  4. JavaScript
  5. Hilfe für Javascript Legastheniker und js v8.3.x
    6.3k
104 Beiträge 8 Kommentatoren 15.8k Aufrufe 7 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    Aber das war nur ein winziger Ausschnitt aus einem größeren Skript:
    const city_id = XXXXX;
    const area_id = XXX;
    const logging = false;
    const name = 'Müllabfuhr';
    const numberOfEntries = 69;
    const instanz = '0_userdata.' + instance + '.muell-test';
    if (logging) log('starting muell.' + instanz);
    extendObject(instanz, {
           type: "device",
           common: {
       }, function (err) {
           if (err) {
               log('could not create device: ', 'warn');
               return;
    let baseData = {};
    // query names first
    httpGet('https://mymuell.jumomind.com/mmapp/api.php?r=trash&city_id=' + city_id + '&area_id=' + area_id, { timeout: 2000 }, (error, response) => {
       if (!error && response.statusCode == 200) {
           console.log(response.statusCode);
           console.log(response.data);
       } else {
           console.error(error);
       var data = JSON.parse(response.data);  // info ist ein Objekt
               data.forEach((v, i) => {
                   baseData[v._name] = v;
       updateMuell();
    schedule('{"time":{"exactTime":true,"start":"12:17"},"period":{"days":1}}', updateMuell);
    function updateMuell() {
       var options = 'https://mymuell.jumomind.com/webservice.php?idx=termins&city_id=' + city_id + '&area_id=' + area_id + '&ws=3'
       httpGet(options), (error, response) => {
           var info = JSON.parse(response.data);  // info ist ein Objekt
               if (info[0].Ack === 'Success') {
                   var data = info[0]._data;  // xy ist eine Eigenschaft des Objektes info
                   let counter = 0;
                   const date = (new Date())
                   const todayStr = date.getFullYear() + "-" + ('00' + (date.getMonth() + 1 )).slice(-2) + "-" + ('00' + date.getDate()).slice(-2)
                   log(todayStr);
                       if (todayStr < v.cal_date && counter <= numberOfEntries) {
                           const basePath = instanz + '.' + ('000' + counter).slice(-3);
                           log(v.cal_date + ' -> ' + basePath, 'debug');
                           // States erstellen
                           extendObject(basePath, {
                                   type: "channel",
                                   common: {
                               }, function (err) {
                                   if (err) {
                                       return;
                           createState(basePath + '.date', v.cal_date_normal, {
                               desc: 'Datum der Abholung',
                               type: 'string',
                               read: true,
                               write: false
                               setState(basePath + '.date', v.cal_date_normal, true);
                           createState(basePath + '.desc', baseData[v.cal_garbage_type].title, {
                               desc: 'Beschreibung der Abholung',
                               type: 'string',
                               read: true,
                               write: false
                               setState(basePath + '.desc', baseData[v.cal_garbage_type].title, true);
                           createState(basePath + '.color', {
                               desc: 'Farbe',
                               type: 'string',
                               role: 'level.color',
                               read: true,
                               write: false
                               setState(basePath + '.color', baseData[v.cal_garbage_type].color, true);
                           counter++;
    TT-Tom
    #74
    @ofbeqnpolkkl6mby5e13 sagte in Hilfe für Javascript Legastheniker und js v8.3.x:
    Zeile 46 hinter options die ) muss weg.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    O 1 Antwort Letzte Antwort
    • T TT-Tom
      O Abwesend
      O Abwesend
      #75
      @tt-tom
      2024-05-26 22:46:45.108  - error: javascript.0 (3416) script.js.common._Tests.Test_17 compile failed:
      at script.js.common._Tests.Test_17:111
      2024-05-26 22:46:45.109  - error: javascript.0 (3416)         };
      2024-05-26 22:46:45.109  - error: javascript.0 (3416)         ^
      2024-05-26 22:46:45.109  - error: javascript.0 (3416) SyntaxError: missing ) after argument list
      2024-05-26 22:46:45.109  - error: javascript.0 (3416)     at new Script (node:vm:99:7)
      2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1917:21)
      2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2183:37)
      2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at /opt/iobroker/node_modules/iobroker.javascript/main.js:2281:17
      2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1703:17)
      2024-05-26 22:46:45.111  - error: javascript.0 (3416)     at process.processImmediate (node:internal/timers:478:21)
      2024-05-26 22:46:46.955  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
        @tt-tom
        TT-Tom
        #76
        da fehlen irgendwo noch Klammern, bin grad mal am suchen
        Edit: probiere mal das jetzt.
            httpGet(options, (error, response) => {
                        let counter = 0;
                        const todayStr = date.getFullYear() + "-" + ('00' + (date.getMonth() + 1)).slice(-2) + "-" + ('00' + date.getDate()).slice(-2)
                        log(todayStr);
                                // States erstellen
                                    type: "channel",
                                    common: {
                                }, function (err) {
                                    if (err) {
                                        return;
                                    type: 'string',
                                    read: true,
                                    write: false
                                    type: 'string',
                                    read: true,
                                    write: false
                                    desc: 'Farbe',
                                    type: 'string',
                                    read: true,
                                    write: false
                                counter++;
        Gruß Tom
        Public Transport
        • T TT-Tom
                          let counter = 0;
                          log(todayStr);
                                  // States erstellen
                                      type: "channel",
                                      common: {
                                  }, function (err) {
                                      if (err) {
                                          return;
                                      type: 'string',
                                      read: true,
                                      write: false
                                      type: 'string',
                                      read: true,
                                      write: false
                                      desc: 'Farbe',
                                      type: 'string',
                                      read: true,
                                      write: false
                                  counter++;
          O Abwesend
          O Abwesend
          #77
          @tt-tom
          Danke, es kommt kein Fehler mehr! Eine Objektstruktur wird weiterhin nicht angelegt.
            @tt-tom
            TT-Tom
            #78
            okay dann brauche ich mal das komplette Log vom Start das Script. Muss mir mal die Daten ansehen, die da kommen.
            Gruß Tom
            Public Transport
            • T TT-Tom
              O Abwesend
              O Abwesend
              #79
              @tt-tom
              2024-05-26 23:06:36.838  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
              2024-05-26 23:06:36.850  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
              2024-05-26 23:06:36.925  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 200
              2024-05-26 23:06:36.926  - info: javascript.0 (3416) script.js.common._Tests.Test_17: [{"title":"Bioabfall","name":"SZ_BIO","_name":"SZ_BIO","color":"a52a2a"},{"title":"Gelber Sack","name":"SZ_G","_name":"SZ_G","color":"FFFF00"},{"title":"Altpapier (120l, 240l)","name":"SZ_P","_name":"SZ_P","color":"2fc2e8"},{"title":"Restabfall (bis 240l)","name":"SZ_R","_name":"SZ_R","color":"2F4F4F"},{"title":"Weihnachtsbaum","name":"SZ_W","_name":"SZ_W","color":"36b515"}]
              2024-05-26 23:14:15.038  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
                @tt-tom
                TT-Tom
                #80
                der erste teil stimmt auch nicht bzw. ist unlogisch. Hast du noch das original?
                Gruß Tom
                Public Transport
                • T TT-Tom
                  O Abwesend
                  O Abwesend
                  #81
                  @tt-tom
                  https://github.com/volkerrichert/ioBroker.mymuell/blob/master/myMuell.iob
                    @tt-tom
                    TT-Tom
                    #82
                    okay, muss den Anfang auch nochmal anpassen. Da ist etwas verrutscht ;)
                       updateMuell();
                       } else {
                    Gruß Tom
                    Public Transport
                    • T TT-Tom
                         updateMuell();
                         } else {
                      O Abwesend
                      O Abwesend
                      #83
                      @tt-tom
                      Ah, jetzt wird die Objektstruktur angelegt! Vielen Dank!
                      Aber, im Original werden keine Daten auf der Konsole ausgegeben. Woran liegt das?
                        @tt-tom
                        TT-Tom
                        #84
                        im Script sind diese Zeilen für die Ausgabe
                        ersetze sie mit diesen Zeilen
                        if (logging) console.log(response.statusCode);
                        if (logging) console.log(response.data);
                        dann kommt die Meldung nur, wenn du logging auf true setzt
                        const logging = true;
                        Gruß Tom
                        Public Transport
                        O 2 Antworten Letzte Antwort
                        • T TT-Tom
                          O Abwesend
                          O Abwesend
                          #85
                          @tt-tom
                          Aber das ist im Original doch auch nicht so und im Original werden im Normalfall keine Meldungen ausgegeben.
                          • T TT-Tom
                            O Abwesend
                            O Abwesend
                            #86
                            @tt-tom
                            Ach sorry, das hatte ich ja selbst hinzugefügt.
                              @tt-tom
                              TT-Tom
                              #87
                              so Feierabend für heute, Script läuft soweit?
                              Gruß Tom
                              Public Transport
                              • T TT-Tom
                                O Abwesend
                                O Abwesend
                                #88
                                @tt-tom
                                Ich weiß nicht...
                                2024-05-26 23:37:50.481  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
                                2024-05-26 23:37:50.492  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                2024-05-26 23:37:50.656  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 200
                                2024-05-26 23:37:50.656  - info: javascript.0 (3416) script.js.common._Tests.Test_17: [{"Ack":"Success","id":"mm_termins","messages":[{"status":"OK","msg":"getTermins"}],"_data":[{"cal_id":"128222324","cal_date":"2024-01-03","cal_date_normal":"03.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222316","cal_date":"2024-01-03","cal_date_normal":"03.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222376","cal_date":"2024-01-09","cal_date_normal":"09.01.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222387","cal_date":"2024-01-10","cal_date_normal":"10.01.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128222464","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_W","cal_comment":""},{"cal_id":"128222458","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222450","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222532","cal_date":"2024-01-23","cal_date_normal":"23.01.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222604","cal_date":"2024-01-30","cal_date_normal":"30.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222596","cal_date":"2024-01-30","cal_date_normal":"30.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222645","cal_date":"2024-02-06","cal_date_normal":"06.02.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222718","cal_date":"2024-02-13","cal_date_normal":"13.02.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222710","cal_date":"2024-02-13","cal_date_normal":"13.02.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222726","cal_date":"2024-02-14","cal_date_normal":"14.02.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128222767","cal_date":"2024-02-20","cal_date_normal":"20.02.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222841","cal_date":"2024-02-27","cal_date_normal":"27.02.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222833","cal_date":"2024-02-27","cal_date_normal":"27.02.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222890","cal_date":"2024-03-05","cal_date_normal":"05.03.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222963","cal_date":"2024-03-12","cal_date_normal":"12.03.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222955","cal_date":"2024-03-12","cal_date_normal":"12.03.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222971","cal_date":"2024-03-13","cal_date_normal":"13.03.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223012","cal_date":"2024-03-19","cal_date_normal":"19.03.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223086","cal_date":"2024-03-25","cal_date_normal":"25.03.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223078","cal_date":"2024-03-25","cal_date_normal":"25.03.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223135","cal_date":"2024-04-03","cal_date_normal":"03.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223208","cal_date":"2024-04-09","cal_date_normal":"09.04.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223200","cal_date":"2024-04-09","cal_date_normal":"09.04.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223216","cal_date":"2024-04-10","cal_date_normal":"10.04.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223257","cal_date":"2024-04-16","cal_date_normal":"16.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223331","cal_date":"2024-04-23","cal_date_normal":"23.04.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223323","cal_date":"2024-04-23","cal_date_normal":"23.04.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223380","cal_date":"2024-04-30","cal_date_normal":"30.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223453","cal_date":"2024-05-07","cal_date_normal":"07.05.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223445","cal_date":"2024-05-07","cal_date_normal":"07.05.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223461","cal_date":"2024-05-08","cal_date_normal":"08.05.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223502","cal_date":"2024-05-14","cal_date_normal":"14.05.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223576","cal_date":"2024-05-22","cal_date_normal":"22.05.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223568","cal_date":"2024-05-22","cal_date_normal":"22.05.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223625","cal_date":"2024-05-28","cal_date_normal":"28.05.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223689","cal_date":"2024-06-04","cal_date_normal":"04.06.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223681","cal_date":"2024-06-04","cal_date_normal":"04.06.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223739","cal_date":"2024-06-11","cal_date_normal":"11.06.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223748","cal_date":"2024-06-12","cal_date_normal":"12.06.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223811","cal_date":"2024-06-18","cal_date_normal":"18.06.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223803","cal_date":"2024-06-18","cal_date_normal":"18.06.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223862","cal_date":"2024-06-25","cal_date_normal":"25.06.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223934","cal_date":"2024-07-02","cal_date_normal":"02.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223926","cal_date":"2024-07-02","cal_date_normal":"02.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223984","cal_date":"2024-07-09","cal_date_normal":"09.07.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223993","cal_date":"2024-07-10","cal_date_normal":"10.07.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224056","cal_date":"2024-07-16","cal_date_normal":"16.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224048","cal_date":"2024-07-16","cal_date_normal":"16.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224107","cal_date":"2024-07-23","cal_date_normal":"23.07.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224179","cal_date":"2024-07-30","cal_date_normal":"30.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224171","cal_date":"2024-07-30","cal_date_normal":"30.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224220","cal_date":"2024-08-06","cal_date_normal":"06.08.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224293","cal_date":"2024-08-13","cal_date_normal":"13.08.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224285","cal_date":"2024-08-13","cal_date_normal":"13.08.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224301","cal_date":"2024-08-14","cal_date_normal":"14.08.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224342","cal_date":"2024-08-20","cal_date_normal":"20.08.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224416","cal_date":"2024-08-27","cal_date_normal":"27.08.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224408","cal_date":"2024-08-27","cal_date_normal":"27.08.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224465","cal_date":"2024-09-03","cal_date_normal":"03.09.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224538","cal_date":"2024-09-10","cal_date_normal":"10.09.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224530","cal_date":"2024-09-10","cal_date_normal":"10.09.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224546","cal_date":"2024-09-11","cal_date_normal":"11.09.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224587","cal_date":"2024-09-17","cal_date_normal":"17.09.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224661","cal_date":"2024-09-24","cal_date_normal":"24.09.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224653","cal_date":"2024-09-24","cal_date_normal":"24.09.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224704","cal_date":"2024-10-01","cal_date_normal":"01.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224777","cal_date":"2024-10-08","cal_date_normal":"08.10.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224769","cal_date":"2024-10-08","cal_date_normal":"08.10.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224785","cal_date":"2024-10-09","cal_date_normal":"09.10.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224826","cal_date":"2024-10-15","cal_date_normal":"15.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224900","cal_date":"2024-10-22","cal_date_normal":"22.10.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224892","cal_date":"2024-10-22","cal_date_normal":"22.10.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224949","cal_date":"2024-10-29","cal_date_normal":"29.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225013","cal_date":"2024-11-05","cal_date_normal":"05.11.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225005","cal_date":"2024-11-05","cal_date_normal":"05.11.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225063","cal_date":"2024-11-12","cal_date_normal":"12.11.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225072","cal_date":"2024-11-13","cal_date_normal":"13.11.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128225135","cal_date":"2024-11-19","cal_date_normal":"19.11.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225127","cal_date":"2024-11-19","cal_date_normal":"19.11.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225186","cal_date":"2024-11-26","cal_date_normal":"26.11.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225258","cal_date":"2024-12-03","cal_date_normal":"03.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225250","cal_date":"2024-12-03","cal_date_normal":"03.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225308","cal_date":"2024-12-10","cal_date_normal":"10.12.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225317","cal_date":"2024-12-11","cal_date_normal":"11.12.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128225380","cal_date":"2024-12-17","cal_date_normal":"17.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225372","cal_date":"2024-12-17","cal_date_normal":"17.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225431","cal_date":"2024-12-23","cal_date_normal":"23.12.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225503","cal_date":"2024-12-31","cal_date_normal":"31.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225495","cal_date":"2024-12-31","cal_date_normal":"31.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225555","cal_date":"2025-01-07","cal_date_normal":"07.01.2025","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225566","cal_date":"2025-01-08","cal_date_normal":"08.01.2025","cal_garbage_type":"SZ_P","cal_comment":""}],"_extra":[]}]
                                2024-05-26 23:37:50.657  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 2024-05-26
                                2024-05-26 23:37:55.515  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.000.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.517  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.001.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.519  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.002.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.520  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.003.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.521  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.004.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.523  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.005.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.524  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.006.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.525  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.007.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.526  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.008.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.528  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.009.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.529  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.010.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.530  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.011.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.541  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.012.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.543  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.013.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.544  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.014.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.546  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.015.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.547  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.016.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.548  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.017.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.549  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.018.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.551  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.019.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.552  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.020.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.553  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.021.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.555  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.022.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.556  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.023.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.558  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.024.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.559  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.025.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.560  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.026.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.562  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.027.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.563  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.028.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.564  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.029.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.566  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.030.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.568  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.031.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.570  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.032.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.571  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.033.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.573  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.034.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.574  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.035.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.575  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.036.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.577  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.037.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.578  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.038.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.579  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.039.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.581  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.040.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.582  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.041.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.583  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.042.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.584  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.043.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.586  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.044.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.587  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.045.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.588  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.046.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.590  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.047.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.591  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.048.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.592  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.049.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.602  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.050.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.603  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.051.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.605  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.052.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.606  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.053.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.607  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.054.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.608  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.055.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:55.669  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.056.color" has been written without ack-flag with value "null"
                                2024-05-26 23:37:59.691  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
                                  @tt-tom
                                  Ich weiß nicht...
                                  TT-Tom
                                  #89
                                  sende bitte nochmal jetzt das komplette Script, ich sehe mir das morgenfrüh an. da Passt etwas mit dem erstellen des color State nicht.
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    O Abwesend
                                    O Abwesend
                                    #90
                                    @tt-tom
                                    Okay, vielen Dank!
                                    const city_id = 66005;
                                    const area_id = 2800;
                                           type: "device",
                                           common: {
                                       }, function (err) {
                                           if (err) {
                                               return;
                                    let baseData = {};
                                      updateMuell();
                                      } else {
                                                   let counter = 0;
                                                   log(todayStr);
                                                           // States erstellen
                                                               type: "channel",
                                                               common: {
                                                           }, function (err) {
                                                               if (err) {
        return;
                                                               type: 'string',
                                                               read: true,
                                                               write: false
                                                               type: 'string',
                                                               read: true,
                                                               write: false
                                                               desc: 'Farbe',
                                                               type: 'string',
                                                               read: true,
                                                               write: false
                                                           counter++;
                                    wolfi913W T 2 Antworten Letzte Antwort
                                      @tt-tom
                                      Okay, vielen Dank!
                                             type: "device",
                                             common: {
                                         }, function (err) {
                                             if (err) {
                                                 return;
                                      let baseData = {};
                                        updateMuell();
                                        } else {
                                                     let counter = 0;
                                                     log(todayStr);
                                                             // States erstellen
        type: "channel",
        common: {
                                                             }, function (err) {
        if (err) {
        return;
        type: 'string',
        read: true,
        write: false
        type: 'string',
        read: true,
        write: false
        desc: 'Farbe',
        type: 'string',
        read: true,
        write: false
                                                             counter++;
                                      wolfi913W Offline
                                      wolfi913W Offline
                                      wolfi913
                                      #91
                                      @tt-tom
                                      Nur eine Idee von jemandem der sich aber mit JS nicht auskennt. Daher schlagt mich nicht, falls ich totalen Unsinn schreibe.
                                      Evtl. liegt's an der Variable var data im Ursprungsscript (z.B. Zeile 51). Möglicherweise funktioniert das nach dem Update auf V8.3.1 nicht mehr. Hatte ein ähnliches Problem in einem Blockly. Da hatte ich eine Variable log. Die musste auch umbenannt werden damit's wieder funktioniert.
                                        @homoran sagte: nur noch mit timeout of x msec exceeded und nicht mehr die ganzen null Meldungen
                                        #92
                                        @paul53 DANKE!
                                        den Block hab ich gesucht.
                                        Das Pulldown habe ich natürlich nicht gesehen.
                                        hatte gestern abend den Timeout auf 4000 gestellt.
                                        Seitdem kein Fehler mehr.
                                        Sehe gerade dass im Original ein Timeout von 3000 steht.
                                        • wolfi913W wolfi913
                                          @tt-tom
                                          #93
                                          @wolfi913 sagte in Hilfe für Javascript Legastheniker und js v8.3.x:
                                          Hab zwar auch keine Ahnung, kann mir aber nicht vorstellen dassdie variable data bei response.data mitmischen sollte.
                                          T O 2 Antworten Letzte Antwort
