  4. ioB stürzt während (Influx) Backup ab
27 Beiträge 5 Kommentatoren 1.1k Aufrufe 4 Beobachtet
  • A Atuk
    Ok, weiß ich Bescheid.
    Hab gerade noch zwei Backup Versuche durchgeführt. Beide male stürtzte IOB ab. Seltsamerweise immer an einer anderen Stelle der Prozedur. Dies ist ist der Inhalt des Fensters der letzten Backitup-Ausführung:
    Started iobroker ...
    [DEBUG] [iobroker] - host.iobroker-pi 9587 states saved
    [DEBUG] [iobroker] - host.iobroker-pi 11293 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_03_08-15_50_46_backupiobroker.tar.gz
    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Packed 68MB so far...
    [DEBUG] [influxDB] - Packed 136MB so far...
    [DEBUG] [influxDB] - Packed 204MB so far...
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_03_08-15_50_54_backupiobroker"
    [ERROR] [influxDB] - The temporary directory "/opt/iobroker/backups/influxDB_2024_03_08-15_50_54_backupiobroker" could not be deleted. Please check the directory permissions and delete the directory manually
    [ERROR] [influxDB] - Error: EIO: i/o error, lstat '/opt/iobroker/backups/influxDB_2024_03_08-15_50_54_backupiobroker/20240308T145054Z.s33.tar.gz'
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [ERROR] [historyHTML] - history html could not be created: Error: Cannot find module '../admin/i18n/de/translations.json'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.backitup/lib/tools.js
    - /opt/iobroker/node_modules/iobroker.backitup/main.js
    ... und Absturz 😫
    @atuk sagte in ioB stürzt während (Influx) Backup ab:
    Ich würde sagen: Dateisystem wurmstichig.
    • A Atuk
      Guten Tag Zusammen,
      mein IOBroker lief zwei Jahre ohne Probleme durch. Nun musste ich nach einem Systemcrash neu aufsetzen. Dazu bediente ich mich des Images für den Raspi von der IOBroker-Download Page und konnte nach weiterer Installation von Influx und Grafana sowie einspielen meiner Backups alles wieder ans laufen bringen.
      Seit diesem Zeitpunkt kommt es allerdings bei jedem Backup (solang Influx aktiviert ist) zu einem Systemabsturz, der nur durch Kaltstart zu beheben ist. Während der Backups kommt es immer wieder zu unterschiedlichen Fehlermeldungen, die wohl irgendwas mit Schreibrechten zu tun haben:
      In einem Fall bekam ich sogar Meldungen aus der Konsole:
      Leider sind meine Systemkenntnisse was den Raspi bzw. Debian angeht noch etwas rudimentär, deshalb kann ich die Meldungen nicht wirklich deuten, gar Abhilfe schaffen.
      Der Raspi läuft mit einer SSD, IoBroker selbst und alle Adapter sind auf dem neuesten Stand, InfluxDB laüft in der Version 1.
      Hat jemand eine Idee was die Ursache für die Abstürze ist?
      VG Olli
      reutli
      schrieb am zuletzt editiert von reutli
      Warum das denn???
      Dort steht eindeutig:
      Wenn ich die ganzen Fehler im Dateisystem so lese, dann würde ich mir überlegen, nochmals alles neu (und richtig) zu machen.
      ... und das Dateisystem ist fritte...
      Edit: Thomas war schneller....
      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
      *Wer freundlich ist, dem wird freundlich geholfen *
      • R reutli
        Warum das denn???
        Atuk
        schrieb am zuletzt editiert von Atuk
        @reutli
        Tja, der Plan war den Rapsi mit zur Nachtschicht zu nehmen, dort mit dem Image zu befeuern und schonmal verschiedene Grundeinstellung zu machen um ihn dann Morgens in mein Netzwerk zu Hause zu integrieren 😁
        Bin davon ausgegangen, dass das Image ebenbürtig zur Installation per curl Befehl ist. :man-tipping-hand:
        Nun also nochmal von vorne. Zum Glück ist Morgen frei...
        Trotzdem war das Ganze nicht ohne Lerneffekt für mich und deshalb besten Dank an alle Beteiligten 👍
        VG Olli
        HomoranH R 2 Antworten Letzte Antwort
        • A Atuk
          @reutli
          VG Olli
          HomoranH Offline
          HomoranH Offline
          sollte es auch (gewesen) sein!
          Dein Hauptproblem ist dein zerschossenes Dateisystem.
          Nach Strom weg während eines Speichervorgangs kann man nie sagen welche Daten korrupt sind.
          Weiter damit arbeiten ist wie russisch Roulette.
          gute Einstellung!
          • A Atuk
            @reutli
            VG Olli
            reutli
            Das kann ich nicht beurteilen, weil ich noch nie vom Image installiert habe.
            AUf jeden Fall würde ich die SD-Karte noch auf "Herz und NIeren" testen oder eine neue nehmen. Da scheint mir was nciht zu passen. Nicht dass DU dir die ganze. Mühe machst und am Ende hängt es an der SD Karte
            • R reutli
              Atuk
              @reutli
              Ich arbeite mit einer Samsung SSD am USB Anschluss.
              • HomoranH Offline
                HomoranH Offline
                @reutli
                und aktivem Hub?
                ...am USB2?
                  @reutli
                  und aktivem Hub?
                  ...am USB2?
                  Atuk
                  Ohne HUB direkt am USB2.
                  • A Atuk
                    HomoranH Offline
                    HomoranH Offline
                    reicht die Leistung des Netzteils?
                      Atuk
                      Original USB-C Raspberry Netzteil :man-shrugging:
                      • A Atuk
                        HomoranH Offline
                        HomoranH Offline
                        ...das nicht für die zusätzliche Versorgung stromhungriger Zusatzgeräte gedacht ist.
                          Atuk
                          OK. Hat zwar fast zwei Jahre ohne Probleme funktioniert, aber dann werd ich mir sicherheitshalber trotzdem einen aktiven Hub zulegen. Schadet ja nicht und ich kann dies zukünftig als mögliche Fehlerquelle ausschliessen.
                          • A Atuk
                            HomoranH Offline
                            HomoranH Offline
                            genau!
                            ein I/O Error kann auch davon herrühren wenn die SSD wegen Spannungsschwankungen n7cht erreichbar ist.
                            Dies kann dann auch zu defekten Daten führen.
                              genau!
                              Atuk
                              OK. Danke für den Tip noch.
                              Ich bereite mich dann jetzt mal auf die Hardwareaufrüstung und Neuinstallation vor. 😖 😵
                                Atuk
                                Heute die SSD über Aktivhub angeschlossen. Backup durchlaufen lassen. Hat einwandfrei funktioniert. So banal :man-tipping-hand:
