  4. IoBroker restart missglückt?
17 Beiträge 6 Kommentatoren 1.3k Aufrufe 5 Beobachtet
  • H hukio
    @david-g
    Hier ist das ausführliche diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspibull
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     14:29:50 up 15:42,  1 user,  load average: 0.56, 0.69, 0.59
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2024-03-20 14:29:51 CET
               Universal time: Wed 2024-03-20 13:29:51 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        2.6G        266M        1.0M        879M        1.2G
    Swap:           2.0G          0B        2.0G
    Total:          5.8G        2.6G        2.3G
             3793 M total memory
             2647 M used memory
             2825 M active memory
              549 M inactive memory
              266 M free memory
              366 M buffer memory
              513 M swap cache
             2027 M total swap
                0 M used swap
             2027 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       30G   20G  8.3G  71% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/sda1      vfat      256M   32M  225M  13% /boot
    /dev/sda3      ext4      439G  1.9G  415G   1% /mnt/hukdata
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Tue Mar 19 22:47:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:1E:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=4d904d30-02 rootfstype=ext4 fsck.repair=yes rootwait rootdelay=5
    [Tue Mar 19 22:47:48 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
    [Tue Mar 19 22:47:48 2024] EXT4-fs (sda2): write access will be enabled during recovery
    [Tue Mar 19 22:47:49 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Tue Mar 19 22:47:49 2024] EXT4-fs (sda2): 4 orphan inodes deleted
    [Tue Mar 19 22:47:49 2024] EXT4-fs (sda2): recovery complete
    [Tue Mar 19 22:47:49 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Mar 19 22:47:49 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Tue Mar 19 22:47:51 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
    [Tue Mar 19 22:48:02 2024] EXT4-fs (sda3): recovery complete
    [Tue Mar 19 22:48:02 2024] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
    TARGET         SOURCE    FSTYPE OPTIONS
    /              /dev/sda2 ext4   rw,noatime
    |-/boot        /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/mnt/hukdata /dev/sda3 ext4   rw,noatime
    /var:
    5.8G    /var/
    3.1G    /var/log
    3.0G    /var/log/journal/1ffd49df1b3a44ffb614b2c58029c285
    563M    /var/cache
    Archived and active journals take up 2.9G in the file system.
    /opt/iobroker/backups:
    8.4G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    745M    /opt/iobroker/iobroker-data/
    328M    /opt/iobroker/iobroker-data/history
    239M    /opt/iobroker/iobroker-data/files
    124M    /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    52M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_323adb3b74d9eb11b6e6178e6fe9f4d9-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
         18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
     *** 18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   2
    Adapter State
      system.adapter.adb.0                    : adb                   : raspibull                                - disabled
    + system.adapter.admin.0                  : admin                 : raspibull                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspibull                                -  enabled
    + system.adapter.backitup.0               : backitup              : raspibull                                -  enabled
      system.adapter.broadlink2.0             : broadlink2            : raspibull                                - disabled
      system.adapter.daikin.0                 : daikin                : raspibull                                - disabled
    + system.adapter.daikin.1                 : daikin                : raspibull                                -  enabled
      system.adapter.discovery.0              : discovery             : raspibull                                - disabled
    + system.adapter.doorbird.0               : doorbird              : raspibull                                -  enabled
    + system.adapter.email.0                  : email                 : raspibull                                -  enabled
    + system.adapter.email.1                  : email                 : raspibull                                - disabled
      system.adapter.flot.0                   : flot                  : raspibull                                - disabled
    + system.adapter.fritzdect.0              : fritzdect             : raspibull                                -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspibull                                - disabled
    + system.adapter.history.0                : history               : raspibull                                -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspibull                                -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspibull                                -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : raspibull                                -  enabled
    + system.adapter.javascript.0             : javascript            : raspibull                                -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : raspibull                                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspibull                                -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.netatmo.0                : netatmo               : raspibull                                -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : raspibull                                -  enabled
    + system.adapter.onkyo.0                  : onkyo                 : raspibull                                -  enabled
      system.adapter.onvif.0                  : onvif                 : raspibull                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.onvif.1                  : onvif                 : raspibull                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.ping.0                   : ping                  : raspibull                                - disabled
      system.adapter.robonect.0               : robonect              : raspibull                                - disabled
    + system.adapter.scenes.0                 : scenes                : raspibull                                -  enabled
    + system.adapter.shelly.0                 : shelly                : raspibull                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspibull                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.signal-cmb.0             : signal-cmb            : raspibull                                -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspibull                                -  enabled, port: 8087, bind: 192.168.178.78, run as: admin
    + system.adapter.socketio.0               : socketio              : raspibull                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspibull                                -  enabled, port: 1889, bind: 0.0.0.0
      system.adapter.telegram.0               : telegram              : raspibull                                - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : raspibull                                - disabled
    + system.adapter.tr-064.0                 : tr-064                : raspibull                                -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspibull                                - disabled
    + system.adapter.web.0                    : web                   : raspibull                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspibull                                -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "doorbird"     : 1.5.0    , installed 1.5.0
    Adapter    "email"        : 1.2.2    , installed 1.2.2
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "fullybrowser" : 3.0.11   , installed 3.0.11
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.17 [Updatable]
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "onvif"        : 1.1.2    , installed 1.1.2
    Adapter    "robonect"     : 1.3.4    , installed 1.3.4
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.2
    Objects and States
    Objects:        11397
    States:         7783
    W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
    Pending Updates: 29
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       28118      3155/adb
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14627      813/iobroker.js-con
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      110        14474      537/redis-server 12
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14970      1364/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       16223      1552/io.shelly.1
    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       17579      1515/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15469      555/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14531      641/influxd
    tcp        0      0 192.168.178.78:8087     0.0.0.0:*               LISTEN      1001       16715      1662/io.simple-api.
    tcp        0      0 192.168.178.78:8100     0.0.0.0:*               LISTEN      1001       16206      1567/io.doorbird.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16478      1283/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17845      1684/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       16739      1669/io.socketio.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        14563      641/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15471      555/sshd: /usr/sbin
    tcp6       0      0 ::1:6379                :::*                    LISTEN      110        14475      537/redis-server 12
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       16103      1454/io.nuki-extend
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        14172      812/grafana
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17558      1496/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14504      638/dhcpcd
    udp        0      0 0.0.0.0:60604           0.0.0.0:*                           108        13941      429/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13939      429/avahi-daemon: r
    udp6       0      0 :::42951                :::*                                108        13942      429/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          10632      638/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13940      429/avahi-daemon: r
    2024-03-20 10:53:55.618  - info: alexa2.0 (1389) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
    2024-03-20 10:53:56.983  - info: alexa2.0 (1389) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2024-03-20 10:57:49.380  - info: javascript.0 (1184) script.js.Sensoren.Trockner: Zählerstand Strom: 30278.02
    2024-03-20 11:13:13.998  - info: javascript.0 (1184) script.js.Sensoren.Proximity_Sensor_Echo: false
    2024-03-20 11:16:38.446  - info: javascript.0 (1184) script.js.Sensoren.Proximity_Sensor_Echo: true
    2024-03-20 11:30:54.450  - info: javascript.0 (1184) script.js.Sensoren.Trockner: Verbrauch (plug): 0.84 kWh
    2024-03-20 11:30:54.451  - info: javascript.0 (1184) script.js.Sensoren.Trockner: totaler Verbrauch Zählerdifferenz: 0.9 kWh
    2024-03-20 11:30:54.533  - info: signal-cmb.0 (1647) Send Karin der Trockner ist seit  11:30 fertig. to f98af11f-c3df-4b54-9f1e-0454df85f8bd
    2024-03-20 11:39:52.301  - info: javascript.0 (1184) script.js.Sensoren.Doorbird_kill_ringing: request: http://ghewml0001:ENDdXvj9Yc@192.168.178.35/bha-api/audio-transmit.cgi
    2024-03-20 11:39:52.301  - info: javascript.0 (1184) script.js.Sensoren.Doorbird_kill_ringing: doorbird ringing killed
    2024-03-20 12:08:58.130  - info: javascript.0 (1184) script.js.Sensoren.Proximity_Sensor_Echo: false
    2024-03-20 12:17:39.029  - info: javascript.0 (1184) script.js.Sensoren.Proximity_Sensor_Echo: true
    2024-03-20 12:19:05.027  - info: javascript.0 (1184) script.js.Schalter.Automower_(mqtt): Statusende: 17 (Schläft), jetzt: Unbekannt
    2024-03-20 12:19:06.005  - info: javascript.0 (1184) script.js.Schalter.Automower_(mqtt): Statusende: 0 (Bitte warten...), jetzt: Parken
    2024-03-20 12:19:13.135  - info: javascript.0 (1184) script.js.Schalter.Automower_(mqtt): Statusende: 1 (Parkt), jetzt: Umsetzen
    2024-03-20 12:19:24.357  - info: javascript.0 (1184) script.js.Schalter.Automower_(mqtt): Statusende: 5 (Suche), jetzt: Mähen
    2024-03-20 12:58:46.949  - info: alexa2.0 (1389) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
    2024-03-20 12:58:48.354  - info: alexa2.0 (1389) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2024-03-20 13:25:56.625  - info: javascript.0 (1184) script.js.Schalter.Test_Helligkeit: %%%%%%%%%%%%%%%%% Helligkeit geschaltet %%%%%%%%%%%% GSunsensor: 13787.705072715826
    2024-03-20 13:26:04.005  - info: javascript.0 (1184) script.js.Schalter.Test_Helligkeit: %%%%%%%%%%%%%%%%% Helligkeit geschaltet %%%%%%%%%%%% GSunsensor: 13787.705072715826
    2024-03-20 13:26:24.986  - info: javascript.0 (1184) script.js.Schalter.Test_Helligkeit: %%%%%%%%%%%%%%%%% Helligkeit geschaltet %%%%%%%%%%%% GSunsensor: 13787.705072715826
    2024-03-20 14:30:01.622  - info: javascript.0 (1184) script.js.Schalter.Automower_(mqtt): Statusende: 2 (Mäht), jetzt: Parken
    2024-03-20 14:30:01.623  - info: javascript.0 (1184) script.js.Schalter.Automower_(mqtt): Mähdauer: 130 Min.
    2024-03-20 14:30:01.623  - info: javascript.0 (1184) script.js.Schalter.Automower_(mqtt): Battery charge: 0 % Battery voltage: 17.5 V
    2024-03-20 14:30:10.701  - info: javascript.0 (1184) script.js.Schalter.Automower_(mqtt): Statusende: 1 (Parkt), jetzt: Suchen der Ladestation
    influxdb hatte ich auf debug, da immer wieder gewisse Werte mehrmahls abgespeichert werden mußten.
    HUK
    crunchipC Offline
    crunchipC Offline
    @hukio sagte in IoBroker restart missglückt?:
    Führt aber unter anderem zu einer erhöhten Logausgabe/Größe
    Dein Backup Ordner ist ebenfalls mit 8Gb belegt
    Simple API bind auf die IP?
    Warum 2x shelly?
    H 1 Antwort Letzte Antwort
    • H hukio
      @david-g
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           2.0G          0B        2.0G
               3793 M total memory
               2647 M used memory
                266 M free memory
                366 M buffer memory
                513 M swap cache
               2027 M total swap
                  0 M used swap
               2027 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      5.8G    /var/
      3.1G    /var/log
      563M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11397
      States:         7783
      Pending Updates: 29
      HUK
      @hukio
      Da es dir ohnehin in allernächster Zeit bevorsteht:
      Installier das frisch NEU ein Raspberry OS 12 'Bookworm'.
        Warum 2x shelly?
        hukio
        @crunchip
        Habe update und upgrade gemacht. 2 Shelly, da die Mehrzahl unter Coap läuft und die neuen über mqtt müssen. Habe den backup Ordner aufgeräumt.
        HUK
          @hukio
          hukio
          Daran habe ich auch schon gedacht. Für mich doch einige Arbeit, da ja nicht nur IoBroker läuft, sondern auch andere Programme wie influxdb, grafana, ffmpeg, adb etc. Die müssen auch alle neu installiert werden. Ich kenne mich mit Linux nicht gut aus.
          Ich frage mich, warum das System immer wieder abschmiert. Irgendwie habe ich den Eindruck, daß influxdb damit zusammenhängt (siehe das log vor dem crash).
          HUK
          HomoranH DJMarc75D Thomas BraunT 3 Antworten Letzte Antwort
          • H hukio
            HUK
            Auf einem
            mit
            Mem: 3.8G
            Meinst du nicht dass das ein kleines Stück zu viel für den kleinen sein könnte?
            und 28 laufende +x scheduled Instanzen von ioBroker
            • H hukio
              HUK
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              läuft das alles auf Deinem RPI lokal ?
              Lehrling seit 1975 !!!
              • DJMarc75D DJMarc75
                hukio
                @djmarc75
                ja (auf einer SSD)
                DJMarc75D HomoranH 2 Antworten Letzte Antwort
                • H hukio
                  @djmarc75
                  ja (auf einer SSD)
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  auf einer SSD
                  ist egal auf welchem Medium, wichtig ist der RAM und nicht der "Festplattenspeicher"
                  • H hukio
                    @djmarc75
                    ja (auf einer SSD)
                    @djmarc75
                    ja (auf einer SSD)
                    Da ist reichlich Platz,
                    Die Engstelle ist RAM, RAM und nochmal RAM
                    • H hukio
                      @crunchip
                      HUK
                      crunchipC Offline
                      crunchipC Offline
                      Laut deiner Ausgabe läuft da Port 1882, also eigentlich mqtt
                      • H hukio
                        HUK
                        Du kommst aber nicht drumherum.
                        Im Sommer ist Schicht für Bullseye.
                        Und auf Bookworm kann man nicht einfach per Dist-Upgrade gehen.
                        Zusätzlich vermute ich, dass du da auch einfach viel zu viel Zeug auf die Kiste wirfst.
                        • H Offline
                          hukio
                          In der Zwischenzeit habe ich alles auf die ganz letzte Version gebracht außr dem js-controller wegen breaking news von 5.0.18.
                          Wie kommt es zu dem Zeitsprung im log um 9:21:16? Dann kommt der Fehler admin.0 already running (9:17:31) und das System haengt sich auf.
                          2024-03-24 08:48:58.796 - info: javascript.0 (26346) script.js.Sensoren.Gasverbrauch: ^^^^^^^ Gasc start: 0
                          2024-03-24 08:52:22.715 - info: javascript.0 (26346) script.js.Sensoren.Gaszähler: 1711266742714 Start of heating: 08:48:57 Length of heating interval: 174.427 Zählerdifferenz: 0.18 Zähler: 13033.68 vZ0: 13033.5 Verbrauch: 3.72 m3/h vdeltamax: 10542 vdeltamin: 9984 timestamp:1711266712211 vtpre: 1711266712211 Wohnzimmer T: 19.4 vtstart: 1711266537784 Zählerstand: 13033.68
                          2024-03-24 08:54:48.260 - info: javascript.0 (26346) script.js.Sensoren.Heizung.Heizung_T_Wz: Temperatur Wz: 19.6 passed &&&upper&&& T limit: 19.6
                          2024-03-24 09:18:55.544 - info: javascript.0 (26346) script.js.Sensoren.Heizung.Heizung_T_Wz: Temperatur Wz: 19.4 under &&&lower&&& limit T: 19.4
                          2024-03-24 09:20:53.324 - info: javascript.0 (26346) script.js.Sensoren.Gasverbrauch: ^^^^^^^ Gasc start: 0
                          2024-03-24 09:21:15.147 - info: alexa2.0 (26369) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s
                          2024-03-24 09:21:16.520 - info: alexa2.0 (26369) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          2024-03-24 09:17:23.605 - info: host.raspibull iobroker.js-controller version 5.0.17 js-controller starting
                          2024-03-24 09:17:23.614 - info: host.raspibull Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                          2024-03-24 09:17:23.615 - info: host.raspibull hostname: raspibull, node: v18.19.1
                          2024-03-24 09:17:23.617 - info: host.raspibull ip addresses: 192.168.178.78 2003:cf:9f25:b400:5f29:e17a:8220:14a1 fe80::ccc:2f5:c76b:81ed 192.168.178.99 2003:cf:9f25:b400:3af:f248:601a:a447 fe80::8f31:1fe9:478a:1454
                          2024-03-24 09:17:26.142 - info: host.raspibull connected to Objects and States
                          2024-03-24 09:17:26.184 - info: host.raspibull added notifications configuration of host
                          2024-03-24 09:17:27.653 - info: host.raspibull Delete state "system.host.raspibull.versions.nodeCurrent"
                          2024-03-24 09:17:27.751 - info: host.raspibull 41 instances found
                          2024-03-24 09:17:27.995 - info: host.raspibull starting 27 instances
                          2024-03-24 09:17:28.374 - info: host.raspibull Delete state "system.host.raspibull.versions.nodeNewest"
                          2024-03-24 09:17:28.407 - info: host.raspibull instance system.adapter.admin.0 started with pid 1063
                          2024-03-24 09:17:28.428 - info: host.raspibull Delete state "system.host.raspibull.versions.nodeNewestNext"
                          2024-03-24 09:17:28.439 - info: host.raspibull Delete state "system.host.raspibull.versions.npmCurrent"
                          2024-03-24 09:17:28.450 - info: host.raspibull Delete state "system.host.raspibull.versions.npmNewest"
                          2024-03-24 09:17:28.461 - info: host.raspibull Delete state "system.host.raspibull.versions.npmNewestNext"
                          2024-03-24 09:17:28.469 - info: host.raspibull Some obsolete host states deleted.
                          2024-03-24 09:17:31.419 - error: admin.0 (1063) admin.0 already running
                          2024-03-24 09:17:31.424 - warn: admin.0 (1063) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2024-03-24 09:17:32.558 - error: host.raspibull instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2024-03-24 09:17:32.559 - info: host.raspibull Restart adapter system.adapter.admin.0 because enabled
                          2024-03-24 09:17:32.581 - info: host.raspibull instance system.adapter.email.0 started with pid 1081
                          2024-03-24 09:17:34.406 - error: email.0 (1081) email.0 already running
                          2024-03-24 09:17:34.411 - warn: email.0 (1081) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2024-03-24 09:17:35.215 - error: host.raspibull instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2024-03-24 09:17:35.217 - info: host.raspibull Restart adapter system.adapter.email.0 because enabled
                          2024-03-24 09:17:36.273 - info: host.raspibull instance system.adapter.history.0 started with pid 1092
                          2024-03-24 09:17:38.088 - error: history.0 (1092) history.0 already running
                          2024-03-24 09:17:38.093 - warn: history.0 (1092) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2024-03-24 09:29:23.922 - error: host.raspibull instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2024-03-24 09:29:23.922 - info: host.raspibull Restart adapter system.adapter.history.0 because enabled
                          2024-03-24 09:29:25.308 - info: host.raspibull instance system.adapter.influxdb.0 started with pid 1181
                          2024-03-24 09:29:28.171 - info: influxdb.0 (1181) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.influxdb, node: v18.19.1, js-controller: 5.0.17
                          2024-03-24 09:29:28.202 - info: influxdb.0 (1181) No stored data from last exit found
                          2024-03-24 09:29:28.204 - info: influxdb.0 (1181) Connecting http://localhost:8086/ ...
                          2024-03-24 09:29:28.206 - info: influxdb.0 (1181) Influx DB Version used: 1.x
                          2024-03-24 09:29:28.367 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d0001d7257f.humidity, Alias=false, 1 points now activated
                          2024-03-24 09:29:28.368 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d0001d7257f.temperature, Alias=false, 2 points now activated
                          2024-03-24 09:29:28.370 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d0002c903e6.humidity, Alias=false, 3 points now activated
                          2024-03-24 09:29:28.371 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d0002c903e6.temperature, Alias=false, 4 points now activated
                          2024-03-24 09:29:28.372 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d0002ca02cd.humidity, Alias=false, 5 points now activated
                          2024-03-24 09:29:28.372 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d0002ca02cd.temperature, Alias=false, 6 points now activated
                          2024-03-24 09:29:28.374 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d0002e99490.humidity, Alias=false, 7 points now activated
                          2024-03-24 09:29:28.375 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d0002e99490.temperature, Alias=false, 8 points now activated
                          2024-03-24 09:29:28.376 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d000589029b.humidity, Alias=false, 9 points now activated
                          2024-03-24 09:29:28.376 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d000589029b.temperature, Alias=false, 10 points now activated
                          2024-03-24 09:29:28.377 - info: influxdb.0 (1181) enabled logging of zigbee.0.842e14fffe1394aa.load_power, Alias=false, 11 points now activated
                          2024-03-24 09:29:28.378 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c13870c77b88bd.humidity, Alias=false, 12 points now activated
                          2024-03-24 09:29:28.379 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c13870c77b88bd.temperature, Alias=false, 13 points now activated
                          2024-03-24 09:29:28.380 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c138947e577a51.humidity, Alias=false, 14 points now activated
                          2024-03-24 09:29:28.381 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c138947e577a51.temperature, Alias=false, 15 points now activated
                          2024-03-24 09:29:28.382 - info: influxdb.0 (1181) enabled logging of sonoff.0.Stromzähler._Zählerstand, Alias=false, 16 points now activated
                          2024-03-24 09:29:28.382 - info: influxdb.0 (1181) enabled logging of javascript.0.gGasc, Alias=false, 17 points now activated
                          2024-03-24 09:29:28.383 - info: influxdb.0 (1181) enabled logging of javascript.0.gGasd, Alias=false, 18 points now activated
                          2024-03-24 09:29:28.384 - info: influxdb.0 (1181) enabled logging of javascript.0.gGash, Alias=false, 19 points now activated
                          2024-03-24 09:29:28.384 - info: influxdb.0 (1181) enabled logging of javascript.0.gStromc, Alias=false, 20 points now activated
                          2024-03-24 09:29:28.384 - info: influxdb.0 (1181) enabled logging of javascript.0.gStromd, Alias=false, 21 points now activated
                          2024-03-24 09:29:28.385 - info: influxdb.0 (1181) enabled logging of javascript.0.gStromh, Alias=false, 22 points now activated
                          2024-03-24 09:29:28.385 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c1387adb854200.temperature, Alias=false, 23 points now activated
                          2024-03-24 09:29:28.386 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c1387adb854200.humidity, Alias=false, 24 points now activated
                          2024-03-24 09:29:28.386 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c138e95e35c14d.temperature, Alias=false, 25 points now activated
                          2024-03-24 09:29:28.387 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c138e95e35c14d.humidity, Alias=false, 26 points now activated
                          2024-03-24 09:29:28.387 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c138bda9a48a36.temperature, Alias=false, 27 points now activated
                          2024-03-24 09:29:28.388 - info: influxdb.0 (1181) enabled logging of zigbee.0.a4c138bda9a48a36.humidity, Alias=false, 28 points now activated
                          2024-03-24 09:29:28.388 - info: influxdb.0 (1181) enabled logging of zigbee.0.048727fffec54ec6.temperature, Alias=false, 29 points now activated
                          2024-03-24 09:29:28.389 - info: influxdb.0 (1181) enabled logging of shelly.1.shellyplus1pm#fcb467279060#1.Relay0.Power, Alias=false, 30 points now activated
                          2024-03-24 09:29:28.389 - info: influxdb.0 (1181) enabled logging of javascript.0.gClimad, Alias=false, 31 points now activated
                          2024-03-24 09:29:28.390 - info: influxdb.0 (1181) enabled logging of javascript.0.gClimah, Alias=false, 32 points now activated
                          2024-03-24 09:29:28.390 - info: influxdb.0 (1181) enabled logging of shelly.1.shellyplusplugs#d4d4daebcba4#1.Relay0.Power, Alias=false, 33 points now activated
                          2024-03-24 09:29:28.391 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d000227f14a.temperature, Alias=false, 34 points now activated
                          2024-03-24 09:29:28.391 - info: influxdb.0 (1181) enabled logging of zigbee.0.00158d000227f14a.humidity, Alias=false, 35 points now activated
                          2024-03-24 09:29:29.393 - info: host.raspibull instance system.adapter.javascript.0 started with pid 1209
                          2024-03-24 09:29:33.322 - info: host.raspibull instance system.adapter.scenes.0 started with pid 1220
                          2024-03-24 09:29:33.526 - info: javascript.0 (1209) starting. Version 7.8.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.19.1, js-controller: 5.0.17
                          2024-03-24 09:29:35.198 - info: javascript.0 (1209) requesting all states
                          2024-03-24 09:29:35.201 - info: javascript.0 (1209) requesting all objects
                          2024-03-24 09:29:36.488 - info: javascript.0 (1209) received all states
                          2024-03-24 09:29:37.605 - info: host.raspibull instance system.adapter.alexa2.0 started with pid 1235
                          2024-03-24 09:29:38.504 - info: scenes.0 (1220) starting. Version 2.3.9 in /opt/iobroker/node_modules/iobroker.scenes, node: v18.19.1, js-controller: 5.0.17
                          2024-03-24 09:29:38.779 - info: javascript.0 (1209) received all objects
                          2024-03-24 09:29:40.321 - info: javascript.0 (1209) Start javascript script.js.Abwesenheit.Abwesenheit_Bewegung
                          Könnte das Problem mit der Öffnung einer website des IoBroker zusammenhaengen? Der Abbruch geschieht zum wiederholten Male ungefaehr zu der Zeit, wenn ich von einem PC auf den IoBroker zugreife.
                          Ich plane einen RPI5 einzusetzen. Das wird aber noch einige Zeit in Anspruch nehmen.
                          HUK
