  5. [gelöst] Datenpunkte aus json erstellen
    6.4k
88 Beiträge 7 Kommentatoren 14.1k Aufrufe 3 Beobachtet
  • metaxaM metaxa
    @paul53 Ich versuche gerade Ähnliches, bekomme aber die Fehlermeldung "undefined"
    javascript.0	21:50:59.113	info	Stopping script script.js.common.800-850_Energie.840_Spritpreise_updaten
    javascript.0	21:50:59.161	info	Start JavaScript script.js.common.800-850_Energie.840_Spritpreise_updaten (Blockly)
    javascript.0	21:50:59.170	info	script.js.common.800-850_Energie.840_Spritpreise_updaten: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.1	21:50:59.335	info	Stop script script.js.common.800-850_Energie.840_Spritpreise_updaten
    javascript.0	21:50:59.492	info	script.js.common.800-850_Energie.840_Spritpreise_updaten: undefined
    Die geholten Daten schauen so aus:
        "id": 33395,
        "name": "SOCAR Perchtoldsdorf",
        "location": {
          "address": "Ketzergasse 191a",
          "postalCode": "2380",
          "city": "Perchtoldsdorf",
          "latitude": 48.1301731,
          "longitude": 16.2919418
        "contact": {
          "telephone": "4318674570",
          "fax": "4318674804",
          "mail": "office-at@socarenergy.com",
          "website": "https://www.socarenergy.at/"
        "openingHours": [
            "day": "MO",
            "label": "Montag",
            "order": 1,
            "from": "00:00",
            "to": "24:00"
            "day": "DI",
            "label": "Dienstag",
            "order": 2,
            "from": "00:00",
            "to": "24:00"
            "day": "MI",
            "label": "Mittwoch",
            "order": 3,
            "from": "00:00",
            "to": "24:00"
            "day": "DO",
            "label": "Donnerstag",
            "order": 4,
            "from": "00:00",
            "to": "24:00"
            "day": "FR",
            "label": "Freitag",
            "order": 5,
            "from": "00:00",
            "to": "24:00"
            "day": "SA",
            "label": "Samstag",
            "order": 6,
            "from": "00:00",
            "to": "24:00"
            "day": "SO",
            "label": "Sonntag",
            "order": 7,
            "from": "00:00",
            "to": "24:00"
            "day": "FE",
            "label": "Feiertag",
            "order": 8,
            "from": "00:00",
            "to": "24:00"
        "offerInformation": {
          "service": false,
          "selfService": true,
          "unattended": true
        "paymentMethods": {
          "cash": true,
          "debitCard": true,
          "creditCard": true,
          "others": "UTA, DKV, Socarcard"
        "paymentArrangements": {
          "cooperative": false,
          "clubCard": false
        "position": 1,
        "open": true,
        "distance": 4.24828720258133,
        "prices": [
            "fuelType": "DIE",
            "amount": 1.554,
            "label": "Diesel"
        "id": 7812,
        "name": "Vivod",
    Kannst du mir da event. bitte helfen?
    @metaxa sagte: Daten schauen so aus:
    Das ist ein Array --> Attribut "0.name".
    metaxaM 1 Antwort Letzte Antwort
      @klaus-0
      Klaus 0
      @paul53 Danke für die schnelle Anwort. Jetzt kommen die Fehlermeldungen. Screenshot 2024-05-27 220424.png
      • K Klaus 0
        @klaus-0
        In Data wird offenbar null geliefert. Debugge mal den Status code
          metaxaM Offline
          metaxaM Offline
          metaxa
          schrieb am zuletzt editiert von metaxa
          @paul53 sagte in Datenpunkte aus json erstellen:
          Das ist ein Array
          Herzlichen Dank! somit ist mir auch klar wie ich an die weiteren Einträge komme (1.name, 2.name....)
            @klaus-0
            Klaus 0
            @paul53 Ist dann auch das gleiche Problem. muss ich vielleicht erst Irgendwas Parsen oder so?Screenshot 2024-05-27 221527.png
            • K Klaus 0
              @klaus-0 sagte: Ist dann auch das gleiche Problem.
              Den Status code ohne "Attribut" debuggen. Er enthält normalerweise eine Zahl (200 bei Erfolg).
              Die URL stimmt? Im Web-Browser kommt das JSON mit dieser URL?
              K 2 Antworten Letzte Antwort
                Klaus 0
                @paul53 Im Web-Browser sieht das so aus
                Beim Status code ohne Attribut kommt das
                paul53P HomoranH 2 Antworten Letzte Antwort
                • K Klaus 0
                  @klaus-0
                  Mit der Fehlermeldung kann ich nichts anfangen. Da muss ein ITler ran.
                  Hast Du es mal mit dem request-Block (und der Variablen result) versucht?
                    Klaus 0
                    hi Paul,
                    das ist die Wetterstation die ich abfrage.
                    https://www.jbmedia.eu/faq/wetterstation
                    • K Klaus 0
                      hi Paul,
                      @klaus-0 sagte: das ist die Wetterstation die ich abfrage.
                      Der Browser liefert das JSON, aber offenbar der httpGet-Block nicht. Keine Ahnung - weshalb.
                      K HomoranH 2 Antworten Letzte Antwort
                        Klaus 0
                        @paul53 habe das jetzt mal so ausprobiert. dann kommt wenigstens keine Fehlermeldung. Bin ich da auf dem richtigen Weg?
                          wenn du das json willst, nicht status code, sonden data nehmen.
                          und zum testen mal das timeout erhöhen
                            Klaus 0
                            hatte ich schon ausprobiert. War aber immer der gleiche Fehler.
                            • K Klaus 0
                              @klaus-0 sagte: Bin ich da auf dem richtigen Weg?
                              Status code 500 = interner Serverfehler. Dann kommen keine Daten.
                              • K Klaus 0
                                @klaus-0 sagte in Datenpunkte aus json erstellen:
                                das ist ein json, dessen letztes Attribut targeturl ein Array enthält.
                                Möglicherweise sind die darin enthaltenen Tilden ein Problem.
                                  Klaus 0
                                  Jetzt sieht das so aus. Und nun hat es auch den Status 200
                                  • K Klaus 0
                                    Klaus 0
                                    @klaus-0 Und die "data" sehen so aus
                                    wolfi913W 1 Antwort Letzte Antwort
                                    • K Klaus 0
                                      wolfi913W Online
                                      wolfi913W Online
                                      wolfi913
                                      Und mit Antwort-Typ Text ?
                                      • wolfi913W wolfi913
                                        Klaus 0
                                        @wolfi913 dann so
                                        • K Klaus 0
                                          @wolfi913 dann so
                                          @klaus-0
                                          Das ist die Simple-API von ioBroker: falsche IP-Adresse!
