  3. Einsteigerfragen
  4. Payload von Timestamp in Node Red weitergeben, wenn
28 Beiträge 2 Kommentatoren 4.4k Aufrufe 2 Beobachtet
  • mickymM mickym
    @derklotz sagte in Payload von Timestamp in Node Red weitergeben, wenn:
    wenn die gesamte PV Leistung für z.B. eine Minute größer= 1000 ist
    hier
    [{"id":"7a67ae22ed136350","type":"inject","z":"27d9496bad8ac6c5","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1000","payloadType":"num","x":290,"y":220,"wires":[["cf91ddd6e7ed9050"]]},{"id":"d941f8abe2f4ef78","type":"inject","z":"27d9496bad8ac6c5","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"900","payloadType":"num","x":290,"y":280,"wires":[["cf91ddd6e7ed9050"]]},{"id":"cf91ddd6e7ed9050","type":"switch","z":"27d9496bad8ac6c5","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"1000","vt":"str"},{"t":"lt","v":"1000","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":450,"y":240,"wires":[["4bd4856c8193177d"],["08e27267381bab8f"]]},{"id":"4bd4856c8193177d","type":"change","z":"27d9496bad8ac6c5","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":220,"wires":[["1988f081e7e45569"]]},{"id":"08e27267381bab8f","type":"change","z":"27d9496bad8ac6c5","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":260,"wires":[["1988f081e7e45569"]]},{"id":"1988f081e7e45569","type":"trigger","z":"27d9496bad8ac6c5","name":"","op1":"","op2":"true","op1type":"nul","op2type":"bool","duration":"1","extend":false,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":830,"y":240,"wires":[["7fdca484b75d542b"]]},{"id":"7fdca484b75d542b","type":"debug","z":"27d9496bad8ac6c5","name":"länger als 1 min > 1000","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1070,"y":240,"wires":[]}]
    DerKlotz
    @mickym
    Moin,
    haut super hin, der Rest meiner Steuerung nimmt auch allmählich finale Gestalt an. Danke an dich!
    Etwas offtopic... Habe für die Batteriespannung eine(n) Gauge im Dashboard erstellt. Gibt es die Möglich am äußeren Rand Werte anzeigen zu lassen? Min - Max an den Enden ist klar, aber wie sieht es mit Zwischenwerten aus?
    • D DerKlotz
      @mickym
      Moin,
      mickymM Offline
      mickymM Offline
      mickym
      @derklotz die aktuellen werte in der gauge werden doch in der mitte angezeigt? ansonsten in der Standardgauge gibts keine skala - auch im neuen Dashboard nicht.
      Das Einzige, was ich Dir als Alternative anbieten kann, sind die Steelseries Widgets - dafür habe ich ja mal einen eigenen Thread gemacht: https://forum.iobroker.net/post/634863
      • mickymM mickym
        DerKlotz
        schrieb am zuletzt editiert von DerKlotz
        @mickym
        nach dem Urlaub und weiterem Programmieren, hab ich meine PV Anlage nun zum Laufen gebracht. Das ganze mit den Gauges habe ich nicht hin bekommen... allerdings schaue ich mittlerweile nicht ständig aufs Dashboard, so dass ich die Gauges auch nicht mehr weiter verfolgen möchte.
        Ich habe zur Zeit eine Funktion in meiner Programierung, die ich noch gerne ändern würde, aber keinen Ansatz finde.
        Per MQTT wird alle 20s ein Trigger vom Wechselrichter ausgelöst, der unter anderem die aktuelle Leistung des Shelly ausliest (current state node) und dann die Berechnung für den neuen Wechselrichter Wert durchführt. Nun ist es so, dass die Leistungswerte des Shelly (habe parallel eine event state node für den Shelly an einem Debug) manchmal recht wild hin und her springen und wenn nun gerade der Trigger kommt, dann ist die Berechnung "weit" weg vom Soll. Ich übertreibe jetzt mal und sage der Shelly liefert jede Sekunde einen anderen Wert.
        Meine Idee: Der Shelly feuert über eine event state node so viel er will, dann kommt eine smooth node und erstellt alle 5 Werte einen Mittelwert. Dieser Mittelwert wird mit dem Triggersignal an die Berechnung weitergeführt. Wurden innerhalb der 20s Triggerzeit mehrere Mittelwerte gebildet, so soll nur der letzte zur Berechnung heran gezogen werden... ist es so klar beschrieben???
        P.S.: Habe nur die Nodes hier eingestellt, die der Veranschaulichung helfen
        [{"id":"ea4ad0f18e32f4d5","type":"server-state-changed","z":"0a2aa4f87f5956e4","name":"Shelly 3EM","server":"6d6a06a0.fdabd8","version":5,"outputs":1,"exposeAsEntityConfig":"","entityId":"sensor.shellypro3em_34987a471964_total_active_power","entityIdType":"exact","outputInitially":true,"stateType":"num","ifState":"","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":40,"wires":[["0d4451c28da95816"]]},{"id":"0d4451c28da95816","type":"smooth","z":"0a2aa4f87f5956e4","name":"","property":"payload","action":"mean","count":"5","round":"0","mult":"single","reduce":true,"x":320,"y":80,"wires":[["5df5e48eaf6c5a06","503598ccfa7b2b44"]]},{"id":"5df5e48eaf6c5a06","type":"debug","z":"0a2aa4f87f5956e4","name":"debug 51","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":800,"y":100,"wires":[]},{"id":"6df252da2441f7af","type":"mqtt in","z":"0a2aa4f87f5956e4","name":"WR Leistung einlesen","topic":"hms800/114491215971/status/limit_absolute","qos":"2","datatype":"auto-detect","broker":"d0d69da0d3c24301","nl":false,"rap":true,"rh":0,"inputs":0,"x":100,"y":220,"wires":[["f83acaa91f44f413","d7d7f106bcbb4013"]]},{"id":"f83acaa91f44f413","type":"change","z":"0a2aa4f87f5956e4","name":"WR Trigger","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":110,"y":160,"wires":[["3d5ee0abe9f74380","e7287f2c54cb5644","1570b4d33454fcb7","589526f7921c6c0d","71a71d3999bcd289","cdaa2d9c336c2ee8","7af26ab867661b30","b7d145577407dba9"]]},{"id":"71a71d3999bcd289","type":"api-current-state","z":"0a2aa4f87f5956e4","name":"Leistung alle Phasen","server":"864f5cad6b0c1ce0","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.shellypro3em_34987a471964_total_active_power","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":440,"y":160,"wires":[["f0b1139468c6c3d2","25ec3c5f853b4e6c"]]},{"id":"25ec3c5f853b4e6c","type":"trigger","z":"0a2aa4f87f5956e4","name":"","op1":"","op2":"","op1type":"nul","op2type":"payl","duration":"10","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":290,"y":280,"wires":[["7e4f2eb2a91c8cc8"]],"info":"Trigger setzen, weil sonst alle Zustände\r\ngleichzeitig kommen"},{"id":"f0b1139468c6c3d2","type":"ui_chart","z":"0a2aa4f87f5956e4","name":"","group":"65436f194880235a","order":1,"width":0,"height":0,"label":"Netzbezug","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"step","nodata":"","dot":false,"ymin":"-150","ymax":"150","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":830,"y":180,"wires":[[]]},{"id":"7e4f2eb2a91c8cc8","type":"switch","z":"0a2aa4f87f5956e4","name":"Überprüfung Differenz","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"20","vt":"num"},{"t":"lte","v":"-20","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":280,"y":360,"wires":[["59a1b7939f9ed580"],["f39428fb43c1582c"]]},{"id":"6d6a06a0.fdabd8","type":"server","name":"Home Assistant","addon":true},{"id":"d0d69da0d3c24301","type":"mqtt-broker","name":"","broker":"192.168.10.9","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"864f5cad6b0c1ce0","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"5","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":": ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"default","statusTimeFormat":"h:m","enableGlobalContextStore":false},{"id":"65436f194880235a","type":"ui_group","name":"Group 2","tab":"84548990a4a4f571","order":2,"disp":true,"width":"6","collapse":false,"className":""},{"id":"84548990a4a4f571","type":"ui_tab","name":"Test","icon":"dashboard","disabled":false,"hidden":false}]
        • D DerKlotz
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          @derklotz Warum nimmst Du nicht die Standard filter Node und filterst auf das Nahbereichsband.
          • mickymM mickym
            DerKlotz
            @mickym
            Aktuell mal geschaut...
            folgende Werte konnte ich sehen
            46
            81
            • D DerKlotz
              @mickym
              46
              81
              mickymM Offline
              mickymM Offline
              mickym
              @derklotz Ja wie gesagt, nutze den Nahbandfilter - was ist denn ein gültiger Wert - das ist ja alles sehr gestreut. Die smooth Node bezieht halt alle Wert mit ein. Kannst ja auch nutzen - aber ich weiß nicht, ob das zielführend ist.
              • mickymM mickym
                DerKlotz
                @mickym
                Vergiss die Werte von eben, da waren einige bei, die zwischen den Rechenzyklen waren. So um 40 springt der auf jeden Fall.
                • D DerKlotz
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @mickym
                  Wie gesagt der Nahbandfilter - ignoriert halt alle Ausreiser, die smooth Node verwendet diese Werte ja mit.
                  • mickymM mickym
                    @mickym
                    DerKlotz
                    @mickym Null wäre die beste "Zahl". Ich kann leider nicht sagen, welcher Wert der Richtige ist, da es ja immer leichte Leistungsschwankungen in der Hauselektrik gibt. Dazu kommt ja die eventuelle Ungenauigkeit des Shelly... deswegen war mein Gedanke alle Werte hinzu zu nehmen...
                    • D DerKlotz
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @derklotz Na ja wie gesagt - leichte Leistungsschwankungen kann man mit dem Nahbereichsfilter ja herausfiltern und wenn 0 die beste Zahl ist, dann ist der % Bereich ja gut - da ja je näher an 0 der Prozentbereich ja enger ist ansonsten gehen ja auch absolute Werte - also Änderungen unter 10 oder was weiss ich. Aber ansonsten nimm halt die smooth Node. Wie gesagt das ist eine Logikentscheidung, die nur selbst beantworten kannst. Statt der smooth Node - kannst Du auch die aggregator Node nehmen und dann keine Mittelwert sondern den Median nehmen.
                      • mickymM mickym
                        DerKlotz
                        @mickym Wenn ich in einem Rechenzyklus die 0 erreicht habe, dann bedeutet es dass ich kein Strom beziehe noch abgebe. Schaltet jetzt z.B. ein großer Verbraucher zu, dann kann ich ja 1000 entfernt sein und meine Berechnung bekommt das nicht mit, weil mein Wert größer 10% ist oder mache ich einen Denkfehler?20240527_192558.jpg
                        Muss mich für heute verabschieden... Danke!
                        • D DerKlotz
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @derklotz
                          Wenn Du es mit dem Eingang vergleichst, dann muss der 2. Wert innerhalb des Nahbandes sein. Teste halt mal mit Inject Nodes.
                                 "id": "e618d0bcb9949b50",
                                 "type": "inject",
                                 "z": "f05041e5.046a7",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "0",
                                 "payloadType": "num",
                                 "x": 310,
                                 "y": 5980,
                                 "wires": [
                                         "44112f7b939c18b3"
                                 "id": "accbe735447258bd",
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                         "p": "topic",
                                         "vt": "str"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "payload": "1000",
                                 "x": 310,
                                 "y": 6020,
                                 "wires": [
                                         "44112f7b939c18b3"
                                 "id": "44112f7b939c18b3",
                                 "type": "rbe",
                                 "name": "",
                                 "func": "narrowband",
                                 "gap": "10%",
                                 "start": "",
                                 "inout": "in",
                                 "septopics": true,
                                 "property": "payload",
                                 "topi": "topic",
                                 "x": 510,
                                 "y": 6000,
                                 "wires": [
                                         "e141f28c1b55ac85"
                                 "id": "e141f28c1b55ac85",
                                 "type": "debug",
                                 "name": "debug 1",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "false",
                                 "statusVal": "",
                                 "statusType": "auto",
                                 "x": 720,
                                 "y": 6000,
                                 "wires": []
                          • mickymM mickym
                            @derklotz
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "0",
                                   "x": 310,
                                   "y": 5980,
                                   "wires": [
                                           "44112f7b939c18b3"
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "1000",
                                   "x": 310,
                                   "y": 6020,
                                   "wires": [
                                           "44112f7b939c18b3"
                                   "type": "rbe",
                                   "name": "",
                                   "gap": "10%",
                                   "start": "",
                                   "inout": "in",
                                   "septopics": true,
                                   "topi": "topic",
                                   "x": 510,
                                   "y": 6000,
                                   "wires": [
                                           "e141f28c1b55ac85"
                                   "type": "debug",
                                   "name": "debug 1",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 720,
                                   "y": 6000,
                                   "wires": []
                            DerKlotz
                            @mickym Ok, jetzt habe ich die node erst richtig verstanden... bleibt für mich immer noch die Frage, wie ich nur den aktuellsten Wert alle 20s über meinen Haupttimer abhole. Zur Zeit kann es immer noch passieren, dass viele Werte innerhalb 20s kommen und dementsprechend viele Berechnungen passieren, die ständig die Wechselrichterleistung anpassen. Dat soll nunmal nicht passieren.
                            Muss auch leider schon wieder weg... Danke für die ganze Mühe
                            • D DerKlotz
                              mickymM Offline
                              mickymM Offline
                              mickym
                              Nun entweder trigger die Werte, dann braucht man sie eigentlich nicht abholen oder Du speicherst die alle in eine Flowvariablen und da diese ja immer mit dem aktuellsten Wert überschrieben werden und holst den damit ab.
                              Wenn Du dauernd unsinnige Berechnungen machst, die Du eh immer verwirfst, dann vergeudest Du ja nur CPU und Resourcen.
                              Natürlich kannst Du auch die Trigger Node im Block Modus verwenden und diesen Block alle 20 s freigeben. Du hast also eine Menge Möglichkeiten - Du musst nur Deine Fantasie walten lassen.
                              Man muss halt generell aufpassen, dass wenn schon einiges weggefiltert wird, dass man hier nicht Dinge verschlimmbessert
                              • mickymM mickym
                                DerKlotz
                                @mickym Moin, der Tipp mit der Flowvariablen hat mir weiter geholfen. Den Ansatz hatte ich zwar vorher schon verfolgt, aber immer irgendwo einen Fehler gemacht. Nun habe ich mich da tief mit beschäftigt und nun läuft es.
                                GANZ DICKES DANKE
