  4. Harmony Adapter versagt seinen Dienst !
94 Beiträge 9 Kommentatoren 15.4k Aufrufe 6 Beobachtet
  • wendy2702W wendy2702
    @springreiter hast du das loggen der Instanz mal auf Debug gestellt und kannst das dann als Text hier in Code Tags posten.
    Den Hub mal neu gestartet?
    Springreiter
    @wendy2702
    2024-02-18 19:13:01.891 - info: host.iobroker instance system.adapter.harmony.0 started with pid 510833
    2024-02-18 19:13:02.739 - debug: harmony.0 (510833) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-02-18 19:13:02.772 - debug: harmony.0 (510833) Objects client ready ... initialize now
    2024-02-18 19:13:02.777 - debug: harmony.0 (510833) Objects create System PubSub Client
    2024-02-18 19:13:02.778 - debug: harmony.0 (510833) Objects create User PubSub Client
    2024-02-18 19:13:02.836 - debug: harmony.0 (510833) Objects client initialize lua scripts
    2024-02-18 19:13:02.840 - debug: harmony.0 (510833) Objects connected to redis: 127.0.0.1:9001
    2024-02-18 19:13:02.872 - debug: harmony.0 (510833) Redis States: Use Redis connection: 127.0.0.1:6379
    2024-02-18 19:13:02.877 - debug: harmony.0 (510833) States create System PubSub Client
    2024-02-18 19:13:02.877 - debug: harmony.0 (510833) States create User PubSub Client
    2024-02-18 19:13:02.882 - debug: harmony.0 (510833) States connected to redis: 127.0.0.1:6379
    2024-02-18 19:13:03.001 - info: harmony.0 (510833) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
    2024-02-18 19:13:03.015 - debug: harmony.0 (510833) [START] Subnet: 255.255.255.255, Discovery interval: 10000
    2024-02-18 19:13:03.026 - info: harmony.0 (510833) [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
    MOD EDIT: CODE TAGS Korrigiert
    wendy2702W FredFF 2 Antworten Letzte Antwort
    • S Springreiter
      @wendy2702
      armony.0
      2024-02-18 19:13:03.026	info	[DISCOVER] Searching for Harmony Hubs on 255.255.255.255
      harmony.0
      2024-02-18 19:13:03.015	debug	[START] Subnet: 255.255.255.255, Discovery interval: 10000
      harmony.0
      2024-02-18 19:13:03.001	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v18.19.1, js-controller: 5.0.17
      harmony.0
      2024-02-18 19:13:02.882	debug	States connected to redis: 127.0.0.1:6379
      harmony.0
      2024-02-18 19:13:02.877	debug	States create User PubSub Client
      harmony.0
      2024-02-18 19:13:02.877	debug	States create System PubSub Client
      harmony.0
      2024-02-18 19:13:02.872	debug	Redis States: Use Redis connection: 127.0.0.1:6379
      harmony.0
      2024-02-18 19:13:02.840	debug	Objects connected to redis: 127.0.0.1:9001
      harmony.0
      2024-02-18 19:13:02.836	debug	Objects client initialize lua scripts
      harmony.0
      2024-02-18 19:13:02.778	debug	Objects create User PubSub Client
      harmony.0
      2024-02-18 19:13:02.777	debug	Objects create System PubSub Client
      harmony.0
      2024-02-18 19:13:02.772	debug	Objects client ready ... initialize now
      harmony.0
      2024-02-18 19:13:02.739	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      harmony.0
      2024-02-18 19:12:59.322	info	terminating
      harmony.0
      2024-02-18 19:12:58.820	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      harmony.0
      2024-02-18 19:12:58.820	info	terminating
      CodierknechtC Offline
      Codierknecht
      @springreiter
      Die 3 Backticks für die Code-Tags müssen jeweils in eigenen Zeilen stehen.
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • S Springreiter
        @wendy2702
        wendy2702W Offline
        wendy2702W Offline
        @springreiter sagte in Harmony Adapter versagt seinen Dienst !:
        Was kommt nach den 10000msec im log ?
        S HomoranH 2 Antworten Letzte Antwort
          Springreiter
          @wendy2702 nichts mehr
          O 1 Antwort Letzte Antwort
            HomoranH Offline
            HomoranH Offline
            @wendy2702 sagte in Harmony Adapter versagt seinen Dienst !:
            @homoran nein- nichts
            • S Springreiter
              O Offline
              O Offline
              oFbEQnpoLKKl6mbY5e13
              @springreiter
              Hast du die IP deines Hubs mal in der Instanz hinzugefügt?
              Edit:
              Konfiguration Harmony Instanz
              S 2 Antworten Letzte Antwort
              • O oFbEQnpoLKKl6mbY5e13
                @springreiter
                Edit:
                Springreiter
                @ofbeqnpolkkl6mby5e13 hatte ich schon mal versucht, ohne Erfolg. Ich versuche es noch einmal, nach den ganzen Ergänzungen
                  @springreiter
                  Edit:
                  Springreiter
                  @ofbeqnpolkkl6mby5e13 nochmal versucht, keine Änderung
                  • S Springreiter
                    O Offline
                    O Offline
                    #66
                    @springreiter
                    Und du bist sicher, dass die IP korrekt ist?
                      @springreiter
                      Springreiter
                      #67
                      wendy2702W O 2 Antworten Letzte Antwort
                      • S Springreiter
                        wendy2702W Offline
                        wendy2702W Offline
                        #68
                        @springreiter Was kommt jetzt im log und welche Updates hast du denn gemacht?
                        Du hast auch geschrieben du hast Adapter gelöscht und neu Installiert, wirklich den Adapter oder nur die Instanz gelöscht?
                        Gerade mal bei mir geschaut, log sieht so aus wenn ich den HUB z.B. vom Strom nehme.
                        • S Springreiter
                          O Offline
                          O Offline
                          #69
                          @springreiter
                          Kannst du die IP-Adresse von deinem iobroker aus erreichen?
                            Springreiter
                            #70
                            @wendy2702
                            @wendy2702 said in Harmony Adapter versagt seinen Dienst !:
                            Instanz gelöscht, Adapter gelöscht- Adapter und Instanz installiert- keine Veränderungen
                            • S Springreiter
                              @wendy2702
                              wendy2702W Offline
                              wendy2702W Offline
                              #71
                              @springreiter Ich würde ehrlich gesagt immer noch vermuten das der HUB nicht erreichbar ist.
                              Wenn du den mal vom Netz nimmst, verschwindet er denn auch in der FB als aktives device?
                                @springreiter
                                Springreiter
                                #72
                                @ofbeqnpolkkl6mby5e13 der ping adapter sagt
                                • wendy2702W Offline
                                  wendy2702W Offline
                                  #73
                                  Wurde der IOB Server mal neu gestartet?
                                  HomoranH S 2 Antworten Letzte Antwort
                                    HomoranH Offline
                                    HomoranH Offline
                                    #74
                                    oder die Fritte?
                                    geht das Ganze nicht über UDP? Gab es da nicht irgendwelche Einschränkungen bezüglich Switche auf dem Weg?
                                      Springreiter
                                      #75
                                      @wendy2702 Stecker gezogen
                                        oder die Fritte?
                                        Springreiter
                                        #76
                                        @homoran dann hätte ich ja irgendetwas geändert haben müssen- definitiv nicht
                                        • S Springreiter
                                          O Offline
                                          O Offline
                                          #77
                                          @springreiter
                                          Sorry, falls du die Frage bereits zuvor beantwortet hast. Ist der iobroker im selben Subnetz?
