  4. Daten aus der Fritzbox visualisieren
    6.5k
113 Beiträge 20 Kommentatoren 25.6k Aufrufe 23 Beobachtet
  • Ro75R Ro75
    @dr-pie sagte in Daten aus der Fritzbox visualisieren:
    leider gibt der Adapter von AVM (tr064) die erforderlichen Daten nicht preis
    das stimmt so definitiv nicht. Der tr-64 Adapter kann dir alles liefern. Es ist immer nur die Frage wie. Versuche es mal so:
    const NewByteReceiveRate    = '0_userdata.0.FritzBox.NewByteReceiveRate';
    const NewByteSendRate       = '0_userdata.0.FritzBox.NewByteSendRate';
    const L1DownMaxRate         = '0_userdata.0.FritzBox.Layer1DownstreamMaxBitRate';
    const L1UpMaxRate           = '0_userdata.0.FritzBox.Layer1UpstreamMaxBitRate';
    const ReceiveR              = '0_userdata.0.FritzBox.Charts.Receive';
    const SendR                 = '0_userdata.0.FritzBox.Charts.Send';
    createState(NewByteReceiveRate, 0, {type: 'number', read: true, write: true});
    createState(NewByteSendRate, 0, {type: 'number', read: true, write: true});
    createState(L1DownMaxRate, 0, {type: 'number', read: true, write: true});
    createState(L1UpMaxRate, 0, {type: 'number', read: true, write: true});
    createState(ReceiveR, 0, {type: 'number', unit: 'MBit/s', read: true, write: true});
    createState(SendR, 0, {type: 'number', unit: 'MBit/s', read: true, write: true});
    schedule('*/6 * * * * *', function Aktualisierung() {
        setState('tr-064.0.states.command', '{"service": "urn:dslforum-org:service:WANCommonInterfaceConfig:1","action": "X_AVM-DE_GetOnlineMonitor","params": {"NewSyncGroupIndex": 0}}');
        var value=getState('tr-064.0.states.commandResult').val;
        if (value.indexOf('NewTotalNumber') == 2) {
            var obj = JSON.parse(value);
            var DownStream = obj.Newds_current_bps;
            var UpStream = obj.Newus_current_bps;
            var ds = DownStream.split(",");
            var us = UpStream.split(",");
            var wds    =  ds[0];
            var wus    =  us[0];
            setState(NewByteReceiveRate, wds*1);
            setState(NewByteSendRate, wus*1);
            setState(ReceiveR, Math.round((wds*0.000008)*100)/100);
            setState(SendR, Math.round((wus*0.000008)*100)/100);
            setState(L1DownMaxRate, obj.Newmax_ds*8);
            setState(L1UpMaxRate, obj.Newmax_us*8);
    Damit hat man einmal die "Basisdaten". Mit einigen weiteren Codezeilen kann man auch erfahren wie groß der Traffic ist (down / up). Mit bissel Spielerei kann man so den Traffic für den Tag, die Woche, den Monat errechnen, speichern und visualisieren.
    Alles über den TR-64 Adapter.
    Ro75.
    haselchenH Offline
    haselchenH Offline
    haselchen
    @ro75
    Klingt spannend und bringt mich zu einer Frage.
    Die FB7590 läuft ja auch an Glasfaser Anschlüssen.
    Der Up und Download wie bei DSL wird da ja nicht angezeigt .
    Liefert Dein Code eventuell die Daten?
    Ro75R 1 Antwort Letzte Antwort
    • haselchenH haselchen
      @ro75
      Ro75R Offline
      Ro75R Offline
      Ro75
      @haselchen sagte in Daten aus der Fritzbox visualisieren:
      Probiere einfach den Code aus. Bei einer 7490 geht es zu 100%.
      Ro75.
      • Ro75R Ro75
        Ro75.
        haselchenH Offline
        haselchenH Offline
        haselchen
        @ro75
        An was für einem Anschluss ?
          @ro75
          Ro75R Offline
          Ro75R Offline
          Ro75
          Was meinst du damit genau?
          Ro75.
          • Ro75R Ro75
                    var wds    =  ds[0];
                    var wus    =  us[0];
            Ro75.
            Dr.PieD Offline
            Dr.PieD Offline
            Dr.Pie
            @ro75 sagte in Daten aus der Fritzbox visualisieren:
            Ro75.
            Magst du die Visualisierung zur Verfügung stellen ?
            L 1 Antwort Letzte Antwort
            • Ro75R Ro75
              Ro75.
              haselchenH Offline
              haselchenH Offline
              haselchen
              @ro75
              Naja, DSL oder Glasfaser
              • Ro75R Offline
                Ro75R Offline
                Ro75
                schrieb am zuletzt editiert von Ro75
                @haselchen Dann ist es DSL.
                Ro75.
                EDIT: In der Dokumentation von AVM finde ich jetzt nicht eine expliziete Unterscheidung zwischen DSL und Glasfaser.
                Probiere den Code einfach aus und dann berichte mal.
                Ro75.
                • Dr.PieD Dr.Pie
                  Ro75.
                  ludino
                  schrieb am zuletzt editiert von ludino
                  @Ro75
                  Hi Habe mir dein Script mal installiert, und es klappt super. Leider weiß ich nicht wie du die Vis gemacht hast besonders intressiert mich die darstellung der letzten 10 tage und der letzten 12 Monaten.
                  Würde du es mir verraten?
                  Ludino
                  • Ro75R Ro75
                            var wds    =  ds[0];
                            var wus    =  us[0];
                    Ro75.
                    Galen
                    @ro75 Vielen Dank!
                    Könntest du noch den Codeteil posten, der das genutzte Datenvolumen berechnet und speichert?
                    Könnte man evtl. noch die derzeitige IP und den Status der Leitung (Verbunden oder getrennt) aus den Daten auslesen?
                    Dr.PieD 1 Antwort Letzte Antwort
                    • G Galen
                      @ro75 Vielen Dank!
                      Dr.PieD Offline
                      Dr.PieD Offline
                      Dr.Pie
                      bei mir scheint nicht zu funktionieren:
                      E 1 Antwort Letzte Antwort
                      • Dr.PieD Dr.Pie
                        emil70
                        @dr-pie
                        Hast du den Adapter tr-064 drauf?
                        gruss emil70
                        iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
                        • E emil70
                          @dr-pie
                          Dr.PieD Offline
                          Dr.PieD Offline
                          Dr.Pie
                          @emil70 ja ... 2 Instanzen
                          • Dr.PieD Dr.Pie
                            Ro75R Offline
                            Ro75R Offline
                            Ro75
                            @dr-pie Was steht denn im DP "tr-064.0.states.commandResult"?
                            Ro75.
                            Dr.PieD D 2 Antworten Letzte Antwort
                            • Ro75R Ro75
                              Ro75.
                              Dr.PieD Offline
                              Dr.PieD Offline
                              Dr.Pie
                              @ro75 Ich habe das Script und die DP's mal gelöscht und wieder neu installiert ... nun scheint es zu funktionieren.
                              Ich hatte das schon mal das ich erst etwas wieder deinstallieren musste und neu installiert habe dann funktionierte es..
                              Komisch
                              • Ro75R Ro75
                                        var wds    =  ds[0];
                                        var wus    =  us[0];
                                Ro75.
                                babl
                                @ro75 Dein Script funktioniert gut, nur es haut mir die Protokolle voll mit den Ergebnissen der Abfragen, wie kann ich das denn in diesem Java Script ausschalten, sorry Javascript ist nicht meine Hauptsprache mache alles über blockly.
                                Ro75R HomoranH 2 Antworten Letzte Antwort
                                • B babl
                                  Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  @babl das Skript selbst enthält keinerlei LOG-Ausgaben. Eventuell musst du bei dem JS-Adapter die LOG-Stufe ändern. Ggfs. von Info auf Error.
                                  Ro75.
                                  • B babl
                                    @babl sagte in Daten aus der Fritzbox visualisieren:
                                    dann zeig mal was genau im log steht
                                      babl
                                      @homoran @Ro75
                                      2024-05-26 10:05:06.055 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729,2052,638,1041","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091,1876,795,850","Newprio_realtime_bps":"4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490,1313,194,142","Newprio_high_bps":"238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53,106,68,48","Newprio_default_bps":"810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548,457,533,660","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                      2024-05-26 10:05:12.114 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729,2052","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091,1876","Newprio_realtime_bps":"295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490,1313","Newprio_high_bps":"48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53,106","Newprio_default_bps":"669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548,457","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                      2024-05-26 10:05:18.054 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336,1729","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321,1091","Newprio_realtime_bps":"377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553,490","Newprio_high_bps":"137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63,53","Newprio_default_bps":"557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705,548","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                      2024-05-26 10:05:24.097 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726,3336","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728,2321","Newprio_realtime_bps":"408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228,1553","Newprio_high_bps":"15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46,63","Newprio_default_bps":"622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454,705","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                      2024-05-26 10:05:30.136 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1041,955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715,726","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"811,1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801,728","Newprio_realtime_bps":"100,408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501,228","Newprio_high_bps":"46,15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70,46","Newprio_default_bps":"665,622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230,454","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                      2024-05-26 10:05:34.307 - info: admin.0 (3910344) ==> Connected system.user.admin from ::ffff:192.168.157.20
                                      2024-05-26 10:05:36.080 - info: tr-064.0 (3958677) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"17291375","Newmax_us":"4518375","Newds_current_bps":"1081,1041,955,1267,956,8147,15703,1360,1917,2653,3724,3357,6570,4579,11200,1980,915,5373,17098,3715","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"842,811,1045,1071,1012,4621,5688,1325,1395,2013,1485,1924,2008,1683,7491,1247,875,2367,6606,1801","Newprio_realtime_bps":"193,100,408,377,295,3428,4640,589,816,815,653,1121,1191,939,6829,500,326,1600,5442,501","Newprio_high_bps":"98,46,15,137,48,188,238,87,48,82,84,54,200,75,118,101,29,120,252,70","Newprio_default_bps":"551,665,622,557,669,1005,810,649,531,1116,748,749,617,669,544,646,520,647,912,1230","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
                                      2024-05-26 10:05:38.586 - info: javascript.0 (3935439) Stopping script script.js.common.FritzBox.Datenmenge
                                        babl
                                        @Ro75 @Homoran Auch wenn ich die Logstufe von Info zu Error ändere kommen die gleichen Infos im Log an.
                                        Habe gestern das System upgedatet auch den Java Script Adapter auf die 8.3.1
                                        Vielleicht ist es ein "Bug"
                                        Node.js: v18.20.3
                                        NPM: 10.7.0
                                        Ro75R DJMarc75D 2 Antworten Letzte Antwort
                                        • B babl
                                          Node.js: v18.20.3
                                          NPM: 10.7.0
                                          Ro75R Offline
                                          Ro75R Offline
                                          Ro75
                                          @babl also im von dir geposteten LOG sehe ich "Info". Mal bitte die LOG-Stufe vom Adapter zeigen und dann nochmal das LOG.
                                          Ro75.
