  4. Daten aus der Fritzbox visualisieren
113 Beiträge 20 Kommentatoren 29.0k Aufrufe 23 Beobachtet
  • Ro75R Ro75
    @dr-pie sagte in Daten aus der Fritzbox visualisieren:
    leider gibt der Adapter von AVM (tr064) die erforderlichen Daten nicht preis
    das stimmt so definitiv nicht. Der tr-64 Adapter kann dir alles liefern. Es ist immer nur die Frage wie. Versuche es mal so:
    const NewByteReceiveRate    = '0_userdata.0.FritzBox.NewByteReceiveRate';
    const NewByteSendRate       = '0_userdata.0.FritzBox.NewByteSendRate';
    const L1DownMaxRate         = '0_userdata.0.FritzBox.Layer1DownstreamMaxBitRate';
    const L1UpMaxRate           = '0_userdata.0.FritzBox.Layer1UpstreamMaxBitRate';
    const ReceiveR              = '0_userdata.0.FritzBox.Charts.Receive';
    const SendR                 = '0_userdata.0.FritzBox.Charts.Send';
    createState(NewByteReceiveRate, 0, {type: 'number', read: true, write: true});
    createState(NewByteSendRate, 0, {type: 'number', read: true, write: true});
    createState(L1DownMaxRate, 0, {type: 'number', read: true, write: true});
    createState(L1UpMaxRate, 0, {type: 'number', read: true, write: true});
    createState(ReceiveR, 0, {type: 'number', unit: 'MBit/s', read: true, write: true});
    createState(SendR, 0, {type: 'number', unit: 'MBit/s', read: true, write: true});
    schedule('*/6 * * * * *', function Aktualisierung() {
        setState('tr-064.0.states.command', '{"service": "urn:dslforum-org:service:WANCommonInterfaceConfig:1","action": "X_AVM-DE_GetOnlineMonitor","params": {"NewSyncGroupIndex": 0}}');
        var value=getState('tr-064.0.states.commandResult').val;
        if (value.indexOf('NewTotalNumber') == 2) {
            var obj = JSON.parse(value);
            var DownStream = obj.Newds_current_bps;
            var UpStream = obj.Newus_current_bps;
            var ds = DownStream.split(",");
            var us = UpStream.split(",");
            var wds    =  ds[0];
            var wus    =  us[0];
            setState(NewByteReceiveRate, wds*1);
            setState(NewByteSendRate, wus*1);
            setState(ReceiveR, Math.round((wds*0.000008)*100)/100);
            setState(SendR, Math.round((wus*0.000008)*100)/100);
            setState(L1DownMaxRate, obj.Newmax_ds*8);
            setState(L1UpMaxRate, obj.Newmax_us*8);
    Damit hat man einmal die "Basisdaten". Mit einigen weiteren Codezeilen kann man auch erfahren wie groß der Traffic ist (down / up). Mit bissel Spielerei kann man so den Traffic für den Tag, die Woche, den Monat errechnen, speichern und visualisieren.
    Alles über den TR-64 Adapter.
    Ro75.
    B
    B
    babl
    @ro75 Dein Script funktioniert gut, nur es haut mir die Protokolle voll mit den Ergebnissen der Abfragen, wie kann ich das denn in diesem Java Script ausschalten, sorry Javascript ist nicht meine Hauptsprache mache alles über blockly.
    Ro75R HomoranH 2 Antworten Letzte Antwort
    • B babl
      Ro75R
      Ro75R
      Ro75
      @babl das Skript selbst enthält keinerlei LOG-Ausgaben. Eventuell musst du bei dem JS-Adapter die LOG-Stufe ändern. Ggfs. von Info auf Error.
      Ro75.
      • B babl
        @babl sagte in Daten aus der Fritzbox visualisieren:
        dann zeig mal was genau im log steht
          B
          B
          babl
          @homoran @Ro75
          2024-05-26 10:05:06.055 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729,2052,638,1041","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091,1876,795,850","Newprio_realtime_bps":"4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490,1313,194,142","Newprio_high_bps":"238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53,106,68,48","Newprio_default_bps":"810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548,457,533,660","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-05-26 10:05:12.114 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729,2052","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091,1876","Newprio_realtime_bps":"295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490,1313","Newprio_high_bps":"48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53,106","Newprio_default_bps":"669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548,457","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-05-26 10:05:18.054 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091","Newprio_realtime_bps":"377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490","Newprio_high_bps":"137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53","Newprio_default_bps":"557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-05-26 10:05:24.097 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321","Newprio_realtime_bps":"408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553","Newprio_high_bps":"15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63","Newprio_default_bps":"622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-05-26 10:05:30.136 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1041,955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"811,1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728","Newprio_realtime_bps":"100,408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228","Newprio_high_bps":"46,15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46","Newprio_default_bps":"665,622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-05-26 10:05:34.307 - info: admin.0 (3910344) ==> Connected system.user.admin from ::ffff:192.168.157.20
          2024-05-26 10:05:36.080 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1081,1041,955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"842,811,1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801","Newprio_realtime_bps":"193,100,408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501","Newprio_high_bps":"98,46,15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70","Newprio_default_bps":"551,665,622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-05-26 10:05:38.586 - info: javascript.0 (3935439) Stopping script script.js.common.FritzBox.Datenmenge
          • B
            B
            babl
            @Ro75 @Homoran Auch wenn ich die Logstufe von Info zu Error ändere kommen die gleichen Infos im Log an.
            Habe gestern das System upgedatet auch den Java Script Adapter auf die 8.3.1
            Vielleicht ist es ein "Bug"
            Node.js: v18.20.3
            NPM: 10.7.0
            Ro75R DJMarc75D 2 Antworten Letzte Antwort
            • B babl
              Node.js: v18.20.3
              NPM: 10.7.0
              Ro75R
              Ro75R
              Ro75
              @babl also im von dir geposteten LOG sehe ich "Info". Mal bitte die LOG-Stufe vom Adapter zeigen und dann nochmal das LOG.
              Ro75.
              • B babl
                Node.js: v18.20.3
                NPM: 10.7.0
                DJMarc75D
                DJMarc75D
                DJMarc75
                @babl
                Das sind LOGS vom TR064 Adapter nicht vom JS.
                Lehrling seit 1975 !!!
                • DJMarc75D DJMarc75
                  @babl
                  B
                  B
                  babl
                  @djmarc75, @Ro75, @Homoran genau das wars, die hat nicht der Java Script Adapter ausgeliefert sondern der tr-064 Adapter, habe diesen auf "Warn" gestellt in der Log Stufe und alles ist gut, danke euch.
                  Da wäre ich jetzt nie draufgekommen, wer lesen kann ist einfach klar im Vorteil.
                  Danke euch
                  • B babl
                    Danke euch
                    Deswegen immer alles zeigen!
                    • Ro75R Ro75
                              var wds    =  ds[0];
                              var wus    =  us[0];
                      Ro75.
                      K
                      K
                      Kuddel
                      @ro75 danke für das Basis-Skript. Funzt bei mir wie es soll:
                      Wie werte ich jetzt den Traffic / Tag aus?
                      Und könntest du deine VIS evtl. teilen?
                      Vielen Dank ;-)
                      Ro75R 1 Antwort Letzte Antwort
                      • K Kuddel
                        Vielen Dank ;-)
                        Ro75R
                        Ro75R
                        Ro75
                        schrieb am zuletzt editiert von Ro75
                        @kuddel also die VIS leider nicht, da ich diese bereits komplett überarbeitet habe - habe mich jetzt doch mit Grafana angefreundet. Aber hier der Code für die summierten Tages- und Monatswerte (Traffic IN und OUT). Auswertung dann halt über Flot oder Grafana.
                        Der nachfolgende Code setzt voraus:
                        1. MYSQL + SQL-Adapter zur Protokollierung
                        2. UPNP-Adapter für Werte
                        3. TR-64-Adapter
                        4. Infux-Adapter (falls Weiterverarbeitung mit Grafana InfluxDB2 notwendig)
                        const Traffic_IN            = '0_userdata.0.FritzBox.Traffic.Traffic_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                        const Traffic_OUT           = '0_userdata.0.FritzBox.Traffic.Traffic_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                        const Traffic_Tag_IN        = '0_userdata.0.FritzBox.Traffic.Tag_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                        const Traffic_Tag_OUT       = '0_userdata.0.FritzBox.Traffic.Tag_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                        const Traffic_Monat_IN      = '0_userdata.0.FritzBox.Traffic.Monat_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                        const Traffic_Monat_OUT     = '0_userdata.0.FritzBox.Traffic.Monat_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                        // die oberen 6 DP müssen protokolliert werden!
                        const sTraffic_Monat_IN     = '0_userdata.0.FritzBox.Traffic.Traffic_Monat_IN';
                        const sTraffic_Monat_OUT    = '0_userdata.0.FritzBox.Traffic.Traffic_Monat_OUT';
                        createState(Traffic_IN, 0, {type: 'number', read: true, write: true});
                        createState(Traffic_OUT, 0, {type: 'number', read: true, write: true});
                        createState(Traffic_Tag_IN, 0, {type: 'number', read: true, write: true});
                        createState(Traffic_Tag_OUT, 0, {type: 'number', read: true, write: true});
                        createState(Traffic_Monat_IN, 0, {type: 'number', read: true, write: true});
                        createState(Traffic_Monat_OUT, 0, {type: 'number', read: true, write: true});
                        createState(sTraffic_Monat_IN, 0, {type: 'number', read: true, write: true});
                        createState(sTraffic_Monat_OUT, 0, {type: 'number', read: true, write: true});
                        var IPV4='';
                        var IPV4I='';
                        var tIN_NEW = 0;
                        var tIN_OLD = 0;
                        var tIN_DIFF = 0;
                        var tIN_SUM = 0;
                        var tOUT_NEW = 0;
                        var tOUT_OLD = 0;
                        var tOUT_DIFF = 0;
                        var tOUT_SUM = 0;
                        //Summierung der Tageswerte via SQL für Monatsergebnis
                        function TrafficlfdMonat() {
                            var Ergebnis=0;
                            const moment = require("moment");
                            let dateX=moment().format();
                            var Stunden = ((parseFloat(formatDate(dateX, "TT"))-1)*24)*-1;
                            sendTo('sql.0', 'query', 'SELECT id FROM iobroker.datapoints WHERE name="0_userdata.0.FritzBox.Traffic.Tag_IN"', function (result) {
                                if (result.error) {
                                    console.error(result.error);
                                } else {
                                    var now = new Date();
                                    now.setHours(Stunden);
                                    sendTo('sql.0', 'query', 'SELECT val FROM iobroker.ts_number WHERE ts >= ' + now.getTime() + ' AND id=' + result.result[0].id, function (result) {
                                        let text = result.result;
                                        for (let i = 0; i <= result.result.length-1; i++) {
                                            var vRow=text[i].val;
                                            Ergebnis=Ergebnis+parseFloat(vRow);
                                        Ergebnis=Ergebnis+getState(Traffic_IN).val;
                                        setState(sTraffic_Monat_IN, Ergebnis, true);
                            var ErgebnisII=0;
                            sendTo('sql.0', 'query', 'SELECT id FROM iobroker.datapoints WHERE name="0_userdata.0.FritzBox.Traffic.Tag_OUT"', function (result) {
                                if (result.error) {
                                } else {
                                            ErgebnisII=ErgebnisII+parseFloat(vRow);
                                        ErgebnisII=ErgebnisII+getState(Traffic_OUT).val;
                                        setState(sTraffic_Monat_OUT, ErgebnisII, true);
                        //um die Monatssumme "laufend" zu halten
                        schedule('*/2 * * * *', function Auswertung7() {
                            TrafficlfdMonat();
                        // Berechnung Empfangsrichtung
                        on({id: 'upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.TotalBytesReceived', change: 'any'}, function(dp) { //DP ggfs. anpassen
                            if (IPV4 == '') {
                                IPV4 = getState('tr-064.0.states.externalIP').val;
                            tIN_OLD=tIN_NEW;
                            tIN_NEW = parseFloat(dp.state.val);
                            if (tIN_OLD == 0) {
                                tIN_OLD=tIN_NEW;
                            } else {
                                if (IPV4 == getState('tr-064.0.states.externalIP').val) {
                                    tIN_DIFF=tIN_NEW-tIN_OLD;
                                } else {
                                    tIN_DIFF=tIN_NEW;
                                if (tIN_DIFF < 0) {
                                    tIN_DIFF=(4294967295-tIN_OLD)+tIN_NEW; //der Counter geht nur bis 4294967295, danach wieder ab 0 >> Berechnung
                                tIN_SUM=tIN_SUM+tIN_DIFF;
                                var oIn = parseFloat(getState(Traffic_IN).val);
                                setState(Traffic_IN, (oIn+tIN_DIFF)*1);
                        // Berechnung Senderichtung
                        on({id: 'upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.TotalBytesSent', change: 'any'}, function(dp) {
                            if (IPV4I == '') {
                                IPV4I = getState('tr-064.0.states.externalIP').val;
                            tOUT_OLD=tOUT_NEW;
                            tOUT_NEW = parseFloat(dp.state.val);
                            if (tOUT_OLD == 0) {
                                tOUT_OLD=tOUT_NEW;
                            } else {
                                if (IPV4I == getState('tr-064.0.states.externalIP').val) {
                                    tOUT_DIFF=tOUT_NEW-tOUT_OLD;
                                } else {
                                    tOUT_DIFF=tOUT_NEW;
                                if (tOUT_DIFF < 0) {
                                    tOUT_DIFF=(4294967295-tOUT_OLD)+tOUT_NEW; //der Counter geht nur bis 4294967295, danach wieder ab 0 >> Berechnung
                                tOUT_SUM=tOUT_SUM+tOUT_DIFF;
                                var oOUT = parseFloat(getState(Traffic_OUT).val);
                                setState(Traffic_OUT, (oOUT+tOUT_DIFF)*1);
                        //Tages und Monatswert in DP schreiben
                        schedule('30 59 23 * * *', function TrafficTagesWert() {
                            setState(Traffic_Tag_IN, getState(Traffic_IN).val);
                            setState(Traffic_Tag_OUT, getState(Traffic_OUT).val);
                            //Reset für neuen Tag
                            tOUT_SUM=0;
                            tIN_SUM=0;
                            setState(Traffic_IN, 0);
                            setState(Traffic_OUT, 0);
                            //herausfinden ob +- 10 Minuten immer noch den selben Monat oder letzter Tag im Monat ist
                            let datePlus=moment().add(10, 'm').format();
                            let dateMinus=moment().subtract(10, 'm').format();
                            if (formatDate(datePlus, "MM") != formatDate(dateMinus, "MM")) {
                                //jetzt ist noch der letzte Tag des Monat
                                TrafficlfdMonat();
                                setState(Traffic_Monat_IN, getState('0_userdata.0.FritzBox.Traffic.Traffic_Monat_IN').val, true);
                                setState(Traffic_Monat_OUT, getState('0_userdata.0.FritzBox.Traffic.Traffic_Monat_OUT').val, true);
                        HINWEIS: Tages- und Monatswerte in Bytes!
                        Der Code verrichtet seit gut 2 Jahren perfekt seinen Dienst. Viel Spaß.
                        Ro75.
                        K LongbowL 2 Antworten Letzte Antwort
                        • Ro75R Ro75
                          3. TR-64-Adapter
                          var IPV4='';
                          var IPV4I='';
                          var tIN_NEW = 0;
                          var tIN_OLD = 0;
                          var tIN_DIFF = 0;
                          var tIN_SUM = 0;
                          var tOUT_NEW = 0;
                          var tOUT_OLD = 0;
                          var tOUT_DIFF = 0;
                          var tOUT_SUM = 0;
                              var Ergebnis=0;
                                  if (result.error) {
                                  } else {
                              var ErgebnisII=0;
                                  if (result.error) {
                                  } else {
                              TrafficlfdMonat();
                              if (IPV4 == '') {
                              tIN_OLD=tIN_NEW;
                              if (tIN_OLD == 0) {
                                  tIN_OLD=tIN_NEW;
                              } else {
                                  } else {
                                      tIN_DIFF=tIN_NEW;
                                  if (tIN_DIFF < 0) {
                              if (IPV4I == '') {
                              tOUT_OLD=tOUT_NEW;
                                  tOUT_OLD=tOUT_NEW;
                              } else {
                                  } else {
                                      tOUT_DIFF=tOUT_NEW;
                              tOUT_SUM=0;
                              tIN_SUM=0;
                                  TrafficlfdMonat();
                          Ro75.
                          K
                          K
                          Kuddel
                          @ro75 vielen Dank für den Code.
                          Muss ich mir mal in Ruhe anschauen, da ich weder SQL noch den UPNP Adapter im Einsatz habe.
                          • Ro75R Ro75
                            3. TR-64-Adapter
                            var IPV4='';
                            var IPV4I='';
                            var tIN_NEW = 0;
                            var tIN_OLD = 0;
                            var tIN_DIFF = 0;
                            var tIN_SUM = 0;
                            var tOUT_NEW = 0;
                            var tOUT_OLD = 0;
                            var tOUT_DIFF = 0;
                            var tOUT_SUM = 0;
                                var Ergebnis=0;
                                    if (result.error) {
                                    } else {
                                var ErgebnisII=0;
                                    if (result.error) {
                                    } else {
                                TrafficlfdMonat();
                                if (IPV4 == '') {
                                tIN_OLD=tIN_NEW;
                                if (tIN_OLD == 0) {
                                    tIN_OLD=tIN_NEW;
                                } else {
                                    } else {
                                        tIN_DIFF=tIN_NEW;
                                    if (tIN_DIFF < 0) {
                                if (IPV4I == '') {
                                tOUT_OLD=tOUT_NEW;
                                    tOUT_OLD=tOUT_NEW;
                                } else {
                                    } else {
                                        tOUT_DIFF=tOUT_NEW;
                                tOUT_SUM=0;
                                tIN_SUM=0;
                                    TrafficlfdMonat();
                            Ro75.
                            LongbowL
                            LongbowL
                            Longbow
                            @ro75
                            also habe Tr-64 installiert, läuft auch. UpNp habe ich auch installiert, hier werden die Daten nur neu angezeigt, wenn ich kurz den Daten Request von true auf false, dann wieder auf true setzt. Es passiert leider nichts automatisch.
                            Was meinst du mit Mysql SQL, hab nur influx... muss ich mir noch einen MYSQL Server erstellen?
                            • LongbowL Longbow
                              @ro75
                              Ro75R
                              Ro75R
                              Ro75
                              @longbow sagte in Daten aus der Fritzbox visualisieren:
                              Daten Request
                              Da gibt es mehrere Button. Musst die mal durchprobieren und auf True setzen.
                              Wichtig: nicht unter 10 Sekunden!
                              Voraussetzung ist MySQL (SQL-Adapter). Kannst es ja auch ggfs. auf Influx anpassen.
                              Ro75.
                              LongbowL 1 Antwort Letzte Antwort
                              • Ro75R Ro75
                                Daten Request
                                Ro75.
                                LongbowL
                                LongbowL
                                Longbow
                                @ro75 Danke mit den tipp UPnP jetzt geht ;-)
                                Aber das mit dem MySQL habe ich nicht verstanden, was muss ich machen? Denn ich habe influx, müsste ich doch nur die Daten in influx schreibe/speichert, dann in Garfana umsetzten Grafisch...
                                Nur deine Script geht nicht, die Datenpunkt werden nicht gefüttert
                                • LongbowL Longbow
                                  Ro75R
                                  Ro75R
                                  Ro75
                                  @longbow stimmt der DP "upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.TotalBytesReceived"?
                                  Der MySQL bzw. der Adapter wird zum Speichern der Werte gebraucht. Du kannst sicherlich auch Influx nutzen, dann musst du den Code aber anpassen, wie kann ich nicht sagen.
                                  Ro75.
                                  • Ro75R Ro75
                                    Ro75.
                                    LongbowL
                                    LongbowL
                                    Longbow
                                    @ro75 ja der stimmt, da kommen Daten und wegen immer neu geschrieben.. muss diese nur umrechnen... da muss ich mal sehen, was ich machen muss um MBits zu erhalten
                                    • LongbowL Longbow
                                      Ro75R
                                      Ro75R
                                      Ro75
                                      @longbow die reinen Daten aus dem UPNP nutzen dir nichts. der Counter der Fritzbox springt imme wieder auf 0. so bekommst du keine summierten Daten. Das Skript muss chon laufen und die Daten wegschreiben. Hast du alles übernommen? Kommen Meldungen?
                                      Ro75.
                                      • Ro75R Ro75
                                        Ro75.
                                        LongbowL
                                        LongbowL
                                        Longbow
                                        @ro75
                                        ja die Daten von dem UPnP kommen in 11sek abständen. Dein Script läuft, aber leider im Protokoll diese Meldung
                                        javascript.0
                                        102336 2024-05-28 21:10:00.976 error script.js.Sonstiges.Daten_FritzBox: Error: SQLITE_ERROR: no such table: iobroker.datapoints
                                        Also bedeutet das, das die Daten von dem UPnP nicht die Daten sind, die man hat. Spricht die Zahl kein Wert ist, den man mal nimmt und dann den MBit wert hat
                                        • LongbowL Longbow
                                          @ro75
                                          javascript.0
                                          Ro75R
                                          Ro75R
                                          Ro75
                                          @longbow ja,weil der SQL-Adapter nicht läuft und du wohl keine MYSQL Datenbank installiert hast - Voraussetzungen.
                                          Ro75.
                                          84.2k
