  4. Beim Update einiger Adapter- "admin" not found
23 Beiträge 4 Kommentatoren 2.7k Aufrufe 3 Beobachtet
  • L line
    @thomas-braun Danke für deine Hilfe!
    Skript v.2024-05-22
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     08:22:32 up 20:51,  2 users,  load average: 0.56, 0.22, 0.38
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    *** Time and Time Zones ***
                   Local time: Wed 2024-07-10 08:22:32 CEST
               Universal time: Wed 2024-07-10 06:22:32 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    feline
    XDG_CONFIG_HOME=/home/feline2/.config
    HOME=/home/feline
    GROUPS=feline adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** Display-Server-Setup ***
    Display-Server: true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            7.8G        2.0G        2.1G         47M        3.7G        5.6G
    Swap:            99M          0B         99M
    Total:          7.9G        2.0G        2.2G
    Active iob-Instances: 	8
             7812 M total memory
             1960 M used memory
             2581 M active memory
             2370 M inactive memory
             2121 M free memory
              319 M buffer memory
             3410 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 08:22:32 up 20:51,  2 users,  load average: 0.56, 0.22, 0.38
    Tasks: 248 total,   1 running, 247 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  6.8 us,  4.1 sy,  0.0 ni, 89.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7812.3 total,   2121.7 free,   1960.2 used,   3730.3 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   5635.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   25G  3.2G  89% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G   18M  1.6G   2% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     782M   28K  782M   1% /run/user/1000
    tmpfs          tmpfs     782M   28K  782M   1% /run/user/1002
    [Tue Jul  9 11:30:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:38:62:0F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b4c0fa64-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Tue Jul  9 11:31:00 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Tue Jul  9 11:31:00 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Tue Jul  9 11:31:01 2024] EXT4-fs (mmcblk0p2): recovery complete
    [Tue Jul  9 11:31:01 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Jul  9 11:31:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Jul  9 11:31:03 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET                            SOURCE         FSTYPE            OPTIONS
    /                                 /dev/mmcblk0p2 ext4              rw,noatime
    |-/dev                            devtmpfs       devtmpfs          rw,relatime,size=3735680k,nr_inodes=933920,mode=755
    | |-/dev/shm                      tmpfs          tmpfs             rw,nosuid,nodev
    | |-/dev/pts                      devpts         devpts            rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | `-/dev/mqueue                   mqueue         mqueue            rw,nosuid,nodev,noexec,relatime
    |-/proc                           proc           proc              rw,relatime
    | `-/proc/sys/fs/binfmt_misc      systemd-1      autofs            rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |   `-/proc/sys/fs/binfmt_misc    binfmt_misc    binfmt_misc       rw,nosuid,nodev,noexec,relatime
    |-/sys                            sysfs          sysfs             rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security          securityfs     securityfs        rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                cgroup2        cgroup2           rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                pstore         pstore            rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                   bpf            bpf               rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug             debugfs        debugfs           rw,nosuid,nodev,noexec,relatime
    | | `-/sys/kernel/debug/tracing   tracefs        tracefs           rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing           tracefs        tracefs           rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections      fusectl        fusectl           rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config            configfs       configfs          rw,nosuid,nodev,noexec,relatime
    |-/run                            tmpfs          tmpfs             rw,nosuid,nodev,size=1599964k,nr_inodes=819200,mode=755
    | |-/run/lock                     tmpfs          tmpfs             rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs               sunrpc         rpc_pipefs        rw,relatime
    | |-/run/user/1000                tmpfs          tmpfs             rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1000,gid=1000
    | | `-/run/user/1000/gvfs         gvfsd-fuse     fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    | `-/run/user/1002                tmpfs          tmpfs             rw,nosuid,nodev,relatime,size=799980k,nr_inodes=199995,mode=700,uid=1002,gid=1002
    |   `-/run/user/1002/gvfs         gvfsd-fuse     fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1002,group_id=1002
    |-/boot                           /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/home/feline2/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1002,group_id=1002
    /var:
    15G	/var/lib
    15G	/var/
    14G	/var/lib/influxdb/.influxdbv2/engine/data/e0d96cc0acf064a1/autogen
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    246M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    582M	/opt/iobroker/iobroker-data/
    485M	/opt/iobroker/iobroker-data/files
    138M	/opt/iobroker/iobroker-data/files/javascript.admin
    118M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    117M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    26M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.20.3
    /usr/bin/node 		v18.20.3
    /usr/bin/npm 		10.7.0
    /usr/bin/npx 		10.7.0
    /usr/bin/corepack 	0.28.0
    nodejs:
      Installed: 18.20.3-1nodesource1
      Candidate: 18.20.4-1nodesource1
      Version table:
         18.20.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
     *** 18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.19
    admin: 		"admin" not found
    javascript: 	8.3.1
    nodejs modules from github: 	6
    +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#56a18d0b76c2acd8e180936cfb01cb63962fbc48)
    +-- iobroker.openligadb@1.3.4 (git+ssh://git@github.com/oweitman/ioBroker.openligadb.git#00633f9e8372a8e9304938f67f0efaed6bb553e8)
    +-- iobroker.tesla-motors@1.4.5 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.tesla-motors.git#6c5dd71e896fbd8ff65fb015df0ed182f980871f)
    +-- iobroker.vis-material-webfont@0.0.3 (git+ssh://git@github.com/om2804/ioBroker.vis-material-webfont.git#c65fcdf49533dc28d70ae074035b6a260e323401)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    +-- my-muell-ical@0.1.0 (git+ssh://git@github.com/benzman81/my-muell-ical.git#1c13794503ead416b1b5739222214e9cfbdc262b)
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
      system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi                              - disabled, compact disabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
      system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled, compact disabled
      system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled, compact disabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled, compact disabled
      system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled, compact disabled
    + system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, compact disabled, port: 7070
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled, compact disabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled, compact disabled
      system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
      system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled, compact disabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, compact disabled, port: 8086
      system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled, compact disabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
      system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled, compact disabled
      system.adapter.mediola-gateway.0        : mediola-gateway       : raspberrypi                              -  enabled, compact disabled
      system.adapter.meross.0                 : meross                : raspberrypi                              - disabled, compact disabled
      system.adapter.modbus.0                 : modbus                : raspberrypi                              - disabled, compact disabled
      system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, compact disabled, port: 1883
      system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              - disabled, compact disabled
      system.adapter.nuki.0                   : nuki                  : raspberrypi                              - disabled, compact disabled
      system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled, compact disabled
      system.adapter.parser.0                 : parser                : raspberrypi                              - disabled, compact disabled
      system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi                              -  enabled, compact disabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled, compact disabled
      system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled, compact disabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 192.168.178.69
      system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.solaredge.0              : solaredge             : raspberrypi                              -  enabled, compact disabled
      system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled, compact disabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled, compact disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled, compact disabled
      system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              - disabled, compact disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled, compact disabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled, compact disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "bshb"         : 0.2.8    , installed 0.2.8
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "denon"        : 1.15.5   , installed 1.15.5
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
    Adapter    "homekit-controller": 0.5.10, installed 0.5.10
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.3.1    , installed 8.3.1
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
    Adapter    "mediola-gateway": 1.1.0  , installed 1.1.0
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
    Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "nuki"         : 2.0.0    , installed 1.6.0  [Updatable]
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "openligadb"   : 1.4.9    , installed 1.3.4  [Updatable]
    Adapter    "parser"       : 2.1.0    , installed 2.1.0
    Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "scenes"       : 3.0.4    , installed 3.0.4
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
    Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
    Adapter    "solarviewdatareader": 1.0.8, installed 1.0.8
    Adapter    "tesla-motors" : 1.3.2    , installed 1.4.5
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects: 	15543
    States: 	13105
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Get:7 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
    Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
    Fetched 5127 B in 2s (2646 B/s)
    Reading package lists...
    Pending Updates: 22
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          163245     9196/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       207549     12963/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       207545     12963/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15493      601/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:41339         0.0.0.0:*               LISTEN      1001       207863     13139/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15495      601/sshd: /usr/sbin
    tcp6       0      0 :::4712                 :::*                    LISTEN      116        22148      2788/evcc
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12594      581/xrdp-sesman
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          163244     9196/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      120        17854      995/grafana
    tcp6       0      0 :::7070                 :::*                    LISTEN      116        23214      2788/evcc
    tcp6       0      0 :::39491                :::*                    LISTEN      1001       206848     13139/io.yahka.0
    tcp6       0      0 :::3389                 :::*                    LISTEN      117        12709      619/xrdp
    tcp6       0      0 :::8086                 :::*                    LISTEN      119        14974      561/influxd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15692      486/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          162369     9198/cups-browsed
    udp        0      0 0.0.0.0:41691           0.0.0.0:*                           108        16508      409/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        158069     2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        157308     2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        155735     2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        154975     2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        153173     2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        153121     2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        23211      2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        24066      2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        23199      2788/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16506      409/avahi-daemon: r
    udp6       0      0 :::49286                :::*                                108        16509      409/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                116        158070     2788/evcc
    udp6       0      0 :::5353                 :::*                                116        157309     2788/evcc
    udp6       0      0 :::5353                 :::*                                116        155736     2788/evcc
    udp6       0      0 :::5353                 :::*                                116        154976     2788/evcc
    udp6       0      0 :::5353                 :::*                                116        153174     2788/evcc
    udp6       0      0 :::5353                 :::*                                116        153122     2788/evcc
    udp6       0      0 :::5353                 :::*                                116        23212      2788/evcc
    udp6       0      0 :::5353                 :::*                                116        24067      2788/evcc
    udp6       0      0 :::5353                 :::*                                116        23200      2788/evcc
    udp6       0      0 :::5353                 :::*                                108        16507      409/avahi-daemon: r
    2024-07-10 08:05:27.185  - info: pollenflug.0 (13124) Next DWD pollen request starts on Wed Jul 10 2024 11:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
    2024-07-10 08:05:30.469  - info: host.raspberrypi instance system.adapter.yahka.0 started with pid 13139
    2024-07-10 08:05:33.228  - info: yahka.0 (13139) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yahka, node: v18.20.3, js-controller: 5.0.19
    2024-07-10 08:05:33.256  - info: yahka.0 (13139) adapter ready, checking config
    2024-07-10 08:05:33.271  - info: yahka.0 (13139) adding Büro Licht with UUID: 68404733-0ee7-4d39-8189-b8a42e2bb7ec
    2024-07-10 08:05:33.282  - info: yahka.0 (13139) adding Wohnzimmer Licht 1 with UUID: 34598146-1bec-4fe8-99f7-07b0fb0b37f9
    2024-07-10 08:05:33.287  - info: yahka.0 (13139) adding Wohnzimmer Licht 2 with UUID: c5dcfd1c-c7ab-4d65-8c8e-f000a9c98d82
    2024-07-10 08:05:33.291  - info: yahka.0 (13139) adding Markise with UUID: 3f32008f-6511-41be-8743-21d5efe935fd
    2024-07-10 08:05:33.301  - info: yahka.0 (13139) adding Küche Licht with UUID: 3ef44851-a815-4b48-968f-97a3c392c47d
    2024-07-10 08:05:33.304  - info: yahka.0 (13139) adding Bad Licht with UUID: ea9bbccf-39c1-4b21-a31d-d205af9f4440
    2024-07-10 08:05:33.306  - info: yahka.0 (13139) adding Galerie Licht with UUID: 6f9d3f0e-2096-4950-ac9c-6afcd62e984d
    2024-07-10 08:05:33.310  - info: yahka.0 (13139) adding Windfang Licht with UUID: 954b6670-6f54-42a2-bb47-726a8b64bfeb
    2024-07-10 08:05:33.315  - info: yahka.0 (13139) adding Schlafzimmer Licht 1 with UUID: cb37b8d7-10bf-4c95-a3cc-bfffbc6e4221
    2024-07-10 08:05:33.318  - info: yahka.0 (13139) adding Schlafzimmer Licht 2 with UUID: 1123330b-5285-487a-9e4a-5aaaca340db3
    2024-07-10 08:05:33.321  - info: yahka.0 (13139) adding Rolladen Küche  with UUID: 5e737590-77b1-4181-98cb-0f6d79b06fb3
    2024-07-10 08:05:33.324  - info: yahka.0 (13139) publishing bridge Iobroker - Live on 0.0.0.0 using avahi
    2024-07-10 08:05:34.437  - error: host.raspberrypi startInstance system.adapter.socketio.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found!
    2024-07-10 08:05:35.912  - info: alexa2.0 (13022) No smart home devices to query
    2024-07-10 08:05:37.194  - info: alexa2.0 (13022) Subscribing to states...
    2024-07-10 08:05:37.200  - info: alexa2.0 (13022) Deleting the following states: ["Smart-Home-Devices.2f763737-569c-4008-b109-79b2363d7a47","Smart-Home-Devices.1a46aae3-b91c-4211-89be-c5e8ea1cc1da","Smart-Home-Devices.7dc85b35-5900-4d33-9f94-8d8bc238d0a0","Smart-Home-Devices.09fa72bf-5cab-4a8a-864b-b088d463210a","Smart-Home-Devices.d1374188-082d-43c5-8689-32157b891940","Smart-Home-Devices.970f2185-5703-4761-bee1-3893200accbd","Smart-Home-Devices.9a96aea3-e363-498e-b201-0c5660d5ae1b","Smart-Home-Devices.a3176fae-c621-403d-8ef2-16022ffe3a08","Smart-Home-Devices.520a4696-d44a-42e5-9fb2-3a81ca2e40b3","Smart-Home-Devices.4260cf44-a432-4128-8707-9c9e7f1b946b","Smart-Home-Devices.a85f9f49-1f87-43df-a8cc-6f1f1337b6cb","Smart-Home-Devices.f6dac303-2a9e-475b-bb07-791659cf1a60","Smart-Home-Devices.280152a5-8875-4ad6-9926-d4b4b13a6399","Smart-Home-Devices.368b8eb9-330c-429a-bd24-b0b09443a129","Smart-Home-Devices.7892fc70-1b6e-4064-92ce-d142b3067c31","Smart-Home-Devices.5b280ae1-2c0b-4220-9103-5b33f4d127f1","Smart-Home-Devices.d2c977ec-7351-48b1-9dad-e9c3975b00b1","Smart-Home-Devices.ed6340f3-7f8a-4d67-831c-5656eaa77dc3","Smart-Home-Devices.8e78557d-6e62-41dd-b4b5-c2f780df0ee9","Smart-Home-Devices.1fc6018a-b1d7-40b3-a617-285c8d6e2283","Smart-Home-Devices.db7e0160-3c50-4d4b-9984-099d005e1688","Smart-Home-Devices.5026dceb-fc58-4864-a4e3-6a0e9ff15196","Smart-Home-Devices.a3d41f72-31bb-46ba-85f6-aa4f54116e81","Smart-Home-Devices.615d0048-f21b-4e8f-abbf-dbfd5f36bd01","Smart-Home-Devices.2ec50d66-7e03-4a6c-b5c5-a212210913de","Smart-Home-Devices.7c7c03d2-b345-4323-9239-cf2ae0bba6a0","Smart-Home-Devices.1c040b05-b900-4afd-a9e0-853b8860272d","Smart-Home-Devices.9e5e167d-e909-44ac-856d-4a2d0817d7a1","Smart-Home-Devices.2adec7a5-a7f7-4219-ba23-8d882cae047e","Smart-Home-Devices.5bf09712-9005-43e0-9112-94fbe9cf4fac","Smart-Home-Devices.533fde82-3ef9-459e-8a70-1c9d233d8d1f","Smart-Home-Devices.8356cd6d-f6be-41a8-afdc-177c8e17e830","Smart-Home-Devices.7955c6a0-db1f-4b9c-b283-818e20c89a1a","Smart-Home-Devices.6a07a0b7-63f7-41b3-91df-276011cd1591","Smart-Home-Devices.39677e96-b0c2-4779-a65b-a01383b8b42b","Smart-Home-Devices.97576182-7eb7-45cb-81f8-c73d8d900a02","Smart-Home-Devices.e0fe5f03-a63c-4bf4-97be-d28133927458","Smart-Home-Devices.5a783a80-cbfc-4f70-8607-8d8aafa6220c","Smart-Home-Devices.71858f82-bcd3-48d6-b0ef-7e456bdbcefb","Smart-Home-Devices.0365ecdd-d81d-4d61-b26b-86f081ea6cc4","Smart-Home-Devices.45ce1797-01d2-4fb0-8e5f-e69c717c24af","Smart-Home-Devices.a4fa06cb-7dab-4c03-8579-ad7d87fbc401","Smart-Home-Devices.09e95f3f-7641-471f-9042-c79d65bf4a67","Smart-Home-Devices.4face9a3-2e45-43dd-9579-9e3c5c9dab8f","Smart-Home-Devices.9030b7cd-3111-4558-a9ca-6ca80b79c3bb","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05","Smart-Home-Devices.71f9b8c6-2663-4a2e-8a3f-39b324778492","Smart-Home-Devices.822fad25-ad22-4689-ae8c-a2816e410e1e","Smart-Home-Devices.9941a8a6-fd8e-4362-8e02-529cd89eb638","Smart-Home-Devices.34a9c988-29b1-4e4b-8a1a-410a9358cc0b","Smart-Home-Devices.9f3865b9-a5df-4263-ae11-a3f157969e69","Smart-Home-Devices.8e14c4ff-818c-478e-9d54-3f68f6b791ed","Smart-Home-Devices.78982010-2664-49d6-8fc1-b2bb17d6b7d9","Smart-Home-Devices.834b909a-a576-427d-bc80-862d3b3e3ad9","Smart-Home-Devices.2f763737-569c-4008-b109-79b2363d7a47.#enabled","Smart-Home-Devices.2f763737-569c-4008-b109-79b2363d7a47.#delete","Smart-Home-Devices.2f763737-569c-4008-b109-79b2363d7a47.powerState","Smart-Home-Devices.2f763737-569c-4008-b109-79b2363d7a47.connectivity","Smart-Home-Devices.2f763737-569c-4008-b109-79b2363d7a47.connectivity-reason","Smart-Home-Devices.2f763737-569c-4008-b109-79b2363d7a47.#query","Smart-Home-Devices.2f763737-569c-4008-b109-79b2363d7a47.#includeInAllQuery","Smart-Home-Devices.1a46aae3-b91c-4211-89be-c5e8ea1cc1da.#enabled","Smart-Home-Devices.1a46aae3-b91c-4211-89be-c5e8ea1cc1da.#delete","Smart-Home-Devices.1a46aae3-b91c-4211-89be-c5e8ea1cc1da.powerState","Smart-Home-Devices.1a46aae3-b91c-4211-89be-c5e8ea1cc1da.connectivity","Smart-Home-Devices.1a46aae3-b91c-4211-89be-c5e8ea1cc1da.connectivity-reason","Smart-Home-Devices.1a46aae3-b91c-4211-89be-c5e8ea1cc1da.#query","Smart-Home-Devices.1a46aae3-b91c-4211-89be-c5e8ea1cc1da.#includeInAllQuery","Smart-Home-Devices.7dc85b35-5900-4d33-9f94-8d8bc238d0a0.#enabled","Smart-Home-Devices.7dc85b35-5900-4d33-9f94-8d8bc238d0a0.#delete","Smart-Home-Devices.7dc85b35-5900-4d33-9f94-8d8bc238d0a0.powerState","Smart-Home-Devices.7dc85b35-5900-4d33-9f94-8d8bc238d0a0.percentage","Smart-Home-Devices.09fa72bf-5cab-4a8a-864b-b088d463210a.#enabled","Smart-Home-Devices.09fa72bf-5cab-4a8a-864b-b088d463210a.#delete","Smart-Home-Devices.09fa72bf-5cab-4a8a-864b-b088d463210a.powerState","Smart-Home-Devices.09fa72bf-5cab-4a8a-864b-b088d463210a.percentage","Smart-Home-Devices.d1374188-082d-43c5-8689-32157b891940.#enabled","Smart-Home-Devices.d1374188-082d-43c5-8689-32157b891940.#delete","Smart-Home-Devices.d1374188-082d-43c5-8689-32157b891940.powerState","Smart-Home-Devices.d1374188-082d-43c5-8689-32157b891940.percentage","Smart-Home-Devices.970f2185-5703-4761-bee1-3893200accbd.#enabled","Smart-Home-Devices.970f2185-5703-4761-bee1-3893200accbd.#delete","Smart-Home-Devices.970f2185-5703-4761-bee1-3893200accbd.percentage","Smart-Home-Devices.9a96aea3-e363-498e-b201-0c5660d5ae1b.#enabled","Smart-Home-Devices.9a96aea3-e363-498e-b201-0c5660d5ae1b.#delete","Smart-Home-Devices.9a96aea3-e363-498e-b201-0c5660d5ae1b.powerState","Smart-Home-Devices.9a96aea3-e363-498e-b201-0c5660d5ae1b.percentage","Smart-Home-Devices.a3176fae-c621-403d-8ef2-16022ffe3a08.#enabled","Smart-Home-Devices.a3176fae-c621-403d-8ef2-16022ffe3a08.#delete","Smart-Home-Devices.a3176fae-c621-403d-8ef2-16022ffe3a08.powerState","Smart-Home-Devices.a3176fae-c621-403d-8ef2-16022ffe3a08.percentage","Smart-Home-Devices.520a4696-d44a-42e5-9fb2-3a81ca2e40b3.#enabled","Smart-Home-Devices.520a4696-d44a-42e5-9fb2-3a81ca2e40b3.#delete","Smart-Home-Devices.520a4696-d44a-42e5-9fb2-3a81ca2e40b3.powerState","Smart-Home-Devices.520a4696-d44a-42e5-9fb2-3a81ca2e40b3.percentage","Smart-Home-Devices.4260cf44-a432-4128-8707-9c9e7f1b946b.#enabled","Smart-Home-Devices.4260cf44-a432-4128-8707-9c9e7f1b946b.#delete","Smart-Home-Devices.4260cf44-a432-4128-8707-9c9e7f1b946b.percentage","Smart-Home-Devices.a85f9f49-1f87-43df-a8cc-6f1f1337b6cb.#enabled","Smart-Home-Devices.a85f9f49-1f87-43df-a8cc-6f1f1337b6cb.#delete","Smart-Home-Devices.a85f9f49-1f87-43df-a8cc-6f1f1337b6cb.powerState","Smart-Home-Devices.a85f9f49-1f87-43df-a8cc-6f1f1337b6cb.percentage","Smart-Home-Devices.f6dac303-2a9e-475b-bb07-791659cf1a60.#enabled","Smart-Home-Devices.f6dac303-2a9e-475b-bb07-791659cf1a60.#delete","Smart-Home-Devices.f6dac303-2a9e-475b-bb07-791659cf1a60.powerState","Smart-Home-Devices.f6dac303-2a9e-475b-bb07-791659cf1a60.percentage","Smart-Home-Devices.280152a5-8875-4ad6-9926-d4b4b13a6399.#enabled","Smart-Home-Devices.280152a5-8875-4ad6-9926-d4b4b13a6399.#delete","Smart-Home-Devices.280152a5-8875-4ad6-9926-d4b4b13a6399.powerState","Smart-Home-Devices.280152a5-8875-4ad6-9926-d4b4b13a6399.percentage","Smart-Home-Devices.368b8eb9-330c-429a-bd24-b0b09443a129.#enabled","Smart-Home-Devices.368b8eb9-330c-429a-bd24-b0b09443a129.#delete","Smart-Home-Devices.368b8eb9-330c-429a-bd24-b0b09443a129.powerState","Smart-Home-Devices.368b8eb9-330c-429a-bd24-b0b09443a129.percentage","Smart-Home-Devices.7892fc70-1b6e-4064-92ce-d142b3067c31.#enabled","Smart-Home-Devices.7892fc70-1b6e-4064-92ce-d142b3067c31.#delete","Smart-Home-Devices.7892fc70-1b6e-4064-92ce-d142b3067c31.powerState","Smart-Home-Devices.7892fc70-1b6e-4064-92ce-d142b3067c31.percentage","Smart-Home-Devices.5b280ae1-2c0b-4220-9103-5b33f4d127f1.#enabled","Smart-Home-Devices.5b280ae1-2c0b-4220-9103-5b33f4d127f1.#delete","Smart-Home-Devices.5b280ae1-2c0b-4220-9103-5b33f4d127f1.powerState","Smart-Home-Devices.5b280ae1-2c0b-4220-9103-5b33f4d127f1.percentage","Smart-Home-Devices.d2c977ec-7351-48b1-9dad-e9c3975b00b1.#enabled","Smart-Home-Devices.d2c977ec-7351-48b1-9dad-e9c3975b00b1.#delete","Smart-Home-Devices.d2c977ec-7351-48b1-9dad-e9c3975b00b1.powerState","Smart-Home-Devices.d2c977ec-7351-48b1-9dad-e9c3975b00b1.percentage","Smart-Home-Devices.ed6340f3-7f8a-4d67-831c-5656eaa77dc3.#enabled","Smart-Home-Devices.ed6340f3-7f8a-4d67-831c-5656eaa77dc3.#delete","Smart-Home-Devices.ed6340f3-7f8a-4d67-831c-5656eaa77dc3.powerState","Smart-Home-Devices.ed6340f3-7f8a-4d67-831c-5656eaa77dc3.percentage","Smart-Home-Devices.8e78557d-6e62-41dd-b4b5-c2f780df0ee9.#enabled","Smart-Home-Devices.8e78557d-6e62-41dd-b4b5-c2f780df0ee9.#delete","Smart-Home-Devices.8e78557d-6e62-41dd-b4b5-c2f780df0ee9.powerState","Smart-Home-Devices.8e78557d-6e62-41dd-b4b5-c2f780df0ee9.percentage","Smart-Home-Devices.1fc6018a-b1d7-40b3-a617-285c8d6e2283.#enabled","Smart-Home-Devices.1fc6018a-b1d7-40b3-a617-285c8d6e2283.#delete","Smart-Home-Devices.1fc6018a-b1d7-40b3-a617-285c8d6e2283.powerState","Smart-Home-Devices.1fc6018a-b1d7-40b3-a617-285c8d6e2283.percentage","Smart-Home-Devices.db7e0160-3c50-4d4b-9984-099d005e1688.#enabled","Smart-Home-Devices.db7e0160-3c50-4d4b-9984-099d005e1688.#delete","Smart-Home-Devices.db7e0160-3c50-4d4b-9984-099d005e1688.powerState","Smart-Home-Devices.db7e0160-3c50-4d4b-9984-099d005e1688.percentage","Smart-Home-Devices.5026dceb-fc58-4864-a4e3-6a0e9ff15196.#enabled","Smart-Home-Devices.5026dceb-fc58-4864-a4e3-6a0e9ff15196.#delete","Smart-Home-Devices.5026dceb-fc58-4864-a4e3-6a0e9ff15196.powerState","Smart-Home-Devices.5026dceb-fc58-4864-a4e3-6a0e9ff15196.percentage","Smart-Home-Devices.a3d41f72-31bb-46ba-85f6-aa4f54116e81.#enabled","Smart-Home-Devices.a3d41f72-31bb-46ba-85f6-aa4f54116e81.#delete","Smart-Home-Devices.a3d41f72-31bb-46ba-85f6-aa4f54116e81.powerState","Smart-Home-Devices.a3d41f72-31bb-46ba-85f6-aa4f54116e81.percentage","Smart-Home-Devices.615d0048-f21b-4e8f-abbf-dbfd5f36bd01.#enabled","Smart-Home-Devices.615d0048-f21b-4e8f-abbf-dbfd5f36bd01.#delete","Smart-Home-Devices.615d0048-f21b-4e8f-abbf-dbfd5f36bd01.powerState","Smart-Home-Devices.615d0048-f21b-4e8f-abbf-dbfd5f36bd01.percentage","Smart-Home-Devices.2ec50d66-7e03-4a6c-b5c5-a212210913de.#enabled","Smart-Home-Devices.2ec50d66-7e03-4a6c-b5c5-a212210913de.#delete","Smart-Home-Devices.2ec50d66-7e03-4a6c-b5c5-a212210913de.powerState","Smart-Home-Devices.2ec50d66-7e03-4a6c-b5c5-a212210913de.percentage","Smart-Home-Devices.7c7c03d2-b345-4323-9239-cf2ae0bba6a0.#enabled","Smart-Home-Devices.7c7c03d2-b345-4323-9239-cf2ae0bba6a0.#delete","Smart-Home-Devices.7c7c03d2-b345-4323-9239-cf2ae0bba6a0.powerState","Smart-Home-Devices.7c7c03d2-b345-4323-9239-cf2ae0bba6a0.percentage","Smart-Home-Devices.1c040b05-b900-4afd-a9e0-853b8860272d.#enabled","Smart-Home-Devices.1c040b05-b900-4afd-a9e0-853b8860272d.#delete","Smart-Home-Devices.1c040b05-b900-4afd-a9e0-853b8860272d.powerState","Smart-Home-Devices.1c040b05-b900-4afd-a9e0-853b8860272d.percentage","Smart-Home-Devices.9e5e167d-e909-44ac-856d-4a2d0817d7a1.#enabled","Smart-Home-Devices.9e5e167d-e909-44ac-856d-4a2d0817d7a1.#delete","Smart-Home-Devices.9e5e167d-e909-44ac-856d-4a2d0817d7a1.powerState","Smart-Home-Devices.2adec7a5-a7f7-4219-ba23-8d882cae047e.#enabled","Smart-Home-Devices.2adec7a5-a7f7-4219-ba23-8d882cae047e.#delete","Smart-Home-Devices.5bf09712-9005-43e0-9112-94fbe9cf4fac.#delete","Smart-Home-Devices.5bf09712-9005-43e0-9112-94fbe9cf4fac.powerState","Smart-Home-Devices.5bf09712-9005-43e0-9112-94fbe9cf4fac.percentage","Smart-Home-Devices.533fde82-3ef9-459e-8a70-1c9d233d8d1f.#delete","Smart-Home-Devices.533fde82-3ef9-459e-8a70-1c9d233d8d1f.powerState","Smart-Home-Devices.533fde82-3ef9-459e-8a70-1c9d233d8d1f.percentage","Smart-Home-Devices.8356cd6d-f6be-41a8-afdc-177c8e17e830.#delete","Smart-Home-Devices.8356cd6d-f6be-41a8-afdc-177c8e17e830.powerState","Smart-Home-Devices.8356cd6d-f6be-41a8-afdc-177c8e17e830.percentage","Smart-Home-Devices.5d2e57de-fc4f-4207-909b-ea792d9ff3ed.powerState","Smart-Home-Devices.5d2e57de-fc4f-4207-909b-ea792d9ff3ed.percentage","Smart-Home-Devices.7955c6a0-db1f-4b9c-b283-818e20c89a1a.#delete","Smart-Home-Devices.7955c6a0-db1f-4b9c-b283-818e20c89a1a.powerState","Smart-Home-Devices.7955c6a0-db1f-4b9c-b283-818e20c89a1a.percentage","Smart-Home-Devices.6a07a0b7-63f7-41b3-91df-276011cd1591.#delete","Smart-Home-Devices.6a07a0b7-63f7-41b3-91df-276011cd1591.powerState","Smart-Home-Devices.6a07a0b7-63f7-41b3-91df-276011cd1591.percentage","Smart-Home-Devices.39677e96-b0c2-4779-a65b-a01383b8b42b.#delete","Smart-Home-Devices.39677e96-b0c2-4779-a65b-a01383b8b42b.powerState","Smart-Home-Devices.39677e96-b0c2-4779-a65b-a01383b8b42b.percentage","Smart-Home-Devices.97576182-7eb7-45cb-81f8-c73d8d900a02.#delete","Smart-Home-Devices.97576182-7eb7-45cb-81f8-c73d8d900a02.powerState","Smart-Home-Devices.97576182-7eb7-45cb-81f8-c73d8d900a02.percentage","Smart-Home-Devices.e0fe5f03-a63c-4bf4-97be-d28133927458.#enabled","Smart-Home-Devices.e0fe5f03-a63c-4bf4-97be-d28133927458.#delete","Smart-Home-Devices.e0fe5f03-a63c-4bf4-97be-d28133927458.powerState","Smart-Home-Devices.e0fe5f03-a63c-4bf4-97be-d28133927458.connectivity","Smart-Home-Devices.e0fe5f03-a63c-4bf4-97be-d28133927458.connectivity-reason","Smart-Home-Devices.e0fe5f03-a63c-4bf4-97be-d28133927458.#query","Smart-Home-Devices.e0fe5f03-a63c-4bf4-97be-d28133927458.#includeInAllQuery","Smart-Home-Devices.5a783a80-cbfc-4f70-8607-8d8aafa6220c.#enabled","Smart-Home-Devices.5a783a80-cbfc-4f70-8607-8d8aafa6220c.#delete","Smart-Home-Devices.5a783a80-cbfc-4f70-8607-8d8aafa6220c.powerState","Smart-Home-Devices.5a783a80-cbfc-4f70-8607-8d8aafa6220c.connectivity","Smart-Home-Devices.5a783a80-cbfc-4f70-8607-8d8aafa6220c.connectivity-reason","Smart-Home-Devices.5a783a80-cbfc-4f70-8607-8d8aafa6220c.#query","Smart-Home-Devices.5a783a80-cbfc-4f70-8607-8d8aafa6220c.#includeInAllQuery","Smart-Home-Devices.71858f82-bcd3-48d6-b0ef-7e456bdbcefb.#enabled","Smart-Home-Devices.71858f82-bcd3-48d6-b0ef-7e456bdbcefb.#delete","Smart-Home-Devices.71858f82-bcd3-48d6-b0ef-7e456bdbcefb.powerState","Smart-Home-Devices.71858f82-bcd3-48d6-b0ef-7e456bdbcefb.connectivity","Smart-Home-Devices.71858f82-bcd3-48d6-b0ef-7e456bdbcefb.connectivity-reason","Smart-Home-Devices.71858f82-bcd3-48d6-b0ef-7e456bdbcefb.#query","Smart-Home-Devices.71858f82-bcd3-48d6-b0ef-7e456bdbcefb.#includeInAllQuery","Smart-Home-Devices.0365ecdd-d81d-4d61-b26b-86f081ea6cc4.#enabled","Smart-Home-Devices.0365ecdd-d81d-4d61-b26b-86f081ea6cc4.#delete","Smart-Home-Devices.0365ecdd-d81d-4d61-b26b-86f081ea6cc4.powerState","Smart-Home-Devices.0365ecdd-d81d-4d61-b26b-86f081ea6cc4.connectivity","Smart-Home-Devices.0365ecdd-d81d-4d61-b26b-86f081ea6cc4.connectivity-reason","Smart-Home-Devices.0365ecdd-d81d-4d61-b26b-86f081ea6cc4.#query","Smart-Home-Devices.0365ecdd-d81d-4d61-b26b-86f081ea6cc4.#includeInAllQuery","Smart-Home-Devices.45ce1797-01d2-4fb0-8e5f-e69c717c24af.#enabled","Smart-Home-Devices.45ce1797-01d2-4fb0-8e5f-e69c717c24af.#delete","Smart-Home-Devices.45ce1797-01d2-4fb0-8e5f-e69c717c24af.powerState","Smart-Home-Devices.45ce1797-01d2-4fb0-8e5f-e69c717c24af.connectivity","Smart-Home-Devices.45ce1797-01d2-4fb0-8e5f-e69c717c24af.connectivity-reason","Smart-Home-Devices.45ce1797-01d2-4fb0-8e5f-e69c717c24af.#query","Smart-Home-Devices.45ce1797-01d2-4fb0-8e5f-e69c717c24af.#includeInAllQuery","Smart-Home-Devices.ead3d204-d8a7-4a27-b784-5e3db229b8d7.percentage","Smart-Home-Devices.a4fa06cb-7dab-4c03-8579-ad7d87fbc401.#enabled","Smart-Home-Devices.a4fa06cb-7dab-4c03-8579-ad7d87fbc401.#delete","Smart-Home-Devices.a4fa06cb-7dab-4c03-8579-ad7d87fbc401.powerState","Smart-Home-Devices.a4fa06cb-7dab-4c03-8579-ad7d87fbc401.connectivity","Smart-Home-Devices.a4fa06cb-7dab-4c03-8579-ad7d87fbc401.connectivity-reason","Smart-Home-Devices.a4fa06cb-7dab-4c03-8579-ad7d87fbc401.#query","Smart-Home-Devices.a4fa06cb-7dab-4c03-8579-ad7d87fbc401.#includeInAllQuery","Smart-Home-Devices.09e95f3f-7641-471f-9042-c79d65bf4a67.#enabled","Smart-Home-Devices.09e95f3f-7641-471f-9042-c79d65bf4a67.#delete","Smart-Home-Devices.09e95f3f-7641-471f-9042-c79d65bf4a67.powerState","Smart-Home-Devices.09e95f3f-7641-471f-9042-c79d65bf4a67.connectivity","Smart-Home-Devices.09e95f3f-7641-471f-9042-c79d65bf4a67.connectivity-reason","Smart-Home-Devices.09e95f3f-7641-471f-9042-c79d65bf4a67.#query","Smart-Home-Devices.09e95f3f-7641-471f-9042-c79d65bf4a67.#includeInAllQuery","Smart-Home-Devices.4face9a3-2e45-43dd-9579-9e3c5c9dab8f.#enabled","Smart-Home-Devices.4face9a3-2e45-43dd-9579-9e3c5c9dab8f.#delete","Smart-Home-Devices.4face9a3-2e45-43dd-9579-9e3c5c9dab8f.powerState","Smart-Home-Devices.4face9a3-2e45-43dd-9579-9e3c5c9dab8f.connectivity","Smart-Home-Devices.4face9a3-2e45-43dd-9579-9e3c5c9dab8f.connectivity-reason","Smart-Home-Devices.4face9a3-2e45-43dd-9579-9e3c5c9dab8f.#query","Smart-Home-Devices.4face9a3-2e45-43dd-9579-9e3c5c9dab8f.#includeInAllQuery","Smart-Home-Devices.9030b7cd-3111-4558-a9ca-6ca80b79c3bb.#enabled","Smart-Home-Devices.9030b7cd-3111-4558-a9ca-6ca80b79c3bb.#delete","Smart-Home-Devices.9030b7cd-3111-4558-a9ca-6ca80b79c3bb.powerState","Smart-Home-Devices.9030b7cd-3111-4558-a9ca-6ca80b79c3bb.connectivity","Smart-Home-Devices.9030b7cd-3111-4558-a9ca-6ca80b79c3bb.connectivity-reason","Smart-Home-Devices.9030b7cd-3111-4558-a9ca-6ca80b79c3bb.#query","Smart-Home-Devices.9030b7cd-3111-4558-a9ca-6ca80b79c3bb.#includeInAllQuery","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05.#enabled","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05.#delete","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05.powerState","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05.brightness","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05.connectivity","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05.connectivity-reason","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05.#query","Smart-Home-Devices.cc6e1d4b-ec4c-43fe-ac65-c12a52e79d05.#includeInAllQuery","Smart-Home-Devices.71f9b8c6-2663-4a2e-8a3f-39b324778492.#enabled","Smart-Home-Devices.71f9b8c6-2663-4a2e-8a3f-39b324778492.#delete","Smart-Home-Devices.71f9b8c6-2663-4a2e-8a3f-39b324778492.powerState","Smart-Home-Devices.71f9b8c6-2663-4a2e-8a3f-39b324778492.percentage","Smart-Home-Devices.822fad25-ad22-4689-ae8c-a2816e410e1e.#enabled","Smart-Home-Devices.822fad25-ad22-4689-ae8c-a2816e410e1e.#delete","Smart-Home-Devices.822fad25-ad22-4689-ae8c-a2816e410e1e.percentage","Smart-Home-Devices.9941a8a6-fd8e-4362-8e02-529cd89eb638.#enabled","Smart-Home-Devices.9941a8a6-fd8e-4362-8e02-529cd89eb638.#delete","Smart-Home-Devices.9941a8a6-fd8e-4362-8e02-529cd89eb638.powerState","Smart-Home-Devices.9941a8a6-fd8e-4362-8e02-529cd89eb638.percentage","Smart-Home-Devices.34a9c988-29b1-4e4b-8a1a-410a9358cc0b.#enabled","Smart-Home-Devices.34a9c988-29b1-4e4b-8a1a-410a9358cc0b.#delete","Smart-Home-Devices.34a9c988-29b1-4e4b-8a1a-410a9358cc0b.powerState","Smart-Home-Devices.34a9c988-29b1-4e4b-8a1a-410a9358cc0b.percentage","Smart-Home-Devices.9f3865b9-a5df-4263-ae11-a3f157969e69.#enabled","Smart-Home-Devices.9f3865b9-a5df-4263-ae11-a3f157969e69.#delete","Smart-Home-Devices.9f3865b9-a5df-4263-ae11-a3f157969e69.powerState","Smart-Home-Devices.9f3865b9-a5df-4263-ae11-a3f157969e69.percentage","Smart-Home-Devices.8e14c4ff-818c-478e-9d54-3f68f6b791ed.#enabled","Smart-Home-Devices.8e14c4ff-818c-478e-9d54-3f68f6b791ed.#delete","Smart-Home-Devices.8e14c4ff-818c-478e-9d54-3f68f6b791ed.powerState","Smart-Home-Devices.8e14c4ff-818c-478e-9d54-3f68f6b791ed.percentage","Smart-Home-Devices.78982010-2664-49d6-8fc1-b2bb17d6b7d9.#enabled","Smart-Home-Devices.78982010-2664-49d6-8fc1-b2bb17d6b7d9.#delete","Smart-Home-Devices.78982010-2664-49d6-8fc1-b2bb17d6b7d9.powerState","Smart-Home-Devices.78982010-2664-49d6-8fc1-b2bb17d6b7d9.connectivity","Smart-Home-Devices.78982010-2664-49d6-8fc1-b2bb17d6b7d9.connectivity-reason","Smart-Home-Devices.78982010-2664-49d6-8fc1-b2bb17d6b7d9.#query","Smart-Home-Devices.78982010-2664-49d6-8fc1-b2bb17d6b7d9.#includeInAllQuery","Smart-Home-Devices.834b909a-a576-427d-bc80-862d3b3e3ad9.#enabled","Smart-Home-Devices.834b909a-a576-427d-bc80-862d3b3e3ad9.#delete","Smart-Home-Devices.834b909a-a576-427d-bc80-862d3b3e3ad9.powerState","Smart-Home-Devices.834b909a-a576-427d-bc80-862d3b3e3ad9.connectivity","Smart-Home-Devices.834b909a-a576-427d-bc80-862d3b3e3ad9.connectivity-reason","Smart-Home-Devices.834b909a-a576-427d-bc80-862d3b3e3ad9.#query","Smart-Home-Devices.834b909a-a576-427d-bc80-862d3b3e3ad9.#includeInAllQuery"]
    2024-07-10 08:05:38.446  - error: host.raspberrypi startInstance system.adapter.openligadb.0 Adapter dependency not fulfilled on "raspberrypi": required adapter "admin" not found!
    2024-07-10 08:05:38.930  - info: alexa2.0 (13022) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2024-07-10 08:05:42.429  - error: host.raspberrypi startInstance system.adapter.fritzdect.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found!
    2024-07-10 08:05:46.430  - error: host.raspberrypi startInstance system.adapter.tesla-motors.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found!
    2024-07-10 08:05:52.161  - info: alexa2.0 (13022) Initialization Done ...
    Ro75R Online
    Ro75R Online
    Ro75
    @line sagte in Beim Update einiger Adapter- "admin" not found:
    tausch die SD-Karte und installiere gleich Debian 12 (Bookworm 64 Bit lite ohne Desktop). Alle anderen Versuche werden gleich oder in einigen Tagen (wieder) scheitern.
    Ro75.
    • Ro75R Ro75
      Ro75.
      @ro75 das kann durch die Schreibversuche bei voller Karte verursacht worden srin.
      Es sind noch keine Orphans dabei gewesen.
      • Ro75R Online
        Ro75R Online
        Ro75
        Und vielleicht auch gleich eine größere SD-Karte. 32GB bei alleine schon 15GB an Influxdb wird auf Dauer sehr knapp.
        Ro75.
        L 1 Antwort Letzte Antwort
        • Ro75R Ro75
          Ro75.
          line
          @ro75
          Also dann besorge ich eine größere SD Karte.
          Installiere alles neu.
          Woher weiß ich wo mein Backup vom iobroker/vis liegt?
          • L line
            @ro75
            Das lieg da, wo du es hinlegst. Kann man z. B. im Backitup-Adapter ja alles einstellen.
            • L Offline
              line
              schrieb am zuletzt editiert von line
              Mein ioBroker Oberfläche startet ja nicht mehr - von dem her kann ich den Adapter nicht mehr einsehen.
              Wenn ich ihn starte kommt:
              $ iobroker status
              Objects type: jsonl
              States  type: jsonl
              Sieht alles gut aus, aber die Webseite kann ich trotzdem nicht öffnen.
              Gibt es irgendwo eine Anleitung, wie ich die Daten von der alten SD Karte auf die Neu übertrage - mit restore von dem Backup.
              • L line
                $ iobroker status
                Objects type: jsonl
                States  type: jsonl
                @line
                Hast du denn was diesbezüglich eingestellt? Ein NAS oder sowas?
                Ansonsten liegt das in /opt/iobroker/backups
                Probier mal:
                iob stop
                iob nodejs-update 20
                iob stop
                sudo reboot
                • L line
                  $ iobroker status
                  Objects type: jsonl
                  States  type: jsonl
                  dann dürfte der admin noch nicht richtig laufen.
                  was sagt iob diag in der Langfassung?
                  ggf. später nochmal iob drüber installieren. Das könnte noch einiges zurechtbiegen.
                  Aber so richtig vertrauenswürdig ist die Installation nicht mehr.
                    line
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     10:33:41 up 9 min,  2 users,  load average: 0.58, 0.52, 0.44
                    CPU threads: 4
                    Current issues:
                                   Local time: Wed 2024-07-10 10:33:41 CEST
                               Universal time: Wed 2024-07-10 08:33:41 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    feline
                    HOME=/home/feline
                    iobroker
                    HOME=/home/iobroker
                    Desktop: 	LXDE-pi
                    Terminal: 	x11
                    *** MEMORY ***
                    Mem:            7.8G        1.1G        5.6G         39M        1.2G        6.6G
                    Swap:            99M          0B         99M
                    Total:          7.9G        1.1G        5.7G
                             7812 M total memory
                             1064 M used memory
                             1599 M active memory
                              479 M inactive memory
                             5570 M free memory
                               81 M buffer memory
                             1096 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    top - 10:33:41 up 9 min,  2 users,  load average: 0.58, 0.52, 0.44
                    Tasks: 228 total,   1 running, 227 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  4.1 us,  2.7 sy,  0.0 ni, 93.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   7812.3 total,   5570.5 free,   1063.8 used,   1178.0 buff/cache
                    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6587.5 avail Mem
                    *** FILESYSTEM ***
                    /dev/root      ext4       29G   25G  3.1G  90% /
                    tmpfs          tmpfs     1.6G  9.3M  1.6G   1% /run
                    [Wed Jul 10 10:23:42 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:38:62:0F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=b4c0fa64-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Wed Jul 10 10:23:43 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Wed Jul 10 10:23:43 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Wed Jul 10 10:23:45 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    | `-/sys/fs/fuse/connections      fusectl        fusectl           rw,nosuid,nodev,noexec,relatime
                    /var:
                    15G	/var/lib
                    15G	/var/
                    Archived and active journals take up 8.0M in the file system.
                    579M	/opt/iobroker/iobroker-data/
                    USB-Devices by-id:
                    /usr/bin/nodejs 	v20.15.1
                    /usr/bin/node 		v20.15.1
                    /usr/bin/npm 		10.7.0
                    /usr/bin/npx 		10.7.0
                    /usr/bin/corepack 	0.28.1
                    nodejs:
                      Installed: 20.15.1-1nodesource1
                      Candidate: 20.15.1-1nodesource1
                      Version table:
                     *** 20.15.1-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		6.17.14
                    javascript: 	8.3.1
                    `-- my-muell-ical@0.1.0 (git+ssh://git@github.com/benzman81/my-muell-ical.git#1c13794503ead416b1b5739222214e9cfbdc262b)
                    Adapter State
                    + instance is alive
                    Adapter    "admin"        : 6.17.14  , installed 6.17.14
                    Objects and States
                    Objects: 	15545
                    States: 	13107
                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                    Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Fetched 5127 B in 2s (2566 B/s)
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18201      1063/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19549      1063/iobroker.js-co
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12778      545/cupsd
                    tcp        0      0 127.0.0.1:45421         0.0.0.0:*               LISTEN      1001       22089      2978/io.yahka.0
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12142      596/sshd: /usr/sbin
                    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12119      577/xrdp-sesman
                    tcp6       0      0 :::34387                :::*                    LISTEN      1001       21320      2978/io.yahka.0
                    tcp6       0      0 :::4712                 :::*                    LISTEN      116        16400      548/evcc
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          12144      596/sshd: /usr/sbin
                    tcp6       0      0 :::8086                 :::*                    LISTEN      119        16652      557/influxd
                    tcp6       0      0 :::3389                 :::*                    LISTEN      117        12264      613/xrdp
                    tcp6       0      0 :::3000                 :::*                    LISTEN      120        18146      1058/grafana
                    tcp6       0      0 :::7070                 :::*                    LISTEN      116        12837      548/evcc
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12777      545/cupsd
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12809      478/dhcpcd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14119      619/cups-browsed
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        15405      548/evcc
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        12834      548/evcc
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12707      406/avahi-daemon: r
                    udp        0      0 0.0.0.0:56872           0.0.0.0:*                           108        12709      406/avahi-daemon: r
                    udp6       0      0 :::42139                :::*                                108        12710      406/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                116        15406      548/evcc
                    udp6       0      0 :::5353                 :::*                                116        12835      548/evcc
                    udp6       0      0 :::5353                 :::*                                108        12708      406/avahi-daemon: r
                    2024-07-10 10:25:48.359  - info: pollenflug.0 (2963) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.pollenflug, node: v20.15.1, js-controller: 5.0.19
                    2024-07-10 10:25:48.382  - info: pollenflug.0 (2963) Starting Adapter pollenflug.0 in version 1.0.6
                    2024-07-10 10:25:48.409  - info: pollenflug.0 (2963) Requesting DWD pollen information now.
                    2024-07-10 10:25:49.850  - error: host.raspberrypi startInstance system.adapter.trashschedule.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found!
                    2024-07-10 10:25:50.499  - info: pollenflug.0 (2963) Next DWD pollen request starts on Wed Jul 10 2024 11:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                    2024-07-10 10:25:53.616  - info: alexa2.0 (2267) Initialization Done ...
                    2024-07-10 10:25:53.896  - info: host.raspberrypi instance system.adapter.yahka.0 started with pid 2978
                    2024-07-10 10:25:56.728  - info: yahka.0 (2978) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yahka, node: v20.15.1, js-controller: 5.0.19
                    2024-07-10 10:25:56.797  - info: yahka.0 (2978) adapter ready, checking config
                    2024-07-10 10:25:56.833  - info: yahka.0 (2978) adding Büro Licht with UUID: 68404733-0ee7-4d39-8189-b8a42e2bb7ec
                    2024-07-10 10:25:56.865  - info: yahka.0 (2978) adding Wohnzimmer Licht 1 with UUID: 34598146-1bec-4fe8-99f7-07b0fb0b37f9
                    2024-07-10 10:25:56.889  - info: yahka.0 (2978) adding Wohnzimmer Licht 2 with UUID: c5dcfd1c-c7ab-4d65-8c8e-f000a9c98d82
                    2024-07-10 10:25:56.899  - info: yahka.0 (2978) adding Markise with UUID: 3f32008f-6511-41be-8743-21d5efe935fd
                    2024-07-10 10:25:56.919  - info: yahka.0 (2978) adding Küche Licht with UUID: 3ef44851-a815-4b48-968f-97a3c392c47d
                    2024-07-10 10:25:56.928  - info: yahka.0 (2978) adding Bad Licht with UUID: ea9bbccf-39c1-4b21-a31d-d205af9f4440
                    2024-07-10 10:25:56.934  - info: yahka.0 (2978) adding Galerie Licht with UUID: 6f9d3f0e-2096-4950-ac9c-6afcd62e984d
                    2024-07-10 10:25:56.944  - info: yahka.0 (2978) adding Windfang Licht with UUID: 954b6670-6f54-42a2-bb47-726a8b64bfeb
                    2024-07-10 10:25:56.954  - info: yahka.0 (2978) adding Schlafzimmer Licht 1 with UUID: cb37b8d7-10bf-4c95-a3cc-bfffbc6e4221
                    2024-07-10 10:25:56.963  - info: yahka.0 (2978) adding Schlafzimmer Licht 2 with UUID: 1123330b-5285-487a-9e4a-5aaaca340db3
                    2024-07-10 10:25:56.969  - info: yahka.0 (2978) adding Rolladen Küche  with UUID: 5e737590-77b1-4181-98cb-0f6d79b06fb3
                    2024-07-10 10:25:56.976  - info: yahka.0 (2978) publishing bridge Iobroker - Live on 0.0.0.0 using avahi
                    2024-07-10 10:25:57.851  - error: host.raspberrypi startInstance system.adapter.socketio.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found!
                    2024-07-10 10:26:01.962  - error: host.raspberrypi startInstance system.adapter.openligadb.0 Adapter dependency not fulfilled on "raspberrypi": required adapter "admin" not found!
                    2024-07-10 10:26:05.884  - error: host.raspberrypi startInstance system.adapter.fritzdect.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found!
                    2024-07-10 10:26:09.865  - error: host.raspberrypi startInstance system.adapter.tesla-motors.0 Adapter dependency not fulfilled on any host: required adapter "admin" not found!
                    Anbei noch die Summary:
                    			v.2024-05-22
                             Icon name: computer
                          Architecture: arm64
                    Installation: 		native
                    Kernel: 		aarch64
                    Userland: 		64 bit
                    Timezone: 		Europe/Berlin (CEST, +0200)
                    User-ID: 		1000
                    Pending OS-Updates: 	0
                    Pending iob updates: 	3
                    Nodejs-Installation:
                    /usr/bin/npm 		10.7.0
                    /usr/bin/npx 		10.7.0
                    Recommended versions are nodejs  and npm
                    MEMORY:
                    Mem:            7.8G        1.1G        5.5G         39M        1.3G        6.5G
                    Swap:            99M          0B         99M
                    Total:          7.9G        1.1G        5.6G
                    ioBroker Core: 		js-controller 		5.0.19
                    			admin 			6.17.14
                    ioBroker Status: 	iobroker is running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		15545
                    States: 		13107
                    Size of iob-Database:
                    16M	/opt/iobroker/iobroker-data/objects.jsonl
                    5.3M	/opt/iobroker/iobroker-data/states.jsonl
                      @line
                      Probier mal:
                      iob stop
                      iob stop
                      sudo reboot
                      line
                      ok da sind in dem Fall die Backups - perfekt. Sie enden mit tar.gz.
                      Die VIS ist in dem Backup auch mit enthalten oder?
                      • L line
                        nicht perfekt!
                        ist echt heftig!
                        und der admin ist noch immer nicht installiert
                        • L line
                          @line
                          iob update
                          iob upgrade all
                          iob add admin.0
                          sagt?
                            @line
                            iob update
                            iob upgrade all
                            iob add admin.0
                            sagt?
                            line
                            $ iob install admin
                            adapter "admin" already installed. Use "upgrade" to upgrade to a newer version.
                            $ iob update
                            $ iob upgrade all
                            Cannot check dependencies: Required dependency "admin" not found.
                            feline@raspberrypi:/home/feline2 $ iob add admin.0
                            host.raspberrypi create instance admin
                            host.raspberrypi object system.adapter.admin.0.alive created
                            host.raspberrypi object system.adapter.admin.0.connected created
                            host.raspberrypi object system.adapter.admin.0.compactMode created
                            host.raspberrypi object system.adapter.admin.0.cpu created
                            host.raspberrypi object system.adapter.admin.0.cputime created
                            host.raspberrypi object system.adapter.admin.0.memHeapUsed created
                            host.raspberrypi object system.adapter.admin.0.memHeapTotal created
                            host.raspberrypi object system.adapter.admin.0.memRss created
                            host.raspberrypi object system.adapter.admin.0.uptime created
                            host.raspberrypi object system.adapter.admin.0.inputCount created
                            host.raspberrypi object system.adapter.admin.0.outputCount created
                            host.raspberrypi object system.adapter.admin.0.eventLoopLag created
                            host.raspberrypi object system.adapter.admin.0.sigKill created
                            host.raspberrypi object system.adapter.admin.0.logLevel created
                            host.raspberrypi object admin.0.info created
                            host.raspberrypi object admin.0 created
                            host.raspberrypi object admin.0.info.connected created
                            host.raspberrypi object admin.0.info.connection created
                            host.raspberrypi object admin.0.info.newsFeed created
                            host.raspberrypi object admin.0.info.newsETag created
                            host.raspberrypi object admin.0.info.newsLastId created
                            host.raspberrypi object admin.0.info.updatesList created
                            host.raspberrypi Set default value of admin.0.info.connected:
                            host.raspberrypi Set default value of admin.0.info.connection: false
                            host.raspberrypi Set default value of admin.0.info.updatesList:
                            host.raspberrypi object system.adapter.admin.0 created
                            So jetzt läuft er wieder - danke!
                              nicht perfekt!
                              ist echt heftig!
                              line
                              @homoran said in Beim Update einiger Adapter- "admin" not found:
                              nicht perfekt!
                              was soll das heißen? Kann ich mit dem backup mein Restore nicht anfangen?
                              • L line
                                $ iob install admin
                                $ iob update
                                $ iob upgrade all
                                @line
                                Dann zieh jetzt ein aktuelles Backup und dann ziehst du damit auf ein NEUINSTALLIERTES
                                Raspberry OS 12 Lite 'Bookworm' (OHNE DESKTOP) in der 64Bit-Version um.
                                Auf einem größeren Datenträger dann.
                                  @line
                                  line
                                  @thomas-braun alles klar - Danke! Ich hoffe, es klappt! Danke für eure Hilfe
                                  • L line
                                    nicht perfekt!
                                    das scheinen gefühlt hunderte zu sein!
                                    nie aufgeräumt??
