  4. Beta Test js-controller Kiera (v6.0)
    6.8k
betajs-controllerkieratest
331 Beiträge 39 Kommentatoren 117.4k Aufrufe 42 Beobachtet
  • FeuersturmF Feuersturm
    Update von meinem Testsystem1 Master-Slave System) auf js-controller 6.0.5:
    Im Admin sieht es so aus:
    Das hier meldet der Worx Adapter nach dem Update
    2024-06-16 21:12:52.899 - info: host.ioBrokerTestsystem instance system.adapter.worx.0 started with pid 46448
    2024-06-16 21:12:53.736 - error: host.ioBrokerTestsystem Caught by controller[0]: node:internal/modules/cjs/loader:1143
    2024-06-16 21:12:53.739 - error: host.ioBrokerTestsystem Caught by controller[0]: throw err;
    2024-06-16 21:12:53.742 - error: host.ioBrokerTestsystem Caught by controller[0]: ^
    2024-06-16 21:12:53.746 - error: host.ioBrokerTestsystem Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
    2024-06-16 21:12:53.749 - error: host.ioBrokerTestsystem Caught by controller[0]: Require stack:
    2024-06-16 21:12:53.752 - error: host.ioBrokerTestsystem Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.worx/main.js
    2024-06-16 21:12:53.755 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-06-16 21:12:53.758 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-06-16 21:12:53.761 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-06-16 21:12:53.765 - error: host.ioBrokerTestsystem Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    2024-06-16 21:12:53.768 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.worx/main.js:7:15)
    2024-06-16 21:12:53.771 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-06-16 21:12:53.788 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-06-16 21:12:53.792 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-06-16 21:12:53.807 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-06-16 21:12:53.810 - error: host.ioBrokerTestsystem Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    2024-06-16 21:12:53.813 - error: host.ioBrokerTestsystem Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2024-06-16 21:12:53.848 - error: host.ioBrokerTestsystem Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.worx/main.js' ]
    2024-06-16 21:12:53.852 - error: host.ioBrokerTestsystem Caught by controller[0]: }
    2024-06-16 21:12:53.883 - error: host.ioBrokerTestsystem Caught by controller[0]: Node.js v18.20.3
    2024-06-16 21:12:53.914 - error: host.ioBrokerTestsystem instance system.adapter.worx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-06-16 21:12:53.917 - info: host.ioBrokerTestsystem Adapter system.adapter.worx.0 needs rebuild and will be restarted afterwards.
    2024-06-16 21:12:53.933 - info: host.ioBrokerTestsystem system.adapter.worx.0 will be rebuilt
    2024-06-16 21:12:53.938 - warn: host.ioBrokerTestsystem adapter "worx" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2024-06-16 21:12:53.946 - info: host.ioBrokerTestsystem iobroker rebuild
    Der Adapter ist danach aber i.O. gestartet.
    Update vom Slave über Admin. Es kommt wieder die Meldung
    In der Browserconsole sehe ich nichts auffällgies:
    system.adapter.ical.2 console.ts:40:19
    system.adapter.ical.3 console.ts:40:19
    system.adapter.ical.4 console.ts:40:19
    system.adapter.ical.5 console.ts:40:19
    system.adapter.icons-material-png.0 console.ts:40:19
    system.adapter.icons-mfd-svg.0 console.ts:40:19
    system.adapter.icons-ultimate-png.0 console.ts:40:19
    system.adapter.influxdb.0 console.ts:40:19
    system.adapter.javascript.0 console.ts:40:19
    system.adapter.mqtt.0 console.ts:40:19
    system.adapter.nina.0 console.ts:40:19
    system.adapter.openweathermap.0 console.ts:40:19
    system.adapter.proxmox.0 console.ts:40:19
    system.adapter.radar-trap.0 console.ts:40:19
    system.adapter.rainbird.0 console.ts:40:19
    system.adapter.samsung.0 console.ts:40:19
    system.adapter.sayit.0 console.ts:40:19
    system.adapter.scenes.0 console.ts:40:19
    system.adapter.scheduler.0 console.ts:40:19
    system.adapter.simple-api.0 console.ts:40:19
    system.adapter.socketio.0 console.ts:40:19
    system.adapter.spotify-premium.0 console.ts:40:19
    system.adapter.sql.0 console.ts:40:19
    system.adapter.tankerkoenig.0 console.ts:40:19
    system.adapter.telegram.0 console.ts:40:19
    system.adapter.tr-064.0 console.ts:40:19
    system.adapter.trashschedule.0 console.ts:40:19
    system.adapter.unifi.0 console.ts:40:19
    system.adapter.valloxmv.0 console.ts:40:19
    system.adapter.vis.0 console.ts:40:19
    system.adapter.vis-2.0 console.ts:40:19
    system.adapter.vis-2-widgets-energy.0 console.ts:40:19
    system.adapter.vis-2-widgets-gauges.0 console.ts:40:19
    system.adapter.vis-2-widgets-jaeger-design.0 console.ts:40:19
    system.adapter.vis-2-widgets-material.0 console.ts:40:19
    system.adapter.vis-fancyswitch.0 console.ts:40:19
    system.adapter.vis-google-fonts.0 console.ts:40:19
    system.adapter.vis-history.0 console.ts:40:19
    system.adapter.vis-inventwo.0 console.ts:40:19
    system.adapter.vis-jqui-mfd.0 console.ts:40:19
    system.adapter.vis-justgage.0 console.ts:40:19
    system.adapter.vis-map.0 console.ts:40:19
    system.adapter.vis-materialdesign.0 console.ts:40:19
    system.adapter.vis-timeandweather.0 console.ts:40:19
    system.adapter.web.0 console.ts:40:19
    system.adapter.worx.0 console.ts:40:19
    getInstances: 512 console.ts:40:19
    Request update status from: http://192.168.178.77:8081/ 55 console.ts:40:19
    Request update status from: http://192.168.178.77:8081/ console.ts:40:19
    Update Testsystem2 (SingleHost)
    Auch die Meldung
    Output Browserconsole vom ganzen Updateprozess:
    iobroker.admin@6.17.14 1486.79b921ab.chunk.js:1:295856
    [2024-06-16T19:30:39.690Z] Try to connect 1804.affd1d04.chunk.js:2:462544
    Stored version: , new version: 6.17.14 1804.affd1d04.chunk.js:2:462544
    Connected: true 1804.affd1d04.chunk.js:2:462544
    Translate: esphome 1804.affd1d04.chunk.js:2:462544
    Translate: time 1804.affd1d04.chunk.js:2:462544
    Request update status from: http://192.168.178.105:8081/ 8 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:06.567Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:06.568Z] Start reconnect 0 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:06.610Z] Try to connect 1804.affd1d04.chunk.js:2:462544
    Request update status from: http://192.168.178.105:8081/ 2 1804.affd1d04.chunk.js:2:462544
    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566266610&name=admin aufbauen. socket.io.js:140:22
    [2024-06-16T19:31:08.910Z] Start reconnect 1 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:08.910Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:08.910Z] Reconnect is already running 1 1804.affd1d04.chunk.js:2:462544
    Request update status from: http://192.168.178.105:8081/ 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:09.914Z] Try to connect 1804.affd1d04.chunk.js:2:462544
    Source-Map-Fehler: Error: NetworkError when attempting to fetch resource.
    Ressourcen-Adresse: http://192.168.178.105:8081/static/js/1804.affd1d04.chunk.js
    Source-Map-Adresse: 1804.affd1d04.chunk.js.map
    Ressourcen-Adresse: http://192.168.178.105:8081/static/js/1486.79b921ab.chunk.js
    Source-Map-Adresse: 1486.79b921ab.chunk.js.map
    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566269915&name=admin aufbauen. socket.io.js:140:22
    [2024-06-16T19:31:11.993Z] Start reconnect 2 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:11.994Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:11.995Z] Reconnect is already running 2 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:14.006Z] Try to connect 1804.affd1d04.chunk.js:2:462544
    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566274007&name=admin aufbauen. socket.io.js:140:22
    [2024-06-16T19:31:16.075Z] Start reconnect 3 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:16.076Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:16.076Z] Reconnect is already running 3 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:19.089Z] Try to connect 1804.affd1d04.chunk.js:2:462544
    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566279090&name=admin aufbauen. socket.io.js:140:22
    [2024-06-16T19:31:19.109Z] Start reconnect 4 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:19.110Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:19.111Z] Reconnect is already running 4 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:23.119Z] Try to connect 1804.affd1d04.chunk.js:2:462544
    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566283120&name=admin aufbauen. socket.io.js:140:22
    [2024-06-16T19:31:23.151Z] Start reconnect 5 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:23.152Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:23.152Z] Reconnect is already running 5 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:28.154Z] Try to connect 1804.affd1d04.chunk.js:2:462544
    Firefox kann keine Verbindung zu dem Server unter ws://192.168.178.105:8081/?sid=1718566288155&name=admin aufbauen. socket.io.js:140:22
    [2024-06-16T19:31:28.179Z] Start reconnect 5 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:28.180Z] ws connection error: CLOSE_ABNORMAL 1804.affd1d04.chunk.js:2:462544
    [2024-06-16T19:31:28.180Z] Reconnect is already running 5 1804.affd1d04.chunk.js:2:462544
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #146
    @feuersturm sagte in Beta Test js-controller Kiera (v6.0):
    Ansonsten ist http://192.168.178.77:8081 die IP vom Slave Admin? Und https ist disabled korrekt?
    Videotutorials & mehr
    • foxriver76F foxriver76
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      #147
      @foxriver76 sagte in Beta Test js-controller Kiera (v6.0):
      http://192.168.178.77:8081 ist die IP vom Master wo Admin läuft
      http://192.168.178.78 ist die IP vom Slave, dort läuft kein seperater Admin
      https ist disabled, korrekt.
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        schrieb am zuletzt editiert von foxriver76
        #148
        @feuersturm ah okay, kannst du mal ein issue mit den Details im Admin machen. Weil er fragt da den falschen Host an wenn der Admin gar nicht auf dem Host läuft der geupgradet wird
          FeuersturmF Offline
          FeuersturmF Offline
          Feuersturm
          #149
          @foxriver76 die Erklärung passt aber nicht zu meinem zweiten Testsystem in dem Beitrag, wo auch der Fehler kommt, es aber nur ein singlehost ist.
          F foxriver76F 2 Antworten Letzte Antwort
            fuchs1978
            #150
            Gibt es eigentlich im neuen Controller nur die Möglichkeit als Admin ein Adapter Update durchzuführen? Früher konnte man dich einfach auf die neue Versionsnummer drücken. Das geht bei mir nicht mehr.
            FeuersturmF mcm1957M 2 Antworten Letzte Antwort
            • Thomas BraunT Online
              #151
              @fuchs1978 sagte in Beta Test js-controller Kiera (v6.0):
              Admin 7.x am Start? Der ist zurüückgezogen worden.
              • F fuchs1978
                FeuersturmF Offline
                FeuersturmF Offline
                Feuersturm
                #152
                @fuchs1978 die 6.0.4 ist die aktuelle Beta Version. Die 6.0.5 ist eine Alpha welche gestern fälschlicherweise gestern als beta getaggt war. Daher siehst du sie im Admin gerade nicht
                Beantwortet das deine Frage, ansonsten hab ich nicht verstanden was du wissen möchtest.
                  da_WoodyD Offline
                  da_WoodyD Offline
                  #153
                  @feuersturm bei mir ist die 6.0.5 vor 10 minuten aufgetaucht. bis jetzt keine auffälligkeiten.
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    #154
                    @feuersturm Jop aber hier ist es definitiv ein Problem mit der ip evtl auch noch was anderes aber von der ip kann er nix bekommen
                      FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      #155
                      @foxriver76 ok, issue mache ich dann fertig.
                      • foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        #156
                        6.0.5 ist jetzt offizielle Beta mit den Änderungen der Alpha
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          #157
                          @feuersturm Danke. Habe mal grob geschaut. Bitte im Issue das Host Objekt vom Slave posten und nach Möglichkeit auch die iobroker.json vom Slave. Da er Daten aus den beiden Quellen nutzt um die IP zu finden.
                          • F fuchs1978
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #158
                            @fuchs1978 said in Beta Test js-controller Kiera (v6.0):
                            Wenn du damit meinst dass es in der Adapterliste im Admin keinen Update Button gibt: das ist ein bekannter Fehler in admin 7.0.1. Admin 7.0.1 wurde zurückgezogen. Bitte downgrade auf aktuelle LATEST Version 6.x.x)
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
                              FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              #159
                              Issue ist angelegt https://github.com/ioBroker/ioBroker.admin/issues/2505
                              • JB_SullivanJ Offline
                                JB_Sullivan
                                #160
                                Möglicherweise hat es nichts mit dem js-controller zu tun, aber ich bilde mir ein, das ich bei Adapter Installationen/Updates VOR js-controller 6.xxx nicht diese ganzen Warnmeldungen hatte.
                                Ja ich weiß, sind "nur" Warnmeldungen, aber auch Warnungen haben ja oftmals einen Hintergrund. Kann man das hier generell ignorieren? Wenn die Meldungen keine Bedeutung haben, kann man das für den Enduser nicht ausblendbar machen?
                                Also eine Checkbox, ob man die Meldungen abschalten möchte? So könnten Entwickler, die mit diesen Meldungen ggf. mehr anfangen können, sich diese Meldungen auch weiterhin anzeigen lassen.
                                Nur mal so ins unreine gesprochen ......
                                npm warn ERESOLVE overriding peer dependency
                                npm warn While resolving: @iobroker/adapter-core@3.1.4 npm warn Found: @iobroker/types@6.0.0 npm warn node_modules/iobroker.admin/node_modules/@iobroker/types npm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14 npm warn node_modules/iobroker.admin npm warn iobroker.admin@"stable" from the root project npm warn npm warn Could not resolve dependency: npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4 npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14 npm warn node_modules/iobroker.admin npm warn npm warn Conflicting peer dependency: @iobroker/types@5.0.19 npm warn node_modules/@iobroker/types npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4 npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14 npm warn node_modules/iobroker.admin
                                foxriver76F ESP8266E Thomas BraunT 3 Antworten Letzte Antwort
                                • JB_SullivanJ JB_Sullivan
                                  foxriver76F Offline
                                  foxriver76F Offline
                                  foxriver76
                                  #161
                                  @jb_sullivan Gerne admin issue machen, dort ist https://github.com/ioBroker/ioBroker.admin/blob/761ded4f4947cef7d051dd74e11b5f785e652c25/packages/admin/package.json#L28 types als Production Dependency angegeben, das ist definitiv falsch.
                                    ESP8266E Offline
                                    ESP8266E Offline
                                    ESP8266
                                    schrieb am zuletzt editiert von ESP8266
                                    #162
                                    @foxriver76 , moin, es gab vor einigen Tagen ein echarts Adapter update. Das hat aber das Problem der Einstellungen nicht gelöst.
                                    Läuft aber im Hintergrund.
                                    foxriver76F sigi234S 2 Antworten Letzte Antwort
                                      #163
                                      @jb_sullivan
                                      Warum sollte es ausgeblendet werden? Gerade Beta-Versionen sollen ja dazu dienen möglichst viele Fehler und Hinweise zu finden und für das Stable-Release in Angriff zu nehmen.
                                      • ESP8266E ESP8266
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        #164
                                        @esp8266 denke nicht dass das was mit controller zu tun hat. Entweder PRoblem bei echarts oder admin evtl. Welche Admin Version läuft denn
                                        ESP8266E 1 Antwort Letzte Antwort
                                          ESP8266E Offline
                                          ESP8266E Offline
                                          ESP8266
                                          #165
                                          @foxriver76 , 6.17.14
