  4. DMP8624 -> iobroker
DMP8624 -> iobroker
235 Beiträge 7 Kommentatoren 51.6k Aufrufe 5 Beobachtet
  • WalW Wal
    @jonas-haber ,
    viel kann ich dir dazu nicht sagen, da ich das Teil nicht habe.
    Ist in dem Teil schon ein ESP eingebaut oder hängst du das Teil an ein Wemos ?
    Falls ein ESP eingebaut ist, kann es schon an dem vorhandenen Speicher scheitern Script zu aktivieren.
    Man kann die Daten von Teleperiode im Script auslesen und in eine Globalen Variablen schreiben.
    >D
    g:cur=0
    >T
    cur=ENERGY#Power
    >S
    if upsecs%10==0 {
      print Solar %cur%W
    hier die Teleperiode und die Ausgabe von print Solar.
    09:39:12.251 MQT: tele/Haus.Balkonkraftwerk/SENSOR = {"Time":"2024-04-19T09:39:12","ENERGY":{"TotalStartTime":"2023-08-17T21:06:39","Total":383.286,"Yesterday":2.448,"Today":0.021,"Period":0,"Power":20,"ApparentPower":45,"ReactivePower":41,"Factor":0.43,"Voltage":232,"Current":0.194}}
    09:39:20.196 Solar 19.00W
    09:39:21.201 Solar 19.00W
    09:39:22.210 MQT: tele/Haus.Balkonkraftwerk/STATE = {"Time":"2024-04-19T09:39:22","Uptime":"199T13:43:36","UptimeSec":17243016,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":96,"POWER":"ON","Wifi":{"AP":1,"SSId":"1000MBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":70,"Signal":-65,"LinkCount":6,"Downtime":"0T00:00:17"}}
    09:39:22.223 MQT: tele/Haus.Balkonkraftwerk/SENSOR = {"Time":"2024-04-19T09:39:22","ENERGY":{"TotalStartTime":"2023-08-17T21:06:39","Total":383.287,"Yesterday":2.448,"Today":0.022,"Period":0,"Power":19,"ApparentPower":45,"ReactivePower":40,"Factor":0.43,"Voltage":231,"Current":0.193}}
    09:39:22.230 Solar 19.00W
    09:39:31.225 Solar 19.00W
    09:39:32.233 MQT: tele/Haus.Balkonkraftwerk/STATE = {"Time":"2024-04-19T09:39:32","Uptime":"199T13:43:46","UptimeSec":17243026,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":96,"POWER":"ON","Wifi":{"AP":1,"SSId":"1000MBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":70,"Signal":-65,"LinkCount":6,"Downtime":"0T00:00:17"}}
    09:39:32.245 MQT: tele/Haus.Balkonkraftwerk/SENSOR = {"Time":"2024-04-19T09:39:32","ENERGY":{"TotalStartTime":"2023-08-17T21:06:39","Total":383.287,"Yesterday":2.448,"Today":0.022,"Period":0,"Power":19,"ApparentPower":45,"ReactivePower":41,"Factor":0.42,"Voltage":231,"Current":0.193}}
    09:39:40.201 Solar 19.00W
    09:39:41.200 Solar 19.00W
    09:39:42.205 MQT: tele/Haus.Balkonkraftwerk/STATE = {"Time":"2024-04-19T09:39:42","Uptime":"199T13:43:56","UptimeSec":17243036,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":96,"POWER":"ON","Wifi":{"AP":1,"SSId":"1000MBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":70,"Signal":-65,"LinkCount":6,"Downtime":"0T00:00:17"}}
    09:39:42.215 MQT: tele/Haus.Balkonkraftwerk/SENSOR = {"Time":"2024-04-19T09:39:42","ENERGY":{"TotalStartTime":"2023-08-17T21:06:39","Total":383.287,"Yesterday":2.448,"Today":0.022,"Period":0,"Power":19,"ApparentPower":45,"ReactivePower":41,"Factor":0.42,"Voltage":232,"Current":0.193}}
    09:39:42.222 Solar 19.00W
    09:39:51.228 Solar 18.00W
    09:39:52.235 MQT: tele/Haus.Balkonkraftwerk/STATE = {"Time":"2024-04-19T09:39:52","Uptime":"199T13:44:06","UptimeSec":17243046,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":96,"POWER":"ON","Wifi":{"AP":1,"SSId":"1000MBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":70,"Signal":-65,"LinkCount":6,"Downtime":"0T00:00:17"}}
    09:39:52.248 MQT: tele/Haus.Balkonkraftwerk/SENSOR = {"Time":"2024-04-19T09:39:52","ENERGY":{"TotalStartTime":"2023-08-17T21:06:39","Total":383.287,"Yesterday":2.448,"Today":0.022,"Period":0,"Power":18,"ApparentPower":45,"ReactivePower":41,"Factor":0.41,"Voltage":232,"Current":0.192}}
    09:40:00.219 Solar 18.00W
    09:40:01.225 Solar 18.00W
    09:40:02.234 MQT: tele/Haus.Balkonkraftwerk/STATE = {"Time":"2024-04-19T09:40:02","Uptime":"199T13:44:16","UptimeSec":17243056,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":96,"POWER":"ON","Wifi":{"AP":1,"SSId":"1000MBit","BSSId":"B0:F2:08:54:F3:97","Channel":11,"Mode":"11n","RSSI":70,"Signal":-65,"LinkCount":6,"Downtime":"0T00:00:17"}}
    09:40:02.247 MQT: tele/Haus.Balkonkraftwerk/SENSOR = {"Time":"2024-04-19T09:40:02","ENERGY":{"TotalStartTime":"2023-08-17T21:06:39","Total":383.287,"Yesterday":2.448,"Today":0.022,"Period":0,"Power":18,"ApparentPower":44,"ReactivePower":41,"Factor":0.40,"Voltage":231,"Current":0.191}}
    09:40:02.254 Solar 18.00W
    09:40:11.216 Solar 17.00W
    Jonas HaberJ Offline
    Jonas Haber
    schrieb am zuletzt editiert von Jonas Haber
    #225
    @wal nein ich hänge das Teil nur an einen NodeMcuESP mit aktiviertem Script und global variable in der Tasmota Firmware. Ich kann also ganz sicher im Script schreiben.
    "Man kann die Daten von Teleperiode im Script auslesen und in eine Globalen Variablen schreiben."
    Das klingt doch super.
    >D
    g:cur=0 ; globale Variable wird definiert.
    >T ; Teleperiod
    cur=ENERGY#Power ; Teleperiod wird aktiviert für cur und nur in Verbindung mit print Solar%cur%W
    >S ; ausgeführt jede Sekunde
    if upsecs%10==0 {  ; wenn ...
      print Solar %cur%W ; schreibe in der Konsole / hier wird die variable geprinted und kann von Teleperiod weiter genutzt werden
    Dann schreibe ich meins mal um:
    >D
    u:volt=0 ; Global Variable u
    >T
    volt=ENERGY#Voltage
    >S
    print Battery %volt%V ; Spannungswert jede Sekunde
    Edit:
    >T ; Teleperiod
    cur=ENERGY#Power ; oder wird hier ein Wert vom WebUI "ENERGY" mit cur verbunden? Wo kann ich sehen dass cur und mein Voltage im WebUI fest verbunden sind?
    Jonas
    WalW 2 Antworten Letzte Antwort
    • Jonas HaberJ Jonas Haber
      >D
      >T ; Teleperiod
      >D
      >T
      volt=ENERGY#Voltage
      >S
      Edit:
      >T ; Teleperiod
      WalW Offline
      WalW Offline
      Wal
      schrieb am zuletzt editiert von Wal
      #226
      @jonas-haber sagte in DMP8624 -> iobroker:
      >D
      falsch
      >D
      g:volt=0 ; Global Variable volt
      edit: Wie kommst du nur auf "u"
      Walter
      DoorIO-Adapter
        >D
        >T ; Teleperiod
        >D
        >T
        volt=ENERGY#Voltage
        >S
        Edit:
        >T ; Teleperiod
        WalW Offline
        WalW Offline
        Wal
        #227
        Schau dir mein Beispiel oben nochmal genau an, wie ich aus der Teleperiode Nachricht die Aktuelle Leistung(Power) gewinne.
        Walter
        DoorIO-Adapter
        Jonas HaberJ 1 Antwort Letzte Antwort
        • Jonas HaberJ Offline
          Jonas Haber
          #228
          @wal ich dachte da ich g schon benutzt habe für den DPM nehme ich eben u für die Spannung. Aber ich glaube, dass g nur zeigt, dass es sich um eine globale variable handelt und erst nach dem : der eigentliche Name der Variablen kommt. Danke
          Jonas
          • WalW Wal
            Jonas Haber
            #229
            @wal
            >S
            if seconds since start %10 == 0 { ; weiss nicht genau was das bedeutet ..
            print Solar %cur%W ; cur ist also "ENERGY" # "Power".
            Ich sehe, dass es eine Struktur gibt beim Teleperiod. Damit habe ich mich noch nicht befasst. Aber was ich verstehe bezüglich meines weiteren Vorgehens ist, dass ich zuerst die Console auslesen muss und damit dann die erforderlichen Verzeichnisse bekomme. Das wären bei dir z.B. "ENERGY" und dann "Power" wobei zwischen diesen noch ein # kommt. Ich glaube das müsste es sein.
            Jonas
            WalW 1 Antwort Letzte Antwort
              @wal
              >S
              WalW Offline
              WalW Offline
              Wal
              #230
              @jonas-haber ,
              dein Bild ist fast richtig, Energy und Power stimmt.
              %cur% ist die Variable cur und hat nichts mit Current zu tun.
              Current wäre "ENERGY#CURRENT"
              Walter
              DoorIO-Adapter
                Jonas Haber
                #231
                @wal ja genau. Vielen Dank.
                Jonas
                • WalW Wal
                  @jonas-haber ,
                  Jonas Haber
                  #232
                  @wal hey. benutzt du eigentlich einen laderegler und einen akku?
                  Jonas
                    WalW Offline
                    WalW Offline
                    Wal
                    #233
                    @jonas-haber ,
                    habe mich noch nicht für einen Akku durchringen können.
                    Walter
                    DoorIO-Adapter
                    • WalW Wal
                      @jonas-haber ,
                      Jonas Haber
                      #234
                      @wal ah verstehe. Ich suche grade einen Laderegler den ich über Tasmota auslesen kann, da mein Projekt mit dem PZEM-017 nach hinten los ging und gleichzeitig der victron 100 /20 den löffel abgegeben hat. Hast du eine Idee für einen Laderegler?
                      Edit:
                      habe mich nun für den Epever entschieden.
                      Dazu habe ich mir dieses Forum angeguckt: https://github.com/arendst/Tasmota/discussions/12800
                      Ein script für den ESP liegt bei:
                      D
                      B
                      ->sensor53 r
                      M 1
                      +1,3,m,1,115200,Epever,1,10,01043100,01043101,01043102,0104310C,0104310D,0104310E,01043105,01043110
                      1,010404UUuuxxxx@i0:100,PV Voltage,V,Voltage,2
                      1,010404UUuuxxxx@i1:100,PV Current,A,Current,2
                      1,010404UUuuxxxx@i2:100,PV Power,W,Power,2
                      1,010404UUuuxxxx@i3:100,Output Voltage,V,lv,2
                      1,010404UUuuxxxx@i4:100,Output Current,A,lc,2
                      1,010404UUuuxxxx@i5:100,Output Power,W,lp,2
                      1,010404UUuuxxxx@i6:100,Charging Current,A,bc,2
                      1,010404SSssxxxx@i7:100,Temperature,°C,Temperature,1
                      Verbunden wird das ganze von einem rj45 über einen rs485 adapter hin zum esp
                      Das kann ja nur schief gehen oder ? :D
                      Jedenfalls mein PZEM-017 ist gestern Nacht abgebrannt. Ich hoffe mit dem neuen Epever Solar Charger Controller kann ich zwei Fliegen mit einer Klappe schlagen nämlich die Spannung auslesen ohne den PZEM zu verbauen und gleichzeitig den kaputten Victron los zuwerden.
                      Jonas
                        Edit:
                        D
                        B
                        ->sensor53 r
                        M 1
                        WalW Offline
                        WalW Offline
                        Wal
                        #235
                        @jonas-haber ,
                        ich habe mir den EASun 80A MPPT Laderegler geholt, habe aber noch nichts gemacht damit.
                        Walter
                        DoorIO-Adapter
