  4. Daten aus der Fritzbox visualisieren
113 Beiträge 20 Kommentatoren 29.2k Aufrufe 23 Beobachtet
  • Ro75R Ro75
    @dr-pie sagte in Daten aus der Fritzbox visualisieren:
    leider gibt der Adapter von AVM (tr064) die erforderlichen Daten nicht preis
    das stimmt so definitiv nicht. Der tr-64 Adapter kann dir alles liefern. Es ist immer nur die Frage wie. Versuche es mal so:
    const NewByteReceiveRate    = '0_userdata.0.FritzBox.NewByteReceiveRate';
    const NewByteSendRate       = '0_userdata.0.FritzBox.NewByteSendRate';
    const L1DownMaxRate         = '0_userdata.0.FritzBox.Layer1DownstreamMaxBitRate';
    const L1UpMaxRate           = '0_userdata.0.FritzBox.Layer1UpstreamMaxBitRate';
    const ReceiveR              = '0_userdata.0.FritzBox.Charts.Receive';
    const SendR                 = '0_userdata.0.FritzBox.Charts.Send';
    createState(NewByteReceiveRate, 0, {type: 'number', read: true, write: true});
    createState(NewByteSendRate, 0, {type: 'number', read: true, write: true});
    createState(L1DownMaxRate, 0, {type: 'number', read: true, write: true});
    createState(L1UpMaxRate, 0, {type: 'number', read: true, write: true});
    createState(ReceiveR, 0, {type: 'number', unit: 'MBit/s', read: true, write: true});
    createState(SendR, 0, {type: 'number', unit: 'MBit/s', read: true, write: true});
    schedule('*/6 * * * * *', function Aktualisierung() {
        setState('tr-064.0.states.command', '{"service": "urn:dslforum-org:service:WANCommonInterfaceConfig:1","action": "X_AVM-DE_GetOnlineMonitor","params": {"NewSyncGroupIndex": 0}}');
        var value=getState('tr-064.0.states.commandResult').val;
        if (value.indexOf('NewTotalNumber') == 2) {
            var obj = JSON.parse(value);
            var DownStream = obj.Newds_current_bps;
            var UpStream = obj.Newus_current_bps;
            var ds = DownStream.split(",");
            var us = UpStream.split(",");
            var wds    =  ds[0];
            var wus    =  us[0];
            setState(NewByteReceiveRate, wds*1);
            setState(NewByteSendRate, wus*1);
            setState(ReceiveR, Math.round((wds*0.000008)*100)/100);
            setState(SendR, Math.round((wus*0.000008)*100)/100);
            setState(L1DownMaxRate, obj.Newmax_ds*8);
            setState(L1UpMaxRate, obj.Newmax_us*8);
    Damit hat man einmal die "Basisdaten". Mit einigen weiteren Codezeilen kann man auch erfahren wie groß der Traffic ist (down / up). Mit bissel Spielerei kann man so den Traffic für den Tag, die Woche, den Monat errechnen, speichern und visualisieren.
    Alles über den TR-64 Adapter.
    Ro75.
    Dr.PieD
    Dr.PieD
    Dr.Pie
    @ro75 sagte in Daten aus der Fritzbox visualisieren:
    Ro75.
    Magst du die Visualisierung zur Verfügung stellen ?
    L 1 Antwort Letzte Antwort
    • Ro75R Ro75
      @haselchen sagte in Daten aus der Fritzbox visualisieren:
      An was für einem Anschluss ?
      Was meinst du damit genau?
      Ro75.
      haselchenH
      haselchenH
      haselchen
      @ro75
      Naja, DSL oder Glasfaser
      • Ro75R
        Ro75R
        Ro75
        schrieb am zuletzt editiert von Ro75
        @haselchen Dann ist es DSL.
        Ro75.
        EDIT: In der Dokumentation von AVM finde ich jetzt nicht eine expliziete Unterscheidung zwischen DSL und Glasfaser.
        Probiere den Code einfach aus und dann berichte mal.
        Ro75.
        SERVER = Proxmox VE 9, Core Ultra 5, 64GB, 2x2TB NVMe ZFS, 6 USB-SSDs, USV ** ioBroker+Redis, MariaDB, Pi-hole, Plex, Samba, ClamAV, Docker (paperless-ngx, PhotoPrism) ** Backup: PBS auf Intel NUC *** FB 7490, FritzDect 200/301/440, ConBee II, Aqara, NOUS A1Z/A1T, Hue *** VIS = Intel NUC 8GB + 24" Touch
        • Dr.PieD Dr.Pie
          Ro75.
          L
          L
          ludino
          schrieb am zuletzt editiert von ludino
          @Ro75
          Hi Habe mir dein Script mal installiert, und es klappt super. Leider weiß ich nicht wie du die Vis gemacht hast besonders intressiert mich die darstellung der letzten 10 tage und der letzten 12 Monaten.
          Würde du es mir verraten?
          Ludino
          • Ro75R Ro75
                    var wds    =  ds[0];
                    var wus    =  us[0];
            Ro75.
            G
            G
            Galen
            @ro75 Vielen Dank!
            Könntest du noch den Codeteil posten, der das genutzte Datenvolumen berechnet und speichert?
            Könnte man evtl. noch die derzeitige IP und den Status der Leitung (Verbunden oder getrennt) aus den Daten auslesen?
            Dr.PieD 1 Antwort Letzte Antwort
            • G Galen
              @ro75 Vielen Dank!
              Dr.PieD
              Dr.PieD
              Dr.Pie
              bei mir scheint nicht zu funktionieren:
              E 1 Antwort Letzte Antwort
              • Dr.PieD Dr.Pie
                E
                E
                emil70
                @dr-pie
                Hast du den Adapter tr-064 drauf?
                gruss emil70
                iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
                • E emil70
                  @dr-pie
                  Dr.PieD
                  Dr.PieD
                  Dr.Pie
                  @emil70 ja ... 2 Instanzen
                  Ro75R 1 Antwort Letzte Antwort
                  • Dr.PieD Dr.Pie
                    Ro75R
                    Ro75R
                    Ro75
                    @dr-pie Was steht denn im DP "tr-064.0.states.commandResult"?
                    Ro75.
                    Dr.PieD D 2 Antworten Letzte Antwort
                    • Ro75R Ro75
                      Ro75.
                      Dr.PieD
                      Dr.PieD
                      Dr.Pie
                      @ro75 Ich habe das Script und die DP's mal gelöscht und wieder neu installiert ... nun scheint es zu funktionieren.
                      Ich hatte das schon mal das ich erst etwas wieder deinstallieren musste und neu installiert habe dann funktionierte es..
                      Komisch
                      • Ro75R Ro75
                                var wds    =  ds[0];
                                var wus    =  us[0];
                        Ro75.
                        B
                        B
                        babl
                        @ro75 Dein Script funktioniert gut, nur es haut mir die Protokolle voll mit den Ergebnissen der Abfragen, wie kann ich das denn in diesem Java Script ausschalten, sorry Javascript ist nicht meine Hauptsprache mache alles über blockly.
                        Ro75R HomoranH 2 Antworten Letzte Antwort
                        • B babl
                          Ro75R
                          Ro75R
                          Ro75
                          @babl das Skript selbst enthält keinerlei LOG-Ausgaben. Eventuell musst du bei dem JS-Adapter die LOG-Stufe ändern. Ggfs. von Info auf Error.
                          Ro75.
                          • B babl
                            @babl sagte in Daten aus der Fritzbox visualisieren:
                            dann zeig mal was genau im log steht
                              B
                              B
                              babl
                              @homoran @Ro75
                              2024-05-26 10:05:06.055 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729,2052,638,1041","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091,1876,795,850","Newprio_realtime_bps":"4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490,1313,194,142","Newprio_high_bps":"238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53,106,68,48","Newprio_default_bps":"810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548,457,533,660","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                              2024-05-26 10:05:12.114 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729,2052","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091,1876","Newprio_realtime_bps":"295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490,1313","Newprio_high_bps":"48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53,106","Newprio_default_bps":"669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548,457","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                              2024-05-26 10:05:18.054 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091","Newprio_realtime_bps":"377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490","Newprio_high_bps":"137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53","Newprio_default_bps":"557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                              2024-05-26 10:05:24.097 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321","Newprio_realtime_bps":"408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553","Newprio_high_bps":"15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63","Newprio_default_bps":"622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                              2024-05-26 10:05:30.136 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1041,955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"811,1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728","Newprio_realtime_bps":"100,408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228","Newprio_high_bps":"46,15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46","Newprio_default_bps":"665,622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                              2024-05-26 10:05:34.307 - info: admin.0 (3910344) ==> Connected system.user.admin from ::ffff:192.168.157.20
                              2024-05-26 10:05:36.080 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1081,1041,955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"842,811,1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801","Newprio_realtime_bps":"193,100,408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501","Newprio_high_bps":"98,46,15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70","Newprio_default_bps":"551,665,622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                              2024-05-26 10:05:38.586 - info: javascript.0 (3935439) Stopping script script.js.common.FritzBox.Datenmenge
                              • B
                                B
                                babl
                                @Ro75 @Homoran Auch wenn ich die Logstufe von Info zu Error ändere kommen die gleichen Infos im Log an.
                                Habe gestern das System upgedatet auch den Java Script Adapter auf die 8.3.1
                                Vielleicht ist es ein "Bug"
                                Node.js: v18.20.3
                                NPM: 10.7.0
                                Ro75R DJMarc75D 2 Antworten Letzte Antwort
                                • B babl
                                  Node.js: v18.20.3
                                  NPM: 10.7.0
                                  Ro75R
                                  Ro75R
                                  Ro75
                                  @babl also im von dir geposteten LOG sehe ich "Info". Mal bitte die LOG-Stufe vom Adapter zeigen und dann nochmal das LOG.
                                  Ro75.
                                  • B babl
                                    Node.js: v18.20.3
                                    NPM: 10.7.0
                                    DJMarc75D
                                    DJMarc75D
                                    DJMarc75
                                    @babl
                                    Das sind LOGS vom TR064 Adapter nicht vom JS.
                                    Lehrling seit 1975 !!!
                                    • DJMarc75D DJMarc75
                                      @babl
                                      B
                                      B
                                      babl
                                      @djmarc75, @Ro75, @Homoran genau das wars, die hat nicht der Java Script Adapter ausgeliefert sondern der tr-064 Adapter, habe diesen auf "Warn" gestellt in der Log Stufe und alles ist gut, danke euch.
                                      Da wäre ich jetzt nie draufgekommen, wer lesen kann ist einfach klar im Vorteil.
                                      Danke euch
                                      • B babl
                                        Danke euch
                                        Deswegen immer alles zeigen!
                                        • Ro75R Ro75
                                                  var wds    =  ds[0];
                                                  var wus    =  us[0];
                                          Ro75.
                                          K
                                          K
                                          Kuddel
                                          @ro75 danke für das Basis-Skript. Funzt bei mir wie es soll:
                                          Wie werte ich jetzt den Traffic / Tag aus?
                                          Und könntest du deine VIS evtl. teilen?
                                          Vielen Dank ;-)
                                          84.2k
