  4. Test Adapter TrashSchedule
    6.0k
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 681.0k Aufrufe 171 Beobachtet
    @virus2k12 sagte in Test Adapter TrashSchedule:
    sagt: das alles läuft
    Zeigen, nix nacherzählen.
    Virus2K12V Offline
    Virus2K12V Offline
    Virus2K12
    #1360
    pi@raspberrypi:~ $ systemctl status iobroker.service
    * iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
         Active: active (running) since Thu 2024-03-07 13:41:39 CET; 27min ago
           Docs: http://iobroker.net
       Main PID: 1239 (iobroker.js-con)
          Tasks: 374 (limit: 4915)
            CPU: 1h 6min 20.668s
         CGroup: /system.slice/iobroker.service
                 |-1239 iobroker.js-controller
                 |-1454 io.admin.0
                 |-1466 io.history.0
                 |-1505 io.javascript.0
                 |-1525 io.telegram.0
                 |-1560 io.alexa2.0
                 |-1576 io.backitup.0
                 |-1614 io.hmip.0
                 |-1621 io.hue.0
                 |-1667 io.mqtt-client.0
                 |-1706 io.mqtt.1
                 |-1718 io.shelly.0
                 |-1759 io.sonoff.0
                 |-1773 io.tr-064.0
                 |-1801 io.tr-064.1
                 |-1812 io.tuya.0
                 |-1870 io.wifilight.0
                 |-1890 io.awtrix-light.0
                 |-1924 io.bring.0
                 |-1972 io.device-watcher.0
                 |-1983 io.discovery.0
                 |-2027 io.echarts.0
                 |-2068 io.hue-extended.0
                 |-2087 io.info.0
                 |-2160 io.simple-api.0
                 |-2171 io.snmp.0
                 |-2182 io.text2command.0
                 |-2211 io.trashschedule.0
                 |-2252 io.vesync.0
                 |-2263 io.vis-2.0
                 |-2305 io.vis-inventwo.0
                 |-2342 io.web.0
                 |-2349 io.wled.0
                 `-2372 io.ws.0
    Mar 07 13:42:13 raspberrypi bash[1239]: host.raspberrypi check instance "system>
    Mar 07 13:42:25 raspberrypi bash[1239]: ================================== > LO>
    Mar 07 13:42:28 raspberrypi bash[1239]: Send diag info: {"uuid":"a2e3c321-5dd7->
    pi@raspberrypi:~ $
    • Virus2K12V Virus2K12
                   |-1454 io.admin.0
                   |-1466 io.history.0
                   |-1525 io.telegram.0
                   |-1560 io.alexa2.0
                   |-1576 io.backitup.0
                   |-1614 io.hmip.0
                   |-1621 io.hue.0
                   |-1706 io.mqtt.1
                   |-1718 io.shelly.0
                   |-1759 io.sonoff.0
                   |-1773 io.tr-064.0
                   |-1801 io.tr-064.1
                   |-1812 io.tuya.0
                   |-1924 io.bring.0
                   |-2027 io.echarts.0
                   |-2087 io.info.0
                   |-2171 io.snmp.0
                   |-2252 io.vesync.0
                   |-2263 io.vis-2.0
                   |-2342 io.web.0
                   |-2349 io.wled.0
                   `-2372 io.ws.0
      pi@raspberrypi:~ $
      #1361
      @virus2k12
      Ruf das mal auf:
      curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      Dürfte ein Netzwerk-Thema sein.
      • CodierknechtC Codierknecht
        @virus2k12
        Wie sieht denn Dein Schedule dazu aus?
        haus-automatisierungH Offline
        #1362
        @codierknecht sagte in Test Adapter TrashSchedule:
        @virus2k12
        Warum hast Du denn einen Neustart-Zeitplan für die Instanz hinterlegt? Ist nicht notwendig.
        Wird das überhaupt gebraucht?
        Nein. Das startet ja bei Dir die Instanz 2x jede Stunde neu. Warum sollte man das tun? Wäre das nötig, würde der Adapter das mitbringen. Ist halt auch eine Option für Experten und deswegen (aus Gründen) nur im Expertenmodus sichtbar.
        📚 Meine Dokumentation
          @virus2k12
          CodierknechtC Online
          Codierknecht
          #1363
          @haus-automatisierung
          Wie gesagt: Keine Ahnung, warum das drin ist.
          Vielleicht mal zu Testzwecken reingekommen und vergessen wieder zu entfernen.
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
            #1364
            Expertenmodus einfach immer auslassen (wozu braucht man den überhaupt?) :)
              Codierknecht
              #1365
              @haus-automatisierung sagte in Test Adapter TrashSchedule:
              Ist er auch - in der Regel.
              Und wenn ich ihn einschalte, dann nicht dauerhaft.
              Um z.B. mal den Loglevel zu verändern.
              Oder das Schedule für beispielsweise "iCal" oder "DasWetter", damit die ihre Daten nicht zu vollen Stunde holen.
                #1366
                Für Schedule-Adapter kann man den Zeitplan auch ohne Expertenmodus anpassen :)
                  Codierknecht
                  #1367
                  Stimmt. Das mache ich halt so selten ;-)
                  Für Loglevel braucht man den EM trotzdem. Aber eben auch nur sehr selten.
                  • DJMarc75D DJMarc75
                    Hab mir eben auch mal den Adapter gegönnt ;)
                    Bei mir funktioniert die 3.2.0 auch mit Loglevel "Info" völlig problemlos.
                    Dito
                    möchte wissen woran das liegt.
                    vll zeigst Du uns mal die Ausgabe von:
                    iob diag
                    Virus2K12V Offline
                    Virus2K12V Offline
                    Virus2K12
                    #1368
                    @djmarc75
                    Copy text starting here:
                    			v.2023-10-25
                     Static hostname: raspberrypi
                           Icon name: computer
                    Operating System: Raspbian GNU/Linux 12 (bookworm)
                              Kernel: Linux 5.10.103-v7l+
                        Architecture: arm
                    Installation: 		native
                    Kernel: 		armv7l
                    Userland: 		armhf
                    Timezone: 		Europe/Berlin (CET, +0100)
                    User-ID: 		1000
                    X-Server: 		true
                    Boot Target: 		graphical.target
                    Pending OS-Updates: 	0
                    Pending iob updates: 	1
                    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
                    			/usr/bin/node 		v18.19.1
                    			/usr/bin/npm 		10.5.0
                    			/usr/bin/npx 		10.5.0
                    			/usr/bin/corepack 	0.22.0
                    Recommended versions are nodejs 18.19.1 and npm 10.2.4
                    MEMORY:
                    Mem:            4.0G        3.0G        487M         13M        705M        1.0G
                    Swap:           104M        104M        4.1K
                    Total:          4.1G        3.1G        487M
                    Active iob-Instances: 	34
                    Active repo(s): Beta (latest)
                    ioBroker Core: 		js-controller 		5.0.19
                    			admin 			6.15.2
                    ioBroker Status: 	iobroker is running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                    Objects: 		21621
                    States: 		14503
                    Size of iob-Database:
                    27M	/opt/iobroker/iobroker-data/objects.jsonl
                    115M	/opt/iobroker/iobroker-data/states.jsonl
                    === Mark text until here for copying ===
                      @djmarc75
                      			v.2023-10-25
                             Icon name: computer
                          Architecture: arm
                      Kernel: 		armv7l
                      Userland: 		armhf
                      User-ID: 		1000
                      X-Server: 		true
                      			/usr/bin/npm 		10.5.0
                      			/usr/bin/npx 		10.5.0
                      MEMORY:
                      			admin 			6.15.2
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		21621
                      States: 		14503
                      #1369
                      @virus2k12
                      Da stimmt was nicht mit npm.
                      iob stop
                      sudo apt install --reinstall nodejs
                      iob restart
                      Und dann nochmal die Langfassung von iob diag.
                      Finger von npm lassen!
                        @virus2k12
                        iob stop
                        iob restart
                        Codierknecht
                        #1370
                        @Virus2K12
                        ... und den Desktop ausschalten.
                          @Virus2K12
                          #1371
                          @Virus2K12
                          Oh, ganz übersehen. Natürlich.
                          Und auch mal prüfen, ob die Hardware nicht 64Bit verträgt.
                          • Virus2K12V Offline
                            Virus2K12V Offline
                            Virus2K12
                            #1372
                            Desktop aus und reinstall nodejs gemacht.
                            Hier jetzt erst einmal die lange Fassung von iob diag
                            Skript v.2023-10-25
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                            Model		: Raspberry Pi 4 Model B Rev 1.1
                            Docker          : false
                            Virtualization  : none
                            Kernel          : armv7l
                            Userland        : armhf
                            Systemuptime and Load:
                             11:46:10 up 4 min,  1 user,  load average: 4.35, 2.76, 1.17
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            *** Time and Time Zones ***
                                           Local time: Fri 2024-03-08 11:46:10 CET
                                       Universal time: Fri 2024-03-08 10:46:10 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            pi
                            /home/pi
                            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                            *** X-Server-Setup ***
                            X-Server: 	false
                            Desktop:
                            Terminal: 	tty
                            Boot Target: 	multi-user.target
                            *** MEMORY ***
                            Mem:            4.0G        2.4G        670M        4.8M        1.1G        1.6G
                            Swap:           104M          0B        104M
                            Total:          4.1G        2.4G        775M
                                     3837 M total memory
                                     2303 M used memory
                                      235 M active memory
                                     2842 M inactive memory
                                      638 M free memory
                                      244 M buffer memory
                                      788 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FAILED SERVICES ***
                              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                            * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
                            1 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4      219G   24G  185G  12% /
                            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                            tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                            tmpfs          tmpfs     768M  2.1M  766M   1% /run
                            tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                            /dev/loop1     squashfs   43M   43M     0 100% /snap/certbot/3642
                            /dev/loop2     squashfs   91M   91M     0 100% /snap/core/16207
                            /dev/loop0     squashfs   42M   42M     0 100% /snap/certbot/3568
                            /dev/loop4     squashfs   54M   54M     0 100% /snap/core20/2106
                            /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16575
                            /dev/loop5     squashfs   54M   54M     0 100% /snap/core20/2185
                            /dev/sda1      vfat      253M   93M  160M  37% /boot
                            tmpfs          tmpfs     384M   80K  384M   1% /run/user/1000
                            [Fri Mar  8 11:41:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:4F:AC:15 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=048e52a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles fsck.mode=force cfg80211.ieee80211_regdom=DE
                            [Fri Mar  8 11:41:27 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                            [Fri Mar  8 11:41:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [Fri Mar  8 11:42:02 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
                            Show mounted filesystems:
                            TARGET                         SOURCE      FSTYPE      OPTIONS
                            /                              /dev/sda2   ext4        rw,noatime
                            |-/dev                         devtmpfs    devtmpfs    rw,relatime,size=1800056k,nr_inodes=84157,mode=755
                            | |-/dev/shm                   tmpfs       tmpfs       rw,nosuid,nodev
                            | |-/dev/pts                   devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                            | `-/dev/mqueue                mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                            |-/proc                        proc        proc        rw,relatime
                            | `-/proc/sys/fs/binfmt_misc   systemd-1   autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                            |   `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                            |-/sys                         sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/security       securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/cgroup             cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                            | |-/sys/fs/bpf                none        bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                            | |-/sys/kernel/debug          debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/tracing        tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/fuse/connections   fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                            | `-/sys/kernel/config         configfs    configfs    rw,nosuid,nodev,noexec,relatime
                            |-/run                         tmpfs       tmpfs       rw,nosuid,nodev,size=785972k,nr_inodes=819200,mode=755
                            | |-/run/lock                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
                            | |-/run/credentials/systemd-sysctl.service
                            | |                            none        ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                            | |-/run/credentials/systemd-sysusers.service
                            | |-/run/credentials/systemd-tmpfiles-setup-dev.service
                            | |-/run/rpc_pipefs            sunrpc      rpc_pipefs  rw,relatime
                            | |-/run/credentials/systemd-tmpfiles-setup.service
                            | `-/run/user/1000             tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=392984k,nr_inodes=98246,mode=700,uid=1000,gid=1000
                            |-/snap/certbot/3642           /dev/loop1  squashfs    ro,nodev,relatime
                            |-/snap/core/16207             /dev/loop2  squashfs    ro,nodev,relatime
                            |-/snap/certbot/3568           /dev/loop0  squashfs    ro,nodev,relatime
                            |-/snap/core20/2106            /dev/loop4  squashfs    ro,nodev,relatime
                            |-/snap/core/16575             /dev/loop3  squashfs    ro,nodev,relatime
                            |-/snap/core20/2185            /dev/loop5  squashfs    ro,nodev,relatime
                            `-/boot                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-r
                            /var:
                            3.6G	/var/
                            2.1G	/var/log
                            1.9G	/var/log/journal/a86ff8ac034a41cc8294fe68053416f8
                            1.3G	/var/lib
                            Archived and active journals take up 1.8G in the file system.
                            /opt/iobroker/backups:
                            178M	/opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            741M	/opt/iobroker/iobroker-data/
                            523M	/opt/iobroker/iobroker-data/files
                            89M	/opt/iobroker/iobroker-data/files/echarts.admin
                            80M	/opt/iobroker/iobroker-data/backup-objects
                            57M	/opt/iobroker/iobroker-data/files/javascript.admin
                            du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c3ec73ec5450fb4cac984fc867dd54eb.js': No such file or directory
                            du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c351437da7e800bc3d9409c431052f9c.js': No such file or directory
                            109M	/opt/iobroker/iobroker-data/states.jsonl
                            35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                            31M	/opt/iobroker/iobroker-data/objects.jsonl
                            24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                            24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                            USB-Devices by-id:
                            *** NodeJS-Installation ***
                            /usr/bin/npm 		10.2.4
                            /usr/bin/npx 		10.2.4
                            nodejs:
                              Installed: 18.19.1-1nodesource1
                              Candidate: 18.19.1-1nodesource1
                              Version table:
                             *** 18.19.1-1nodesource1 600
                                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                 18.19.0+dfsg-6~deb12u1+rpi1 500
                                    500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                                 18.19.0-1nodesource1 600
                                 18.18.2-1nodesource1 600
                                 18.18.1-1nodesource1 600
                                 18.18.0-1nodesource1 600
                                 18.17.1-1nodesource1 600
                                 18.17.0-1nodesource1 600
                                 18.16.1-1nodesource1 600
                                 18.16.0-1nodesource1 600
                                 18.15.0-1nodesource1 600
                                 18.14.2-1nodesource1 600
                                 18.14.1-1nodesource1 600
                                 18.14.0-1nodesource1 600
                                 18.13.0-1nodesource1 600
                                 18.12.0-1nodesource1 600
                                 18.11.0-1nodesource1 600
                                 18.10.0-1nodesource1 600
                                 18.9.1-1nodesource1 600
                                 18.9.0-1nodesource1 600
                                 18.8.0-1nodesource1 600
                                 18.7.0-1nodesource1 600
                                 18.6.0-1nodesource1 600
                                 18.5.0-1nodesource1 600
                                 18.4.0-1nodesource1 600
                                 18.3.0-1nodesource1 600
                                 18.2.0-1nodesource1 600
                                 18.1.0-1nodesource1 600
                                 18.0.0-1nodesource1 600
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller: 	5.0.19
                            admin: 		6.15.2
                            javascript: 	7.8.0
                            Adapters from github: 	1
                            Adapter State
                            + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled, compact disabled
                              system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled, compact disabled
                              system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                            + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
                              system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
                              system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                            + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, compact disabled, port: 80
                              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
                              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                              system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
                              system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                            + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, compact disabled, port: 1884
                              system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
                              system.adapter.netatmo-crawler.1        : netatmo-crawler       : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
                            + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.vesync.0                 : vesync                : raspberrypi                              -  enabled, compact disabled
                              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
                            + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled, compact disabled
                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                              system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled, compact disabled
                              system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                              system.adapter.vis-homekittiles.0       : vis-homekittiles      : raspberrypi                              -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled, compact disabled
                              system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                              system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
                              system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                              system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                              system.adapter.vis-owl.0                : vis-owl               : raspberrypi                              -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                              system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled, compact disabled
                              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled, compact disabled
                            + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                            + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled, compact disabled
                            + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            ioBroker-Repositories
                            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                            Installed ioBroker-Instances
                            Used repository: Beta (latest)
                            Adapter    "admin"        : 6.15.2   , installed 6.15.2
                            Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                            Adapter    "awtrix-light" : 0.15.0   , installed 0.15.0
                            Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                            Adapter    "bring"        : 1.8.4    , installed 1.8.4
                            Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                            Adapter    "device-watcher": 2.10.5  , installed 2.10.5
                            Adapter    "devices"      : 1.1.5    , installed 1.1.5
                            Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                            Adapter    "espresense"   : 0.4.4    , installed 0.4.4
                            Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                            Adapter    "hue"          : 3.10.2   , installed 3.10.2
                            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                            Adapter    "ical"         : 1.14.3   , installed 1.14.3
                            Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                            Adapter    "info"         : 2.0.0    , installed 2.0.0
                            Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                            Controller "js-controller": 5.0.19   , installed 5.0.19
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                            Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                            Adapter    "snmp"         : 3.1.0    , installed 3.1.0
                            Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                            Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                            Adapter    "text2command" : 3.0.3    , installed 3.0.3
                            Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                            Adapter    "vesync"       : 0.0.7    , installed 0.0.7
                            Adapter    "vis"          : 1.5.4    , installed 1.5.4
                            Adapter    "vis-2"        : 2.9.40   , installed 2.9.40
                            Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
                            Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
                            Adapter    "vis-homekittiles": 0.0.9 , installed 0.0.9
                            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                            Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
                            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                            Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                            Adapter    "web"          : 6.2.5    , installed 6.2.5
                            Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                            Adapter    "wled"         : 0.7.2    , installed 0.7.2
                            Adapter    "ws"           : 2.5.11   , installed 2.5.11
                            Objects and States
                            Objects: 	21668
                            States: 	14569
                            Hit:1 http://linux.teamviewer.com/deb stable InRelease
                            Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                            Hit:3 http://archive.raspberrypi.org/debian bookworm InRelease
                            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Hit:5 https://packages.sury.org/php buster InRelease
                            Update rpimonitor Packages Status
                            Reading package lists... Done
                            Pending Updates: 0
                            *** Listening Ports ***
                            Netid          State           Recv-Q          Send-Q                                 Local Address:Port                    Peer Address:Port         Process
                            udp            UNCONN          0               0                                            0.0.0.0:6666                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=37))
                            udp            UNCONN          0               0                                            0.0.0.0:6667                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=38))
                            udp            UNCONN          0               0                                            0.0.0.0:5683                         0.0.0.0:*             users:(("io.shelly.0",pid=1704,fd=32))
                            udp            UNCONN          0               0                                          127.0.0.1:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=11))
                            udp            UNCONN          0               0                                            0.0.0.0:33903                        0.0.0.0:*             users:(("io.snmp.0",pid=2100,fd=29))
                            udp            UNCONN          0               0                                            0.0.0.0:631                          0.0.0.0:*             users:(("cups-browsed",pid=1293,fd=7))
                            udp            UNCONN          0               0                                    192.168.178.255:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=17))
                            udp            UNCONN          0               0                                     192.168.178.51:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=16))
                            udp            UNCONN          0               0                                            0.0.0.0:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=14))
                            udp            UNCONN          0               0                                    192.168.178.255:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=19))
                            udp            UNCONN          0               0                                     192.168.178.51:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=18))
                            udp            UNCONN          0               0                                            0.0.0.0:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=15))
                            udp            UNCONN          0               0                                            0.0.0.0:45212                        0.0.0.0:*             users:(("connmand",pid=570,fd=21))
                            udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("io.wled.0",pid=2673,fd=21))
                            udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.1",pid=1762,fd=29))
                            udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.0",pid=1736,fd=30))
                            udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=12))
                            udp            UNCONN          0               0                                            0.0.0.0:47932                        0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=14))
                            udp            UNCONN          0               0                                                  *:50208                              *:*             users:(("avahi-daemon",pid=456,fd=15))
                            udp            UNCONN          0               0                                                  *:546                                *:*             users:(("connmand",pid=570,fd=18))
                            udp            UNCONN          23616           0                        [fe80::ac64:680b:efa1:4b03]:546                                *:*             users:(("NetworkManager",pid=569,fd=24))
                            udp            UNCONN          0               0                                              [::1]:53                                 *:*             users:(("connmand",pid=570,fd=12))
                            udp            UNCONN          0               0                                                  *:5353                               *:*             users:(("avahi-daemon",pid=456,fd=13))
                            tcp            LISTEN          0               128                                        127.0.0.1:5939                         0.0.0.0:*             users:(("teamviewerd",pid=1322,fd=12))
                            tcp            LISTEN          0               4096                                         0.0.0.0:8083                         0.0.0.0:*             users:(("motion",pid=866,fd=5))
                            tcp            LISTEN          0               10                                      127.0.0.1%lo:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=13))
                            tcp            LISTEN          0               128                                          0.0.0.0:22                           0.0.0.0:*             users:(("sshd",pid=707,fd=3))
                            tcp            LISTEN          0               128                                        127.0.0.1:631                          0.0.0.0:*             users:(("cupsd",pid=617,fd=7))
                            tcp            LISTEN          0               5                                            0.0.0.0:8888                         0.0.0.0:*             users:(("rpimonitord",pid=754,fd=4))
                            tcp            LISTEN          0               511                                          0.0.0.0:1883                         0.0.0.0:*             users:(("io.sonoff.0",pid=1711,fd=34))
                            tcp            LISTEN          0               511                                          0.0.0.0:1884                         0.0.0.0:*             users:(("io.mqtt.1",pid=1666,fd=29))
                            tcp            LISTEN          0               50                                           0.0.0.0:445                          0.0.0.0:*             users:(("smbd",pid=1348,fd=31))
                            tcp            LISTEN          0               128                                          0.0.0.0:8765                         0.0.0.0:*             users:(("meyectl",pid=470,fd=12))
                            tcp            LISTEN          0               4096                                         0.0.0.0:7999                         0.0.0.0:*             users:(("motion",pid=866,fd=7))
                            tcp            LISTEN          0               511                                        127.0.0.1:9000                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=27))
                            tcp            LISTEN          0               511                                        127.0.0.1:9001                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=21))
                            tcp            LISTEN          0               80                                         127.0.0.1:3306                         0.0.0.0:*             users:(("mariadbd",pid=714,fd=27))
                            tcp            LISTEN          0               50                                           0.0.0.0:139                          0.0.0.0:*             users:(("smbd",pid=1348,fd=32))
                            tcp            LISTEN          0               511                                        127.0.0.1:6379                         0.0.0.0:*             users:(("redis-server",pid=620,fd=6))
                            tcp            LISTEN          0               511                                                *:80                                 *:*             users:(("apache2",pid=799,fd=4),("apache2",pid=797,fd=4),("apache2",pid=796,fd=4),("apache2",pid=795,fd=4),("apache2",pid=794,fd=4),("apache2",pid=793,fd=4),("apache2",pid=739,fd=4))
                            tcp            LISTEN          0               511                                                *:8081                               *:*             users:(("io.admin.0",pid=1419,fd=29))
                            tcp            LISTEN          0               511                                                *:8082                               *:*             users:(("io.web.0",pid=2666,fd=29))
                            tcp            LISTEN          0               511                                                *:8084                               *:*             users:(("io.ws.0",pid=2703,fd=28))
                            tcp            LISTEN          0               10                                          [::1]%lo:53                              [::]:*             users:(("connmand",pid=570,fd=14))
                            tcp            LISTEN          0               128                                             [::]:22                              [::]:*             users:(("sshd",pid=707,fd=4))
                            tcp            LISTEN          0               511                                                *:8087                               *:*             users:(("io.simple-api.0",pid=2067,fd=28))
                            tcp            LISTEN          0               128                                            [::1]:631                             [::]:*             users:(("cupsd",pid=617,fd=6))
                            tcp            LISTEN          0               4096                                               *:3000                               *:*             users:(("grafana-server",pid=1295,fd=11))
                            tcp            LISTEN          0               50                                              [::]:445                             [::]:*             users:(("smbd",pid=1348,fd=29))
                            tcp            LISTEN          0               511                                            [::1]:6379                            [::]:*             users:(("redis-server",pid=620,fd=7))
                            tcp            LISTEN          0               50                                              [::]:139                             [::]:*             users:(("smbd",pid=1348,fd=30))
                            2024-03-08 11:46:19.657  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value": Connection is closed.]
                            2024-03-08 11:46:19.659  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.
                            2024-03-08 11:46:19.660  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.]
                            2024-03-08 11:46:19.662  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.
                            2024-03-08 11:46:19.664  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.]
                            2024-03-08 11:46:19.666  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.
                            2024-03-08 11:46:19.667  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.]
                            2024-03-08 11:46:19.669  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.
                            2024-03-08 11:46:19.671  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.]
                            2024-03-08 11:46:19.673  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.
                            2024-03-08 11:46:19.675  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.]
                            2024-03-08 11:46:19.677  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.
                            2024-03-08 11:46:19.680  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.]
                            2024-03-08 11:46:19.682  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.
                            2024-03-08 11:46:19.684  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.]
                            2024-03-08 11:46:20.212  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                            2024-03-08 11:46:21.158  - info: tuya.0 (1804) bf047f0676f4973f71uyin: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.59:6668
                            2024-03-08 11:46:35.239  - info: tuya.0 (1804) bf7e8a579d18ba290elhqa: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.34:6668
                            2024-03-08 11:46:40.760  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                            2024-03-08 11:46:40.844  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                            2024-03-08 11:47:01.160  - error: vesync.0 (2220) {"traceId":"1709894813723","code":-11302030,"msg":"device timeout","module":null,"stacktrace":null,"result":null}
                            2024-03-08 11:47:42.466  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                            2024-03-08 11:47:42.960  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                            2024-03-08 11:48:40.996  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
                            2024-03-08 11:48:41.296  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
                            iob diag has finished.
                            Press any key for a summary
                              Virus2K12V Offline
                              Virus2K12
                              #1373
                              zusammenfassung iob_diag
                              			v.2023-10-25
                                     Icon name: computer
                                  Architecture: arm
                              Kernel: 		armv7l
                              Userland: 		armhf
                              User-ID: 		1000
                              X-Server: 		false
                              			/usr/bin/npm 		10.2.4
                              			/usr/bin/npx 		10.2.4
                              MEMORY:
                              Mem:            4.0G        2.7G        223M        4.8M        1.3G        1.3G
                              Swap:           104M          0B        104M
                              Total:          4.1G        2.7G        328M
                              			admin 			6.15.2
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		21668
                              States: 		14569
                              32M	/opt/iobroker/iobroker-data/objects.jsonl
                              112M	/opt/iobroker/iobroker-data/states.jsonl
                                Skript v.2023-10-25
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm
                                Docker          : false
                                Kernel          : armv7l
                                Userland        : armhf
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server: 	false
                                Desktop:
                                Terminal: 	tty
                                *** MEMORY ***
                                Swap:           104M          0B        104M
                                         3837 M total memory
                                         2303 M used memory
                                          235 M active memory
                                          638 M free memory
                                          244 M buffer memory
                                          788 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                3.6G	/var/
                                2.1G	/var/log
                                1.3G	/var/lib
                                USB-Devices by-id:
                                /usr/bin/npm 		10.2.4
                                /usr/bin/npx 		10.2.4
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin: 		6.15.2
                                javascript: 	7.8.0
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects: 	21668
                                States: 	14569
                                Pending Updates: 0
                                #1374
                                @virus2k12
                                Hast du das per Dist-Upgrade von einer Vorversion auf 'Debian 12 - Bookworm' gebracht (bzw. es versucht?).
                                Das funktioniert nicht. Neuinstallation von Null an.
                                Virus2K12V 1 Antwort Letzte Antwort
                                  @virus2k12
                                  Virus2K12V Offline
                                  Virus2K12V Offline
                                  Virus2K12
                                  schrieb am zuletzt editiert von Virus2K12
                                  #1375
                                  @thomas-braun ja, von bullseye auf bookworm, aber schon vor ewigkeiten. Lief auch die ganze Zeit ohne Probleme.
                                  Zuletzt habe ich eine smb Freigabe für verschieden Verzeichnisse gemacht, kann es daran liegen zwecks Zugriffsrechte etc. ?
                                    #1376
                                    @virus2k12
                                    Aber nicht richtig.
                                    Der Kernel ist z. B. noch aus Bullseye-Zeiten.
                                      Virus2K12V Offline
                                      Virus2K12
                                      #1377
                                      Problem gelöst. Node, npm und iob deinstalliert, Kernelupdate gemacht, node, npm und iob neu installiert und alles läuft.
                                        #1378
                                        @virus2k12
                                        Du hockst aber immer noch auf einer 32Bit-Version.
                                          Virus2K12V Offline
                                          Virus2K12
                                          #1379
                                          @thomas-braun ja, kann ich das einfach von 32 auf 64 updaten?
                                          da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
