    6.6k
7.6k Beiträge 296 Kommentatoren 7.8m Aufrufe 201 Beobachtet
  • R Rookie50
    Hi, falls es jemanden interessiert. Ich habe es nun geschafft meine Kameras mit RTSPtoWeb in iQontrol darzustellen. Man muss einfach ein neues Geräte als Widget erstellen und unter Background_HTML folgenden Code einfügen:
    <input type="hidden" name="webrtc-url" id="webrtc-url" value="http://192.168.2.2:8083/stream/a34525d7-6d13-421d-9127-2cd7bc4323dc/channel/0/webrtc" />
    <video id="webrtc-video" autoplay muted playsinline controls style="max-width: 100%; max-height: 100%;" />
    <script>
    setTimeout(function () {
      function startPlay(videoEl, url) {
        const webrtc = new RTCPeerConnection({
          iceServers: [
              urls: ["stun:stun.l.google.com:19302"],
          sdpSemantics: "unified-plan",
        webrtc.ontrack = function (event) {
          console.log(event.streams.length + " track is delivered");
          videoEl.srcObject = event.streams[0];
          videoEl.play();
        webrtc.addTransceiver("video", { direction: "sendrecv" });
        webrtc.onnegotiationneeded = async function handleNegotiationNeeded() {
          const offer = await webrtc.createOffer();
          await webrtc.setLocalDescription(offer);
          fetch(url, {
            method: "POST",
            body: new URLSearchParams({ data: btoa(webrtc.localDescription.sdp) }),
            .then((response) => response.text())
            .then((data) => {
              try {
                webrtc.setRemoteDescription(new RTCSessionDescription({ type: "answer", sdp: atob(data) }));
              } catch (e) {
                console.warn(e);
        const webrtcSendChannel = webrtc.createDataChannel("rtsptowebSendChannel");
        webrtcSendChannel.onopen = (event) => {
          console.log(`${webrtcSendChannel.label} has opened`);
          webrtcSendChannel.send("ping");
        webrtcSendChannel.onclose = (_event) => {
          console.log(`${webrtcSendChannel.label} has closed`);
          startPlay(videoEl, url);
        webrtcSendChannel.onmessage = (event) => console.log(event.data);
      const videoEl = document.querySelector("#webrtc-video");
      const webrtcUrl = document.querySelector("#webrtc-url").value;
      startPlay(videoEl, webrtcUrl);
    }, 1000);
    </script>
    In der erste Zeile muss nur die IP addresse und die Kamera ID angepasst werden:
    Sobald die Ansicht geladen wird startet der Player mit Videobild.
    Banjo89
    #7612
    Guten Morgen,
    das funktioniert bei mir sehr gut, wenn ich das Skript aber in die VIS 2 übernehme startet der Player nicht mehr. Hat das jemand gelöst oder eine Idee warum es nicht geht?
    @rookie50 sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
    <script>
          iceServers: [
          videoEl.play();
          fetch(url, {
            method: "POST",
            .then((data) => {
              try {
              } catch (e) {
                console.warn(e);
    }, 1000);
    </script>
    • R Rookie50
      @woduwolle Du hast einen DP der AUTOMATIK EIN/AUS schaltet und einen Datenpunkt der den Sprenger EIN/AUS schaltet. Du bentuzt in iQontrol für die Darstellung "Schalter", soweit richtig?
      In der Kachel für den Sprenger 0815 benutzt als State den Datenpunkt um den Sprenger ein bzw. auszuschalten. z.B.:
      Unten in der Kacheleinstellung benutzt Du dann als "Bedingung für eine aktive Kachel" den DP von AUTOMATIK.
      Damit sollte es funktionieren
      WoduwolleW Offline
      WoduwolleW Offline
      Woduwolle
      #7613
      @rookie50 Hallo Rockie,
      Ich habe mich nochmals daran versucht eine kachel bei bedingung einzublenden.....
      Gibt es einen Punkt in dem man nur einblenden kann ohne aktiv oder inaktiv ????
      sowas würde mir fehlen.
      Gruß Konrad
      • R Rookie50
        @woduwolle Es ist mir nicht so ganz klar was Du erreichen möchtest. In der Kachel wird der Datenpunkt, den Du als State, oben in den Einstellungen, eingetragen hast, angezeigt. Das muss aber nicht der Gleiche sein, wie der DP, den Du als Bedingung für eine aktive Gerätekachel benutzt.
        WoduwolleW Offline
        WoduwolleW Offline
        Woduwolle
        #7614
        @rookie50Hallo Ich versuche es hier nochmals besser zu erklären. Wenn ich diese wenn ich eine beedingung als aktive kachel wähle, wird sobald diese bedingung True wird die Kachel eingeblendet. Alles so wie es sein soll. Doch was mir nicht so passt ist das diese dann als Aktiv dargestellt wird und sich der Schieberegler nicht mehr als AUS darstellen lässt. Oder gibt es hier in den Einstellungen einen Hacken den ich setzten muss das dies wieder geht ????
        Wenn ich eine beedingung als inaktiv wähle funktioniert dies auch nur das dann die Kachel (wenn sie eingeblendet ist) immer als inaktiv dargestellt ist..
        Mein vorhaben ist das ich eine Kachel ein oder ausblende aber als Neutral nicht aktiv aber auch nicht inaktiv.
        Vielleicht auch jemand anderst eine Idee oder Lösung
        Ich würde mich freuen
        • WoduwolleW Offline
          WoduwolleW Offline
          Woduwolle
          #7615
          @rockie50
          Was ich damit machen möchte ...
          Mein gedanke ist der das ich schalter ausblenden möchte wenn die Automarik aktiv wenn ich die Automatik deaktiviere sollen die manuellen schalter wieder eingeblendet werden und dann zum manuellen schalten benutzt werden können. das funktioniert auch soweit nur das dann die kachel schon als aktiv eingeblendet wird. Was teilweise verwirrend ist wenn man nicht auf den State Status schaut....
          • WoduwolleW Woduwolle
            @rockie50
            dslraserD Offline
            dslraserD Offline
            dslraser
            #7616
            @woduwolle sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
            @rockie50
            Nur so als Idee...
            hast Du es mal mit einem Widget probiert und beim State nichts verlinken.
            Das Verhalten der Kachel dann in den Einstellungen...
            Die Schaltung selbst dann über ADDITIONAL_CONTROLS
            (die Bilder sollen nur als Beispiel dienen...)
            WoduwolleW 1 Antwort Letzte Antwort
            • s.bormannS s.bormann
              Willkommen im iQontrol-Entwicklungs-Thread!
              iQontrol ist ein Visualisierungs-Adapter.
              Number of Installations
              Stable version
              NPM version
              Known Vulnerabilities
              Dies ist der Entwicklungs-Thread
              Hier werden die neuesten Updates veröffentlicht, neue Ideen und Features diskutiert und es finden alpha und beta-Tests statt. Wer also immer auf dem neuesten Stand sein will oder sich aktiv einbringen möchte, ist hier richtig aufgehoben.
              Alternativ gibt es noch den iQontrol-Support-Thread. Hier sollen Support-Anfragen gestellt und diskutiert werden:
              https://forum.iobroker.net/topic/52077
              Wichtige Resourcen
              Das Readme auf Github beschreibt die wichtigsten Einstellungen, Troubleshooting etc.:
              https://github.com/sbormann/ioBroker.iqontrol
              Video-Tutorials:
              https://www.youtube.com/playlist?list=PL8epyNz8pGEv6-R8dnfXm-m5aBlZFKOBG
              Wiki mit einer Sammlung nützlicher Scripte, Widgets etc.:
              https://github.com/sbormann/ioBroker.iqontrol/wiki
              Viel Spaß und Erfolg,
              Sebastian
              I Offline
              I Offline
              Iqontrol-Nutzer
              #7617
              @s-bormann
              Hallo, danke für die super IQontrol Visualisierung!
              Nur durch diese Visu konnte ich als Neueinsteiger alles so visualisieren, wie ich es mir vorgestellte habe!
              Jedoch stehe ich vor einem Problem mit dem automatischen Seitenwechsel....
              Da ich nicht möchte, dass sich bei meinen neuen Geräten die Hauptseite "einbrennt" habe ich mir gedacht ich nutze die automatische Seitenwechsel-Funktion, als Schutz.
              Meine Idee war daher, dass ich die Seiten im Minutentakt durchlaufen lasse...
              nur bekomme ich das irgendwie nicht ganz hin mit dieser Funktion?
              hat irgendwer eine Idee wie ich das umsetzen kann?
              • I Iqontrol-Nutzer
                @s-bormann
                da_WoodyD Online
                da_WoodyD Online
                #7618
                @iqontrol-nutzer auch mit Doppel Posts kommst du nicht weiter...
                I 1 Antwort Letzte Antwort
                • da_WoodyD da_Woody
                  I Offline
                  I Offline
                  Iqontrol-Nutzer
                  #7619
                  @da_woody
                  statt die anderen ständig auf irgendetwas hinzuweisen, könntest du ja mal was sinnvolles posten und mir und anderen zum Beispiel helfen?
                  dann wäre das Thema nämlich schneller erledigt und gelöst...
                  und für was ist dann denn bitte ein Thread/Forum da?
                  • I Iqontrol-Nutzer
                    @da_woody
                    da_WoodyD Online
                    da_WoodyD Online
                    #7620
                    @iqontrol-nutzer ich hab dich im anderen posting etwas gefragt und keine antwort bekommen.
                    ein forum ist für fragen da, aber wenn schon, dann im passenden tread.
                    hat deine frage irgendetwas mit der entwicklung des adapters zu tun?
                    abgesehn davon sind imho doppelposts nie gerne gesehn. tragen nur zur verwirrung bei wenn in beiden posts dann "sinnvolles" gepostet wird.
                    schönes wochenende...
                      I Offline
                      I Offline
                      Iqontrol-Nutzer
                      #7621
                      @da_woody
                      da geb ich dir natürlich recht, aber dann sag mir bitte wohin ich mich in so einem Fall wenden kann?
                      bzw wo der Thread hin gehört...
                      und nicht wie es nicht gehört....
                      es tut mir leid, dass ich hier neu bin, mich noch nicht so gut zurechtfinde und einfach nur hilfe benötige....
                      • I Iqontrol-Nutzer
                        @da_woody
                        da_WoodyD Online
                        da_WoodyD Online
                        #7622
                        @iqontrol-nutzer ist schon ok. ich hab dir im support tread gerade geantwortet!
                        braucht dir auch nicht leid tun. so hinweise sollen ja auch helfen dich im forum zurechtzufinden.
                        ich bin schon sehr lange in diversen foren unterwegs, bin selber admin eines boards.
                        glaub mir, so ein entspanntes gibts selten. in einigen brettern gibts haue für doppelpostings...
                          I Offline
                          I Offline
                          Iqontrol-Nutzer
                          #7623
                          @da_woody
                          ok, dann werde ich hier mal aufhören zurückzuschreiben...
                          mich nervt das ja selber, aber alles kann man eben nicht wissen😞
                          • dslraserD dslraser
                            @rockie50
                            Nur so als Idee...
                            WoduwolleW Offline
                            WoduwolleW Offline
                            Woduwolle
                            #7624
                            @dslraser Hey dslraser,
                            Vielen Dank für den Tip das funktioniert super. Kann ich mir diese Ansicht auch in dem Widget dahrstellen lassen ???
                            Aktuell muss ich das Widget aufklappen das ich die Schalter sehe .....
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              #7625
                              Ich verstehe nicht wie Du Deine Frage meinst ?
                                WoduwolleW Offline
                                WoduwolleW Offline
                                Woduwolle
                                #7626
                                @dslraser ich bekomme im widmet selbst nur den Namen angezeigt erst wenn ich auf das Widget drauf tippe kommen dann die angelegten schalter
                                  WoduwolleW Offline
                                  WoduwolleW Offline
                                  Woduwolle
                                  #7627
                                  Einmal das widmet und Einmal das aufgeklappt widget
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #7628
                                    @woduwolle
                                    Ich nutze in meiner Hauptansicht nur Symbole. Wenn irgendwas aktiv ist, dann ist es mit einem weißen Hintergrund und der Anzahl der aktiven Geräte sowie etwas rotem Rand dargestellt. Wenn ich dann darauf klicke, dann werden mir die Schalter bzw. Listen oder weitere Menüs angezeigt. Ich weiß ja nicht wie Du es gern hättest.
                                      @woduwolle
                                      da_WoodyD Online
                                      da_WoodyD Online
                                      #7629
                                      @dslraser irgendwie hat @Woduwolle widgets nicht verstanden. gibts aber genug doku dazu.
                                      im entwickler fred hats einen seltsamen geschmack.
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #7630
                                        @woduwolle
                                        Stelle Deine Fragen besser im iQontrol Support Bereich
                                        https://forum.iobroker.net/post/753923
                                          @woduwolle
                                          WoduwolleW Offline
                                          WoduwolleW Offline
                                          Woduwolle
                                          #7631
                                          @dslraser Okay super danke für eure Hilfe... Ich werde dann meine Fragen dort stellen ich glaube ich habe es verstanden wie du meinst ;-) werde mich aber mal in den Dokus schlau machen
