  4. Ical.0 findet lokalen Kalender nicht
14 Beiträge 4 Kommentatoren 305 Aufrufe 3 Beobachtet
    Mico
    Hallo alle zusammen,
    Ich habe seit dem ich auf einen "neuen Raspberry umgezogen bin" das Problem das der Adapter Ical meine als lokale Kalender abgelegeten Dateien nicht findet.
    2024-06-04 06:00:01.086 - warn: ical.0 (10915) Error reading "/home/pi/muell24.ics": File does not exist: "/home/pi/muell24.ics"
    2024-06-04 06:00:01.129 - warn: ical.0 (10915) Error reading "/home/pi/carsten.ics": File does not exist: "/home/pi/carsten.ics"
    2024-06-04 06:00:01.129 - info: ical.0 (10915) All calenders could not be processed, Do not clean up events
    2024-06-04 06:00:05.006 - warn: trashschedule.0 (8949) no events matches type "Restmülltonne" with match "Restmüll" (exact match)
    2024-06-04 06:00:05.098 - warn: trashschedule.0 (8949) no events matches type "Wertstoffsack" with match "Gelber Sack" (exact match)
    2024-06-04 06:00:05.101 - warn: trashschedule.0 (8949) no events matches type "Bioabfalltonne" with match "Bioabfall" (exact match)
    2024-06-04 06:00:05.104 - warn: trashschedule.0 (8949) no events matches type "Altpapiertonne" with match "Altpapier" (exact match)
    2024-06-04 06:00:05.107 - warn: trashschedule.0 (8949) no events matches type "Schadstoffmobil" with match "Mobile Schadstoffsammlung" (exact match)
    2024-06-04 06:00:05.110 - warn: trashschedule.0 (8949) no events matches type "Weihnachtsbaum" with match "Tannenbaum"
    2024-06-04 06:00:05.117 - warn: trashschedule.0 (8949) (5) next has no entries. Check configuration of trashschedule!
    2024-06-04 06:00:05.120 - warn: trashschedule.0 (8949) (5) nextAfter has no entries. Check configuration of trashschedule!
    2024-06-04 06:00:06.133 - info: ical.0 (10915) Terminated (NO_ERROR): Without reason
    2024-06-04 06:00:06.646 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-06-04 06:02:31.138 - warn: admin.0 (1308) ical has an invalid jsonConfig: [{"instancePath":"/items/_calendars/items/calendars/items/5","schemaPath":"#/items/allOf/5/then/allOf/1/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"width"},"message":"must NOT have additional properties"},{"instancePath":"/items/_calendars/items/calendars","schemaPath":"#/patternProperties/%5E.%2B/allOf/23/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"/items/_calendars","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
    2024-06-04 06:02:57.481 - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
    2024-06-04 06:02:57.482 - info: host.raspberrypi stopInstance canceled schedule system.adapter.ical.0
    2024-06-04 06:03:00.507 - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 * * * *
    2024-06-04 06:03:00.512 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 10933
    2024-06-04 06:03:01.346 - info: ical.0 (10933) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 5.0.19
    2024-06-04 06:03:01.483 - warn: ical.0 (10933) Error reading "/home/pi/abfuhr/muell24.ics": File does not exist: "/home/pi/abfuhr/muell24.ics"
    2024-06-04 06:03:01.525 - warn: ical.0 (10933) Error reading "/home/pi/carsten.ics": File does not exist: "/home/pi/carsten.ics"
    2024-06-04 06:03:01.525 - info: ical.0 (10933) All calenders could not be processed, Do not clean up events
    Ich habe die ics Dateien in den Ordner home/pi/abfuhr und eine Sicherung in home/pi/ :
    Ich komme da nicht weiter warum der Kalender nicht verarbeitet wird.
    Mico
    T MartinPM 2 Antworten Letzte Antwort
    • M Mico
      Mico
      TT-Tom
      @mico
      Hat der iobroker den leserechte im Home Verzeichnis von pi?
      Warum nutzt du nicht das Dateiverzeichnis vom iobroker für die Daten?
      Gruß Tom
      https://github.com/tt-tom17
      NSPanel Script Wiki
      NSPanel Adapter Wiki
      • M Mico
        Mico
        MartinPM Offline
        MartinPM Offline
        MartinP
        @mico der ical Adapter kann nur auf lokale Dateien zugreifen, die mit dem Iobroker Dateimanager hochgeladen wurden.
        Es sind auch nur bestimmte Verzeichnisse erreichbar
        Intel(R) Celeron(R) CPU N3000 @ 1.04GHz 8G RAM 480G SSD
        Virtualization : unprivileged lxc container (debian 13) on Proxmox 9.1.5)
        Linux pve 6.17.9-1-pve
        6 GByte RAM für den Container
        Fritzbox 6591 FW 8.20 (Vodafone Leih-Box)
        Remote-Access über Wireguard der Fritzbox
        • MartinPM MartinP
          haus-automatisierungH Offline
          @martinp Es gehen auch absolute Pfade. Das geht sogar schon deutlich länger. Aber dafür müssen halt die Rechte stimmen
            Mico
            schrieb am zuletzt editiert von Mico
            @haus-automatisierung :
            also die Dateien haben die Rechte wie oben das Bild zeigt -rw-r ich meine es würde auf 644 stehen.
            pi@raspberrypi:~/abfuhr $ ls -al
            total 28
            drwxr-xr-x 2 pi pi 4096 Jun 3 06:12 .
            drwx------ 17 pi pi 4096 Jun 3 07:10 ..
            -rw-r--r-- 1 pi pi 5243 Jun 3 06:09 carsten.ics
            -rw-r--r-- 1 pi pi 11384 May 11 05:22 muell24.ics
            Bis her meine ich mich zu errinnern habe ich die Dateien immer mit Fillzilla auf dem Pi hochgeladen, un dieses Verzeichnis benutzt.
            Wie würde ich denn das mit Iobroker machen? Dateimanager?
            • M Mico
              total 28
              @mico Dein Pfad ist /home/pi/abfuhr/carsten.ics
              Also richtig in der Instanz angeben.
              Ansonsten per Dateimanager unter ical.0 hochladen und dann nur den Namen angeben. Hab ich im Kurs auch gerade hinzugefügt
                Mico
                Wo ist denn in ical.0 ein Dateimanager ??
                • M Mico
                  @mico Links das Tab "Dateien"
                    Mico
                    Meinst du das da und so?
                    Wie kommt das nun wieder zu /home/pi/abfuhr/ ? und wo ist jetzt diese Datei ? diese habe ich jetzt per Drag and Drop vom Rechner hochgeladen.
                    • M Mico
                      @mico sagte in Ical.0 findet lokalen Kalender nicht:
                      Gar nicht. Warum auch? Darum geht es ja: Dass man mit dem Dateisystem nichts zu tun hat. Bitte die Grundlagen anschauen, ich habe das an anderer Stelle schon super ausführlich erklärt.
                      Du kannst jetzt einfach muell24.ics als Datei bei iCal eintragen.
                        Mico
                        Danke so müsste es klappen oder?
                        • M Mico
                          @mico Wenn deine iCal-Version >= 1.14.0 ist, ja
                            Mico
                            Ist 1.15 also ja Prima
                            Das alles wird auch im Kurs genau erklärt ich meine so "für klein Dummies"
                            • M Mico
                              @mico Richtig
                              82.8k
