  4. Test Adapter TrashSchedule
    6.0k
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 681.0k Aufrufe 171 Beobachtet
    @virus2k12
    systemctl status iobroker.service
    sagt?
    Virus2K12V Offline
    Virus2K12V Offline
    Virus2K12
    #1357
    @thomas-braun sagt: das alles läuft
    • DJMarc75D DJMarc75
      @virus2k12
      Dann starte mal den kompletten PI neu.
      Virus2K12V Offline
      Virus2K12V Offline
      Virus2K12
      #1358
      @djmarc75 zeigt trotzdem nichts an.
      na egal ich muss jetzt bissl schlafen, hab dann noch Nachtschicht.
      Danke erstmal soweit für die Tipps. Es läuft ja soweit.
      • Virus2K12V Virus2K12
        #1359
        @virus2k12 sagte in Test Adapter TrashSchedule:
        Zeigen, nix nacherzählen.
        Virus2K12V 1 Antwort Letzte Antwort
          Virus2K12V Offline
          Virus2K12V Offline
          Virus2K12
          #1360
          pi@raspberrypi:~ $ systemctl status iobroker.service
          * iobroker.service - ioBroker Server
               Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
               Active: active (running) since Thu 2024-03-07 13:41:39 CET; 27min ago
                 Docs: http://iobroker.net
             Main PID: 1239 (iobroker.js-con)
                Tasks: 374 (limit: 4915)
                  CPU: 1h 6min 20.668s
               CGroup: /system.slice/iobroker.service
                       |-1239 iobroker.js-controller
                       |-1454 io.admin.0
                       |-1466 io.history.0
                       |-1505 io.javascript.0
                       |-1525 io.telegram.0
                       |-1560 io.alexa2.0
                       |-1576 io.backitup.0
                       |-1614 io.hmip.0
                       |-1621 io.hue.0
                       |-1667 io.mqtt-client.0
                       |-1706 io.mqtt.1
                       |-1718 io.shelly.0
                       |-1759 io.sonoff.0
                       |-1773 io.tr-064.0
                       |-1801 io.tr-064.1
                       |-1812 io.tuya.0
                       |-1870 io.wifilight.0
                       |-1890 io.awtrix-light.0
                       |-1924 io.bring.0
                       |-1972 io.device-watcher.0
                       |-1983 io.discovery.0
                       |-2027 io.echarts.0
                       |-2068 io.hue-extended.0
                       |-2087 io.info.0
                       |-2160 io.simple-api.0
                       |-2171 io.snmp.0
                       |-2182 io.text2command.0
                       |-2211 io.trashschedule.0
                       |-2252 io.vesync.0
                       |-2263 io.vis-2.0
                       |-2305 io.vis-inventwo.0
                       |-2342 io.web.0
                       |-2349 io.wled.0
                       `-2372 io.ws.0
          Mar 07 13:42:13 raspberrypi bash[1239]: host.raspberrypi check instance "system>
          Mar 07 13:42:25 raspberrypi bash[1239]: ================================== > LO>
          Mar 07 13:42:28 raspberrypi bash[1239]: Send diag info: {"uuid":"a2e3c321-5dd7->
          pi@raspberrypi:~ $
                         |-1454 io.admin.0
                         |-1466 io.history.0
                         |-1525 io.telegram.0
                         |-1560 io.alexa2.0
                         |-1576 io.backitup.0
                         |-1614 io.hmip.0
                         |-1621 io.hue.0
                         |-1706 io.mqtt.1
                         |-1718 io.shelly.0
                         |-1759 io.sonoff.0
                         |-1773 io.tr-064.0
                         |-1801 io.tr-064.1
                         |-1812 io.tuya.0
                         |-1924 io.bring.0
                         |-2027 io.echarts.0
                         |-2087 io.info.0
                         |-2171 io.snmp.0
                         |-2252 io.vesync.0
                         |-2263 io.vis-2.0
                         |-2342 io.web.0
                         |-2349 io.wled.0
                         `-2372 io.ws.0
            pi@raspberrypi:~ $
            #1361
            @virus2k12
            Ruf das mal auf:
            curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
            Dürfte ein Netzwerk-Thema sein.
            • CodierknechtC Codierknecht
              @virus2k12
              Wie sieht denn Dein Schedule dazu aus?
              haus-automatisierungH Offline
              #1362
              @codierknecht sagte in Test Adapter TrashSchedule:
              @virus2k12
              Warum hast Du denn einen Neustart-Zeitplan für die Instanz hinterlegt? Ist nicht notwendig.
              Wird das überhaupt gebraucht?
              Nein. Das startet ja bei Dir die Instanz 2x jede Stunde neu. Warum sollte man das tun? Wäre das nötig, würde der Adapter das mitbringen. Ist halt auch eine Option für Experten und deswegen (aus Gründen) nur im Expertenmodus sichtbar.
              📚 Meine Dokumentation
                @virus2k12
                CodierknechtC Online
                Codierknecht
                #1363
                @haus-automatisierung
                Wie gesagt: Keine Ahnung, warum das drin ist.
                Vielleicht mal zu Testzwecken reingekommen und vergessen wieder zu entfernen.
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                  #1364
                  Expertenmodus einfach immer auslassen (wozu braucht man den überhaupt?) :)
                    Codierknecht
                    #1365
                    @haus-automatisierung sagte in Test Adapter TrashSchedule:
                    Ist er auch - in der Regel.
                    Und wenn ich ihn einschalte, dann nicht dauerhaft.
                    Um z.B. mal den Loglevel zu verändern.
                    Oder das Schedule für beispielsweise "iCal" oder "DasWetter", damit die ihre Daten nicht zu vollen Stunde holen.
                      #1366
                      Für Schedule-Adapter kann man den Zeitplan auch ohne Expertenmodus anpassen :)
                        Codierknecht
                        #1367
                        Stimmt. Das mache ich halt so selten ;-)
                        Für Loglevel braucht man den EM trotzdem. Aber eben auch nur sehr selten.
                          Hab mir eben auch mal den Adapter gegönnt ;)
                          Bei mir funktioniert die 3.2.0 auch mit Loglevel "Info" völlig problemlos.
                          Dito
                          möchte wissen woran das liegt.
                          vll zeigst Du uns mal die Ausgabe von:
                          iob diag
                          Virus2K12V Offline
                          Virus2K12V Offline
                          Virus2K12
                          #1368
                          @djmarc75
                          Copy text starting here:
                          			v.2023-10-25
                           Static hostname: raspberrypi
                                 Icon name: computer
                          Operating System: Raspbian GNU/Linux 12 (bookworm)
                                    Kernel: Linux 5.10.103-v7l+
                              Architecture: arm
                          Installation: 		native
                          Kernel: 		armv7l
                          Userland: 		armhf
                          Timezone: 		Europe/Berlin (CET, +0100)
                          User-ID: 		1000
                          X-Server: 		true
                          Boot Target: 		graphical.target
                          Pending OS-Updates: 	0
                          Pending iob updates: 	1
                          Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                          			/usr/bin/node 		v18.19.1
                          			/usr/bin/npm 		10.5.0
                          			/usr/bin/npx 		10.5.0
                          			/usr/bin/corepack 	0.22.0
                          Recommended versions are nodejs 18.19.1 and npm 10.2.4
                          MEMORY:
                          Mem:            4.0G        3.0G        487M         13M        705M        1.0G
                          Swap:           104M        104M        4.1K
                          Total:          4.1G        3.1G        487M
                          Active iob-Instances: 	34
                          Active repo(s): Beta (latest)
                          ioBroker Core: 		js-controller 		5.0.19
                          			admin 			6.15.2
                          ioBroker Status: 	iobroker is running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                          Objects: 		21621
                          States: 		14503
                          Size of iob-Database:
                          27M	/opt/iobroker/iobroker-data/objects.jsonl
                          115M	/opt/iobroker/iobroker-data/states.jsonl
                          === Mark text until here for copying ===
                            @djmarc75
                            			v.2023-10-25
                                   Icon name: computer
                                Architecture: arm
                            Kernel: 		armv7l
                            Userland: 		armhf
                            User-ID: 		1000
                            X-Server: 		true
                            			/usr/bin/npm 		10.5.0
                            			/usr/bin/npx 		10.5.0
                            MEMORY:
                            			admin 			6.15.2
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		21621
                            States: 		14503
                            #1369
                            @virus2k12
                            Da stimmt was nicht mit npm.
                            iob stop
                            sudo apt install --reinstall nodejs
                            iob restart
                            Und dann nochmal die Langfassung von iob diag.
                            Finger von npm lassen!
                              @virus2k12
                              iob stop
                              iob restart
                              Codierknecht
                              #1370
                              @Virus2K12
                              ... und den Desktop ausschalten.
                                @Virus2K12
                                #1371
                                @Virus2K12
                                Oh, ganz übersehen. Natürlich.
                                Und auch mal prüfen, ob die Hardware nicht 64Bit verträgt.
                                • Virus2K12V Offline
                                  Virus2K12V Offline
                                  Virus2K12
                                  #1372
                                  Desktop aus und reinstall nodejs gemacht.
                                  Hier jetzt erst einmal die lange Fassung von iob diag
                                  Skript v.2023-10-25
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm
                                  Model		: Raspberry Pi 4 Model B Rev 1.1
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : armv7l
                                  Userland        : armhf
                                  Systemuptime and Load:
                                   11:46:10 up 4 min,  1 user,  load average: 4.35, 2.76, 1.17
                                  CPU threads: 4
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  *** Time and Time Zones ***
                                                 Local time: Fri 2024-03-08 11:46:10 CET
                                             Universal time: Fri 2024-03-08 10:46:10 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  pi
                                  /home/pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                  *** X-Server-Setup ***
                                  X-Server: 	false
                                  Desktop:
                                  Terminal: 	tty
                                  Boot Target: 	multi-user.target
                                  *** MEMORY ***
                                  Mem:            4.0G        2.4G        670M        4.8M        1.1G        1.6G
                                  Swap:           104M          0B        104M
                                  Total:          4.1G        2.4G        775M
                                           3837 M total memory
                                           2303 M used memory
                                            235 M active memory
                                           2842 M inactive memory
                                            638 M free memory
                                            244 M buffer memory
                                            788 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FAILED SERVICES ***
                                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                  * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                                  1 loaded units listed.
                                  *** FILESYSTEM ***
                                  /dev/root      ext4      219G   24G  185G  12% /
                                  devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                  tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                                  tmpfs          tmpfs     768M  2.1M  766M   1% /run
                                  tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                                  /dev/loop1     squashfs   43M   43M     0 100% /snap/certbot/3642
                                  /dev/loop2     squashfs   91M   91M     0 100% /snap/core/16207
                                  /dev/loop0     squashfs   42M   42M     0 100% /snap/certbot/3568
                                  /dev/loop4     squashfs   54M   54M     0 100% /snap/core20/2106
                                  /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16575
                                  /dev/loop5     squashfs   54M   54M     0 100% /snap/core20/2185
                                  /dev/sda1      vfat      253M   93M  160M  37% /boot
                                  tmpfs          tmpfs     384M   80K  384M   1% /run/user/1000
                                  [Fri Mar  8 11:41:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:4F:AC:15 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=048e52a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles fsck.mode=force cfg80211.ieee80211_regdom=DE
                                  [Fri Mar  8 11:41:27 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                  [Fri Mar  8 11:41:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                  [Fri Mar  8 11:42:02 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                                  Show mounted filesystems:
                                  TARGET                         SOURCE      FSTYPE      OPTIONS
                                  /                              /dev/sda2   ext4        rw,noatime
                                  |-/dev                         devtmpfs    devtmpfs    rw,relatime,size=1800056k,nr_inodes=84157,mode=755
                                  | |-/dev/shm                   tmpfs       tmpfs       rw,nosuid,nodev
                                  | |-/dev/pts                   devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                  | `-/dev/mqueue                mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                                  |-/proc                        proc        proc        rw,relatime
                                  | `-/proc/sys/fs/binfmt_misc   systemd-1   autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                  |   `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                                  |-/sys                         sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/kernel/security       securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/fs/cgroup             cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                  | |-/sys/fs/bpf                none        bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                                  | |-/sys/kernel/debug          debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/kernel/tracing        tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/fs/fuse/connections   fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                                  | `-/sys/kernel/config         configfs    configfs    rw,nosuid,nodev,noexec,relatime
                                  |-/run                         tmpfs       tmpfs       rw,nosuid,nodev,size=785972k,nr_inodes=819200,mode=755
                                  | |-/run/lock                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                                  | |-/run/credentials/systemd-sysctl.service
                                  | |                            none        ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                  | |-/run/credentials/systemd-sysusers.service
                                  | |-/run/credentials/systemd-tmpfiles-setup-dev.service
                                  | |-/run/rpc_pipefs            sunrpc      rpc_pipefs  rw,relatime
                                  | |-/run/credentials/systemd-tmpfiles-setup.service
                                  | `-/run/user/1000             tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=392984k,nr_inodes=98246,mode=700,uid=1000,gid=1000
                                  |-/snap/certbot/3642           /dev/loop1  squashfs    ro,nodev,relatime
                                  |-/snap/core/16207             /dev/loop2  squashfs    ro,nodev,relatime
                                  |-/snap/certbot/3568           /dev/loop0  squashfs    ro,nodev,relatime
                                  |-/snap/core20/2106            /dev/loop4  squashfs    ro,nodev,relatime
                                  |-/snap/core/16575             /dev/loop3  squashfs    ro,nodev,relatime
                                  |-/snap/core20/2185            /dev/loop5  squashfs    ro,nodev,relatime
                                  `-/boot                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-r
                                  /var:
                                  3.6G	/var/
                                  2.1G	/var/log
                                  1.9G	/var/log/journal/a86ff8ac034a41cc8294fe68053416f8
                                  1.3G	/var/lib
                                  Archived and active journals take up 1.8G in the file system.
                                  /opt/iobroker/backups:
                                  178M	/opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  741M	/opt/iobroker/iobroker-data/
                                  523M	/opt/iobroker/iobroker-data/files
                                  89M	/opt/iobroker/iobroker-data/files/echarts.admin
                                  80M	/opt/iobroker/iobroker-data/backup-objects
                                  57M	/opt/iobroker/iobroker-data/files/javascript.admin
                                  du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c3ec73ec5450fb4cac984fc867dd54eb.js': No such file or directory
                                  du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c351437da7e800bc3d9409c431052f9c.js': No such file or directory
                                  109M	/opt/iobroker/iobroker-data/states.jsonl
                                  35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                  31M	/opt/iobroker/iobroker-data/objects.jsonl
                                  24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                  24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                  USB-Devices by-id:
                                  *** NodeJS-Installation ***
                                  /usr/bin/npm 		10.2.4
                                  /usr/bin/npx 		10.2.4
                                  nodejs:
                                    Installed: 18.19.1-1nodesource1
                                    Candidate: 18.19.1-1nodesource1
                                    Version table:
                                   *** 18.19.1-1nodesource1 600
                                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                       18.19.0+dfsg-6~deb12u1+rpi1 500
                                          500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                                       18.19.0-1nodesource1 600
                                       18.18.2-1nodesource1 600
                                       18.18.1-1nodesource1 600
                                       18.18.0-1nodesource1 600
                                       18.17.1-1nodesource1 600
                                       18.17.0-1nodesource1 600
                                       18.16.1-1nodesource1 600
                                       18.16.0-1nodesource1 600
                                       18.15.0-1nodesource1 600
                                       18.14.2-1nodesource1 600
                                       18.14.1-1nodesource1 600
                                       18.14.0-1nodesource1 600
                                       18.13.0-1nodesource1 600
                                       18.12.0-1nodesource1 600
                                       18.11.0-1nodesource1 600
                                       18.10.0-1nodesource1 600
                                       18.9.1-1nodesource1 600
                                       18.9.0-1nodesource1 600
                                       18.8.0-1nodesource1 600
                                       18.7.0-1nodesource1 600
                                       18.6.0-1nodesource1 600
                                       18.5.0-1nodesource1 600
                                       18.4.0-1nodesource1 600
                                       18.3.0-1nodesource1 600
                                       18.2.0-1nodesource1 600
                                       18.1.0-1nodesource1 600
                                       18.0.0-1nodesource1 600
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  js-controller: 	5.0.19
                                  admin: 		6.15.2
                                  javascript: 	7.8.0
                                  Adapters from github: 	1
                                  Adapter State
                                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                  + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, compact disabled, port: 80
                                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                                    system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                                    system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                                  + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, compact disabled, port: 1884
                                    system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
                                    system.adapter.netatmo-crawler.1        : netatmo-crawler       : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.vesync.0                 : vesync                : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
                                  + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                                    system.adapter.vis-homekittiles.0       : vis-homekittiles      : raspberrypi                              -  enabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                                    system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled, compact disabled
                                    system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                                    system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                    system.adapter.vis-owl.0                : vis-owl               : raspberrypi                              -  enabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                    system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled, compact disabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled, compact disabled
                                  + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                                  + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled, compact disabled
                                  + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  ioBroker-Repositories
                                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                  Installed ioBroker-Instances
                                  Used repository: Beta (latest)
                                  Adapter    "admin"        : 6.15.2   , installed 6.15.2
                                  Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                  Adapter    "awtrix-light" : 0.15.0   , installed 0.15.0
                                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                  Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                  Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                  Adapter    "device-watcher": 2.10.5  , installed 2.10.5
                                  Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                  Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                  Adapter    "espresense"   : 0.4.4    , installed 0.4.4
                                  Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                                  Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                  Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                  Adapter    "ical"         : 1.14.3   , installed 1.14.3
                                  Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                                  Adapter    "info"         : 2.0.0    , installed 2.0.0
                                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                  Controller "js-controller": 5.0.19   , installed 5.0.19
                                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                  Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                                  Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                  Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                                  Adapter    "snmp"         : 3.1.0    , installed 3.1.0
                                  Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                  Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                  Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                  Adapter    "vesync"       : 0.0.7    , installed 0.0.7
                                  Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                  Adapter    "vis-2"        : 2.9.40   , installed 2.9.40
                                  Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
                                  Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
                                  Adapter    "vis-homekittiles": 0.0.9 , installed 0.0.9
                                  Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                  Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
                                  Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                  Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                                  Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                  Adapter    "web"          : 6.2.5    , installed 6.2.5
                                  Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                                  Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                  Adapter    "ws"           : 2.5.11   , installed 2.5.11
                                  Objects and States
                                  Objects: 	21668
                                  States: 	14569
                                  Hit:1 http://linux.teamviewer.com/deb stable InRelease
                                  Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                                  Hit:3 http://archive.raspberrypi.org/debian bookworm InRelease
                                  Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Hit:5 https://packages.sury.org/php buster InRelease
                                  Update rpimonitor Packages Status
                                  Reading package lists... Done
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  Netid          State           Recv-Q          Send-Q                                 Local Address:Port                    Peer Address:Port         Process
                                  udp            UNCONN          0               0                                            0.0.0.0:6666                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=37))
                                  udp            UNCONN          0               0                                            0.0.0.0:6667                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=38))
                                  udp            UNCONN          0               0                                            0.0.0.0:5683                         0.0.0.0:*             users:(("io.shelly.0",pid=1704,fd=32))
                                  udp            UNCONN          0               0                                          127.0.0.1:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=11))
                                  udp            UNCONN          0               0                                            0.0.0.0:33903                        0.0.0.0:*             users:(("io.snmp.0",pid=2100,fd=29))
                                  udp            UNCONN          0               0                                            0.0.0.0:631                          0.0.0.0:*             users:(("cups-browsed",pid=1293,fd=7))
                                  udp            UNCONN          0               0                                    192.168.178.255:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=17))
                                  udp            UNCONN          0               0                                     192.168.178.51:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=16))
                                  udp            UNCONN          0               0                                            0.0.0.0:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=14))
                                  udp            UNCONN          0               0                                    192.168.178.255:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=19))
                                  udp            UNCONN          0               0                                     192.168.178.51:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=18))
                                  udp            UNCONN          0               0                                            0.0.0.0:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=15))
                                  udp            UNCONN          0               0                                            0.0.0.0:45212                        0.0.0.0:*             users:(("connmand",pid=570,fd=21))
                                  udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("io.wled.0",pid=2673,fd=21))
                                  udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.1",pid=1762,fd=29))
                                  udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.0",pid=1736,fd=30))
                                  udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=12))
                                  udp            UNCONN          0               0                                            0.0.0.0:47932                        0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=14))
                                  udp            UNCONN          0               0                                                  *:50208                              *:*             users:(("avahi-daemon",pid=456,fd=15))
                                  udp            UNCONN          0               0                                                  *:546                                *:*             users:(("connmand",pid=570,fd=18))
                                  udp            UNCONN          23616           0                        [fe80::ac64:680b:efa1:4b03]:546                                *:*             users:(("NetworkManager",pid=569,fd=24))
                                  udp            UNCONN          0               0                                              [::1]:53                                 *:*             users:(("connmand",pid=570,fd=12))
                                  udp            UNCONN          0               0                                                  *:5353                               *:*             users:(("avahi-daemon",pid=456,fd=13))
                                  tcp            LISTEN          0               128                                        127.0.0.1:5939                         0.0.0.0:*             users:(("teamviewerd",pid=1322,fd=12))
                                  tcp            LISTEN          0               4096                                         0.0.0.0:8083                         0.0.0.0:*             users:(("motion",pid=866,fd=5))
                                  tcp            LISTEN          0               10                                      127.0.0.1%lo:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=13))
                                  tcp            LISTEN          0               128                                          0.0.0.0:22                           0.0.0.0:*             users:(("sshd",pid=707,fd=3))
                                  tcp            LISTEN          0               128                                        127.0.0.1:631                          0.0.0.0:*             users:(("cupsd",pid=617,fd=7))
                                  tcp            LISTEN          0               5                                            0.0.0.0:8888                         0.0.0.0:*             users:(("rpimonitord",pid=754,fd=4))
                                  tcp            LISTEN          0               511                                          0.0.0.0:1883                         0.0.0.0:*             users:(("io.sonoff.0",pid=1711,fd=34))
                                  tcp            LISTEN          0               511                                          0.0.0.0:1884                         0.0.0.0:*             users:(("io.mqtt.1",pid=1666,fd=29))
                                  tcp            LISTEN          0               50                                           0.0.0.0:445                          0.0.0.0:*             users:(("smbd",pid=1348,fd=31))
                                  tcp            LISTEN          0               128                                          0.0.0.0:8765                         0.0.0.0:*             users:(("meyectl",pid=470,fd=12))
                                  tcp            LISTEN          0               4096                                         0.0.0.0:7999                         0.0.0.0:*             users:(("motion",pid=866,fd=7))
                                  tcp            LISTEN          0               511                                        127.0.0.1:9000                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=27))
                                  tcp            LISTEN          0               511                                        127.0.0.1:9001                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=21))
                                  tcp            LISTEN          0               80                                         127.0.0.1:3306                         0.0.0.0:*             users:(("mariadbd",pid=714,fd=27))
                                  tcp            LISTEN          0               50                                           0.0.0.0:139                          0.0.0.0:*             users:(("smbd",pid=1348,fd=32))
                                  tcp            LISTEN          0               511                                        127.0.0.1:6379                         0.0.0.0:*             users:(("redis-server",pid=620,fd=6))
                                  tcp            LISTEN          0               511                                                *:80                                 *:*             users:(("apache2",pid=799,fd=4),("apache2",pid=797,fd=4),("apache2",pid=796,fd=4),("apache2",pid=795,fd=4),("apache2",pid=794,fd=4),("apache2",pid=793,fd=4),("apache2",pid=739,fd=4))
                                  tcp            LISTEN          0               511                                                *:8081                               *:*             users:(("io.admin.0",pid=1419,fd=29))
                                  tcp            LISTEN          0               511                                                *:8082                               *:*             users:(("io.web.0",pid=2666,fd=29))
                                  tcp            LISTEN          0               511                                                *:8084                               *:*             users:(("io.ws.0",pid=2703,fd=28))
                                  tcp            LISTEN          0               10                                          [::1]%lo:53                              [::]:*             users:(("connmand",pid=570,fd=14))
                                  tcp            LISTEN          0               128                                             [::]:22                              [::]:*             users:(("sshd",pid=707,fd=4))
                                  tcp            LISTEN          0               511                                                *:8087                               *:*             users:(("io.simple-api.0",pid=2067,fd=28))
                                  tcp            LISTEN          0               128                                            [::1]:631                             [::]:*             users:(("cupsd",pid=617,fd=6))
                                  tcp            LISTEN          0               4096                                               *:3000                               *:*             users:(("grafana-server",pid=1295,fd=11))
                                  tcp            LISTEN          0               50                                              [::]:445                             [::]:*             users:(("smbd",pid=1348,fd=29))
                                  tcp            LISTEN          0               511                                            [::1]:6379                            [::]:*             users:(("redis-server",pid=620,fd=7))
                                  tcp            LISTEN          0               50                                              [::]:139                             [::]:*             users:(("smbd",pid=1348,fd=30))
                                  2024-03-08 11:46:19.657  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value": Connection is closed.]
                                  2024-03-08 11:46:19.659  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.
                                  2024-03-08 11:46:19.660  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.]
                                  2024-03-08 11:46:19.662  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.
                                  2024-03-08 11:46:19.664  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.]
                                  2024-03-08 11:46:19.666  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.
                                  2024-03-08 11:46:19.667  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.]
                                  2024-03-08 11:46:19.669  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.
                                  2024-03-08 11:46:19.671  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.]
                                  2024-03-08 11:46:19.673  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.
                                  2024-03-08 11:46:19.675  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.]
                                  2024-03-08 11:46:19.677  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.
                                  2024-03-08 11:46:19.680  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.]
                                  2024-03-08 11:46:19.682  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.
                                  2024-03-08 11:46:19.684  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.]
                                  2024-03-08 11:46:20.212  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                                  2024-03-08 11:46:21.158  - info: tuya.0 (1804) bf047f0676f4973f71uyin: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.59:6668
                                  2024-03-08 11:46:35.239  - info: tuya.0 (1804) bf7e8a579d18ba290elhqa: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.34:6668
                                  2024-03-08 11:46:40.760  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                  2024-03-08 11:46:40.844  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                  2024-03-08 11:47:01.160  - error: vesync.0 (2220) {"traceId":"1709894813723","code":-11302030,"msg":"device timeout","module":null,"stacktrace":null,"result":null}
                                  2024-03-08 11:47:42.466  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                  2024-03-08 11:47:42.960  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                  2024-03-08 11:48:40.996  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                                  2024-03-08 11:48:41.296  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                                  iob diag has finished.
                                  Press any key for a summary
                                    Virus2K12V Offline
                                    Virus2K12
                                    #1373
                                    zusammenfassung iob_diag
                                    			v.2023-10-25
                                           Icon name: computer
                                        Architecture: arm
                                    Kernel: 		armv7l
                                    Userland: 		armhf
                                    User-ID: 		1000
                                    X-Server: 		false
                                    			/usr/bin/npm 		10.2.4
                                    			/usr/bin/npx 		10.2.4
                                    MEMORY:
                                    Mem:            4.0G        2.7G        223M        4.8M        1.3G        1.3G
                                    Swap:           104M          0B        104M
                                    Total:          4.1G        2.7G        328M
                                    			admin 			6.15.2
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects: 		21668
                                    States: 		14569
                                    32M	/opt/iobroker/iobroker-data/objects.jsonl
                                    112M	/opt/iobroker/iobroker-data/states.jsonl
                                      Skript v.2023-10-25
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm
                                      Docker          : false
                                      Kernel          : armv7l
                                      Userland        : armhf
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server: 	false
                                      Desktop:
                                      Terminal: 	tty
                                      *** MEMORY ***
                                      Swap:           104M          0B        104M
                                               3837 M total memory
                                               2303 M used memory
                                                235 M active memory
                                                638 M free memory
                                                244 M buffer memory
                                                788 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      3.6G	/var/
                                      2.1G	/var/log
                                      1.3G	/var/lib
                                      USB-Devices by-id:
                                      /usr/bin/npm 		10.2.4
                                      /usr/bin/npx 		10.2.4
                                      nodejs:
                                        Version table:
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin: 		6.15.2
                                      javascript: 	7.8.0
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects: 	21668
                                      States: 	14569
                                      Pending Updates: 0
                                      #1374
                                      @virus2k12
                                      Hast du das per Dist-Upgrade von einer Vorversion auf 'Debian 12 - Bookworm' gebracht (bzw. es versucht?).
                                      Das funktioniert nicht. Neuinstallation von Null an.
                                        @virus2k12
                                        Virus2K12V Offline
                                        Virus2K12V Offline
                                        Virus2K12
                                        schrieb am zuletzt editiert von Virus2K12
                                        #1375
                                        @thomas-braun ja, von bullseye auf bookworm, aber schon vor ewigkeiten. Lief auch die ganze Zeit ohne Probleme.
                                        Zuletzt habe ich eine smb Freigabe für verschieden Verzeichnisse gemacht, kann es daran liegen zwecks Zugriffsrechte etc. ?
                                          #1376
                                          @virus2k12
                                          Aber nicht richtig.
                                          Der Kernel ist z. B. noch aus Bullseye-Zeiten.
