. Test Adapter todoist2 v0.9 Latest/GitHub
    6.4k
Geplant Angeheftet Gesperrt Verschoben ...nicht in offiziellem Repo
testertodoist
145 Beiträge 19 Kommentatoren 26.4k Aufrufe 17 Beobachtet
  • haselchenH haselchen
    @mcm57
    Wollte noch abwarten , aber in unregelmässigen Abständen kommt da immer wieder ne Meldung.
    Diesmal ist es Error 502.
    {"message":"Request failed with status code 502","name":"AxiosError","stack":"AxiosError: Request failed with status code 502\n at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:1913:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:2995:11)\n at IncomingMessage.emit (node:events:529:35)\n at endReadableNT (node:internal/streams/readable:1368:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer ","User-Agent":"axios/1.5.1","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","baseURL":"https://api.todoist.com","url":"/rest/v2/tasks","responseType":"json"},"code":"ERR_BAD_RESPONSE","status":502}
    	received error 502 response from todoist with content: "<html>\r\n<head><title>502 Bad Gateway</title></head>\r\n<body>\r\n<center><h1>502 Bad Gateway</h1></center>\r\n</body>\r\n</html>\r\n"
    https://github.com/rde-master/ioBroker.todoist2/issues/126
    mcm1957M Online
    mcm1957M Online
    mcm1957
    #110
    @haselchen
    Klingt aber eher nach Netzwerk oder Website Problem.
    502er kennen wir ja euch hier :-)
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    • mcm1957M mcm1957
      @haselchen
      haselchenH Offline
      haselchenH Offline
      haselchen
      #111
      @mcm57
      Dann müssten doch aber mehrere dieses Problem haben mit deren Website?
      Netzwerk ist bei mir vollkommen okay.
      Keine Ausfälle oder Hinweise in irgendwelchen Logs.
      mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
        @mcm57
        mcm1957M Online
        mcm1957M Online
        mcm1957
        #112
        @haselchen
        Sorry,
        zu 502 bad gateway gibts hier sicher Leute die mehr Ahnung haben als ich.
          @mcm57
          #113
          @haselchen
          500er sind eigentlich immer Dinge auf dem entfernten Server.
          Den aktuellen Status kann man hier sehen:
          https://status.todoist.net/
          • DickenD Offline
            DickenD Offline
            Dicken
            #114
            Ich seh grad das der ersteller @rde-master zuletzt 2022 online war, und auf github tut sich auch nichts mehr. Schade... Ich hatte gehoft, das man hier irgendwie eine Brücke implementieren könnte, die eine Synchronisation mit der Einkaufsliste vom Alexa2 Adapter ermöglicht.
            Theoretisch müsste das doch gehen oder?
            • DickenD Offline
              DickenD Offline
              Dicken
              #115
              Ich hab leider wenig Ahnung von Javascript aber hab mal was zusammen getragen:
              Alexa2 JSON (mit 3 Einträgen: Brot, Milch, Windeln):
              [{"completed":false,"createdDateTime":1720556300850,"customerId":"AQZSGMZJKPS56","id":"a199868f-16d2-463f-9b95-06c686f083ea","listId":"AQZSGMZJKPS56-SHOP","shoppingListItem":true,"updatedDateTime":1720556300850,"value":"Brot","version":1},{"completed":false,"createdDateTime":1720556251289,"customerId":"AQZSGMZJKPS56","id":"0a74e8a7-23b9-466a-9c77-265d9c6853ad","listId":"AQZSGMZJKPS56-SHOP","shoppingListItem":true,"updatedDateTime":1720556251289,"value":"Milch","version":1},
              {"completed":true,"createdDateTime":1679216676514,"customerId":"AQZSGMZJKPS56","id":"ecd1fe78-015b-44a3bfe2-5ef81f96fdc3","listId":"AQZSGMZJKPS56-SHOP","shoppingListItem":true,"updatedDateTime":1679307658738,"value":"Windeln","version":3}]
              Todist2 JSON (mit 3 Einträgen: Brot, Milch, Windeln):
              [{"Task":"Brot", "ID":"8192765247"},{"Task":"Milch", "ID":"8192765437"},{"Task":"Windeln", "ID":"8192765492"},{"Task":"no todo", "ID":"-"}]
              Nun kann man ja laut der Github Seite von iobroker.todoist2 Befehle über die API senden mit Hilfe von sendTo.
              Es wäre wirklich nett wenn sich das jemand mal ansehen könnte. Da sollte man doch ein Script schreiben können, welches die Listen miteinander synchronisiert oder?
              LG
              Dicken
              Ro75R 1 Antwort Letzte Antwort
              • DickenD Dicken
                LG
                Dicken
                Ro75R Offline
                Ro75R Offline
                Ro75
                #116
                @dicken wie ich dir im anderen Thread schon geschrieben und gezeigt habe, kannst du mit meinem Skript die Daten von Alexa in ein eigenes (z.B. JSON) transferieren. Mit ein wenig Anpassung kannst du auch die einzelnen Einträge (z.B. Brot, Milch, ...) anstatt in ein JSON eben via API wo anders hin transferieren lassen.
                ABER. Mit ToDoIst habe ich nichts mehr am Hut. Aber vielleicht kann jemand anderes helfen.
                Ro75.
                DickenD 1 Antwort Letzte Antwort
                • Ro75R Ro75
                  Ro75.
                  DickenD Offline
                  DickenD Offline
                  Dicken
                  schrieb am zuletzt editiert von Dicken
                  #117
                  @ro75 dein Script klappt ja auch super, nur ist das eben für bring. Und da es im Titel des anderen Threads um Bring geht, hab ich mal hier reingeschrieben. :)
                  Ich denke mir das man dein Script anpassen könnte nur kann ich das leider nicht :D
                  • DickenD Dicken
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    #118
                    @dicken sagte in Test Adapter todoist2 v0.9 Latest/GitHub:
                    ist es nicht. Ein Teil davon wird für das Bring-Skript genutzt. Das Skript sollte nur zeigen dass die Daten weiterhin kommen, da ja Bring, ToDoIst & Co. nicht mehr regulär via Alexa funktionieren und es ja auch darum ging, dass das mit dem Alexa-Adapter wohl auch nicht mehr gehen würde (Stichpunkt "Vermutung"). Aber wie gesagt, helfen kann uch nicht, da ich schon vor langer Zeit mit ToDoIst (aus diversen Gründen) abgeschlossen habe.
                    Ro75.
                    • Ro75R Ro75
                      Ro75.
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #119
                      Da dieses Topic lt. Titel den ADAPTER todoist2 betrifft bitte für allfällige Scripts ein getrenntes Topic aufmachen. Mit "Test Adapter todoist2" hat das Skript ja wohl nichts zu tun.
                      • mcm1957M mcm1957
                        Ro75R Offline
                        Ro75R Offline
                        Ro75
                        schrieb am zuletzt editiert von Ro75
                        #120
                        @mcm1957 hier ist auch kein Skript von mir! Ich hatte geschrieben "@dicken wie ich dir im anderen Thread schon geschrieben und gezeigt habe".
                        Ro75.
                        • Ro75R Ro75
                          Ro75.
                          DickenD Offline
                          DickenD Offline
                          Dicken
                          #121
                          Hört auf euch zu zanken, habs verstanden :D
                          • haselchenH Offline
                            haselchenH Offline
                            haselchen
                            #122
                            @mcm1957
                            Naja, naja....natürlich gehört zum Adaptertest auch das Zusammenspiel mit Skripten.
                            Also würde ich mich FÜR das Zeigen aussprechen.
                            Da er HTML , JSON und Text bereithält, denke ich, dass da Skripten wohl von Vorteil wäre ;)
                            • DickenD Dicken
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #123
                              @dicken
                              Hab das Einkaufslisten Problem nur am Rande mitbekommen.
                              Schau mal in die To Doist App.
                              Ich meine, da kann man 3rd Party Apps/Geräte einbinden.
                              Unter anderem Alexa?!
                                @mcm1957
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #124
                                @haselchen
                                Ok Wenn das so gemeint ist sorry u ich zieh alles zurück. Für mich hat es so ausgesehen dass das genannte Script ANSTELLE des Adapters verwendet werden kann. Wenn es MIT dem Adapter zu verwenden idt dann passt es natürlich zum Test.
                                Übrigends
                                Da der Adapter anscheinend verwaist ist könnte man / ich ihn in den nächsten Wochen ggF in den community Bereich schieben. Fragt sich nur ob es überhaupt Bedarf dafür gibt und ev Tester oder noch besser einen Maintainer.
                                  @dicken
                                  Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  #125
                                  @haselchen das ist richtig, nur musst du jetzt "Handstände" machen damit Daten von der Alexa in diese Liste kommen, geht nicht mehr so ohne weiteres.
                                  Ro75.
                                  • Ro75R Ro75
                                    Ro75.
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    #126
                                    @ro75
                                    Ja, aus der Thematik war ich raus.
                                    Ich hab die ToDoist App geöffnet, meine Sachen eingegeben und dann zuHause mit dem Adapter verbunden, damit es auf dem Tablet erscheint.
                                    Kleiner Zusatz, wenn meine Frau Einkaufsliste in Telegram eingibt, wird diese Liste abgerufen.
                                      @ro75
                                      DickenD Offline
                                      DickenD Offline
                                      Dicken
                                      #127
                                      @haselchen ja darum gehts ja, wie @Ro75 schon sagt, das wurde von alexa abgeschaltet und Ich suche jetzt nach einer alternativen Lösung.
                                      @mcm1957 genau, ich möchte den adapter nicht ersetzen, ich habe gehofft das man mit ihm eine lösung scripten kann.
                                      • DickenD Dicken
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        #128
                                        @dicken
                                        Ok
                                        Dann nochmal sorry für meinen falschen Einwurf.
                                        • mcm1957M mcm1957
                                          @dicken
                                          Ok
                                          DickenD Offline
                                          DickenD Offline
                                          Dicken
                                          #129
                                          @mcm1957 alles gut :) aber wie du schon sagtest, is der Adapter leider verwaist. Hatte gehofft das sich vllt jemand finden der auch gerne todoist benutzt und ein bisschen mehr ahnung von javascript hat als ich.
