  4. IoBroker Web nicht mehr unter :8081 verfügbar
63 Beiträge 5 Kommentatoren 9.1k Aufrufe 4 Beobachtet
  • M marcelinho
    @homoran ist drin
    @marcelinho
    Du hast da auch noch andere Böcke drin...
    *** nodejs is NOT correctly installed ***
    Bring das erstmal das Untergeschoß in Ordnung, dann kannst du dich um die oberen Etagen kümmern.
    iob nodejs-update 20
    Pending Updates: 127
    Nach dem nodejs-update einmal sauber neustarten.
    • M marcelinho
      Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.28+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       15:48:00 up  1:02,  3 users,  load average: 1.04, 1.22, 1.50
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-07-01 15:48:00 CEST
                 Universal time: Mon 2024-07-01 13:48:00 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        2.6G        202M        1.1M        1.3G        1.4G
      Swap:           209M        524K        209M
      Total:          4.2G        2.6G        411M
      Active iob-Instances:   24
               3792 M total memory
               2443 M used memory
               1952 M active memory
               1434 M inactive memory
                193 M free memory
                104 M buffer memory
               1127 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 15:48:00 up  1:02,  3 users,  load average: 1.04, 1.22, 1.50
      Tasks: 220 total,   1 running, 219 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 20.0 us, 20.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.1 total,    192.1 free,   2444.2 used,   1232.4 buff/cache
      MiB Swap:    200.0 total,    199.5 free,      0.5 used.   1347.8 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.3M  378M   1% /run
      /dev/mmcblk0p2 ext4       29G   24G  4.2G  85% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
      tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
      [Mon Jul  1 14:45:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Jul  1 14:45:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add-4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
      [Mon Jul  1 14:45:12 2024] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab98-e9f0235e06b3 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE      OPTIONS
      /                                                       /dev/mmcblk0p2 ext4        rw,noatime
      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5370
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1668360k,nr_inodes=417090,mode=755
      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
      `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      11G     /var/
      8.8G    /var/lib
      8.4G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
      Archived and active journals take up 869.0M in the file system.
      /opt/iobroker/backups:
      2.7G    /opt/iobroker/backups/
      1.3G    /opt/iobroker/backups/influxDB_2024_06_11-09_25_30_backupiobroker
      434M    /opt/iobroker/backups/influxDB_2024_06_11-09_35_27_backupiobroker
      /opt/iobroker/iobroker-data:
      396M    /opt/iobroker/iobroker-data/
      273M    /opt/iobroker/iobroker-data/files
      138M    /opt/iobroker/iobroker-data/files/javascript.admin
      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.3
      /usr/local/bin/node             v22.2.0
      /usr/local/bin/npm              10.8.1
      /usr/local/bin/npx              10.8.1
      /usr/local/bin/corepack         0.28.1
      nodejs:
        Installed: 18.20.3-1nodesource1
        Candidate: 18.20.3-1nodesource1
        Version table:
       *** 18.20.3-1nodesource1 600
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           18.20.2-1nodesource1 600
           18.20.1-1nodesource1 600
           18.20.0-1nodesource1 600
           18.19.1-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.17.14
      javascript:     8.3.1
      nodejs modules from github:     3
      +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
      +-- iobroker.fusionsolar@1.2.4 (git+ssh://git@github.com/KornSW/ioBroker.fusionsolar.git#50f776fd8f991d0832be3d660de7a38a4763093d)
      +-- iobroker.smart-eq@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.smart-eq.git#9030604bbf5c6ad568873f80bb24c614600d3c51)
      Adapter State
      + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
      + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
      + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.smart-eq.0               : smart-eq              : raspberrypi                              - disabled
      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.17.14  , installed 6.17.14
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
      Adapter    "homekit-controller": 0.5.10, installed 0.5.10
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "openhab"      : 1.2.0    , installed 1.2.0
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
      Objects and States
      Objects:        16130
      States:         14417
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:8 https://repo.homebridge.io stable InRelease
      Reading package lists...
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:46721         0.0.0.0:*               LISTEN      112        12956      2366/homebridge: ho
      tcp        0      0 127.0.0.1:46833         0.0.0.0:*               LISTEN      112        7839       1241/homebridge: ho
      tcp        0      0 127.0.0.1:38099         0.0.0.0:*               LISTEN      112        7122       1227/homebridge: ho
      tcp        0      0 127.0.0.1:33999         0.0.0.0:*               LISTEN      112        7127       1221/homebridge: @0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6677       783/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       12820      2178/node
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       37539      4541/io.mqtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        8443       778/mosquitto
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       37524      4530/io.shelly.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       38975      4314/node-red
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7319       769/cupsd
      tcp        0      0 127.0.0.1:37791         0.0.0.0:*               LISTEN      112        7817       1213/homebridge: ho
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37945      4243/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37939      4243/iobroker.js-co
      tcp        0      0 127.0.0.1:34933         0.0.0.0:*               LISTEN      112        9350       1246/homebridge: ho
      tcp        0      0 127.0.0.1:39197         0.0.0.0:*               LISTEN      112        9363       1207/homebridge: ho
      tcp        0      0 127.0.0.1:41305         0.0.0.0:*               LISTEN      112        9019       1206/homebridge: ho
      tcp        0      0 127.0.0.1:43369         0.0.0.0:*               LISTEN      112        7856       1230/homebridge: @t
      tcp6       0      0 :::52120                :::*                    LISTEN      112        7785       1246/homebridge: ho
      tcp6       0      0 :::3000                 :::*                    LISTEN      113        6075       965/grafana
      tcp6       0      0 :::47961                :::*                    LISTEN      112        7776       1206/homebridge: ho
      tcp6       0      0 :::39667                :::*                    LISTEN      112        9333       1213/homebridge: ho
      tcp6       0      0 :::51798                :::*                    LISTEN      112        8984       1171/homebridge
      tcp6       0      0 :::8581                 :::*                    LISTEN      112        6135       1099/hb-service
      tcp6       0      0 :::45391                :::*                    LISTEN      112        9054       1221/homebridge: @0
      tcp6       0      0 :::37166                :::*                    LISTEN      112        9014       1207/homebridge: ho
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6679       783/sshd: /usr/sbin
      tcp6       0      0 :::53299                :::*                    LISTEN      112        7099       1227/homebridge: ho
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        8632       884/influxd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       37986      4262/io.admin.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      112        9022       1230/homebridge: @t
      tcp6       0      0 :::1883                 :::*                    LISTEN      114        8444       778/mosquitto
      tcp6       0      0 :::36476                :::*                    LISTEN      112        9028       1230/homebridge: @t
      tcp6       0      0 :::44253                :::*                    LISTEN      112        9013       1241/homebridge: ho
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7318       769/cupsd
      tcp6       0      0 :::52403                :::*                    LISTEN      112        13594      2366/homebridge: ho
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       39954      4445/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       39955      4445/io.tuya.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          7444       875/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        7810       1213/homebridge: ho
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        6132       1099/hb-service
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7187       564/avahi-daemon: r
      udp        0      0 0.0.0.0:36310           0.0.0.0:*                           104        7189       564/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       40071      4563/io.shelly.1
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        9025       1230/homebridge: @t
      udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          5908       696/NetworkManager
      udp6       0      0 :::33612                :::*                                104        7190       564/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        7188       564/avahi-daemon: r
      @marcelinho zusätzlich ist nodejs vollkommen schief installiert und dein Betriebssystem braucht dringend Pflege
      M 2 Antworten Letzte Antwort
        marcelinho
        @homoran ```
        Skript v.2024-05-22
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
         16:03:44 up  1:18,  3 users,  load average: 0.64, 0.43, 0.81
        CPU threads: 4
        Current issues:
                       Local time: Mon 2024-07-01 16:03:44 CEST
                   Universal time: Mon 2024-07-01 14:03:44 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            4.0G        2.6G        240M        1.1M        1.3G        1.4G
        Total:          4.2G        2.6G        449M
                 3792 M total memory
                 2446 M used memory
                 1961 M active memory
                 1389 M inactive memory
                  229 M free memory
                  110 M buffer memory
                 1082 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        top - 16:03:44 up  1:18,  3 users,  load average: 0.64, 0.43, 0.81
        Tasks: 216 total,   1 running, 215 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3792.1 total,    229.4 free,   2446.3 used,   1193.0 buff/cache
        MiB Swap:    200.0 total,    199.5 free,      0.5 used.   1345.7 avail Mem
        *** FILESYSTEM ***
        /var:
        11G     /var/
        8.8G    /var/lib
        397M    /opt/iobroker/iobroker-data/
        26M     /opt/iobroker/iobroker-data/objects.jsonl
        9.3M    /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.17.14
        javascript:     8.3.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        16130
        States:         14417
        2024-07-01 15:49:27.648  - warn: influxdb.0 (4307) Error on writePoint("{"value":1499,"time":"2024-07-01T13:49:13.690Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
        2024-07-01 15:49:27.648  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=6
        2024-07-01 15:49:27.651  - warn: influxdb.0 (4307) Point could not be written to database: admin
        2024-07-01 15:49:27.652  - warn: influxdb.0 (4307) Error on writePoint("{"value":3.6327,"time":"2024-07-01T13:49:10.003Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
        2024-07-01 15:49:27.652  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh to buffer again, error-count=3
        2024-07-01 15:49:27.655  - warn: influxdb.0 (4307) Point could not be written to database: admin
        2024-07-01 15:49:27.655  - warn: influxdb.0 (4307) Error on writePoint("{"value":25.5,"time":"2024-07-01T13:49:12.997Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
        2024-07-01 15:49:27.656  - info: influxdb.0 (4307) Add point that had error for KuecheThermostat to buffer again, error-count=4
        2024-07-01 15:49:27.659  - warn: influxdb.0 (4307) Point could not be written to database: admin
        2024-07-01 15:49:27.659  - warn: influxdb.0 (4307) Error on writePoint("{"value":1982,"time":"2024-07-01T13:49:10.936Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
        2024-07-01 15:49:27.659  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_Power to buffer again, error-count=3
        2024-07-01 15:49:27.664  - warn: influxdb.0 (4307) Point could not be written to database: admin
        2024-07-01 15:49:27.665  - warn: influxdb.0 (4307) Error on writePoint("{"value":25,"time":"2024-07-01T13:49:15.744Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
        2024-07-01 15:49:27.665  - info: influxdb.0 (4307) Add point that had error for KuecheThermostat to buffer again, error-count=5
        2024-07-01 15:49:27.670  - warn: influxdb.0 (4307) Point could not be written to database: admin
        2024-07-01 15:49:27.670  - warn: influxdb.0 (4307) Error on writePoint("{"value":0.254289,"time":"2024-07-01T13:49:10.005Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
        2024-07-01 15:49:27.670  - info: influxdb.0 (4307) Add point that had error for Netzeinspeisung_Tag_Euro to buffer again, error-count=3
        2024-07-01 15:49:46.507  - warn: zigbee2mqtt.0 (4515) Failed to ping 'Nachtlicht Schlafzimmer' (attempt 1/1, Read 0xa4c1388d509aac33/1 genBasic(["zclVersion"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205)))
        2024-07-01 15:52:41.401  - info: tuya.0 (4445) 73103057e868e767b347: Connect locally to device
        2024-07-01 15:52:41.402  - info: tuya.0 (4445) 73103057e868e767b347 Init with IP=192.168.2.128, Key=5xJDx8!3L%N;&}6E, Version=3.3
        2024-07-01 15:59:51.457  - warn: zigbee2mqtt.0 (4515) Failed to ping 'Nachtlicht Schlafzimmer' (attempt 1/1, Read 0xa4c1388d509aac33/1 genBasic(["zclVersion"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205)))
        2024-07-01 16:00:43.795  - info: awtrix-light.0 (4682) error ECONNABORTED from custom?name=pvleistung: timeout of 3000ms exceeded
        2024-07-01 16:00:43.796  - warn: awtrix-light.0 (4682) (custom?name=pvleistung) Unable to update custom app "pvleistung": AxiosError: timeout of 3000ms exceeded
        2024-07-01 16:01:16.414  - info: tuya.0 (4445) 73103057e868e767b347: Connect locally to device
        2024-07-01 16:01:16.415  - info: tuya.0 (4445) 73103057e868e767b347 Init with IP=192.168.2.128, Key=5xJDx8!3L%N;&}6E, Version=3.3
          @marcelinho
          marcelinho
          @thomas-braun danke mache ich
            marcelinho
            @homoran danke bin gerade dabei mache einen neustart und lade eine neue iob diag hoch
            • M marcelinho
              marcelinho
              schrieb am zuletzt editiert von marcelinho
              @Homoran und @Thomas-Braun so hat etwas länger gedauert, habe nun: iob nodejs-update 20 und einen restart gemacht, nun die neue:
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
               16:31:41 up  1:46,  3 users,  load average: 6.76, 4.50, 3.06
              CPU threads: 4
              Current issues:
                             Local time: Mon 2024-07-01 16:31:41 CEST
                         Universal time: Mon 2024-07-01 14:31:41 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.0G        2.6G         49M        823K        1.4G        1.4G
              Swap:           209M        3.9M        205M
              Total:          4.2G        2.6G        254M
              Active iob-Instances:   16
                       3792 M total memory
                       2490 M used memory
                       2659 M active memory
                        806 M inactive memory
                         46 M free memory
                        220 M buffer memory
                       1111 M swap cache
                        199 M total swap
                          3 M used swap
                        196 M free swap
              top - 16:31:41 up  1:46,  3 users,  load average: 6.76, 4.50, 3.06
              Tasks: 217 total,   2 running, 215 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 14.3 us, 28.6 sy,  0.0 ni, 42.9 id,  0.0 wa,  0.0 hi, 14.3 si,  0.0 st
              MiB Mem :   3792.1 total,     43.1 free,   2493.4 used,   1332.3 buff/cache
              MiB Swap:    200.0 total,    196.2 free,      3.8 used.   1298.7 avail Mem
              *** FILESYSTEM ***
              /dev/mmcblk0p2 ext4       29G   24G  3.7G  87% /
              [Mon Jul  1 14:45:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
              [Mon Jul  1 14:45:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add        -4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
              [Mon Jul  1 14:45:12 2024] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab        98-e9f0235e06b3 r/w. Quota mode: none.
              | |-/sys/kernel/security                                securityfs     securityf        s  rw,nosuid,nodev,noexec,relatime
              |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_mi        sc rw,nosuid,nodev,noexec,relatime
              | |-/run/rpc_pipefs                                     sunrpc         rpc_pipef        s  rw,relatime
              | `-/run/user/1000                                      tmpfs          tmpfs        rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1        000
              `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixe        d,errors=remount-ro
              /var:
              12G     /var/
              8.8G    /var/lib
              403M    /opt/iobroker/iobroker-data/
              31M     /opt/iobroker/iobroker-data/objects.jsonl
              9.8M    /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              /usr/bin/nodejs         v20.15.0
              /usr/bin/node           v20.15.0
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              /usr/bin/corepack       0.28.1
              nodejs:
                Installed: 20.15.0-1nodesource1
                Candidate: 20.15.0-1nodesource1
                Version table:
               *** 20.15.0-1nodesource1 600
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                   20.14.0-1nodesource1 600
                   20.13.1-1nodesource1 600
                   20.13.0-1nodesource1 600
                   20.12.2-1nodesource1 600
                   20.12.1-1nodesource1 600
                   20.12.0-1nodesource1 600
                   20.11.1-1nodesource1 600
                   20.11.0-1nodesource1 600
                   20.10.0-1nodesource1 600
                   20.9.0-1nodesource1 600
                   20.8.1-1nodesource1 600
                   20.8.0-1nodesource1 600
                   20.7.0-1nodesource1 600
                   20.6.1-1nodesource1 600
                   20.6.0-1nodesource1 600
                   20.5.1-1nodesource1 600
                   20.5.0-1nodesource1 600
                   20.4.0-1nodesource1 600
                   20.3.1-1nodesource1 600
                   20.3.0-1nodesource1 600
                   20.2.0-1nodesource1 600
                   20.1.0-1nodesource1 600
                   20.0.0-1nodesource1 600
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.17.14
              javascript:     8.3.1
              Adapter State
              + instance is alive
              Objects and States
              Objects:        16130
              States:         14429
              Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
              Pending Updates: 0
              tcp        0      0 127.0.0.1:34457         0.0.0.0:*               LISTEN      112        98074      15199/homebridge: h
              tcp        0      0 127.0.0.1:40099         0.0.0.0:*               LISTEN      112        97094      15160/homebridge: h
              tcp        0      0 127.0.0.1:46159         0.0.0.0:*               LISTEN      112        98066      15192/homebridge: h
              tcp        0      0 127.0.0.1:46189         0.0.0.0:*               LISTEN      112        99401      15179/homebridge: h
              tcp        0      0 127.0.0.1:40347         0.0.0.0:*               LISTEN      112        99390      15173/homebridge: @
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          97314      14853/sshd: /usr/sb
              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       111759     31894/io.mqtt.0
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       111751     31853/io.shelly.0
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       109182     31623/node-red
              tcp        0      0 127.0.0.1:33705         0.0.0.0:*               LISTEN      112        98044      15166/homebridge: h
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       107271     31547/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       107266     31547/iobroker.js-c
              tcp        0      0 127.0.0.1:33645         0.0.0.0:*               LISTEN      112        98537      15185/homebridge: @
              tcp        0      0 127.0.0.1:45557         0.0.0.0:*               LISTEN      112        97072      15159/homebridge: h
              tcp        0      0 127.0.0.1:41221         0.0.0.0:*               LISTEN      112        97126      15168/homebridge: h
              tcp6       0      0 :::52120                :::*                    LISTEN      112        97079      15199/homebridge: h
              tcp6       0      0 :::3000                 :::*                    LISTEN      113        94967      14664/grafana
              tcp6       0      0 :::47961                :::*                    LISTEN      112        98025      15159/homebridge: h
              tcp6       0      0 :::39667                :::*                    LISTEN      112        98481      15166/homebridge: h
              tcp6       0      0 :::51798                :::*                    LISTEN      112        98419      15079/homebridge
              tcp6       0      0 :::8581                 :::*                    LISTEN      112        96103      15037/hb-service
              tcp6       0      0 :::45391                :::*                    LISTEN      112        97115      15173/homebridge: @
              tcp6       0      0 :::37166                :::*                    LISTEN      112        98476      15160/homebridge: h
              tcp6       0      0 :::22                   :::*                    LISTEN      0          97316      14853/sshd: /usr/sb
              tcp6       0      0 :::53299                :::*                    LISTEN      112        98548      15179/homebridge: h
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       109851     31571/io.admin.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      112        98498      15185/homebridge: @
              tcp6       0      0 :::36476                :::*                    LISTEN      112        97092      15185/homebridge: @
              tcp6       0      0 :::44253                :::*                    LISTEN      112        98037      15192/homebridge: h
              tcp6       0      0 :::52403                :::*                    LISTEN      112        97065      15168/homebridge: h
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       111705     31735/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       111706     31735/io.tuya.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        98083      15166/homebridge: h
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        96100      15037/hb-service
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       111790     31915/io.shelly.1
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        97083      15185/homebridge: @
              was compiled against a different Node.js version using
              NODE_MODULE_VERSION 120. This version of Node.js requires
              NODE_MODULE_VERSION 115. Please try re-compiling or re-installing
              the module (for instance, using `npm rebuild` or `npm install`).
              2024-07-01 16:31:47.421  - warn: ecovacs-deebot.0 (32008) The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
              2024-07-01 16:31:47.643  - warn: ecovacs-deebot.0 (32008) The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
              2024-07-01 16:31:50.194  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus1-fcb467bf172c" connected!
              2024-07-01 16:31:54.649  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-d4d4dae918f0" connected!
              2024-07-01 16:31:58.510  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-fcb467a697e8" connected!
              2024-07-01 16:31:59.599  - error: zigbee2mqtt.0 (31821) Publish 'set' 'state' to 'Nachtlicht Schlafzimmer' failed: 'Error: Command 0xa4c1388d509aac33/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
              2024-07-01 16:31:59.602  - error: zigbee2mqtt.0 (31821) Publish 'set' 'system_mode' to 'Thermostat Badezimmer OG' failed: 'Error: Command 0xa4c1380ceefe7b79/1 manuSpecificTuya.dataRequest({"seq":1,"dpValues":[{"dp":2,"datatype":4,"data":[2]}]}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
              2024-07-01 16:32:00.442  - info: cloud.0 (31736) Trying to connect as system.user.admin to cloud
              2024-07-01 16:32:00.551  - info: cloud.0 (31736) Connection changed: connect
              2024-07-01 16:32:04.600  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-fcb467a5f910" connected!
              2024-07-01 16:32:22.028  - error: zigbee2mqtt.0 (31821) Publish 'get' 'state' to 'Nachtlicht Schlafzimmer' failed: 'Error: Read 0xa4c1388d509aac33/1 genOnOff(["onOff"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
              2024-07-01 16:32:22.033  - error: zigbee2mqtt.0 (31821) Publish 'get' 'color_temp' to 'Nachtlicht Schlafzimmer' failed: 'Error: Cluster 'lightingColorCtrl' has no attribute 'currentLevel''
              2024-07-01 16:32:22.038  - error: zigbee2mqtt.0 (31821) Publish 'get' 'color' to 'Nachtlicht Schlafzimmer' failed: 'Error: Cluster 'lightingColorCtrl' has no attribute 'currentLevel''
              • M marcelinho
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                         3792 M total memory
                         2490 M used memory
                           46 M free memory
                          220 M buffer memory
                         1111 M swap cache
                          199 M total swap
                            3 M used swap
                          196 M free swap
                *** FILESYSTEM ***
                /var:
                12G     /var/
                8.8G    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.17.14
                javascript:     8.3.1
                Adapter State
                + instance is alive
                Objects and States
                Objects:        16130
                States:         14429
                Pending Updates: 0
                @marcelinho sagte in IoBroker Web nicht mehr unter :8081 verfügbar:
                tc
                8081 für den admin wird hier bereits genutzt
                der web Adapter läuft nicht weil 8082 hier
                für den Admin verwendet wird, obwohl er hier
                mit Port 8081 konfiguriert ist
                  tc
                  marcelinho
                  @homoran habe nun auf :8083 geändert jetzt läuft es anscheinend Screenshot 2024-07-01 164108.png Screenshot 2024-07-01 164119.png
                  • M marcelinho
                    und der admin?
                      und der admin?
                      marcelinho
                                              v.2024-05-22
                             Icon name: computer
                          Architecture: arm64
                      Kernel:                 aarch64
                      Userland:               64 bit
                      User-ID:                1000
                      Pending OS-Updates:     0
                      Pending iob updates:    0
                      Nodejs-Installation:
                      /usr/bin/npm            10.7.0
                      /usr/bin/npx            10.7.0
                      Recommended versions are nodejs 18.20.3 and npm 10.7.0
                      MEMORY:
                      Mem:            4.0G        2.4G        208M        147K        1.5G        1.6G
                      Swap:           209M        4.7M        204M
                      Total:          4.2G        2.4G        413M
                      ioBroker Core:          js-controller           5.0.19
                                              admin                   6.17.14
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                16130
                      States:                 14429
                      Size of iob-Database:
                      32M     /opt/iobroker/iobroker-data/objects.jsonl
                      11M     /opt/iobroker/iobroker-data/states.jsonl
                      • M marcelinho
                                                v.2024-05-22
                               Icon name: computer
                            Architecture: arm64
                        Kernel:                 aarch64
                        Userland:               64 bit
                        User-ID:                1000
                        /usr/bin/npm            10.7.0
                        /usr/bin/npx            10.7.0
                        MEMORY:
                                                admin                   6.17.14
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                16130
                        States:                 14429
                        web noch auf 8082 und läuft nicht
                        admin auf 8081umd läuft.
                        Hast du 2 Installationen parallel laufen?
                          marcelinho
                          @homoran eigentlich nicht - zumindest nicht das ich wüsste
                          • M marcelinho
                            die Daten in iob diag passen nicht zu deinen Aussagen und Screenshots
                              marcelinho
                              @homoran auf die Weboberfläche bin ich immer mit :8081 gekommen jetzt komme ich mit :8082 drauf seit ich den oben erwähnten Adapter installiert habe auf der :8082 bin ich in IoBroker Oberfläche und auf der :8082 kommt das: Screenshot 2024-07-01 165102.png was eigentlich vorher die Weboberfläche von IoBroker war deswegen bin ich verwirrt. Screenshot 2024-07-01 165202.png
                              • M marcelinho
                                das passt ja zu
                                @homoran sagte in IoBroker Web nicht mehr unter :8081 verfügbar:
                                tc
                                  das passt ja zu
                                  tc
                                  marcelinho
                                  @homoran und wie kann ich es wieder ändern? ich bin verwirrt sorry für die Umstände.
                                  • M marcelinho
                                    das sollte eigentlich nicht der Auslöser sein, aber vielleicht sieht sich das @skb mal an.
                                    Das Durcheinander mit den Ports hängt eher an IPv4 vs IPv6 und der Installation weiterer Software die die selben Ports nutzt.
                                    M SKBS 2 Antworten Letzte Antwort
                                      marcelinho
                                      @homoran danke für deine bisherige Hilfe und Mühe
                                      • M marcelinho
                                        keine Ahnung.
                                        Ich weiss zwar schon einiges aber immer noch viel zu wenig.
                                        Ich kann hier nur die Fakten zusammentragen um zu zeigen wo es klemmen wird.
                                          keine Ahnung.
                                          marcelinho
                                          @homoran aber anscheinend geht es wieder bis auf dass ich jetzt auf :8082 aufrufen muss... Vorher war zb iqontrol nicht erreichbar aber jetzt geht es wieder...web adapter ist grün... komisch irgendwie
