  4. iobroker auf https umstellen
https
16 Beiträge 6 Kommentatoren 3.0k Aufrufe 9 Beobachtet
  • M Online
    M Online
    MCU
    Ich habe versucht iobroker auf https umzustellen und bekomme einige Probleme.
    Hierfür benötige ich ein wenig Hilfe.
    Einstellungen Admin
    Einstellungen Web
    Bekomme dann im Log folgende Meldungen
    web.0
    2024-07-01 15:05:26.567	info	Secure socket.io server listening on port 8082
    web.0
    2024-07-01 15:05:26.487	warn	Falling back to self-signed certificates or to custom certificates
    web.0
    2024-07-01 15:05:26.487	warn	Could not find any certificate collections - check ACME installation or consider installing
    admin.0
    2024-07-01 15:05:26.494	info	<== Disconnect system.user.admin from ::ffff:192.168.178.77 admin
    web.0
    2024-07-01 15:05:26.442	info	starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v20.15.0, js-controller: 5.0.19
    host.iobrokerPROD
    2024-07-01 15:05:25.949	info	instance system.adapter.web.0 started with pid 860722
    host.iobrokerPROD
    2024-07-01 15:05:23.936	info	instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    web.0
    2024-07-01 15:05:23.392	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    web.0
    2024-07-01 15:05:23.387	info	terminating
    admin.0
    2024-07-01 15:05:23.262	info	<== Disconnect system.user.admin from ::ffff:192.168.178.77 web
    host.iobrokerPROD
    2024-07-01 15:05:22.918	info	stopInstance system.adapter.web.0 send kill signal
    cloud.0
    2024-07-01 15:05:22.917	info	Trying to connect as system.user.admin to cloud
    cloud.0
    2024-07-01 15:05:22.916	error	Cannot activate web.0 for cloud, because HTTPs is enabled. Please create extra instance for cloud
    cloud.0
    2024-07-01 15:05:22.890	info	Reconnect because web instance started
    cloud.0
    2024-07-01 15:05:22.884	error	Cannot activate web.0 for cloud, because HTTPs is enabled. Please create extra instance for cloud
    web.0
    2024-07-01 15:05:22.887	warn	setTimeout called, but adapter is shutting down
    web.0
    2024-07-01 15:05:22.878	info	Got terminate signal TERMINATE_YOURSELF
    Was mache ich jetzt mit der cloud? Wie muss ich jetzt die 2.Instanz einstellen?
    Warum bekomme ich jetzt den Hinweis, dass die Seite doch nicht sicher ist und ich dort keine Passwörter eingeben soll?
    Wie bekomme ich die Seiten (ioBroker) sicher?
    Bitte detaillierte Anleitung, wenn möglich. Danke.
    HomoranH MartinPM 2 Antworten Letzte Antwort
    • M MCU
      Einstellungen Admin
      Einstellungen Web
      web.0
      web.0
      web.0
      admin.0
      web.0
      host.iobrokerPROD
      host.iobrokerPROD
      web.0
      web.0
      admin.0
      host.iobrokerPROD
      cloud.0
      cloud.0
      cloud.0
      cloud.0
      web.0
      web.0
      @mcu sagte in iobroker auf https umstellen:
      ja, eine ohne https
        ja, eine ohne https
        M Online
        M Online
        MCU
        Dann muss ich auch eine 2. Web-Instanz ohne https erstellen, damit ich diese dann der 2. Instanz von cloud zuordnen kann. Richtig?
        • M MCU
          Richtig
          ja, aber warum deswegen 2x cloud?
            Richtig
            M Online
            M Online
            MCU
            @homoran Brauchte nur die Web-Instanz umstellen. Bekomme noch bei admin
            admin.0
            2024-07-01 16:48:47.868	warn	cloud has an invalid jsonConfig: [{"instancePath":"/items/_options/items/_instanceAlive/instance","schemaPath":"#/definitions/aliveProps/properties/instance/type","keyword":"type","params":{"type":"number"},"message":"must be number"},{"instancePath":"/items/_options","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
            Was ist da zu tun?
            HomoranH mcm1957M 2 Antworten Letzte Antwort
            • M MCU
              admin.0
              Was ist da zu tun?
              Was ist da zu tun?
              keine Ahnung.
              Da war mal was mit einer "Falschmeldung" wegen json-Konfig. @mcm1957 kann sich da vielleicht dran erinnern.
              • M MCU
                Einstellungen Admin
                Einstellungen Web
                web.0
                web.0
                web.0
                admin.0
                web.0
                host.iobrokerPROD
                host.iobrokerPROD
                web.0
                web.0
                admin.0
                host.iobrokerPROD
                cloud.0
                cloud.0
                cloud.0
                cloud.0
                web.0
                web.0
                MartinPM Offline
                MartinPM Offline
                MartinP
                @mcu Wieso benötigst Du denn https? Möchtest Du den ioBroker ins Internet stellen?
                Dazu habe ich etwas:
                978aae2f-2a0c-40ab-b226-d5a3e98d090c-1719844705416-2276d287-8eef-4625-8ddb-113d583e2b45-image.png
                Liegt sicher an den "self signed certificates"....
                web.0
                Mir ist das auch zu viel Mühe. Ich gehe aus dem Internet per Fritzbox Wireguard VPN auf die ioBroker Webseiten und hoffe das Beste, dass im Heimnetz auch http: sicher genug ist ...
                Intel(R) Celeron(R) CPU N3000 @ 1.04GHz 8G RAM 480G SSD
                Virtualization : unprivileged lxc container (debian 13) on Proxmox 9.1.5)
                Linux pve 6.17.9-1-pve
                6 GByte RAM für den Container
                Fritzbox 6591 FW 8.20 (Vodafone Leih-Box)
                Remote-Access über Wireguard der Fritzbox
                • MartinPM MartinP
                  web.0
                  M Online
                  M Online
                  MCU
                  @martinp Nein, nicht ins Internet. Jarvis benötigt (zurzeit) https für die PIN-Eingabe (wird noch diskutiert). Aber um es diskutieren zu können muss ich es auch mal umgestellt haben.
                  Nun stelle ich bei der Umstellung die Probleme fest und bedenke, dass es auch bei anderen Usern so wäre.
                  EDIT: Das mache ich auch per VPN über Wireguard.
                  • MartinPM MartinP
                    web.0
                    M Online
                    M Online
                    MCU
                    @martinp Das ist halt verwirrend. Auf der einen Seite richte ich https ein, damit ich die PIN / Passwörter schütze und auf der anderen Seite erhalte ich, wenn ich einstelle, den Hinweis, dass es nicht sicher ist und ich dort keine Passwörter eingeben soll.
                    Ist es jetzt sicher, was ist sicher und was nicht? Darf ich jetzt die PIN / Passwort dort eingeben und den Hinweis kann ich ignorieren bzw. muss ihn einfach ignorieren?
                    SKBS 1 Antwort Letzte Antwort
                    • M MCU
                      MartinPM Offline
                      MartinPM Offline
                      MartinP
                      @mcu
                      Nervig, aber solche Spielchen werden einem wohl immer öfter vor die Flinte kommen ... wird wohl Zeit, sich mit dem Zertifikats-Gedöns zu beschäftigen ... neues Spielchen ist ja, dass die Anwendungen anfangen Zertifikate abzulehnen, die eine zu lange Laufzeit haben...
                      • M MCU
                        admin.0
                        Was ist da zu tun?
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @mcu said in iobroker auf https umstellen:
                        admin.0
                        Was ist da zu tun?
                        Muss der Dev fixen
                        https://github.com/ioBroker/ioBroker.cloud/issues/373
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • M MCU
                          SKBS Offline
                          SKBS Offline
                          SKB
                          @mcu Ich habe seit gestern ioBroker-Web auch mit Zertifikaten versehen.
                          Allerdings bin ich etwas anders vorgangen.
                          Ich habe mir eine Zertifikat CA (Certificate Authority) erstellt, welches als "root-Zertifikat" fungiert - muss man einmal im System einbinden. Dann kann man mit diesem root-Zertifikat Gerätezertifikate bzw. Unterzertifikate erstellen und sie bsp. in ioBroker oder anderen Geräten im Netzwerk einspeisen, damit sie vollkommen https können. Da man hier das root-Zertifikat eingespielt hat, erlauben sie auch Namen wie "meinIoBroker" oder eben "iobroker-master". Selbst IP-Adressen lassen sich signieren, was bei lokalen Adressen sonst nicht geht, weil eine 192.168.x.x gibt es ja millionenfach ;)
                          War relativ einfach :)
                          • SKBS SKB
                            M Online
                            M Online
                            MCU
                            @skb
                            Hast du dazu eine detaillierte Anleitung? Links? Videos?
                            Danke.
                            Wenn man weiß wie es geht, dann sind die meisten Dinge einfach.
                            OliverIOO SKBS 2 Antworten Letzte Antwort
                            • M MCU
                              @skb
                              Danke.
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @mcu
                              Für linux/debian-artige
                              Kann man hier nachlesen
                              https://wiki.ubuntuusers.de/CA/
                              Meine Adapter und Widgets
                              Links im Profil
                              • M MCU
                                @skb
                                Danke.
                                SKBS Offline
                                SKBS Offline
                                SKB
                                @mcu Natürlich. Habe 2 Links - ein relativ einfacher Prozess, der funktioniert - mit Ausnahme, dass das Zertifikat so heißt, wie das Programm.
                                Und ein Prozess, der beschreibt, wie der eigene Name drin vorkommt (gefiel mir besser) ;)
                                Wenn ich gleich am Rechner bin, schreibe ich dir die Links dazu.
                                • SKBS Offline
                                  SKBS Offline
                                  SKB
                                  Hier ist der Link, der einfacher ist, aber das Zertifikat den Namen des Programms trägt (nicht weiter schlimm, aber mein Monk mag keine fremden Namen ;) )
                                  https://www.digitalocean.com/community/tutorials/how-to-set-up-and-configure-a-certificate-authority-ca-on-debian-10-de
                                  Bei diesem Link nennst Du deine CA (Cerficate Authority) wie Du möchtest. Sieht irgendwie besser aus:
                                  https://linux-admin-blog.de/2022/04/09/eigene-ca-fuer-zertifikatserstellung/
                                  82.8k
