  4. [gelöst] Namen defekt -> anstatt Unterstrich Minus
20 Beiträge 4 Kommentatoren 2.2k Aufrufe 4 Beobachtet
  • S stfan1409
    Ich dachte wenn es so klar drinn steht ist es nicht weiter von Interesse 😊
    connection lost .
    /opt/iobroker$ iob diag
    TERM environment variable not set.
    *** iob diag is starting up, please wait ***
    107*** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    /opt/iobroker$
    /opt/iobroker$
    Skript v.2024-05-22
    107*** BASE SYSTEM ***
    Static hostname: ubuntu
           Icon name: computer-desktop
             Chassis: desktop
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 5.15.0-94-generic
        Architecture: x86-64
    Hardware Vendor: Lenovo
      Hardware Model: ThinkCentre M910q
    model name    : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
    10:06:22 up 112 days, 19:54,  0 users,  load average: 0.14, 0.16, 0.16
    CPU threads: 4
    This system needs to be REBOOTED!
    107*** Time and Time Zones ***
                   Local time: Wed 2024-06-05 10:06:22 CEST
               Universal time: Wed 2024-06-05 08:06:22 UTC
                     RTC time: Wed 2024-06-05 08:06:22
                  NTP service: active
              RTC in local TZ: no
    107*** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video
    iobroker
    HOME=/home/iobroker
    107*** Display-Server-Setup ***
    Display-Server: false
    Desktop:
    Terminal:
    Boot Target:     graphical.target
    107*** MEMORY ***
    Mem:             15G        5.3G        5.7G        1.0M        4.9G         10G
    Swap:           4.1G          0B        4.1G
    Total:           19G        5.3G        9.8G
    Active iob-Instances:     28
            15877 M total memory
             5287 M used memory
             2249 M active memory
             7223 M inactive memory
             5718 M free memory
              775 M buffer memory
             4096 M swap cache
             4095 M total swap
                0 M used swap
             4095 M free swap
    107*** top - Table Of Processes  ***
    top - 10:06:23 up 112 days, 19:54,  0 users,  load average: 0.14, 0.16, 0.16
    Tasks: 178 total,   1 running, 177 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  7.9 us,  1.6 sy,  0.0 ni, 90.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  15877.8 total,   5718.1 free,   5287.2 used,   4872.5 buff/cache
    MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.  10252.6 avail Mem
    107*** FAILED SERVICES ***
    0 loaded units listed.
    107*** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  1.6G  1.6M  1.6G   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   13G   81G  14% /
    tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/nvme0n1p2                    ext4   2.0G  253M  1.6G  14% /boot
    /dev/nvme0n1p1                    vfat   1.1G  6.1M  1.1G   1% /boot/efi
    sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
    sudo: a password is required
    Show mounted filesystems:
    TARGET                                        SOURCE                            FSTYPE      OPTIONS
    /                                             /dev/mapper/ubuntu--vg-ubuntu--lv ext4        rw,relatime
    |-/sys                                        sysfs                             sysfs       rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security                      securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                            cgroup2                           cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
    | |-/sys/fs/pstore                            pstore                            pstore      rw,nosuid,nodev,noexec,relatime
    | |-/sys/firmware/efi/efivars                 efivarfs                          efivarfs    rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/bpf                               bpf                               bpf         rw,nosuid,nodev,noexec,relatime,mode=700
    | |-/sys/kernel/debug                         debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/tracing                       tracefs                           tracefs     rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/fuse/connections                  fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
    | `-/sys/kernel/config                        configfs                          configfs    rw,nosuid,nodev,noexec,relatime
    |-/proc                                       proc                              proc        rw,nosuid,nodev,noexec,relatime
    | `-/proc/sys/fs/binfmt_misc                  systemd-1                         autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=21418
    |   `-/proc/sys/fs/binfmt_misc                binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
    |-/dev                                        udev                              devtmpfs    rw,nosuid,relatime,size=8071492k,nr_inodes=2017873,mode=755,inode64
    | |-/dev/pts                                  devpts                            devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                                  tmpfs                             tmpfs       rw,nosuid,nodev,inode64
    | |-/dev/hugepages                            hugetlbfs                         hugetlbfs   rw,relatime,pagesize=2M
    | `-/dev/mqueue                               mqueue                            mqueue      rw,nosuid,nodev,noexec,relatime
    |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=1625892k,mode=755,inode64
    | |-/run/lock                                 tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
    | |-/run/credentials/systemd-sysusers.service none                              ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
    | |-/run/rpc_pipefs                           sunrpc                            rpc_pipefs  rw,relatime
    | `-/run/snapd/ns                             tmpfs[/snapd/ns]                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=1625892k,mode=755,inode64
    |   `-/run/snapd/ns/lxd.mnt                   nsfs[mnt:[4026532433]]            nsfs        rw
    |-/snap/snapd/21465                           /dev/loop1                        squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core20/2264                           /dev/loop2                        squashfs    ro,nodev,relatime,errors=continue
    |-/snap/lxd/28373                             /dev/loop7                        squashfs    ro,nodev,relatime,errors=continue
    |-/snap/core20/2318                           /dev/loop0                        squashfs    ro,nodev,relatime,errors=continue
    |-/boot                                       /dev/nvme0n1p2                    ext4        rw,relatime
    | `-/boot/efi                                 /dev/nvme0n1p1                    vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
    |-/snap/lxd/27948                             /dev/loop4                        squashfs    ro,nodev,relatime,errors=continue
    `-/snap/snapd/21759                           /dev/loop3                        squashfs    ro,nodev,relatime,errors=continue
    /var:
    Archived and active journals take up 224.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    531M    /opt/iobroker/iobroker-data/
    396M    /opt/iobroker/iobroker-data/files
    138M    /opt/iobroker/iobroker-data/files/javascript.admin
    118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    33M    /opt/iobroker/iobroker-data/objects.jsonl
    27M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    22M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    21M    /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.9f443724.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d7c3ec945ed11a48597a40a86e0b4-if00-port0
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    107*** NodeJS-Installation ***
    /usr/bin/nodejs     v18.18.2
    /usr/bin/node         v18.18.2
    /usr/bin/npm         9.8.1
    /usr/bin/npx         9.8.1
    /usr/bin/corepack     0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.20.3-1nodesource1
      Version table:
         18.20.3-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.2-1nodesource1 500
         18.20.1-1nodesource1 500
         18.20.0-1nodesource1 500
         18.19.1-1nodesource1 500
         18.19.0-1nodesource1 500
    *** 18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.9~dfsg-1ubuntu3.5 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    107*** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:     5.0.19
    admin:         6.13.16
    javascript:     8.3.1
    nodejs modules from github:     2
    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
    | +-- onvif@0.7.0 (git+ssh://git@github.com/agsh/onvif.git#74c21e63f4f8c3db19c5e529842af361050138cf)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ubuntu                                   -  enabled
    + system.adapter.artnet.0                 : artnet                : ubuntu                                   -  enabled, port: 6454
    + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
      system.adapter.denon.0                  : denon                 : ubuntu                                   - disabled
    + system.adapter.device-reminder.0        : device-reminder       : ubuntu                                   -  enabled
      system.adapter.discovery.0              : discovery             : ubuntu                                   - disabled
      system.adapter.flot.0                   : flot                  : ubuntu                                   - disabled
      system.adapter.fritzdect.0              : fritzdect             : ubuntu                                   - disabled
      system.adapter.hue.0                    : hue                   : ubuntu                                   - disabled, port: 80
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ubuntu                                   - disabled
    + system.adapter.info.0                   : info                  : ubuntu                                   -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : ubuntu                                   -  enabled
    + system.adapter.iqontrol.1               : iqontrol              : ubuntu                                   -  enabled
    + system.adapter.javascript.0             : javascript            : ubuntu                                   -  enabled
      system.adapter.kodi.0                   : kodi                  : ubuntu                                   - disabled, port: 9090
      system.adapter.logparser.0              : logparser             : ubuntu                                   - disabled
    + system.adapter.milight.0                : milight               : ubuntu                                   -  enabled, port: 5987
      system.adapter.mobile.0                 : mobile                : ubuntu                                   - disabled
    + system.adapter.modbus.0                 : modbus                : ubuntu                                   -  enabled
    + system.adapter.modbus.1                 : modbus                : ubuntu                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ubuntu                                   -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : ubuntu                                   -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.parser.0                 : parser                : ubuntu                                   - disabled
      system.adapter.ping.0                   : ping                  : ubuntu                                   - disabled
    + system.adapter.s7.0                     : s7                    : ubuntu                                   -  enabled
    + system.adapter.scenes.0                 : scenes                : ubuntu                                   -  enabled
      system.adapter.shelly.0                 : shelly                : ubuntu                                   - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.signal-cmb.0             : signal-cmb            : ubuntu                                   -  enabled
    + system.adapter.signal-cmb.1             : signal-cmb            : ubuntu                                   -  enabled
    + system.adapter.sql.0                    : sql                   : ubuntu                                   -  enabled, port: 3307
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ubuntu                                   -  enabled
    + system.adapter.telegram.0               : telegram              : ubuntu                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : ubuntu                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : ubuntu                                   -  enabled
    + system.adapter.time-switch.0            : time-switch           : ubuntu                                   -  enabled
    + system.adapter.viessmannapi.1           : viessmannapi          : ubuntu                                   -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ubuntu                                   - disabled
      system.adapter.vis-history.0            : vis-history           : ubuntu                                   - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ubuntu                                   - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ubuntu                                   - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ubuntu                                   - disabled
      system.adapter.vis.0                    : vis                   : ubuntu                                   -  enabled
    + system.adapter.web.0                    : web                   : ubuntu                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : ubuntu                                   -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "artnet"       : 1.2.2    , installed 1.2.2
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "denon"        : 1.15.5   , installed 1.15.5
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "hue"          : 3.11.0   , installed 3.11.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 8.3.1    , installed 8.3.1
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
    Adapter    "milight"      : 0.4.0    , installed 0.4.0
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "onvif"        : 1.1.3    , installed 1.1.3
    Adapter    "parser"       : 2.1.0    , installed 2.1.0
    Adapter    "s7"           : 1.4.3    , installed 1.4.3
    Adapter    "shelly"       : 6.9.0    , installed 6.9.0
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 3.3.2    , installed 3.3.2
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:     11061
    States:     9028
    107*** OS-Repositories and Updates ***
    W: Target Packages (contrib/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list:2
    W: Target Packages (contrib/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list:2
    W: Target Translations (contrib/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list:2
    W: Target Translations (contrib/i18n/Translation-de) is configured multiple times in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list:2
    W: Target CNF (contrib/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list:2
    W: Target CNF (contrib/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list:2
    W:
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Ign:6 https://download.webmin.com/download/newkey/repository stable InRelease
    Hit:7 https://download.webmin.com/download/newkey/repository stable Release
    Reading package lists...
    Pending Updates: 69
    107*** Listening Ports ***
    107*** Log File - Last 25 Lines ***
    2024-06-05 09:34:09.498  - info: info.0 (439389) cpu Temp res = {"main":32,"cores":[32,31,33,32],"max":33,"socket":[],"chipset":null}
    2024-06-05 09:50:14.515  - info: admin.0 (439094) Adapter rating updated
    2024-06-05 09:53:58.027  - info: iqontrol.0 (1063306) COUNTER Fenster OPEN: 1 of 16
    2024-06-05 09:53:58.029  - info: iqontrol.0 (1063306) COUNTER Fenster LONG_OPEN: 0 of 16
    2024-06-05 09:57:50.828  - info: admin.0 (439094) Request actual repository...
    2024-06-05 09:57:51.196  - info: host.ubuntu Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2024-06-05 09:57:53.077  - info: admin.0 (439094) Repository received successfully.
    2024-06-05 10:02:02.255  - error: sql.0 (439173) Counter must have type "number"!
    2024-06-05 10:02:02.506  - info: iqontrol.0 (1063306) COUNTER Fenster OPEN: 2 of 16
    2024-06-05 10:02:02.508  - info: iqontrol.0 (1063306) COUNTER Fenster LONG_OPEN: 0 of 16
    2024-06-05 10:02:23.009  - info: iqontrol.0 (1063306) COUNTER Fenster OPEN: 1 of 16
    2024-06-05 10:02:23.011  - info: iqontrol.0 (1063306) COUNTER Fenster LONG_OPEN: 0 of 16
    2024-06-05 10:02:24.807  - error: sql.0 (439173) Counter must have type "number"!
    2024-06-05 10:02:25.054  - info: iqontrol.0 (1063306) COUNTER Fenster OPEN: 2 of 16
    2024-06-05 10:02:25.056  - info: iqontrol.0 (1063306) COUNTER Fenster LONG_OPEN: 0 of 16
    2024-06-05 10:02:27.169  - info: admin.0 (439094) ==> Connected system.user.admin from ::ffff:10.242.2.2
    2024-06-05 10:02:35.369  - info: iqontrol.0 (1063306) COUNTER Fenster OPEN: 1 of 16
    2024-06-05 10:02:35.371  - info: iqontrol.0 (1063306) COUNTER Fenster LONG_OPEN: 0 of 16
    2024-06-05 10:02:40.217  - error: sql.0 (439173) Counter must have type "number"!
    2024-06-05 10:02:40.507  - info: iqontrol.0 (1063306) COUNTER Fenster OPEN: 2 of 16
    2024-06-05 10:02:40.508  - info: iqontrol.0 (1063306) COUNTER Fenster LONG_OPEN: 0 of 16
    2024-06-05 10:02:48.724  - info: iqontrol.0 (1063306) COUNTER Fenster OPEN: 1 of 16
    2024-06-05 10:02:48.726  - info: iqontrol.0 (1063306) COUNTER Fenster LONG_OPEN: 0 of 16
    2024-06-05 10:04:47.179  - info: admin.0 (439094) <== Disconnect system.user.admin from ::ffff:10.242.2.2 admin
    2024-06-05 10:05:14.287  - info: admin.0 (439094) ==> Connected system.user.admin from ::ffff:10.242.2.2
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
                v.2024-05-22
             Chassis: desktop
    Installation:         native
    Kernel:         x86_64
    Userland:         64 bit
    Timezone:         Europe/Berlin (CEST, +0200)
    User-ID:         1001
    Pending OS-Updates:     69
    Pending iob updates:     0
    This system needs to be REBOOTED NOW!
    Nodejs-Installation:
    /usr/bin/npm         9.8.1
    /usr/bin/npx         9.8.1
    Recommended versions are nodejs 18.20.3 and npm 10.7.0
    MEMORY:
    Swap:           4.1G          0B        4.1G
    ioBroker Core:         js-controller         5.0.19
                admin             6.13.16
    ioBroker Status:     iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects:         11061
    States:         9028
    Size of iob-Database:
    16M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    /opt/iobroker$
    @stfan1409 sagte in [gelöst] Namen defekt -> anstatt Unterstrich Minus:
    nur meist kommt so ein Fehler nicht allein.
    ist das jetzt ein neuer Check?
    auf due Scnelle und unvollständig
    da steht immer noch was von reboot.
    und node ist auch nicht aktuell
      stfan1409
      Das ist VOR dem Neustart.
      Node muss ich tatsächlich aktualisieren. Das hab ich übersehen. Danke.
      • S stfan1409
        @stfan1409
        iob stop
        iob fix
        iob nodejs-update
        sudo reboot
        Und dann die Langfassung von
        iob diag
        posten.
          @stfan1409
          iob stop
          iob fix
          iob nodejs-update
          sudo reboot
          iob diag
          posten.
          stfan1409
          schrieb am zuletzt editiert von stfan1409
          so, nun sollte alles aktuell sein.
          1 Error habe ich aber noch gesehen:
          Errors in npm tree: 107*** ioBroker-Installation ***
          wofür steht der?
          iob diag:
          Skript v.2024-05-22
                   Chassis: desktop
          Operating System: Ubuntu 22.04.4 LTS
                    Kernel: Linux 5.15.0-107-generic
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          18:41:16 up 40 min,  0 users,  load average: 0.42, 0.36, 0.25
          CPU threads: 4
                         Local time: Wed 2024-06-05 18:41:16 CEST
                     Universal time: Wed 2024-06-05 16:41:16 UTC
                           RTC time: Wed 2024-06-05 16:41:16
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:
          107*** MEMORY ***
          Mem:             15G        1.8G         13G        1.0M        1.0G         13G
          Swap:           4.1G          0B        4.1G
          Total:           19G        1.8G         17G
                   1787 M used memory
                    504 M active memory
                   1974 M inactive memory
                  13069 M free memory
                    111 M buffer memory
                    909 M swap cache
                   4095 M total swap
                      0 M used swap
                   4095 M free swap
          top - 18:41:16 up 40 min,  0 users,  load average: 0.42, 0.36, 0.25
          Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  3.1 us,  1.5 sy,  0.0 ni, 95.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  15877.8 total,  13068.8 free,   1788.0 used,   1020.9 buff/cache
          MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.  13787.8 avail Mem
          tmpfs                             tmpfs  1.6G  1.5M  1.6G   1% /run
          /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   14G   80G  15% /
          /dev/nvme0n1p2                    ext4   2.0G  254M  1.6G  14% /boot
          | `-/proc/sys/fs/binfmt_misc                  systemd-1                         autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=18348
          |-/dev                                        udev                              devtmpfs    rw,nosuid,relatime,size=8071116k,nr_inodes=2017779,mode=755,inode64
          |-/run                                        tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=1625888k,mode=755,inode64
          | `-/run/snapd/ns                             tmpfs[/snapd/ns]                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=1625888k,mode=755,inode64
          |   `-/run/snapd/ns/lxd.mnt                   nsfs[mnt:[4026532501]]            nsfs        rw
          |-/snap/core20/2264                           /dev/loop0                        squashfs    ro,nodev,relatime,errors=continue
          |-/snap/lxd/28373                             /dev/loop2                        squashfs    ro,nodev,relatime,errors=continue
          |-/snap/lxd/27948                             /dev/loop1                        squashfs    ro,nodev,relatime,errors=continue
          |-/snap/snapd/21465                           /dev/loop3                        squashfs    ro,nodev,relatime,errors=continue
          |-/snap/core20/2318                           /dev/loop4                        squashfs    ro,nodev,relatime,errors=continue
          |-/snap/snapd/21759                           /dev/loop5                        squashfs    ro,nodev,relatime,errors=continue
          `-/boot                                       /dev/nvme0n1p2                    ext4        rw,relatime
          /var:
          515M    /opt/iobroker/iobroker-data/
          21M    /opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          /usr/bin/nodejs     v20.14.0
          /usr/bin/node         v20.14.0
          /usr/bin/npm         10.7.0
          /usr/bin/npx         10.7.0
          /usr/bin/corepack     0.28.1
          nodejs:
            Installed: 20.14.0-1nodesource1
            Candidate: 20.14.0-1nodesource1
            Version table:
          *** 20.14.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:         6.13.16
          javascript:     8.3.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:     11076
          States:     9032
          W:
          Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
          Pending Updates: 5
          2024-06-05 18:02:18.845  - info: time-switch.0 (1827) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.time-switch, node: v20.14.0, js-controller: 5.0.19
          2024-06-05 18:02:22.843  - info: vis.0 (1842) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v20.14.0, js-controller: 5.0.19
          2024-06-05 18:02:23.524  - info: vis.0 (1842) Terminated (NO_ERROR): Without reason
          2024-06-05 18:02:24.142  - info: host.ubuntu instance system.adapter.vis.0 terminated while should be started once
          2024-06-05 18:02:26.309  - info: host.ubuntu instance system.adapter.web.0 started with pid 1857
          2024-06-05 18:02:26.943  - info: web.0 (1857) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.14.0, js-controller: 5.0.19
          2024-06-05 18:02:27.094  - info: web.0 (1857) socket.io server listening on port 8082
          2024-06-05 18:02:27.096  - info: web.0 (1857) http server listening on port 8082
          2024-06-05 18:02:30.349  - info: host.ubuntu instance system.adapter.viessmannapi.1 started with pid 1874
          2024-06-05 18:02:30.943  - info: viessmannapi.1 (1874) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v20.14.0, js-controller: 5.0.19
          2024-06-05 18:02:33.568  - info: viessmannapi.1 (1874) 1 installations found.
          2024-06-05 18:02:34.374  - info: host.ubuntu instance system.adapter.signal-cmb.0 started with pid 1889
          2024-06-05 18:02:34.910  - info: signal-cmb.0 (1889) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.signal-cmb, node: v20.14.0, js-controller: 5.0.19
          2024-06-05 18:02:38.320  - info: host.ubuntu instance system.adapter.signal-cmb.1 started with pid 1904
          2024-06-05 18:02:38.843  - info: signal-cmb.1 (1904) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.signal-cmb, node: v20.14.0, js-controller: 5.0.19
          2024-06-05 18:02:42.347  - info: host.ubuntu instance system.adapter.device-reminder.0 started with pid 1919
          2024-06-05 18:02:42.900  - info: device-reminder.0 (1919) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v20.14.0, js-controller: 5.0.19
          2024-06-05 18:02:46.232  - info: host.ubuntu instance system.adapter.milight.0 started with pid 1934
          2024-06-05 18:02:46.725  - info: milight.0 (1934) starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.milight, node: v20.14.0, js-controller: 5.0.19
          2024-06-05 18:02:46.736  - warn: milight.0 (1934) No IP address defined
          2024-06-05 18:13:38.340  - info: mqtt.0 (1159) Client [DVES_BD22D6] connection closed: closed
          2024-06-05 18:13:49.115  - info: mqtt.0 (1159) Client [DVES_BD22D6] connected with secret 1717604029114_9915
          2024-06-05 18:13:49.231  - info: mqtt.0 (1159) Client [DVES_BD22D6] subscribes on "BB_EVU/cmnd/#" with regex /^BB_EVU\.cmnd\..*/
          2024-06-05 18:13:49.231  - info: mqtt.0 (1159) Client [DVES_BD22D6] subscribes on "BB_EVU/cmnd/#"  with regex /^mqtt\.0\.BB_EVU\.cmnd\..*/
          2024-06-05 18:13:49.431  - info: mqtt.0 (1159) Client [DVES_BD22D6] publishOnSubscribe send all known states
                      v.2024-05-22
                   Chassis: desktop
          Kernel:         x86_64
          Userland:         64 bit
          User-ID:         1001
          Pending OS-Updates:     5
          /usr/bin/npm         10.7.0
          /usr/bin/npx         10.7.0
          MEMORY:
          Swap:           4.1G          0B        4.1G
          Total:           19G        1.8G         17G
                      admin             6.13.16
          Objects type: jsonl
          States  type: jsonl
          Objects:         11076
          States:         9032
          12M    /opt/iobroker/iobroker-data/states.jsonl
          • S stfan1409
            wofür steht der?
            iob diag:
            Skript v.2024-05-22
                     Chassis: desktop
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            iobroker
            HOME=/home/iobroker
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:
            107*** MEMORY ***
            Swap:           4.1G          0B        4.1G
            Total:           19G        1.8G         17G
                     1787 M used memory
                      504 M active memory
                    13069 M free memory
                      111 M buffer memory
                      909 M swap cache
                     4095 M total swap
                        0 M used swap
                     4095 M free swap
            /var:
            USB-Devices by-id:
            HINT:
            /dev/ttyUSB0
            /usr/bin/npm         10.7.0
            /usr/bin/npx         10.7.0
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:         6.13.16
            javascript:     8.3.1
            Adapter State
            + instance is alive
            Objects and States
            Objects:     11076
            States:     9032
            W:
            Pending Updates: 5
                        v.2024-05-22
                     Chassis: desktop
            Kernel:         x86_64
            Userland:         64 bit
            User-ID:         1001
            /usr/bin/npm         10.7.0
            /usr/bin/npx         10.7.0
            MEMORY:
            Swap:           4.1G          0B        4.1G
            Total:           19G        1.8G         17G
                        admin             6.13.16
            Objects type: jsonl
            States  type: jsonl
            Objects:         11076
            States:         9032
            Stell das um auf
            sudo systemctl set-default multi-user.target
            Und log dich nicht mit dem user ioBroker sondern mit dem offenbar ja auch vorhandenen user mit der uid=1000 ein.
            sudo apt update
            sudo apt full-upgrade
            Kann aber auch sein, dass das diese 'staged updates' bei Schnubbibuntu sind.
            Wie gehst du denn auf die Kiste drauf?
            HINT:
            /dev/ttyUSB0
            Setz den COM-Port im Zigbee-Adapter auf
            Nimm den doppelten Eintrag in der Datei raus:
            Da ist kein Fehler. Die 107 kommt aus deinem Terminal 'falsch' raus. Welches verwendest du da?
              Stell das um auf
              sudo apt update
              HINT:
              /dev/ttyUSB0
              stfan1409
              @thomas-braun sagte in [gelöst] Namen defekt -> anstatt Unterstrich Minus:
              Stell das um auf
              erledigt
              sudo apt update
              erledigt
              tobi@ubuntu:~$ sudo systemctl set-default multi-user.target
              [sudo] password for tobi:
              Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-u        ser.target.
              tobi@ubuntu:~$ sudo apt update
              OK:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
              Holen:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease [128 kB]
              OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
              OK:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
              Holen:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease [129 kB]
              Holen:6 http://de.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [1.687 kB]
              Holen:7 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [1.084 kB]
              Holen:8 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe Translation-en [250 kB]
              Holen:9 http://de.archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 Packages [43,0 kB]
              Ign:10 https://download.webmin.com/download/newkey/repository stable InRelease
              OK:11 https://download.webmin.com/download/newkey/repository stable Release
              Es wurden 3.322 kB in 5 s geholt (707 kB/s).
              Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
              W: Ziel Packages (contrib/binary-amd64/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/webmin.list:1 und /etc/apt/sources.list.d/webmin.list:2
              W: Ziel Packages (contrib/binary-all/Packages) ist mehrfach konfiguriert in /etc/apt/sources.list.d/webmin.list:1 und /etc/apt/sources.list.d/webmin.list:2
              W: Ziel Translations (contrib/i18n/Translation-de_DE) ist mehrfach konfiguriert in /etc/apt/sources.list.d/webmin.list:1 und /etc/apt/sources.list.d/webmin.list:2
              W: Ziel Translations (contrib/i18n/Translation-de) ist mehrfach konfiguriert in /etc/apt/sources.list.d/webmin.list:1 und /etc/apt/sources.list.d/webmin.list:2
              W: Ziel Translations (contrib/i18n/Translation-en) ist mehrfach konfiguriert in /etc/apt/sources.list.d/webmin.list:1 und /etc/apt/sources.list.d/webmin.list:2
              W: Ziel CNF (contrib/cnf/Commands-amd64) ist mehrfach konfiguriert in /etc/apt/sources.list.d/webmin.list:1 und /etc/apt/sources.list.d/webmin.list:2
              W: Ziel CNF (contrib/cnf/Commands-all) ist mehrfach konfiguriert in /etc/apt/sources.list.d/webmin.list:1 und /etc/apt/sources.list.d/webmin.list:2
              tobi@ubuntu:~$ sudo apt full-upgrade
              Paketaktualisierung (Upgrade) wird berechnet… Fertig
              Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                libflashrom1 libftdi1-2
              Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
              Die folgenden Pakete sind zurückgehalten worden:
                cloud-init
              0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
              W: Ziel CNF (contrib/cnf/Commands-amd64) ist mehrfach konfiguriert in /etc/apt/sources.l/sources.list.d/webmin.list:1 und /e^Cnslation-de) ist mehrfach konfiguriert in /etc/apt
              tobi@ubuntu:~$
              normalerweise mit Putty. Gestern war ich unterwegs und habe das Terminal aus ioBroker genutzt.
              HINT:
              /dev/ttyUSB0
              dieser Port ist auf der Weboberfläche in ioB bereits ausgewählt:
              wie mache ich das?
              Aber heute wieder Putty
              Ich habe gerade festgestellt, dass der Befehl
              iob diag
              nicht mehr funktioniert. Nach dem Befehl wird das Passwort abgefragt und dann ist ende:
              Last login: Thu Jun  6 05:22:06 2024 from 192.168.20.176
              tobi@ubuntu:~$ iob diag
              tobi@ubuntu:~$
              • Thomas BraunT Online
                Nein, trag da statt /dev/GERAET den by-id-Link ein.
                Zu den Doubletten:
                Dateien bearbeitet man mit einem Editor, z.B. nano.
                • S stfan1409
                  Stell das um auf
                  erledigt
                  sudo apt update
                  erledigt
                    cloud-init
                  tobi@ubuntu:~$
                  HINT:
                  /dev/ttyUSB0
                  wie mache ich das?
                  iob diag
                  tobi@ubuntu:~$
                  @stfan1409
                  Ruf iob diag mal so auf:
                  curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                    @stfan1409
                    stfan1409
                    @stfan1409
                    das sieht dann so aus:
                    tobi@ubuntu:~$ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                     Dload  Upload   Total   Spent    Left  Speed
                      0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                    curl: (7) Failed to connect to iobroker.net port 443 after 22 ms: Connection ref                                   used
                    tobi@ubuntu:~$
                    • S stfan1409
                      @stfan1409
                      tobi@ubuntu:~$
                      @stfan1409
                      Der Server iobroker.net ist gerade nicht zu erreichen.
                        @stfan1409
                        stfan1409
                        also mein eigener?
                        • S stfan1409
                          also mein eigener?
                          @stfan1409
                          Nein, iobroker.net
                            @stfan1409
                            Nein, iobroker.net
                            stfan1409
                            ok nun funktioniert es: (die Fehler muss ich noch beheben. ic hhoffe ich schaffe das zeitlich am Wochenende)
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                                     Chassis: desktop
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             05:25:04 up 23:51,  1 user,  load average: 0.06, 0.11, 0.09
                            CPU threads: 4
                                           Local time: Fri 2024-06-07 05:25:04 CEST
                                       Universal time: Fri 2024-06-07 03:25:04 UTC
                                             RTC time: Fri 2024-06-07 03:25:04
                                          NTP service: active
                                      RTC in local TZ: no
                            tobi
                            HOME=/home/tobi
                            GROUPS=tobi adm cdrom sudo dip plugdev lxd iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:             15G        2.1G         12G        1.0M        926M         13G
                            Swap:           4.1G          0B        4.1G
                            Total:           19G        2.1G         16G
                                     2085 M used memory
                                      466 M active memory
                                     2235 M inactive memory
                                    12865 M free memory
                                      220 M buffer memory
                                      705 M swap cache
                                     4095 M total swap
                                        0 M used swap
                                     4095 M free swap
                            top - 05:25:15 up 23:51,  1 user,  load average: 0.22, 0.14, 0.10
                            %Cpu(s):  1.6 us,  0.0 sy,  0.0 ni, 98.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :  15877.8 total,  12865.7 free,   2085.7 used,    926.3 buff/cache
                            MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.  13499.7 avail Mem
                            *** FILESYSTEM ***
                            tmpfs                             tmpfs  1.6G  4.0K  1.6G   1% /run/user/1000
                            [Thu Jun  6 05:33:46 2024] EXT4-fs (dm-0): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
                            [Thu Jun  6 05:33:46 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:        none.
                            [Thu Jun  6 05:33:47 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered        data mode. Opts: (null). Quota mode: none.
                            |                                               ext4    rw,relatime
                            | |-/sys/kernel/security       securityfs       securit rw,nosuid,nodev,noexec,r
                            | |-/sys/firmware/efi/efivars  efivarfs         efivarf rw,nosuid,nodev,noexec,r
                            | `-/sys/kernel/config         configfs         configf rw,nosuid,nodev,noexec,r
                            |   `-/proc/sys/fs/binfmt_misc binfmt_misc      binfmt_ rw,nosuid,nodev,noexec,r
                            |-/dev                         udev             devtmpf rw,nosuid,relatime,size=
                            | |-/dev/hugepages             hugetlbfs        hugetlb rw,relatime,pagesize=2M
                            | |-/run/rpc_pipefs            sunrpc           rpc_pip rw,relatime
                            | | `-/run/snapd/ns/lxd.mnt    nsfs[mnt:[4026532431]]
                            | |                                             nsfs    rw
                            | `-/run/user/1000             tmpfs            tmpfs   rw,nosuid,nodev,relatime
                            |-/snap/core20/2264            /dev/loop0       squashf ro,nodev,relatime,errors
                            |-/snap/lxd/27948              /dev/loop1       squashf ro,nodev,relatime,errors
                            |-/snap/snapd/21465            /dev/loop2       squashf ro,nodev,relatime,errors
                            |-/snap/lxd/28373              /dev/loop3       squashf ro,nodev,relatime,errors
                            |-/snap/core20/2318            /dev/loop4       squashf ro,nodev,relatime,errors
                            |-/snap/snapd/21759            /dev/loop5       squashf ro,nodev,relatime,errors
                            /var:
                            2.1G    /var/
                            816M    /var/lib
                            759M    /var/log
                            753M    /var/log/journal/855baa55560646729ffa74c22b1a720b
                            Archived and active journals take up 752.1M in the file system.
                            514M    /opt/iobroker/iobroker-data/
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                            22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
                            21M     /opt/iobroker/iobroker-data/files/s7.admin/static/js/main.9f443724.js.ma        p
                            19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc        3820.js.map
                            USB-Devices by-id:
                            USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d7c3ec945ed11a4        8597a40a86e0b4-if00-port0
                            HINT:
                            /dev/ttyUSB0
                            /usr/bin/npm            10.7.0
                            /usr/bin/npx            10.7.0
                            nodejs:
                              Version table:
                                    500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Pac        kages
                                    500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Pa        ckages
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.13.16
                            javascript:     8.3.1
                            | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi        -ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                            | +-- onvif@0.7.0 (git+ssh://git@github.com/agsh/onvif.git#74c21e63f4f8c3db19c5e        529842af361050138cf)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : ubuntu        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                            + system.adapter.terminal.0               : terminal              : ubuntu        -  enabled, port: 8088, bind: 0.0.0.0, run as: admi        n
                            + system.adapter.web.0                    : web                   : ubuntu        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                            + instance is alive
                            Objects and States
                            Objects:        11076
                            States:         9032
                            W: Target Packages (contrib/binary-amd64/Packages) is configured multiple times        in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list        :2
                            W: Target Translations (contrib/i18n/Translation-en) is configured multiple time        s in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.li        st:2
                            W: Target Translations (contrib/i18n/Translation-de) is configured multiple time        s in /etc/apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.li        st:2
                            W: Target CNF (contrib/cnf/Commands-amd64) is configured multiple times in /etc/        apt/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list:2
                            W: Target CNF (contrib/cnf/Commands-all) is configured multiple times in /etc/ap        t/sources.list.d/webmin.list:1 and /etc/apt/sources.list.d/webmin.list:2
                            Reading package lists... Done
                            Pending Updates: 1
                            Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
                            tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN        0          28007      796/perl
                            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN        1001       30823      1321/node-red
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        1001       29296      1649/io.mqtt.0
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          26074      727/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN        0          19385      1/init
                            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN        102        25870      652/systemd-resolve
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       26148      700/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       27985      700/iobroker.js-con
                            tcp6       0      0 :::22                   :::*                    LISTEN        0          26076      727/sshd: /usr/sbin
                            tcp6       0      0 :::111                  :::*                    LISTEN        0          15483      1/init
                            tcp6       0      0 :::8088                 :::*                    LISTEN        1001       33197      2659/io.terminal.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN        1001       26421      789/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN        1001       35993      2857/io.web.0
                            udp        0      0 127.0.0.53:53           0.0.0.0:*        102        25869      652/systemd-resolve
                            udp        0      0 0.0.0.0:111             0.0.0.0:*        0          19905      1/init
                            udp        0      0 0.0.0.0:10000           0.0.0.0:*        0          28008      796/perl
                            udp6       0      0 :::111                  :::*        0          19386      1/init
                            2024-06-07 04:44:41.106  - info: mqtt.0 (1649) Client [ESP_Mama_0] connected wit        h secret 1717728281106_4664
                            2024-06-07 04:44:41.136  - info: mqtt.0 (1649) Client [ESP_Mama_0] subscribes on        "ESP_Mama/#" with regex /^ESP_Mama\..*/
                            2024-06-07 04:44:41.136  - info: mqtt.0 (1649) Client [ESP_Mama_0] subscribes on        "ESP_Mama/#"  with regex /^mqtt\.0\.ESP_Mama\..*/
                            2024-06-07 04:44:41.336  - info: mqtt.0 (1649) Client [ESP_Mama_0] publishOnSubs        cribe send all known states
                            2024-06-07 04:45:59.846  - info: mqtt.0 (1649) Client [ESP_Mama_0] connection cl        osed: timeout
                            2024-06-07 04:46:00.110  - info: mqtt.0 (1649) Client [ESP_Mama_0] connected wit        h secret 1717728360110_6451
                            2024-06-07 04:46:00.137  - info: mqtt.0 (1649) Client [ESP_Mama_0] subscribes on        "ESP_Mama/#" with regex /^ESP_Mama\..*/
                            2024-06-07 04:46:00.137  - info: mqtt.0 (1649) Client [ESP_Mama_0] subscribes on        "ESP_Mama/#"  with regex /^mqtt\.0\.ESP_Mama\..*/
                            2024-06-07 04:46:00.337  - info: mqtt.0 (1649) Client [ESP_Mama_0] publishOnSubs        cribe send all known states
                            2024-06-07 04:48:07.802  - info: mqtt.0 (1649) Client [ESP_Mama_0] connection cl        osed: timeout
                            2024-06-07 04:48:38.390  - info: mqtt.0 (1649) Client [ESP_Mama_0] connected wit        h secret 1717728518389_344
                            2024-06-07 04:48:38.412  - info: mqtt.0 (1649) Client [ESP_Mama_0] subscribes on        "ESP_Mama/#" with regex /^ESP_Mama\..*/
                            2024-06-07 04:48:38.413  - info: mqtt.0 (1649) Client [ESP_Mama_0] subscribes on        "ESP_Mama/#"  with regex /^mqtt\.0\.ESP_Mama\..*/
                            2024-06-07 04:48:38.614  - info: mqtt.0 (1649) Client [ESP_Mama_0] publishOnSubs        cribe send all known states
                            2024-06-07 04:48:39.219  - warn: javascript.0 (1247) State "0_userdata.0.Datenpu        nkte.test.WasserSpeicherDiff" not found
                            2024-06-07 04:48:39.223  - warn: javascript.0 (1247)     at setState (/opt/iobro        ker/node_modules/iobroker.javascript/lib/sandbox.js:1975:20)
                            2024-06-07 04:48:39.223  - warn: javascript.0 (1247)     at Object.<anonymous> (        script.js.common.Heizungswerte:142:5)
                            2024-06-07 04:48:39.223  - warn: javascript.0 (1247)     at Object.callback (/op        t/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1396:38)
                            2024-06-07 04:48:39.223  - warn: javascript.0 (1247)     at Object.stateChange (        /opt/iobroker/node_modules/iobroker.javascript/main.js:641:29)
                            2024-06-07 04:48:39.224  - warn: javascript.0 (1247)     at Immediate._onImmedia        te (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/a        dapter.ts:11200:62)
                            2024-06-07 04:48:39.224  - warn: javascript.0 (1247)     at processImmediate (no        de:internal/timers:478:21)
                            2024-06-07 05:24:08.056  - info: admin.0 (789) ==> Connected system.user.admin f        rom ::ffff:192.168.20.176
                            2024-06-07 05:24:10.471  - info: admin.0 (789) ==> Connected system.user.admin f        rom ::ffff:192.168.20.176
                            2024-06-07 05:24:10.684  - info: zigbee.0 (1750) List of port: [{"path":"/dev/tt        yUSB0","manufacturer":"ITead","serialNumber":"c24d7c3ec945ed11a48597a40a86e0b4",        "pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c24d7c3ec945ed11a48597a40a8        6e0b4-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS4","ve        ndorId":"8086","productId":"a2bd"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{        "path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/de        v/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},        {"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/d        ev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},        {"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/d        ev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"}        ,{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/d        ev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"p        ath":"/dev/ttyS9"}]
                            2024-06-07 05:24:18.541  - info: admin.0 (789) <== Disconnect system.user.admin        from ::ffff:192.168.20.176
