  4. IoBroker Web nicht mehr unter :8081 verfügbar
63 Beiträge 5 Kommentatoren 9.1k Aufrufe 4 Beobachtet
  • MartinPM Online
    MartinPM Online
    MartinP
    Da ein Update sowieso einen iob-Neustart gemacht hat hier mal die Logging von meiner iob Instanz
    93
    Log-Größe: 115.3 KB
    Zeit
    Nachricht
    web.0
    	2024-07-01 13:16:05.855	info	starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.15.0, js-controller: 5.0.19
    web.0
    	2024-07-01 13:16:07.182	info	socket.io server listening on port 8082
    web.0
    	2024-07-01 13:16:07.225	info	http server listening on port 8082
    • MartinPM MartinP
      93
      Log-Größe: 115.3 KB
      Zeit
      Nachricht
      web.0
      web.0
      web.0
      @martinp Was willst du uns damit sagen?
        marcelinho
        Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.6.28+rpt-rpi-v8
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         15:48:00 up  1:02,  3 users,  load average: 1.04, 1.22, 1.50
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2024-07-01 15:48:00 CEST
                   Universal time: Mon 2024-07-01 13:48:00 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            4.0G        2.6G        202M        1.1M        1.3G        1.4G
        Swap:           209M        524K        209M
        Total:          4.2G        2.6G        411M
        Active iob-Instances:   24
                 3792 M total memory
                 2443 M used memory
                 1952 M active memory
                 1434 M inactive memory
                  193 M free memory
                  104 M buffer memory
                 1127 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        top - 15:48:00 up  1:02,  3 users,  load average: 1.04, 1.22, 1.50
        Tasks: 220 total,   1 running, 219 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 20.0 us, 20.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3792.1 total,    192.1 free,   2444.2 used,   1232.4 buff/cache
        MiB Swap:    200.0 total,    199.5 free,      0.5 used.   1347.8 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  1.3M  378M   1% /run
        /dev/mmcblk0p2 ext4       29G   24G  4.2G  85% /
        tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
        tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
        [Mon Jul  1 14:45:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Jul  1 14:45:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add-4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
        [Mon Jul  1 14:45:12 2024] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab98-e9f0235e06b3 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET                                                  SOURCE         FSTYPE      OPTIONS
        /                                                       /dev/mmcblk0p2 ext4        rw,noatime
        |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
        |-/proc                                                 proc           proc        rw,relatime
        | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5370
        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1668360k,nr_inodes=417090,mode=755
        | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
        | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
        |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
        | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
        `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        11G     /var/
        8.8G    /var/lib
        8.4G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
        Archived and active journals take up 869.0M in the file system.
        /opt/iobroker/backups:
        2.7G    /opt/iobroker/backups/
        1.3G    /opt/iobroker/backups/influxDB_2024_06_11-09_25_30_backupiobroker
        434M    /opt/iobroker/backups/influxDB_2024_06_11-09_35_27_backupiobroker
        /opt/iobroker/iobroker-data:
        396M    /opt/iobroker/iobroker-data/
        273M    /opt/iobroker/iobroker-data/files
        138M    /opt/iobroker/iobroker-data/files/javascript.admin
        118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
        8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.3
        /usr/local/bin/node             v22.2.0
        /usr/local/bin/npm              10.8.1
        /usr/local/bin/npx              10.8.1
        /usr/local/bin/corepack         0.28.1
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 18.20.3-1nodesource1
          Candidate: 18.20.3-1nodesource1
          Version table:
         *** 18.20.3-1nodesource1 600
                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
             18.20.2-1nodesource1 600
             18.20.1-1nodesource1 600
             18.20.0-1nodesource1 600
             18.19.1-1nodesource1 600
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
             18.19.0-1nodesource1 600
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        admin:          6.17.14
        javascript:     8.3.1
        nodejs modules from github:     3
        +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
        +-- iobroker.fusionsolar@1.2.4 (git+ssh://git@github.com/KornSW/ioBroker.fusionsolar.git#50f776fd8f991d0832be3d660de7a38a4763093d)
        +-- iobroker.smart-eq@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.smart-eq.git#9030604bbf5c6ad568873f80bb24c614600d3c51)
        Adapter State
        + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
        + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
        + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
        + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
        + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
        + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.smart-eq.0               : smart-eq              : raspberrypi                              - disabled
        + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.17.14  , installed 6.17.14
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "awtrix-light" : 1.2.0    , installed 1.2.0
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "daikin"       : 1.4.2    , installed 1.4.2
        Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "homekit-controller": 0.5.10, installed 0.5.10
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "javascript"   : 8.3.1    , installed 8.3.1
        Controller "js-controller": 5.0.19   , installed 5.0.19
        Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
        Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "openhab"      : 1.2.0    , installed 1.2.0
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
        Objects and States
        Objects:        16130
        States:         14417
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:8 https://repo.homebridge.io stable InRelease
        Reading package lists...
        Pending Updates: 127
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:46721         0.0.0.0:*               LISTEN      112        12956      2366/homebridge: ho
        tcp        0      0 127.0.0.1:46833         0.0.0.0:*               LISTEN      112        7839       1241/homebridge: ho
        tcp        0      0 127.0.0.1:38099         0.0.0.0:*               LISTEN      112        7122       1227/homebridge: ho
        tcp        0      0 127.0.0.1:33999         0.0.0.0:*               LISTEN      112        7127       1221/homebridge: @0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6677       783/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       12820      2178/node
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       37539      4541/io.mqtt.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        8443       778/mosquitto
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       37524      4530/io.shelly.0
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       38975      4314/node-red
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7319       769/cupsd
        tcp        0      0 127.0.0.1:37791         0.0.0.0:*               LISTEN      112        7817       1213/homebridge: ho
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       37945      4243/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37939      4243/iobroker.js-co
        tcp        0      0 127.0.0.1:34933         0.0.0.0:*               LISTEN      112        9350       1246/homebridge: ho
        tcp        0      0 127.0.0.1:39197         0.0.0.0:*               LISTEN      112        9363       1207/homebridge: ho
        tcp        0      0 127.0.0.1:41305         0.0.0.0:*               LISTEN      112        9019       1206/homebridge: ho
        tcp        0      0 127.0.0.1:43369         0.0.0.0:*               LISTEN      112        7856       1230/homebridge: @t
        tcp6       0      0 :::52120                :::*                    LISTEN      112        7785       1246/homebridge: ho
        tcp6       0      0 :::3000                 :::*                    LISTEN      113        6075       965/grafana
        tcp6       0      0 :::47961                :::*                    LISTEN      112        7776       1206/homebridge: ho
        tcp6       0      0 :::39667                :::*                    LISTEN      112        9333       1213/homebridge: ho
        tcp6       0      0 :::51798                :::*                    LISTEN      112        8984       1171/homebridge
        tcp6       0      0 :::8581                 :::*                    LISTEN      112        6135       1099/hb-service
        tcp6       0      0 :::45391                :::*                    LISTEN      112        9054       1221/homebridge: @0
        tcp6       0      0 :::37166                :::*                    LISTEN      112        9014       1207/homebridge: ho
        tcp6       0      0 :::22                   :::*                    LISTEN      0          6679       783/sshd: /usr/sbin
        tcp6       0      0 :::53299                :::*                    LISTEN      112        7099       1227/homebridge: ho
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        8632       884/influxd
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       37986      4262/io.admin.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      112        9022       1230/homebridge: @t
        tcp6       0      0 :::1883                 :::*                    LISTEN      114        8444       778/mosquitto
        tcp6       0      0 :::36476                :::*                    LISTEN      112        9028       1230/homebridge: @t
        tcp6       0      0 :::44253                :::*                    LISTEN      112        9013       1241/homebridge: ho
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7318       769/cupsd
        tcp6       0      0 :::52403                :::*                    LISTEN      112        13594      2366/homebridge: ho
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       39954      4445/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       39955      4445/io.tuya.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          7444       875/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        7810       1213/homebridge: ho
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        6132       1099/hb-service
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7187       564/avahi-daemon: r
        udp        0      0 0.0.0.0:36310           0.0.0.0:*                           104        7189       564/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       40071      4563/io.shelly.1
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        9025       1230/homebridge: @t
        udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          5908       696/NetworkManager
        udp6       0      0 :::33612                :::*                                104        7190       564/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        7188       564/avahi-daemon: r
          @marcelinho sagte in IoBroker Web nicht mehr unter :8081 verfügbar:
          @homoran ich glaube schon bin mir nicht sicher, was kann ich tun ?
          iob diag in der Langfassung bitte!
          ich glaube es nämlich nicht! admin belegt nach wie vor 8081
          marcelinho
          @homoran ist drin
          • M marcelinho
            @homoran ist drin
            @homoran ist drin
            was?
            und
            der läuft aber nicht
            leider ist die Ausgabe unvollständig
            Da blockieren einige andere Anwendungen die Ports.
            ggf. hat IoBroker bei der Installation nicht die standardmäßigen Ports genommen, weil die belegt waren.
            Außerdem sind 8081 und 8082 nur per tcpv6 erreichbar
            • M marcelinho
              @homoran ist drin
              @marcelinho
              Du hast da auch noch andere Böcke drin...
              Bring das erstmal das Untergeschoß in Ordnung, dann kannst du dich um die oberen Etagen kümmern.
              iob nodejs-update 20
              Nach dem nodejs-update einmal sauber neustarten.
              • M marcelinho
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                         3792 M total memory
                         2443 M used memory
                          193 M free memory
                          104 M buffer memory
                         1127 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                *** FILESYSTEM ***
                /var:
                11G     /var/
                8.8G    /var/lib
                USB-Devices by-id:
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.17.14
                javascript:     8.3.1
                Adapter State
                + instance is alive
                Objects and States
                Objects:        16130
                States:         14417
                @marcelinho zusätzlich ist nodejs vollkommen schief installiert und dein Betriebssystem braucht dringend Pflege
                M 2 Antworten Letzte Antwort
                  marcelinho
                  @homoran ```
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   16:03:44 up  1:18,  3 users,  load average: 0.64, 0.43, 0.81
                  CPU threads: 4
                  Current issues:
                                 Local time: Mon 2024-07-01 16:03:44 CEST
                             Universal time: Mon 2024-07-01 14:03:44 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.0G        2.6G        240M        1.1M        1.3G        1.4G
                  Total:          4.2G        2.6G        449M
                           3792 M total memory
                           2446 M used memory
                           1961 M active memory
                           1389 M inactive memory
                            229 M free memory
                            110 M buffer memory
                           1082 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  top - 16:03:44 up  1:18,  3 users,  load average: 0.64, 0.43, 0.81
                  Tasks: 216 total,   1 running, 215 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   3792.1 total,    229.4 free,   2446.3 used,   1193.0 buff/cache
                  MiB Swap:    200.0 total,    199.5 free,      0.5 used.   1345.7 avail Mem
                  *** FILESYSTEM ***
                  /var:
                  11G     /var/
                  8.8G    /var/lib
                  397M    /opt/iobroker/iobroker-data/
                  26M     /opt/iobroker/iobroker-data/objects.jsonl
                  9.3M    /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.17.14
                  javascript:     8.3.1
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        16130
                  States:         14417
                  2024-07-01 15:49:27.648  - warn: influxdb.0 (4307) Error on writePoint("{"value":1499,"time":"2024-07-01T13:49:13.690Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-07-01 15:49:27.648  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=6
                  2024-07-01 15:49:27.651  - warn: influxdb.0 (4307) Point could not be written to database: admin
                  2024-07-01 15:49:27.652  - warn: influxdb.0 (4307) Error on writePoint("{"value":3.6327,"time":"2024-07-01T13:49:10.003Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-07-01 15:49:27.652  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh to buffer again, error-count=3
                  2024-07-01 15:49:27.655  - warn: influxdb.0 (4307) Point could not be written to database: admin
                  2024-07-01 15:49:27.655  - warn: influxdb.0 (4307) Error on writePoint("{"value":25.5,"time":"2024-07-01T13:49:12.997Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-07-01 15:49:27.656  - info: influxdb.0 (4307) Add point that had error for KuecheThermostat to buffer again, error-count=4
                  2024-07-01 15:49:27.659  - warn: influxdb.0 (4307) Point could not be written to database: admin
                  2024-07-01 15:49:27.659  - warn: influxdb.0 (4307) Error on writePoint("{"value":1982,"time":"2024-07-01T13:49:10.936Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-07-01 15:49:27.659  - info: influxdb.0 (4307) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_Power to buffer again, error-count=3
                  2024-07-01 15:49:27.664  - warn: influxdb.0 (4307) Point could not be written to database: admin
                  2024-07-01 15:49:27.665  - warn: influxdb.0 (4307) Error on writePoint("{"value":25,"time":"2024-07-01T13:49:15.744Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-07-01 15:49:27.665  - info: influxdb.0 (4307) Add point that had error for KuecheThermostat to buffer again, error-count=5
                  2024-07-01 15:49:27.670  - warn: influxdb.0 (4307) Point could not be written to database: admin
                  2024-07-01 15:49:27.670  - warn: influxdb.0 (4307) Error on writePoint("{"value":0.254289,"time":"2024-07-01T13:49:10.005Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-07-01 15:49:27.670  - info: influxdb.0 (4307) Add point that had error for Netzeinspeisung_Tag_Euro to buffer again, error-count=3
                  2024-07-01 15:49:46.507  - warn: zigbee2mqtt.0 (4515) Failed to ping 'Nachtlicht Schlafzimmer' (attempt 1/1, Read 0xa4c1388d509aac33/1 genBasic(["zclVersion"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205)))
                  2024-07-01 15:52:41.401  - info: tuya.0 (4445) 73103057e868e767b347: Connect locally to device
                  2024-07-01 15:52:41.402  - info: tuya.0 (4445) 73103057e868e767b347 Init with IP=192.168.2.128, Key=5xJDx8!3L%N;&}6E, Version=3.3
                  2024-07-01 15:59:51.457  - warn: zigbee2mqtt.0 (4515) Failed to ping 'Nachtlicht Schlafzimmer' (attempt 1/1, Read 0xa4c1388d509aac33/1 genBasic(["zclVersion"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205)))
                  2024-07-01 16:00:43.795  - info: awtrix-light.0 (4682) error ECONNABORTED from custom?name=pvleistung: timeout of 3000ms exceeded
                  2024-07-01 16:00:43.796  - warn: awtrix-light.0 (4682) (custom?name=pvleistung) Unable to update custom app "pvleistung": AxiosError: timeout of 3000ms exceeded
                  2024-07-01 16:01:16.414  - info: tuya.0 (4445) 73103057e868e767b347: Connect locally to device
                  2024-07-01 16:01:16.415  - info: tuya.0 (4445) 73103057e868e767b347 Init with IP=192.168.2.128, Key=5xJDx8!3L%N;&}6E, Version=3.3
                    @marcelinho
                    marcelinho
                    @thomas-braun danke mache ich
                      marcelinho
                      @homoran danke bin gerade dabei mache einen neustart und lade eine neue iob diag hoch
                      • M marcelinho
                        marcelinho
                        schrieb am zuletzt editiert von marcelinho
                        @Homoran und @Thomas-Braun so hat etwas länger gedauert, habe nun: iob nodejs-update 20 und einen restart gemacht, nun die neue:
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         16:31:41 up  1:46,  3 users,  load average: 6.76, 4.50, 3.06
                        CPU threads: 4
                        Current issues:
                                       Local time: Mon 2024-07-01 16:31:41 CEST
                                   Universal time: Mon 2024-07-01 14:31:41 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            4.0G        2.6G         49M        823K        1.4G        1.4G
                        Swap:           209M        3.9M        205M
                        Total:          4.2G        2.6G        254M
                        Active iob-Instances:   16
                                 3792 M total memory
                                 2490 M used memory
                                 2659 M active memory
                                  806 M inactive memory
                                   46 M free memory
                                  220 M buffer memory
                                 1111 M swap cache
                                  199 M total swap
                                    3 M used swap
                                  196 M free swap
                        top - 16:31:41 up  1:46,  3 users,  load average: 6.76, 4.50, 3.06
                        Tasks: 217 total,   2 running, 215 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 14.3 us, 28.6 sy,  0.0 ni, 42.9 id,  0.0 wa,  0.0 hi, 14.3 si,  0.0 st
                        MiB Mem :   3792.1 total,     43.1 free,   2493.4 used,   1332.3 buff/cache
                        MiB Swap:    200.0 total,    196.2 free,      3.8 used.   1298.7 avail Mem
                        *** FILESYSTEM ***
                        /dev/mmcblk0p2 ext4       29G   24G  3.7G  87% /
                        [Mon Jul  1 14:45:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
                        [Mon Jul  1 14:45:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add        -4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
                        [Mon Jul  1 14:45:12 2024] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab        98-e9f0235e06b3 r/w. Quota mode: none.
                        | |-/sys/kernel/security                                securityfs     securityf        s  rw,nosuid,nodev,noexec,relatime
                        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_mi        sc rw,nosuid,nodev,noexec,relatime
                        | |-/run/rpc_pipefs                                     sunrpc         rpc_pipef        s  rw,relatime
                        | `-/run/user/1000                                      tmpfs          tmpfs        rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1        000
                        `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixe        d,errors=remount-ro
                        /var:
                        12G     /var/
                        8.8G    /var/lib
                        403M    /opt/iobroker/iobroker-data/
                        31M     /opt/iobroker/iobroker-data/objects.jsonl
                        9.8M    /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        /usr/bin/nodejs         v20.15.0
                        /usr/bin/node           v20.15.0
                        /usr/bin/npm            10.7.0
                        /usr/bin/npx            10.7.0
                        /usr/bin/corepack       0.28.1
                        nodejs:
                          Installed: 20.15.0-1nodesource1
                          Candidate: 20.15.0-1nodesource1
                          Version table:
                         *** 20.15.0-1nodesource1 600
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                             20.14.0-1nodesource1 600
                             20.13.1-1nodesource1 600
                             20.13.0-1nodesource1 600
                             20.12.2-1nodesource1 600
                             20.12.1-1nodesource1 600
                             20.12.0-1nodesource1 600
                             20.11.1-1nodesource1 600
                             20.11.0-1nodesource1 600
                             20.10.0-1nodesource1 600
                             20.9.0-1nodesource1 600
                             20.8.1-1nodesource1 600
                             20.8.0-1nodesource1 600
                             20.7.0-1nodesource1 600
                             20.6.1-1nodesource1 600
                             20.6.0-1nodesource1 600
                             20.5.1-1nodesource1 600
                             20.5.0-1nodesource1 600
                             20.4.0-1nodesource1 600
                             20.3.1-1nodesource1 600
                             20.3.0-1nodesource1 600
                             20.2.0-1nodesource1 600
                             20.1.0-1nodesource1 600
                             20.0.0-1nodesource1 600
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.17.14
                        javascript:     8.3.1
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        16130
                        States:         14429
                        Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:34457         0.0.0.0:*               LISTEN      112        98074      15199/homebridge: h
                        tcp        0      0 127.0.0.1:40099         0.0.0.0:*               LISTEN      112        97094      15160/homebridge: h
                        tcp        0      0 127.0.0.1:46159         0.0.0.0:*               LISTEN      112        98066      15192/homebridge: h
                        tcp        0      0 127.0.0.1:46189         0.0.0.0:*               LISTEN      112        99401      15179/homebridge: h
                        tcp        0      0 127.0.0.1:40347         0.0.0.0:*               LISTEN      112        99390      15173/homebridge: @
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          97314      14853/sshd: /usr/sb
                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       111759     31894/io.mqtt.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       111751     31853/io.shelly.0
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       109182     31623/node-red
                        tcp        0      0 127.0.0.1:33705         0.0.0.0:*               LISTEN      112        98044      15166/homebridge: h
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       107271     31547/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       107266     31547/iobroker.js-c
                        tcp        0      0 127.0.0.1:33645         0.0.0.0:*               LISTEN      112        98537      15185/homebridge: @
                        tcp        0      0 127.0.0.1:45557         0.0.0.0:*               LISTEN      112        97072      15159/homebridge: h
                        tcp        0      0 127.0.0.1:41221         0.0.0.0:*               LISTEN      112        97126      15168/homebridge: h
                        tcp6       0      0 :::52120                :::*                    LISTEN      112        97079      15199/homebridge: h
                        tcp6       0      0 :::3000                 :::*                    LISTEN      113        94967      14664/grafana
                        tcp6       0      0 :::47961                :::*                    LISTEN      112        98025      15159/homebridge: h
                        tcp6       0      0 :::39667                :::*                    LISTEN      112        98481      15166/homebridge: h
                        tcp6       0      0 :::51798                :::*                    LISTEN      112        98419      15079/homebridge
                        tcp6       0      0 :::8581                 :::*                    LISTEN      112        96103      15037/hb-service
                        tcp6       0      0 :::45391                :::*                    LISTEN      112        97115      15173/homebridge: @
                        tcp6       0      0 :::37166                :::*                    LISTEN      112        98476      15160/homebridge: h
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          97316      14853/sshd: /usr/sb
                        tcp6       0      0 :::53299                :::*                    LISTEN      112        98548      15179/homebridge: h
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       109851     31571/io.admin.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      112        98498      15185/homebridge: @
                        tcp6       0      0 :::36476                :::*                    LISTEN      112        97092      15185/homebridge: @
                        tcp6       0      0 :::44253                :::*                    LISTEN      112        98037      15192/homebridge: h
                        tcp6       0      0 :::52403                :::*                    LISTEN      112        97065      15168/homebridge: h
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       111705     31735/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       111706     31735/io.tuya.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        98083      15166/homebridge: h
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        96100      15037/hb-service
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       111790     31915/io.shelly.1
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           112        97083      15185/homebridge: @
                        was compiled against a different Node.js version using
                        NODE_MODULE_VERSION 120. This version of Node.js requires
                        NODE_MODULE_VERSION 115. Please try re-compiling or re-installing
                        the module (for instance, using `npm rebuild` or `npm install`).
                        2024-07-01 16:31:47.421  - warn: ecovacs-deebot.0 (32008) The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                        2024-07-01 16:31:47.643  - warn: ecovacs-deebot.0 (32008) The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                        2024-07-01 16:31:50.194  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus1-fcb467bf172c" connected!
                        2024-07-01 16:31:54.649  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-d4d4dae918f0" connected!
                        2024-07-01 16:31:58.510  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-fcb467a697e8" connected!
                        2024-07-01 16:31:59.599  - error: zigbee2mqtt.0 (31821) Publish 'set' 'state' to 'Nachtlicht Schlafzimmer' failed: 'Error: Command 0xa4c1388d509aac33/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
                        2024-07-01 16:31:59.602  - error: zigbee2mqtt.0 (31821) Publish 'set' 'system_mode' to 'Thermostat Badezimmer OG' failed: 'Error: Command 0xa4c1380ceefe7b79/1 manuSpecificTuya.dataRequest({"seq":1,"dpValues":[{"dp":2,"datatype":4,"data":[2]}]}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
                        2024-07-01 16:32:00.442  - info: cloud.0 (31736) Trying to connect as system.user.admin to cloud
                        2024-07-01 16:32:00.551  - info: cloud.0 (31736) Connection changed: connect
                        2024-07-01 16:32:04.600  - info: shelly.0 (31853) [MQTT] Device with client id "shellyplus2pm-fcb467a5f910" connected!
                        2024-07-01 16:32:22.028  - error: zigbee2mqtt.0 (31821) Publish 'get' 'state' to 'Nachtlicht Schlafzimmer' failed: 'Error: Read 0xa4c1388d509aac33/1 genOnOff(["onOff"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
                        2024-07-01 16:32:22.033  - error: zigbee2mqtt.0 (31821) Publish 'get' 'color_temp' to 'Nachtlicht Schlafzimmer' failed: 'Error: Cluster 'lightingColorCtrl' has no attribute 'currentLevel''
                        2024-07-01 16:32:22.038  - error: zigbee2mqtt.0 (31821) Publish 'get' 'color' to 'Nachtlicht Schlafzimmer' failed: 'Error: Cluster 'lightingColorCtrl' has no attribute 'currentLevel''
                        • M marcelinho
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                                   3792 M total memory
                                   2490 M used memory
                                     46 M free memory
                                    220 M buffer memory
                                   1111 M swap cache
                                    199 M total swap
                                      3 M used swap
                                    196 M free swap
                          *** FILESYSTEM ***
                          /var:
                          12G     /var/
                          8.8G    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.7.0
                          /usr/bin/npx            10.7.0
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.17.14
                          javascript:     8.3.1
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        16130
                          States:         14429
                          Pending Updates: 0
                          tc
                          8081 für den admin wird hier bereits genutzt
                          der web Adapter läuft nicht weil 8082 hier
                          für den Admin verwendet wird, obwohl er hier
                          mit Port 8081 konfiguriert ist
                            tc
                            marcelinho
                            @homoran habe nun auf :8083 geändert jetzt läuft es anscheinend Screenshot 2024-07-01 164108.png Screenshot 2024-07-01 164119.png
                            • M marcelinho
                              und der admin?
                                und der admin?
                                marcelinho
                                                        v.2024-05-22
                                       Icon name: computer
                                    Architecture: arm64
                                Kernel:                 aarch64
                                Userland:               64 bit
                                User-ID:                1000
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:
                                /usr/bin/npm            10.7.0
                                /usr/bin/npx            10.7.0
                                Recommended versions are nodejs 18.20.3 and npm 10.7.0
                                MEMORY:
                                Mem:            4.0G        2.4G        208M        147K        1.5G        1.6G
                                Swap:           209M        4.7M        204M
                                Total:          4.2G        2.4G        413M
                                ioBroker Core:          js-controller           5.0.19
                                                        admin                   6.17.14
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                16130
                                States:                 14429
                                Size of iob-Database:
                                32M     /opt/iobroker/iobroker-data/objects.jsonl
                                11M     /opt/iobroker/iobroker-data/states.jsonl
                                • M marcelinho
                                                          v.2024-05-22
                                         Icon name: computer
                                      Architecture: arm64
                                  Kernel:                 aarch64
                                  Userland:               64 bit
                                  User-ID:                1000
                                  /usr/bin/npm            10.7.0
                                  /usr/bin/npx            10.7.0
                                  MEMORY:
                                                          admin                   6.17.14
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                16130
                                  States:                 14429
                                  web noch auf 8082 und läuft nicht
                                  admin auf 8081umd läuft.
                                  Hast du 2 Installationen parallel laufen?
                                    marcelinho
                                    @homoran eigentlich nicht - zumindest nicht das ich wüsste
                                    • M marcelinho
                                      die Daten in iob diag passen nicht zu deinen Aussagen und Screenshots
                                        marcelinho
                                        @homoran auf die Weboberfläche bin ich immer mit :8081 gekommen jetzt komme ich mit :8082 drauf seit ich den oben erwähnten Adapter installiert habe auf der :8082 bin ich in IoBroker Oberfläche und auf der :8082 kommt das: Screenshot 2024-07-01 165102.png was eigentlich vorher die Weboberfläche von IoBroker war deswegen bin ich verwirrt. Screenshot 2024-07-01 165202.png
                                        • M marcelinho
                                          das passt ja zu
                                          @homoran sagte in IoBroker Web nicht mehr unter :8081 verfügbar:
                                          tc
