  4. ioBroker reagiert sehr langsam oder garnicht
17 Beiträge 5 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • KlausStoertebekerK KlausStoertebeker
    Hier die Ausgabe von iobroker diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: my_ioBroker_Server
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     16:00:06 up 3 days, 17:49,  2 users,  load average: 1.60, 1.44, 1.55
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** Time and Time Zones ***
                   Local time: Thu 2024-03-14 16:00:06 CET
               Universal time: Thu 2024-03-14 15:00:06 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    ioBroker_user
    /home/ioBroker_user
    ioBroker_user adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            4.0G        2.3G        631M        1.3M        1.2G        1.7G
    Swap:           104M          0B        104M
    Total:          4.1G        2.3G        736M
             3792 M total memory
             2174 M used memory
             2392 M active memory
              621 M inactive memory
              601 M free memory
              111 M buffer memory
              989 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT               LOAD   ACTIVE SUB    DESCRIPTION
    * media-Bilder.mount loaded failed failed /media/Bilder
    1 loaded units listed.
    *** FILESYSTEM ***
    <aus Sicherheitsgründen gelöscht>
    /var:
    793M	/var/
    351M	/var/cache
    345M	/var/cache/apt
    233M	/var/cache/apt/archives
    181M	/var/log
    Archived and active journals take up 179.8M in the file system.
    /opt/iobroker/backups:
    4.0K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    739M	/opt/iobroker/iobroker-data/
    554M	/opt/iobroker/iobroker-data/files
    179M	/opt/iobroker/iobroker-data/files/vis-2
    114M	/opt/iobroker/iobroker-data/backup-objects
    89M	/opt/iobroker/iobroker-data/files/echarts.admin
    46M	/opt/iobroker/iobroker-data/objects.jsonl
    24M	/opt/iobroker/iobroker-data/states.jsonl
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-0658_0200-if00
    /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DB_FT2PTYKW-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.1
    /usr/bin/node 		v18.19.1
    /usr/bin/npm 		10.2.4
    /usr/bin/npx 		10.2.4
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.19
    admin: 		6.15.2
    javascript: 	7.8.0
    Adapters from github: 	3
    Adapter State
    + system.adapter.adb.0                    : adb                   : my_ioBroker_Server                -  enabled
    + system.adapter.admin.0                  : admin                 : my_ioBroker_Server                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : my_ioBroker_Server                - disabled
    + system.adapter.backitup.0               : backitup              : my_ioBroker_Server                -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : my_ioBroker_Server                -  enabled
      system.adapter.discovery.0              : discovery             : my_ioBroker_Server                - disabled
      system.adapter.dwd.0                    : dwd                   : my_ioBroker_Server                -  enabled
    + system.adapter.echarts.0                : echarts               : my_ioBroker_Server                -  enabled
    + system.adapter.ekey.0                   : ekey                  : my_ioBroker_Server                -  enabled, port: 56000, bind: 0.0.0.0
    + system.adapter.enocean.0                : enocean               : my_ioBroker_Server                -  enabled
      system.adapter.flot.0                   : flot                  : my_ioBroker_Server                -  enabled
    + system.adapter.ford.0                   : ford                  : my_ioBroker_Server                -  enabled
    + system.adapter.homepilot20.0            : homepilot20           : my_ioBroker_Server                -  enabled
    + system.adapter.hue.0                    : hue                   : my_ioBroker_Server                -  enabled, port: 443
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : my_ioBroker_Server                - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: my_ioBroker_Server                - disabled
    + system.adapter.influxdb.0               : influxdb              : my_ioBroker_Server                -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : my_ioBroker_Server                -  enabled
    + system.adapter.netatmo.0                : netatmo               : my_ioBroker_Server                -  enabled
    + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : my_ioBroker_Server                -  enabled, port: 23
    + system.adapter.signal-cmb.0             : signal-cmb            : my_ioBroker_Server                -  enabled
    + system.adapter.sql.0                    : sql                   : my_ioBroker_Server                -  enabled, port: 3306
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : my_ioBroker_Server                - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : my_ioBroker_Server                - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: my_ioBroker_Server                - disabled
    + system.adapter.vis-2.0                  : vis-2                 : my_ioBroker_Server                -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : my_ioBroker_Server                - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : my_ioBroker_Server                - disabled
    + system.adapter.web.0                    : web                   : my_ioBroker_Server                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zwave2.0                 : zwave2                : my_ioBroker_Server                -  enabled
    + instance is alive
    ioBroker-Repositories
    latest        : http://download.iobroker.net/sources-dist-latest.json
    stable        : http://download.iobroker.net/sources-dist-stable.json
    Active repo(s): latest
    Installed ioBroker-Instances
    Used repository: latest
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 6.15.2   , installed 6.15.2
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "ekey"         : 1.2.3    , installed 1.2.3
    Adapter    "enocean"      : 0.9.3    , installed 0.9.3
    Adapter    "ford"         : 0.2.0    , installed 0.2.0
    Adapter    "hue"          : 3.10.2   , installed 3.10.2
    Adapter    "javascript"   : 7.9.0    , installed 7.8.0  [Updatable]
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "vis-2"        : 2.9.42   , installed 2.9.42
    Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
    Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.2 [Updatable]
    Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
    Objects and States
    Objects: 	12783
    States: 	8083
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 13
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16496      735/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       18735      1383/adb
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16608      703/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16241      703/iobroker.js-con
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17928      1295/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16992      1109/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16498      735/sshd: /usr/sbin
    udp        0      0 0.0.0.0:36527           0.0.0.0:*                           1001       1059343    26291/io.broadlink2
    udp        0      0 0.0.0.0:34866           0.0.0.0:*                           1001       1912494    26291/io.broadlink2
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       1058465    26291/io.broadlink2
    udp        0      0 0.0.0.0:56000           0.0.0.0:*                           1001       18884      1448/io.ekey.0
    udp        0      0 0.0.0.0:48200           0.0.0.0:*                           104        14637      580/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14635      580/avahi-daemon: r
    udp6       0      0 :::57193                :::*                                104        14638      580/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        14636      580/avahi-daemon: r
    2024-03-14 16:03:42.945  - debug: zwave2.0 (30878) Node 28: value updated: value_electric_kwh_consumed => 54.43
    2024-03-14 16:03:43.191  - debug: zwave2.0 (30878) Node 10: metadata updated: value_electric_kwh_consumed
    2024-03-14 16:03:43.193  - debug: zwave2.0 (30878) Node 10: value updated: value_electric_kwh_consumed => 1.64
    2024-03-14 16:03:43.264  - debug: zwave2.0 (30878) Node 10: metadata updated: power
    2024-03-14 16:03:43.267  - debug: zwave2.0 (30878) Node 10: value updated: power => 0.5
    2024-03-14 16:03:43.341  - debug: zwave2.0 (30878) Node 10: metadata updated: power
    2024-03-14 16:03:43.348  - debug: zwave2.0 (30878) Node 10: value updated: power => 0.5
    2024-03-14 16:03:43.400  - debug: zwave2.0 (30878) Node 26: metadata updated: power
    2024-03-14 16:03:43.402  - debug: zwave2.0 (30878) Node 26: value updated: power => 0.5
    2024-03-14 16:03:43.606  - debug: zwave2.0 (30878) Node 9: metadata updated: value_001_electric_w_consumed
    2024-03-14 16:03:43.609  - debug: zwave2.0 (30878) Node 9: value updated: value_001_electric_w_consumed => 0.8
    2024-03-14 16:03:43.749  - debug: zwave2.0 (30878) Node 45: metadata updated: value_electric_kwh_consumed
    2024-03-14 16:03:43.751  - debug: zwave2.0 (30878) Node 45: value updated: value_electric_kwh_consumed => 0.92
    2024-03-14 16:03:44.346  - debug: zwave2.0 (30878) Node 24: metadata updated: value_electric_kwh_consumed
    2024-03-14 16:03:44.348  - debug: zwave2.0 (30878) Node 24: value updated: value_electric_kwh_consumed => 1.71
    2024-03-14 16:03:44.397  - debug: zwave2.0 (30878) Node 24: metadata updated: power
    2024-03-14 16:03:44.399  - debug: zwave2.0 (30878) Node 24: value updated: power => 0.5
    2024-03-14 16:03:44.447  - debug: zwave2.0 (30878) Node 4: metadata updated: value_002_electric_w_consumed
    2024-03-14 16:03:44.449  - debug: zwave2.0 (30878) Node 4: value updated: value_002_electric_w_consumed => 0
    2024-03-14 16:03:44.464  - debug: zwave2.0 (30878) Node 24: metadata updated: power
    2024-03-14 16:03:44.466  - debug: zwave2.0 (30878) Node 24: value updated: power => 0.5
    2024-03-14 16:03:44.746  - debug: zwave2.0 (30878) Node 22: metadata updated: power
    2024-03-14 16:03:44.748  - debug: zwave2.0 (30878) Node 22: value updated: power => 4.1
    2024-03-14 16:03:45.255  - debug: zwave2.0 (30878) Node 30: metadata updated: value_electric_kwh_consumed
    2024-03-14 16:03:45.256  - debug: zwave2.0 (30878) Node 30: value updated: value_electric_kwh_consumed => 4.32
    			v.2023-10-10
           Icon name: computer
        Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		arm64
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Pending OS-Updates: 	13
    Pending iob updates: 	2
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
    			/usr/bin/npm 		10.2.4
    			/usr/bin/npx 		10.2.4
    Recommended versions are nodejs 18.19.1 and npm 10.2.4
    MEMORY:
    Mem:            4.0G        2.3G        653M        1.3M        1.2G        1.7G
    Swap:           104M          0B        104M
    Total:          4.1G        2.3G        758M
    Active iob-Instances: 	20
    ioBroker Core: 		js-controller 		5.0.19
    			admin 			6.15.2
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		12783
    States: 		8083
    Size of iob-Database:
    23M	/opt/iobroker/iobroker-data/states.jsonl
    Einige Passagen (beispielsweise Informationen über das Filesystem) habe ich gelöscht, da sie hier nichts zu suchen haben.
    Ein Problem habe ich schon gefunden:
    Current issues:
    Da muss ich mal schauen, was das ist und welche Gründe das haben könnte.
    @klausstoertebeker sagte in ioBroker reagiert sehr langsam oder garnicht:
    und warum meinst du das?
    ein volles Laufwerk stört schon die Funktion :-)
    KlausStoertebekerK 1 Antwort Letzte Antwort
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      ioBroker_user
      /home/ioBroker_user
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3792 M total memory
               2174 M used memory
                601 M free memory
                111 M buffer memory
                989 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      793M	/var/
      351M	/var/cache
      345M	/var/cache/apt
      181M	/var/log
      USB-Devices by-id:
      /usr/bin/npm 		10.2.4
      /usr/bin/npx 		10.2.4
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.15.2
      javascript: 	7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	12783
      States: 	8083
      Pending Updates: 13
      			v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Kernel: 		aarch64
      Userland: 		arm64
      User-ID: 		1000
      X-Server: 		false
      			/usr/bin/npm 		10.2.4
      			/usr/bin/npx 		10.2.4
      MEMORY:
      Swap:           104M          0B        104M
      			admin 			6.15.2
      Objects type: jsonl
      States  type: jsonl
      Objects: 		12783
      States: 		8083
      Current issues:
      was das ist
      ein zu schwaches Netzteil
      • arteckA arteck
        weil die Befehlskette vollgelaufen ist
        das ist dein Problem..
        du schriebst nicht wie gross dein Netzwerk ist.. aber je grösse es ist desto mehr Geräte melden isch mit deren Daten und das kann sehr Netzbelastend sein.
        https://zwave-js.github.io/node-zwave-js/#/troubleshooting/network-health?id=optimizing-the-reporting-configuration
        KlausStoertebekerK Offline
        KlausStoertebeker
        @arteck
        Naja, ein paar Z-Wave-Geräte habe ich schon:
        4  Fibaro FGS-223 Unterputzdoppelschalter 2 (2)	Binary Power Switch
        7  Fibaro FGMS-001 Bewegungssensor (2)	Notification Sensor
        8  Fibaro FGRGBW-442 RGBW-Controller 2 (1)	Tunable Color Switch
        9  Fibaro FGS-213 Unterputzschalter 2 (2)	Binary Power Switch
        10 Fibaro FGWP-102 Zwischenstecker (3)	Binary Power Switch
        11 Fibaro FGWP-102 Zwischenstecker (5)	Binary Power Switch
        12 Fibaro FGWP-102 Zwischenstecker (6)	Binary Power Switch
        13 Fibaro FGS-223 Unterputzdoppelschalter 2 (1)	Binary Power Switch
        14 Fibaro FGS-213 Unterputzschalter 2 (1)	Binary Power Switch
        18 ABUS HomeTec CFA3010 Türschloßantrieb (1)	Secure Keypad Door Lock
        19 Fibaro FGBS-222 Smart Implant (1)	Notification Sensor
        20 Fibaro FGMS-001 Bewegungssensor (1)	Notification Sensor
        21 Fibaro FGS-213 Unterputzschalter 2 (4)	Binary Power Switch
        22 Fibaro FGWP-102 Zwischenstecker (10)	Binary Power Switch
        23 Fibaro FGWP-102 Zwischenstecker (11)	Binary Power Switch
        24 Fibaro FGWP-102 Zwischenstecker (12)	Binary Power Switch
        25 Fibaro FGWP-102 Zwischenstecker (9)	Binary Power Switch
        26 Fibaro FGWP-102 Zwischenstecker (8)	Binary Power Switch
        27 Fibaro FGS-213 Unterputzschalter 2 (3)	Binary Power Switch
        28 Fibaro FGWP-102 Zwischenstecker (1)	Binary Power Switch
        29 Fibaro FGWP-102 Zwischenstecker (2)	Binary Power Switch
        30 Fibaro FGWP-102 Zwischenstecker (13)	Binary Power Switch
        31 Fibaro FGSD-002 Rauchmelder (5)	Notification Sensor
        32 Fibaro FGSD-002 Rauchmelder (1)	Notification Sensor
        33 Fibaro FGSD-002 Rauchmelder (4)	Notification Sensor
        34 Fibaro FGSD-002 Rauchmelder (3)	Notification Sensor
        35 Fibaro FGSD-002 Rauchmelder (2)	Notification Sensor
        36 Fibaro FGWP-102 Zwischenstecker (7)	Binary Power Switch
        37 Fibaro FGDW-002 Tür-/Fenstersensor 2 (1)	Notification Sensor
        38 Eurotronic Spirit-Thermostatventil (1)	General Thermostat V2
        40 Eurotronic Spirit-Thermostatventil (3)	General Thermostat V2
        41 Eurotronic Spirit-Thermostatventil (4)	General Thermostat V2
        42 Eurotronic Spirit-Thermostatventil (5)	General Thermostat V2
        45 Fibaro FGWP-102 Zwischenstecker (15)	Binary Power Switch
        46 Fibaro FGWP-102 Zwischenstecker (14)	Binary Power Switch
        47 Fibaro FGMS-001 Bewegungssensor (3)	Notification Sensor
        48 Secure SRT321 Wandthermostat (1)	General Thermostat V2
        49 Secure SRT321 Wandthermostat (2)	General Thermostat V2
        50 Secure SRT321 Wandthermostat (3)	General Thermostat V2
        51 Secure SRT321 Wandthermostat (4)	General Thermostat V2
        52 Secure SRT321 Wandthermostat (5)	General Thermostat V2
        63 Z-Wave.Me WALLC-S Wandschalter (2)	Basic Wall Controller
        64 Z-Wave.Me WALLC-S Wandschalter (3)	Basic Wall Controller
        66 Z-Wave.Me WALLC-S Wandschalter (1)	Basic Wall Controller
        67 Z-Wave.Me WALLC-S Wandschalter (4)	Basic Wall Controller
        69 Eurotronic Spirit-Thermostatventil (2)	General Thermostat V2
        70 Fibaro FGWP-102 Zwischenstecker (4)	Binary Power Switch
        72 Fibaro FGWP-102 Zwischenstecker (16)	Binary Power Switch
        74 Fibaro FGS-213 Unterputzschalter 2 (7)	Binary Power Switch
        ioBroker-Host: Raspberry Pi 5 (8GByte RAM) mit Halo8-KI-Hat, Argon ONE M.2-Gehäuse mit 256GByte PCIe-SSD
          KlausStoertebeker
          Moin homoran,
          Ich glaube, es geht hier niemanden etwas an, welche NAS und darauf gemountetes Freigabeordner ich habe. Und mein Raspberry hat keine SD-Karte, sondern eine 256GByte-SSD ;-) Und das Laufwerk ist noch lange nicht voll.
          Und ich speichere meine Date in einer InfluxDB V2 auf einem NAS...
          HomoranH W 2 Antworten Letzte Antwort
            was das ist
            KlausStoertebeker
            @homoran said in ioBroker reagiert sehr langsam oder garnicht:
            was das ist
            Ja, aber das muss ich mir anschauen. Denn ich glaube, ich habe ein Original-Raspberry 4B-Netzteil im Einsatz
              Moin homoran,
              @klausstoertebeker Naja, wenn man bei "reagieet sehr langsam" wirklich helfen soll sind die I/O Vorgänge nicht eirklich uninteressant
                was das ist
                was das ist
                Was gar nichts aussagt, wenn da noch eine SSD dran hängt ohne eigene Stromversorgung, womöglich noch am USB3
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  ioBroker_user
                  /home/ioBroker_user
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Swap:           104M          0B        104M
                           3792 M total memory
                           2174 M used memory
                            601 M free memory
                            111 M buffer memory
                            989 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  793M	/var/
                  351M	/var/cache
                  345M	/var/cache/apt
                  181M	/var/log
                  USB-Devices by-id:
                  /usr/bin/npm 		10.2.4
                  /usr/bin/npx 		10.2.4
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.15.2
                  javascript: 	7.8.0
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	12783
                  States: 	8083
                  Pending Updates: 13
                  			v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                  Kernel: 		aarch64
                  Userland: 		arm64
                  User-ID: 		1000
                  X-Server: 		false
                  			/usr/bin/npm 		10.2.4
                  			/usr/bin/npx 		10.2.4
                  MEMORY:
                  Swap:           104M          0B        104M
                  			admin 			6.15.2
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		12783
                  States: 		8083
                  Current issues:
                  Lösch da nix raus, das ist alles hilfreich bei einer Fehlersuche.
                  Sicherheitsrelevantes sieht man da auch nicht. Wer in deinem Netz zu besuch ist kann sich das (und noch viel mehr) eh anschauen.
                  Pending Updates: 13
                  Fehlende Updates sind da schon eher sicherheitsrelevant. Bring lieber die Kiste auf einen aktuellen Stand. Inkl. Kernel-Update auf Kernel 6.6.
                    Moin homoran,
                    W Offline
                    W Offline
                    warp735
                    Was sollte man denn mit diesen Informationen "anstellen" können?!
                      Pending Updates: 13
                      KlausStoertebeker
                      schrieb am zuletzt editiert von KlausStoertebeker
                      @thomas-braun said in ioBroker reagiert sehr langsam oder garnicht:
                      Pending Updates: 13
                      Das mit den Updates ist korrekt und ich behebe es gerade.
                      Aber hier muss niemand eine Kopie meiner fstab sehen. Wissen nur soweit notwendig. Natürlich hast Du recht, dass jemand, der in meinem Heimatnetz unterwegs ist, unter Umständen auch noch mehr sehen kann. Aber ich muss ja potentielle Angreifer nicht dabei unterstützen, Angriffsvektoren zu entwickeln...
                        KlausStoertebeker
                        Ja, verstehe ich. Soll ich dann das gesamte Log hier posten oder nur den Anteil Z-Wave?
                          du machst es uns extra schwer!
                          loggst du da Werte in der Influx?
                          klemmtves da?
                          viel zu viele Kombinationsmöglichkeiten potentieller Troublemaker.
                          Genau um diese Diskussionen zu vermeiden ist iob diag entwickelt worden um alle potentiellen Dinge in einer Übersicht zur Verfügung zu haben.
                          Ob einzelne Positionen relevant sind weiss man erst später.
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            bevor das hier ausartet ...
                            du musst die Sendezeiten anpassen von jedem ZWave Gerät..
                            unter configuration.. so dass diese nicht das Netz blokieren.. bei der Menge an Geräte ist es der Fall
                            was du zu tun hast steht im Link
