  4. Umzug auf Raspberry Pi 5
41 Beiträge 5 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • L legro
    @thomas-braun sagte in Umzug auf Raspberry Pi 5:
    @legro
    mount | sort
    sagt?
    .. dies ..
    pi@raspiBullseye:~ $ mount | sort
    binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
    bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
    configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
    /dev/sda2 on / type ext4 (rw,noatime)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=3735168k,nr_inodes=933792,mode=755)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
    lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
    mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
    proc on /proc type proc (rw,relatime)
    pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
    ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
    ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
    ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
    ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,size=1599760k,nr_inodes=819200,mode=755)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=799876k,nr_inodes=199969,mode=700,uid=1000,gid=1000)
    tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
    .. womit ich als Laie nicht viel anfangen kann.
    @legro
    Alles gut. Ich wollte nur Segen, ob vielleicht die Freigabe noch gemountet ist.
    L 1 Antwort Letzte Antwort
      @legro
      legro
      schrieb am zuletzt editiert von legro
      Alles gut.
      Da bin ich mir jedoch alles Andere als sicher. Müsste nicht - zumindest das InfluxDB - Backup deutlich größer sein?
      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
      • L legro
        Alles gut.
        @legro
        Das alles gut bezog sich auf die mounts.
        Warum die Backups so klein sind erklärt das nicht.
          @legro
          legro
          Schon klar.
          Wo befinden sich eigentlich die Dateien von InfluxDB?
          • L legro
            Schon klar.
            legro
            @Homoran @Thomas-Braun
            Da ich hier nicht weiterkomme, habe ich nach Alternativen gesucht. Zurzeit scheint mir eine mögliche Lösung ..
            • influx backup <BackupDatei>
            • Backupdatei von InfluxDB auf PC (mit FileZilla)
            • Auf dem Pi5 InfluxDB und CLI installieren
            • Backupdatei vom PC auf Pi5 kopieren
            • influx restore <BackupDatei>
            Vermutlich dürfte das auch das nicht auf Anhieb funktionieren, weil ich als Glückspilz im Pechhaben gewiss wieder etwas übersehen habe.
            • L legro
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              @legro sagte in Umzug auf Raspberry Pi 5:
              Woher weißt du eigentlich, dass das Backup zu klein ist? Ich vermute fast, dass deine Backupeinstellungen für die InfluxDB nicht korrekt sind. Zeig diese mal und welche Buckets auf der Datenbank existieren.
              • Marc BergM Marc Berg
                legro
                @marc-berg
                Bereits über zwei Jahre sammle ich Daten mittels InfluxDB. Da kommen ganz sicher mehr als bloß 16KB zusammen.
                • L legro
                  @marc-berg
                  @legro
                  Und ein Backup 'von Hand' der Datenbank funktioniert?
                  • L legro
                    @marc-berg
                    HomoranH Offline
                    HomoranH Offline
                    @legro und was ist mit
                    @marc-berg sagte in Umzug auf Raspberry Pi 5:
                      @legro
                      legro
                      Das Backup via CLI von InfluxDB habe ich noch nicht ausprobiert. Wenn ich's durchgeführt habe, werde ich berichten.
                      @Marc-Berg
                      Wo finde ich die von dir gewünschten Einstellungen? In BackItUp kann ich doch bloß die Option zu InfluxDB aktivieren.
                      Marc BergM HomoranH 2 Antworten Letzte Antwort
                      • L legro
                        @Marc-Berg
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                          legro
                          @marc-berg
                          Was soll ich da anderes einstellen?
                          Im Laufe der Zeit war der Token - warum auch immer - ungültig geworden. Diesen habe ich erneuert. Seither funktioniert das Update ja auch wieder - leider nicht richtig.
                          • L legro
                            @marc-berg
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            Kein Wunder, dein Bucket heißt nicht so, wie du es dort eingetragen hast.
                            EDIT: und wie hast du den neuen Token erzeugt?
                            • L legro
                              @Marc-Berg
                              HomoranH Offline
                              HomoranH Offline
                              zu jeder angewählten Option gibt es eine zugehörige Konfigurationsseite
                                legro
                                Oh je, wie konnte ich nur so blind sein.😕
                                Die Datenbank lautete seit Jahr und Tag "iobroker". Im Herbst letzten Jahres hatte ich bei den Buckets aufgeräumt, dabei habe ich dann wohl diesen Namen neu eingetragen.
                                So, und nun geht's an das Grafana Update. Das kann doch auch mit 16KB nicht alles enthalten.
                                • L legro
                                  Marc BergM Offline
                                  Marc BergM Offline
                                  Marc Berg
                                  Doch, das passt. Mein Grafana Backup ist bei 12 Dashboards und 5 Datenquellen ca. 18kB groß.
                                    legro
                                    @marc-berg
                                    Vielen Dank für deine Rückmeldung. Dann kann ich ja endlich mit dem Umzug auf den Pi5 beginnen.
