  4. Ical.0 findet lokalen Kalender nicht
14 Beiträge 4 Kommentatoren 540 Aufrufe 3 Beobachtet
  • M Mico
    Hallo alle zusammen,
    Ich habe seit dem ich auf einen "neuen Raspberry umgezogen bin" das Problem das der Adapter Ical meine als lokale Kalender abgelegeten Dateien nicht findet.
    2024-06-04 06:00:01.086 - warn: ical.0 (10915) Error reading "/home/pi/muell24.ics": File does not exist: "/home/pi/muell24.ics"
    2024-06-04 06:00:01.129 - warn: ical.0 (10915) Error reading "/home/pi/carsten.ics": File does not exist: "/home/pi/carsten.ics"
    2024-06-04 06:00:01.129 - info: ical.0 (10915) All calenders could not be processed, Do not clean up events
    2024-06-04 06:00:05.006 - warn: trashschedule.0 (8949) no events matches type "Restmülltonne" with match "Restmüll" (exact match)
    2024-06-04 06:00:05.098 - warn: trashschedule.0 (8949) no events matches type "Wertstoffsack" with match "Gelber Sack" (exact match)
    2024-06-04 06:00:05.101 - warn: trashschedule.0 (8949) no events matches type "Bioabfalltonne" with match "Bioabfall" (exact match)
    2024-06-04 06:00:05.104 - warn: trashschedule.0 (8949) no events matches type "Altpapiertonne" with match "Altpapier" (exact match)
    2024-06-04 06:00:05.107 - warn: trashschedule.0 (8949) no events matches type "Schadstoffmobil" with match "Mobile Schadstoffsammlung" (exact match)
    2024-06-04 06:00:05.110 - warn: trashschedule.0 (8949) no events matches type "Weihnachtsbaum" with match "Tannenbaum"
    2024-06-04 06:00:05.117 - warn: trashschedule.0 (8949) (5) next has no entries. Check configuration of trashschedule!
    2024-06-04 06:00:05.120 - warn: trashschedule.0 (8949) (5) nextAfter has no entries. Check configuration of trashschedule!
    2024-06-04 06:00:06.133 - info: ical.0 (10915) Terminated (NO_ERROR): Without reason
    2024-06-04 06:00:06.646 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-06-04 06:02:31.138 - warn: admin.0 (1308) ical has an invalid jsonConfig: [{"instancePath":"/items/_calendars/items/calendars/items/5","schemaPath":"#/items/allOf/5/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_calendars/items/calendars","schemaPath":"#/patternProperties/%5E.%2B/allOf/23/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/_calendars","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
    2024-06-04 06:02:57.481 - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
    2024-06-04 06:02:57.482 - info: host.raspberrypi stopInstance canceled schedule system.adapter.ical.0
    2024-06-04 06:03:00.507 - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 * * * *
    2024-06-04 06:03:00.512 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 10933
    2024-06-04 06:03:01.346 - info: ical.0 (10933) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
    2024-06-04 06:03:01.483 - warn: ical.0 (10933) Error reading "/home/pi/abfuhr/muell24.ics": File does not exist: "/home/pi/abfuhr/muell24.ics"
    2024-06-04 06:03:01.525 - warn: ical.0 (10933) Error reading "/home/pi/carsten.ics": File does not exist: "/home/pi/carsten.ics"
    2024-06-04 06:03:01.525 - info: ical.0 (10933) All calenders could not be processed, Do not clean up events
    Ich habe die ics Dateien in den Ordner home/pi/abfuhr und eine Sicherung in home/pi/ :
    Ich komme da nicht weiter warum der Kalender nicht verarbeitet wird.
    Mico
    MartinPM Online
    MartinPM Online
    MartinP
    @mico der ical Adapter kann nur auf lokale Dateien zugreifen, die mit dem Iobroker Dateimanager hochgeladen wurden.
    Es sind auch nur bestimmte Verzeichnisse erreichbar
    • MartinPM MartinP
      haus-automatisierungH Offline
      @martinp Es gehen auch absolute Pfade. Das geht sogar schon deutlich länger. Aber dafür müssen halt die Rechte stimmen
      📚 Meine Dokumentation
        Mico
        schrieb am zuletzt editiert von Mico
        @haus-automatisierung :
        also die Dateien haben die Rechte wie oben das Bild zeigt -rw-r ich meine es würde auf 644 stehen.
        pi@raspberrypi:~/abfuhr $ ls -al
        total 28
        drwxr-xr-x 2 pi pi 4096 Jun 3 06:12 .
        drwx------ 17 pi pi 4096 Jun 3 07:10 ..
        -rw-r--r-- 1 pi pi 5243 Jun 3 06:09 carsten.ics
        -rw-r--r-- 1 pi pi 11384 May 11 05:22 muell24.ics
        Bis her meine ich mich zu errinnern habe ich die Dateien immer mit Fillzilla auf dem Pi hochgeladen, un dieses Verzeichnis benutzt.
        Wie würde ich denn das mit Iobroker machen? Dateimanager?
        • M Mico
          total 28
          @mico Dein Pfad ist /home/pi/abfuhr/carsten.ics
          Also richtig in der Instanz angeben.
          Ansonsten per Dateimanager unter ical.0 hochladen und dann nur den Namen angeben. Hab ich im Kurs auch gerade hinzugefügt
            Mico
            Wo ist denn in ical.0 ein Dateimanager ??
            • M Mico
              @mico Links das Tab "Dateien"
                Mico
                Meinst du das da und so?
                Wie kommt das nun wieder zu /home/pi/abfuhr/ ? und wo ist jetzt diese Datei ? diese habe ich jetzt per Drag and Drop vom Rechner hochgeladen.
                • M Mico
                  @mico sagte in Ical.0 findet lokalen Kalender nicht:
                  Gar nicht. Warum auch? Darum geht es ja: Dass man mit dem Dateisystem nichts zu tun hat. Bitte die Grundlagen anschauen, ich habe das an anderer Stelle schon super ausführlich erklärt.
                  Du kannst jetzt einfach muell24.ics als Datei bei iCal eintragen.
                    Mico
                    Danke so müsste es klappen oder?
                    • M Mico
                      @mico Wenn deine iCal-Version >= 1.14.0 ist, ja
                        Mico
                        Ist 1.15 also ja Prima
                        Das alles wird auch im Kurs genau erklärt ich meine so "für klein Dummies"
                        • M Mico
                          @mico Richtig
