  4. Test Adapter Weather-Warnings
1.1k Beiträge 36 Kommentatoren 496.5k Aufrufe 41 Beobachtet
  • sigi234S sigi234
    @ticaki
    UWZ wurde deaktiviert, aber laut Log holt es die Daten?
    weather-warnings.0
    2023-12-11 20:56:44.671	info	UWZ activated. Retrieve data.
    weather-warnings.0
    2023-12-11 20:56:44.668	info	ZAMG activated. Retrieve data.
    weather-warnings.0
    2023-12-11 20:56:44.668	info	[alexa2] Create notification service alexa2 state: alexa2.0.Echo-Devices.G0922H0724770WBW.Commands.speak.
    weather-warnings.0
    2023-12-11 20:56:44.652	info	[email] Create notification service email adapter: email.0.
    weather-warnings.0
    2023-12-11 20:56:44.636	info	[history] Create notification service history.
    weather-warnings.0
    2023-12-11 20:56:44.621	info	[json] Create notification service json.
    weather-warnings.0
    2023-12-11 20:56:44.605	info	Refresh Interval: 20 minutes
    weather-warnings.0
    2023-12-11 20:56:44.593	info	[provider] Silent time added: Profil: Mo-So start: 22 end: 5 days: ["0","1","2","3","4","5","6"]
    weather-warnings.0
    2023-12-11 20:56:44.592	info	[provider] Silent time added: Profil: Sa-So start: 7 end: 17 days: ["0","6"]
    weather-warnings.0
    2023-12-11 20:56:44.592	info	[provider] Silent time added: Profil: Mo-Fr start: 10 end: 12 days: ["1","2","3","4","5"]
    weather-warnings.0
    2023-12-11 20:56:41.646	info	starting. Version 0.6.4 in C:/SmartHome/node_modules/iobroker.weather-warnings, node: v18.19.0, js-controller: 5.0.17
    weather-warnings.0
    2023-12-11 20:56:38.199	info	terminating
    weather-warnings.0
    2023-12-11 20:56:37.688	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    weather-warnings.0
    2023-12-11 20:56:37.687	info	terminating
    weather-warnings.0
    2023-12-11 20:56:37.685	info	Got terminate signal TERMINATE_YOURSELF
    T Nicht stören
    T Nicht stören
    ticaki
    #893
    @sigi234 sagte in Test Adapter Weather-Warnings:
    Bestätigt, wenn in der UWZ Tabelle noch Einträge vorhanden sind, wird diese Einstellung ignoriert. (Fehler)
    Spenden
    • T Nicht stören
      T Nicht stören
      ticaki
      #894
      Ich werde mich wohl ab morgen hier wieder dran geben und die gewünschte Funktion einbauen und den Admin umsortieren, der sieht auf einem Handy doof aus. Falls also noch jemand was sinnvolles möchte: https://github.com/ticaki/ioBroker.weather-warnings/issues
      Gibt zum WE dann eine neue Version - uwz hab ich schon gefixt, aber nicht released.
      Nina schaffe ich leider nicht bis Neujahr - da fehlt mir aktuell die Zeit und Lust zu. Wenn die sich nur an die Definitionen halten würden und nicht alles so kompliziert wäre. :)
      Spenden
      • T Nicht stören
        T Nicht stören
        ticaki
        #895
        Hey hat noch jemand das Problem:
        eine ausgehende Warnung, dann schreibt telegram das ins log
        2024-01-16 14:18:52.635 - error: telegram.0 (663) Failed sending [chatId - 995922549]: Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
        2024-01-16 14:18:54.688 - error: telegram.0 (663) Failed sending [chatId - 995922549]: Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
        2024-01-16 14:19:12.056 - error: telegram.0 (663) Failed sending [chatId - 995922549]: Error: ETELEGRAM: 429 Too Many Requests: retry after 11
        Und ich bekomme ca. 30 Nachrichten pro Sekunde. Bis ich den Telegram-Adapter neu starte?
        Spenden
        rtwlR 1 Antwort Letzte Antwort
        • T ticaki
          rtwlR Offline
          rtwlR Offline
          rtwl
          #896
          @ticaki
          ich nutze nur pushover und da klappt es einwandfrei
          -Peter
          • rtwlR rtwl
            @ticaki
            T Nicht stören
            T Nicht stören
            ticaki
            #897
            @rtwl
            Hab oben vergessen zu erwähnen das ich den Telegram Adapter neustarte nicht diesen. Ich werfe mal alle sendToAsync() raus, die machen nur probleme.
            Spenden
            • T Nicht stören
              T Nicht stören
              ticaki
              #898
              Neue Version ist auf dem Weg.
              • Reduziere die Anzahl Einträge bei History/Verlauf auf 80 Stück, hat gerade bei mir mit ca 120 geruckelt (6500 Zeilen)
              Spenden
              • W Offline
                W Offline
                Wurzelfuchs
                #899
                • ich habe den Adapter installiert und bekomme folgende Fehlermeldung im Protokoll:
                weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_Additional_settings/items/silentTime/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","fileSelector","text","textSendTo","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid","timePicker","datePicker"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_Additional_settings","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                kann mir da jemand helfen, was das bedeutet?
                • Ist es möglich, unter E-Mail einen Empfänger zu definieren?
                  hab leider keine entsprechende Einstellung gefunden.
                mcm1957M T 3 Antworten Letzte Antwort
                -1
                • W Wurzelfuchs
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #900
                  @wurzelfuchs
                  Bitte bei Problemen immer die entsprechenden Versionen angeben:
                  Adapterversion?
                  P.S: Du kannst die Warning ziemlich sicher mal ignorieren
                  @ticaki
                  Falls das ein json Schema Fehler ist, leg bitte ein Issue an sollte kein offenens existiereren. Foxriver hat eigentlich die bekannten mittlerweile gefixed
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • W Wurzelfuchs
                    T Nicht stören
                    T Nicht stören
                    ticaki
                    #901
                    @wurzelfuchs
                    Den Fehler kannst du ignorieren, der kommt von einer fehlenden Definition im Admin.
                    https://github.com/ioBroker/adapter-react-v5/issues/195
                    Email Empfänger kann man aktuell nicht angeben, kannst du bitte auf Github eine entsprechende Feature Request aufmachen. Ich schaue dann mal wie ich das einbau, hab aktuell sehr wenig Zeit.
                    Spenden
                    • W Wurzelfuchs
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      #902
                      @wurzelfuchs
                      ist vor ein paar Minuten gefixt worden. Wenn admin >v6.13.21 verfügbar ist, sollte der Fehler nicht mehr erscheinen.
                      Spenden
                      W 1 Antwort Letzte Antwort
                      • T ticaki
                        @wurzelfuchs
                        W Offline
                        W Offline
                        Wurzelfuchs
                        #903
                        @ticaki Danke für die schnelle Rückmeldung!
                        • S Online
                          S Online
                          spike2
                          schrieb am zuletzt editiert von spike2
                          #904
                          @ticaki
                          Ich habe in der NewJson noch einige Parameter bei mir eingefügt, alle funktionieren bis auf die Handlungsanweisung (instruction).
                          So sieht der letze Teil der NewJson aus.
                          "Beschreibung": "${description}", "Handlungsanweisung": "${instruction"\}
                          Auszug der Json:
                          "Beschreibung":"Es tritt leichter Frost zwischen -3 °C und -5 °C auf.","Handlungsanweisung":"instruction"}]
                          Datenpunkt:
                          weather-warnings.0.provider.dwd.------------.formatedKeys.00.instruction
                          Hinweis auf mögliche Frostschäden.
                          Handlungsempfehlungen: ggf. Frostschutzmaßnahmen ergreifen
                          Hast du eine Idee, warum die Handlungsanweisung in der Json nicht gefüllt wird?
                          T T 2 Antworten Letzte Antwort
                          • S spike2
                            @ticaki
                            Auszug der Json:
                            Datenpunkt:
                            TT-Tom
                            #905
                            @spike2
                            Würde sagen deine Anführungszeichen sind falsch gesetzt, siehe dir das mal bei Beschreibung an.
                            Gruß Tom
                            Public Transport
                            NSPanel Adapter Wiki
                            • S spike2
                              @ticaki
                              Auszug der Json:
                              Datenpunkt:
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              #906
                              @spike2
                              Wie Tom geschrieben hat. "${token}" das \} gehört zum Json und nicht zum Token.
                              Spenden
                              • S Online
                                S Online
                                spike2
                                #907
                                Beide Varianten getestet, Fehlermeldung im Adapter:
                                [json] Json template has wrong formate. Conversion deactivated! template: NewJson
                                "Handlungsanweisung": "${instruction}" \}
                                "Handlungsanweisung": "${instruction}"\}
                                So steht es auch in der Doku drin :)
                                • S spike2
                                  T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  #908
                                  @spike2 sagte in Test Adapter Weather-Warnings:
                                  bitte das ganze template
                                  Spenden
                                  • T ticaki
                                    S Online
                                    S Online
                                    spike2
                                    #909
                                    @ticaki
                                    { "action": "${status}", "startdatum": "${startdate}", "start": "${starttime}", "enddatum": "${enddate}", "ende": "${endtime}", "type": "${warntypename}", "Stufe": "${warnlevelnumber}", "Beschreibung": "${description}", "Handlungsanweisung": "${instruction}" \}
                                    • S spike2
                                      @ticaki
                                      TT-Tom
                                      #910
                                      @spike2 schon mal ohne \ probiert?
                                      Gruß Tom
                                      Public Transport
                                      • S spike2
                                        @ticaki
                                        T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        #911
                                        @spike2
                                        Ich sehe keinen Fehler und bei mir geht es... mal alle "getauscht, bei mir waren da mal falsche drin. Wie auch immer die da hingekommen sind.
                                        Spenden
                                        • T TT-Tom
                                          T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          #912
                                          @tt-tom sagte in Test Adapter Weather-Warnings:
                                          das \ muß da hin
                                          Spenden
