  4. Simple-api startet nicht mehr
simple-api
22 Beiträge 9 Kommentatoren 2.9k Aufrufe 7 Beobachtet
  • R ReRo
    @haselchen
    habe erst mal recherchiert was iob diag bedeutet...
    Anbei das Summary oder soll ich alles bereitstellen
    			v.2024-04-21
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.28+rpt-rpi-v8
        Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		64 bit
    Timezone: 		Europe/London (BST, +0100)
    User-ID: 		1000
    Display-Server: 	true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	3
    Pending iob updates: 	0
    Nodejs-Installation:
    /usr/bin/nodejs 	v18.20.2
    /usr/bin/node 		v18.20.2
    /usr/bin/npm 		10.5.0
    /usr/bin/npx 		10.5.0
    /usr/bin/corepack 	0.25.2
    Recommended versions are nodejs 18.20.3 and npm 10.7.0
    MEMORY:
    Mem:            4.0G        2.9G        246M        212M        1.1G        1.1G
    Swap:           104M        104M         81K
    Total:          4.1G        3.0G        246M
    Active iob-Instances: 	28
    Active repo(s): stable
    ioBroker Core: 		js-controller 		5.0.19
    			admin 			6.13.16
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		7494
    States: 		5816
    Size of iob-Database:
    30M	/opt/iobroker/iobroker-data/objects.jsonl
    2.3M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    crunchipC Offline
    crunchipC Offline
    @rero sagte in Simple-api startet nicht mehr:
    alles
    R 1 Antwort Letzte Antwort
      alles
      ReRo
      @crunchip
      na viel Spaß damit - Danke!
      Skript v.2024-04-21
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       18:55:56 up 1 day, 10:19,  3 users,  load average: 1.19, 1.14, 0.91
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-05-22 18:55:56 BST
                 Universal time: Wed 2024-05-22 17:55:56 UTC
                       RTC time: n/a
                      Time zone: Europe/London (BST, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      rasbe
      HOME=/home/rasbe
      GROUPS=rasbe adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** Display-Server-Setup ***
      Desktop: 	LXDE-pi-wayfire
      Terminal: 	wayland
      *** MEMORY ***
      Mem:            4.0G        2.9G        285M        170M        1.1G        1.1G
      Swap:           104M        104M        155K
      Total:          4.1G        3.0G        285M
               3792 M total memory
               2753 M used memory
               2214 M active memory
                939 M inactive memory
                272 M free memory
                 55 M buffer memory
                957 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      top - 18:55:57 up 1 day, 10:19,  3 users,  load average: 1.19, 1.14, 0.91
      Tasks: 275 total,   1 running, 274 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 63.6 us,  0.0 sy,  0.0 ni, 36.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.1 total,    269.9 free,   2755.9 used,   1013.0 buff/cache
      MiB Swap:    100.0 total,      0.1 free,     99.8 used.   1036.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.4M  378M   1% /run
      /dev/mmcblk0p2 ext4       29G  7.2G   21G  27% /
      tmpfs          tmpfs     1.9G   56M  1.8G   3% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
      tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
      /dev/sda1      ext4      938G   13G  926G   2% /media/rasbe/296fd2c4-0e52-4dc0-ac76-af9716f26165
      [Tue May 21 08:36:21 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DA:3A:D6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a0a0b294-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Tue May 21 08:36:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
      [Tue May 21 08:36:27 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
      [Tue May 21 08:36:44 2024] EXT4-fs (sda1): recovery complete
      [Tue May 21 08:36:44 2024] EXT4-fs (sda1): mounted filesystem 296fd2c4-0e52-4dc0-ac76-af9716f26165 r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE          OPTIONS
      /                                                       /dev/mmcblk0p2 ext4            rw,noatime,commit=600
      |-/sys                                                  sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore          rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs       configfs        rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc            rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5531
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc     rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=1668360k,nr_inodes=417090,mode=755
      | |-/dev/pts                                            devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs           rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs      rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
      |   |-/run/user/1000/gvfs                               gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |   `-/run/user/1000/doc                                portal         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |-/boot/firmware                                        /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/media/rasbe/296fd2c4-0e52-4dc0-ac76-af9716f26165     /dev/sda1      ext4            rw,nosuid,nodev,relatime,errors=remount-ro,stripe=8191
      /var:
      559M	/var/
      195M	/var/lib
      181M	/var/cache
      174M	/var/cache/apt
      133M	/var/lib/apt/lists
      Archived and active journals take up 79.8M in the file system.
      /opt/iobroker/backups:
      6.0M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      299M	/opt/iobroker/iobroker-data/
      232M	/opt/iobroker/iobroker-data/files
      57M	/opt/iobroker/iobroker-data/files/javascript.admin
      48M	/opt/iobroker/iobroker-data/files/iot.admin/static
      38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      8.8M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/npm 		10.5.0
      /usr/bin/npx 		10.5.0
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.3-1nodesource1
        Version table:
           18.20.3-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
       *** 18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.19
      admin: 		6.13.16
      javascript: 	7.8.0
      nodejs modules from github: 	0
      Adapter State
      + system.adapter.bmw.0                    : bmw                   : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
      + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
      + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
      + system.adapter.daikin.2                 : daikin                : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
      + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.2                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.3                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        system.adapter.rest-api.0               : rest-api              : raspberrypi                              - disabled, port: 8093, bind: 0.0.0.0, run as: admin
        system.adapter.ring.0                   : ring                  : raspberrypi                              - disabled
        system.adapter.sbfspot.0                : sbfspot               : raspberrypi                              -  enabled
        system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sma-em.0                 : sma-em                : raspberrypi                              -  enabled
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "bmw"          : 2.5.7    , installed 2.8.0
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "iot"          : 3.2.2    , installed 3.2.2
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "ring"         : 5.0.10   , installed 5.0.10
      Adapter    "sbfspot"      : 4.2.4    , installed 4.2.4
      Adapter    "sma-em"       : 1.0.1    , installed 1.0.1
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tronity"      : 1.1.1    , installed 1.1.1
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Objects and States
      Objects: 	7494
      States: 	5816
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          558109     106091/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1008135    199934/iobroker.js-
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1009080    199934/iobroker.js-
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4821       817/sshd: /usr/sbin
      tcp        0      0 192.168.178.86:8701     0.0.0.0:*               LISTEN      1001       1007439    200263/io.hm-rpc.2
      tcp        0      0 192.168.178.86:2001     0.0.0.0:*               LISTEN      1001       1008438    200233/io.hm-rpc.0
      tcp        0      0 192.168.178.86:2010     0.0.0.0:*               LISTEN      1001       1009538    200248/io.hm-rpc.1
      tcp6       0      0 :::22                   :::*                    LISTEN      0          4823       817/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          558108     106091/cupsd
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       1006360    200076/io.sonos.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1006271    199953/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1072064    210709/io.web.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1012099    200743/io.terminal.
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          558141     106093/cups-browsed
      udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       925397     176756/chromium-bro
      udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       925395     176756/chromium-bro
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6047       603/avahi-daemon: r
      udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       1012897    200716/io.sma-em.0
      udp        0      0 0.0.0.0:50661           0.0.0.0:*                           104        6049       603/avahi-daemon: r
      udp6       0      0 fe80::1da7:3f0f:174:546 :::*                                0          12039      709/NetworkManager
      udp6       0      0 fe80::ec63:5f2f:296:546 :::*                                0          7746       709/NetworkManager
      udp6       0      0 :::60412                :::*                                104        6050       603/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        6048       603/avahi-daemon: r
      2024-05-22 18:45:08.100  - info: host.raspberrypi instance system.adapter.sbfspot.0 started with pid 248249
      2024-05-22 18:45:11.248  - info: sbfspot.0 (248249) starting. Version 4.2.4 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v18.20.2, js-controller: 5.0.19
      2024-05-22 18:45:11.547  - info: sbfspot.0 (248249) start with mySQL
      2024-05-22 18:45:11.604  - error: sbfspot.0 (248249) exception in DB_Connect [Error: connect ECONNREFUSED 127.0.0.1:3306]
      2024-05-22 18:45:11.606  - info: sbfspot.0 (248249) all done ...
      2024-05-22 18:45:11.611  - info: sbfspot.0 (248249) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-05-22 18:45:12.151  - info: host.raspberrypi instance system.adapter.sbfspot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-05-22 18:45:15.201  - info: daswetter.0 (248234) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2024-05-22 18:45:15.718  - info: daswetter.0 (248234) cleaned everything up...
      2024-05-22 18:45:15.735  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-05-22 18:45:52.348  - info: admin.0 (199953) <== Disconnect system.user.admin from ::ffff:192.168.178.39 admin
      2024-05-22 18:49:19.090  - info: linux-control.0 (200278) getting data from Raspberry_PI (192.168.178.87:22)
      2024-05-22 18:49:28.562  - info: linux-control.0 (200278) successful received data from Raspberry_PI (192.168.178.87:22)
      2024-05-22 18:50:00.030  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 250221
      2024-05-22 18:50:02.612  - info: dwd.0 (250221) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
      2024-05-22 18:50:05.071  - info: dwd.0 (250221) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-05-22 18:50:05.606  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-05-22 18:50:14.949  - info: admin.0 (199953) ==> Connected system.user.admin from ::ffff:192.168.178.39
      2024-05-22 18:50:24.127  - info: admin.0 (199953) <== Disconnect system.user.admin from ::ffff:192.168.178.39 admin
      2024-05-22 18:54:28.564  - info: linux-control.0 (200278) getting data from Raspberry_PI (192.168.178.87:22)
      2024-05-22 18:54:39.557  - info: linux-control.0 (200278) successful received data from Raspberry_PI (192.168.178.87:22)
      2024-05-22 18:55:00.030  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 250867
      2024-05-22 18:55:03.669  - info: dwd.0 (250867) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
      2024-05-22 18:55:05.524  - info: dwd.0 (250867) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-05-22 18:55:06.063  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      • R ReRo
        @crunchip
        Skript v.2024-04-21
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        rasbe
        HOME=/home/rasbe
        iobroker
        HOME=/home/iobroker
        Terminal: 	wayland
        *** MEMORY ***
                 3792 M total memory
                 2753 M used memory
                  272 M free memory
                   55 M buffer memory
                  957 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        559M	/var/
        195M	/var/lib
        181M	/var/cache
        174M	/var/cache/apt
        USB-Devices by-id:
        /usr/bin/npm 		10.5.0
        /usr/bin/npx 		10.5.0
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.13.16
        javascript: 	7.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	7494
        States: 	5816
        Pending Updates: 3
        haselchenH Offline
        haselchenH Offline
        haselchen
        @rero
        Auf Anhieb sieht man, Deine Zeitzone ist falsch.
        Europe/Berlin
        nicht
        Europe/London
        Dann nutzt Deine Raspi schon den Swap.
        Der ist überfordert. Zuviele Adapter am Laufen.
        Desktop abschalten. Der frisst auch Ressourcen.
        • haselchenH haselchen
          @rero
          Europe/Berlin
          nicht
          Europe/London
          ReRo
          @haselchen
          So, alles umgesetzt und warum auch immer es funktioniert nun. Auch meine 3 Modbus Instanzen, die in der Vergangenheit für gewisse Stunden immer mal wieder ausgestiegen sind, laufen nun fehlerfrei. Vielen Dank!
          • R ReRo
            @haselchen
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            alles umgesetzt
            Zeig lieber nochmal die komplette Ausgabe von
            iob diag
            bitte ;)
            Lehrling seit 1975 !!!
            mcm1957M R 2 Antworten Letzte Antwort
            • DJMarc75D DJMarc75
              alles umgesetzt
              iob diag
              bitte ;)
              mcm1957M Offline
              mcm1957M Offline
              mcm1957
              simple-api hat heute eine neue Version bekommen. Diese sollte bereits od. spätestens morgen im LATEST verfügbar sein.
              Im Kern wurde zwar nur LE entfernt und auf webserver umgestellt da dies für js-controller 6 erforderlich ist. Aber ev. wurde da noch was anderes mitgefixed. Ev. mal mit aktuelle LATEST (2.8.0) testen
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
                alles umgesetzt
                iob diag
                bitte ;)
                ReRo
                @DJMarc75
                Skript v.2024-04-21
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 20:29:15 up 22:27,  3 users,  load average: 0.81, 0.34, 0.34
                CPU threads: 4
                Current issues:
                               Local time: Thu 2024-05-23 20:29:15 CEST
                           Universal time: Thu 2024-05-23 18:29:15 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                rasbe
                HOME=/home/rasbe
                iobroker
                HOME=/home/iobroker
                pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                Try `pgrep -f' option to match against the complete command line.
                Display-Server: false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            4.0G        2.0G        1.2G        1.4M        879M        2.0G
                Swap:           104M          0B        104M
                Total:          4.1G        2.0G        1.3G
                Active iob-Instances:   26
                         3792 M total memory
                         1925 M used memory
                         1973 M active memory
                          535 M inactive memory
                         1104 M free memory
                          117 M buffer memory
                          721 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                top - 20:29:15 up 22:27,  3 users,  load average: 0.81, 0.34, 0.34
                Tasks: 207 total,   1 running, 206 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3792.1 total,   1104.0 free,   1926.1 used,    839.0 buff/cache
                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1866.0 avail Mem
                *** FILESYSTEM ***
                tmpfs          tmpfs     380M  1.3M  378M   1% /run
                /dev/mmcblk0p2 ext4       29G  7.3G   20G  27% /
                tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
                [Wed May 22 22:02:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:DA:3A:D6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a0a0b294-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                [Wed May 22 22:02:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
                [Wed May 22 22:02:06 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
                | `-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
                | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=1626
                `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                584M    /var/
                203M    /var/lib
                182M    /var/cache
                175M    /var/cache/apt
                140M    /var/lib/apt/lists
                Archived and active journals take up 95.8M in the file system.
                12M     /opt/iobroker/backups/
                298M    /opt/iobroker/iobroker-data/
                20M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /usr/bin/nodejs         v18.20.3
                /usr/bin/node           v18.20.3
                /usr/bin/npm            10.7.0
                /usr/bin/npx            10.7.0
                /usr/bin/corepack       0.28.0
                nodejs:
                  Installed: 18.20.3-1nodesource1
                  Version table:
                 *** 18.20.3-1nodesource1 600
                     18.20.2-1nodesource1 600
                     18.20.1-1nodesource1 600
                     18.20.0-1nodesource1 600
                     18.19.1-1nodesource1 600
                     18.19.0-1nodesource1 600
                     18.18.2-1nodesource1 600
                     18.18.1-1nodesource1 600
                     18.18.0-1nodesource1 600
                     18.17.1-1nodesource1 600
                     18.17.0-1nodesource1 600
                     18.16.1-1nodesource1 600
                     18.16.0-1nodesource1 600
                     18.15.0-1nodesource1 600
                     18.14.2-1nodesource1 600
                     18.14.1-1nodesource1 600
                     18.14.0-1nodesource1 600
                     18.13.0+dfsg1-1 500
                     18.13.0-1nodesource1 600
                     18.12.0-1nodesource1 600
                     18.11.0-1nodesource1 600
                     18.10.0-1nodesource1 600
                     18.9.1-1nodesource1 600
                     18.9.0-1nodesource1 600
                     18.8.0-1nodesource1 600
                     18.7.0-1nodesource1 600
                     18.6.0-1nodesource1 600
                     18.5.0-1nodesource1 600
                     18.4.0-1nodesource1 600
                     18.3.0-1nodesource1 600
                     18.2.0-1nodesource1 600
                     18.1.0-1nodesource1 600
                     18.0.0-1nodesource1 600
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.13.16
                javascript:     7.8.0
                Adapter State
                  system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
                  system.adapter.sbfspot.0                : sbfspot               : raspberrypi                              - disabled
                  system.adapter.terminal.0               : terminal              : raspberrypi                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                + instance is alive
                Objects and States
                Objects:        7474
                States:         5782
                Pending Updates: 2
                tcp        0      0 192.168.178.86:2001     0.0.0.0:*               LISTEN      1001       10369      1290/io.hm-rpc.0
                tcp        0      0 192.168.178.86:2010     0.0.0.0:*               LISTEN      1001       8859       1305/io.hm-rpc.1
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6700       782/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5078       733/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8307       733/iobroker.js-con
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          107894     17820/cupsd
                tcp        0      0 192.168.178.86:8701     0.0.0.0:*               LISTEN      1001       8178       1320/io.hm-rpc.2
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          107893     17820/cupsd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          6702       782/sshd: /usr/sbin
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11125      1914/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8403       866/io.admin.0
                tcp6       0      0 :::3500                 :::*                    LISTEN      1001       7089       1092/io.sonos.0
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          106308     17845/cups-browsed
                udp        0      0 0.0.0.0:36046           0.0.0.0:*                           104        4877       526/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4875       526/avahi-daemon: r
                udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       12291      1834/io.sma-em.0
                udp6       0      0 fe80::1da7:3f0f:174:546 :::*                                0          9261       655/NetworkManager
                udp6       0      0 fe80::679f:ea40:123:546 :::*                                0          6747       655/NetworkManager
                udp6       0      0 :::5353                 :::*                                104        4876       526/avahi-daemon: r
                udp6       0      0 :::38640                :::*                                104        4878       526/avahi-daemon: r
                2024-05-23 20:15:13.930  - info: daswetter.0 (172697) cleaned everything up...
                2024-05-23 20:15:13.948  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-05-23 20:15:14.315  - info: daikin-cloud.0 (1197) Daikin-Cloud tokens updated ...
                2024-05-23 20:15:14.762  - info: daikin-cloud.0 (1197) Daikin-Cloud tokens updated ...
                2024-05-23 20:16:54.117  - info: linux-control.0 (1384) getting data from Raspberry_PI (192.168.178.87:22)
                2024-05-23 20:17:07.317  - info: linux-control.0 (1384) successful received data from Raspberry_PI (192.168.178.87:22)
                2024-05-23 20:20:00.024  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 173342
                2024-05-23 20:20:02.404  - info: dwd.0 (173342) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.3, js-controller: 5.0.19
                2024-05-23 20:20:04.217  - info: dwd.0 (173342) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-05-23 20:20:04.752  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-05-23 20:22:07.319  - info: linux-control.0 (1384) getting data from Raspberry_PI (192.168.178.87:22)
                2024-05-23 20:22:16.372  - info: linux-control.0 (1384) successful received data from Raspberry_PI (192.168.178.87:22)
                2024-05-23 20:22:18.938  - info: admin.0 (866) <== Disconnect system.user.admin from ::ffff:192.168.178.39 admin
                2024-05-23 20:25:00.032  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 173985
                2024-05-23 20:25:02.284  - info: dwd.0 (173985) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.3, js-controller: 5.0.19
                2024-05-23 20:25:03.433  - info: dwd.0 (173985) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-05-23 20:25:03.973  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-05-23 20:25:07.621  - warn: bmw.0 (1931) Out of call volume quota. Quota will be replenished in 00:34:53.
                2024-05-23 20:27:16.374  - info: linux-control.0 (1384) getting data from Raspberry_PI (192.168.178.87:22)
                2024-05-23 20:27:29.511  - info: linux-control.0 (1384) successful received data from Raspberry_PI (192.168.178.87:22)
                2024-05-23 20:28:12.948  - info: admin.0 (866) ==> Connected system.user.admin from ::ffff:192.168.178.39
                2024-05-23 20:28:13.147  - info: admin.0 (866) <== Disconnect system.user.admin from ::ffff:192.168.178.39 admin
                2024-05-23 20:28:14.207  - info: admin.0 (866) ==> Connected system.user.admin from ::ffff:192.168.178.39
                2024-05-23 20:29:03.428  - info: admin.0 (866) <== Disconnect system.user.admin from ::ffff:192.168.178.39 admin
                2024-05-23 20:30:00.039  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 175755
                • R ReRo
                  @DJMarc75
                  Skript v.2024-04-21
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  rasbe
                  HOME=/home/rasbe
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           104M          0B        104M
                           3792 M total memory
                           1925 M used memory
                           1104 M free memory
                            117 M buffer memory
                            721 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  *** FILESYSTEM ***
                  /var:
                  584M    /var/
                  203M    /var/lib
                  182M    /var/cache
                  175M    /var/cache/apt
                  USB-Devices by-id:
                  /usr/bin/npm            10.7.0
                  /usr/bin/npx            10.7.0
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        7474
                  States:         5782
                  Pending Updates: 2
                  Schaut ganz gut aus.
                  Perfekt machst du es, wenn die
                  Pending Updates: 2
                  eingespielt werden und nodejs@20 installiert wird.
                  Per
                  iob nodejs-update 20
                  z. B.
                    Pending Updates: 2
                    Per
                    z. B.
                    Andreas 9
                    @thomas-braun said in Simple-api startet nicht mehr:
                    Hallo, ich habe das selbe Problem: Simple Rest Api startet nicht.
                    Ich habe alle Adapter aktualisiert und auch nodejs auf 20. Aber npm ist Version 10.5.2
                    Wie wird npm geupdatet? npm install -g npm soll wohl nicht benutzt werden...
                    Vielen Dank!
                    Homematic-Raspi auf Raspi 3+
                    IOBroker auf Raspi 4
                    Kostal PLENTICORE plus 4.2 mit Batterie;
                    HomoranH mcm1957M 2 Antworten Letzte Antwort
                    • A Andreas 9
                      Vielen Dank!
                      @andreas-9 sagte in Simple-api startet nicht mehr:
                      gar nicht! kommt mit node in der passenden Version
                      • A Andreas 9
                        Vielen Dank!
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @andreas-9 said in Simple-api startet nicht mehr:
                        Vielen Dank!
                        Welche Versionen sind aktiv ?
                        • simple-api
                        • js-controller
                        • node
                        • o/s
                          Andreas 9
                          @mcm1957
                          ich hab mal iob diag ausgeführt:
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                           Static hostname: IOBroker-Raspi4
                                 Icon name: computer
                          Operating System: Raspbian GNU/Linux 12 (bookworm)
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 32 bit
                           12:01:29 up  1:50,  2 users,  load average: 0.48, 0.25, 0.14
                          CPU threads: 4
                          Current issues:
                                         Local time: Mon 2024-05-27 12:01:29 CEST
                                     Universal time: Mon 2024-05-27 10:01:29 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          andi
                          HOME=/home/andi
                          GROUPS=andi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                          iobroker
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            4.0G        809M        1.9G        1.2M        1.3G        3.2G
                          Swap:           104M          0B        104M
                          Total:          4.1G        809M        2.0G
                          Active iob-Instances:   13
                                   3792 M total memory
                                    772 M used memory
                                   1004 M active memory
                                    807 M inactive memory
                                   1813 M free memory
                                    168 M buffer memory
                                   1046 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          top - 12:01:29 up  1:50,  2 users,  load average: 0.48, 0.25, 0.14
                          Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   3792.1 total,   1812.7 free,    773.4 used,   1214.9 buff/cache
                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3018.7 avail Mem
                            UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                          * telegraf.service loaded failed failed Telegraf
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          tmpfs          tmpfs     380M  1.2M  379M   1% /run
                          /dev/mmcblk0p2 ext4      117G  9.0G  102G   9% /
                          /dev/mmcblk0p1 vfat      510M   96M  415M  19% /boot/firmware
                          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                          [Mon May 27 10:10:51 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:95:FE:04 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6f9649ea-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Mon May 27 10:10:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem ee354f68-c22f-48b7-a81c-43ae87c280f8 ro with ordered data mode. Quota mode: none.
                          [Mon May 27 10:10:56 2024] EXT4-fs (mmcblk0p2): re-mounted ee354f68-c22f-48b7-a81c-43ae87c280f8 r/w. Quota mode: none.
                          | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3943
                          |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671560k,nr_inodes=417890,mode=755
                          /var:
                          4.5G    /var/
                          3.0G    /var/log/journal/f1efad6ddc4841dc8c5c94b6519006b3
                          3.0G    /var/log
                          1.1G    /var/cache/apt/archives
                          Archived and active journals take up 2.9G in the file system.
                          531M    /opt/iobroker/backups/
                          28M     /opt/iobroker/backups/influx
                          222M    /opt/iobroker/iobroker-data/
                          164M    /opt/iobroker/iobroker-data/files
                          138M    /opt/iobroker/iobroker-data/files/javascript.admin
                          118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                          117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                          12M     /opt/iobroker/iobroker-data/objects.jsonl
                          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
                          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/61.54b23816.chunk.js.map
                          6.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/139.52cd9c26.chunk.js.map
                          6.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/516.837647f3.chunk.js.map
                          USB-Devices by-id:
                          /usr/bin/nodejs         v20.13.1
                          /usr/bin/node           v20.13.1
                          /usr/bin/npm            10.8.0
                          /usr/bin/npx            10.8.0
                          nodejs:
                            Installed: 20.13.1-1nodesource1
                            Candidate: 20.13.1-1nodesource1
                            Version table:
                           *** 20.13.1-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                               20.13.0-1nodesource1 1001
                               20.12.2-1nodesource1 1001
                               20.12.1-1nodesource1 1001
                               20.12.0-1nodesource1 1001
                               20.11.1-1nodesource1 1001
                               20.11.0-1nodesource1 1001
                               20.10.0-1nodesource1 1001
                               20.9.0-1nodesource1 1001
                               20.8.1-1nodesource1 1001
                               20.8.0-1nodesource1 1001
                               20.7.0-1nodesource1 1001
                               20.6.1-1nodesource1 1001
                               20.6.0-1nodesource1 1001
                               20.5.1-1nodesource1 1001
                               20.5.0-1nodesource1 1001
                               20.4.0-1nodesource1 1001
                               20.3.1-1nodesource1 1001
                               20.3.0-1nodesource1 1001
                               20.2.0-1nodesource1 1001
                               20.1.0-1nodesource1 1001
                               20.0.0-1nodesource1 1001
                               18.19.0+dfsg-6~deb12u1+rpi1 500
                                  500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.13.16
                          javascript:     8.3.1
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : IOBroker-Raspi4                          -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          + system.adapter.backitup.0               : backitup              : IOBroker-Raspi4                          -  enabled
                          + system.adapter.discovery.0              : discovery             : IOBroker-Raspi4                          -  enabled
                          + system.adapter.fritzdect.0              : fritzdect             : IOBroker-Raspi4                          -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : IOBroker-Raspi4                          -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker-Raspi4                          -  enabled, port: 0
                          + system.adapter.influxdb.0               : influxdb              : IOBroker-Raspi4                          -  enabled, port: 8086
                          + system.adapter.javascript.0             : javascript            : IOBroker-Raspi4                          -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : IOBroker-Raspi4                          -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.ping.0                   : ping                  : IOBroker-Raspi4                          -  enabled
                          + system.adapter.plenticore.0             : plenticore            : IOBroker-Raspi4                          -  enabled, port: 443
                            system.adapter.simple-api.0             : simple-api            : IOBroker-Raspi4                          - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                          + system.adapter.sonoff.0                 : sonoff                : IOBroker-Raspi4                          -  enabled, port: 1884, bind: 0.0.0.0
                          + instance is alive
                          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                          Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
                          Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                          Objects and States
                          Objects:        1982
                          States:         1689
                          Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
                          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:3 https://apt.grafana.com stable InRelease
                          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Hit:5 https://repos.influxdata.com/debian stable InRelease
                          Hit:6 https://repos.influxdata.com/debian stretch InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6657       668/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       60093      6270/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       60088      6270/iobroker.js-co
                          tcp        0      0 0.0.0.0:42010           0.0.0.0:*               LISTEN      1001       63636      6442/io.hm-rpc.0
                          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       63601      6424/io.sonoff.0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       62277      6393/io.mqtt.0
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        5750       727/influxd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          6659       668/sshd: /usr/sbin
                          tcp6       0      0 :::3000                 :::*                    LISTEN      106        6799       785/grafana
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        6759       727/influxd
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60137      6291/io.admin.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        494        502/avahi-daemon: r
                          udp        0      0 0.0.0.0:59264           0.0.0.0:*                           104        496        502/avahi-daemon: r
                          udp6       0      0 fe80::7747:b49b:2be:546 :::*                                0          5736       609/NetworkManager
                          udp6       0      0 :::39670                :::*                                104        497        502/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                104        495        502/avahi-daemon: r
                          2024-05-27 11:58:19.843  - info: javascript.0 (8692) Start JavaScript script.js.common.Gaszähler.Zähler-Korrektur (Blockly)
                          2024-05-27 11:58:19.849  - info: javascript.0 (8692) script.js.common.Gaszähler.Zähler-Korrektur: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2024-05-27 11:58:20.016  - error: javascript.0 (8692) [sunTimeSchedules] Unable to set state for astro time "nightEnd"
                          2024-05-27 11:58:20.020  - error: javascript.0 (8692) [sunTimeSchedules] Unable to set state for astro time "night"
                          2024-05-27 11:58:29.763  - info: javascript.0 (8692) Stopping script script.js.common.Heizstab.Heizstab-Generalschalter
                          2024-05-27 11:58:29.861  - info: javascript.0 (8692) Start JavaScript script.js.common.Heizstab.Heizstab-Generalschalter (Blockly)
                          2024-05-27 11:58:29.873  - info: javascript.0 (8692) script.js.common.Heizstab.Heizstab-Generalschalter: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                          2024-05-27 11:58:40.508  - info: javascript.0 (8692) Stopping script script.js.common.Heizstab.Heizstab-Generalschalter
                          2024-05-27 11:58:40.608  - info: javascript.0 (8692) Start JavaScript script.js.common.Heizstab.Heizstab-Generalschalter (Blockly)
                          2024-05-27 11:58:40.634  - info: javascript.0 (8692) script.js.common.Heizstab.Heizstab-Generalschalter: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                          2024-05-27 11:58:43.265  - info: admin.0 (6291) <== Disconnect system.user.admin from ::ffff:192.168.178.5 javascript
                          2024-05-27 11:59:00.041  - info: javascript.0 (8692) script.js.common.Heizstab.Heizstab-Steuerung: ----> Heizstabsteuerung...
                          2024-05-27 11:59:16.504  - info: admin.0 (6291) ==> Connected system.user.admin from ::ffff:192.168.178.5
                          2024-05-27 12:00:00.048  - info: javascript.0 (8692) script.js.common.Heizstab.Heizstab-Steuerung: ----> Heizstabsteuerung...
                          2024-05-27 12:00:00.074  - info: javascript.0 (8692) script.js.common.Status: ========== Status: ==========
                          2024-05-27 12:00:00.075  - info: javascript.0 (8692) script.js.common.Status: DS-Excess: 1141.12
                          2024-05-27 12:00:00.076  - info: javascript.0 (8692) script.js.common.Status: Hausverbrauch: 1244.6540496411
                          2024-05-27 12:00:00.076  - info: javascript.0 (8692) script.js.common.Status: Batterie-Ladung: 15
                          2024-05-27 12:00:00.077  - info: javascript.0 (8692) script.js.common.Status: HSTGeneralSchalter: true
                          2024-05-27 12:00:00.077  - info: javascript.0 (8692) script.js.common.Status: HSTGeneralSchalter: 229
                          2024-05-27 12:00:00.077  - info: javascript.0 (8692) script.js.common.Status: Heizstableistung: 991
                          2024-05-27 12:00:00.078  - info: javascript.0 (8692) script.js.common.Status: WWPumpe: false
                          2024-05-27 12:00:00.079  - info: javascript.0 (8692) script.js.common.Status: WWTermperatur: 45.8
                          2024-05-27 12:00:00.079  - info: javascript.0 (8692) script.js.common.Status: WWSpeicher: false
                          2024-05-27 12:00:00.079  - info: javascript.0 (8692) script.js.common.Status: ========== Status: ==========
                          Zusammmenfassung:
                                                  v.2024-05-22
                                 Icon name: computer
                              Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               32 bit
                          User-ID:                1000
                          Pending OS-Updates:     0
                          /usr/bin/npm            10.8.0
                          /usr/bin/npx            10.8.0
                          MEMORY:
                          Mem:            4.0G        838M        1.9G        1.2M        1.3G        3.1G
                          Swap:           104M          0B        104M
                          Total:          4.1G        838M        2.0G
                                                  admin                   6.13.16
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                1982
                          States:                 1689
                          5.8M    /opt/iobroker/iobroker-data/states.jsonl
                          Danke für die Mühe!!!
                          DJMarc75D mcm1957M Thomas BraunT 3 Antworten Letzte Antwort
                          • A Andreas 9
                            @mcm1957
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 32 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            andi
                            HOME=/home/andi
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           104M          0B        104M
                                     3792 M total memory
                                      772 M used memory
                                     1813 M free memory
                                      168 M buffer memory
                                     1046 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            *** FILESYSTEM ***
                            /var:
                            4.5G    /var/
                            3.0G    /var/log
                            USB-Devices by-id:
                            /usr/bin/npm            10.8.0
                            /usr/bin/npx            10.8.0
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.13.16
                            javascript:     8.3.1
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        1982
                            States:         1689
                            Pending Updates: 0
                            Zusammmenfassung:
                                                    v.2024-05-22
                                   Icon name: computer
                                Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               32 bit
                            User-ID:                1000
                            /usr/bin/npm            10.8.0
                            /usr/bin/npx            10.8.0
                            MEMORY:
                            Swap:           104M          0B        104M
                                                    admin                   6.13.16
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                1982
                            States:                 1689
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            /usr/bin/npm 10.8.0
                            Wohl nachträglich NPM reingebügelt ?
                            Die richtige Version wäre 10.5.2 und kommt immer automatisch mit wenn NodeJS korrekt upgedatet wird.
                            • A Andreas 9
                              @mcm1957
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 32 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              andi
                              HOME=/home/andi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           104M          0B        104M
                                       3792 M total memory
                                        772 M used memory
                                       1813 M free memory
                                        168 M buffer memory
                                       1046 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /var:
                              4.5G    /var/
                              3.0G    /var/log
                              USB-Devices by-id:
                              /usr/bin/npm            10.8.0
                              /usr/bin/npx            10.8.0
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.13.16
                              javascript:     8.3.1
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        1982
                              States:         1689
                              Pending Updates: 0
                              Zusammmenfassung:
                                                      v.2024-05-22
                                     Icon name: computer
                                  Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               32 bit
                              User-ID:                1000
                              /usr/bin/npm            10.8.0
                              /usr/bin/npx            10.8.0
                              MEMORY:
                              Swap:           104M          0B        104M
                                                      admin                   6.13.16
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                1982
                              States:                 1689
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              @andreas-9
                              https://forum.iobroker.net/topic/74827/simple-api-startet-nicht-mehr/9 und nachfolgend.
                              Teste mal mit aktueller LATEST von simple-api
                              H 1 Antwort Letzte Antwort
                              • mcm1957M mcm1957
                                @andreas-9
                                hkettler
                                @mcm1957 Anfängerfrage zum gleichen Problem: Standardmässig wird noch 2.7.2 installiert. Wie installiere ich die latest (2.8.0 zur Zeit) Version?
                                • A Andreas 9
                                  @mcm1957
                                  Skript v.2024-05-22
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 32 bit
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  andi
                                  HOME=/home/andi
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           104M          0B        104M
                                           3792 M total memory
                                            772 M used memory
                                           1813 M free memory
                                            168 M buffer memory
                                           1046 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  4.5G    /var/
                                  3.0G    /var/log
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.8.0
                                  /usr/bin/npx            10.8.0
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.13.16
                                  javascript:     8.3.1
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        1982
                                  States:         1689
                                  Pending Updates: 0
                                  Zusammmenfassung:
                                                          v.2024-05-22
                                         Icon name: computer
                                      Architecture: arm64
                                  Kernel:                 aarch64
                                  Userland:               32 bit
                                  User-ID:                1000
                                  /usr/bin/npm            10.8.0
                                  /usr/bin/npx            10.8.0
                                  MEMORY:
                                  Swap:           104M          0B        104M
                                                          admin                   6.13.16
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                1982
                                  States:                 1689
                                  /usr/bin/npm 10.8.0
                                  npm falsch installiert.
                                  Lasst von npm ganz einfach die Finger...
                                  Kann doch nicht so schwer sein...
                                  iob stop
                                  sudo apt update
                                  sudo apt install --reinstall nodejs
                                  iob start
                                  • H hkettler
                                    mcm1957M Offline
                                    mcm1957M Offline
                                    mcm1957
                                    @hkettler said in Simple-api startet nicht mehr:
                                    a) Repository temporär auf LATEST (Beta) umstellen, search for updates klicken und NUR diesen Adapter aktualisiseren
                                    oder
                                    b) im Expertmode auf custom install simple-api@latest eingeben
                                    • mcm1957M mcm1957
                                      oder
                                      hkettler
                                      @mcm1957 Danke. Funktioniert. 2.8.0 installiert und Fehler ist weg.
                                        /usr/bin/npm 10.8.0
                                        iob stop
                                        sudo apt update
                                        iob start
                                        Andreas 9
                                        so, geschafft!
                                        nodejs /npm reinstalliert und Version 2.8.0 installiert - läuft!
                                        Herzlichen Dank an alle!
