  4. Test Adapter Pylontech v0.0.10
226 Beiträge 32 Kommentatoren 56.3k Aufrufe 26 Beobachtet
  • B bios123
    @plchome-0 habe gerade nochmal ins log geschaut:
    pylontech.0
    2024-02-21 12:42:30.168	silly	bat 1 @ Battery Volt Tempr Base State Volt. State Curr. State Temp. State Coulomb 0 3361 19000 Charge Normal Normal Normal 60% 60896 mAH 1 3360 19000 Charge Normal Normal Normal 60% 60446 mAH 2 3362 19000 Charge Normal Normal Normal 60% 60841 mAH 3 3361 19000 Charge Normal Normal Normal 60%
    pylontech.0
    2024-02-21 12:42:30.124	silly	PYTES>i1 @ Unknown command 'i1' - try 'help' $$ PYTES>
    pylontech.0
    2024-02-21 12:42:30.092	silly	- - Absent - - - - - - - - - Command completed successfully $$
    pylontech.0
    2024-02-21 12:42:30.065	silly	- - - - - - 14 - - - - - - - Absent - - - - - - - - - 15 - - - - - - - Absent - - - - - - - - - 16 - - - - -
    pylontech.0
    2024-02-21 12:42:30.022	silly	- 11 - - - - - - - Absent - - - - - - - - - 12 - - - - - - - Absent - - - - - - - - - 13 - - - - - - - Absent - - -
    pylontech.0
    2024-02-21 12:42:29.979	silly	- - - - - - Absent - - - - - - - - - 9 - - - - - - - Absent - - - - - - - - - 10 - - - - - - - Absent - - - - - - - -
    pylontech.0
    2024-02-21 12:42:29.936	silly	- - - - - - - - 6 - - - - - - - Absent - - - - - - - - - 7 - - - - - - - Absent - - - - - - - - - 8 -
    pylontech.0
    2024-02-21 12:42:29.893	silly	- - - - 3 - - - - - - - Absent - - - - - - - - - 4 - - - - - - - Absent - - - - - - - - - 5 - - - - - - - Absent -
    pylontech.0
    2024-02-21 12:42:29.850	silly	S>pwr @ Power Volt Curr Tempr Tlow Thigh Vlow Vhigh Base.St Volt.St Curr.St Temp.St Coulomb Time B.V.St B.T.St Barcode DevType 1 53780 529 24000 19000 19000 3359 3363 Charge Normal Normal Normal 60% 2024-02-21 19:39:27 Normal Normal ES1000626P010443 E-BOX-48100V-D 2 - - - - - - - Absent - - - - -
    pylontech.0
    2024-02-21 12:42:29.807	silly	@ Unknown command 'i' - try 'help' $$ PYTES> PYTE
    pylontech.0
    2024-02-21 12:36:35.083	error	Error: timeout
    pylontech.0
    2024-02-21 12:36:30.112	silly	PYTES>i
    pylontech.0
    2024-02-21 12:36:30.080	silly	- - - - Absent - - - - - - - - - Command completed successfully $$
    pylontech.0
    2024-02-21 12:36:30.048	silly	- - - - - - - 14 - - - - - - - Absent - - - - - - - - - 15 - - - - - - - Absent - - - - - - - - - 16 - - -
    pylontech.0
    2024-02-21 12:36:30.005	silly	- - - 11 - - - - - - - Absent - - - - - - - - - 12 - - - - - - - Absent - - - - - - - - - 13 - - - - - - - Absent - -
    pylontech.0
    2024-02-21 12:36:29.962	silly	8 - - - - - - - Absent - - - - - - - - - 9 - - - - - - - Absent - - - - - - - - - 10 - - - - - - - Absent - - - - - -
    pylontech.0
    2024-02-21 12:36:29.919	silly	Absent - - - - - - - - - 6 - - - - - - - Absent - - - - - - - - - 7 - - - - - - - Absent - - - - - - - - -
    pylontech.0
    2024-02-21 12:36:29.876	silly	- - - - 3 - - - - - - - Absent - - - - - - - - - 4 - - - - - - - Absent - - - - - - - - - 5 - - - - - - -
    pylontech.0
    2024-02-21 12:36:29.833	silly	PYTES> PYTES>pwr @ Power Volt Curr Tempr Tlow Thigh Vlow Vhigh Base.St Volt.St Curr.St Temp.St Coulomb Time B.V.St B.T.St Barcode DevType 1 53903 3338 24000 19000 19000 3367 3371 Charge Normal Normal Normal 60% 2024-02-21 19:33:27 Normal Normal ES1000626P010443 E-BOX-48100V-D 2 - - - - - - - Absent - - - - -
    den Aufruf 'i' bzw 'i1' gibt es nicht, wo kommt der her?
    Heute Abend hab ich sicher mehr Zeit...
    PLCHome 0P Offline
    PLCHome 0P Offline
    PLCHome 0
    #117
    @bios123
    Da gibts nur das i von Info und die Nummer von den anderen Befehl. Das sieht mir aber nach eier Schnittstelle aus, die zeitweise abkackt oder NodeJs mach blödsinn :-(
    protected _getDataUS(option: any): Promise<any> {
      return new Promise<any>((resolve, reject) => {
        this._getUsPwr()
          .then((p: { pwrs: any; batteries: string[] }) => {
            this._getUsInfo(p, option.info, option.power)
              .then((p: resultForGet) => {
                this._getUsNormal(p, PWR, POWER, option.power)
                  .then(p => {
                    this._getUsNormal(p, STAT, STATISTIC, option.statistic)
                      .then(p => {
                        this._getUsBatterie(p, BAT, option.celldata)
                          .then(p => {
                            this._getUsBatterie(p, SOH, option.cellsoh)
                              .then(p => {
                                this._getOne(p.allData, LOG, LOG, option.log)
                                  .then(allData => {
                                    this._getOne(allData, TIME, TIME, option.time)
                                      .then(allData => {
                                        resolve(allData);
                                      .catch(reject);
                                  .catch(reject);
                              .catch(reject);
                          .catch(reject);
                      .catch(reject);
                  .catch(reject);
              .catch(reject);
          .catch(reject);
    • PLCHome 0P PLCHome 0
      @bios123
          this._getUsPwr()
                    .then(p => {
                        .then(p => {
                            .then(p => {
                                .then(p => {
                                    .then(allData => {
                                        .then(allData => {
                                          resolve(allData);
                                        .catch(reject);
                                    .catch(reject);
                                .catch(reject);
                            .catch(reject);
                        .catch(reject);
                    .catch(reject);
                .catch(reject);
            .catch(reject);
      bios123
      #118
      @plchome-0 Das fruchtet leider alles nicht. Zeit erhöhen macht keinen Unterschied und Zeilenabschluss mit \r und/oder \n in vielen Kombination, bringt auch keine Besserung. Hatte neben dem FTDI Adapter (vergossen mit Consolenanschluss auf RJ45) auch einen alten PL2303 versucht. Der scheint aber nicht wirklich gut zu laufen. Würde den USB/Serial Adapter gerne ausschließen, kannst du mir sagen welcher Adapter (vorzugweise über Amazon zu bekommen) gut funktioniert? Hab zwar noch ESP32/ESP8266 da, aber keine MAX Pegelwandler mehr.
      Wie gesagt teilweise klappt die Abfrage mehrfach hintereinander und dann wieder timeout. Vielleicht ist die serielle Schnitstelle von der Pytes-V5 einfach eine Diva.
      PLCHome 0P 2 Antworten Letzte Antwort
      • B bios123
        PLCHome 0P Offline
        PLCHome 0P Offline
        PLCHome 0
        schrieb am zuletzt editiert von PLCHome 0
        #119
        @bios123 Ich hab gerade den LogiLink AU0034 aus der Readme im einasatz, weil mir bei dem ESP die USB-Buchse zur Spannungsversorgung abgerissen ist und ich noch keine Zeit (oder Bock) hatte, den wieder zu reparieren :-(
        Ich habe aber auch keinen PI, sondern einen NUC im Einsatz. Ich gehe mal von einem PI als Hardware aus.
        Zuerst solltest du mal im dmesg schauen, ob die Schnittstelle Fehler meldet, wenn da irgendwas nicht stimmt, dann sieht man es da.
        Komisch ist ja, das es mit den Testscripts funktioniert und im Adapter Fehler produziert.
        In der Debugausgabe, die Du gepostet hast, überholen sich auch die Meldungen. Das kann aber auch wegen Multitasking normal sein.
        • B bios123
          PLCHome 0P Offline
          PLCHome 0P Offline
          PLCHome 0
          #120
          @bios123 Du hast aber auch die Masse verbunden? Das fehlte mal eine Zeit in den Anleitungen.
          DSUB signal
          2 RxD
          3 TxD
          5 Ground
          Andere Seite in deinem Handbuch
            bios123
            #121
            @PLCHome-0 Die Schnittstelle habe schon kontrolliert, dmesg zeigt da keine Aufälligkeiten: USB ran, wird erkannt und dann ist stille. Hab heute morgen einen Waveshare mit RS232/485/TTL geordert (den brauche ich noch für andere Projekt) und einen billigen USB Adapter mit Prolific Chipsatz, kommt morgen.
            Wie gesagt iobroker läuft in einem LXC (Proxmox Host) und ttyUSB0 ist direkt durchgereicht. Den Aufbau hab ich mit verschiedenen USB Geräten am laufen da gibt es keine Probleme.
            Wenn ich die Schnittstelle z.B. mit screen /dev/ttyUSB0 115200 öffne, kann ich jeden Befehl ohne Probleme absetzen und sehe auch keine Übertragungsfehler. Die Befehle bat, info, pwr, soh, stat, time, ver schließen direkt mit "Command completed successfully" ab:
            PYTES>
            Bei help undlog braucht es ein Bestätigung der Abschnitte mit ENTER
            PYTES>log
             Index   : 29
             Time    : 24-02-22 11:41:23
             ModID   : BMM
             Code    : 1c5
             Info    : The device start charging.
             Index   : 28
             Time    : 24-02-22 11:36:37
             ModID   : BMM
             Code    : 1c4
             Index   : 27
             Time    : 24-02-22 11:30:09
             ModID   : BMM
             Code    : 1c3
            Press [Enter] to be continued,other key to exit
            Ich hab jetzt keine tiefere Analyse gemacht: Wartet dein Code oder wertet er die Zeile aus? Welchen Indikator nimmst du um festzustellen das ein Abfrage fertig ist, also zB info.
            Ich hoffe du hast noch ein wenig Geduld mit mir...
            PLCHome 0P 1 Antwort Letzte Antwort
            • B bios123
              PYTES>
              PYTES>log
               Index   : 29
               ModID   : BMM
               Code    : 1c5
               Index   : 28
               ModID   : BMM
               Code    : 1c4
               Index   : 27
               ModID   : BMM
               Code    : 1c3
              PLCHome 0P Offline
              PLCHome 0P Offline
              PLCHome 0
              #122
              @bios123 sagte in Test Adapter Pylontech v0.0.8:
              Danke, dass du dir Gedanken machst. Aber einen Adapter, der nicht funktioniert, den braucht keiner :-)
                  while ((position = data.lastIndexOf('$$')) !== -1) {
                    if ((start = data.lastIndexOf('>', position)) !== -1) {
                      this.push(data.subarray(start, position - 1));
              Der Code wertet alles zwischen > und $$ aus.
              if ((position = data.lastIndexOf('[Enter]')) !== -1) {
                    data.write('-------', position);
                    this.emit('needsenddata', '\r');
              Wenn er [Enter] empängt, ersetzt er es mit - und sendet ein \r, das wird für das Log benötigt.
              Alles in ConsolenReader.ts zu finden.
              Was ich komisch finde, ist das i1.
              Was man im Log sieht, ist das echo. Das bedeutet, man sendet ein Zeichen an den Akku und dieser sendet es zurück.
              @Radi hatte auch ein Problem mit dem Kabel. @Radi, vielleicht kannst du noch mal bescheriben, was genau der Fehler war?
              Da hat sich der Adapter doch auch total komisch verhalten. Es fehlten Zeichen und es waren welche da, die da nicht hingehörten.
              • B bios123
                @PLCHome-0 die alten Objekte hatte ich bereits gelöscht um sicher zu gehen das alles sauber angelegt wird. SOH und STAT hab ich wie beschrieben ausgeschaltet. Das hilft aber nicht wirklich. Der Adapter ruft die Daten mal ab und mal nicht. Ich habe versucht den blockierenden Punkt zu finden. Das Kommando 'pwr' wird geschickt und ein Antwort gibt es auch, danach dann wieder Error: timeout. Ich vermute 'pwr' kann ich mit 'Batteriestromdaten herunterladen' abschalten? Wie schnell rufst du die Daten ab? Eventuell braucht die Pytes V5 nach jeder Anfrage einen Moment. Ich kann das zumindest nicht nachstellen, wenn ich manuell hintereinader ein Request abschicke. Ich rufe übrigens direkt per /dev/ttyUSB0 ab, Interface hängt am iobroker und 'US series' ist ausgewählt.
                pylontech.0
                2024-02-21 11:19:04.886	error	Error: timeout
                pylontech.0
                2024-02-21 11:18:59.932	silly	if
                pylontech.0
                2024-02-21 11:18:59.884	silly	16 - - - - - - - Absent - - - - - - - - - Command completed successfully $$ PYTES>
                pylontech.0
                2024-02-21 11:18:59.852	silly	- - Absent - - - - - - - - - 14 - - - - - - - Absent - - - - - - - - - 15 - - - - - - - Absent - - - - - - - - -
                pylontech.0
                2024-02-21 11:18:59.810	silly	- - - - - - 11 - - - - - - - Absent - - - - - - - - - 12 - - - - - - - Absent - - - - - - - - - 13 - - - - -
                pylontech.0
                2024-02-21 11:18:59.766	silly	- 8 - - - - - - - Absent - - - - - - - - - 9 - - - - - - - Absent - - - - - - - - - 10 - - - - - - - Absent - - -
                pylontech.0
                2024-02-21 11:18:59.723	silly	- - - - - - Absent - - - - - - - - - 6 - - - - - - - Absent - - - - - - - - - 7 - - - - - - - Absent - - - - - - - -
                pylontech.0
                2024-02-21 11:18:59.680	silly	- - - - - - - - 3 - - - - - - - Absent - - - - - - - - - 4 - - - - - - - Absent - - - - - - - - - 5 -
                pylontech.0
                2024-02-21 11:18:59.397	silly	PYTES> PYTES>pwr @ Power Volt Curr Tempr Tlow Thigh Vlow Vhigh Base.St Volt.St Curr.St Temp.St Coulomb Time B.V.St B.T.St Barcode DevType 1 53708 2164 24000 19000 19000 3352 3359 Charge Normal Normal Normal 52% 2024-02-21 18:15:57 Normal Normal ES1000XXXP010XXX E-BOX-48100V-D 2 - - - - - - - Absent -
                Gruß Markus
                PLCHome 0P Offline
                PLCHome 0P Offline
                PLCHome 0
                #123
                Also wenn du eine Pause ausprobieren möchtest, dann kannst du folgende Zeile einfügen:
                setTimeout(()=>{....},1000);
                **Editiert
                1000 ist die Wartezeit in ms.
                File build/pylontech/WorkerAbstract.js
                Alt:
                  _nextcommand() {
                    debugApi("MyWorkerAbstract._nextcommand", "this._activeCmd:", this._activeCmd, "this._started:", this._started);
                    if (!this._activeCmd && this._started) {
                      this._activeCmd = this._commands.shift();
                      if (this._activeCmd) {
                        this._parsers.setCMD(this._activeCmd.cmd);
                        this.sendData(this._activeCmd.cmd + "\r");
                        this._activeCmd.timeout = setTimeout(this._ontimeout.bind(this), this._timeout);
                Neu:
                  _nextcommand() {
                        setTimeout(()=>{
                        },1000);
                **Editiert
                Pass bitte auf das sich der Adapter nicht überholt. Das Abfrageintervall kann man in der Konfiguration einstellen. Aktuell hatte ich da nichts vorgesehen, da durch die Timeout der Abruf nicht länger als 1 Minute dauern konnte.
                  **Editiert
                  Alt:
                    _nextcommand() {
                  Neu:
                    _nextcommand() {
                          setTimeout(()=>{
                          },1000);
                  **Editiert
                  bios123
                  #124
                  @plchome-0
                  host.iobroker
                  2024-02-23 09:14:28.602	error	Caught by controller[0]: SyntaxError: await is only valid in async functions and the top level bodies of modules
                  host.iobroker
                  2024-02-23 09:14:28.602	error	Caught by controller[0]: ^^^^^
                  host.iobroker
                  2024-02-23 09:14:28.602	error	Caught by controller[0]: await new Promise((a)=>{setTimeout(a,1000)});
                  host.iobroker
                  2024-02-23 09:14:28.602	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.pylontech/build/pylontech/WorkerAbstract.js:72
                  so leider nicht.
                  • B bios123
                    @plchome-0
                    host.iobroker
                    host.iobroker
                    host.iobroker
                    host.iobroker
                    so leider nicht.
                    PLCHome 0P Offline
                    PLCHome 0P Offline
                    PLCHome 0
                    #125
                    so leider nicht.
                    Ups sorry ich habs oben korrigiert :-(
                    Ich sagte ja, eine Pause ist nicht so trivial.
                      so leider nicht.
                      bios123
                      #126
                      @plchome-0 Kurzer Zwischenstand mit der Codeanpassung scheint es zu funktionieren. Ich lasse das mal so über Nacht laufen. Bin etxra auf 1 Minute Intervall runter und habe mich bei setTimeout(()=>{....},100); auf 100 Millisekunden rangetastet. Sobald ich die anderen USB-Serial Wandler habe, wird aber nochmal ohne Pause getestet.
                      • B bios123
                        PLCHome 0P Offline
                        PLCHome 0P Offline
                        PLCHome 0
                        #127
                        @bios123 Kannst vielleicht auch mal mit 10ms probieren.
                        In 100ms kann die Schnittstelle schon 1152 Zeichen übertragen. Da könnte dir der Akku ja schon seine ganze Lebensgeschichte erzählen :-)
                        115200 Baud 8n1 macht 1 Start + 8 Datenbit + kein Parity Bit + 1 Stop Bit, also 1+8+0+1 = 10 Bit für ein Zeichen, also 11520 Zeichen pro Sekunde im Maximum.
                        Ich gucke mir das mal an und werde die Wartezeit einmal pflegbar machen.
                          bios123
                          #128
                          @PLCHome-0 Update: Neben meinem Consolenkabel (USB->RJ45) mit FTDI Chip, habe ich noch einen
                          Waveshare FT232RNL (FTDI), UGREEN mit PL2303 (Prolific) und den besagten LogiLink AU0034 (FTDI) zur Verfügung. Bei dem PL2303 werden offensichtlich immer nur kleine Datenmengen eingelesen und es gibt das totale Chaoslog. Bei den FDTI Konsorten kann ich keine wesentliche Unterschiede feststellen. Im weiteren Verlauf wurde der LogiLink benutzt.
                          Kommen wir mal zurück zum Problem: Egal ob mit Pause oder ohne, es kommen immer wieder Timeouts. Abfrageintervalle getestet 1, 3 und 5 Minuten ohne/mit Pause von 100 ms bis 1000 ms. Die Tendenz, dass die Abfrage in einen Timeout läuft, ist ohne Pause auf jeden Fall höher. Mit Pause von 1000 ms und 5 Minuten Intervallen läuft der Adapter 2, 3 oder auch 5 Stunden ohne Probleme. Es kann aber auch passieren das ein oder mehrer Timouts hintereinader stattfinden und danach läufts wiede für 3 Stunden.
                          Welche Informationen gerade abgerufen werden scheint auch unerheblich zu sein. Abbrüche hatte ich sowohl bei pwr, bat, log, info und time.
                          Um wirklich sicher auszuschließen das es mit der Schnittstelle nix zu tun hat, habe ich kurzerhand ser2net bemüht und die Daten nicht direkt geholt. Das hat leider gar keinen Unterschied gemacht.
                          So langsam gehen mir die Ideen aus, bis auf die Tatsache das eine Pytes-V5 an der Console nicht dafür gemacht zu seien scheint. Die Abfragen für soh, stat waren immer inaktiv beim testen. Hier müsste für stat ja noch eine Anpassung rein das es die Abfrage stat 1 nicht gibt.
                          • B bios123
                            PLCHome 0P Offline
                            PLCHome 0P Offline
                            PLCHome 0
                            #129
                            soh, stat
                            Ja, die beiden gibt es so nicht, die solltest du ausschalten, damit es keine Irritationen gibt. stat unterscheidet sich auch zum Pylontech, da dort die stat pro Akku ausgegeben wird. Die Abfrage stat oder stat 1 sendet dort die Abfrage des ersten Akkus.
                            Aber eigentlich sollten diese Abfragen kein Problem darstellen, da sie mit > beginnen und mit $$ aufhören. Es finden sich nur keine Treffer mit den regex.
                            Das mit dem timeout ist irgendwie seltsam. Weil es zeitweise funktioniert und zeitweise nicht. Der Pylontch läuft mir ab und zu auch auf ein timeout so alle ein bis zwei Tage eine Abfrage. Ich dachte immer, es liegt bei mir am Wlan. Aber auch mit dem FTDI bekomme ich die Fehler auch alle ein bis zwei Tage mal.
                            Es kann natürlich sein, dass der Akku nicht gleichzeitig mit zwei Geräten kommunizieren möchte und die Konsole dann keine Antwort bekommt, wenn er gerade mit dem Inverter quasselt.
                            Ich muss mal schauen, ob es eine elegante Lösung gibt, im Falle eines Timeout das letzte Kommando zu wiederholen.
                            Und wie ich eine Verriegelung umsetzte, dass sich das Intervall nicht überholt.
                            Ich hätte allerdings nicht gedacht, dass es nicht dem nicht passenden Regex noch so viele Probleme gibt
                              bios123
                              #130
                              @PLCHome-0 Noch eine kleine Anmerkung, da passt die Zuordnung nicht. Muss ich mal beobachten ob das nur bei 100% auftritt (habe den Fall mit fetchCmdSerial.js gesichert):
                              State value to set for "pylontech.0.ES1000626P010443.battery16.coulomb" has to be type "number" but received type "string"
                              • B bios123
                                PLCHome 0P Offline
                                PLCHome 0P Offline
                                PLCHome 0
                                #131
                                Wird wohl da da sonst nicht 100000mAh stehen. Bei 99% sind im Accu 99000mAh, dann passt der RegEx.
                                /build/pylontech/ParserUSBatN.js
                                aus
                                const rowB = /^(.{9})(.{9})(.{9})(.{13})(.{13})(.{13})(.{13})(.{10})(.{9,16})?(.{1,3})?/gm;
                                wird
                                const rowB = /^(.{9})(.{9})(.{9})(.{13})(.{13})(.{13})(.{13})(.{9})(.{10,17})?(.{1,3})?/gm;
                                Ja, das ist dann ein String weil "100% 1" nicht als Zahl erkannt wird.
                                  bios123
                                  #132
                                  @PLCHome-0 Mit dem angepassten RegEx scheint es zu passen, habe keine Meldung mehr bekommen.
                                  Unter pylontech.0.ES1000626P010443.power.power_events erwartet der Adpater ebenfalls eine Zahl.
                                  Mir is noch nicht ganz klar was "0x8000000 DSG" bedeutet, muss ich mal weiter beobachten falls es nochnmal kommt.
                                  • B bios123
                                    PLCHome 0P Offline
                                    PLCHome 0P Offline
                                    PLCHome 0
                                    #133
                                    @bios123 Ok, das ist ein Problem. Der Adapter hat wie auch in den Beispieldaten 0x0 gefunden. Das ist eine Hexadezimale 0. darus macht er eien Dezimale 0.
                                    Weil er 0x<ziffern sieht>. Nun sieht er 0x<ziffern sieht> <text> und wandelt es in Text.
                                      PLCHome 0P Offline
                                      PLCHome 0P Offline
                                      PLCHome 0
                                      #134
                                      @plchome-0 ich mache gleich mal eine 0.0.10 die sollte das dann können
                                      • L l1berty
                                        Hi, Der Adapter läuft sauber bei mir.
                                        Initial mit nem ESP32 der die Daten auf einem Port über Wifi zur Verfügung gestellt hat.
                                        Nun mit Waveshare RS232/485/422 TO POE ETH (B).
                                        Hersteller Link
                                        POE powered mit Hutschienenmontage sieht das ganze schon ganz nett aus !
                                        (Das Webinterface von dem Ding ist eine Katastrophe, mit der Software vom Hersteller lässt es sich aber gut parametrieren, bei Switches die kein 10 Mbit mehr unterstützen kann es Probleme geben).
                                        Viele Grüße
                                        derAugeD Offline
                                        derAugeD Offline
                                        derAuge
                                        #135
                                        @l1berty
                                        Den Waveshare RS232/485/422 to RJ45 Ethernet Module, TCP/IP to Serial habe ich mir gerade bestellt.
                                        nun fertige ich gerade das Anschlusskabel.
                                        Pin1
                                        Pin2
                                        Pin3 => 232TX
                                        Pin4
                                        Pin5
                                        Pin6 => 232RX
                                        Pin7
                                        Pin8 => GND
                                        Pin2 => RXD
                                        Pin3 => TXD
                                        Pin5 => GND
                                        Frage: Müssen die Anschlüsse gekreuzt werden? (232TX-RXD) (232RX-TXD) (GND-GND)
                                        Oder eine 1:1 Verbindung?
                                        Wenn die Lieferung am Montag kommt, kann ich mit dem Testen unterstützen.
                                        Es sollen 4x UC3000 ausgelesen werden
                                        Jürgen
                                        • derAugeD derAuge
                                          @l1berty
                                          Pin1
                                          Pin2
                                          Pin3 => 232TX
                                          Pin4
                                          Pin5
                                          Pin6 => 232RX
                                          Pin7
                                          Pin8 => GND
                                          Pin2 => RXD
                                          Pin3 => TXD
                                          Pin5 => GND
                                          Jürgen
                                          PLCHome 0P Offline
                                          PLCHome 0P Offline
                                          PLCHome 0
                                          #136
                                          @derauge
                                          Das Bild findest du zusammen mit dem Pinout in der readme.
                                          Die Geräte haben einen Stecker, daher muss es an der Kupplung so wie in der Readme angeschlossen werden.
                                          Bei Kupplungen an den Geräten und Steckern am Kabel müssen RX und TX getaucht werden.
                                          US3000 sollten einwandfrei funktionieren. Bitte nur den Ersten im Stack auslesen.
                                          derAugeD 1 Antwort Letzte Antwort
