  4. Wir Empfehlen: Node.js 20.x :-)
237 Beiträge 49 Kommentatoren 109.2k Aufrufe 46 Beobachtet
    @hansmeier
    Fällt mir nix mehr zu ein.
    MartinPM
    MartinPM
    MartinP
    #96
    @thomas-braun Mein Senf:
    hauptseite und forum funktionieren, Repository Down?
    martin@iobroker-test-sicher:/var$ ping iobroker.net
    PING iobroker.net (82.165.135.239) 56(84) bytes of data.
    64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=55 time=22.0 ms
    64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=55 time=19.3 ms
    64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=3 ttl=55 time=17.6 ms
    64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=4 ttl=55 time=17.9 ms
    ^C
    --- iobroker.net ping statistics ---
    4 packets transmitted, 4 received, 0% packet loss, time 3007ms
    rtt min/avg/max/mdev = 17.605/19.196/21.973/1.721 ms
    martin@iobroker-test-sicher:/var$ ping forum.iobroker.net
    PING forum.iobroker.net (213.136.68.177) 56(84) bytes of data.
    64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=1 ttl=57 time=26.0 ms
    64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=2 ttl=57 time=24.0 ms
    64 bytes from m1713.contaboserver.net (213.136.68.177): icmp_seq=3 ttl=57 time=21.9 ms
    ^C
    --- forum.iobroker.net ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2003ms
    rtt min/avg/max/mdev = 21.918/23.954/25.978/1.657 ms
    martin@iobroker-test-sicher:/var$ ping download.iobroker.net
    PING download.iobroker.net (93.90.206.45) 56(84) bytes of data.
    ^C
    --- download.iobroker.net ping statistics ---
    3 packets transmitted, 0 received, 100% packet loss, time 2042ms
    • MartinPM MartinP
      ^C
      ^C
      ^C
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #97
      @martinp
      Der antwortet nicht auf pings.
      Der host iobroker.net selber antwortet nämlich.
      MartinPM H 2 Antworten Letzte Antwort
        @martinp
        MartinPM
        MartinPM
        MartinP
        #98
        @thomas-braun Das Problem von Gestern sollte behoben sein?
        forum, Hauptseite und repositories scheinen unterschiedliche IP-Adressen zu haben
        • MartinPM MartinP
          Thomas BraunT
          Thomas BraunT
          #99
          @martinp sagte in Wir Empfehlen: Node.js 20.x :-):
          Ja, soweit ich weiß läuft wieder alles.
            @martinp
            H
            H
            hansmeier
            #100
            @thomas-braun Das heisst dann wohl für mich: ioBroker neu installieren und dann das letzte Backup per Backitup Adapter einspielen ?
            Proxmox Backup ist zu jung. Da dürfte der Fehler schon enthalten sein.
              MartinPM
              MartinPM
              MartinP
              #101
              @thomas-braun stimmt, aber mit Merkwürdigkeiten gibt einen Redirect auf repo.iobroker.live, ab da geht es per IPv6 weiter:
              martin@iobroker-test-sicher:~$ wget http://download.iobroker.net/sources-dist.json
              --2024-06-07 15:31:32--  http://download.iobroker.net/sources-dist.json
              Resolving download.iobroker.net (download.iobroker.net)... 93.90.206.45
              Connecting to download.iobroker.net (download.iobroker.net)|93.90.206.45|:80... connected.
              HTTP request sent, awaiting response... 301 Moved Permanently
              Location: http://repo.iobroker.live/sources-dist.json [following]
              --2024-06-07 15:31:32--  http://repo.iobroker.live/sources-dist.json
              Resolving repo.iobroker.live (repo.iobroker.live)... 2606:4700:3030::ac43:de66, 2606:4700:3035::6815:56aa, 104.21.86.170, ...
              Connecting to repo.iobroker.live (repo.iobroker.live)|2606:4700:3030::ac43:de66|:80... connected.
              HTTP request sent, awaiting response... 200 OK
              Length: 4600604 (4.4M) [application/json]
              Saving to: 'sources-dist.json'
              sources-dist.json              100%[====================================================>]   4.39M  --.-KB/s    in 0.1s
              2024-06-07 15:31:33 (36.9 MB/s) - 'sources-dist.json' saved [4600604/4600604]
              EDIT: Gibt ja auch eine IPv4 Adresse, und die lässt sich auch anpingen....
              • H
                H
                hansmeier
                schrieb am zuletzt editiert von hansmeier
                #102
                IPv6 habe ich in meinem Router ungefähr zum gleichen Zeitpunkt wo ich keine Updates mehr angezeigt bekam, deaktiviert.
                Der Grund waren Probleme mit WireGuard.
                Es könnte also ein Zusammenhang bestehen.
                Hab jetzt mal IPv6 wieder freigegeben.
                Bringt aber leider keine Änderung
                • H hansmeier
                  Thomas BraunT
                  Thomas BraunT
                  #103
                  @hansmeier sagte in Wir Empfehlen: Node.js 20.x :-):
                  Schlechte Idee.
                  Versuch es mal mit
                  iob setup first
                  H 1 Antwort Letzte Antwort
                    Schlechte Idee.
                    Versuch es mal mit
                    iob setup first
                    H
                    H
                    hansmeier
                    #104
                    @thomas-braun sagte in Wir Empfehlen: Node.js 20.x :-):
                    iob setup first
                    Cool ! Das hat es gebracht. Die Repositories sind wieder da. Und gleich kamen 11 Adapter Updates hoch.
                    Danke, du hast meinen Tag gerettet.
                    Ich muss mal Proxmox unbedingt so einstellen, dass die Backups länger zurückreichen als eine Woche. 🙄
                                            v.2024-05-22
                     Static hostname: ioBrokerUbuntu2204
                           Icon name: computer-container
                             Chassis: container
                      Virtualization: lxc
                    Operating System: Ubuntu 22.04.4 LTS
                              Kernel: Linux 6.8.4-3-pve
                        Architecture: x86-64
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               64 bit
                    User-ID:                1001
                    Display-Server:         false
                    Pending OS-Updates:     0
                    Pending iob updates:    11
                    Nodejs-Installation:
                    /usr/bin/nodejs         v20.14.0
                    /usr/bin/node           v20.14.0
                    /usr/bin/npm            10.7.0
                    /usr/bin/npx            10.7.0
                    /usr/bin/corepack       0.28.1
                    Recommended versions are nodejs 18.20.3 and npm 10.7.0
                    MEMORY:
                    Mem:            6.1G        2.2G        3.1G        0.0K        811M        3.9G
                    Swap:           2.0G          0B        2.0G
                    Total:          8.2G        2.2G        5.2G
                    Active iob-Instances:   39
                    Active repo(s): stable
                    ioBroker Core:          js-controller           5.0.19
                                            admin                   6.13.16
                    Objects type: jsonl
                    States  type: jsonl
                    + system.adapter.admin.0                  : admin                 : ioBrokerUbuntu2204                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.web.0                    : web                   : ioBrokerUbuntu2204                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects:                17559
                    States:                 15478
                    Size of iob-Database:
                    17M     /opt/iobroker/iobroker-data/objects.jsonl
                    12M     /opt/iobroker/iobroker-data/objects.json.migrated
                    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                    9.4M    /opt/iobroker/iobroker-data/states.jsonl
                    2.3M    /opt/iobroker/iobroker-data/states.json.migrated
                    2.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                    • H hansmeier
                      iob setup first
                                              v.2024-05-22
                               Chassis: container
                        Virtualization: lxc
                      Installation:           lxc
                      Kernel:                 x86_64
                      Userland:               64 bit
                      User-ID:                1001
                      /usr/bin/npm            10.7.0
                      /usr/bin/npx            10.7.0
                      MEMORY:
                      Swap:           2.0G          0B        2.0G
                                              admin                   6.13.16
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                17559
                      States:                 15478
                      mcm1957M
                      mcm1957M
                      mcm1957
                      #105
                      Die Repositories kann man übrigends auch via Browser checken:
                      https://repo.iobroker.live/sources-dist-latest.json
                      https://repo.iobroker.live/sources-dist.json
                      sollten ein größeres json liefern. In edge ist es bei mir auch bracuhbar formatiert, in chrome nicht.
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      • mcm1957M mcm1957
                        #106
                        @mcm1957 sagte in Wir Empfehlen: Node.js 20.x :-):
                        leider klappt das oft 8bw8hl der ioBroker Probleme hat.
                          mcm1957M
                          mcm1957M
                          mcm1957
                          #107
                          Ja - aber da ihr oben gemutmaßt habt dass der Server weg ist wäre das in dem Fall eine Testmöglichkeit. Wenn das nicht geht ists klar dass was am Server klemmt ...
                          • DJMarc75D DJMarc75
                            @myssv sagte in Wir Empfehlen: Node.js 20.x :-):
                            folgende Fehler
                            Du wohnst in einer Zone wo es diese beiden Astros im Moment nicht gibt.
                            Kann man ignorieren und ist in der neuen Version 8.4.2 vom JavaSkriptAdapter behoben.
                            MartinPM
                            MartinPM
                            MartinP
                            #108
                            @djmarc75 said in Wir Empfehlen: Node.js 20.x :-):
                            folgende Fehler
                            Hmm, in wohne in Dortmund, ist eigentlich nicht nahe genug am Polarkreis um dieses Meldungen zu triggern - oder muss man da irgendwo seinen Geo-Position eintragen?
                            In den Basiseinstellungen ist das erfolgt..
                            HomoranH Marc BergM 2 Antworten Letzte Antwort
                            • MartinPM MartinP
                              folgende Fehler
                              #109
                              Hmm, in wohne in NRW, ist eigentlich nicht nahe genug am Polarkreis um dieses Meldungen zu triggern -
                              aber sicher doch!
                              sieh mal bei sonnenverlauf.de nach ob bei dir die Sonne unter -18° Elevation kommt.
                              Würde mich sehr wundern.
                              • MartinPM MartinP
                                folgende Fehler
                                Marc BergM
                                Marc BergM
                                Marc Berg
                                #110
                                Alles ca. nördlich des 49. Breitengrades ist davon "betroffen", also auch NRW.
                                Pi-hole, Traefik, Checkmk, Conbee II+Zigbee2MQTT, LoRaWAN
                                • Marc BergM Marc Berg
                                  MartinPM
                                  MartinPM
                                  MartinP
                                  #111
                                  @marc-berg said in Wir Empfehlen: Node.js 20.x :-):
                                  Irritierend, aber wenn, wie @homoran schrieb die "Nacht" erst beginnt, wenn die Sonne 18° unter dem Horizont steht ist das wahrscheinlich unter dem Gesichtspunkt, dass es selbst bei Neumond nie GANZ dunkel wird eine schlüssige Definition.
                                  • T
                                    T
                                    Tobi 1
                                    #112
                                    Also ich hab nach dem befehl iob nodejs-update das Problem dass ioBroker gar nicht mehr startet.
                                    Auch iob start hilft nicht, reboot und iob fix auch nicht.
                                    Könnt ihr mir helfen?
                                    Iob diag sagt folgendes:
                                                            v.2024-05-22
                                       Static hostname: raspberrypi
                                             Icon name: computer
                                      Operating System: Raspbian GNU/Linux 10 (buster)
                                                Kernel: Linux 6.6.30-v8+
                                          Architecture: arm64
                                    Kernel:                 aarch64
                                    Userland:               32 bit
                                    User-ID:                1000
                                    node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
                                    Pending iob updates:    0
                                    nodejs: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    /usr/bin/corepack
                                    Recommended versions are nodejs  and npm
                                    MEMORY:
                                    Mem:           3.8G        184M        2.0G        8.0M        1.6G        3.5G
                                    Swap:           99M          0B         99M
                                    Total:         3.9G        184M        2.1G
                                    Active iob-Instances:   0
                                                            admin
                                    ioBroker Status:
                                    Objects:                0
                                    States:                 0
                                    37M     /opt/iobroker/iobroker-data/objects.jsonl
                                    15M     /opt/iobroker/iobroker-data/objects.json.migrated
                                    15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    12M     /opt/iobroker/iobroker-data/objects_original.json
                                    32M     /opt/iobroker/iobroker-data/states.jsonl
                                    4.5M    /opt/iobroker/iobroker-data/states.json.migrated
                                    4.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                    Ro75R 1 Antwort Letzte Antwort
                                    • T Tobi 1
                                                              v.2024-05-22
                                               Icon name: computer
                                            Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               32 bit
                                      User-ID:                1000
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      /usr/bin/npx
                                      /usr/bin/corepack
                                      MEMORY:
                                      Swap:           99M          0B         99M
                                                              admin
                                      ioBroker Status:
                                      Objects:                0
                                      States:                 0
                                      Ro75R
                                      Ro75R
                                      Ro75
                                      #113
                                      @tobi-1
                                      1. Buster ist tot! Bookworm ist aktuell
                                      2. 32 Bit: besser 64 Bit lite Version
                                      3. graphical.target: Server benötigt keine grafische Oberfläche
                                      Wenn du ein Backup der ioBroker-Daten hast (sollte so sein), installiere den PI neu.
                                      Ro75
                                      • Ro75R Ro75
                                        @tobi-1
                                        Ro75
                                        T
                                        T
                                        Tobi 1
                                        #114
                                        @ro75
                                        Glaube ich alles, dass es was neueres, besseres usw.. bereits gibt 🙂
                                        Hab jetzt ein downgrade zu NodeJs 18.20.3 gemacht damit startet die Kiste auch wieder.
                                        Entweder ist bei mir eine Konfiguration im Raspi falsch oder NodeJS ist nicht kompatibel mit meinem System.
                                        Kenne mich da zu wenig aus.
                                        Ro75R HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                                        • T Tobi 1
                                          @ro75
                                          Ro75R
                                          Ro75R
                                          Ro75
                                          #115
                                          @tobi-1 sagte in Wir Empfehlen: Node.js 20.x :-):
                                          genau, da Buster zu alt und nicht mehr gepflegt wird. Du wirst Folgeprobleme bekommen! Angefangen, das sich Adapter werder installieren noch Updaten lassen.
                                          Bringe dein System auf einen aktuellen Stand - Buster ist es nicht!
                                          Ro75.
                                          84.1k
