  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.8k Aufrufe 45 Beobachtet
    @muckel
    Dann nimm die 11 Updates, die da in der Pipeline hängen auch noch mit.
    muckel
    schrieb am zuletzt editiert von muckel
    #417
    updates mitgenommen. leider kein erfolg. nach ca. 110 sekunden nach dem adapterstart:
    zigbee2mqtt.0
    2024-05-13 18:56:11.862	info	Zigbee2MQTT started!
    zigbee2mqtt.0
    2024-05-13 18:56:11.862	info	Started frontend on port 8890
    zigbee2mqtt.0
    2024-05-13 18:54:22.595	info	Zigbee2MQTT started!
    zigbee2mqtt.0
    2024-05-13 18:54:22.595	info	Started frontend on port 8890
    zigbee2mqtt.0
    2024-05-13 18:54:13.610	info	==================================================================================
    zigbee2mqtt.0
    2024-05-13 18:54:13.610	info	|| Network panid 6754 channel: 11 ext_pan_id: 0x00124b002e20cfcd
    zigbee2mqtt.0
    2024-05-13 18:54:13.610	info	|| Coordinator type: zStack3x0 Version: 20210708 Serial: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_709a16d9b08ded118da709f6b86ce6f8-if00-port0
    zigbee2mqtt.0
    2024-05-13 18:54:13.610	info	|| Zigbee2MQTT Version: 1.37.0
    zigbee2mqtt.0
    2024-05-13 18:54:13.610	info	============================ Zigbee2MQTT Information =============================
    zigbee2mqtt.0
    2024-05-13 18:54:13.575	info	Connect to Zigbee2MQTT over internal mqtt connection.
    zigbee2mqtt.0
    2024-05-13 18:54:12.008	info	Statring MQTT-Server on IP 0.0.0.0 and Port 8889
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	==================================================================================
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	|| Coordinator Check Cron : 0 3 * * *
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	|| Coordinator Check Loglevel: info
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	|| Use Automatic Coordinator Check: no
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	|| Use Simple Press/Release State: no
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	|| Use Simple Move/Stop State: no
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	|| Use Simple Hold/Release State: yes
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	|| Use Device Icons: yes
    zigbee2mqtt.0
    2024-05-13 18:54:11.956	info	|| Use Event In Desc: yes
    zigbee2mqtt.0
    2024-05-13 18:54:11.955	info	|| Use BrightnessStep OnOff: no
    zigbee2mqtt.0
    2024-05-13 18:54:11.955	info	|| Use BrightnessMove OnOff: no
    zigbee2mqtt.0
    2024-05-13 18:54:11.955	info	|| Use ColorTemperature ColorSync: no
    zigbee2mqtt.0
    2024-05-13 18:54:11.955	info	|| Use Kelvin: no
    zigbee2mqtt.0
    2024-05-13 18:54:11.955	info	|| Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
    zigbee2mqtt.0
    2024-05-13 18:54:11.955	info	|| Zigbee2MQTT Debug Log: deactivated
    zigbee2mqtt.0
    2024-05-13 18:54:11.955	info	|| Zigbee2MQTT Internal MQTT Port: 8889
    zigbee2mqtt.0
    2024-05-13 18:54:11.954	info	|| Zigbee2MQTT Internal MQTT IP-Bind: 0.0.0.0
    zigbee2mqtt.0
    2024-05-13 18:54:11.954	info	|| Zigbee2MQTT Connection Type: intmqtt
    zigbee2mqtt.0
    2024-05-13 18:54:11.954	info	|| Zigbee2MQTT Frontend Port: 8890
    zigbee2mqtt.0
    2024-05-13 18:54:11.954	info	|| Zigbee2MQTT Frontend Server: 192.168.0.230
    zigbee2mqtt.0
    2024-05-13 18:54:11.954	info	|| Zigbee2MQTT Frontend Scheme: http
    zigbee2mqtt.0
    2024-05-13 18:54:11.953	info	================================= Adapter Config =================================
    zigbee2mqtt.0
    2024-05-13 18:54:11.944	info	starting. Version 2.13.6 in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v18.20.2, js-controller: 5.0.19
    Ich muss jetzt auf ein paar stunden weg, darf ich dich morgen nochmals belästigen?
    lg. erich
    • M muckel
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      zigbee2mqtt.0
      lg. erich
      BananaJoeB Offline
      BananaJoeB Offline
      BananaJoe
      #418
      @muckel ich sehe so erst einmal keine Fehler in dem Log? Oder übersehe ich etwas?
      • M muckel
        @idlebit
        Ich möchte auf zigbee2mqtt umstellen. Ich habe auch ein paar Testgeräte angelernt.
        Funktioniert so weit so gut.
        Allerdings kommt im Logfile alle ca 110 Sekunden folgendes: (Zigbee2MQTT startet)
        Der Adapter wird orange und nach ein paar Sekunden wieder grün.
        zigbee2mqtt.0
        2024-05-12 08:26:23.774	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:26:23.774	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:24:33.235	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:24:33.234	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:22:43.751	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:22:43.751	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:20:53.851	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:20:53.851	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:19:04.615	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:19:04.615	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:17:14.552	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:17:14.552	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:15:24.261	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:15:24.261	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:13:34.628	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:13:34.628	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:11:44.355	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:11:44.355	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:09:54.459	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:09:54.459	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:08:05.353	info	Zigbee2MQTT started!
        zigbee2mqtt.0
        2024-05-12 08:08:05.352	info	Started frontend on port 8890
        zigbee2mqtt.0
        2024-05-12 08:07:47.699	info	==================================================================================
        zigbee2mqtt.0
        2024-05-12 08:07:47.699	info	|| Network panid 6754 channel: 11 ext_pan_id: 0x00124b002e20cfcd
        zigbee2mqtt.0
        2024-05-12 08:07:47.699	info	|| Coordinator type: zStack3x0 Version: 20210708 Serial: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_709a16d9b08ded118da709f6b86ce6f8-if00-port0
        zigbee2mqtt.0
        2024-05-12 08:07:47.699	info	|| Zigbee2MQTT Version: 1.37.0
        zigbee2mqtt.0
        2024-05-12 08:07:47.698	info	============================ Zigbee2MQTT Information =============================
        zigbee2mqtt.0
        2024-05-12 08:07:47.670	info	Connect to Zigbee2MQTT over internal mqtt connection.
        zigbee2mqtt.0
        2024-05-12 08:07:46.096	info	Statring MQTT-Server on IP 0.0.0.0 and Port 8889
        zigbee2mqtt.0
        2024-05-12 08:07:46.047	info	==================================================================================
        zigbee2mqtt.0
        2024-05-12 08:07:46.047	info	|| Coordinator Check Cron : 0 3 * * *
        zigbee2mqtt.0
        2024-05-12 08:07:46.047	info	|| Coordinator Check Loglevel: info
        zigbee2mqtt.0
        2024-05-12 08:07:46.047	info	|| Use Automatic Coordinator Check: no
        zigbee2mqtt.0
        2024-05-12 08:07:46.047	info	|| Use Simple Press/Release State: no
        zigbee2mqtt.0
        2024-05-12 08:07:46.047	info	|| Use Simple Move/Stop State: no
        zigbee2mqtt.0
        2024-05-12 08:07:46.047	info	|| Use Simple Hold/Release State: yes
        zigbee2mqtt.0
        2024-05-12 08:07:46.046	info	|| Use Device Icons: yes
        zigbee2mqtt.0
        2024-05-12 08:07:46.046	info	|| Use Event In Desc: yes
        zigbee2mqtt.0
        2024-05-12 08:07:46.046	info	|| Use BrightnessStep OnOff: no
        zigbee2mqtt.0
        2024-05-12 08:07:46.046	info	|| Use BrightnessMove OnOff: no
        zigbee2mqtt.0
        2024-05-12 08:07:46.046	info	|| Use ColorTemperature ColorSync: no
        zigbee2mqtt.0
        2024-05-12 08:07:46.045	info	|| Use Kelvin: no
        zigbee2mqtt.0
        2024-05-12 08:07:46.045	info	|| Proxy Zigbee2MQTT Logs to ioBroker Logs: activated
        zigbee2mqtt.0
        2024-05-12 08:07:46.045	info	|| Zigbee2MQTT Debug Log: deactivated
        zigbee2mqtt.0
        2024-05-12 08:07:46.045	info	|| Zigbee2MQTT Internal MQTT Port: 8889
        zigbee2mqtt.0
        2024-05-12 08:07:46.045	info	|| Zigbee2MQTT Internal MQTT IP-Bind: 0.0.0.0
        zigbee2mqtt.0
        2024-05-12 08:07:46.044	info	|| Zigbee2MQTT Connection Type: intmqtt
        zigbee2mqtt.0
        2024-05-12 08:07:46.044	info	|| Zigbee2MQTT Frontend Port: 8890
        zigbee2mqtt.0
        2024-05-12 08:07:46.044	info	|| Zigbee2MQTT Frontend Server: 192.168.0.230
        zigbee2mqtt.0
        2024-05-12 08:07:46.043	info	|| Zigbee2MQTT Frontend Scheme: http
        zigbee2mqtt.0
        2024-05-12 08:07:46.043	info	================================= Adapter Config =================================
        zigbee2mqtt.0
        2024-05-12 08:07:46.031	info	starting. Version 2.13.6 in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v18.20.2, js-controller: 5.0.19
        Kannst du mir zum log kurz eine Antwort geben? Config Einstellungen, welche das bewirken könnten etc.
        Danke im Voraus
        arteckA Offline
        arteckA Offline
        arteck
        #419
        @muckel so ich habs..da scheint zigbee2mqtt ein fehler zu haben
        das ist die trennung vom mqtt server..hab ich bei mir auch im Log
        guckmal ob der bei dir an ist
        wenn ja mach den mal aus
        oder
        in der config von zigbee2mqtt
        https://www.zigbee2mqtt.io/guide/configuration/mqtt.html#server-connection
        setz unter mqtt
        keepalive: 90
        oder
        lass alles wie es ist.. wird bestimmt mit neuer version behoben
        M B 2 Antworten Letzte Antwort
        • arteckA arteck
          oder
          setz unter mqtt
          keepalive: 90
          oder
          muckel
          #420
          @arteck
          Danke für den Tip. Das wars anscheinend.
          Derzeit läuft es schon 5 Minuten ohne restart.
          • arteckA arteck
            oder
            setz unter mqtt
            keepalive: 90
            oder
            biker1602
            schrieb am zuletzt editiert von biker1602
            #421
            @arteck Eine kurze Frage! ich habe heute auch mal einen Versuch gewagt mit einen zweiten Coordinator SLZB-06 mit dem mqtt2 Adapter über meinen iobroker Geräte anzulernen was auch funktioniert.
            Was mich stutzig macht ist das unter Objekte ein Angelernter Button zu sehen ist und auch funktioniert das Antennensignal aber Gelb und durchgstrichen ist.
            Woran kann das liegen?
            Gleich noch eine Frage hinterher was mir gerade aufgefallen ist.
            Ich habe einen Philips Bewegungsmelder der schon lange im iOBroker unter dem normalen Zigbee Adapter läuft aber der hat sich ohne das ich ihn angelernt habe auch mit dem neuen verbunden. Ich dachte die Geräte kommunizieren nur mit einem Adapter?
            MartinPM BananaJoeB crunchipC 3 Antworten Letzte Antwort
            • B biker1602
              MartinPM Offline
              MartinPM Offline
              MartinP
              #422
              @biker1602 In einem Zigbee Netz DARF es meines Wissens nach nur einen Coordinator geben: Hast Du ein zweites Netz auf einem anderen Kanal aufgemacht?
              • MartinPM MartinP
                biker1602
                #423
                @martinp said in Test Adapter zigbee2mqtt:
                Ja ich habe ja sonst den normalen Zigbee Adapter mit einem Sonoff USB Dongle betrieben den ich über USB bei Proxmox durgeschliffen habe.
                Der andere läuft ja über Netzwerk
                • B biker1602
                  MartinPM Offline
                  MartinPM Offline
                  MartinP
                  #424
                  @biker1602 Sind die denn nun parallel in Betrieb?
                  Wenn ja, unterschiedliche Kanäle?
                  • B biker1602
                    BananaJoeB Offline
                    BananaJoeB Offline
                    BananaJoe
                    #425
                    @biker1602 @MartinP gemeint ist sicherlich das das 2. ZigBee-Netz Idealweise auf einem anderen Kanal, auf jeden Fall aber mit eigener PAN-Id / Extended PAN-Id läuft
                    • MartinPM MartinP
                      biker1602
                      #426
                      @martinp Ja sie laufen parallel im gleichen Netzwerk vom Zigbee Adapter ist es Kanal 11 und der andere ist ja über LAN angeschlossen der hat keinen Kanal
                      • B biker1602
                        BananaJoeB Offline
                        BananaJoeB Offline
                        BananaJoe
                        #427
                        @biker1602 ZigBee-Kanal! ungleich WLAN Kanal. Beide ZigBee Koordinatoren sollten unterschiedliche Kanäle habe, auf jeden Fall unterschiedliche PAN-Ids
                        • BananaJoeB BananaJoe
                          biker1602
                          #428
                          @bananajoe said in Test Adapter zigbee2mqtt:
                          der Zigbee2mqtt Adapter hat keine PAN-ID oder ich weiß nicht wo sie steht.
                          • B biker1602
                            MartinPM Offline
                            MartinPM Offline
                            MartinP
                            #429
                            @biker1602 Da musst Du schon im Web-Interface Deines Zigbee2Mqtt Servers schauen ..
                            EDIT
                            Du betreibst ja einen SLZB-06
                            https://smlight.tech/manual/slzb-06/guide/configuration/
                            • B biker1602
                              crunchipC Offline
                              crunchipC Offline
                              #430
                              @biker1602 sagte in Test Adapter zigbee2mqtt:
                              Hast du auch dies hinterlegt?
                              availability: true
                                availability: true
                                biker1602
                                #431
                                @crunchip said in Test Adapter zigbee2mqtt:
                                availability: true
                                Muss das in die Config von mqtt und wenn ja ist es egal an welcher Stelle?
                                • B biker1602
                                  availability: true
                                  MartinPM Offline
                                  MartinPM Offline
                                  MartinP
                                  #432
                                  @biker1602 Ich kenne diese Hardware zugegebenerweise nicht...
                                  In order to properly use SLZB-06 you need to have an instance of Home Assistant and Zigbee2MQTT
                                  Zigbee2MQTT ist eine Server-Anwendung, die Geräte aus einem Zigbee Netzwerk nach MQTT mappt. https://www.zigbee2mqtt.io/
                                  "zigbee2mqtt" ist ein spezieller iobroker Adapter, den man verwenden kann, um einen Zigbee2MQTT Server anzusteuern...
                                  Ein Zigbee2MQTT Server unterstützt diverse Hardware, USB Sticks und Netzwerk-Zigbee Gateways
                                  Meines Verständnisses nach ist die Kette zwischen Iobroker und diesem Device
                                  iobroker->(zigbee2mqtt adapter oder mqtt client/broker) -> Zigbee2MQTT Server -> SLZB-06...
                                  Im Zigbee2MQTT Server kann man dann Konfigurationen bzgl Zigbee Kanal usw vornehmen...
                                  Sei gewarnt: Falls Du beide Zigbee-Koordinatoren weiter betreiben willst, musst Du Dich meines Wissens für jedes Gerät entscheiden, in welches Netz zu es pairen willst. Ein Gerät kann meines Wissens nicht in zwei Netzen gleichzeitig präsent sein.
                                  EDIT:
                                  Der SLZB-06 kann wohl als Zigbee-Koordinator im iobroker Zigbee Adapter eingetragen werden...
                                  Sollte er als zweiter Koordinator laufen, wäre also Anlegen einer zweiten Zigbee Adapter Instanz die einfachste Lösung.
                                  Sollte der USB-basierte Koordinator in Rente geschickt werden, muss lediglich die vorhandene Zigbee Adapter Instanz umkonfiguriert werden.
                                  Grundsätzlich kann alles beim Alten bleiben. Ob die Geräte ihre Pairung verlieren .. darüber möchte ich keine Prognosen stellen ...
                                    availability: true
                                    biker1602
                                    #433
                                    availability: true
                                    Nachdem ich das in der Config des zigbeemqtt2 hinterlegt habe, wurden beide grün.
                                    Jetzt laufen auch beide parallel.
                                    • MartinPM Offline
                                      MartinPM Offline
                                      MartinP
                                      #434
                                      Ich bin etwas sprachlos. Hast Du die IP-Adresse des SLZB-06 im Zigbee2mqtt Adapter eingetragen?
                                      Dann müsste der SLZB-06 ja selber eine Art zigbee2MQTT Server Emulation bieten...
                                      BananaJoeB B 2 Antworten Letzte Antwort
                                      • MartinPM MartinP
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        #435
                                        @martinp sagte in Test Adapter zigbee2mqtt:
                                        ok, ok, jetzt habe ich begriffen was du meinst. Im "zigbee-adapter" funktioniert das, im "zigbee2mqtt" Adapter dürfte das nicht gehen
                                        öhm, Seriell über TCP/IP ? Bei ähnlichen Geräten oder auch bei meinem ZigBee-LAN-Gateway (was ich allerdings mit dem zigbee-Adapter betreibe) gibt man statt des lokalen Gerätes (ist USB, stellt sich ja aber als serielles gerät dar) auch einfach die IP ein:
                                        Je nachdem wie "schlau" Zigbee2MQTT ist denkt der sich den Rest dazu. Aber einen genauen Screenshot davon wurde uns ja nicht gezeigt
                                        • MartinPM MartinP
                                          biker1602
                                          #436
                                          Da war ich wohl etwas voreiöig und frohen Mutes aber es geht wirklich nur einer und bei der Gelegenheit habe ich jetzt mehr zerschossen als ich wollte.
                                          Ich hatte nach ein schlaflosen Nacht heute Morgen gedacht ich mache es nochmal nei auch die Installation von zigbeemqtt2 und lasse dann nur den laufen und den normalen Zigbee Adapter lasse ich dann weg und mache alles über Zigbee2mqtt. Ich glaube aber das ich mir den zerschossen habe da ich ihn nochmal neu unter installieren wollte und ich habe ihn versucht zu deinstallieren. Das ging aber richtig schief denn ich habe dann den kompletten Ordner von zigbee2mqtt in WinSCP gelöscht und gedacht das ich alles weg habe aber es ist irgenwo immer noch etwas versteckt und läßt mich jetzt zum verzweifeln bringen da ich es nicht mehr richtig nur mit Fehlermeldungen installieren kann. Hat jemand einen Plan wie ich das mit Putty alles löschen kann?
                                          AsgothianA MartinPM 2 Antworten Letzte Antwort
