  4. Energiefluss Adapter - Support
energieflussvisvisualisierungvisualizationsupport
462 Beiträge 49 Kommentatoren 201.0k Aufrufe 45 Beobachtet
  • SKBS SKB
    @docadams Habe mir deine Konfiguration gerade in mein Test-System geladen. Die Instanz startet ohne Fehler.
    Achte bitte darauf, das Du die Daten so in den Datenpunkt kopierst, das die Klammern so aussehen:
    Habe es dir hier auch nochmal einmal eingestellt.
        "basic": {
            "enable_grid": true,
            "enable_animation": true,
            "enable_area_catch": false,
            "enable_config_icon": true,
            "enable_last_id": true,
            "enable_icon_proxy": false,
            "enable_low_performance": false,
            "height": 950,
            "width": 646,
            "styles": "",
            "font": {
                "family": "\"Arial\", sans-serif",
                "size": "17",
                "color": "",
                "fill": "#000000",
                "align": "middle"
            "rect": {
                "height": 100,
                "width": 100,
                "corners": 10
            "circle": {
                "radius": 50
            "elm": {
                "stroke_width": 5,
                "color": "",
                "fill": "",
                "pos_x": 450,
                "pos_y": 850
            "icon": {
                "height": 24,
                "width": 24,
                "color": ""
            "background_color": "#FFFFFF"
        "calculation": {
            "battery": {
                "dod": 5,
                "capacity": 10000,
                "percent": 2,
                "charge": 17,
                "charge_prop": false,
                "charge_kw": false,
                "discharge": 16,
                "discharge_prop": false,
                "discharge_kw": false
            "consumption": {
                "production": [
                    "19",
                    "1"
                "production_kw": false,
                "gridFeed": 4,
                "gridFeed_kw": false,
                "gridFeed_prop": false,
                "gridConsume": 8,
                "gridConsume_kw": false,
                "gridConsume_prop": false,
                "batteryCharge": 6,
                "batteryCharge_kw": false,
                "batteryCharge_prop": false,
                "batteryDischarge": -1,
                "batteryDischarge_kw": false,
                "batteryDischarge_prop": false
        "animation": {
            "stroke": "#ffce4a",
            "stroke_dasharray": "15 17 15 17 15 17 15  25",
            "stroke_width": 7,
            "animation_duration": 7000,
            "stroke_linecap": "round",
            "animation_timing_function": "linear"
        "animation_configuration": {
            "dots": 4,
            "distance": 17,
            "length": 15
        "line": {
            "stroke_width": 8,
            "stroke": "#000000"
        "elements": {
            "2": {
                "position": 42,
                "type": "text",
                "subType": "datasource",
                "id": 2,
                "pos_x": 206,
                "pos_y": 32,
                "color": "none",
                "fill": "rgb(130, 105, 38)",
                "font_family": "Arial, sans-serif",
                "font_size": 22,
                "align": "end",
                "text": "ID 2",
                "unit": "kW",
                "source": 19,
                "source_option": -1,
                "source_display": "value",
                "shadow": "",
                "threshold": 11,
                "calculate_kw": "auto",
                "counter_animation": true,
                "convert": false,
                "decimal_places": 2,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "5": {
                "position": 14,
                "type": "rect",
                "id": 5,
                "rx": 10,
                "height": 100,
                "width": 200,
                "pos_x": 22,
                "pos_y": 6,
                "fill": "none",
                "color": "rgb(255, 255, 0)",
                "stroke": 3,
                "shadow": "rgba(0, 0, 0, 0.7)",
                "frame": "_overlay",
                "fill_value": "rgba(255,255,0,0.3)",
                "fill_type": "value",
                "fill_direction": 90,
                "fill_max": 11220,
                "border_type": -1,
                "border_direction": "cw",
                "border_style": "round",
                "border_reverse": false,
                "border_start": null,
                "source": 1,
                "threshold": 0
            "6": {
                "position": 14,
                "type": "icon",
                "id": "6",
                "icon": "mdi:solar-panel",
                "width": 33,
                "height": 33,
                "color": "rgba(0, 0, 0, 0.7)",
                "pos_x": "176",
                "pos_y": "70",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "7": {
                "position": 13,
                "type": "rect",
                "id": 7,
                "rx": 10,
                "height": 80,
                "width": 160,
                "pos_x": 250,
                "pos_y": 413,
                "fill": "none",
                "color": "rgb(0, 181, 221)",
                "stroke": 2,
                "fill_type": "percent",
                "border_type": -1,
                "source": 9,
                "threshold": 0
            "10": {
                "position": 41,
                "type": "text",
                "id": 10,
                "pos_x": 121,
                "pos_y": 87,
                "color": "none",
                "fill": "rgba(0, 0, 0, 0.7)",
                "font_size": 22,
                "align": "middle",
                "text": "Gen24",
                "shadow": "",
                "frame": "_overlay"
            "11": {
                "position": 40,
                "type": "text",
                "id": 11,
                "pos_x": 341,
                "pos_y": 456,
                "color": "none",
                "font_size": 20,
                "align": "middle",
                "text": "Gesamt-\nVerbrauch",
                "shadow": "",
                "frame": "_overlay"
            "12": {
                "position": 13,
                "type": "icon",
                "id": "12",
                "icon": "mdi:house-city",
                "width": 24,
                "height": 24,
                "pos_x": "308",
                "pos_y": "596",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "13": {
                "position": 12,
                "type": "rect",
                "id": 13,
                "rx": 10,
                "height": 190,
                "width": 160,
                "pos_x": 250,
                "pos_y": 50,
                "fill": "none",
                "stroke": 4,
                "fill_type": -1,
                "fill_max": 19140,
                "border_value": "#030008",
                "border_type": "value",
                "border_max": 19140,
                "border_reverse": true,
                "border_start": 90,
                "source": 9,
                "threshold": 0
            "14": {
                "position": 11,
                "type": "rect",
                "id": 14,
                "rx": 10,
                "height": 100,
                "width": 120,
                "pos_x": 6,
                "pos_y": 532,
                "fill": "none",
                "color": "rgba(12, 0, 122, 0.7)",
                "stroke": 4,
                "border_type": -1,
                "source": -1,
                "threshold": 0
            "15": {
                "position": 39,
                "type": "text",
                "id": 15,
                "pos_x": 309,
                "pos_y": 342,
                "color": "none",
                "font_size": 20,
                "align": "middle",
                "text": "Haus-\nAkku",
                "shadow": "",
                "frame": "_overlay"
            "18": {
                "position": 38,
                "type": "text",
                "id": 18,
                "pos_x": 294,
                "pos_y": 319,
                "color": "none",
                "fill": "rgb(0, 0, 0)",
                "font_size": 22,
                "align": "middle",
                "text": "ID 18",
                "unit": "%",
                "source": 2,
                "shadow": "",
                "threshold": 0,
                "calculate_kw": "none",
                "counter_animation": false,
                "convert": false,
                "decimal_places": 0,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "20": {
                "position": 12,
                "type": "icon",
                "id": "20",
                "icon": "mdi:electricity-from-grid",
                "width": 33,
                "height": 33,
                "pos_x": "18",
                "pos_y": "380",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "21": {
                "position": 37,
                "type": "text",
                "id": 21,
                "pos_x": 87,
                "pos_y": 599,
                "color": "none",
                "fill": "rgba(0, 0, 0, 0.43)",
                "font_size": 18,
                "align": "middle",
                "text": "Wärme-\nPumpe",
                "shadow": "",
                "frame": "_overlay"
            "23": {
                "position": 11,
                "type": "icon",
                "id": "23",
                "icon": "material-symbols:electric-car",
                "width": 24,
                "height": 24,
                "pos_x": "162",
                "pos_y": "594",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "24": {
                "position": 36,
                "type": "text",
                "id": 24,
                "pos_x": 226,
                "pos_y": 621,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "Auto",
                "shadow": "",
                "frame": "_overlay"
            "26": {
                "position": 35,
                "type": "text",
                "id": 26,
                "pos_x": 216,
                "pos_y": 558,
                "color": "none",
                "font_size": 22,
                "align": "middle",
                "text": "ID 26",
                "unit": "kW",
                "source": 7,
                "source_display": "text",
                "shadow": "",
                "threshold": 0,
                "calculate_kw": "calc",
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "27": {
                "position": 34,
                "type": "text",
                "id": 27,
                "pos_x": 217,
                "pos_y": 581,
                "color": "none",
                "font_size": 22,
                "align": "middle",
                "text": "ID 27",
                "unit": "%",
                "source": 5,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "29": {
                "position": 10,
                "type": "rect",
                "id": 29,
                "rx": 10,
                "height": 110,
                "width": 100,
                "pos_x": 240,
                "pos_y": 270,
                "fill": "none",
                "color": "rgb(252, 13, 230)",
                "stroke": 2,
                "fill_value": "rgba(197,0,193,0.22)",
                "fill_max": 100,
                "border_type": -1,
                "border_start": 180,
                "source": 2,
                "threshold": 0
            "31": {
                "position": 10,
                "type": "icon",
                "id": "31",
                "width": 33,
                "height": 33,
                "pos_x": "448",
                "pos_y": "73",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "32": {
                "position": 33,
                "type": "text",
                "id": 32,
                "pos_x": 521,
                "pos_y": 87,
                "color": "none",
                "font_size": 22,
                "align": "middle",
                "text": "Symo",
                "shadow": "",
                "frame": "_overlay"
            "33": {
                "position": 32,
                "type": "text",
                "id": 33,
                "pos_x": 449,
                "pos_y": 33,
                "color": "none",
                "font_size": 22,
                "align": "start",
                "text": "ID 33",
                "unit": "kW",
                "source": 1,
                "shadow": "",
                "threshold": 11,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "34": {
                "position": 9,
                "type": "rect",
                "id": 34,
                "rx": 10,
                "height": 100,
                "width": 200,
                "pos_x": 435,
                "pos_y": 8,
                "fill": "none",
                "stroke": 3,
                "fill_max": 7920,
                "border_type": -1,
                "source": 1,
                "threshold": 0
            "35": {
                "position": 8,
                "type": "rect",
                "id": 35,
                "rx": 10,
                "height": 270,
                "width": 160,
                "pos_x": 5,
                "pos_y": 150,
                "fill": "none",
                "color": "rgba(0, 0, 0, 0.39)",
                "stroke": 7,
                "fill_type": -1,
                "border_type": -1,
                "source": -1,
                "threshold": 0
            "36": {
                "position": 31,
                "type": "text",
                "id": 36,
                "pos_x": 132,
                "pos_y": 399,
                "color": "none",
                "font_size": 20,
                "align": "middle",
                "text": "Netz",
                "shadow": "",
                "frame": "_overlay"
            "37": {
                "position": 30,
                "type": "text",
                "id": 37,
                "pos_x": 88,
                "pos_y": 175,
                "color": "none",
                "font_size": 22,
                "align": "middle",
                "text": "ID 37",
                "unit": "kW",
                "source": 18,
                "shadow": "",
                "threshold": 22,
                "convert": true,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "38": {
                "position": 29,
                "type": "text",
                "id": 38,
                "pos_x": 355,
                "pos_y": 197,
                "color": "none",
                "font_size": 20,
                "align": "middle",
                "text": "PV\nErzeugung\n\n",
                "shadow": "",
                "frame": "_overlay"
            "39": {
                "position": 28,
                "type": "text",
                "id": 39,
                "pos_x": 330,
                "pos_y": 79,
                "color": "none",
                "fill": "rgb(101, 81, 29)",
                "font_size": 24,
                "align": "middle",
                "text": "ID 39",
                "unit": "kW",
                "source": 19,
                "shadow": "",
                "threshold": 11,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    "1"
                "frame": "_overlay"
            "41": {
                "position": 7,
                "type": "rect",
                "id": 41,
                "rx": 10,
                "height": 100,
                "width": 120,
                "pos_x": 300,
                "pos_y": 531,
                "fill": "none",
                "color": "rgb(197, 144, 46)",
                "stroke": 4,
                "border_type": -1,
                "source": -1,
                "threshold": 0
            "42": {
                "position": 27,
                "type": "text",
                "id": 42,
                "pos_x": 383,
                "pos_y": 599,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "Haus\nRest",
                "shadow": "",
                "frame": "_overlay"
            "45": {
                "position": 9,
                "type": "icon",
                "id": "45",
                "icon": "emojione-monotone:battery",
                "width": 24,
                "height": 24,
                "color": "rgb(95, 194, 103)",
                "pos_x": "248",
                "pos_y": "347",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "46": {
                "position": 26,
                "type": "text",
                "id": 46,
                "pos_x": 201,
                "pos_y": 747,
                "color": "none",
                "fill": "rgb(91, 66, 21)",
                "font_size": 22,
                "align": "middle",
                "text": "ID 46",
                "unit": "h",
                "prepend": "fertig in ",
                "source": 10,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "47": {
                "position": 25,
                "type": "text",
                "id": 47,
                "pos_x": 213,
                "pos_y": 718,
                "color": "none",
                "font_size": 22,
                "align": "middle",
                "text": "ID 47",
                "unit": "Uhr",
                "append": " ",
                "prepend": "fertig um ",
                "source": 11,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "48": {
                "position": 24,
                "type": "text",
                "id": 48,
                "pos_x": 620,
                "pos_y": 57,
                "color": "none",
                "font_size": 19,
                "align": "end",
                "text": "ID 48",
                "unit": "kWh",
                "prepend": "Ertrag Tag ",
                "source": 12,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "51": {
                "position": 23,
                "type": "text",
                "id": 51,
                "pos_x": 30,
                "pos_y": 57,
                "color": "none",
                "fill": "rgba(130, 105, 38, 0.46)",
                "font_size": 19,
                "align": "start",
                "text": "ID 51",
                "unit": "kWh",
                "source": 15,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "52": {
                "position": 22,
                "type": "text",
                "id": 52,
                "pos_x": 331,
                "pos_y": 160,
                "color": "none",
                "font_size": 19,
                "align": "middle",
                "text": "ID 52",
                "unit": "Wh",
                "prepend": "total ",
                "source": 15,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    "14"
                "frame": "_overlay"
            "56": {
                "position": 21,
                "type": "text",
                "id": 56,
                "pos_x": 324,
                "pos_y": 433,
                "color": "none",
                "font_size": 24,
                "align": "middle",
                "text": "ID 56",
                "unit": "kW",
                "source": 19,
                "shadow": "",
                "threshold": 11,
                "convert": false,
                "action": "none",
                "subtract": [
                    "4",
                    "17"
                "add": [
                    "8",
                    "16",
                    "1"
                "frame": "_overlay"
            "58": {
                "position": 20,
                "type": "text",
                "id": 58,
                "pos_x": 289,
                "pos_y": 291,
                "color": "none",
                "font_size": 24,
                "align": "middle",
                "text": "ID 58",
                "unit": "kW",
                "source": 6,
                "shadow": "",
                "threshold": 11,
                "convert": true,
                "decimal_places": 1,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "59": {
                "position": 19,
                "type": "text",
                "id": 59,
                "pos_x": 360,
                "pos_y": 557,
                "color": "none",
                "font_size": 24,
                "align": "middle",
                "text": "ID 59",
                "unit": "kW",
                "source": 19,
                "shadow": "",
                "threshold": 11,
                "convert": false,
                "action": "none",
                "subtract": [
                    "7",
                    "26",
                    "28",
                    "27",
                    "20",
                    "29",
                    "4",
                    "17"
                "add": [
                    "8",
                    "16",
                    "1"
                "frame": "_overlay"
            "60": {
                "position": 6,
                "type": "rect",
                "id": 60,
                "rx": 10,
                "height": 70,
                "width": 120,
                "pos_x": 502,
                "pos_y": 234,
                "fill": "none",
                "color": "rgb(179, 132, 73)",
                "stroke": 2,
                "fill_type": -1,
                "border_max": 2000,
                "source": 20,
                "threshold": 0
            "61": {
                "position": 18,
                "type": "text",
                "id": 61,
                "pos_x": 613,
                "pos_y": 258,
                "color": "none",
                "font_size": 20,
                "align": "end",
                "text": "ID 61",
                "unit": "kW",
                "source": 20,
                "shadow": "",
                "threshold": 2,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "63": {
                "position": 8,
                "type": "icon",
                "id": "63",
                "icon": "mdi:dishwasher",
                "width": 24,
                "height": 24,
                "color": "rgb(0, 0, 0)",
                "pos_x": "506",
                "pos_y": "276",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "64": {
                "position": 5,
                "type": "rect",
                "id": 64,
                "rx": 10,
                "height": 70,
                "width": 120,
                "pos_x": 502,
                "pos_y": 150,
                "fill": "none",
                "stroke": 2,
                "shadow": "",
                "fill_type": -1,
                "border_max": 2000,
                "source": 20,
                "threshold": 0
            "65": {
                "position": 17,
                "type": "text",
                "id": 65,
                "pos_x": 605,
                "pos_y": 206,
                "color": "none",
                "fill": "rgba(0, 0, 0, 0.49)",
                "font_size": 18,
                "align": "end",
                "text": "Abgabe",
                "shadow": "",
                "frame": "_overlay"
            "66": {
                "position": 4,
                "type": "rect",
                "id": 66,
                "rx": 10,
                "height": 70,
                "width": 120,
                "pos_x": 502,
                "pos_y": 318,
                "fill": "none",
                "stroke": 2,
                "fill_type": -1,
                "border_max": 2000,
                "source": 20,
                "threshold": 0
            "68": {
                "position": 3,
                "type": "rect",
                "id": 68,
                "rx": 10,
                "height": 70,
                "width": 120,
                "pos_x": 502,
                "pos_y": 398,
                "fill": "none",
                "stroke": 2,
                "shadow": "rgba(0, 0, 0, 0.69)",
                "fill_type": -1,
                "border_max": 2000,
                "source": 20,
                "threshold": 0
            "69": {
                "position": 16,
                "type": "text",
                "id": 69,
                "pos_x": 611,
                "pos_y": 437,
                "color": "none",
                "font_size": 18,
                "align": "end",
                "text": "Kühl-\nschränke",
                "shadow": "",
                "frame": "_overlay"
            "70": {
                "position": 2,
                "type": "rect",
                "id": 70,
                "rx": 10,
                "height": 70,
                "width": 120,
                "pos_x": 502,
                "pos_y": 480,
                "fill": "none",
                "stroke": 2,
                "shadow": "",
                "fill_type": -1,
                "border_max": 2000,
                "source": 20,
                "threshold": 0
            "71": {
                "position": 15,
                "type": "text",
                "id": 71,
                "pos_x": 615,
                "pos_y": 520,
                "color": "none",
                "fill": "rgba(0, 0, 0, 0.51)",
                "font_size": 18,
                "align": "end",
                "text": "Wasch-\nmaschine",
                "shadow": "",
                "frame": "_overlay"
            "72": {
                "position": 14,
                "type": "text",
                "id": 72,
                "pos_x": 613,
                "pos_y": 598,
                "color": "none",
                "font_size": 18,
                "align": "end",
                "text": "Kom-\nmunikation",
                "shadow": "",
                "frame": "_overlay"
            "73": {
                "position": 1,
                "type": "rect",
                "id": 73,
                "rx": 10,
                "height": 70,
                "width": 120,
                "pos_x": 502,
                "pos_y": 560,
                "fill": "none",
                "stroke": 2,
                "shadow": "rgba(0, 0, 0, 0.68)",
                "fill_type": -1,
                "border_max": 2000,
                "source": 20,
                "threshold": 0
            "74": {
                "position": 7,
                "type": "icon",
                "id": "74",
                "icon": "mdi:telephone",
                "width": 24,
                "height": 24,
                "color": "rgb(65, 55, 134)",
                "pos_x": "509",
                "pos_y": "585",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "75": {
                "position": 6,
                "type": "icon",
                "id": "75",
                "icon": "mdi:sun-wireless",
                "width": 30,
                "height": 30,
                "pos_x": "262",
                "pos_y": "199",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "76": {
                "position": 5,
                "type": "icon",
                "id": "76",
                "icon": "mdi:house",
                "width": 30,
                "height": 30,
                "pos_x": "264",
                "pos_y": "457",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "77": {
                "position": 4,
                "type": "icon",
                "id": "77",
                "icon": "mdi:coffee-maker-outline",
                "width": 24,
                "height": 24,
                "pos_x": "509",
                "pos_y": "358",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "78": {
                "position": 3,
                "type": "icon",
                "id": "78",
                "icon": "mdi:refrigerator",
                "width": 24,
                "height": 24,
                "pos_x": "510",
                "pos_y": "435",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "79": {
                "position": 2,
                "type": "icon",
                "id": "79",
                "icon": "mdi:washing-machine",
                "width": 24,
                "height": 24,
                "pos_x": "510",
                "pos_y": "517",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "81": {
                "position": 13,
                "type": "text",
                "id": 81,
                "pos_x": 607,
                "pos_y": 287,
                "color": "none",
                "font_size": 18,
                "align": "end",
                "text": "Spüle\n",
                "shadow": "",
                "frame": "_overlay"
            "82": {
                "position": 12,
                "type": "text",
                "id": 82,
                "pos_x": 608,
                "pos_y": 359,
                "color": "none",
                "font_size": 18,
                "align": "end",
                "text": "Kaffee-\nmaschine",
                "shadow": "",
                "frame": "_overlay"
            "84": {
                "position": 1,
                "type": "icon",
                "id": "84",
                "icon": "mdi:euro",
                "width": 24,
                "height": 24,
                "pos_x": "508",
                "pos_y": "190",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "86": {
                "position": 0,
                "type": "icon",
                "id": "86",
                "icon": "material-symbols:heat-pump-outline",
                "width": 24,
                "height": 24,
                "pos_x": "10",
                "pos_y": "592",
                "shadow": "",
                "source": -1,
                "threshold": 0,
                "action": "none"
            "91": {
                "position": 11,
                "type": "text",
                "id": 91,
                "pos_x": 160,
                "pos_y": 316,
                "color": "none",
                "font_size": 18,
                "align": "end",
                "text": "ID 91",
                "unit": "EUR",
                "prepend": "Einkauf: ",
                "source": 22,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "93": {
                "position": 10,
                "type": "text",
                "id": 93,
                "pos_x": 160,
                "pos_y": 250,
                "color": "none",
                "fill": "rgba(0, 0, 0, 0.38)",
                "font_size": 18,
                "align": "end",
                "text": "ID 93",
                "unit": "EUR",
                "prepend": "Verkauf: ",
                "source": 24,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "94": {
                "position": 9,
                "type": "text",
                "id": 94,
                "pos_x": 84,
                "pos_y": 364,
                "color": "none",
                "fill": "rgb(163, 0, 0)",
                "font_size": 22,
                "align": "middle",
                "text": "ID 94",
                "unit": "ct/kWh",
                "source": 25,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "95": {
                "position": 8,
                "type": "text",
                "id": 95,
                "pos_x": 86,
                "pos_y": 341,
                "color": "none",
                "font_size": 18,
                "align": "middle",
                "text": "aktueller Preis:",
                "shadow": "",
                "frame": "_overlay"
            "96": {
                "position": 7,
                "type": "text",
                "id": 96,
                "pos_x": 339,
                "pos_y": 138,
                "color": "none",
                "fill": "rgba(130, 105, 38, 0.4)",
                "font_size": 19,
                "align": "middle",
                "text": "ID 96",
                "unit": "Wh",
                "prepend": "Jahr",
                "source": 15,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    "14"
                "frame": "_overlay"
            "97": {
                "position": 6,
                "type": "text",
                "id": 97,
                "pos_x": 341,
                "pos_y": 115,
                "color": "none",
                "font_size": 19,
                "align": "middle",
                "text": "ID 97",
                "unit": "Wh",
                "prepend": "Tag",
                "source": 15,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    "14"
                "frame": "_overlay"
            "98": {
                "position": 0,
                "type": "rect",
                "id": 98,
                "rx": 10,
                "height": 100,
                "width": 120,
                "pos_x": 153,
                "pos_y": 531,
                "fill": "none",
                "stroke": 4,
                "border_type": -1,
                "source": 5,
                "threshold": 0
            "99": {
                "position": 5,
                "type": "text",
                "id": 99,
                "pos_x": 614,
                "pos_y": 339,
                "color": "none",
                "font_family": "\"Arial\", sans-serif",
                "font_size": 20,
                "align": "end",
                "text": "ID 99",
                "unit": "kW",
                "source": 26,
                "shadow": "",
                "threshold": 4,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "100": {
                "position": 4,
                "type": "text",
                "id": 100,
                "pos_x": 615,
                "pos_y": 415,
                "color": "none",
                "font_size": 20,
                "align": "end",
                "text": "ID 100",
                "unit": "kW",
                "source": 27,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "101": {
                "position": 3,
                "type": "text",
                "id": 101,
                "pos_x": 615,
                "pos_y": 577,
                "color": "none",
                "font_size": 20,
                "align": "end",
                "text": "ID 101",
                "unit": "kW",
                "source": 28,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "102": {
                "position": 2,
                "type": "text",
                "id": 102,
                "pos_x": 63,
                "pos_y": 559,
                "color": "none",
                "font_size": 22,
                "align": "middle",
                "text": "ID 102",
                "unit": "kW",
                "source": 29,
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "103": {
                "position": 1,
                "type": "text",
                "id": 103,
                "pos_x": 161,
                "pos_y": 297,
                "color": "none",
                "font_size": 18,
                "align": "end",
                "text": "ID 103",
                "unit": "kW",
                "source": "21",
                "source_option": "-1",
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
            "104": {
                "position": 0,
                "type": "text",
                "id": 104,
                "pos_x": 205,
                "pos_y": 193,
                "color": "none",
                "font_size": 18,
                "align": "end",
                "text": "ID 104",
                "unit": "kW",
                "source": "23",
                "shadow": "",
                "threshold": 0,
                "convert": false,
                "action": "none",
                "subtract": [
                    -1
                "add": [
                    -1
                "frame": "_overlay"
        "defs": {
            "path_7_41": {
                "type": "def",
                "id": "path_7_41",
                "d": "M330 494  V 501 A 15 15 0 0 0 345 516  H 345 A 15 15 0 0 1 360 531  V 529",
                "startSlot": "bottom",
                "endSlot": "top"
            "path_35_7": {
                "type": "def",
                "id": "path_35_7",
                "d": "M168.5 295  H 184.5 A 15 15 0 0 1 199.5 310  V 438 A 15 15 0 0 0 214.5 453  H 249",
                "startSlot": "right_bottom",
                "endSlot": "left"
            "path_13_7": {
                "type": "def",
                "id": "path_13_7",
                "d": "M350 242  V 412",
                "startSlot": "bottom_right",
                "endSlot": "top_right"
            "path_34_13": {
                "type": "def",
                "id": "path_34_13",
                "d": "M433.5 38  H 416.9   H 355 A 5 5 0 0 0 350 43  V 48",
                "startSlot": "left_top",
            "path_29_7": {
                "type": "def",
                "id": "path_29_7",
                "d": "M310 382.5  V 412",
                "endSlot": "top_left"
            "path_13_29": {
                "type": "def",
                "id": "path_13_29",
                "d": "M310 242  V 267.5",
                "startSlot": "bottom_left",
            "path_7_64": {
                "type": "def",
                "id": "path_7_64",
                "d": "M411 453  H 429 A 15 15 0 0 0 444 438  V 200 A 15 15 0 0 1 459 185  H 501",
                "startSlot": "right",
                "endSlot": "left"
            "path_7_60": {
                "type": "def",
                "id": "path_7_60",
                "d": "M411 453  H 429 A 15 15 0 0 0 444 438  V 284 A 15 15 0 0 1 459 269  H 501",
                "endSlot": "left"
            "path_7_66": {
                "type": "def",
                "id": "path_7_66",
                "d": "M411 453  H 429 A 15 15 0 0 0 444 438  V 368 A 15 15 0 0 1 459 353  H 501",
                "endSlot": "left"
            "path_7_68": {
                "type": "def",
                "id": "path_7_68",
                "d": "M411 453  H 429 A 10 10 0 0 0 439 443  V 443 A 10 10 0 0 1 449 433  H 501",
                "endSlot": "left"
            "path_7_70": {
                "type": "def",
                "id": "path_7_70",
                "d": "M411 453  H 429 A 15 15 0 0 1 444 468  V 500 A 15 15 0 0 0 459 515  H 501",
                "endSlot": "left"
            "path_7_73": {
                "type": "def",
                "id": "path_7_73",
                "d": "M411 453  H 429 A 15 15 0 0 1 444 468  V 580 A 15 15 0 0 0 459 595  H 501",
                "endSlot": "left"
            "path_7_14": {
                "type": "def",
                "id": "path_7_14",
                "d": "M330 494  V 501.2 A 15 15 0 0 1 315 516.2  H 81 A 15 15 0 0 0 66 531.2  V 530",
                "endSlot": "top"
            "path_13_35": {
                "type": "def",
                "id": "path_13_35",
                "d": "M248 145  H 232.2 A 15 15 0 0 0 217.2 160  V 240 A 15 15 0 0 1 202.2 255  H 168.5",
                "startSlot": "left",
                "endSlot": "right_top"
            "path_5_13": {
                "type": "def",
                "id": "path_5_13",
                "d": "M223.5 36  H 240.7   H 304 A 6 6 0 0 1 310 42  V 48",
                "startSlot": "right_top",
            "path_7_98": {
                "type": "def",
                "id": "path_7_98",
                "d": "M330 494  V 501.2 A 15 15 0 0 1 315 516.2  H 228 A 15 15 0 0 0 213 531.2  V 530",
                "endSlot": "top"
        "lines": {
            "line_path_7_41": {
                "type": "line",
                "id": "line_path_7_41",
                "href": "#path_7_41",
                "shadow": ""
            "line_path_35_7": {
                "type": "line",
                "id": "line_path_35_7",
                "href": "#path_35_7",
                "shadow": ""
            "line_path_13_7": {
                "type": "line",
                "id": "line_path_13_7",
                "href": "#path_13_7",
                "shadow": ""
            "line_path_34_13": {
                "type": "line",
                "id": "line_path_34_13",
                "href": "#path_34_13",
                "shadow": ""
            "line_path_29_7": {
                "type": "line",
                "id": "line_path_29_7",
                "href": "#path_29_7",
                "shadow": ""
            "line_path_13_29": {
                "type": "line",
                "id": "line_path_13_29",
                "href": "#path_13_29",
                "shadow": ""
            "line_path_7_64": {
                "type": "line",
                "id": "line_path_7_64",
                "href": "#path_7_64",
                "shadow": ""
            "line_path_7_60": {
                "type": "line",
                "id": "line_path_7_60",
                "href": "#path_7_60",
                "shadow": ""
            "line_path_7_66": {
                "type": "line",
                "id": "line_path_7_66",
                "href": "#path_7_66",
                "shadow": ""
            "line_path_7_68": {
                "type": "line",
                "id": "line_path_7_68",
                "href": "#path_7_68",
                "shadow": ""
            "line_path_7_70": {
                "type": "line",
                "id": "line_path_7_70",
                "href": "#path_7_70",
                "shadow": ""
            "line_path_7_73": {
                "type": "line",
                "id": "line_path_7_73",
                "href": "#path_7_73",
                "shadow": ""
            "line_path_7_14": {
                "type": "line",
                "id": "line_path_7_14",
                "href": "#path_7_14",
                "shadow": ""
            "line_path_13_35": {
                "type": "line",
                "id": "line_path_13_35",
                "href": "#path_13_35",
                "shadow": ""
            "line_path_5_13": {
                "type": "line",
                "id": "line_path_5_13",
                "href": "#path_5_13",
                "shadow": ""
            "line_path_7_98": {
                "type": "line",
                "id": "line_path_7_98",
                "href": "#path_7_98",
                "shadow": ""
        "animations": {
            "anim_path_7_41": {
                "type": "animation",
                "id": "anim_path_7_41",
                "color": "rgb(255, 206, 74)",
                "source": 2,
                "threshold": 0,
                "animation_properties": "positive",
                "animation_option": false,
                "dots": 0,
                "duration": 0,
                "power": 0,
                "animation_type": -1
            "anim_path_35_7": {
                "id": "anim_path_35_7",
                "source": 8,
                "threshold": 20,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_13_7": {
                "id": "anim_path_13_7",
                "source": 19,
                "threshold": 10,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_34_13": {
                "id": "anim_path_34_13",
                "source": 1,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_29_7": {
                "id": "anim_path_29_7",
                "source": 16,
                "threshold": 5,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_13_29": {
                "id": "anim_path_13_29",
                "source": 17,
                "threshold": 5,
                "animation_option": true,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_64": {
                "id": "anim_path_7_64",
                "source": -1,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_60": {
                "id": "anim_path_7_60",
                "source": 20,
                "threshold": 2,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_66": {
                "id": "anim_path_7_66",
                "source": 26,
                "threshold": 2,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_68": {
                "id": "anim_path_7_68",
                "source": 27,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_70": {
                "id": "anim_path_7_70",
                "source": -1,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_73": {
                "id": "anim_path_7_73",
                "source": 28,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_14": {
                "id": "anim_path_7_14",
                "source": 29,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_13_35": {
                "id": "anim_path_13_35",
                "source": 4,
                "threshold": 22,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_5_13": {
                "id": "anim_path_5_13",
                "source": 19,
                "threshold": 22,
                "dots": 0,
                "duration": 0,
                "power": 0,
            "anim_path_7_98": {
                "id": "anim_path_7_98",
                "source": 7,
                "threshold": 0,
                "dots": 0,
                "duration": 0,
                "power": 0,
        "datasources": {
            "1": {
                "source": "fronius.1.site.P_PV",
                "alias": "PV Symo Leistung",
                "factor": 1
            "2": {
                "source": "fronius.0.storage.0.StateOfCharge_Relative",
                "alias": "PV Akku SoC",
                "factor": 1
            "3": {
                "source": "fronius.0.storage.0.DesignedCapacity",
                "alias": "PV Akku Kapazität",
                "factor": 1
            "4": {
                "source": "tibberlink.0.Homes.867-xxx-b9.LiveMeasurement.powerProduction",
                "alias": "Netz Verkauf",
                "factor": 1
            "5": {
                "source": "bluelink.0.KNAJ3811FM7017652.vehicleStatus.battery.soc",
                "alias": "Auto Akku SoC",
                "factor": 1
            "6": {
                "source": "fronius.0.site.P_Akku",
                "alias": "PV Akku Power",
                "factor": 1
            "7": {
                "source": "go-e.0.energy.power",
                "alias": "Auto Akku laden",
                "factor": 1000
            "8": {
                "source": "tibberlink.0.Homes.867-xxx-b9.LiveMeasurement.powerConsumption",
                "alias": "Netz Einkauf",
                "factor": 1
            "9": {
                "source": "energiefluss-erweitert.0.calculation.consumption.consumption",
                "alias": "PV gesamt Verbrauch",
                "factor": 1
            "10": {
                "source": "energiefluss-erweitert.0.calculation.battery.remaining_target",
                "alias": "Auto 100% Stunden",
                "factor": 1
            "11": {
                "source": "energiefluss-erweitert.0.calculation.battery.remaining",
                "alias": "Auto 100% Zeit",
                "factor": 1
            "12": {
                "source": "fronius.1.inverter.1.E_Day",
                "alias": "PV Symo Tag",
                "factor": 1
            "13": {
                "source": "fronius.1.inverter.1.E_Year",
                "alias": "PV Symo Jahr",
                "factor": 1
            "14": {
                "source": "fronius.1.inverter.1.E_Total",
                "alias": "PV Symo total",
                "factor": 1
            "15": {
                "source": "fronius.0.site.E_Total",
                "alias": "PV Gen24 total",
                "factor": 1
            "16": {
                "source": "bydhvs.0.State.Power_Consumption",
                "alias": "PV Akku entladen",
                "factor": 1
            "17": {
                "source": "bydhvs.0.State.Power_Delivery",
                "alias": "PV Akku Lieferung",
                "factor": 1
            "18": {
                "source": "tibberlink.0.Homes.867-xxx-b9.LiveMeasurement.power",
                "alias": "Netz Power",
                "factor": 1
            "19": {
                "source": "fronius.0.site.P_PV",
                "alias": "PV Gen24 Leistung",
                "factor": 1
            "20": {
                "source": "fritzdect.0.DECT_087610022950.power",
                "alias": "Haus Spüle",
                "factor": 1
            "21": {
                "source": "0_userdata.0.Import.Strom_AT",
                "alias": "Netz Einkauf kWh",
                "factor": 1
            "22": {
                "source": "tibberlink.0.Homes.867-xxx-b9.LiveMeasurement.accumulatedCost",
                "alias": "Netz Einkauf EUR",
                "factor": 1
            "23": {
                "source": "0_userdata.0.Import.PV_AT",
                "alias": "Netz Verkauf kWh",
                "factor": 1
            "24": {
                "source": "tibberlink.0.Homes.867-xxx-b9.LiveMeasurement.accumulatedProductionLastHour",
                "alias": "Netz Verkauf EUR",
                "factor": 1
            "25": {
                "source": "tibberlink.0.Homes.867-xxx-b9.CurrentPrice.total",
                "alias": "Netz Einkauf Preis aktuell",
                "factor": 1
            "26": {
                "source": "alias.0.Küche.Kaffeemaschine.ENERGY_Power",
                "alias": "Haus Kaffeemaschine",
                "factor": 1
            "27": {
                "source": "alias.0.Küche.Kühlschrank.Kühlschrank-Power",
                "alias": "Haus Kühlschrank",
                "factor": 1
            "28": {
                "source": "alias.0.Keller.USV.USV-ENERGY_Power",
                "alias": "Haus Kommunikation",
                "factor": 1
            "29": {
                "source": "alias.0.Keller.WP.TotalActivePower",
                "alias": "Haus WP gesamt",
                "factor": 1
    docadamsD Offline
    docadamsD Offline
    docadams
    #336
    @skb
    ich denke, ich habs:
    Ich habe deinen Spoiler reinkopiert. Die Instanz wurde sehr kurz grün und dann wieder rot, als wenn er erst zum Fehler kommen muss, um sich aufzuhängen.
    Dann habe ich mir die Datenquellen angeschaut. Dort gab es eine Datenquelle, die auf einen Datenpunkt in 0_userdata verwies, der inzwischen gelöscht wurde.
    Das wars. 👍 👍 👍
    Vielen Dank bei der Rettung.
    PS. wie hast du so schnell aus meinem Datensalat die json-Struktur erzeugt?
    SKBS 1 Antwort Letzte Antwort
    • docadamsD docadams
      @skb
      Das wars. 👍 👍 👍
      SKBS Offline
      SKBS Offline
      SKB
      #337
      @docadams Eigentlich sollte die Instanz nicht abstürzen, wenn der Datenpunkt fehlt. Schaue ich mir nochmal an. Danke Dir für das Beispiel 😉
      Ich nutze Visual Studio Code zum Programmieren. Das Programm erkennt Text mit JSON und kann daraus eine eingerückte Struktur erzeugen 😀
      Aber, die Hauptsache ist ja, das dein Layout wieder da ist.
      docadamsD 1 Antwort Letzte Antwort
        KaFaBe
        #338
        Meine Anzeige öffnet sich nicht.
        Egal on firefox oder opera.
        iobroker und Homeassistent auf Fujitsu 740. KNX für Licht+Steckdose+Rollladen, Homematic für Thermostate und Rauchmelder, Zigbee. Zwei SMA Wechselrichter und drei Hoymiles Wechselrichter
        • K KaFaBe
          SKBS Offline
          SKBS Offline
          SKB
          #339
          @kafabe Web-Adapter auf integriert stellen. Nicht auf Socket.
          • SKBS SKB
            KaFaBe
            #340
            @skb sagte in Energiefluss Adapter - Support:
            Perfekt, das war die Lösung.
            • SKBS SKB
              docadamsD Offline
              docadamsD Offline
              docadams
              #341
              Vielen Dank für die schnelle Hilfe. Im Nachhinein betrachtet hätte ich auch alleine auf den Fehler kommen müssen...
                armalite-2
                #342
                Hallo
                gibt es die Möglichkeit noch 1 oder 2 weitere Solarquellen hinzuzufügen?
                • A armalite-2
                  Hallo
                  da_WoodyD Offline
                  da_WoodyD Offline
                  #343
                  @armalite-2 sogar in der urversion kannst du schon 3 Quellen angeben.
                    @lamo1966 sagte in Eigenverbrauch:
                    hab ich aber auch nicht
                    Eigentlich sollte da der Unterordner Photovoltaik zu sehen sein
                    möglich, dass das nicht angelegt wird, wenn darin kein State existiert.
                    Ich kenne dieses Kontextmenü nicht, gehe immer über das (+) in der Menüzeile oben.
                    lamo1966
                    #344
                    ich ha gesehen, dass du auch den Energieflussadapter nutzt.
                    Ich hab mal damit angefangen.
                    Bei Netz müssten doch eigentlich 2 Werte stehen - Netzbezug und Netzeinspeisung
                    Bei Werte kommen bei mir vom Hichi Lesekopf und ich ha auch beide Werte im Iobroker unter sonoff
                    So kann man es hier auch eintragen, wenn ich das richtig verstehe
                    Wenn ich aber den Datenpunkt für Netzbezug eintrage, bleib der ganze "Kreis" Netz leer
                    • L lamo1966
                      #345
                      L 1 Antwort Letzte Antwort
                        lamo1966
                        #346
                        @homoran said in Eigenverbrauch:
                        das hatte ich schon gesehen, hab ich auch getestet
                        Ergebnis
                        Hast du auch einen Lesekopf dran?
                        • L lamo1966
                          Ergebnis
                          #347
                          natürlich!
                          ich nutze aber ebergiefluss erweitert.
                          müsste morgen mal die Einstellungen von Energiefluss suchen.
                          edit: hast du da die Datenpunkte für Energiewerte ???
                          du brauchst Leistungen
                            natürlich!
                            lamo1966
                            schrieb am zuletzt editiert von lamo1966
                            #348
                            das wär super.
                            Den Energiefluss erweitert - Adapter hab ich auch installiert, aber mich noch nicht damit beschäftigt
                            • L lamo1966
                              das wär super.
                              #349
                              das wär super.
                              wenn du die letzte Frage
                              @homoran sagte in Eigenverbrauch:
                              beantworten würdest
                                das wär super.
                                beantworten würdest
                                lamo1966
                                #350
                                ja hab ich. Die sind auch in den Einstellungen eingetragen
                                Und sie sind natürlich in den Objekten und passen auch inhaltlich
                                Das wären die beiden Werte, die ich in der Tasmota App sehe
                                • L lamo1966
                                  #351
                                  ja hab ich.
                                  was?
                                  nicht Energiewerte!
                                    ja hab ich.
                                    was?
                                    nicht Energiewerte!
                                    lamo1966
                                    #352
                                    nicht Energiewerte!
                                    meinst du Verbraucher ? Mit gehts erstmal nur um das Auslesen der beiden HICHI-Werte, Netzeinspeisung und Netzbezug?
                                    • L lamo1966
                                      nicht Energiewerte!
                                      #353
                                      nein!
                                      ich meine was ich schreibe!
                                      Du verwendest die falschen Datenpunkte!
                                      das ist falsch!
                                      du hast nur einen Leistungswert, und der scheint das Vorzeichen zu wechseln.
                                      Negativ bei Einspeisung und wahrscheinlich positiv bei Bezug.
                                      Außerdem hat die Konfiguration des Adapters Energiefluss nichts mit dem Unterforum Blockly und diesem Thread zu tun.
                                      EDIT:
                                      Habs hierhin verschoben
                                        nein!
                                        das ist falsch!
                                        EDIT:
                                        lamo1966
                                        #354
                                        sind denn die des Sonoff die falschen Werte?
                                        Ich hab nur noch den ...power...Wert
                                        Aber dass ist der Wert, den die Module gerade erzeugen
                                        Außerdem hat die Konfiguration des Adapters Energiefluss nichts mit diesem Unterforum und diesem Thread zu tun.
                                        ich vermeide halt nicht wegen jeder Kleinigkeit neue Threads auf zu machen
                                        • L lamo1966
                                          #355
                                          @lamo1966 sagte in Energiefluss Adapter - Support:
                                          auch falsch!
                                          bitte lesen: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
                                          falsch ist relativ!
                                          sicher?
                                          du erzeugst negative Werte?
                                          und was ist das?
