  4. JavaScript
  5. Hilfe für Javascript Legastheniker und js v8.3.x
    6.3k
104 Beiträge 8 Kommentatoren 15.8k Aufrufe 7 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @tt-tom
    2024-05-26 22:46:45.108  - error: javascript.0 (3416) script.js.common._Tests.Test_17 compile failed:
    at script.js.common._Tests.Test_17:111
    2024-05-26 22:46:45.109  - error: javascript.0 (3416)         };
    2024-05-26 22:46:45.109  - error: javascript.0 (3416)         ^
    2024-05-26 22:46:45.109  - error: javascript.0 (3416) SyntaxError: missing ) after argument list
    2024-05-26 22:46:45.109  - error: javascript.0 (3416)     at new Script (node:vm:99:7)
    2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1917:21)
    2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2183:37)
    2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at /opt/iobroker/node_modules/iobroker.javascript/main.js:2281:17
    2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1703:17)
    2024-05-26 22:46:45.111  - error: javascript.0 (3416)     at process.processImmediate (node:internal/timers:478:21)
    2024-05-26 22:46:46.955  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
    TT-Tom
    #76
    @ofbeqnpolkkl6mby5e13
    da fehlen irgendwo noch Klammern, bin grad mal am suchen
    Edit: probiere mal das jetzt.
    function updateMuell() {
        var options = 'https://mymuell.jumomind.com/webservice.php?idx=termins&city_id=' + city_id + '&area_id=' + area_id + '&ws=3'
        httpGet(options, (error, response) => {
            console.log(response.statusCode);
            console.log(response.data);
            if (!error && response.statusCode == 200) {
                var info = JSON.parse(response.data);  // info ist ein Objekt
                if (info[0].Ack === 'Success') {
                    var data = info[0]._data;  // xy ist eine Eigenschaft des Objektes info
                    let counter = 0;
                    const date = (new Date())
                    const todayStr = date.getFullYear() + "-" + ('00' + (date.getMonth() + 1)).slice(-2) + "-" + ('00' + date.getDate()).slice(-2)
                    log(todayStr);
                    data.forEach((v, i) => {
                        if (todayStr < v.cal_date && counter <= numberOfEntries) {
                            const basePath = instanz + '.' + ('000' + counter).slice(-3);
                            log(v.cal_date + ' -> ' + basePath, 'debug');
                            // States erstellen
                            extendObject(basePath, {
                                type: "channel",
                                common: {
                            }, function (err) {
                                if (err) {
                                    log('could not create device: ', 'warn');
                                    return;
                            createState(basePath + '.date', v.cal_date_normal, {
                                desc: 'Datum der Abholung',
                                type: 'string',
                                read: true,
                                write: false
                                setState(basePath + '.date', v.cal_date_normal, true);
                            createState(basePath + '.desc', baseData[v.cal_garbage_type].title, {
                                desc: 'Beschreibung der Abholung',
                                type: 'string',
                                read: true,
                                write: false
                                setState(basePath + '.desc', baseData[v.cal_garbage_type].title, true);
                            createState(basePath + '.color', {
                                desc: 'Farbe',
                                type: 'string',
                                role: 'level.color',
                                read: true,
                                write: false
                                setState(basePath + '.color', baseData[v.cal_garbage_type].color, true);
                            counter++;
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    O 1 Antwort Letzte Antwort
    • T TT-Tom
                      let counter = 0;
                      log(todayStr);
                              // States erstellen
                                  type: "channel",
                                  common: {
                              }, function (err) {
                                  if (err) {
                                      return;
                                  type: 'string',
                                  read: true,
                                  write: false
                                  type: 'string',
                                  read: true,
                                  write: false
                                  desc: 'Farbe',
                                  type: 'string',
                                  read: true,
                                  write: false
                              counter++;
      O Abwesend
      O Abwesend
      #77
      @tt-tom
      Danke, es kommt kein Fehler mehr! Eine Objektstruktur wird weiterhin nicht angelegt.
        @tt-tom
        TT-Tom
        #78
        okay dann brauche ich mal das komplette Log vom Start das Script. Muss mir mal die Daten ansehen, die da kommen.
        Gruß Tom
        Public Transport
        • T TT-Tom
          O Abwesend
          O Abwesend
          #79
          @tt-tom
          2024-05-26 23:06:36.838  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
          2024-05-26 23:06:36.850  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
          2024-05-26 23:06:36.925  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 200
          2024-05-26 23:06:36.926  - info: javascript.0 (3416) script.js.common._Tests.Test_17: [{"title":"Bioabfall","name":"SZ_BIO","_name":"SZ_BIO","color":"a52a2a"},{"title":"Gelber Sack","name":"SZ_G","_name":"SZ_G","color":"FFFF00"},{"title":"Altpapier (120l, 240l)","name":"SZ_P","_name":"SZ_P","color":"2fc2e8"},{"title":"Restabfall (bis 240l)","name":"SZ_R","_name":"SZ_R","color":"2F4F4F"},{"title":"Weihnachtsbaum","name":"SZ_W","_name":"SZ_W","color":"36b515"}]
          2024-05-26 23:14:15.038  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
            @tt-tom
            TT-Tom
            #80
            der erste teil stimmt auch nicht bzw. ist unlogisch. Hast du noch das original?
            Gruß Tom
            Public Transport
            • T TT-Tom
              O Abwesend
              O Abwesend
              #81
              @tt-tom
              https://github.com/volkerrichert/ioBroker.mymuell/blob/master/myMuell.iob
                @tt-tom
                TT-Tom
                #82
                okay, muss den Anfang auch nochmal anpassen. Da ist etwas verrutscht ;)
                httpGet('https://mymuell.jumomind.com/mmapp/api.php?r=trash&city_id=' + city_id + '&area_id=' + area_id, { timeout: 2000 }, (error, response) => {
                       var data = JSON.parse(response.data);  // info ist ein Objekt
                               baseData[v._name] = v;
                   updateMuell();
                   } else {
                       console.error(error);
                Gruß Tom
                Public Transport
                • T TT-Tom
                     updateMuell();
                     } else {
                  O Abwesend
                  O Abwesend
                  #83
                  @tt-tom
                  Ah, jetzt wird die Objektstruktur angelegt! Vielen Dank!
                  Aber, im Original werden keine Daten auf der Konsole ausgegeben. Woran liegt das?
                    @tt-tom
                    TT-Tom
                    #84
                    im Script sind diese Zeilen für die Ausgabe
                    ersetze sie mit diesen Zeilen
                    if (logging) console.log(response.statusCode);
                    if (logging) console.log(response.data);
                    dann kommt die Meldung nur, wenn du logging auf true setzt
                    const logging = true;
                    Gruß Tom
                    Public Transport
                    O 2 Antworten Letzte Antwort
                    • T TT-Tom
                      O Abwesend
                      O Abwesend
                      #85
                      @tt-tom
                      Aber das ist im Original doch auch nicht so und im Original werden im Normalfall keine Meldungen ausgegeben.
                      • T TT-Tom
                        O Abwesend
                        O Abwesend
                        #86
                        @tt-tom
                        Ach sorry, das hatte ich ja selbst hinzugefügt.
                          @tt-tom
                          TT-Tom
                          #87
                          so Feierabend für heute, Script läuft soweit?
                          Gruß Tom
                          Public Transport
                          • T TT-Tom
                            O Abwesend
                            O Abwesend
                            #88
                            @tt-tom
                            Ich weiß nicht...
                            2024-05-26 23:37:50.481  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
                            2024-05-26 23:37:50.492  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                            2024-05-26 23:37:50.656  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 200
                            2024-05-26 23:37:50.656  - info: javascript.0 (3416) script.js.common._Tests.Test_17: [{"Ack":"Success","id":"mm_termins","messages":[{"status":"OK","msg":"getTermins"}],"_data":[{"cal_id":"128222324","cal_date":"2024-01-03","cal_date_normal":"03.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222316","cal_date":"2024-01-03","cal_date_normal":"03.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222376","cal_date":"2024-01-09","cal_date_normal":"09.01.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222387","cal_date":"2024-01-10","cal_date_normal":"10.01.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128222464","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_W","cal_comment":""},{"cal_id":"128222458","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222450","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222532","cal_date":"2024-01-23","cal_date_normal":"23.01.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222604","cal_date":"2024-01-30","cal_date_normal":"30.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222596","cal_date":"2024-01-30","cal_date_normal":"30.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222645","cal_date":"2024-02-06","cal_date_normal":"06.02.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222718","cal_date":"2024-02-13","cal_date_normal":"13.02.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222710","cal_date":"2024-02-13","cal_date_normal":"13.02.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222726","cal_date":"2024-02-14","cal_date_normal":"14.02.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128222767","cal_date":"2024-02-20","cal_date_normal":"20.02.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222841","cal_date":"2024-02-27","cal_date_normal":"27.02.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222833","cal_date":"2024-02-27","cal_date_normal":"27.02.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222890","cal_date":"2024-03-05","cal_date_normal":"05.03.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222963","cal_date":"2024-03-12","cal_date_normal":"12.03.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222955","cal_date":"2024-03-12","cal_date_normal":"12.03.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222971","cal_date":"2024-03-13","cal_date_normal":"13.03.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223012","cal_date":"2024-03-19","cal_date_normal":"19.03.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223086","cal_date":"2024-03-25","cal_date_normal":"25.03.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223078","cal_date":"2024-03-25","cal_date_normal":"25.03.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223135","cal_date":"2024-04-03","cal_date_normal":"03.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223208","cal_date":"2024-04-09","cal_date_normal":"09.04.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223200","cal_date":"2024-04-09","cal_date_normal":"09.04.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223216","cal_date":"2024-04-10","cal_date_normal":"10.04.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223257","cal_date":"2024-04-16","cal_date_normal":"16.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223331","cal_date":"2024-04-23","cal_date_normal":"23.04.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223323","cal_date":"2024-04-23","cal_date_normal":"23.04.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223380","cal_date":"2024-04-30","cal_date_normal":"30.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223453","cal_date":"2024-05-07","cal_date_normal":"07.05.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223445","cal_date":"2024-05-07","cal_date_normal":"07.05.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223461","cal_date":"2024-05-08","cal_date_normal":"08.05.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223502","cal_date":"2024-05-14","cal_date_normal":"14.05.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223576","cal_date":"2024-05-22","cal_date_normal":"22.05.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223568","cal_date":"2024-05-22","cal_date_normal":"22.05.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223625","cal_date":"2024-05-28","cal_date_normal":"28.05.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223689","cal_date":"2024-06-04","cal_date_normal":"04.06.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223681","cal_date":"2024-06-04","cal_date_normal":"04.06.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223739","cal_date":"2024-06-11","cal_date_normal":"11.06.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223748","cal_date":"2024-06-12","cal_date_normal":"12.06.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223811","cal_date":"2024-06-18","cal_date_normal":"18.06.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223803","cal_date":"2024-06-18","cal_date_normal":"18.06.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223862","cal_date":"2024-06-25","cal_date_normal":"25.06.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223934","cal_date":"2024-07-02","cal_date_normal":"02.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223926","cal_date":"2024-07-02","cal_date_normal":"02.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223984","cal_date":"2024-07-09","cal_date_normal":"09.07.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223993","cal_date":"2024-07-10","cal_date_normal":"10.07.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224056","cal_date":"2024-07-16","cal_date_normal":"16.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224048","cal_date":"2024-07-16","cal_date_normal":"16.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224107","cal_date":"2024-07-23","cal_date_normal":"23.07.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224179","cal_date":"2024-07-30","cal_date_normal":"30.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224171","cal_date":"2024-07-30","cal_date_normal":"30.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224220","cal_date":"2024-08-06","cal_date_normal":"06.08.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224293","cal_date":"2024-08-13","cal_date_normal":"13.08.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224285","cal_date":"2024-08-13","cal_date_normal":"13.08.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224301","cal_date":"2024-08-14","cal_date_normal":"14.08.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224342","cal_date":"2024-08-20","cal_date_normal":"20.08.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224416","cal_date":"2024-08-27","cal_date_normal":"27.08.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224408","cal_date":"2024-08-27","cal_date_normal":"27.08.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224465","cal_date":"2024-09-03","cal_date_normal":"03.09.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224538","cal_date":"2024-09-10","cal_date_normal":"10.09.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224530","cal_date":"2024-09-10","cal_date_normal":"10.09.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224546","cal_date":"2024-09-11","cal_date_normal":"11.09.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224587","cal_date":"2024-09-17","cal_date_normal":"17.09.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224661","cal_date":"2024-09-24","cal_date_normal":"24.09.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224653","cal_date":"2024-09-24","cal_date_normal":"24.09.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224704","cal_date":"2024-10-01","cal_date_normal":"01.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224777","cal_date":"2024-10-08","cal_date_normal":"08.10.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224769","cal_date":"2024-10-08","cal_date_normal":"08.10.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224785","cal_date":"2024-10-09","cal_date_normal":"09.10.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224826","cal_date":"2024-10-15","cal_date_normal":"15.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224900","cal_date":"2024-10-22","cal_date_normal":"22.10.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224892","cal_date":"2024-10-22","cal_date_normal":"22.10.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224949","cal_date":"2024-10-29","cal_date_normal":"29.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225013","cal_date":"2024-11-05","cal_date_normal":"05.11.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225005","cal_date":"2024-11-05","cal_date_normal":"05.11.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225063","cal_date":"2024-11-12","cal_date_normal":"12.11.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225072","cal_date":"2024-11-13","cal_date_normal":"13.11.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128225135","cal_date":"2024-11-19","cal_date_normal":"19.11.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225127","cal_date":"2024-11-19","cal_date_normal":"19.11.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225186","cal_date":"2024-11-26","cal_date_normal":"26.11.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225258","cal_date":"2024-12-03","cal_date_normal":"03.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225250","cal_date":"2024-12-03","cal_date_normal":"03.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225308","cal_date":"2024-12-10","cal_date_normal":"10.12.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225317","cal_date":"2024-12-11","cal_date_normal":"11.12.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128225380","cal_date":"2024-12-17","cal_date_normal":"17.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225372","cal_date":"2024-12-17","cal_date_normal":"17.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225431","cal_date":"2024-12-23","cal_date_normal":"23.12.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225503","cal_date":"2024-12-31","cal_date_normal":"31.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225495","cal_date":"2024-12-31","cal_date_normal":"31.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225555","cal_date":"2025-01-07","cal_date_normal":"07.01.2025","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225566","cal_date":"2025-01-08","cal_date_normal":"08.01.2025","cal_garbage_type":"SZ_P","cal_comment":""}],"_extra":[]}]
                            2024-05-26 23:37:50.657  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 2024-05-26
                            2024-05-26 23:37:55.515  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.000.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.517  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.001.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.519  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.002.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.520  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.003.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.521  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.004.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.523  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.005.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.524  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.006.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.525  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.007.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.526  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.008.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.528  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.009.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.529  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.010.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.530  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.011.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.541  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.012.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.543  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.013.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.544  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.014.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.546  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.015.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.547  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.016.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.548  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.017.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.549  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.018.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.551  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.019.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.552  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.020.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.553  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.021.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.555  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.022.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.556  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.023.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.558  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.024.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.559  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.025.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.560  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.026.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.562  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.027.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.563  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.028.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.564  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.029.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.566  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.030.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.568  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.031.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.570  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.032.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.571  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.033.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.573  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.034.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.574  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.035.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.575  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.036.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.577  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.037.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.578  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.038.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.579  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.039.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.581  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.040.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.582  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.041.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.583  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.042.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.584  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.043.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.586  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.044.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.587  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.045.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.588  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.046.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.590  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.047.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.591  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.048.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.592  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.049.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.602  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.050.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.603  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.051.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.605  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.052.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.606  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.053.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.607  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.054.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.608  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.055.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:55.669  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.056.color" has been written without ack-flag with value "null"
                            2024-05-26 23:37:59.691  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
                              @tt-tom
                              Ich weiß nicht...
                              TT-Tom
                              #89
                              sende bitte nochmal jetzt das komplette Script, ich sehe mir das morgenfrüh an. da Passt etwas mit dem erstellen des color State nicht.
                              Gruß Tom
                              Public Transport
                              • T TT-Tom
                                O Abwesend
                                O Abwesend
                                #90
                                @tt-tom
                                Okay, vielen Dank!
                                const city_id = 66005;
                                const area_id = 2800;
                                const logging = false;
                                const name = 'Müllabfuhr';
                                const numberOfEntries = 69;
                                const instanz = '0_userdata.' + instance + '.muell-test';
                                if (logging) log('starting muell.' + instanz);
                                extendObject(instanz, {
                                       type: "device",
                                       common: {
                                   }, function (err) {
                                       if (err) {
                                           return;
                                let baseData = {};
                                // query names first
                                  updateMuell();
                                  } else {
                                schedule('{"time":{"exactTime":true,"start":"12:17"},"period":{"days":1}}', updateMuell);
                                               let counter = 0;
                                               log(todayStr);
                                                       // States erstellen
                                                           type: "channel",
                                                           common: {
                                                       }, function (err) {
                                                           if (err) {
                                                               return;
                                                           type: 'string',
                                                           read: true,
                                                           write: false
                                                           type: 'string',
                                                           read: true,
                                                           write: false
                                                           desc: 'Farbe',
                                                           type: 'string',
                                                           read: true,
                                                           write: false
                                                       counter++;
                                wolfi913W T 2 Antworten Letzte Antwort
                                  @tt-tom
                                  Okay, vielen Dank!
                                         type: "device",
                                         common: {
                                     }, function (err) {
                                         if (err) {
                                             return;
                                  let baseData = {};
                                    updateMuell();
                                    } else {
                                                 let counter = 0;
                                                 log(todayStr);
                                                         // States erstellen
                                                             type: "channel",
                                                             common: {
                                                         }, function (err) {
                                                             if (err) {
        return;
                                                             type: 'string',
                                                             read: true,
                                                             write: false
                                                             type: 'string',
                                                             read: true,
                                                             write: false
                                                             desc: 'Farbe',
                                                             type: 'string',
                                                             read: true,
                                                             write: false
                                                         counter++;
                                  wolfi913W Online
                                  wolfi913W Online
                                  wolfi913
                                  #91
                                  @tt-tom
                                  Nur eine Idee von jemandem der sich aber mit JS nicht auskennt. Daher schlagt mich nicht, falls ich totalen Unsinn schreibe.
                                  Evtl. liegt's an der Variable var data im Ursprungsscript (z.B. Zeile 51). Möglicherweise funktioniert das nach dem Update auf V8.3.1 nicht mehr. Hatte ein ähnliches Problem in einem Blockly. Da hatte ich eine Variable log. Die musste auch umbenannt werden damit's wieder funktioniert.
                                    @homoran sagte: nur noch mit timeout of x msec exceeded und nicht mehr die ganzen null Meldungen
                                    #92
                                    @paul53 DANKE!
                                    den Block hab ich gesucht.
                                    Das Pulldown habe ich natürlich nicht gesehen.
                                    hatte gestern abend den Timeout auf 4000 gestellt.
                                    Seitdem kein Fehler mehr.
                                    Sehe gerade dass im Original ein Timeout von 3000 steht.
                                    • wolfi913W wolfi913
                                      @tt-tom
                                      #93
                                      @wolfi913 sagte in Hilfe für Javascript Legastheniker und js v8.3.x:
                                      Hab zwar auch keine Ahnung, kann mir aber nicht vorstellen dassdie variable data bei response.data mitmischen sollte.
                                      T O 2 Antworten Letzte Antwort
                                        @tt-tom
                                        Okay, vielen Dank!
                                               type: "device",
                                               common: {
                                           }, function (err) {
                                               if (err) {
                                                   return;
                                        let baseData = {};
                                          updateMuell();
                                          } else {
                                                       let counter = 0;
                                                       log(todayStr);
                                                               // States erstellen
        type: "channel",
        common: {
                                                               }, function (err) {
        if (err) {
        return;
        type: 'string',
        read: true,
        write: false
        type: 'string',
        read: true,
        write: false
        desc: 'Farbe',
        type: 'string',
        read: true,
        write: false
                                                               counter++;
                                        TT-Tom
                                        #94
                                        bei mir kommen die Meldungen auch, aber nur beim anlegen der States, irgendwie verschluckt er sich da mit den Daten. Wenn die States alle angelegt sind bekomme ich dann keine Meldungen mehr. Werde mal die Stateserstellung mir nochmal genauer ansehen, kann aber etwas dauern.
                                        Gruß Tom
                                        Public Transport
                                          TT-Tom
                                          #95
                                          Nein daran liegt es nicht. Die Meldungen kommen nur beim anlegen der States. Danach läuft es bei mir ohne Meldungen weiter.
                                          Gruß Tom
                                          Public Transport
